xfs_fsync() fails to wait for data I/O completion before checking if the
inode is dirty or clean to decide whether to log the inode or not. This
misses inode size updates when the data flushed by the fsync() is
extending the file.
Hence, like fdatasync(), we need to wait for I/o completion first, then
check the inode for cleanliness. Doing so makes the behaviour of
xfs_fsync() identical for fsync and fdatasync and we *always* use
synchronous semantics if the inode is dirty. Therefore also kill the
differences and remove the unused flags from the xfs_fsync function and
callers.
SGI-PV: 981296
SGI-Modid: xfs-linux-melb:xfs-kern:31033a
Signed-off-by: David Chinner <dgc@sgi.com>
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
The dmapi cruft in xfs_file.c is totally out of date in mainline vs
CVS, and at this point just removing this code which can't be used on
mainline at all seems to be the best option to keep it maintainable.
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30545a
When xfs_file_readdir() exactly fills a buffer, it can move it's index
past the end of the buffer and dereference it even though the result of
the dereference is never used. On some platforms this causes an oops.
SGI-PV: 976923
SGI-Modid: xfs-linux-melb:xfs-kern:30458a
This patch should fix the issue seen on Alpha with unaligned accesses in
the new readdir code. By aligning each dirent to sizeof(u64) we'll avoid
unaligned accesses. To make doubly sure we're not hitting problems also
rearrange struct hack_dirent to avoid holes.
SGI-PV: 975411
SGI-Modid: xfs-linux-melb:xfs-kern:30302a
After reading the directory contents into the temporary buffer, we grab
each dirent and pass it to filldir witht eh current offset of the dirent.
The current offset was not being set for the first dirent in the temporary
buffer, which coul dresult in bad offsets being set in the f_pos field
result in looping and duplicate entries being returned from readdir.
SGI-PV: 974905
SGI-Modid: xfs-linux-melb:xfs-kern:30282a
Signed-off-by: Tim Shimmin <tes@sgi.com>
The recent filldir regression fix was not putting the correct d_off in
each dirent. This was resulting in incorrect cookies being passed to dmapi
ioctls and the wrong offset appearing in the dirents. readdir was
unaffected as the filp->f_pos was being updated with the correct offset
and this was being written into the last dirent in each buffer. Fix the
XFS code to do the right thing.
SGI-PV: 973746
SGI-Modid: xfs-linux-melb:xfs-kern:30240a
The current readdir implementation deadlocks on a btree buffers locks
because nfsd calls back into ->lookup from the filldir callback. The only
short-term fix for this is to revert to the old inefficient
double-buffering scheme.
SGI-PV: 973377
SGI-Modid: xfs-linux-melb:xfs-kern:30201a
All flags are added to xfs_mount's m_flag instead. Note that the 32bit
inode flag was duplicated in both of them, but only cleared in the mount
when it was not nessecary due to the filesystem beeing small enough. Two
flags are still required here - one to indicate the mount option setting,
and one to indicate if it applies or not.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29507a
All flags previously handled at the vnode level are not in the xfs_inode
where we already have a flags mechanisms and free bits for flags
previously in the vnode.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29495a
We can easily get at the vfsp through the super_block but it will soon be
gone anyway.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29494a
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29493a
Currently xfs has a rather complicated internal scheme to allow for
different directory formats in IRIX. This patch rips all code related to
this out and pushes useage of the Linux filldir callback into the lowlevel
directory code. This does not make the code any less portable because
filldir can be used to create dirents of all possible variations
(including the IRIX ones as proved by the IRIX binary emulation code under
arch/mips/).
This patch get rid of an unessecary copy in the readdir path, about 400
lines of code and one of the last two users of the uio structure.
This version is updated to deal with dmapi aswell which greatly simplifies
the get_dirattrs code. The dmapi part has been tested using the
get_dirattrs tools from the xfstest dmapi suite1 with various small and
large directories.
SGI-PV: 968563
SGI-Modid: xfs-linux-melb:xfs-kern:29478a
SGI-PV: 968690
SGI-Modid: xfs-linux-melb:xfs-kern:29340a
Signed-off-by: Vlad Apostolov <vapo@sgi.com>
* 'for-linus' of git://oss.sgi.com:8090/xfs/xfs-2.6:
[XFS] Fix inode size update before data write in xfs_setattr
[XFS] Allow punching holes to free space when at ENOSPC
[XFS] Implement ->page_mkwrite in XFS.
[FS] Implement block_page_mkwrite.
Manually fix up conflict with Nick's VM fault handling patches in
fs/xfs/linux-2.6/xfs_file.c
Change ->fault prototype. We now return an int, which contains
VM_FAULT_xxx code in the low byte, and FAULT_RET_xxx code in the next byte.
FAULT_RET_ code tells the VM whether a page was found, whether it has been
locked, and potentially other things. This is not quite the way he wanted
it yet, but that's changed in the next patch (which requires changes to
arch code).
This means we no longer set VM_CAN_INVALIDATE in the vma in order to say
that a page is locked which requires filemap_nopage to go away (because we
can no longer remain backward compatible without that flag), but we were
going to do that anyway.
struct fault_data is renamed to struct vm_fault as Linus asked. address
is now a void __user * that we should firmly encourage drivers not to use
without really good reason.
The page is now returned via a page pointer in the vm_fault struct.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Nonlinear mappings are (AFAIKS) simply a virtual memory concept that encodes
the virtual address -> file offset differently from linear mappings.
->populate is a layering violation because the filesystem/pagecache code
should need to know anything about the virtual memory mapping. The hitch here
is that the ->nopage handler didn't pass down enough information (ie. pgoff).
But it is more logical to pass pgoff rather than have the ->nopage function
calculate it itself anyway (because that's a similar layering violation).
Having the populate handler install the pte itself is likewise a nasty thing
to be doing.
This patch introduces a new fault handler that replaces ->nopage and
->populate and (later) ->nopfn. Most of the old mechanism is still in place
so there is a lot of duplication and nice cleanups that can be removed if
everyone switches over.
The rationale for doing this in the first place is that nonlinear mappings are
subject to the pagefault vs invalidate/truncate race too, and it seemed stupid
to duplicate the synchronisation logic rather than just consolidate the two.
After this patch, MAP_NONBLOCK no longer sets up ptes for pages present in
pagecache. Seems like a fringe functionality anyway.
NOPAGE_REFAULT is removed. This should be implemented with ->fault, and no
users have hit mainline yet.
[akpm@linux-foundation.org: cleanup]
[randy.dunlap@oracle.com: doc. fixes for readahead]
[akpm@linux-foundation.org: build fix]
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Fix the race between invalidate_inode_pages and do_no_page.
Andrea Arcangeli identified a subtle race between invalidation of pages from
pagecache with userspace mappings, and do_no_page.
The issue is that invalidation has to shoot down all mappings to the page,
before it can be discarded from the pagecache. Between shooting down ptes to
a particular page, and actually dropping the struct page from the pagecache,
do_no_page from any process might fault on that page and establish a new
mapping to the page just before it gets discarded from the pagecache.
The most common case where such invalidation is used is in file truncation.
This case was catered for by doing a sort of open-coded seqlock between the
file's i_size, and its truncate_count.
Truncation will decrease i_size, then increment truncate_count before
unmapping userspace pages; do_no_page will read truncate_count, then find the
page if it is within i_size, and then check truncate_count under the page
table lock and back out and retry if it had subsequently been changed (ptl
will serialise against unmapping, and ensure a potentially updated
truncate_count is actually visible).
Complexity and documentation issues aside, the locking protocol fails in the
case where we would like to invalidate pagecache inside i_size. do_no_page
can come in anytime and filemap_nopage is not aware of the invalidation in
progress (as it is when it is outside i_size). The end result is that
dangling (->mapping == NULL) pages that appear to be from a particular file
may be mapped into userspace with nonsense data. Valid mappings to the same
place will see a different page.
Andrea implemented two working fixes, one using a real seqlock, another using
a page->flags bit. He also proposed using the page lock in do_no_page, but
that was initially considered too heavyweight. However, it is not a global or
per-file lock, and the page cacheline is modified in do_no_page to increment
_count and _mapcount anyway, so a further modification should not be a large
performance hit. Scalability is not an issue.
This patch implements this latter approach. ->nopage implementations return
with the page locked if it is possible for their underlying file to be
invalidated (in that case, they must set a special vm_flags bit to indicate
so). do_no_page only unlocks the page after setting up the mapping
completely. invalidation is excluded because it holds the page lock during
invalidation of each page (and ensures that the page is not mapped while
holding the lock).
This also allows significant simplifications in do_no_page, because we have
the page locked in the right place in the pagecache from the start.
Hook XFS up to ->page_mkwrite to ensure that we know about mmap pages
being written to. This allows use to do correct delayed allocation and
ENOSPC checking as well as remap unwritten extents so that they get
converted correctly during writeback. This is done via the generic
block_page_mkwrite code.
SGI-PV: 940392
SGI-Modid: xfs-linux-melb:xfs-kern:29149a
A check for file_count is always a bad idea. Linux has the ->release
method to deal with cleanups on last close and ->flush is only for the
very rare case where we want to perform an operation on every drop of a
reference to a file struct.
This patch gets rid of vop_close and surrounding code in favour of simply
doing the page flushing from ->release.
SGI-PV: 966562
SGI-Modid: xfs-linux-melb:xfs-kern:28952a
They can use generic_file_splice_read() instead. Since sys_sendfile() now
prefers that, there should be no change in behaviour.
gcc-4.1 and more recent aggressively inline static functions which
increases XFS stack usage by ~15% in critical paths. Prevent this from
occurring by adding noinline to the STATIC definition.
Also uninline some functions that are too large to be inlined and were
causing problems with CONFIG_FORCED_INLINING=y.
Finally, clean up all the different users of inline, __inline and
__inline__ and put them under one STATIC_INLINE macro. For debug kernels
the STATIC_INLINE macro uninlines those functions.
SGI-PV: 957159
SGI-Modid: xfs-linux-melb:xfs-kern:27585a
Signed-off-by: David Chatterton <chatz@sgi.com>
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the xfs
filesystem.
Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu>
This patch removes readv() and writev() methods and replaces them with
aio_read()/aio_write() methods.
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
This patch vectorizes aio_read() and aio_write() methods to prepare for
collapsing all aio & vectored operations into one interface - which is
aio_read()/aio_write().
Cc: Michael Holzheu <HOLZHEU@de.ibm.com>
* Removing useless casts
* Removing useless wrapper
* Conversion from kmalloc+memset to kzalloc
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Acked-by: Dave Kleikamp <shaggy@austin.ibm.com>
Cc: Nathan Scott <nathans@sgi.com>
pure bloat.
SGI-PV: 952969
SGI-Modid: xfs-linux-melb:xfs-kern:26251a
Signed-off-by: Nathan Scott <nathans@sgi.com>
SGI-PV: 904196
SGI-Modid: xfs-linux-melb:xfs-kern:26247a
SGI-PV: 953338
SGI-Modid: xfs-linux-melb:xfs-kern:26107a
truncate down followed by delayed allocation (buffered writes) - worst
case scenario for the notorious NULL files problem. This reduces the
window where we are exposed to that problem significantly.
SGI-PV: 917976
SGI-Modid: xfs-linux-melb:xfs-kern:26100a
mmap only.
SGI-PV: 952736
SGI-Modid: xfs-linux-melb:xfs-kern:25922a
We need not use ->f_pos as the offset for the file input/output. If the
user passed an offset pointer in through sys_splice(), just use that and
leave ->f_pos alone.
Signed-off-by: Jens Axboe <axboe@suse.de>
separate out the 'internal pipe object' abstraction, and make it
usable to splice. This cleans up and fixes several aspects of the
internal splice APIs and the pipe code:
- pipes: the allocation and freeing of pipe_inode_info is now more symmetric
and more streamlined with existing kernel practices.
- splice: small micro-optimization: less pointer dereferencing in splice
methods
Update XFS for the ->splice_read/->splice_write changes.
This is a conversion to make the various file_operations structs in fs/
const. Basically a regexp job, with a few manual fixups
The goal is both to increase correctness (harder to accidentally write to
shared datastructures) and reducing the false sharing of cachelines with
things that get dirty in .data (while .rodata is nicely read only and thus
cache clean)
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
SGI-PV: 947038
SGI-Modid: xfs-linux-melb:xfs-kern:25474a
help here and vattr may be small enough.
SGI-PV: 947312
SGI-Modid: xfs-linux-melb:xfs-kern:25423a
naming.
SGI-PV: 950556
SGI-Modid: xfs-linux-melb:xfs-kern:25379a
reduce stack use. Also re-use vattr in some places so that multiple
copies are not held on-stack.
SGI-PV: 947312
SGI-Modid: xfs-linux-melb:xfs-kern:25369a
to reduce stack footprint.
SGI-PV: 947312
SGI-Modid: xfs-linux-melb:xfs-kern:25358a
SGI-PV: 947206
SGI-Modid: xfs-linux-melb:xfs-kern:203960a
Signed-off-by: Christoph Hellwig <hch@sgi.com>
boilerplate.
SGI-PV: 913862
SGI-Modid: xfs-linux:xfs-kern:23903a
SGI-PV: 943122
SGI-Modid: xfs-linux:xfs-kern:23901a
SGI-PV: 935317
SGI-Modid: xfs-linux:xfs-kern:192007a
Signed-off-by: Dean Roehrich <roehrich@sgi.com>
SGI-PV: 933551
SGI-Modid: xfs-linux:xfs-kern:190622a
SGI Modid: xfs-linux:xfs-kern:21810a
handling for unwritten extents can be moved out of interrupt context.
SGI Modid: xfs-linux:xfs-kern:22343a
infrastructure for it.
Let it rip!
