commit 093019cf1b18dd31b2c3b77acce4e000e2cbc9ce upstream.
Commit fa8b18ed didn't prevent the integer overflow and possible
memory corruption. "count" can go negative and bypass the check.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit fa8b18edd752a8b4e9d1ee2cd615b82c93cf8bba upstream.
This prevents in-memory corruption and possible panics if the on-disk
ACL is badly corrupted.
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the
annoying subdirectories in the XFS source code. Besides the large
amount of file rename the only changes are to the Makefile, a few
files including headers with the subdirectory prefix, and the binary
sysctl compat code that includes a header under fs/xfs/ from
kernel/.
Signed-off-by: Alex Elder <aelder@sgi.com>
This patch rips out the XFS ACL handling code and uses the generic
fs/posix_acl.c code instead. The ondisk format is of course left
unchanged.
This also introduces the same ACL caching all other Linux filesystems do
by adding pointers to the acl and default acl in struct xfs_inode.
Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
capable_cred has been unused for a while so we can kill it and sys_cred.
That also means the cred argument to xfs_setattr and xfs_change_file_space
can be removed now.
SGI-PV: 988918
SGI-Modid: xfs-linux-melb:xfs-kern:32412a
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Tim Shimmin <tes@sgi.com>
Signed-off-by: David Chinner <david@fromorbit.com>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
All remaining bhv_vnode_t instance are in code that's more or less Linux
specific. (Well, for xfs_acl.c that could be argued, but that code is on
the removal list, too). So just do an s/bhv_vnode_t/struct inode/ over the
whole tree. We can clean up variable naming and some useless helpers
later.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31781a
All the ACL routines are called from inode operations which are guaranteed
to have a referenced inode by the VFS, so there's no need for the ACL code
to grab another temporary one.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31763a
xfs_vtoi() is redundant and only unsed in small sections of code.
Replace them with widely used XFS_I() inline and kill xfs_vtoi().
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31725a
Signed-off-by: Niv Sardi <xaiki@sgi.com>
it can be switched to take struct iattr directly and thus simplify the
implementation greatly. Also rename the ATTR_ flags to XFS_ATTR_ to not
conflict with the ATTR_ flags used by the VFS.
SGI-PV: 984565
SGI-Modid: xfs-linux-melb:xfs-kern:31678a
and not go through xfs_attr_list.
SGI-PV: 983395
SGI-Modid: xfs-linux-melb:xfs-kern:31324a
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30913a
Signed-off-by: Barry Naujok <bnaujok@sgi.com>
It's currently used by the ACL code to read di_mode/di_uid, but these are
simple 32bit scalar values we can just read directly without locking.
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30897a
We can just check i_mode / di_mode directly.
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30896a
Removing an ACL can return an error. Propagate it.
SGI-PV: 980084
SGI-Modid: xfs-linux-melb:xfs-kern:30793a
Signed-off-by: David Chinner <dgc@sgi.com>
Propagate the error status from xfs_acl_setmode() so that callers know if
the ACl was set correctly or not.
SGI-PV: 980084
SGI-Modid: xfs-linux-melb:xfs-kern:30792a
Now that all direct caller of xfs_iaccess are gone we can kill xfs_iaccess
and xfs_access and just use generic_permission with a check_acl callback.
This is required for the per-mount read-only patchset in -mm to work
properly with XFS.
SGI-PV: 971186
SGI-Modid: xfs-linux-melb:xfs-kern:30370a
Simplify the prototype for xfs_create/xfs_mkdir/xfs_symlink by not passing
down a bhv_vattr_t that just hogs stack space. Instead pass down the mode
in a mode_t and in case of xfs_create the rdev as a scalar type as well.
SGI-PV: 968563
SGI-Modid: xfs-linux-melb:xfs-kern:29794a
Now that struct bhv_vnode is empty we can just kill it. Retain bhv_vnode_t
as a typedef for struct inode for the time being until all the fallout is
cleaned up.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29500a
We can easily get at the vfsp through the super_block but it will soon be
gone anyway.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29494a
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29493a
xfs_mac.h and xfs_cap.h provide definitions and macros that aren't used
anywhere in XFS at all. They are left-overs from "to be implement at some
point in the future" functionality that Irix XFS has. If this
functionality ever goes into Linux, it will be provided at a different
layer, most likely through the security hooks in the kernel so we will
never need this functionality in XFS.
Patch provided by Eric Sandeen (sandeen@sandeen.net).
SGI-PV: 960895
SGI-Modid: xfs-linux-melb:xfs-kern:28036a
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
pure bloat.
SGI-PV: 952969
SGI-Modid: xfs-linux-melb:xfs-kern:26251a
Signed-off-by: Nathan Scott <nathans@sgi.com>
porters.
SGI-PV: 953338
SGI-Modid: xfs-linux-melb:xfs-kern:26108a
SGI-PV: 953338
SGI-Modid: xfs-linux-melb:xfs-kern:26107a
these typos.
SGI-PV: 904196
SGI-Modid: xfs-linux-melb:xfs-kern:25539a
fs: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de>
information gcc could not find out (that a directory always has a ..
entry), the others are outright gcc bugs.
SGI-PV: 943511
SGI-Modid: xfs-linux:xfs-kern:200055a
Signed-off-by: Christoph Hellwig <hch@sgi.com>
boilerplate.
SGI-PV: 913862
SGI-Modid: xfs-linux:xfs-kern:23903a
SGI-PV: 943122
SGI-Modid: xfs-linux:xfs-kern:23901a
SGI-PV: 942986
SGI-Modid: xfs-linux:xfs-kern:23859a
SGI-PV: 936236
SGI-Modid: xfs-linux:xfs-kern:195878a
infrastructure for it.
Let it rip!
