path: root/fs/xfs/Makefile
2011-08-22xfs: fix tracing builds inside the source treeChristoph Hellwig
The code really requires the current source directory to be in the header search path. We already do this if building with an object tree separate from the source, but it needs to be added manually if building inside the source. The cflags addition for it accidentally got removed when collapsing the xfs directory structure. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: remove subdirectoriesChristoph Hellwig
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the annoying subdirectories in the XFS source code. Besides the large amount of file rename the only changes are to the Makefile, a few files including headers with the subdirectory prefix, and the binary sysctl compat code that includes a header under fs/xfs/ from kernel/. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: don't expect xfs headers to be in subdirectoriesAlex Elder
Fix up some #include directives in preparation for moving a few header files out of xfs source subdirectories. Note that "xfs_linux.h" also got its quoting convention for included files switched. Signed-off-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-07-13xfs: remove leftovers of the old btree tracing codeChristoph Hellwig
Remove various bits left over from the old kdb-only btree tracing code, but leave the actual trace point stubs in place to ease adding new event based btree tracing. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-03-21Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: (23 commits) xfs: don't name variables "panic" xfs: factor agf counter updates into a helper xfs: clean up the xfs_alloc_compute_aligned calling convention xfs: kill support/debug.[ch] xfs: Convert remaining cmn_err() callers to new API xfs: convert the quota debug prints to new API xfs: rename xfs_cmn_err_fsblock_zero() xfs: convert xfs_fs_cmn_err to new error logging API xfs: kill xfs_fs_mount_cmn_err() macro xfs: kill xfs_fs_repair_cmn_err() macro xfs: convert xfs_cmn_err to xfs_alert_tag xfs: Convert xlog_warn to new logging interface xfs: Convert linux-2.6/ files to new logging interface xfs: introduce new logging API. xfs: zero proper structure size for geometry calls xfs: enable delaylog by default xfs: more sensible inode refcounting for ialloc xfs: stop using xfs_trans_iget in the RT allocator xfs: check if device support discard in xfs_ioc_trim() xfs: prevent leaking uninitialized stack memory in FSGEOMETRY_V1 ...
2011-03-17fs: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y for cleaner conditional inclusion. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-07xfs: kill support/debug.[ch]Dave Chinner
The remaining functionality in debug.[ch] is effectively just assert handling, conditional debug definitions and hex dumping. The hex dumping and assert function can be moved into the new printk module, while the rest can be moved into top-level header files. This allows fs/xfs/support/debug.[ch] to be completely removed from the codebase. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-03-02xfs: introduce new logging API.Dave Chinner
Most of the logging infrastructure in XFS is unneccessary and designed around the infrastructure supplied by Irix rather than Linux. To rationalise the logging interfaces, start by introducing simple printk wrappers similar to the dev_printk() infrastructure. Later patches will convert code to use this new interface. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-01-11xfs: add FITRIM supportChristoph Hellwig
Allow manual discards from userspace using the FITRIM ioctl. This is not intended to be run during normal workloads, as the freepsace btree walks can cause large performance degradation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-07-26xfs: simplify log item descriptor trackingChristoph Hellwig
Currently we track log item descriptor belonging to a transaction using a complex opencoded chunk allocator. This code has been there since day one and seems to work around the lack of an efficient slab allocator. This patch replaces it with dynamically allocated log item descriptors from a dedicated slab pool, linked to the transaction by a linked list. This allows to greatly simplify the log item descriptor tracking to the point where it's just a couple hundred lines in xfs_trans.c instead of a separate file. The external API has also been simplified while we're at it - the xfs_trans_add_item and xfs_trans_del_item functions to add/ delete items from a transaction have been simplified to the bare minium, and the xfs_trans_find_item function is replaced with a direct dereference of the li_desc field. All debug code walking the list of log items in a transaction is down to a simple list_for_each_entry. Note that we could easily use a singly linked list here instead of the double linked list from list.h as the fastpath only does deletion from sequential traversal. But given that we don't have one available as a library function yet I use the list.h functions for simplicity. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-07-26xfs: drop dmapi hooksChristoph Hellwig
Dmapi support was never merged upstream, but we still have a lot of hooks bloating XFS for it, all over the fast pathes of the filesystem. This patch drops over 700 lines of dmapi overhead. If we'll ever get HSM support in mainline at least the namespace events can be done much saner in the VFS instead of the individual filesystem, so it's not like this is much help for future work. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-05-24xfs: Introduce delayed logging core codeDave Chinner
The delayed logging code only changes in-memory structures and as such can be enabled and disabled with a mount option. Add the mount option and emit a warning that this is an experimental feature that should not be used in production yet. We also need infrastructure to track committed items that have not yet been written to the log. This is what the Committed Item List (CIL) is for. The log item also needs to be extended to track the current log vector, the associated memory buffer and it's location in the Commit Item List. Extend the log item and log vector structures to enable this tracking. To maintain the current log format for transactions with delayed logging, we need to introduce a checkpoint transaction and a context for tracking each checkpoint from initiation to transaction completion. This includes adding a log ticket for tracking space log required/used by the context checkpoint. To track all the changes we need an io vector array per log item, rather than a single array for the entire transaction. Using the new log vector structure for this requires two passes - the first to allocate the log vector structures and chain them together, and the second to fill them out. This log vector chain can then be passed to the CIL for formatting, pinning and insertion into the CIL. Formatting of the log vector chain is relatively simple - it's just a loop over the iovecs on each log vector, but it is made slightly more complex because we re-write the iovec after the copy to point back at the memory buffer we just copied into. This code also needs to pin log items. If the log item is not already tracked in this checkpoint context, then it needs to be pinned. Otherwise it is already pinned and we don't need to pin it again. The only other complexity is calculating the amount of new log space the formatting has consumed. This needs to be accounted to the transaction in progress, and the accounting is made more complex becase we need also to steal space from it for log metadata in the checkpoint transaction. Calculate all this at insert time and update all the tickets, counters, etc correctly. Once we've formatted all the log items in the transaction, attach the busy extents to the checkpoint context so the busy extents live until checkpoint completion and can be processed at that point in time. Transactions can then be freed at this point in time. Now we need to issue checkpoints - we are tracking the amount of log space used by the items in the CIL, so we can trigger background checkpoints when the space usage gets to a certain threshold. Otherwise, checkpoints need ot be triggered when a log synchronisation point is reached - a log force event. Because the log write code already handles chained log vectors, writing the transaction is trivial, too. Construct a transaction header, add it to the head of the chain and write it into the log, then issue a commit record write. Then we can release the checkpoint log ticket and attach the context to the log buffer so it can be called during Io completion to complete the checkpoint. We also need to allow for synchronising multiple in-flight checkpoints. This is needed for two things - the first is to ensure that checkpoint commit records appear in the log in the correct sequence order (so they are replayed in the correct order). The second is so that xfs_log_force_lsn() operates correctly and only flushes and/or waits for the specific sequence it was provided with. To do this we need a wait variable and a list tracking the checkpoint commits in progress. We can walk this list and wait for the checkpoints to change state or complete easily, an this provides the necessary synchronisation for correct operation in both cases. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-03-01xfs: merge xfs_lrw.c into xfs_file.cChristoph Hellwig
Currently the code to implement the file operations is split over two small files. Merge the content of xfs_lrw.c into xfs_file.c to have it in one place. Note that I haven't done various cleanups that are possible after this yet, they will follow in the next patch. Also the function xfs_dev_is_read_only which was in xfs_lrw.c before really doesn't fit in here at all and was moved to xfs_mount.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-01-26xfs: turn off sign warningsDave Chinner
Because they cause warnings in static inline functions conditionally compiled into XFS from the VFS (e.g. fsnotify). Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-01-20xfs: make compile warn about char sign mismatches againDave Chinner
The -fno-unsigned-char directive has no effect anymore as the XFs build is clean. However, the kernel build hides pointer sign differences so turn that back on so that we can clean up all the mismatches prior to a userspace code resync. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2009-12-14xfs: event tracing supportChristoph Hellwig
Convert the old xfs tracing support that could only be used with the out of tree kdb and xfsidbg patches to use the generic event tracer. To use it make sure CONFIG_EVENT_TRACING is enabled and then enable all xfs trace channels by: echo 1 > /sys/kernel/debug/tracing/events/xfs/enable or alternatively enable single events by just doing the same in one event subdirectory, e.g. echo 1 > /sys/kernel/debug/tracing/events/xfs/xfs_ihold/enable or set more complex filters, etc. In Documentation/trace/events.txt all this is desctribed in more detail. To reads the events do a cat /sys/kernel/debug/tracing/trace Compared to the last posting this patch converts the tracing mostly to the one tracepoint per callsite model that other users of the new tracing facility also employ. This allows a very fine-grained control of the tracing, a cleaner output of the traces and also enables the perf tool to use each tracepoint as a virtual performance counter, allowing us to e.g. count how often certain workloads git various spots in XFS. Take a look at http://lwn.net/Articles/346470/ for some examples. Also the btree tracing isn't included at all yet, as it will require additional core tracing features not in mainline yet, I plan to deliver it later. And the really nice thing about this patch is that it actually removes many lines of code while adding this nice functionality: fs/xfs/Makefile | 8 fs/xfs/linux-2.6/xfs_acl.c | 1 fs/xfs/linux-2.6/xfs_aops.c | 52 - fs/xfs/linux-2.6/xfs_aops.h | 2 fs/xfs/linux-2.6/xfs_buf.c | 117 +-- fs/xfs/linux-2.6/xfs_buf.h | 33 fs/xfs/linux-2.6/xfs_fs_subr.c | 3 fs/xfs/linux-2.6/xfs_ioctl.c | 1 fs/xfs/linux-2.6/xfs_ioctl32.c | 1 fs/xfs/linux-2.6/xfs_iops.c | 1 fs/xfs/linux-2.6/xfs_linux.h | 1 fs/xfs/linux-2.6/xfs_lrw.c | 87 -- fs/xfs/linux-2.6/xfs_lrw.h | 45 - fs/xfs/linux-2.6/xfs_super.c | 104 --- fs/xfs/linux-2.6/xfs_super.h | 7 fs/xfs/linux-2.6/xfs_sync.c | 1 fs/xfs/linux-2.6/xfs_trace.c | 75 ++ fs/xfs/linux-2.6/xfs_trace.h | 1369 +++++++++++++++++++++++++++++++++++++++++ fs/xfs/linux-2.6/xfs_vnode.h | 4 fs/xfs/quota/xfs_dquot.c | 110 --- fs/xfs/quota/xfs_dquot.h | 21 fs/xfs/quota/xfs_qm.c | 40 - fs/xfs/quota/xfs_qm_syscalls.c | 4 fs/xfs/support/ktrace.c | 323 --------- fs/xfs/support/ktrace.h | 85 -- fs/xfs/xfs.h | 16 fs/xfs/xfs_ag.h | 14 fs/xfs/xfs_alloc.c | 230 +----- fs/xfs/xfs_alloc.h | 27 fs/xfs/xfs_alloc_btree.c | 1 fs/xfs/xfs_attr.c | 107 --- fs/xfs/xfs_attr.h | 10 fs/xfs/xfs_attr_leaf.c | 14 fs/xfs/xfs_attr_sf.h | 40 - fs/xfs/xfs_bmap.c | 507 +++------------ fs/xfs/xfs_bmap.h | 49 - fs/xfs/xfs_bmap_btree.c | 6 fs/xfs/xfs_btree.c | 5 fs/xfs/xfs_btree_trace.h | 17 fs/xfs/xfs_buf_item.c | 87 -- fs/xfs/xfs_buf_item.h | 20 fs/xfs/xfs_da_btree.c | 3 fs/xfs/xfs_da_btree.h | 7 fs/xfs/xfs_dfrag.c | 2 fs/xfs/xfs_dir2.c | 8 fs/xfs/xfs_dir2_block.c | 20 fs/xfs/xfs_dir2_leaf.c | 21 fs/xfs/xfs_dir2_node.c | 27 fs/xfs/xfs_dir2_sf.c | 26 fs/xfs/xfs_dir2_trace.c | 216 ------ fs/xfs/xfs_dir2_trace.h | 72 -- fs/xfs/xfs_filestream.c | 8 fs/xfs/xfs_fsops.c | 2 fs/xfs/xfs_iget.c | 111 --- fs/xfs/xfs_inode.c | 67 -- fs/xfs/xfs_inode.h | 76 -- fs/xfs/xfs_inode_item.c | 5 fs/xfs/xfs_iomap.c | 85 -- fs/xfs/xfs_iomap.h | 8 fs/xfs/xfs_log.c | 181 +---- fs/xfs/xfs_log_priv.h | 20 fs/xfs/xfs_log_recover.c | 1 fs/xfs/xfs_mount.c | 2 fs/xfs/xfs_quota.h | 8 fs/xfs/xfs_rename.c | 1 fs/xfs/xfs_rtalloc.c | 1 fs/xfs/xfs_rw.c | 3 fs/xfs/xfs_trans.h | 47 + fs/xfs/xfs_trans_buf.c | 62 - fs/xfs/xfs_vnodeops.c | 8 70 files changed, 2151 insertions(+), 2592 deletions(-) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-06-10xfs: use generic Posix ACL codeChristoph Hellwig
This patch rips out the XFS ACL handling code and uses the generic fs/posix_acl.c code instead. The ondisk format is of course left unchanged. This also introduces the same ACL caching all other Linux filesystems do by adding pointers to the acl and default acl in struct xfs_inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
2009-06-08xfs: kill xfs_qmopsChristoph Hellwig
Kill the quota ops function vector and replace it with direct calls or stubs in the CONFIG_XFS_QUOTA=n case. Make sure we check XFS_IS_QUOTA_RUNNING in the right spots. We can remove the number of those checks because the XFS_TRANS_DQ_DIRTY flag can't be set otherwise. This brings us back closer to the way this code worked in IRIX and earlier Linux versions, but we keep a lot of the more useful factoring of common code. Eventually we should also kill xfs_qm_bhv.c, but that's left for a later patch. Reduces the size of the source code by about 250 lines and the size of XFS module by about 1.5 kilobytes with quotas enabled: text data bss dec hex filename 615957 2960 3848 622765 980ad fs/xfs/xfs.o 617231 3152 3848 624231 98667 fs/xfs/xfs.o.old Fallout: - xfs_qm_dqattach is split into xfs_qm_dqattach_locked which expects the inode locked and xfs_qm_dqattach which does the locking around it, thus removing XFS_QMOPT_ILOCKED. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
2009-02-09xfs: get rid of indirections in the quotaops implementationChristoph Hellwig
Currently we call from the nicely abstracted linux quotaops into a ugly multiplexer just to split the calls out at the same boundary again. Rewrite the quota ops handling to remove that obfucation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2008-12-04move inode tracing out of xfs_vnode.Christoph Hellwig
Move the inode tracing into xfs_iget.c / xfs_inode.h and kill xfs_vnode.c now that it's empty. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-04kill xfs_unmount_flushChristoph Hellwig
There's almost nothing left in this function, instead remove the IRELE on the real times inodes and the call to XFS_QM_UNMOUNT into xfs_unmountfs. For the regular unmount case that means it now also happenes after dmapi notification, but otherwise there is no difference in behaviour. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-10-30[XFS] move sync code to its own fileDavid Chinner
The sync code in XFS is spread around several files. While it used to make sense to have such a distribution, the code is about to be cleaned up and so centralising it in one spot as the first step makes sense. SGI-PV: 988139 SGI-Modid: xfs-linux-melb:xfs-kern:32282a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-10-30[XFS] make btree tracing genericChristoph Hellwig
Make the existing bmap btree tracing generic so that it applies to all btree types. Some fragments lifted from a patch by Dave Chinner. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32187a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-07-28[XFS] Use the generic xattr methods.Lachlan McIlroy
Use the generic set, get and removexattr methods and supply the s_xattr array with fine-grained handlers. All XFS/Linux highlevel attr handling is rewritten from scratch and placed into fs/xfs/linux-2.6/xfs_xattr.c so that it's separated from the generic low-level code. SGI-PV: 982343 SGI-Modid: xfs-linux-melb:xfs-kern:31234a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-18[XFS] Added quota targets and removed dmapi directoryLachlan McIlroy
Fixes build failures introduced by bad merge to mainline.
2008-02-18[XFS] Fix up xfs out-of-tree builds. (a.k.a. external modules)Eric Sandeen
Change -I include directives to find headers in the out-of-tree spot. This allows a directory containing only xfs files to be built as: SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:29878a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-18[XFS] Remove Makefile wrappers in XFSAndi Kleen
Makefile (and Kbuild) would include Makefile-linux-26 I doubt XFS will really still compile on 2.4; so drop that. This moves Makefile-linux-26 into Makefile and drops Kbuild. Also having wrappers as both Kbuild and Makefile seemed redundant anyways. The patch is relatively large because it renames a file, but no functional changes. SGI-PV: 971050 SGI-Modid: xfs-linux-melb:xfs-kern:29781a Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2005-09-05[XFS] Sort out some cosmetic differences between XFS trees.Nathan Scott
SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:23719a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-05-05[XFS] Enable XFS_VNODE_TRACEEric Sandeen
SGI Modid: xfs-linux:xfs-kern:190725a Signed-off-by: Eric Sandeen <sandeen@sgi.com> Signed-off-by: Christoph Hellwig <hch@sgi.com> .
