path: root/fs/xfs/xfs_attr_leaf.c
2010-01-21xfs: remove duplicate buffer flagsChristoph Hellwig
Currently we define aliases for the buffer flags in various namespaces, which only adds confusion. Remove all but the XBF_ flags to clean this up a bit. Note that we still abuse XFS_B_ASYNC/XBF_ASYNC for some non-buffer uses, but I'll clean that up later. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-01-20xfs: convert attr to use unsigned namesDave Chinner
To be consistent with the directory code, the attr code should use unsigned names. Convert the names from the vfs at the highest level to unsigned, and ænsure they are consistenly used as unsigned down to disk. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2009-12-14xfs: event tracing supportChristoph Hellwig
Convert the old xfs tracing support that could only be used with the out of tree kdb and xfsidbg patches to use the generic event tracer. To use it make sure CONFIG_EVENT_TRACING is enabled and then enable all xfs trace channels by: echo 1 > /sys/kernel/debug/tracing/events/xfs/enable or alternatively enable single events by just doing the same in one event subdirectory, e.g. echo 1 > /sys/kernel/debug/tracing/events/xfs/xfs_ihold/enable or set more complex filters, etc. In Documentation/trace/events.txt all this is desctribed in more detail. To reads the events do a cat /sys/kernel/debug/tracing/trace Compared to the last posting this patch converts the tracing mostly to the one tracepoint per callsite model that other users of the new tracing facility also employ. This allows a very fine-grained control of the tracing, a cleaner output of the traces and also enables the perf tool to use each tracepoint as a virtual performance counter, allowing us to e.g. count how often certain workloads git various spots in XFS. Take a look at http://lwn.net/Articles/346470/ for some examples. Also the btree tracing isn't included at all yet, as it will require additional core tracing features not in mainline yet, I plan to deliver it later. And the really nice thing about this patch is that it actually removes many lines of code while adding this nice functionality: fs/xfs/Makefile | 8 fs/xfs/linux-2.6/xfs_acl.c | 1 fs/xfs/linux-2.6/xfs_aops.c | 52 - fs/xfs/linux-2.6/xfs_aops.h | 2 fs/xfs/linux-2.6/xfs_buf.c | 117 +-- fs/xfs/linux-2.6/xfs_buf.h | 33 fs/xfs/linux-2.6/xfs_fs_subr.c | 3 fs/xfs/linux-2.6/xfs_ioctl.c | 1 fs/xfs/linux-2.6/xfs_ioctl32.c | 1 fs/xfs/linux-2.6/xfs_iops.c | 1 fs/xfs/linux-2.6/xfs_linux.h | 1 fs/xfs/linux-2.6/xfs_lrw.c | 87 -- fs/xfs/linux-2.6/xfs_lrw.h | 45 - fs/xfs/linux-2.6/xfs_super.c | 104 --- fs/xfs/linux-2.6/xfs_super.h | 7 fs/xfs/linux-2.6/xfs_sync.c | 1 fs/xfs/linux-2.6/xfs_trace.c | 75 ++ fs/xfs/linux-2.6/xfs_trace.h | 1369 +++++++++++++++++++++++++++++++++++++++++ fs/xfs/linux-2.6/xfs_vnode.h | 4 fs/xfs/quota/xfs_dquot.c | 110 --- fs/xfs/quota/xfs_dquot.h | 21 fs/xfs/quota/xfs_qm.c | 40 - fs/xfs/quota/xfs_qm_syscalls.c | 4 fs/xfs/support/ktrace.c | 323 --------- fs/xfs/support/ktrace.h | 85 -- fs/xfs/xfs.h | 16 fs/xfs/xfs_ag.h | 14 fs/xfs/xfs_alloc.c | 230 +----- fs/xfs/xfs_alloc.h | 27 fs/xfs/xfs_alloc_btree.c | 1 fs/xfs/xfs_attr.c | 107 --- fs/xfs/xfs_attr.h | 10 fs/xfs/xfs_attr_leaf.c | 14 fs/xfs/xfs_attr_sf.h | 40 - fs/xfs/xfs_bmap.c | 507 +++------------ fs/xfs/xfs_bmap.h | 49 - fs/xfs/xfs_bmap_btree.c | 6 fs/xfs/xfs_btree.c | 5 fs/xfs/xfs_btree_trace.h | 17 fs/xfs/xfs_buf_item.c | 87 -- fs/xfs/xfs_buf_item.h | 20 fs/xfs/xfs_da_btree.c | 3 fs/xfs/xfs_da_btree.h | 7 fs/xfs/xfs_dfrag.c | 2 fs/xfs/xfs_dir2.c | 8 fs/xfs/xfs_dir2_block.c | 20 fs/xfs/xfs_dir2_leaf.c | 21 fs/xfs/xfs_dir2_node.c | 27 fs/xfs/xfs_dir2_sf.c | 26 fs/xfs/xfs_dir2_trace.c | 216 ------ fs/xfs/xfs_dir2_trace.h | 72 -- fs/xfs/xfs_filestream.c | 8 fs/xfs/xfs_fsops.c | 2 fs/xfs/xfs_iget.c | 111 --- fs/xfs/xfs_inode.c | 67 -- fs/xfs/xfs_inode.h | 76 -- fs/xfs/xfs_inode_item.c | 5 fs/xfs/xfs_iomap.c | 85 -- fs/xfs/xfs_iomap.h | 8 fs/xfs/xfs_log.c | 181 +---- fs/xfs/xfs_log_priv.h | 20 fs/xfs/xfs_log_recover.c | 1 fs/xfs/xfs_mount.c | 2 fs/xfs/xfs_quota.h | 8 fs/xfs/xfs_rename.c | 1 fs/xfs/xfs_rtalloc.c | 1 fs/xfs/xfs_rw.c | 3 fs/xfs/xfs_trans.h | 47 + fs/xfs/xfs_trans_buf.c | 62 - fs/xfs/xfs_vnodeops.c | 8 70 files changed, 2151 insertions(+), 2592 deletions(-) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: kill the STATIC_INLINE macroChristoph Hellwig
Remove our own STATIC_INLINE macro. For small function inside implementation files just use STATIC and let gcc inline it, and for those in headers do the normal static inline - they are all small enough to be inlined for debug builds, too. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-03-29xfs: remove m_attroffsetChristoph Hellwig
With the upcoming v3 inodes the default attroffset needs to be calculated for each specific inode, so we can't cache it in the superblock anymore. Also replace the assert for wrong inode sizes with a proper error check also included in non-debug builds. Note that the ENOSYS return for that might seem odd, but that error is returned by xfs_mount_validate_sb for all theoretically valid but not supported filesystem geometries. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Josef 'Jeff' Sipek <jeffpc@josefsipek.net>
2009-02-04xfs: factor out attr fork reset handlingChristoph Hellwig
We currently duplicate code to reset the attribute fork after the last attribute has been deleted. Factor this out into a small helper. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Felix Blyakher <felixb@sgi.com>
2009-01-09[XFS] Remove macro-to-function indirections in attr codeEric Sandeen
Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] Move xfs_attr_rolltrans to xfs_trans_rollNiv Sardi
Move it from the attr code to the transaction code and make the attr code call the new function. We rolltrans is really usefull whenever we want to use rolling transaction, should be generic, it isn't dependent on any part of the attr code anyway. We use this excuse to change all the: if ((error = xfs_attr_rolltrans())) calls into: error = xfs_trans_roll(); if (error) SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31729a Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Switches xfs_vn_listxattr to set it's put_listent callback directlyChristoph Hellwig
and not go through xfs_attr_list. SGI-PV: 983395 SGI-Modid: xfs-linux-melb:xfs-kern:31324a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Add op_flags field and helpers to xfs_da_argsBarry Naujok
The end of the xfs_da_args structure has 4 unsigned char fields for true/false information on directory and attr operations using the xfs_da_args structure. The following converts these 4 into a op_flags field that uses the first 4 bits for these fields and allows expansion for future operation information (eg. case-insensitive lookup request). SGI-PV: 981520 SGI-Modid: xfs-linux-melb:xfs-kern:31206a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Remove unused arg from kmem_free()Denys Vlasenko
kmem_free() function takes (ptr, size) arguments but doesn't actually use second one. This patch removes size argument from all callsites. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31050a Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Always use di_forkoff when checking for attr space.Eric Sandeen
In the case where we mount a filesystem which was previously using the attr2 format as attr1, returning the default mp->m_attroffset instead of the per-inode di_forkoff for inline attribute fit calculations, may result in corruption, if for example, the data fork is already taking more space than the default fork offset and we try to add an extended attribute. Fix tested by xfstests/186. SGI-PV: 979606 SGI-Modid: xfs-linux-melb:xfs-kern:30861a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-10[XFS] remove shouting-indirection macros from xfs_sb.hEric Sandeen
Remove macro-to-small-function indirection from xfs_sb.h, and remove some which are completely unused. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30528a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-13xfs: convert beX_add to beX_add_cpu (new common API)Marcin Slusarz
remove beX_add functions and replace all uses with beX_add_cpu Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Dave Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07[XFS] Unwrap XFS_SB_LOCK.Eric Sandeen
Un-obfuscate XFS_SB_LOCK, remove XFS_SB_LOCK->mutex_lock->spin_lock macros, call spin_lock directly, remove extraneous cookie holdover from old xfs code, and change lock type to spinlock_t. SGI-PV: 970382 SGI-Modid: xfs-linux-melb:xfs-kern:29746a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] The last argument "lsn" of xfs_trans_commit() is always called withEric Sandeen
NULL. Patch provided by Eric Sandeen. SGI-PV: 961693 SGI-Modid: xfs-linux-melb:xfs-kern:28199a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Fix assertion in xfs_attr_shortform_remove().Lachlan McIlroy
SGI-PV: 960791 SGI-Modid: xfs-linux-melb:xfs-kern:28021a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Fix attr2 corruption with btree data extentsBarry Naujok
SGI-PV: 958747 SGI-Modid: xfs-linux-melb:xfs-kern:27792a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Russell Cattelan <cattelan@thebarn.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Keep stack usage down for 4k stacks by using noinline.David Chinner
gcc-4.1 and more recent aggressively inline static functions which increases XFS stack usage by ~15% in critical paths. Prevent this from occurring by adding noinline to the STATIC definition. Also uninline some functions that are too large to be inlined and were causing problems with CONFIG_FORCED_INLINING=y. Finally, clean up all the different users of inline, __inline and __inline__ and put them under one STATIC_INLINE macro. For debug kernels the STATIC_INLINE macro uninlines those functions. SGI-PV: 957159 SGI-Modid: xfs-linux-melb:xfs-kern:27585a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: David Chatterton <chatz@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Add EA list callbacks for xfs kernel use. Cleanup some namespaceTim Shimmin
code. SGI-PV: 954372 SGI-Modid: xfs-linux-melb:xfs-kern:26583a Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Add parameters to xfs_bmapi() and xfs_bunmapi() to have them reportOlaf Weber
the range spanned by modifications to the in-core extent map. Add XFS_BUNMAPI() and XFS_SWAP_EXTENTS() macros that call xfs_bunmapi() and xfs_swap_extents() via the ioops vector. Change all calls that may modify the in-core extent map for the data fork to go through the ioops vector. This allows a cache of extent map data to be kept in sync. SGI-PV: 947615 SGI-Modid: xfs-linux-melb:xfs-kern:209226a Signed-off-by: Olaf Weber <olaf@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_node_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25505a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_node_entry_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25504a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] store xfs_attr_inactive_list_t in native endian Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25503a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] store xfs_attr_sf_sort in native endian Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25502a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_shortform_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25501a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_leaf_name_remote_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25500a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_leaf_name_local_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25499a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_leaf_entry_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25498a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_leaf_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25497a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_blkinfo_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25495a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Reverse the sense of COMPAT_ATTR and ATTR2, keeps it simple andNathan Scott
consistent. SGI-PV: 941645 SGI-Modid: xfs-linux-melb:xfs-kern:202961a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-25[XFS] Fix a case where attr2 format was being used unconditionally.Nathan Scott
SGI-PV: 941645 SGI-Modid: xfs-linux-melb:xfs-kern:24566a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Fix up a 32/64 local flags variable issue when enabling attr2 mode.Nathan Scott
SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23925a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Fix up an internal sort function name collision issue.Nathan Scott
SGI-PV: 942986 SGI-Modid: xfs-linux:xfs-kern:23859a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Ondisk format extension for extended attributes (attr2). Basically,Nathan Scott
the data/attr forks now grow up/down from either end of the literal area, rather than dividing the literal area into two chunks and growing both upward. Means we can now make much more efficient use of the attribute space, incl. fitting DMF attributes inline in 256 byte inodes, and large jumps in dbench3 performance numbers. It is self enabling, but can be forced on/off via the attr2/noattr2 mount options. SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23835a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Move some code around to prepare for the upcoming extendedNathan Scott
attributes format change (attr2). SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23833a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] mark various symbols static Patch from Adrian BunkChristoph Hellwig
SGI-PV: 936255 SGI-Modid: xfs-linux:xfs-kern:192760a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
