path: root/fs/xattr.c
2007-05-11[PATCH] audit inode for all xattr syscallsAmy Griffis
Collect inode info for the remaining xattr syscalls that operate on a file descriptor. These don't call a path_lookup variant, so they aren't covered by the general audit hook. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] Fix user.* xattr permission check for sticky dirsAndreas Gruenbacher
The user.* extended attributes are only allowed on regular files and directories. Sticky directories further restrict write access to the owner and privileged users. (See the attr(5) man page for an explanation.) The original check in ext2/ext3 when user.* xattrs were merged was more restrictive than intended, and when the xattr permission checks were moved into the VFS, read access to user.* attributes on sticky directores ended up being denied in addition. Originally-from: Gerard Neil <xyzzy@devferret.org> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-09[PATCH] Introduce vfs_listxattrBill Nottingham
This patch moves code out of fs/xattr.c:listxattr into a new function - vfs_listxattr. The code for vfs_listxattr was originally submitted by Bill Nottingham <notting@redhat.com> to Unionfs. Sorry about that. The reason for this submission is to make the listxattr code in fs/xattr.c a little cleaner (as well as to clean up some code in Unionfs.) Currently, Unionfs has vfs_listxattr defined in its code. I think that's very ugly, and I'd like to see it (re)moved. The logical place to put it, is along side of all the other vfs_*xattr functions. Overall, I think this patch is benefitial for both kernel.org kernel and Unionfs. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20[PATCH] log more info for directory entry change eventsAmy Griffis
When an audit event involves changes to a directory entry, include a PATH record for the directory itself. A few other notable changes: - fixed audit_inode_child() hooks in fsnotify_move() - removed unused flags arg from audit_inode() - added audit log routines for logging a portion of a string Here's some sample output. before patch: type=SYSCALL msg=audit(1149821605.320:26): arch=40000003 syscall=39 success=yes exit=0 a0=bf8d3c7c a1=1ff a2=804e1b8 a3=bf8d3c7c items=1 ppid=739 pid=800 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS0 comm="mkdir" exe="/bin/mkdir" subj=root:system_r:unconfined_t:s0-s0:c0.c255 type=CWD msg=audit(1149821605.320:26): cwd="/root" type=PATH msg=audit(1149821605.320:26): item=0 name="foo" parent=164068 inode=164010 dev=03:00 mode=040755 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_t:s0 after patch: type=SYSCALL msg=audit(1149822032.332:24): arch=40000003 syscall=39 success=yes exit=0 a0=bfdd9c7c a1=1ff a2=804e1b8 a3=bfdd9c7c items=2 ppid=714 pid=777 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS0 comm="mkdir" exe="/bin/mkdir" subj=root:system_r:unconfined_t:s0-s0:c0.c255 type=CWD msg=audit(1149822032.332:24): cwd="/root" type=PATH msg=audit(1149822032.332:24): item=0 name="/root" inode=164068 dev=03:00 mode=040750 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_dir_t:s0 type=PATH msg=audit(1149822032.332:24): item=1 name="foo" inode=164010 dev=03:00 mode=040755 ouid=0 ogid=0 rdev=00:00 obj=root:object_r:user_home_t:s0 Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-20[PATCH] Collect more inode information during syscall processing.Amy Griffis
This patch augments the collection of inode info during syscall processing. It represents part of the functionality that was provided by the auditfs patch included in RHEL4. Specifically, it: - Collects information for target inodes created or removed during syscalls. Previous code only collects information for the target inode's parent. - Adds the audit_inode() hook to syscalls that operate on a file descriptor (e.g. fchown), enabling audit to do inode filtering for these calls. - Modifies filtering code to check audit context for either an inode # or a parent inode # matching a given rule. - Modifies logging to provide inode # for both parent and child. - Protect debug info from NULL audit_names.name. [AV: folded a later typo fix from the same author] Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-10[PATCH] move xattr permission checks into the VFSakpm@osdl.org
) From: Christoph Hellwig <hch@lst.de> The xattr code has rather complex permission checks because the rules are very different for different attribute namespaces. This patch moves as much as we can into the generic code. Currently all the major disk based filesystems duplicate these checks, while many minor filesystems or network filesystems lack some or all of them. To do this we need defines for the extended attribute names in common code, I moved them up from JFS which had the nicest defintions. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] add vfs_* helpers for xattr operationsChristoph Hellwig
Add vfs_getxattr, vfs_setxattr and vfs_removexattr helpers for common checks around invocation of the xattr methods. NFSD already was missing some of the checks and there will be more soon. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: James Morris <jmorris@namei.org> (James, I haven't touched selinux yet because it's doing various odd things and I'm not sure how it would interact with the security attribute fallbacks you added. Could you investigate whether it could use vfs_getxattr or if not add a __vfs_getxattr helper to share the bits it is fine with?) For NFSv4: instead of just converting it add an nfsd_getxattr helper for the code shared by NFSv2/3 and NFSv4 ACLs. In fact that code isn't even NFS-specific, but I'll wait for more users to pop up first before moving it to common code. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-12-12[PATCH] Fix listxattr() for generic security attributesDaniel Drake
Commit f549d6c18c0e8e6cf1bf0e7a47acc1daf7e2cec1 introduced a generic fallback for security xattrs, but appears to include a subtle bug. Gentoo users with kernels with selinux compiled in, and coreutils compiled with acl support, noticed that they could not copy files on tmpfs using 'cp'. cp (compiled with acl support) copies the file, lists the extended attributes on the old file, copies them all to the new file, and then exits. However the listxattr() calls were failing with this odd behaviour: llistxattr("a.out", (nil), 0) = 17 llistxattr("a.out", 0x7fffff8c6cb0, 17) = -1 ERANGE (Numerical result out of range) I believe this is a simple problem in the logic used to check the buffer sizes; if the user sends a buffer the exact size of the data, then its ok :) This change solves the problem. More info can be found at http://bugs.gentoo.org/113138 Signed-off-by: Daniel Drake <dsd@gentoo.org> Acked-by: James Morris <jmorris@namei.org> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] SELinux: canonicalize getxattr()James Morris
This patch allows SELinux to canonicalize the value returned from getxattr() via the security_inode_getsecurity() hook, which is called after the fs level getxattr() function. The purpose of this is to allow the in-core security context for an inode to override the on-disk value. This could happen in cases such as upgrading a system to a different labeling form (e.g. standard SELinux to MLS) without needing to do a full relabel of the filesystem. In such cases, we want getxattr() to return the canonical security context that the kernel is using rather than what is stored on disk. The implementation hooks into the inode_getsecurity(), adding another parameter to indicate the result of the preceding fs-level getxattr() call, so that SELinux knows whether to compare a value obtained from disk with the kernel value. We also now allow getxattr() to work for mountpoint labeled filesystems (i.e. mount with option context=foo_t), as we are able to return the kernel value to the user. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] fsnotify: hook on removexattr, tooRobert Love
Add fsnotify_xattr() hook to removexattr(). Signed-off-by: Robert Love <rml@novell.com> Signed-off-by: John McCtuchan <ttb@tentacle.dhs.org> Cc: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] Generic VFS fallback for security xattrsStephen Smalley
This patch modifies the VFS setxattr, getxattr, and listxattr code to fall back to the security module for security xattrs if the filesystem does not support xattrs natively. This allows security modules to export the incore inode security label information to userspace even if the filesystem does not provide xattr storage, and eliminates the need to individually patch various pseudo filesystem types to provide such access. The patch removes the existing xattr code from devpts and tmpfs as it is then no longer needed. The patch restructures the code flow slightly to reduce duplication between the normal path and the fallback path, but this should only have one user-visible side effect - a program may get -EACCES rather than -EOPNOTSUPP if policy denied access but the filesystem didn't support the operation anyway. Note that the post_setxattr hook call is not needed in the fallback case, as the inode_setsecurity hook call handles the incore inode security state update directly. In contrast, we do call fsnotify in both cases. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] inotifyRobert Love
inotify is intended to correct the deficiencies of dnotify, particularly its inability to scale and its terrible user interface: * dnotify requires the opening of one fd per each directory that you intend to watch. This quickly results in too many open files and pins removable media, preventing unmount. * dnotify is directory-based. You only learn about changes to directories. Sure, a change to a file in a directory affects the directory, but you are then forced to keep a cache of stat structures. * dnotify's interface to user-space is awful. Signals? inotify provides a more usable, simple, powerful solution to file change notification: * inotify's interface is a system call that returns a fd, not SIGIO. You get a single fd, which is select()-able. * inotify has an event that says "the filesystem that the item you were watching is on was unmounted." * inotify can watch directories or files. Inotify is currently used by Beagle (a desktop search infrastructure), Gamin (a FAM replacement), and other projects. See Documentation/filesystems/inotify.txt. Signed-off-by: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
