path: root/fs/ufs/ufs.h
2011-03-02ufs: remove the BKLArnd Bergmann
This introduces a new per-superblock mutex in UFS to replace the big kernel lock. I have been careful to avoid nested calls to lock_ufs and to get the lock order right with respect to other mutexes, in particular lock_super. I did not make any attempt to prove that the big kernel lock is not needed in a particular place in the code, which is very possible. The mutex has a significant performance impact, so it is only used on SMP or PREEMPT configurations. As Nick Piggin noticed, any allocation inside of the lock may end up deadlocking when we get to ufs_getfrag_block in the reclaim task, so we now use GFP_NOFS. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Nick Bowler <nbowler@elliptictech.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Nick Piggin <npiggin@gmail.com>
2010-08-09switch ufs to ->evict_inode()Al Viro
2010-05-21ufs: add ufs speciffic ->setattr callDmitry Monakhov
generic setattr not longer responsible for quota transfer. use ufs_setattr for all ufs's inodes. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-03sanitize const/signedness of ufs a bitAl Viro
2009-12-16ufs: pass qstr instead of dentry where necessary for NFSAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11switch ufs to simple_fsync()Al Viro
2009-05-09switch ufs directories to ufs_sync_file()Al Viro
2009-03-27ufs: don't truncate longer ufs2 fast symlinksDuane Griffin
ufs2 fast symlinks can be twice as long as ufs ones, however the code was using the ufs size in various places. Fix that so ufs2 symlinks over 60 characters aren't truncated. Note that we copy the entire area instead of using the maxsymlinklen field from the superblock. This way we will be more robust against corruption (of the superblock). While we are at it, use memcpy instead of open-coding it with for loops. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-13ufs: remove unneeded ufs_put_inode prototypeChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ufs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop UFS from using iget() and read_inode()David Howells
Stop the UFS filesystem from using iget() and read_inode(). Replace ufs_read_inode() with ufs_iget(), and call that instead of iget(). ufs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. ufs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: move non-layout parts of ufs_fs.h to fs/ufs/Christoph Hellwig
Move prototypes and in-core structures to fs/ufs/ similar to what most other filesystems already do. I made little modifications: move also ufs debug macros and mount options constants into fs/ufs/ufs.h, this stuff also private for ufs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
