path: root/fs/ufs
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] ufs: truncate correctionEvgeniy Dushistov
1) When we allocated last fragment in ufs_truncate, we read page, check if block mapped to address, and if not trying to allocate it. This is wrong behaviour, fragment may be NOT allocated, but mapped, this happened because of "block map" function not checked allocated fragment or not, it just take address of the first fragment in the block, add offset of fragment and return result, this is correct behaviour in almost all situation except call from ufs_truncate. 2) Almost all implementation of UFS, which I can investigate have such "defect": if you have full disk, and try truncate file, for example 3GB to 2MB, and have hole in this region, truncate return -ENOSPC. I tried evade from this problem, but "block allocation" algorithm is tied to right value of i_lastfrag, and fix of this corner case may slow down of ordinaries scenarios, so this patch makes behavior of "truncate" operations similar to what other UFS implementations do. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] ufs: write to hole in big fileEvgeniy Dushistov
On UFS, this scenario: open(O_TRUNC) lseek(1024 * 1024 * 80) write("A") lseek(1024 * 2) write("A") may cause access to invalid address. This happened because of "goal" is calculated in wrong way in block allocation path, as I see this problem exists also in 2.4. We use construction like this i_data[lastfrag], i_data array of pointers to direct blocks, indirect and so on, it has ceratain size ~20 elements, and lastfrag may have value for example 40000. Also this patch fixes related to handling such scenario issues, wrong zeroing metadata, in case of block(not fragment) allocation, and wrong goal calculation, when we allocate block Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] ufs: handle truncated pagesEvgeniy Dushistov
ufs_get_locked_page is called twice in ufs code, one time in ufs_truncate path(we allocated last block), and another time when fragments are reallocated. In ideal world in the second case on allocation/free block layer we should not know that things like `truncate' exists, but now with such crutch like ufs_get_locked_page we can (or should?) skip truncated pages. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] ufs: ufs_get_locked_page() race fixEvgeniy Dushistov
As discussed earlier: http://lkml.org/lkml/2006/6/28/136 this patch fixes such issue: `ufs_get_locked_page' takes page from cache after that `vmtruncate' takes page and deletes it from cache `ufs_get_locked_page' locks page, and reports about EIO error. Also because of find_lock_page always return valid page or NULL, we have no need to check it if page not NULL. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] ufs: remove incorrect unlock_kernel from failure path in ufs_symlink()Josh Triplett
ufs_symlink, in one of its error paths, calls unlock_kernel without ever having called lock_kernel(); fix this by creating and jumping to a new label out_notlocked rather than the out label used after calling lock_kernel(). Signed-off-by: Josh Triplett <josh@freedesktop.org> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate the quota codeArjan van de Ven
The quota code plays interesting games with the lock ordering; to quote Jan: | i_mutex of inode containing quota file is acquired after all other | quota locks. i_mutex of all other inodes is acquired before quota | locks. Quota code makes sure (by resetting inode operations and | setting special flag on inode) that noone tries to enter quota code | while holding i_mutex on a quota file... The good news is that all of this special case i_mutex grabbing happens in the (per filesystem) low level quota write function. For this special case we need a new I_MUTEX_* nesting level, since this just entirely outside any of the regular VFS locking rules for i_mutex. I trust Jan on his blue eyes that this is not ever going to deadlock; and based on that the patch below is what it takes to inform lockdep of these very interesting new locking rules. The new locking rule for the I_MUTEX_QUOTA nesting level is that this is the deepest possible level of nesting for i_mutex, and that this only should be used in quota write (and possibly read) function of filesystems. This makes the lock ordering of the I_MUTEX_* levels: I_MUTEX_PARENT -> I_MUTEX_CHILD -> I_MUTEX_NORMAL -> I_MUTEX_QUOTA Has no effect on non-lockdep kernels. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] ufs: truncate should allocate block for last byteEvgeniy Dushistov
This patch fixes buggy behaviour of UFS in such kind of scenario: open(, O_TRUNC...) ftruncate(, 1024) ftruncate(, 0) Such a scenario causes ufs_panic and remount read-only. This happen because of according to specification UFS should always allocate block for last byte, and many parts of our implementation rely on this, but `ufs_truncate' doesn't care about this. To make possible return error code and to know about old size, this patch removes `truncate' from ufs inode_operations and uses `setattr' method to call ufs_truncate. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] ufs: printk() fixAndrew Morton
fs/ufs/inode.c: In function `ufs_frag_map': fs/ufs/inode.c:101: warning: long long unsigned int format, u64 arg (arg 4) fs/ufs/inode.c: In function `ufs_getfrag_block': fs/ufs/inode.c:432: warning: long long unsigned int format, u64 arg (arg 2) Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] ufs: ufs_read_inode cleanupEvgeniy Dushistov
Add missed ufsi->i_dir_start_lookup initialization in ufs_read_inode in UFS2 case. Also it cleans ufs_read_inode function to prevent such kind of situation in the future: it move depend on UFS type parts of code into separate functions and leaves in ufs_read_inode only generic code. It cleans code and avoids duplication. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fs/ufs/inode.c: make 2 functions staticAdrian Bunk
Make two needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: ubh_ll_rw_block cleanupEvgeniy Dushistov
In ufs code there is function: ubh_ll_rw_block, it has parameter how many ufs_buffer_head it should handle, but it always called with "1" on the place of this parameter. This patch removes unused parameter of "ubh_ll_wr_block". Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: make fsck -f happyEvgeniy Dushistov
ufs super block contains some statistic about file systems, like amount of directories, free blocks, inodes and so on. UFS1 hold this information in one location and uses 32bit integers for such information, UFS2 hold statistic in another location and uses 64bit integers. There is transition variant, if UFS1 has type 44BSD and flags field in super block has some special value this mean that we work with statistic like UFS2 does. and this also means that nobody care about old(UFS1) statistic. So if start fsck against such file system, after usage linux ufs driver, it found error: at now only UFS1 like statistic is updated. This patch should fix this. Also it contains some minor cleanup: CodingSytle and remove unused variables. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: fsync implementationEvgeniy Dushistov
Presently ufs doesn't support "fsync", this make some applications unhappy, for example vim. This patch fixes this situation. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: one way to access super blockEvgeniy Dushistov
Super block of UFS usually has size >512, because of fragment size may be 512, this cause some problems. Currently, there are two methods to work with ufs super block: 1) split structure which describes ufs super blocks into structures with size <=512 2) use one structure which describes ufs super block, and hope that array of "buffer_head" which holds "super block", has such construction: bh[n]->b_data + bh[n]->b_size == bh[n + 1]->b_data The second variant may cause some problems in the future, and usage of two variants cause unnecessary code duplication. This patch remove the second variant. Also patch contains some CodingStyle fixes. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: missed brelse and wrong baseblkEvgeniy Dushistov
This patch fixes two bugs, which introduced by previous patches: 1) Missed "brelse" 2) Sometimes "baseblk" may be wrongly calculated, if i_size is equal to zero, which lead infinite cycle in "mpage_writepages". Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: printk warning fixesAndrew Morton
fs/ufs/super.c: In function `ufs_print_super_stuff': fs/ufs/super.c:103: warning: unsigned int format, different type arg (arg 2) fs/ufs/super.c: In function `ufs2_print_super_stuff': fs/ufs/super.c:147: warning: unsigned int format, different type arg (arg 2) fs/ufs/super.c: In function `ufs_print_cylinder_stuff': fs/ufs/super.c:175: warning: unsigned int format, different type arg (arg 2) Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: zero metadataEvgeniy Dushistov
Presently if we allocate several "metadata" blocks (pointers to indirect blocks for example), we fill with zeroes only the first block. This cause some problems in "truncate" function. Also this patch remove some unused arguments from several functions and add comments. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: unlock_super without lockEvgeniy Dushistov
ufs_free_blocks function looks now in so way: if (err) goto failed; lock_super(); failed: unlock_super(); So if error happen we'll unlock not locked super. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: i_blocks wrong countEvgeniy Dushistov
At now UFS code uses DQUOT_* mechanism, but it also update inode->i_blocks manually, this cause wrong i_blocks value. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: little directory lookup optimizationEvgeniy Dushistov
This patch make little optimization of ufs_find_entry like "ext2" does. Save number of page and reuse it again in the next call. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: easy debugEvgeniy Dushistov
Currently to turn on debug mode "user" has to edit ~10 files, to turn off he has to do it again. This patch introduce such changes: 1)turn on(off) debug messages via ".config" 2)remove unnecessary duplication of code 3)make "UFSD" macros more similar to function 4)fix some compiler warnings Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: not usual amounts of fragments per blockEvgeniy Dushistov
The writing to UFS file system with block/fragment!=8 may cause bogus behaviour. The problem in "ufs_bitmap_search" function, which doesn't work correctly in "block/fragment!=8" case. The idea is stolen from BSD code. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: wrong type castEvgeniy Dushistov
There are two ugly macros in ufs code: #define UCPI_UBH ((struct ufs_buffer_head *)ucpi) #define USPI_UBH ((struct ufs_buffer_head *)uspi) when uspi looks like struct { struct ufs_buffer_head ; } and USPI_UBH has some sence, ucpi looks like struct { struct not_ufs_buffer_head; } To prevent bugs in future, this patch convert macros to inline function and fix "ucpi" structure. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: directory and page cache: from blocks to pagesEvgeniy Dushistov
Change function in fs/ufs/dir.c and fs/ufs/namei.c to work with pages instead of straight work with blocks. It fixed such bugs: * for i in `seq 1 1000`; do touch $i; done - crash system * mkdir create directory without "." and ".." entries Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: directory and page cache: install aopsEvgeniy Dushistov
This series of patches finished "bugs fixing" mentioned here http://lkml.org/lkml/2006/1/31/275 . The main bugs: * for i in `seq 1 1000`; do touch $i; done - crash system * mkdir create directory without "." and ".." entries The suggested solution is work with page cache instead of straight work with blocks. Such solution has following advantages * reduce code size and its complexity * some global locks go away * fix bugs The most part of code is stolen from ext2, because of it has similar directory structure. Patches testes with UFS1 and UFS2 file systems. This patch installs i_mapping->a_ops for directory inodes and removes some duplicated code. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: change block number on the flyEvgeniy Dushistov
First of all some necessary notes about UFS by it self: To avoid waste of disk space the tail of file consists not from blocks (which is ordinary big enough, 16K usually), it consists from fragments(which is ordinary 2K). When file is growing its tail occupy 1 fragment, 2 fragments... At some stage decision to allocate whole block is made and all fragments are moved to one block. How this situation was handled before: ufs_prepare_write ->block_prepare_write ->ufs_getfrag_block ->... ->ufs_new_fragments: bh = sb_bread bh->b_blocknr = result + i; mark_buffer_dirty (bh); This is wrong solution, because: - it didn't take into consideration that there is another cache: "inode page cache" - because of sb_getblk uses not b_blocknr, (it uses page->index) to find certain block, this breaks sb_getblk. How this situation is handled now: we go though all "page inode cache", if there are no such page in cache we load it into cache, and change b_blocknr. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: right block allocationEvgeniy Dushistov
* After block allocation, we map it on the same "address" as 8 others blocks * We nullify block several times: once in ufs/block.c and once in block_*write_full_page, and use different "caches" for this. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: ufs_trunc_indirect: infinite cycleEvgeniy Dushistov
Currently, ufs write support have two sets of problems: work with files and work with directories. This series of patches should solve the first problem. This patch is similar to http://lkml.org/lkml/2006/1/17/61 this patch complements it. The situation the same: in ufs_trunc_(not direct), we read block, check if count of links to it is equal to one, if so we finish cycle, if not continue. Because of "count of links" always >=2 this operation cause infinite cycle and hang up the kernel. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24typo patch for fs/ufs/super.cMichael Owen
Quick and simple typo fix. neTXstep -> neXTstep Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] ufs: switch to inode_inc_count, inode_dec_countAlexey Dobriyan
2006-03-23[PATCH] fs/ufs/file.c: drop insane header dependenciesAlexey Dobriyan
2006-02-03[PATCH] ufs: fix hang during `rm'Evgeniy Dushistov
This fixes the code like this: bh = sb_find_get_block (sb, tmp + j); if ((bh && DATA_BUFFER_USED(bh)) || tmp != fs32_to_cpu(sb, *p)) { retry = 1; brelse (bh); goto next1; } bforget (bh); sb_find_get_block() ordinarily returns a buffer_head with b_count>=2, and this code assume that in case if "b_count>1" buffer is used, so this caused infinite loop. (akpm: that is-the-buffer-busy code is incomprehensible. Good riddance. Use of block_truncate_page() seems sane). Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] ufs: fix oops with `ufs1' typeEvgeniy Dushistov
"rm" command, on file system with "ufs1" type cause system hang up. This is, in fact, not so bad as it seems to be, because of after that in "kernel control path" there are 3-4 places which may cause "oops". So the first patch fix oopses, and the second patch fix "kernel hang up". "oops" appears because of reading of group's summary info partly wrong, and access to not first group's summary info cause "oops". Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] ufs cleanupEvgeniy
Here is update of ufs cleanup patch, brought on by the recently fixed ubh_get_usb_second() bug that made some ugly code rather painfully obvious. It also includes - fix compilation warnings which appears if debug mode turn on - remove unnecessary duplication of code to support UFS2 I tested it on ufs1 and ufs2 file-systems. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-13[PATCH] Fix oops in ufs_fill_super at mount timeEvgeniy
There's a lack of parenthesis in fs/ufs/utils.h, so instead of the 512th byte of buffer, the usb2 pointer will point to the nth structure of type ufs_super_block_second. This can cause a mount-time oops if you're unlucky (especially with DEBUG_PAGEALLOC, which is how Alexey Dobriyan saw this problem) Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Acked-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-08[PATCH] UFS: inode->i_sem is not released in error pathEvgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] fs/ufs: debug mode compilation failureEvgeniy
This patch should fix compilation failure of fs/ufs/dir.c with defined UFS_DIR_DEBUG Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
