path: root/fs/ubifs/debug.h
2010-08-30UBIFS: introduce list sorting debugging checksArtem Bityutskiy
The UBIFS bug in the GC list sorting comparison functions inspired me to write internal debugging check functions which verify that the list of nodes is sorted properly. So, this patch implements 2 new debugging functions: o 'dbg_check_data_nodes_order()' - check order of data nodes list o 'dbg_check_nondata_nodes_order()' - check order of non-data nodes list The debugging functions are executed only if general UBIFS debugging checks are enabled. And they are compiled out if UBIFS debugging is disabled. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-09-15UBIFS: improve journal head debugging printsArtem Bityutskiy
Convert the journal head integer into the head name when printing debugging information. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-09-10UBIFS: add inode size debugging checkArtem Bityutskiy
Add one more check to UBIFS - a check that makes sure that there are no data nodes beyond inode size. And few commantaries fixes along the line. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Adrian Hunter <Adrian.Hunter@nokia.com>
2009-01-26UBIFS: add re-mount debugging checksArtem Bityutskiy
We observe space corrupted accounting when re-mounting. So add some debbugging checks to catch problems like this. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-12-03UBIFS: introduce LPT dump functionArtem Bityutskiy
2008-12-03UBIFS: add debugfs supportArtem Bityutskiy
We need to have a possibility to see various UBIFS variables and ask UBIFS to dump various information. Debugfs is what we need. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-12-03UBIFS: separate debugging fields outArtem Bityutskiy
Introduce a new data structure which contains all debugging stuff inside. This is cleaner than having debugging stuff directly in 'c'. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-09-30UBIFS: add more debugging messages for LPTAdrian Hunter
Also add debugging checks for LPT size and separate out c->check_lpt_free from unrelated bitfields. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-08-13UBIFS: improve arguments checking in debugging messagesArtem Bityutskiy
Use "if (0) printk()" construct in debugging print macros to make the debugging messages be checked even if debugging is off. This patch also removes some unneeded spaces and blank lines. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-07-15UBIFS: add new flash file systemArtem Bityutskiy
This is a new flash file system. See http://www.linux-mtd.infradead.org/doc/ubifs.html Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
