path: root/fs/udf/dir.c
2011-01-06udf: Remove unnecessary bkl usagesAlessio Igor Bogani
The udf_readdir(), udf_lookup(), udf_create(), udf_mknod(), udf_mkdir(), udf_rmdir(), udf_link(), udf_get_parent() and udf_unlink() seems already adequately protected by i_mutex held by VFS invoking calls. The udf_rename() instead should be already protected by lock_rename again by VFS. The udf_ioctl(), udf_fill_super() and udf_evict_inode() don't requires any further protection. This work was supported by a hardware donation from the CE Linux Forum. Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs/: do not fallback to default_llseek() when readdir() uses BKLjan Blunck
Do not use the fallback default_llseek() if the readdir operation of the filesystem still uses the big kernel lock. Since llseek() modifies file->f_pos of the directory directly it may need locking to not confuse readdir which usually uses file->f_pos directly as well Since the special characteristics of the BKL (unlocked on schedule) are not necessary in this case, the inode mutex can be used for locking as provided by generic_file_llseek(). This is only possible since all filesystems, except reiserfs, either use a directory as a flat file or with disk address offsets. Reiserfs on the other hand uses a 32bit hash off the filename as the offset so generic_file_llseek() can get used as well since the hash is always smaller than sb->s_maxbytes (= (512 << 32) - blocksize). Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Anders Larsen <al@alarsen.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-05udf: BKL ioctl pushdownJohn Kacur
Convert udf_ioctl to an unlocked_ioctl and push the BKL down into it. Signed-off-by: John Kacur <jkacur@redhat.com Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-03sanitize const/signedness for udfAl Viro
2009-06-11switch udf to simple_fsync()Al Viro
2009-04-02Fix the udf code not to pass structs on stack where possible.Pekka Enberg
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-02Remove struct typedefs from fs/udf/ecma_167.h et al.Pekka Enberg
2008-04-17udf: Remove declarations of arrays of size UDF_NAME_LEN (256 bytes)Jan Kara
There are several places in UDF where we declared temporary arrays of UDF_NAME_LEN bytes on stack. This is not nice to stack usage so this patch changes those places to use kmalloc() instead. Also clean up bail-out paths in those functions when we are changing them. Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: kill useless file header comments for vfs method implementationsChristoph Hellwig
There's not need to document vfs method invocation rules, we have Documentation/filesystems/vfs.txt and Documentation/filesystems/Locking for that. Also a lot of these comments where either plain wrong or horrible out of date. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2008-02-13udf: fix directory offset handlingJan Kara
Patch cleaning up UDF directory offset handling missed modifications in dir.c (because I've submitted an old version :(). Fix it. Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com> Tested-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: remove wrong prototype of udf_readdirMarcin Slusarz
sparse generated: fs/udf/dir.c:78:5: warning: symbol 'udf_readdir' was not declared. Should it be static? there are 2 different prototypes of udf_readdir - remove them and move code around to make it still compile Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: cache struct udf_inode_infoMarcin Slusarz
cache UDF_I(struct inode *) return values when there are at least 2 uses in one function Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: remove UDF_I_* macros and open code themMarcin Slusarz
2007-07-21UDF: coding style conversion - lindent fixupsCyrill Gorcunov
This patch fixes up sources after conversion by Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19UDF: coding style conversion - lindentCyrill Gorcunov
This patch converts UDF coding style to kernel coding style using Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: use get_bh()Jan Kara
Make UDF use get_bh() instead of directly accessing b_count and use brelse() instead of udf_release_data() which does just brelse()... Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08UDF: introduce struct extent_positionJan Kara
Introduce a structure extent_position to store a position of an extent and the corresponding buffer_head in one place. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: use sector_t and loff_t for file offsetsJan Kara
Use sector_t and loff_t for file offsets in UDF filesystem. Otherwise an overflow may occur for long files. Also make inode_bmap() return offset in the extent in number of blocks instead of number of bytes - for most callers this is more convenient. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert udfJosef Sipek
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03remove pointers to the defunct UDF mailing listAdrian Bunk
This patch removes pointers to the defunct UDF mailing list. Signed-off-by: Adrian Bunk <bunk@stusta.de>
