commit 87c7bec7fc3377b3873eb3a0f4b603981ea16ebb upstream.
The code to flush buffers in the umount code is a bit iffy: we first
flush all delwri buffers out, but then might be able to queue up a
new one when logging the sb counts. On a normal shutdown that one
would get flushed out when doing the synchronous superblock write in
xfs_unmountfs_writesb, but we skip that one if the filesystem has
been shut down.
Fix this by moving the delwri list flushing until just before unmounting
the log, and while we're at it also remove the superflous delwri list
and buffer lru flusing for the rt and log device that can never have
cached or delwri buffers.
Reported-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
Tested-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
When we free a vmapped buffer, we need to ensure the vmap address
and length we free is the same as when it was allocated. In various
places in the log code we change the memory the buffer is pointing
to before issuing IO, but we never reset the buffer to point back to
it's original memory (or no memory, if that is the case for the
buffer).
As a result, when we free the buffer it points to memory that is
owned by something else and attempts to unmap and free it. Because
the range does not match any known mapped range, it can trigger
BUG_ON() traps in the vmap code, and potentially corrupt the vmap
area tracking.
Fix this by always resetting these buffers to their original state
before freeing them.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Now that the buffer cache has it's own LRU, we do not need to use
the page cache to provide persistent caching and reclaim
infrastructure. Convert the buffer cache to use alloc_pages()
instead of the page cache. This will remove all the overhead of page
cache management from setup and teardown of the buffers, as well as
needing to mark pages accessed as we find buffers in the buffer
cache.
By avoiding the page cache, we also remove the need to keep state in
the page_private(page) field for persistant storage across buffer
free/buffer rebuild and so all that code can be removed. This also
fixes the long-standing problem of not having enough bits in the
page_private field to track all the state needed for a 512
sector/64k page setup.
It also removes the need for page locking during reads as the pages
are unique to the buffer and nobody else will be attempting to
access them.
Finally, it removes the buftarg address space lock as a point of
global contention on workloads that allocate and free buffers
quickly such as when creating or removing large numbers of inodes in
parallel. This remove the 16TB limit on filesystem size on 32 bit
machines as the page index (32 bit) is no longer used for lookups
of metadata buffers - the buffer cache is now solely indexed by disk
address which is stored in a 64 bit field in the buffer.
Reviewed-by: Alex Elder <aelder@sgi.com>
If we get an IO error on a synchronous superblock write, we attach an
error release function to it so that when the last reference goes away
the release function is called and the buffer is invalidated and
unlocked. The buffer is left locked until the release function is
called so that other concurrent users of the buffer will be locked out
until the buffer error is fully processed.
Unfortunately, for the superblock buffer the filesyetm itself holds a
reference to the buffer which prevents the reference count from
dropping to zero and the release function being called. As a result,
once an IO error occurs on a sync write, the buffer will never be
unlocked and all future attempts to lock the buffer will hang.
To make matters worse, this problems is not unique to such buffers;
if there is a concurrent _xfs_buf_find() running, the lookup will grab
a reference to the buffer and then wait on the buffer lock, preventing
the reference count from ever falling to zero and hence unlocking the
buffer.
As such, the whole b_relse function implementation is broken because it
cannot rely on the buffer reference count falling to zero to unlock the
errored buffer. The synchronous write error path is the only path that
uses this callback - it is used to ensure that the synchronous waiter
gets the buffer error before the error state is cleared from the buffer
by the release function.
Given that the only sychronous buffer writes now go through xfs_bwrite
and the error path in question can only occur for a write of a dirty,
logged buffer, we can move most of the b_relse processing to happen
inline in xfs_buf_iodone_callbacks, just like a normal I/O completion.
In addition to that we make sure the error is not cleared in
xfs_buf_iodone_callbacks, so that xfs_bwrite can reliably check it.
Given that xfs_bwrite keeps the buffer locked until it has waited for
it and checked the error this allows to reliably propagate the error
to the caller, and make sure that the buffer is reliably unlocked.
Given that xfs_buf_iodone_callbacks was the only instance of the
b_relse callback we can remove it entirely.
Based on earlier patches by Dave Chinner and Ajeet Yadav.
Reported-by: Ajeet Yadav <ajeet.yadav.77@gmail.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Now that the buffer reclaim infrastructure can handle different reclaim
priorities for different types of buffers, reconnect the hooks in the
XFS code that has been sitting dormant since it was ported to Linux. This
should finally give use reclaim prioritisation that is on a par with the
functionality that Irix provided XFS 15 years ago.
Introduce a per-buftarg LRU for memory reclaim to operate on. This
is the last piece we need to put in place so that we can fully
control the buffer lifecycle. This allows XFS to be responsibile for
maintaining the working set of buffers under memory pressure instead
of relying on the VM reclaim not to take pages we need out from
underneath us.
The implementation introduces a b_lru_ref counter into the buffer.
This is currently set to 1 whenever the buffer is referenced and so is used to
determine if the buffer should be added to the LRU or not when freed.
Effectively it allows lazy LRU initialisation of the buffer so we do not need
to touch the LRU list and locks in xfs_buf_find().
Instead, when the buffer is being released and we drop the last
reference to it, we check the b_lru_ref count and if it is none zero
we re-add the buffer reference and add the inode to the LRU. The
b_lru_ref counter is decremented by the shrinker, and whenever the
shrinker comes across a buffer with a zero b_lru_ref counter, if
released the LRU reference on the buffer. In the absence of a lookup
race, this will result in the buffer being freed.
This counting mechanism is used instead of a reference flag so that
it is simple to re-introduce buffer-type specific reclaim reference
counts to prioritise reclaim more effectively. We still have all
those hooks in the XFS code, so this will provide the infrastructure
to re-implement that functionality.
Before we introduce per-buftarg LRU lists, split the shrinker
implementation into per-buftarg shrinker callbacks. At the moment
we wake all the xfsbufds to run the delayed write queues to free
the dirty buffers and make their pages available for reclaim.
However, with an LRU, we want to be able to free clean, unused
buffers as well, so we need to separate the xfsbufd from the
shrinker callbacks.
* 'for-linus' of git://oss.sgi.com/xfs/xfs: (36 commits)
xfs: semaphore cleanup
xfs: Extend project quotas to support 32bit project ids
xfs: remove xfs_buf wrappers
xfs: remove xfs_cred.h
xfs: remove xfs_globals.h
xfs: remove xfs_version.h
xfs: remove xfs_refcache.h
xfs: fix the xfs_trans_committed
xfs: remove unused t_callback field in struct xfs_trans
xfs: fix bogus m_maxagi check in xfs_iget
xfs: do not use xfs_mod_incore_sb_batch for per-cpu counters
xfs: do not use xfs_mod_incore_sb for per-cpu counters
xfs: remove XFS_MOUNT_NO_PERCPU_SB
xfs: pack xfs_buf structure more tightly
xfs: convert buffer cache hash to rbtree
xfs: serialise inode reclaim within an AG
xfs: batch inode reclaim lookup
xfs: implement batched inode lookups for AG walking
xfs: split out inode walk inode grabbing
xfs: split inode AG walking into separate code for reclaim
block/blk-core.c
drivers/block/loop.c
mm/swapfile.c
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Stop having two different names for many buffer functions and use
the more descriptive xfs_buf_* names directly.
pahole reports the struct xfs_buf has quite a few holes in it, so
packing the structure better will reduce the size of it by 16 bytes.
Also, move all the fields used in cache lookups into the first
cacheline.
Before on x86_64:
/* size: 320, cachelines: 5 */
/* sum members: 298, holes: 6, sum holes: 22 */
After on x86_64:
/* size: 304, cachelines: 5 */
/* padding: 6 */
/* last cacheline: 48 bytes */
The buffer cache hash is showing typical hash scalability problems.
In large scale testing the number of cached items growing far larger
than the hash can efficiently handle. Hence we need to move to a
self-scaling cache indexing mechanism.
I have selected rbtrees for indexing becuse they can have O(log n)
search scalability, and insert and remove cost is not excessive,
even on large trees. Hence we should be able to cache large numbers
of buffers without incurring the excessive cache miss search
penalties that the hash is imposing on us.
To ensure we still have parallel access to the cache, we need
multiple trees. Rather than hashing the buffers by disk address to
select a tree, it seems more sensible to separate trees by typical
access patterns. Most operations use buffers from within a single AG
at a time, so rather than searching lots of different lists,
separate the buffer indexes out into per-AG rbtrees. This means that
searches during metadata operation have a much higher chance of
hitting cache resident nodes, and that updates of the tree are less
likely to disturb trees being accessed on other CPUs doing
independent operations.
Filesystem level managed buffers are buffers that have their
lifecycle controlled by the filesystem layer, not the buffer cache.
We currently cache these buffers, which makes cleanup and cache
walking somewhat troublesome. Convert the fs managed buffers to
uncached buffers obtained by via xfs_buf_get_uncached(), and remove
the XBF_FS_MANAGED special cases from the buffer cache.
Each buffer contains both a buftarg pointer and a mount pointer. If
we add a mount pointer into the buftarg, we can avoid needing the
b_mount field in every buffer and grab it from the buftarg when
needed instead. This shrinks the xfs_buf by 8 bytes.
To avoid the need to use cached buffers for single-shot or buffers
cached at the filesystem level, introduce a new buffer read
primitive that bypasses the cache an reads directly from disk.
xfs_buf_get_nodaddr() is really used to allocate a buffer that is
uncached. While it is not directly assigned a disk address, the fact
that they are not cached is a more important distinction. With the
upcoming uncached buffer read primitive, we should be consistent
with this disctinction.
While there, make page allocation in xfs_buf_get_nodaddr() safe
against memory reclaim re-entrancy into the filesystem by allowing
a flags parameter to be passed.
Switch to the WRITE_FLUSH_FUA flag for log writes and remove the EOPNOTSUPP
detection for barriers.
When doing large parallel file creates on a 16p machines, large amounts of
time is being spent in _xfs_buf_find(). A system wide profile with perf top
shows this:
1134740.00 19.3% _xfs_buf_find
733142.00 12.5% __ticket_spin_lock
The problem is that the hash contains 45,000 buffers, and the hash table width
is only 256 buffers. That means we've got around 200 buffers per chain, and
searching it is quite expensive. The hash table size needs to increase.
Secondly, every time we do a lookup, we promote the buffer we find to the head
of the hash chain. This is causing cachelines to be dirtied and causes
invalidation of cachelines across all CPUs that may have walked the hash chain
recently. hence every walk of the hash chain is effectively a cold cache walk.
Remove the promotion to avoid this invalidation.
The results are:
1045043.00 21.2% __ticket_spin_lock
326184.00 6.6% _xfs_buf_find
A 70% drop in the CPU usage when looking up buffers. Unfortunately that does
not result in an increase in performance underthis workload as contention on
the inode_lock soaks up most of the reduction in CPU usage.
The b_strat callback is used by xfs_buf_iostrategy to perform additional
checks before submitting a buffer. It is used in xfs_bwrite and when
writing out delayed buffers. In xfs_bwrite it we can de-virtualize the
call easily as b_strat is set a few lines above the call to
xfs_buf_iostrategy. For the delayed buffers the rationale is a bit
more complicated:
- there are three callers of xfs_buf_delwri_queue, which places buffers
on the delwri list:
(1) xfs_bdwrite - this sets up b_strat, so it's fine
(2) xfs_buf_iorequest. None of the callers can have XBF_DELWRI set:
- xlog_bdstrat is only used for log buffers, which are never delwri
- _xfs_buf_read explicitly clears the delwri flag
- xfs_buf_iodone_work retries log buffers only
- xfsbdstrat - only used for reads, superblock writes without the
delwri flag, log I/O and file zeroing with explicitly allocated
buffers.
- xfs_buf_iostrategy - only calls xfs_buf_iorequest if b_strat is
not set
(3) xfs_buf_unlock
- only puts the buffer on the delwri list if the DELWRI flag is
already set. The DELWRI flag is only ever set in xfs_bwrite,
xfs_buf_iodone_callbacks, or xfs_trans_log_buf. For
xfs_buf_iodone_callbacks and xfs_trans_log_buf we require
an initialized buf item, which means b_strat was set to
xfs_bdstrat_cb in xfs_buf_item_init.
Conclusion: we can just get rid of the callback and replace it with
explicit calls to xfs_bdstrat_cb.
Signed-off-by: Dave Chinner <david@fromorbit.com>
The tracing code can't print flags defined as enums. Most flags that
we want to print are defines as macros already, but move the few remaining
ones over to make the trace output more useful.
Get rid of the xfs_buf_pin/xfs_buf_unpin/xfs_buf_ispin helpers and opencode
them in their only callers, just like we did for the inode pinning a while
ago. Also remove duplicate trace points - the bufitem tracepoints cover
all the information that is present in a buffer tracepoint.
This allows to see in `ps` and similar tools which kthreads are
allotted to which block device/filesystem, similar to what jbd2
does. As the process name is a fixed 16-char array, no extra
space is needed in tasks.
PID TTY STAT TIME COMMAND
2 ? S 0:00 [kthreadd]
197 ? S 0:00 \_ [jbd2/sda2-8]
198 ? S 0:00 \_ [ext4-dio-unwrit]
204 ? S 0:00 \_ [flush-8:0]
2647 ? S 0:00 \_ [xfs_mru_cache]
2648 ? S 0:00 \_ [xfslogd/0]
2649 ? S 0:00 \_ [xfsdatad/0]
2650 ? S 0:00 \_ [xfsconvertd/0]
2651 ? S 0:00 \_ [xfsbufd/ram0]
2652 ? S 0:00 \_ [xfsaild/ram0]
2653 ? S 0:00 \_ [xfssyncd/ram0]
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Reviewed-by: Dave Chinner <david@fromorbit.com>
There are no more users of this function left in the XFS code
now that we've switched everything to delayed write flushing.
Remove it.
All buffers logged into the AIL are marked as delayed write.
When the AIL needs to push the buffer out, it issues an async write of the
buffer. This means that IO patterns are dependent on the order of
buffers in the AIL.
Instead of flushing the buffer, promote the buffer in the delayed
write list so that the next time the xfsbufd is run the buffer will
be flushed by the xfsbufd. Return the state to the xfsaild that the
buffer was promoted so that the xfsaild knows that it needs to cause
the xfsbufd to run to flush the buffers that were promoted.
Using the xfsbufd for issuing the IO allows us to dispatch all
buffer IO from the one queue. This means that we can make much more
enlightened decisions on what order to flush buffers to disk as
we don't have multiple places issuing IO. Optimisations to xfsbufd
will be in a future patch.
Version 2
- kill XFS_ITEM_FLUSHING as it is now unused.
Currently we define aliases for the buffer flags in various
namespaces, which only adds confusion. Remove all but the XBF_
flags to clean this up a bit.
Note that we still abuse XFS_B_ASYNC/XBF_ASYNC for some non-buffer
uses, but I'll clean that up later.
xfs_buf_iomove() uses xfs_caddr_t as it's parameter types, but it doesn't
care about the signedness of the variables as it is just copying the
data. Change the prototype to use void * so that we don't get sign
warnings at call sites.
Move xfsbdstrat and xfs_bdstrat_cb from xfs_lrw.c and xfs_bioerror
and xfs_bioerror_relse from xfs_rw.c into xfs_buf.c. This also
means xfs_bioerror and xfs_bioerror_relse can be marked static now.
Fold XFS_bwrite into it's only caller, xfs_bwrite and move it into
xfs_buf.c instead of leaving it as a fairly large inline function.
Don't bother using XFS_bwrite as it doesn't provide much code for
our use case. Instead opencode it and fold xlog_bdstrat_cb into the
new xlog_bdstrat helper.
Change all async metadata buffers to use [READ|WRITE]_META I/O types
so that the I/O doesn't get issued immediately. This allows merging of
adjacent metadata requests but still prioritises them over bulk data.
This shows a 10-15% improvement in sequential create speed of small
files.
Don't include the log buffers in this classification - leave them as
sync types so they are issued immediately.
Signed-off-by: Dave Chinner <dgc@sgi.com>
Convert the old xfs tracing support that could only be used with the
out of tree kdb and xfsidbg patches to use the generic event tracer.
To use it make sure CONFIG_EVENT_TRACING is enabled and then enable
all xfs trace channels by:
echo 1 > /sys/kernel/debug/tracing/events/xfs/enable
or alternatively enable single events by just doing the same in one
event subdirectory, e.g.
echo 1 > /sys/kernel/debug/tracing/events/xfs/xfs_ihold/enable
or set more complex filters, etc. In Documentation/trace/events.txt
all this is desctribed in more detail. To reads the events do a
cat /sys/kernel/debug/tracing/trace
Compared to the last posting this patch converts the tracing mostly to
the one tracepoint per callsite model that other users of the new
tracing facility also employ. This allows a very fine-grained control
of the tracing, a cleaner output of the traces and also enables the
perf tool to use each tracepoint as a virtual performance counter,
allowing us to e.g. count how often certain workloads git various
spots in XFS. Take a look at
http://lwn.net/Articles/346470/
for some examples.
Also the btree tracing isn't included at all yet, as it will require
additional core tracing features not in mainline yet, I plan to
deliver it later.
And the really nice thing about this patch is that it actually removes
many lines of code while adding this nice functionality:
fs/xfs/Makefile | 8
fs/xfs/linux-2.6/xfs_acl.c | 1
fs/xfs/linux-2.6/xfs_aops.c | 52 -
fs/xfs/linux-2.6/xfs_aops.h | 2
fs/xfs/linux-2.6/xfs_buf.c | 117 +--
fs/xfs/linux-2.6/xfs_buf.h | 33
fs/xfs/linux-2.6/xfs_fs_subr.c | 3
fs/xfs/linux-2.6/xfs_ioctl.c | 1
fs/xfs/linux-2.6/xfs_ioctl32.c | 1
fs/xfs/linux-2.6/xfs_iops.c | 1
fs/xfs/linux-2.6/xfs_linux.h | 1
fs/xfs/linux-2.6/xfs_lrw.c | 87 --
fs/xfs/linux-2.6/xfs_lrw.h | 45 -
fs/xfs/linux-2.6/xfs_super.c | 104 ---
fs/xfs/linux-2.6/xfs_super.h | 7
fs/xfs/linux-2.6/xfs_sync.c | 1
fs/xfs/linux-2.6/xfs_trace.c | 75 ++
fs/xfs/linux-2.6/xfs_trace.h | 1369 +++++++++++++++++++++++++++++++++++++++++
fs/xfs/linux-2.6/xfs_vnode.h | 4
fs/xfs/quota/xfs_dquot.c | 110 ---
fs/xfs/quota/xfs_dquot.h | 21
fs/xfs/quota/xfs_qm.c | 40 -
fs/xfs/quota/xfs_qm_syscalls.c | 4
fs/xfs/support/ktrace.c | 323 ---------
fs/xfs/support/ktrace.h | 85 --
fs/xfs/xfs.h | 16
fs/xfs/xfs_ag.h | 14
fs/xfs/xfs_alloc.c | 230 +-----
fs/xfs/xfs_alloc.h | 27
fs/xfs/xfs_alloc_btree.c | 1
fs/xfs/xfs_attr.c | 107 ---
fs/xfs/xfs_attr.h | 10
fs/xfs/xfs_attr_leaf.c | 14
fs/xfs/xfs_attr_sf.h | 40 -
fs/xfs/xfs_bmap.c | 507 +++------------
fs/xfs/xfs_bmap.h | 49 -
fs/xfs/xfs_bmap_btree.c | 6
fs/xfs/xfs_btree.c | 5
fs/xfs/xfs_btree_trace.h | 17
fs/xfs/xfs_buf_item.c | 87 --
fs/xfs/xfs_buf_item.h | 20
fs/xfs/xfs_da_btree.c | 3
fs/xfs/xfs_da_btree.h | 7
fs/xfs/xfs_dfrag.c | 2
fs/xfs/xfs_dir2.c | 8
fs/xfs/xfs_dir2_block.c | 20
fs/xfs/xfs_dir2_leaf.c | 21
fs/xfs/xfs_dir2_node.c | 27
fs/xfs/xfs_dir2_sf.c | 26
fs/xfs/xfs_dir2_trace.c | 216 ------
fs/xfs/xfs_dir2_trace.h | 72 --
fs/xfs/xfs_filestream.c | 8
fs/xfs/xfs_fsops.c | 2
fs/xfs/xfs_iget.c | 111 ---
fs/xfs/xfs_inode.c | 67 --
fs/xfs/xfs_inode.h | 76 --
fs/xfs/xfs_inode_item.c | 5
fs/xfs/xfs_iomap.c | 85 --
fs/xfs/xfs_iomap.h | 8
fs/xfs/xfs_log.c | 181 +----
fs/xfs/xfs_log_priv.h | 20
fs/xfs/xfs_log_recover.c | 1
fs/xfs/xfs_mount.c | 2
fs/xfs/xfs_quota.h | 8
fs/xfs/xfs_rename.c | 1
fs/xfs/xfs_rtalloc.c | 1
fs/xfs/xfs_rw.c | 3
fs/xfs/xfs_trans.h | 47 +
fs/xfs/xfs_trans_buf.c | 62 -
fs/xfs/xfs_vnodeops.c | 8
70 files changed, 2151 insertions(+), 2592 deletions(-)
Currently the low-level buffer cache interfaces are highly confusing
as we have a _flags variant of each that does actually respect the
flags, and one without _flags which has a flags argument that gets
ignored and overriden with a default set. Given that very few places
use the default arguments get rid of the duplication and convert all
callers to pass the flags explicitly. Also remove the now confusing
_flags postfix.
Currently we unconditionally issue a flush from xfs_free_buftarg, but
since 2.6.29-rc1 this gives a warning in the style of
end_request: I/O error, dev vdb, sector 0
Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
Signed-off-by: Felix Blyakher <felixb@sgi.com>
Code does nothing so remove it.
Reviewed-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
Replace the b_fspriv pointer and it's ugly accessors with a properly types
xfs_mount pointer. Also switch log reocvery over to it instead of using
b_fspriv for the mount pointer.
xfs_buf_iostart is a "shared" helper for xfs_buf_read_flags,
xfs_bawrite, and xfs_bdwrite - except that there isn't much shared
code but rather special cases for each caller.
So remove this function and move the functionality to the caller.
xfs_bawrite and xfs_bdwrite are now big enough to be moved out of
line and the xfs_buf_read_flags is moved into a new helper called
_xfs_buf_read.
Signed-off-by: Niv Sardi <xaiki@sgi.com>
Currently we disable barriers as soon as we get a buffer in xlog_iodone
that has the XBF_ORDERED flag cleared. But this can be the case not only
for buffers where the barrier failed, but also the first buffer of a
split log write in case of a log wraparound. Due to the disabled
barriers we can easily get directory corruption on unclean shutdowns.
So instead of using this check add a new buffer flag for failed barrier
writes.
This is a regression vs 2.6.26 caused by patch to use the right macro
to check for the ORDERED flag, as we previously got true returned for
every buffer.
Thanks to Toei Rei for reporting the bug.
Reviewed-by: David Chinner <david@fromorbit.com>
Signed-off-by: Tim Shimmin <tes@sgi.com>
The xfs_buf_t b_iodonesema is really just a semaphore that wants to be a
completion. Change it to a completion and remove the last user of the
sema_t from XFS.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31815a
Signed-off-by: David Chinner <david@fromorbit.com>
Currently closing the rt/log block device is done in the wrong spot, and
far too early. So revampt it:
- xfs_blkdev_put moved out of xfs_free_buftarg into the caller so that
it is done after tearing down the buftarg completely.
- call to xfs_unmountfs_close moved from xfs_mountfs into caller so
that it's done after tearing down the filesystem completely.
- xfs_unmountfs_close is renamed to xfs_close_devices and made static
in xfs_super.c
- opening of the block devices is split into a helper xfs_open_devices
that is symetric in use to xfs_close_devices
- xfs_unmountfs can now lose struct cred
- error handling around device opening sanitized in xfs_fs_fill_super
SGI-PV: 981951
SGI-Modid: xfs-linux-melb:xfs-kern:31193a
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: David Chinner <dgc@sgi.com>
When we have multiple buffers in a single page for a blocksize == pagesize
filesystem we might overwrite the page contents if two callers hit it
shortly after each other. To prevent that we need to keep the page locked
until I/O is completed and the page marked uptodate.
Thanks to Eric Sandeen for triaging this bug and finding a reproducible
testcase and Dave Chinner for additional advice.
This should fix kernel.org bz #10421.
Tested-by: Eric Sandeen <sandeen@sandeen.net>
SGI-PV: 981813
SGI-Modid: xfs-linux-melb:xfs-kern:31173a
xfs_bdwrite() cannot return an error; it only queues buffers to the
delayed write list and as such never encounters anything that can fail.
Mark it void.
SGI-PV: 980084
SGI-Modid: xfs-linux-melb:xfs-kern:30825a
There is no need to lock any page in xfs_buf.c because we operate on our
own address_space and all locking is covered by the buffer semaphore. If
we ever switch back to main blockdeive address_space as suggested e.g. for
fsblock with a similar scheme the locking will have to be totally revised
anyway because the current scheme is neither correct nor coherent with
itself.
SGI-PV: 971186
SGI-Modid: xfs-linux-melb:xfs-kern:30156a
SGI-PV: 971596
SGI-Modid: xfs-linux-melb:xfs-kern:29902a
itself.
SGI-PV: 971186
SGI-Modid: xfs-linux-melb:xfs-kern:29845a
Many block drivers (aoe, iscsi) really want refcountable pages in bios,
which is what almost everyone send down. XFS unfortunately has a few
places where it sends down buffers that may come from kmalloc, which
breaks them.
Fix the places that use kmalloc()d buffers.
SGI-PV: 964546
SGI-Modid: xfs-linux-melb:xfs-kern:28562a
Signed-Off-By: Christoph Hellwig <hch@infradead.org>
SGI-PV: 963465
SGI-Modid: xfs-linux-melb:xfs-kern:28414a
The {test,set,clear}_bit() operations take a bit index for the bit to
operate on. The XBT_* flags are defined as bit fields which is incorrect,
not to mention the way the bit fields are enumerated is broken too. This
was only working by chance.
Fix the definitions of the flags and make the code using them use the
{test,set,clear}_bit() operations correctly.
SGI-PV: 958639
SGI-Modid: xfs-linux-melb:xfs-kern:27565a
SGI-PV: 955302
SGI-Modid: xfs-linux-melb:xfs-kern:26749a
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
Signed-off-by: Nathan Scott <nathans@sgi.com>
SGI-PV: 955302
SGI-Modid: xfs-linux-melb:xfs-kern:26746a
flags from iclog buffers before submitting them for writing.
SGI-PV: 954772
SGI-Modid: xfs-linux-melb:xfs-kern:26605a
