path: root/fs/udf/truncate.c
2011-02-23udf: Convert UDF to new truncate calling sequenceJan Kara
Use new truncation sequence in UDF and fix up error handling in the code. Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-02Fix the udf code not to pass structs on stack where possible.Pekka Enberg
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-02Remove struct typedefs from fs/udf/ecma_167.h et al.Pekka Enberg
2008-04-17udf: truncate: create function for updating of Allocation Ext Descriptormarcin.slusarz@gmail.com
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: simple cleanup of truncate.cmarcin.slusarz@gmail.com
- remove one indentation level by little code reorganization - convert "if (smth) BUG();" to "BUG_ON(smth);" Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: move headers out include/linux/Christoph Hellwig
There's really no reason to keep udf headers in include/linux as they're not used by anything but fs/udf/. This patch merges most of include/linux/udf_fs_i.h into fs/udf/udf_i.h, include/linux/udf_fs_sb.h into fs/udf/udf_sb.h and include/linux/udf_fs.h into fs/udf/udfdecl.h. The only thing remaining in include/linux/ is a stub of udf_fs_i.h defining the four user-visible udf ioctls. It's also moved from unifdef-y to headers-y because it can be included unconditionally now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2008-02-08udf: cache struct udf_inode_infoMarcin Slusarz
cache UDF_I(struct inode *) return values when there are at least 2 uses in one function Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: remove UDF_I_* macros and open code themMarcin Slusarz
2008-02-08udf: fix coding styleMarcin Slusarz
fix coding style errors found by checkpatch: - assignments in if conditions - braces {} around single statement blocks - no spaces after commas - printks without KERN_* - lines longer than 80 characters - spaces between "type *" and variable name before: 192 errors, 561 warnings, 8987 lines checked after: 1 errors, 38 warnings, 9468 lines checked Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: remove some ugly macrosMarcin Slusarz
remove macros: - UDF_SB_PARTMAPS - UDF_SB_PARTTYPE - UDF_SB_PARTROOT - UDF_SB_PARTLEN - UDF_SB_PARTVSN - UDF_SB_PARTNUM - UDF_SB_TYPESPAR - UDF_SB_TYPEVIRT - UDF_SB_PARTFUNC - UDF_SB_PARTFLAGS - UDF_SB_VOLIDENT - UDF_SB_NUMPARTS - UDF_SB_PARTITION - UDF_SB_SESSION - UDF_SB_ANCHOR - UDF_SB_LASTBLOCK - UDF_SB_LVIDBH - UDF_SB_LVID - UDF_SB_UMASK - UDF_SB_GID - UDF_SB_UID - UDF_SB_RECORDTIME - UDF_SB_SERIALNUM - UDF_SB_UDFREV - UDF_SB_FLAGS - UDF_SB_VAT - UDF_UPDATE_UDFREV - UDF_SB_FREE and open code them convert UDF_SB_LVIDIU macro to udf_sb_lvidiu function rename some struct udf_sb_info fields: - s_volident to s_volume_ident - s_lastblock to s_last_block - s_lvidbh to s_lvid_bh - s_recordtime to s_record_time - s_serialnum to s_serial_number; - s_vat to s_vat_inode; Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Cc: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21UDF: coding style conversion - lindent fixupsCyrill Gorcunov
This patch fixes up sources after conversion by Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19UDF: coding style conversion - lindentCyrill Gorcunov
This patch converts UDF coding style to kernel coding style using Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16udf: fix possible leakage of blocksJan Kara
We have to take care that when we call udf_discard_prealloc() from udf_clear_inode() we have to write inode ourselves afterwards (otherwise, some changes might be lost leading to leakage of blocks, use of free blocks or improperly aligned extents). Also udf_discard_prealloc() does two different things - it removes preallocated blocks and truncates the last extent to exactly match i_size. We move the latter functionality to udf_truncate_tail_extent(), call udf_discard_prealloc() when last reference to a file is dropped and call udf_truncate_tail_extent() when inode is being removed from inode cache (udf_clear_inode() call). We cannot call udf_truncate_tail_extent() earlier as subsequent open+write would find the last block of the file mapped and happily write to the end of it, although the last extent says it's shorter. [akpm@linux-foundation.org: Make checkpatch.pl happier] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Eric Sandeen <sandeen@sandeen.net> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: support files larger than 1GJan Kara
Make UDF work correctly for files larger than 1GB. As no extent can be longer than (1<<30)-blocksize bytes, we have to create several extents if a big hole is being created. As a side-effect, we now don't discard preallocated blocks when creating a hole. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: add assertionsJan Kara
Add a few assertions into udf_discard_prealloc() to check that the file is sane (mostly helps debugging further patches ;). Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: use get_bh()Jan Kara
Make UDF use get_bh() instead of directly accessing b_count and use brelse() instead of udf_release_data() which does just brelse()... Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08UDF: introduce struct extent_positionJan Kara
Introduce a structure extent_position to store a position of an extent and the corresponding buffer_head in one place. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: use sector_t and loff_t for file offsetsJan Kara
Use sector_t and loff_t for file offsets in UDF filesystem. Otherwise an overflow may occur for long files. Also make inode_bmap() return offset in the extent in number of blocks instead of number of bytes - for most callers this is more convenient. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-08-22Fix possible UDF deadlock and memory corruption (CVE-2006-4145)Jan Kara
UDF code is not really ready to handle extents larger that 1GB. This is the easy way to forbid creating those. Also truncation code did not count with the case when there are no extents in the file and we are extending the file. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-03remove pointers to the defunct UDF mailing listAdrian Bunk
This patch removes pointers to the defunct UDF mailing list. Signed-off-by: Adrian Bunk <bunk@stusta.de>
