The delayed logging code only changes in-memory structures and as
such can be enabled and disabled with a mount option. Add the mount
option and emit a warning that this is an experimental feature that
should not be used in production yet.
We also need infrastructure to track committed items that have not
yet been written to the log. This is what the Committed Item List
(CIL) is for.
The log item also needs to be extended to track the current log
vector, the associated memory buffer and it's location in the Commit
Item List. Extend the log item and log vector structures to enable
this tracking.
To maintain the current log format for transactions with delayed
logging, we need to introduce a checkpoint transaction and a context
for tracking each checkpoint from initiation to transaction
completion. This includes adding a log ticket for tracking space
log required/used by the context checkpoint.
To track all the changes we need an io vector array per log item,
rather than a single array for the entire transaction. Using the new
log vector structure for this requires two passes - the first to
allocate the log vector structures and chain them together, and the
second to fill them out. This log vector chain can then be passed
to the CIL for formatting, pinning and insertion into the CIL.
Formatting of the log vector chain is relatively simple - it's just
a loop over the iovecs on each log vector, but it is made slightly
more complex because we re-write the iovec after the copy to point
back at the memory buffer we just copied into.
This code also needs to pin log items. If the log item is not
already tracked in this checkpoint context, then it needs to be
pinned. Otherwise it is already pinned and we don't need to pin it
again.
The only other complexity is calculating the amount of new log space
the formatting has consumed. This needs to be accounted to the
transaction in progress, and the accounting is made more complex
becase we need also to steal space from it for log metadata in the
checkpoint transaction. Calculate all this at insert time and update
all the tickets, counters, etc correctly.
Once we've formatted all the log items in the transaction, attach
the busy extents to the checkpoint context so the busy extents live
until checkpoint completion and can be processed at that point in
time. Transactions can then be freed at this point in time.
Now we need to issue checkpoints - we are tracking the amount of log space
used by the items in the CIL, so we can trigger background checkpoints when the
space usage gets to a certain threshold. Otherwise, checkpoints need ot be
triggered when a log synchronisation point is reached - a log force event.
Because the log write code already handles chained log vectors, writing the
transaction is trivial, too. Construct a transaction header, add it
to the head of the chain and write it into the log, then issue a
commit record write. Then we can release the checkpoint log ticket
and attach the context to the log buffer so it can be called during
Io completion to complete the checkpoint.
We also need to allow for synchronising multiple in-flight
checkpoints. This is needed for two things - the first is to ensure
that checkpoint commit records appear in the log in the correct
sequence order (so they are replayed in the correct order). The
second is so that xfs_log_force_lsn() operates correctly and only
flushes and/or waits for the specific sequence it was provided with.
To do this we need a wait variable and a list tracking the
checkpoint commits in progress. We can walk this list and wait for
the checkpoints to change state or complete easily, an this provides
the necessary synchronisation for correct operation in both cases.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
When we free a metadata extent, we record it in the per-AG busy
extent array so that it is not re-used before the freeing
transaction hits the disk. This array is fixed size, so when it
overflows we make further allocation transactions synchronous
because we cannot track more freed extents until those transactions
hit the disk and are completed. Under heavy mixed allocation and
freeing workloads with large log buffers, we can overflow this array
quite easily.
Further, the array is sparsely populated, which means that inserts
need to search for a free slot, and array searches often have to
search many more slots that are actually used to check all the
busy extents. Quite inefficient, really.
To enable this aspect of extent freeing to scale better, we need
a structure that can grow dynamically. While in other areas of
XFS we have used radix trees, the extents being freed are at random
locations on disk so are better suited to being indexed by an rbtree.
So, use a per-AG rbtree indexed by block number to track busy
extents. This incures a memory allocation when marking an extent
busy, but should not occur too often in low memory situations. This
should scale to an arbitrary number of extents so should not be a
limitation for features such as in-memory aggregation of
transactions.
However, there are still situations where we can't avoid allocating
busy extents (such as allocation from the AGFL). To minimise the
overhead of such occurences, we need to avoid doing a synchronous
log force while holding the AGF locked to ensure that the previous
transactions are safely on disk before we use the extent. We can do
this by marking the transaction doing the allocation as synchronous
rather issuing a log force.
Because of the locking involved and the ordering of transactions,
the synchronous transaction provides the same guarantees as a
synchronous log force because it ensures that all the prior
transactions are already on disk when the synchronous transaction
hits the disk. i.e. it preserves the free->allocate order of the
extent correctly in recovery.
By doing this, we avoid holding the AGF locked while log writes are
in progress, hence reducing the length of time the lock is held and
therefore we increase the rate at which we can allocate and free
from the allocation group, thereby increasing overall throughput.
The only problem with this approach is that when a metadata buffer is
marked stale (e.g. a directory block is removed), then buffer remains
pinned and locked until the log goes to disk. The issue here is that
if that stale buffer is reallocated in a subsequent transaction, the
attempt to lock that buffer in the transaction will hang waiting
the log to go to disk to unlock and unpin the buffer. Hence if
someone tries to lock a pinned, stale, locked buffer we need to
push on the log to get it unlocked ASAP. Effectively we are trading
off a guaranteed log force for a much less common trigger for log
force to occur.
Ideally we should not reallocate busy extents. That is a much more
complex fix to the problem as it involves direct intervention in the
allocation btree searches in many places. This is left to a future
set of modifications.
Finally, now that we track busy extents in allocated memory, we
don't need the descriptors in the transaction structure to point to
them. We can replace the complex busy chunk infrastructure with a
simple linked list of busy extents. This allows us to remove a large
chunk of code, making the overall change a net reduction in code
size.
Signed-off-by: Dave Chinner <david@fromorbit.com>
Clean up the buffer log format (XFS_BLI_*) flags because they have a
polluted namespace. They XFS_BLI_ prefix is used for both in-memory
and on-disk flag feilds, but have overlapping values for different
flags. Rename the buffer log format flags to use the XFS_BLF_*
prefix to avoid confusing them with the in-memory XFS_BLI_* prefixed
flags.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (69 commits)
fix handling of offsets in cris eeprom.c, get rid of fake on-stack files
get rid of home-grown mutex in cris eeprom.c
switch ecryptfs_write() to struct inode *, kill on-stack fake files
switch ecryptfs_get_locked_page() to struct inode *
simplify access to ecryptfs inodes in ->readpage() and friends
AFS: Don't put struct file on the stack
Ban ecryptfs over ecryptfs
logfs: replace inode uid,gid,mode initialization with helper function
ufs: replace inode uid,gid,mode initialization with helper function
udf: replace inode uid,gid,mode init with helper
ubifs: replace inode uid,gid,mode initialization with helper function
sysv: replace inode uid,gid,mode initialization with helper function
reiserfs: replace inode uid,gid,mode initialization with helper function
ramfs: replace inode uid,gid,mode initialization with helper function
omfs: replace inode uid,gid,mode initialization with helper function
bfs: replace inode uid,gid,mode initialization with helper function
ocfs2: replace inode uid,gid,mode initialization with helper function
nilfs2: replace inode uid,gid,mode initialization with helper function
minix: replace inode uid,gid,mode init with helper
ext4: replace inode uid,gid,mode init with helper
Trivial conflict in fs/fs-writeback.c (mark bitfields unsigned)
fs/ext3/fsync.c
Pass the larger struct fs_disk_quota to the ->set_dqblk operation so
that the Q_SETQUOTA and Q_XSETQUOTA operations can be implemented
with a single filesystem operation and we can retire the ->set_xquota
operation. The additional information (RT-subvolume accounting and
warn counts) are left zero for the VFS quota implementation.
Add new fieldmask values for setting the numer of blocks and inodes
values which is required for the VFS quota, but wasn't for XFS.
Pass the larger struct fs_disk_quota to the ->get_dqblk operation so
that the Q_GETQUOTA and Q_XGETQUOTA operations can be implemented
with a single filesystem operation and we can retire the ->get_xquota
Rename all iomap_valid identifiers to imap_valid to fit the new
world order, and clean up xfs_iomap_valid to convert the passed in
offset to blocks instead of the imap values to bytes. Use the
simpler inode->i_blkbits instead of the XFS macros for this.
The IOMAP_ flags are now only used inside xfs_aops.c for extent
probing and I/O completion tracking, so more them here, and rename
them to IO_* as there's no mapping involved at all.
Now that struct xfs_iomap contains exactly the same units as struct
xfs_bmbt_irec we can just use the latter directly in the aops code.
Replace the missing IOMAP_NEW flag with a new boolean output
parameter to xfs_iomap.
Report the iomap_bn field of struct xfs_iomap in terms of filesystem
blocks instead of in terms of bytes. Shift the byte conversions
into the caller, and replace the IOMAP_DELAY and IOMAP_HOLE flag
checks with checks for HOLESTARTBLOCK and DELAYSTARTBLOCK.
Report the iomap_offset and iomap_bsize fields of struct xfs_iomap
in terms of fsblocks instead of in terms of disk blocks. Shift the
byte conversions into the callers temporarily, but they will
disappear or get cleaned up later.
The iomap_delta field in struct xfs_iomap just contains the
difference between the offset passed to xfs_iomap and the
iomap_offset. Just calculate it in the only caller that cares.
Instead of using the iomap_target field in struct xfs_iomap
and the IOMAP_REALTIME flag just use the already existing
xfs_find_bdev_for_inode helper. There's some fallout as we
need to pass the inode in a few more places, which we also
use to sanitize some calling conventions.
According to Documentation/filesystems/fiemap.txt, If fm_extent_count
is zero, then the fm_extents[] array is ignored (no extents will be
returned), and the fm_mapped_extents count will hold the number of
extents needed.
But as the commit 97db39a1f6f69e906e98118392400de5217aa33a has changed
bmv_count to the caller's input buffer, this number query function can't
work any more. As this commit is written to change bmv_count from
MAXEXTNUM because of ENOMEM.
This patch just try to set bm.bmv_count to something sane.
Thanks to Dave Chinner <david@fromorbit.com> for the suggestion.
Cc: Eric Sandeen <sandeen@redhat.com>
Cc: Alex Elder <aelder@sgi.com>
Signed-off-by: Tao Ma <tao.ma@oracle.com>
We need to wait for all pending direct I/O requests before taking care of
metadata in fsync and write_inode.
Reviewed-by: Dave Chinner <david@fromorbit.com>
fs/xfs/linux-2.6/xfs_trace.c: xfs_attr_sf.h is included more than once.
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
xfs_bwrite is used with the intention of synchronously writing out
buffers, but currently it does not actually clear the async flag if
that's left from previous writes but instead implements async
behaviour if it finds it. Remove the code handling asynchronous
writes as we've got rid of those entirely outside of the log and
delwri buffers, and make sure that we clear the async and read flags
before writing the buffer.
All modifications to the superblock are done transactional through
xfs_trans_log_buf, so there is no reason to initiate periodic
asynchronous writeback. This only removes the superblock from the
delwri list and will lead to sub-optimal I/O scheduling.
Cut down xfs_sync_fsdata now that it's only used for synchronous
superblock writes and move the log coverage checks into the two
callers.
Convert the dquot hash list on the filesystem to use listhead
infrastructure rather than the roll-your-own in the quota code.
The dquot shaker and the free-list reclaim code use exactly the same
algorithm but the code is duplicated and slightly different in each
case. Make the shaker code use the single dquot reclaim code to
remove the code duplication.
Currently there is no tracing in log recovery, so it is difficult to
determine what is going on when something goes wrong.
Add tracing for log item recovery to provide visibility into the log
recovery process. The tracing added shows regions being extracted
from the log transactions and added to the transaction hash forming
recovery items, followed by the reordering, cancelling and finally
recovery of the items.
We don't record pin counts in inode events right now, and this makes
it difficult to track down problems related to pinning inodes. Add
the pin count to the inode trace class and add trace events for
pinning and unpinning inodes.
This allows to see in `ps` and similar tools which kthreads are
allotted to which block device/filesystem, similar to what jbd2
does. As the process name is a fixed 16-char array, no extra
space is needed in tasks.
PID TTY STAT TIME COMMAND
2 ? S 0:00 [kthreadd]
197 ? S 0:00 \_ [jbd2/sda2-8]
198 ? S 0:00 \_ [ext4-dio-unwrit]
204 ? S 0:00 \_ [flush-8:0]
2647 ? S 0:00 \_ [xfs_mru_cache]
2648 ? S 0:00 \_ [xfslogd/0]
2649 ? S 0:00 \_ [xfsdatad/0]
2650 ? S 0:00 \_ [xfsconvertd/0]
2651 ? S 0:00 \_ [xfsbufd/ram0]
2652 ? S 0:00 \_ [xfsaild/ram0]
2653 ? S 0:00 \_ [xfssyncd/ram0]
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
The am_hreq.opcount field in the xfs_attrmulti_by_handle() interface
is not bounded correctly. The opcount is used to determine the size
of the buffer required. The size is bounded, but can overflow and so
the size checks may not be sufficient to catch invalid opcounts.
Fix it by catching opcount values that would cause overflows before
calculating the size.
Signed-off-by: Zhitong Wang <zhitong.wangzt@alibaba-inc.com>
On low memory boxes or those with highmem, kernel can OOM before the
background reclaims inodes via xfssyncd. Add a shrinker to run inode
reclaim so that it inode reclaim is expedited when memory is low.
This is more complex than it needs to be because the VM folk don't
want a context added to the shrinker infrastructure. Hence we need
to add a global list of XFS mount structures so the shrinker can
traverse them.
fs/block_dev.c
The patch just convert all blkdev_issue_xxx function to common
set of flags. Wait/allocation semantics preserved.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Any inode reclaim flush that returns EAGAIN will result in the inode
reclaim being attempted again later. There is no need to issue a
warning into the logs about this situation.
Reviewed-by: Alex Elder <aelder@sgi.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
If we are doing a forced shutdown, we can get lots of noise about
delalloc pages being discarded. This is happens by design during a
forced shutdown, so don't spam the logs with these messages.
Re-apply a commit that had been reverted due to regressions
that have since been fixed.
From 95f8e302c04c0b0c6de35ab399a5551605eeb006 Mon Sep 17 00:00:00 2001
Date: Tue, 6 Jan 2009 14:43:09 +1100
Implement XFS's large buffer support with the new vmap APIs. See the vmap
rewrite (db64fe02) for some numbers. The biggest improvement that comes from
using the new APIs is avoiding the global KVA allocation lock on every call.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Reviewed-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
Only modifications here were a minor reformat, plus making the patch
apply given the new use of xfs_buf_is_vmapped().
Modified-by: Alex Elder <aelder@sgi.com>
Original commit: d2859751cd0bf586941ffa7308635a293f943c17
Author: Nick Piggin <npiggin@suse.de>
Date: Tue, 6 Jan 2009 14:40:44 +1100
XFS's vmap batching simply defers a number (up to 64) of vunmaps,
and keeps track of them in a list. To purge the batch, it just goes
through the list and calls vunamp on each one. This is pretty poor:
a global TLB flush is generally still performed on each vunmap, with
the most expensive parts of the operation being the broadcast IPIs
and locking involved in the SMP callouts, and the locking involved
in the vmap management -- none of these are avoided by just batching
up the calls. I'm actually surprised it ever made much difference.
(Now that the lazy vmap allocator is upstream, this description is
not quite right, but the vunmap batching still doesn't seem to do
much).
Rip all this logic out of XFS completely. I will improve vmap
performance and scalability directly in subsequent patch.
The only change I made was to use the "new" xfs_buf_is_vmapped()
function in a place it had been open-coded in the original.
* 'for-linus' of git://oss.sgi.com/xfs/xfs: (21 commits)
xfs: return inode fork offset in bulkstat for fsr
xfs: Increase the default size of the reserved blocks pool
xfs: truncate delalloc extents when IO fails in writeback
xfs: check for more work before sleeping in xfssyncd
xfs: Fix a build warning in xfs_aops.c
xfs: fix locking for inode cache radix tree tag updates
xfs: remove xfs_ipin/xfs_iunpin
xfs: cleanup xfs_iunpin_wait/xfs_iunpin_nowait
xfs: kill xfs_lrw.h
xfs: factor common xfs_trans_bjoin code
xfs: stop passing opaque handles to xfs_log.c routines
xfs: split xfs_bmap_btalloc
xfs: fix xfs_fsblock_t tracing
xfs: fix inode pincount check in fsync
xfs: Non-blocking inode locking in IO completion
xfs: implement optimized fdatasync
xfs: remove wrapper for the fsync file operation
xfs: remove wrappers for read/write file operations
xfs: merge xfs_lrw.c into xfs_file.c
xfs: fix dquota trace format
* 'for-2.6.34' of git://linux-nfs.org/~bfields/linux: (22 commits)
nfsd4: fix minor memory leak
svcrpc: treat uid's as unsigned
nfsd: ensure sockets are closed on error
Revert "sunrpc: move the close processing after do recvfrom method"
Revert "sunrpc: fix peername failed on closed listener"
sunrpc: remove unnecessary svc_xprt_put
NFSD: NFSv4 callback client should use RPC_TASK_SOFTCONN
xfs_export_operations.commit_metadata
commit_metadata export operation replacing nfsd_sync_dir
lockd: don't clear sm_monitored on nsm_reboot_lookup
lockd: release reference to nsm_handle in nlm_host_rebooted
nfsd: Use vfs_fsync_range() in nfsd_commit
NFSD: Create PF_INET6 listener in write_ports
SUNRPC: NFS kernel APIs shouldn't return ENOENT for "transport not found"
SUNRPC: Bury "#ifdef IPV6" in svc_create_xprt()
NFSD: Support AF_INET6 in svc_addsock() function
SUNRPC: Use rpc_pton() in ip_map_parse()
nfsd: 4.1 has an rfc number
nfsd41: Create the recovery entry for the NFSv4.1 client
nfsd: use vfs_fsync for non-directories
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits)
quota: stop using QUOTA_OK / NO_QUOTA
dquot: cleanup dquot initialize routine
dquot: move dquot initialization responsibility into the filesystem
dquot: cleanup dquot drop routine
dquot: move dquot drop responsibility into the filesystem
dquot: cleanup dquot transfer routine
dquot: move dquot transfer responsibility into the filesystem
dquot: cleanup inode allocation / freeing routines
dquot: cleanup space allocation / freeing routines
ext3: add writepage sanity checks
ext3: Truncate allocated blocks if direct IO write fails to update i_size
quota: Properly invalidate caches even for filesystems with blocksize < pagesize
quota: generalize quota transfer interface
quota: sb_quota state flags cleanup
jbd: Delay discarding buffers in journal_unmap_buffer
ext3: quota_write cross block boundary behaviour
quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota
quota: split out compat_sys_quotactl support from quota.c
quota: split out netlink notification support from quota.c
quota: remove invalid optimization from quota_sync_all
Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
This gives the filesystem more information about the writeback that
is happening. Trond requested this for the NFS unstable write handling,
and other filesystems might benefit from this too by beeing able to
distinguish between the different callers in more detail.
Similar to the fsync issue fixed a while ago in commit
2daea67e966dc0c42067ebea015ddac6834cef88 we need to write for data to
actually hit the disk before writing out the metadata to guarantee
data integrity for filesystems that modify the inode in the data I/O
completion path. Currently XFS and NFS handle this manually, and AFS
has a write_inode method that does nothing but waiting for data, while
others are possibly missing out on this.
Fortunately this change has a lot less impact than the fsync change
as none of the write_inode methods starts data writeout of any form
by itself.
We currently use block_invalidatepage() to clean up pages where I/O
fails in ->writepage(). Unfortunately, if the page has delalloc
regions on it, we fail to remove the delalloc regions when we
invalidate the page. This can result in tripping a BUG() in
xfs_get_blocks() later on if a direct IO read is done on that same
region - the delalloc extent is returned when none is supposed to be
there.
Fix this by truncating away the delalloc regions on the page before
invalidating it. Because they are delalloc, we can do this without
needing a transaction. Indeed - if we get ENOSPC errors, we have to
be able to do this truncation without a transaction as there is
no space left for block reservation (typically why we see a ENOSPC
in writeback).
xfssyncd processes a queue of work by detaching the queue and
then iterating over all the work items. It then sleeps for a
time period or until new work comes in. If new work is queued
while xfssyncd is actively processing the detached work queue,
it will not process that new work until after a sleep timeout
or the next work event queued wakes it.
Fix this by checking the work queue again before going to sleep.
Fix a build warning that slipped through. Dave Chinner had posted
an updated version of his patch but the previous version--without
this fix--was what got committed.
We already do these checks in the generic code.
Currently Q_XQUOTASYNC calls into the quota_sync method, but XFS does something
entirely different in it than the rest of the filesystems. xfs_quota which
calls Q_XQUOTASYNC expects an asynchronous data writeout to flush delayed
allocations, while the "VFS" quota support wants to flush changes to the quota
file.
So make Q_XQUOTASYNC call into the writeback code directly and make the
quota_sync method optional as XFS doesn't need in the sense expected by the
rest of the quota code.
GFS2 was using limited XFS-style quota and has a quota_sync method fitting
neither the style used by vfs_quota_sync nor xfs_fs_quota_sync. I left it
in for now as per discussion with Steve it expects to be called from the
sync path this way.
Resolve merge conflict in fs/xfs/linux-2.6/xfs_export.c.
