path: root/fs/xattr_acl.c
2012-10-12userns: Fix posix_acl_file_xattr_userns gid conversionEric W. Biederman
The code needs to be from_kgid(make_kgid(...)...) not from_kuid(make_kgid(...)...). Doh! Reported-by: Jan Kara <jack@suse.cz> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-18userns: Pass a userns parameter into posix_acl_to_xattr and posix_acl_from_xattrEric W. Biederman
- Pass the user namespace the uid and gid values in the xattr are stored in into posix_acl_from_xattr. - Pass the user namespace kuid and kgid values should be converted into when storing uid and gid values in an xattr in posix_acl_to_xattr. - Modify all callers of posix_acl_from_xattr and posix_acl_to_xattr to pass in &init_user_ns. In the short term this change is not strictly needed but it makes the code clearer. In the longer term this change is necessary to be able to mount filesystems outside of the initial user namespace that natively store posix acls in the linux xattr format. Cc: Theodore Tso <tytso@mit.edu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-18userns: Convert vfs posix_acl support to use kuids and kgidsEric W. Biederman
- In setxattr if we are setting a posix acl convert uids and gids from the current user namespace into the initial user namespace, before the xattrs are passed to the underlying filesystem. Untranslatable uids and gids are represented as -1 which posix_acl_from_xattr will represent as INVALID_UID or INVALID_GID. posix_acl_valid will fail if an acl from userspace has any INVALID_UID or INVALID_GID values. In net this guarantees that untranslatable posix acls will not be stored by filesystems. - In getxattr if we are reading a posix acl convert uids and gids from the initial user namespace into the current user namespace. Uids and gids that can not be tranlsated into the current user namespace will be represented as -1. - Replace e_id in struct posix_acl_entry with an anymouns union of e_uid and e_gid. For the short term retain the e_id field until all of the users are converted. - Don't set struct posix_acl.e_id in the cases where the acl type does not use e_id. Greatly reducing the use of ACL_UNDEFINED_ID. - Rework the ordering checks in posix_acl_valid so that I use kuid_t and kgid_t types throughout the code, and so that I don't need arithmetic on uid and gid types. Cc: Theodore Tso <tytso@mit.edu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-03VFS: Use GFP_NOFS in posix_acl_from_xattr()Steven Whitehouse
GFS2 needs to call this from under a glock, so we need GFP_NOFS and I suspect that other filesystems might require this too. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
