Cleanup the unneeded intermediate vnode step in the flushing helpers and
go directly from the xfs_inode to the struct address_space.
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30530a
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
All flags previously handled at the vnode level are not in the xfs_inode
where we already have a flags mechanisms and free bits for flags
previously in the vnode.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29495a
Signed-off-by: David Chinner <dgc@sgi.com>
Signed-off-by: Tim Shimmin <tes@sgi.com>
All vnode ops now take struct xfs_inode pointers and the behaviour related
glue is split out into methods of it's own. This required fixing
xfs_create/mkdir/symlink to not mess with the inode pointer but rather use
a separate boolean for error handling. Thanks to Dave Chinner for that
fix.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29492a
This patch handles error return values in fs_flush_pages and
fs_flushinval_pages. It changes the prototype of fs_flushinval_pages so we
can propogate the errors and handle them at higher layers. I also modified
xfs_itruncate_start so that it could propogate the error further.
SGI-PV: 961990
SGI-Modid: xfs-linux-melb:xfs-kern:28231a
Signed-off-by: Stewart Smith <stewart@flamingspork.com>
SGI-PV: 953338
SGI-Modid: xfs-linux-melb:xfs-kern:26107a
Signed-off-by: Nathan Scott <nathans@sgi.com>
truncate down followed by delayed allocation (buffered writes) - worst
case scenario for the notorious NULL files problem. This reduces the
window where we are exposed to that problem significantly.
SGI-PV: 917976
SGI-Modid: xfs-linux-melb:xfs-kern:26100a
SGI-PV: 947038
SGI-Modid: xfs-linux-melb:xfs-kern:25474a
This patch add EXPORT_SYMBOL(filemap_write_and_wait) and use it.
See mm/filemap.c:
And changes the filemap_write_and_wait() and filemap_write_and_wait_range().
Current filemap_write_and_wait() doesn't wait if filemap_fdatawrite()
returns error. However, even if filemap_fdatawrite() returned an
error, it may have submitted the partially data pages to the device.
(e.g. in the case of -ENOSPC)
<quotation>
Andrew Morton writes,
If filemap_fdatawrite() returns an error, this might be due to some
I/O problem: dead disk, unplugged cable, etc. Given the generally
crappy quality of the kernel's handling of such exceptions, there's a
good chance that the filemap_fdatawait() will get stuck in D state
forever.
</quotation>
So, this patch doesn't wait if filemap_fdatawrite() returns the -EIO.
Trond, could you please review the nfs part? Especially I'm not sure,
nfs must use the "filemap_fdatawrite(inode->i_mapping) == 0", or not.
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
boilerplate.
SGI-PV: 913862
SGI-Modid: xfs-linux:xfs-kern:23903a
SGI-PV: 942815
SGI-Modid: xfs-linux:xfs-kern:23829a
infrastructure for it.
Let it rip!
