path: root/fs/ubifs
2014-01-23fs/ubifs: use rbtree postorder iteration helper instead of opencodingCody P Schafer
Use rbtree_postorder_for_each_entry_safe() to destroy the rbtree instead of opencoding an alternate postorder iteration that modifies the tree Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Michel Lespinasse <walken@google.com> Cc: Jan Kara <jack@suse.cz> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "All kinds of stuff this time around; some more notable parts: - RCU'd vfsmounts handling - new primitives for coredump handling - files_lock is gone - Bruce's delegations handling series - exportfs fixes plus misc stuff all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits) ecryptfs: ->f_op is never NULL locks: break delegations on any attribute modification locks: break delegations on link locks: break delegations on rename locks: helper functions for delegation breaking locks: break delegations on unlink namei: minor vfs_unlink cleanup locks: implement delegations locks: introduce new FL_DELEG lock flag vfs: take i_mutex on renamed file vfs: rename I_MUTEX_QUOTA now that it's not used for quotas vfs: don't use PARENT/CHILD lock classes for non-directories vfs: pull ext4's double-i_mutex-locking into common code exportfs: fix quadratic behavior in filehandle lookup exportfs: better variable name exportfs: move most of reconnect_path to helper function exportfs: eliminate unused "noprogress" counter exportfs: stop retrying once we race with rename/remove exportfs: clear DISCONNECTED on all parents sooner exportfs: more detailed comment for path_reconnect ...
2013-11-13Merge tag 'upstream-3.13-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull ubifs changes from Artem Bityutskiy: "Mostly fixes for the power cut emulation UBIFS mode, and only one functional change which fixes a return error code" * tag 'upstream-3.13-rc1' of git://git.infradead.org/linux-ubifs: UBIFS: correct data corruption range UBIFS: fix return code UBIFS: remove unnecessary code in ubifs_garbage_collect
2013-10-26UBIFS: correct data corruption rangeMats Kärrman
With power-cut emulation, it is possible that sometimes no data at all is corrupted and that confusing messages are printed due to errors in the computation of data corruption range. [1] The start of the range should be [0..len-1], not [0..len]. [2] The end of the range should always be at least 1 greater than the start. Signed-off-by: Mats Karrman <mats.karrman@tritech.se> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-10-26UBIFS: fix return codeWei Yongjun
Fix to return -ENOMEM in the kmalloc() and d_make_root() error handling case instead of 0, as done elsewhere in those functions. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-10-24ubifs: switch to %pdAl Viro
2013-10-22UBIFS: remove unnecessary code in ubifs_garbage_collectwang.bo116@zte.com.cn
In ubifs_garbage_collect,local variable "space_before" calculate twice. In fact, at the beginning of the loop, there is no need to calculate this variable. Calculate it before call "ubifs_garbage_collect_leb" is enough. This patch just remove the unnecessary calculate code. Signed-off-by: wang bo <wang.bo116@zte.com.cn> Acked-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-09-16Merge tag 'upstream-3.12-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull ubifs fix from Artem Bityutskiy: "Just one patch which fixes the power-cut recovery testing mode. I'll start using a single UBI/UBIFS tree instead of 2 trees from now on. So in the future you'll get 1 small pull request instead of 2 tiny ones" * tag 'upstream-3.12-rc1' of git://git.infradead.org/linux-ubifs: UBIFS: remove invalid warn msg with tst_recovery enabled
2013-09-10fs: convert fs shrinkers to new scan/count APIDave Chinner
Convert the filesystem shrinkers to use the new API, and standardise some of the behaviours of the shrinkers at the same time. For example, nr_to_scan means the number of objects to scan, not the number of objects to free. I refactored the CIFS idmap shrinker a little - it really needs to be broken up into a shrinker per tree and keep an item count with the tree root so that we don't need to walk the tree every time the shrinker needs to count the number of objects in the tree (i.e. all the time under memory pressure). [glommer@openvz.org: fixes for ext4, ubifs, nfs, cifs and glock. Fixes are needed mainly due to new code merged in the tree] [assorted fixes folded in] Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Glauber Costa <glommer@openvz.org> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Arve Hjønnevåg <arve@android.com> Cc: Carlos Maiolino <cmaiolino@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: David Rientjes <rientjes@google.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: J. Bruce Fields <bfields@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Jerome Glisse <jglisse@redhat.com> Cc: John Stultz <john.stultz@linaro.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Kent Overstreet <koverstreet@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-08-16UBIFS: remove invalid warn msg with tst_recovery enabledMats Kärrman
2013-07-05Merge tag 'upstream-3.11-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull ubifs fix from Artem Bityutskiy: "Only a single patch which fixes a message" * tag 'upstream-3.11-rc1' of git://git.infradead.org/linux-ubifs: UBIFS: correct mount message
2013-07-02Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 update from Ted Ts'o: "Lots of bug fixes, cleanups and optimizations. In the bug fixes category, of note is a fix for on-line resizing file systems where the block size is smaller than the page size (i.e., file systems 1k blocks on x86, or more interestingly file systems with 4k blocks on Power or ia64 systems.) In the cleanup category, the ext4's punch hole implementation was significantly improved by Lukas Czerner, and now supports bigalloc file systems. In addition, Jan Kara significantly cleaned up the write submission code path. We also improved error checking and added a few sanity checks. In the optimizations category, two major optimizations deserve mention. The first is that ext4_writepages() is now used for nodelalloc and ext3 compatibility mode. This allows writes to be submitted much more efficiently as a single bio request, instead of being sent as individual 4k writes into the block layer (which then relied on the elevator code to coalesce the requests in the block queue). Secondly, the extent cache shrink mechanism, which was introduce in 3.9, no longer has a scalability bottleneck caused by the i_es_lru spinlock. Other optimizations include some changes to reduce CPU usage and to avoid issuing empty commits unnecessarily." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (86 commits) ext4: optimize starting extent in ext4_ext_rm_leaf() jbd2: invalidate handle if jbd2_journal_restart() fails ext4: translate flag bits to strings in tracepoints ext4: fix up error handling for mpage_map_and_submit_extent() jbd2: fix theoretical race in jbd2__journal_restart ext4: only zero partial blocks in ext4_zero_partial_blocks() ext4: check error return from ext4_write_inline_data_end() ext4: delete unnecessary C statements ext3,ext4: don't mess with dir_file->f_pos in htree_dirblock_to_tree() jbd2: move superblock checksum calculation to jbd2_write_superblock() ext4: pass inode pointer instead of file pointer to punch hole ext4: improve free space calculation for inline_data ext4: reduce object size when !CONFIG_PRINTK ext4: improve extent cache shrink mechanism to avoid to burn CPU time ext4: implement error handling of ext4_mb_new_preallocation() ext4: fix corruption when online resizing a fs with 1K block size ext4: delete unused variables ext4: return FIEMAP_EXTENT_UNKNOWN for delalloc extents jbd2: remove debug dependency on debug_fs and update Kconfig help text jbd2: use a single printk for jbd_debug() ...
2013-06-29[readdir] convert ubifsAl Viro
2013-06-29UBIFS: fix a horrid bugArtem Bityutskiy
Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are in the middle of 'ubifs_readdir()'. This means that 'file->private_data' can be freed while 'ubifs_readdir()' uses it, and this is a very bad bug: not only 'ubifs_readdir()' can return garbage, but this may corrupt memory and lead to all kinds of problems like crashes an security holes. This patch fixes the problem by using the 'file->f_version' field, which '->llseek()' always unconditionally sets to zero. We set it to 1 in 'ubifs_readdir()' and whenever we detect that it became 0, we know there was a seek and it is time to clear the state saved in 'file->private_data'. I tested this patch by writing a user-space program which runds readdir and seek in parallell. I could easily crash the kernel without these patches, but could not crash it with these patches. Cc: stable@vger.kernel.org Reported-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29UBIFS: prepare to fix a horrid bugArtem Bityutskiy
Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are in the middle of 'ubifs_readdir()'. First of all, this means that 'file->private_data' can be freed while 'ubifs_readdir()' uses it. But this particular patch does not fix the problem. This patch is only a preparation, and the fix will follow next. In this patch we make 'ubifs_readdir()' stop using 'file->f_pos' directly, because 'file->f_pos' can be changed by '->llseek()' at any point. This may lead 'ubifs_readdir()' to returning inconsistent data: directory entry names may correspond to incorrect file positions. So here we introduce a local variable 'pos', read 'file->f_pose' once at very the beginning, and then stick to 'pos'. The result of this is that when 'ubifs_dir_llseek()' changes 'file->f_pos' while we are in the middle of 'ubifs_readdir()', the latter "wins". Cc: stable@vger.kernel.org Reported-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-21mm: change invalidatepage prototype to accept lengthLukas Czerner
Currently there is no way to truncate partial page where the end truncate point is not at the end of the page. This is because it was not needed and the functionality was enough for file system truncate operation to work properly. However more file systems now support punch hole feature and it can benefit from mm supporting truncating page just up to the certain point. Specifically, with this functionality truncate_inode_pages_range() can be changed so it supports truncating partial page at the end of the range (currently it will BUG_ON() if 'end' is not at the end of the page). This commit changes the invalidatepage() address space operation prototype to accept range to be invalidated and update all the instances for it. We also change the block_invalidatepage() in the same way and actually make a use of the new length argument implementing range invalidation. Actual file system implementations will follow except the file systems where the changes are really simple and should not change the behaviour in any way .Implementation for truncate_page_range() which will be able to accept page unaligned ranges will follow as well. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com>
2013-05-10UBIFS: correct mount messageRichard Genoud
When mounting an UBIFS R/W volume, we have the message: UBIFS: mounted UBI device 0, volume 1, name "rootfs"(null) With this patch, we'll have: UBIFS: mounted UBI device 0, volume 1, name "rootfs" Which is, I think, what was intended. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Cc: stable@vger.kernel.org [v3.7+] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-14UBIFS: make space fixup work in the remount caseArtem Bityutskiy
The UBIFS space fixup is a useful feature which allows to fixup the "broken" flash space at the time of the first mount. The "broken" space is usually the result of using a "dumb" industrial flasher which is not able to skip empty NAND pages and just writes all 0xFFs to the empty space, which has grave side-effects for UBIFS when UBIFS trise to write useful data to those empty pages. The fix-up feature works roughly like this: 1. mkfs.ubifs sets the fixup flag in UBIFS superblock when creating the image (see -F option) 2. when the file-system is mounted for the first time, UBIFS notices the fixup flag and re-writes the entire media atomically, which may take really a lot of time. 3. UBIFS clears the fixup flag in the superblock. This works fine when the file system is mounted R/W for the very first time. But it did not really work in the case when we first mount the file-system R/O, and then re-mount R/W. The reason was that we started the fixup procedure too late, which we cannot really do because we have to fixup the space before it starts being used. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Reported-by: Mark Jackson <mpfj-list@mimc.co.uk> Cc: stable@vger.kernel.org # 3.0+
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26Merge tag 'upstream-3.9-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull ubifs updates from Artem Bityutskiy: "It's been quite silent and we have only a couple of bug-fixes for the orphans handling code plus one cosmetic change." * tag 'upstream-3.9-rc1' of git://git.infradead.org/linux-ubifs: UBIFS: fix double free of ubifs_orphan objects UBIFS: fix use of freed ubifs_orphan objects UBIFS: rename random32() to prandom_u32()
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21ubifs: wait for page writeback to provide stable pagesJan Kara
When stable pages are required, we have to wait if the page is just going to disk and we want to modify it. Add proper callback to ubifs_vm_page_mkwrite(). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-04UBIFS: fix double free of ubifs_orphan objectsAdam Thomas
The last orphan in the dnext list has its dnext set to NULL. Because of that, ubifs_delete_orphan assumes that it is not on the dnext list and frees it immediately instead ignoring it as a second delete. The orphan is later freed again by erase_deleted. This change adds an explicit flag to ubifs_orphan indicating whether it is pending delete. Signed-off-by: Adam Thomas <adamthomas1111@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: stable@vger.kernel.org
2013-02-04UBIFS: fix use of freed ubifs_orphan objectsAdam Thomas
The last orphan in the cnext list has its cnext set to NULL. Because of that, ubifs_delete_orphan assumes that it is not on the cnext list and frees it immediately instead of adding it to the dnext list. The freed orphan is later modified by write_orph_node. This can cause various inconsistencies including directory entries that cannot be removed and this error: UBIFS error (pid 20685): layout_cnodes: LPT out of space at LEB 14:129009 needing 17, done_ltab 1, done_lsave 1 This is a regression introduced by "7074e5eb UBIFS: remove invalid reference to list iterator variable". This change adds an explicit flag to ubifs_orphan indicating whether it is pending commit. Signed-off-by: Adam Thomas <adamthomas1111@gmail.com> Reviewed-by: Adrian Hunter <adrian.hunter@intel.com> Cc: stable@vger.kernel.org # v3.6+ Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-01-15UBIFS: rename random32() to prandom_u32()Akinobu Mita
Use more preferable function name which implies using a pseudo-random number generator. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-12-17ubifs: use prandom_bytesAkinobu Mita
This also converts filling memory loop to use memset. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: David Laight <david.laight@aculab.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Michel Lespinasse <walken@google.com> Cc: Robert Love <robert.w.love@intel.com> Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17lseek: the "whence" argument is called "whence"Andrew Morton
But the kernel decided to call it "origin" instead. Fix most of the sites. Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-26UBIFS: fix mounting problems after power cutsArtem Bityutskiy
This is a bugfix for a problem with the following symptoms: 1. A power cut happens 2. After reboot, we try to mount UBIFS 3. Mount fails with "No space left on device" error message UBIFS complains like this: UBIFS error (pid 28225): grab_empty_leb: could not find an empty LEB The root cause of this problem is that when we mount, not all LEBs are categorized. Only those which were read are. However, the 'ubifs_find_free_leb_for_idx()' function assumes that all LEBs were categorized and 'c->freeable_cnt' is valid, which is a false assumption. This patch fixes the problem by teaching 'ubifs_find_free_leb_for_idx()' to always fall back to LPT scanning if no freeable LEBs were found. This problem was reported by few people in the past, but Brent Taylor was able to reproduce it and send me a flash image which cannot be mounted, which made it easy to hunt the bug. Kudos to Brent. Reported-by: Brent Taylor <motobud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: stable@vger.kernel.org
2012-10-26UBIFS: introduce categorized lprops counterArtem Bityutskiy
This commit is a preparation for a subsequent bugfix. We introduce a counter for categorized lprops. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: stable@vger.kernel.org
2012-10-09mm: kill vma flag VM_CAN_NONLINEARKonstantin Khlebnikov
Move actual pte filling for non-linear file mappings into the new special vma operation: ->remap_pages(). Filesystems must implement this method to get non-linear mapping support, if it uses filemap_fault() then generic_file_remap_pages() can be used. Now device drivers can implement this method and obtain nonlinear vma support. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> #arch/tile Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-02Merge tag 'upstream-3.7-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull ubifs changes from Artem Bityutskiy: "No big changes for 3.7 in UBIFS: - Error reporting and debug printing improvements - Power cut emulation fixes - Minor cleanups" Fix trivial conflict in fs/ubifs/debug.c due to the user namespace changes. * tag 'upstream-3.7-rc1' of git://git.infradead.org/linux-ubifs: UBIFS: print less UBIFS: use pr_ helper instead of printk UBIFS: comply with coding style UBIFS: use __aligned() attribute UBIFS: remove __DATE__ and __TIME__ UBIFS: fix power cut emulation for mtdram UBIFS: improve scanning debug output UBIFS: always print full error reports UBIFS: print PID in debug messages
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-21userns: Convert ubifs to use kuid/kgidEric W. Biederman
Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-08-31UBIFS: print lessArtem Bityutskiy
UBIFS currently prints a lot of information when it mounts a volume, which bothers some people. Make it less chatty - print only important information by default. Get rid of 'dbg_msg()' macro completely. Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-31UBIFS: use pr_ helper instead of printkArtem Bityutskiy
Use 'pr_err()' instead of 'printk(KERN_ERR', etc. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-31UBIFS: comply with coding styleArtem Bityutskiy
Join all the split printk lines in order to stop checkpatch complaining. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-31UBIFS: use __aligned() attributeArtem Bityutskiy
.. instead of __attribute__((aligned())). Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-31UBIFS: remove __DATE__ and __TIME__Jiri Slaby
This tag is useless and it breaks automatic builds. It causes rebuilds for packages that depend on kernel for no real reason. Further, quoting Michal, who removed most of the users already: The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-31UBIFS: fix power cut emulation for mtdramArtem Bityutskiy
The power cut emulation did not work correctly because we corrupted more than one max. I/O unit in the buffer and then wrote the entire buffer. This lead to recovery errors because UBIFS complained about corrupted free space. And this was easily reproducible on mtdram because max. write size is very small there (64 bytes), and we could easily have a 1KiB buffer, corrupt 128 bytes there, and then write the entire buffer. The fix is to corrupt max. write size bytes at most, and write only up to the last corrupted max. write size chunk, not the entire buffer. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-23UBIFS: improve scanning debug outputArtem Bityutskiy
Include LEB number and offset in scanning debugging output. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-22UBIFS: always print full error reportsArtem Bityutskiy
Even when we are emulating power cuts, otherwise it is difficult to investigate failures during emulated power cuts testing. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-22UBIFS: print PID in debug messagesArtem Bityutskiy
2012-08-22UBIFS: fix error messages spellingArtem Bityutskiy
Corruptio -> corruption. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-22UBIFS: fix complaints about too small debug buffer sizeArtem Bityutskiy
When debugging is enabled, we use a temporary on-stack buffer for formatting the key strings like "(11368871, direntry, 0xcd0750)". The buffer size is 32 bytes and sometimes it is not enough to fit the key string - e.g., when inode numbers are high. This is not fatal, but the key strings are incomplete and UBIFS complains like this: UBIFS assert failed in dbg_snprintf_key at 137 (pid 1) This is a regression caused by "515315a UBIFS: fix key printing". Fix the issue by increasing the buffer to 48 bytes. Reported-by: Michael Hench <michaelhench@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Tested-by: Michael Hench <michaelhench@gmail.com> Cc: stable@vger.kernel.org [v3.3+]
2012-08-21UBIFS: fix replay regressionArtem Bityutskiy
Commit "d51f17e UBIFS: simplify reply code a bit" introduces a bug with the following symptoms: UBIFS error (pid 1): replay_log_leb: first CS node at LEB 3:0 has wrong commit number 0 expected 1 The issue is that we start replaying the log from UBIFS_LOG_LNUM instead of c->lhead_lnum. This patch fixes that. Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-21UBIFS: fix crash on error pathArtem Bityutskiy
This patch fixes a regression introduced by "4994297 UBIFS: make ubifs_lpt_init clean-up in case of failure" which I've hit while running the 'integck -p' test. When remount the file-system from R/O mode to R/W mode and 'lpt_init_wr()' fails, we free _all_ LPT resources by calling 'ubifs_lpt_free(c, 0)', even those needed for R/O mode. This leads to subsequent crashes, e.g., if we try to unmount the file-system. Cc: stable@vger.kernel.org [v3.5+] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
