Convert the old xfs tracing support that could only be used with the
out of tree kdb and xfsidbg patches to use the generic event tracer.
To use it make sure CONFIG_EVENT_TRACING is enabled and then enable
all xfs trace channels by:
echo 1 > /sys/kernel/debug/tracing/events/xfs/enable
or alternatively enable single events by just doing the same in one
event subdirectory, e.g.
echo 1 > /sys/kernel/debug/tracing/events/xfs/xfs_ihold/enable
or set more complex filters, etc. In Documentation/trace/events.txt
all this is desctribed in more detail. To reads the events do a
cat /sys/kernel/debug/tracing/trace
Compared to the last posting this patch converts the tracing mostly to
the one tracepoint per callsite model that other users of the new
tracing facility also employ. This allows a very fine-grained control
of the tracing, a cleaner output of the traces and also enables the
perf tool to use each tracepoint as a virtual performance counter,
allowing us to e.g. count how often certain workloads git various
spots in XFS. Take a look at
http://lwn.net/Articles/346470/
for some examples.
Also the btree tracing isn't included at all yet, as it will require
additional core tracing features not in mainline yet, I plan to
deliver it later.
And the really nice thing about this patch is that it actually removes
many lines of code while adding this nice functionality:
fs/xfs/Makefile | 8
fs/xfs/linux-2.6/xfs_acl.c | 1
fs/xfs/linux-2.6/xfs_aops.c | 52 -
fs/xfs/linux-2.6/xfs_aops.h | 2
fs/xfs/linux-2.6/xfs_buf.c | 117 +--
fs/xfs/linux-2.6/xfs_buf.h | 33
fs/xfs/linux-2.6/xfs_fs_subr.c | 3
fs/xfs/linux-2.6/xfs_ioctl.c | 1
fs/xfs/linux-2.6/xfs_ioctl32.c | 1
fs/xfs/linux-2.6/xfs_iops.c | 1
fs/xfs/linux-2.6/xfs_linux.h | 1
fs/xfs/linux-2.6/xfs_lrw.c | 87 --
fs/xfs/linux-2.6/xfs_lrw.h | 45 -
fs/xfs/linux-2.6/xfs_super.c | 104 ---
fs/xfs/linux-2.6/xfs_super.h | 7
fs/xfs/linux-2.6/xfs_sync.c | 1
fs/xfs/linux-2.6/xfs_trace.c | 75 ++
fs/xfs/linux-2.6/xfs_trace.h | 1369 +++++++++++++++++++++++++++++++++++++++++
fs/xfs/linux-2.6/xfs_vnode.h | 4
fs/xfs/quota/xfs_dquot.c | 110 ---
fs/xfs/quota/xfs_dquot.h | 21
fs/xfs/quota/xfs_qm.c | 40 -
fs/xfs/quota/xfs_qm_syscalls.c | 4
fs/xfs/support/ktrace.c | 323 ---------
fs/xfs/support/ktrace.h | 85 --
fs/xfs/xfs.h | 16
fs/xfs/xfs_ag.h | 14
fs/xfs/xfs_alloc.c | 230 +-----
fs/xfs/xfs_alloc.h | 27
fs/xfs/xfs_alloc_btree.c | 1
fs/xfs/xfs_attr.c | 107 ---
fs/xfs/xfs_attr.h | 10
fs/xfs/xfs_attr_leaf.c | 14
fs/xfs/xfs_attr_sf.h | 40 -
fs/xfs/xfs_bmap.c | 507 +++------------
fs/xfs/xfs_bmap.h | 49 -
fs/xfs/xfs_bmap_btree.c | 6
fs/xfs/xfs_btree.c | 5
fs/xfs/xfs_btree_trace.h | 17
fs/xfs/xfs_buf_item.c | 87 --
fs/xfs/xfs_buf_item.h | 20
fs/xfs/xfs_da_btree.c | 3
fs/xfs/xfs_da_btree.h | 7
fs/xfs/xfs_dfrag.c | 2
fs/xfs/xfs_dir2.c | 8
fs/xfs/xfs_dir2_block.c | 20
fs/xfs/xfs_dir2_leaf.c | 21
fs/xfs/xfs_dir2_node.c | 27
fs/xfs/xfs_dir2_sf.c | 26
fs/xfs/xfs_dir2_trace.c | 216 ------
fs/xfs/xfs_dir2_trace.h | 72 --
fs/xfs/xfs_filestream.c | 8
fs/xfs/xfs_fsops.c | 2
fs/xfs/xfs_iget.c | 111 ---
fs/xfs/xfs_inode.c | 67 --
fs/xfs/xfs_inode.h | 76 --
fs/xfs/xfs_inode_item.c | 5
fs/xfs/xfs_iomap.c | 85 --
fs/xfs/xfs_iomap.h | 8
fs/xfs/xfs_log.c | 181 +----
fs/xfs/xfs_log_priv.h | 20
fs/xfs/xfs_log_recover.c | 1
fs/xfs/xfs_mount.c | 2
fs/xfs/xfs_quota.h | 8
fs/xfs/xfs_rename.c | 1
fs/xfs/xfs_rtalloc.c | 1
fs/xfs/xfs_rw.c | 3
fs/xfs/xfs_trans.h | 47 +
fs/xfs/xfs_trans_buf.c | 62 -
fs/xfs/xfs_vnodeops.c | 8
70 files changed, 2151 insertions(+), 2592 deletions(-)
Signed-off-by: Alex Elder <aelder@sgi.com>
We set the IO_ISAIO flag for all read/write I/O since early Linux
2.6.x. Remove it as it has lost it's purpose long ago.
Reviewed-by: Dave Chinner <david@fromorbit.com>
Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
Remove this rather pointless wrapper and use is_bad_inode directly.
Two out of three are unused already, and the third is better done open-coded
with a comment describing what's going on here.
Splitting the task for a VFS-induced inode flush into two functions doesn't
make any sense, so merge the two functions dealing with it.
Reviewed-by: Felix Blyakher <felixb@sgi.com>
Move the inode tracing into xfs_iget.c / xfs_inode.h and kill xfs_vnode.c
now that it's empty.
Signed-off-by: Niv Sardi <xaiki@sgi.com>
The whole machinery to wait on I/O completion is related to the I/O path
and should be there instead of in xfs_vnode.c. Also give the functions
more descriptive names.
There's just one caller of this helper, and it's much cleaner to just merge
the xfs_do_force_shutdown call into it.
Currently we explicitly call xfs_iflush on the quota, real-time and root
inodes from xfs_unmount_flush. But we just called xfs_sync_inodes with
SYNC_ATTR and do an XFS_bflush aka xfs_flush_buftarg to make sure all inodes
are on disk already, so there is no need for these special cases.
The only thing left are the forced shutdown flags and freeze macros which
fit into xfs_mount.h much better.
With the sync code relocated to the linux-2.6 directory we can use struct
inodes directly. If we do the same thing for the quota release code, we
can remove vn_grab altogether. While here, convert the VN_BAD() checks to
is_bad_inode() so we can remove vnodes entirely from this code.
SGI-PV: 988140
SGI-Modid: xfs-linux-melb:xfs-kern:32304a
Signed-off-by: David Chinner <david@fromorbit.com>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
Signed-off-by: Christoph Hellwig <hch@infradead.org>
All remaining bhv_vnode_t instance are in code that's more or less Linux
specific. (Well, for xfs_acl.c that could be argued, but that code is on
the removal list, too). So just do an s/bhv_vnode_t/struct inode/ over the
whole tree. We can clean up variable naming and some useless helpers
later.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31781a
Now that all direct calls to VN_HOLD/VN_RELE are gone we can implement
IHOLD/IRELE directly.
For the IHOLD case also replace igrab with a direct increment of i_count
because we are guaranteed to already have a live and referenced inode by
the VFS. Also remove the vn_hold statistic because it's been rather
meaningless for some time with most references done by other callers.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31764a
bhv_vnode_t is just a typedef for struct inode, so there's
no need for a helper to convert between the two.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31761a
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31760a
xfs_vtoi() is redundant and only unsed in small sections of code.
Replace them with widely used XFS_I() inline and kill xfs_vtoi().
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31725a
These days most of the attributes in struct inode are properly kept in
sync by XFS. This patch removes the need for vn_revalidate completely by:
- keeping inode.i_flags uptodate after any flags are updated in
xfs_ioctl_setattr
- keeping i_mode, i_uid and i_gid uptodate in xfs_setattr
SGI-PV: 984566
SGI-Modid: xfs-linux-melb:xfs-kern:31679a
Signed-off-by: Tim Shimmin <tes@sgi.com>
it can be switched to take struct iattr directly and thus simplify the
implementation greatly. Also rename the ATTR_ flags to XFS_ATTR_ to not
conflict with the ATTR_ flags used by the VFS.
SGI-PV: 984565
SGI-Modid: xfs-linux-melb:xfs-kern:31678a
->setattr but also addition XFS-specific attributes: project id, inode
flags and extent size hint. Having these in a single function makes it
more complicated and forces to have us a bhv_vattr intermediate structure
eating up stackspace.
This patch adds a new xfs_ioctl_setattr helper for the XFS ioctls that set
these attributes and remove the code to set them through xfs_setattr.
SGI-PV: 984564
SGI-Modid: xfs-linux-melb:xfs-kern:31677a
xfs_fsync() fails to wait for data I/O completion before checking if the
inode is dirty or clean to decide whether to log the inode or not. This
misses inode size updates when the data flushed by the fsync() is
extending the file.
Hence, like fdatasync(), we need to wait for I/o completion first, then
check the inode for cleanliness. Doing so makes the behaviour of
xfs_fsync() identical for fsync and fdatasync and we *always* use
synchronous semantics if the inode is dirty. Therefore also kill the
differences and remove the unused flags from the xfs_fsync function and
callers.
SGI-PV: 981296
SGI-Modid: xfs-linux-melb:xfs-kern:31033a
Signed-off-by: David Chinner <dgc@sgi.com>
We can just check i_mode / di_mode directly.
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30896a
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30804a
Signed-off-by: Barry Naujok <bnaujok@sgi.com>
__FUNCTION__ is gcc-specific, use __func__
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30775a
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
We can just use xfs_ilock/xfs_iunlock instead and get rid of the ugly
bhv_vrwlock_t.
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30533a
Instead of of xfs_get_dir_entry use a macro to get the xfs_inode from the
dentry in the callers and grab the reference manually.
Only grab the reference once as it's fine to keep it over the dmapi calls.
(And even that reference is actually superflous in Linux but I'll leave
that for another patch)
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30531a
When pdflush is writing back inodes, it can get stuck on inode cluster
buffers that are currently under I/O. This occurs when we write data to
multiple inodes in the same inode cluster at the same time.
Effectively, delayed allocation marks the inode dirty during the data
writeback. Hence if the inode cluster was flushed during the writeback of
the first inode, the writeback of the second inode will block waiting for
the inode cluster write to complete before writing it again for the newly
dirtied inode.
Basically, we want to avoid this from happening so we don't block pdflush
and slow down all of writeback. Hence we introduce a non-blocking async
inode flush flag that pdflush uses. If this flag is set, we use
non-blocking operations (e.g. try locks) whereever we can to avoid
blocking or extra I/O being issued.
SGI-PV: 970925
SGI-Modid: xfs-linux-melb:xfs-kern:30501a
Get rid of vnode useage in xfs_iget.c and pass Linux inode / xfs_inode
where apropinquate. And kill some useless helpers while we're at it.
SGI-PV: 971186
SGI-Modid: xfs-linux-melb:xfs-kern:29808a
No need to allocate a bhv_vattr_t on stack and call xfs_getattr to update
a few fields in the Linux inode from the XFS inode, just do it directly.
And yes, this function is in dire need of a better name and prototype,
I'll do in a separate patch, though.
SGI-PV: 970705
SGI-Modid: xfs-linux-melb:xfs-kern:29713a
SGI-PV: 970335
SGI-Modid: xfs-linux-melb:xfs-kern:29697a
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
Simplify vnode tracing calls by embedding function name & return addr in
the calling macro.
Also do a lot of vnode->inode renaming for consistency, while we're at it.
SGI-PV: 970335
SGI-Modid: xfs-linux-melb:xfs-kern:29650a
Now that struct bhv_vfs doesn't have any members left we can kill it and
go directly from the super_block to the xfs_mount everywhere.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29509a
Now that struct bhv_vnode is empty we can just kill it. Retain bhv_vnode_t
as a typedef for struct inode for the time being until all the fallout is
cleaned up.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29500a
It's entirely unused except for ignored arguments in the mrlock
initialization, so remove it.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29499a
struct bhv_vnode is on it's way out, so move the trace buffer to the XFS
inode. Note that this makes the tracing macros rather misnamed, but this
kind of fallout will be fixed up incrementally later on.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29498a
struct bhv_vnode is on it's way out, so move the I/O count to the XFS
inode.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29497a
All flags previously handled at the vnode level are not in the xfs_inode
where we already have a flags mechanisms and free bits for flags
previously in the vnode.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29495a
We can easily get at the vfsp through the super_block but it will soon be
gone anyway.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29494a
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29493a
Simplify the readlink code to get rid of the last user of uio.
SGI-PV: 968563
SGI-Modid: xfs-linux-melb:xfs-kern:29479a
Currently xfs has a rather complicated internal scheme to allow for
different directory formats in IRIX. This patch rips all code related to
this out and pushes useage of the Linux filldir callback into the lowlevel
directory code. This does not make the code any less portable because
filldir can be used to create dirents of all possible variations
(including the IRIX ones as proved by the IRIX binary emulation code under
arch/mips/).
This patch get rid of an unessecary copy in the readdir path, about 400
lines of code and one of the last two users of the uio structure.
This version is updated to deal with dmapi aswell which greatly simplifies
the get_dirattrs code. The dmapi part has been tested using the
get_dirattrs tools from the xfstest dmapi suite1 with various small and
large directories.
SGI-PV: 968563
SGI-Modid: xfs-linux-melb:xfs-kern:29478a
A check for file_count is always a bad idea. Linux has the ->release
method to deal with cleanups on last close and ->flush is only for the
very rare case where we want to perform an operation on every drop of a
reference to a file struct.
This patch gets rid of vop_close and surrounding code in favour of simply
doing the page flushing from ->release.
SGI-PV: 966562
SGI-Modid: xfs-linux-melb:xfs-kern:28952a
They can use generic_file_splice_read() instead. Since sys_sendfile() now
prefers that, there should be no change in behaviour.
This patch handles error return values in fs_flush_pages and
fs_flushinval_pages. It changes the prototype of fs_flushinval_pages so we
can propogate the errors and handle them at higher layers. I also modified
xfs_itruncate_start so that it could propogate the error further.
SGI-PV: 961990
SGI-Modid: xfs-linux-melb:xfs-kern:28231a
Signed-off-by: Stewart Smith <stewart@flamingspork.com>
gcc-4.1 and more recent aggressively inline static functions which
increases XFS stack usage by ~15% in critical paths. Prevent this from
occurring by adding noinline to the STATIC definition.
Also uninline some functions that are too large to be inlined and were
causing problems with CONFIG_FORCED_INLINING=y.
Finally, clean up all the different users of inline, __inline and
__inline__ and put them under one STATIC_INLINE macro. For debug kernels
the STATIC_INLINE macro uninlines those functions.
SGI-PV: 957159
SGI-Modid: xfs-linux-melb:xfs-kern:27585a
Signed-off-by: David Chatterton <chatz@sgi.com>
semantics.
SGI-PV: 954580
SGI-Modid: xfs-linux-melb:xfs-kern:26563a
Signed-off-by: Nathan Scott <nathans@sgi.com>
flags and mode of final inode are looked at. Pass original inode
instead. * Two occurences of bhv_vnode_t go out.
SGI-PV: 904196
SGI-Modid: xfs-linux-melb:xfs-kern:26298a
porters.
SGI-PV: 953338
SGI-Modid: xfs-linux-melb:xfs-kern:26108a
SGI-PV: 953338
SGI-Modid: xfs-linux-melb:xfs-kern:26107a
SGI-PV: 9533338
SGI-Modid: xfs-linux-melb:xfs-kern:26106a
truncate down followed by delayed allocation (buffered writes) - worst
case scenario for the notorious NULL files problem. This reduces the
window where we are exposed to that problem significantly.
SGI-PV: 917976
SGI-Modid: xfs-linux-melb:xfs-kern:26100a
