path: root/fs/xfs/xfs_da_btree.c
2011-08-08Merge branch 'master' of ↵Alex Elder
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
2011-07-26xfs: encapsulate a block of debug codeAlex Elder
Pull into a helper function some debug-only code that validates a xfs_da_blkinfo structure that's been read from disk. Signed-off-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@infradead.org>
2011-07-25xfs: Remove the macro XFS_BUF_PTRChandra Seetharaman
Remove the definition and usages of the macro XFS_BUF_PTR. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25xfs: Remove the macro XFS_BUF_ERROR and familyChandra Seetharaman
Remove the definitions and usage of the macros XFS_BUF_ERROR, XFS_BUF_GETERROR and XFS_BUF_ISERROR. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-13xfs: remove the dead XFS_DABUF_DEBUG codeChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-07-13xfs: factor out xfs_da_grow_inode_intChristoph Hellwig
xfs_da_grow_inode and xfs_dir2_grow_inode are mostly duplicate code. Factor the meat of those two functions into a new common helper. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-07-13xfs: reshuffle dir2 headersChristoph Hellwig
Replace the current mess of dir2 headers with just three that have a clear purpose: - xfs_dir2_format.h for all format definitions, including the inline helpers to access our variable size structures - xfs_dir2_priv.h for all prototypes that are internal to the dir2 code and not needed by anything outside of the directory code. For this purpose xfs_da_btree.c, and phase6.c in xfs_repair are considered part of the directory code. - xfs_dir2.h for the public interface to the directory code In addition to the reshuffle I have also update the comments to not only match the new file structure, but also to describe the directory format better. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-07-08xfs: byteswap constants instead of variablesChristoph Hellwig
Micro-optimize various comparisms by always byteswapping the constant instead of the variable, which allows to do the swap at compile instead of runtime. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-07-08xfs: avoid usage of struct xfs_dir2_dataChristoph Hellwig
In most places we can simply pass around and use the struct xfs_dir2_data_hdr, which is the first and most important member of struct xfs_dir2_data instead of the full structure. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-03-07xfs: Convert remaining cmn_err() callers to new APIDave Chinner
Once converted, kill the remainder of the cmn_err() interface. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-10-18xfs: remove xfs_buf wrappersChristoph Hellwig
Stop having two different names for many buffer functions and use the more descriptive xfs_buf_* names directly. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-07-26xfs: fix gcc 4.6 set but not read and unused statement warningsChristoph Hellwig
[hch: dropped a few hunks that need structural changes instead] Signed-off-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2010-07-26xfs: remove unused delta tracking code in xfs_bmapiChristoph Hellwig
This code was introduced four years ago in commit 3e57ecf640428c01ba1ed8c8fc538447ada1715b without any review and has been unused since. Remove it just as the rest of the code introduced in that commit to reduce that stack usage and complexity in this central piece of code. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-07-26xfs: remove unneeded #include statementsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2010-07-26xfs: drop dmapi hooksChristoph Hellwig
Dmapi support was never merged upstream, but we still have a lot of hooks bloating XFS for it, all over the fast pathes of the filesystem. This patch drops over 700 lines of dmapi overhead. If we'll ever get HSM support in mainline at least the namespace events can be done much saner in the VFS instead of the individual filesystem, so it's not like this is much help for future work. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-01-20xfs: convert dirnameops to unsigned char namesDave Chinner
To be consistent across the codebase, convert the dirnameops to pass the directory names by unsigned char strings. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2009-12-14xfs: event tracing supportChristoph Hellwig
Convert the old xfs tracing support that could only be used with the out of tree kdb and xfsidbg patches to use the generic event tracer. To use it make sure CONFIG_EVENT_TRACING is enabled and then enable all xfs trace channels by: echo 1 > /sys/kernel/debug/tracing/events/xfs/enable or alternatively enable single events by just doing the same in one event subdirectory, e.g. echo 1 > /sys/kernel/debug/tracing/events/xfs/xfs_ihold/enable or set more complex filters, etc. In Documentation/trace/events.txt all this is desctribed in more detail. To reads the events do a cat /sys/kernel/debug/tracing/trace Compared to the last posting this patch converts the tracing mostly to the one tracepoint per callsite model that other users of the new tracing facility also employ. This allows a very fine-grained control of the tracing, a cleaner output of the traces and also enables the perf tool to use each tracepoint as a virtual performance counter, allowing us to e.g. count how often certain workloads git various spots in XFS. Take a look at http://lwn.net/Articles/346470/ for some examples. Also the btree tracing isn't included at all yet, as it will require additional core tracing features not in mainline yet, I plan to deliver it later. And the really nice thing about this patch is that it actually removes many lines of code while adding this nice functionality: fs/xfs/Makefile | 8 fs/xfs/linux-2.6/xfs_acl.c | 1 fs/xfs/linux-2.6/xfs_aops.c | 52 - fs/xfs/linux-2.6/xfs_aops.h | 2 fs/xfs/linux-2.6/xfs_buf.c | 117 +-- fs/xfs/linux-2.6/xfs_buf.h | 33 fs/xfs/linux-2.6/xfs_fs_subr.c | 3 fs/xfs/linux-2.6/xfs_ioctl.c | 1 fs/xfs/linux-2.6/xfs_ioctl32.c | 1 fs/xfs/linux-2.6/xfs_iops.c | 1 fs/xfs/linux-2.6/xfs_linux.h | 1 fs/xfs/linux-2.6/xfs_lrw.c | 87 -- fs/xfs/linux-2.6/xfs_lrw.h | 45 - fs/xfs/linux-2.6/xfs_super.c | 104 --- fs/xfs/linux-2.6/xfs_super.h | 7 fs/xfs/linux-2.6/xfs_sync.c | 1 fs/xfs/linux-2.6/xfs_trace.c | 75 ++ fs/xfs/linux-2.6/xfs_trace.h | 1369 +++++++++++++++++++++++++++++++++++++++++ fs/xfs/linux-2.6/xfs_vnode.h | 4 fs/xfs/quota/xfs_dquot.c | 110 --- fs/xfs/quota/xfs_dquot.h | 21 fs/xfs/quota/xfs_qm.c | 40 - fs/xfs/quota/xfs_qm_syscalls.c | 4 fs/xfs/support/ktrace.c | 323 --------- fs/xfs/support/ktrace.h | 85 -- fs/xfs/xfs.h | 16 fs/xfs/xfs_ag.h | 14 fs/xfs/xfs_alloc.c | 230 +----- fs/xfs/xfs_alloc.h | 27 fs/xfs/xfs_alloc_btree.c | 1 fs/xfs/xfs_attr.c | 107 --- fs/xfs/xfs_attr.h | 10 fs/xfs/xfs_attr_leaf.c | 14 fs/xfs/xfs_attr_sf.h | 40 - fs/xfs/xfs_bmap.c | 507 +++------------ fs/xfs/xfs_bmap.h | 49 - fs/xfs/xfs_bmap_btree.c | 6 fs/xfs/xfs_btree.c | 5 fs/xfs/xfs_btree_trace.h | 17 fs/xfs/xfs_buf_item.c | 87 -- fs/xfs/xfs_buf_item.h | 20 fs/xfs/xfs_da_btree.c | 3 fs/xfs/xfs_da_btree.h | 7 fs/xfs/xfs_dfrag.c | 2 fs/xfs/xfs_dir2.c | 8 fs/xfs/xfs_dir2_block.c | 20 fs/xfs/xfs_dir2_leaf.c | 21 fs/xfs/xfs_dir2_node.c | 27 fs/xfs/xfs_dir2_sf.c | 26 fs/xfs/xfs_dir2_trace.c | 216 ------ fs/xfs/xfs_dir2_trace.h | 72 -- fs/xfs/xfs_filestream.c | 8 fs/xfs/xfs_fsops.c | 2 fs/xfs/xfs_iget.c | 111 --- fs/xfs/xfs_inode.c | 67 -- fs/xfs/xfs_inode.h | 76 -- fs/xfs/xfs_inode_item.c | 5 fs/xfs/xfs_iomap.c | 85 -- fs/xfs/xfs_iomap.h | 8 fs/xfs/xfs_log.c | 181 +---- fs/xfs/xfs_log_priv.h | 20 fs/xfs/xfs_log_recover.c | 1 fs/xfs/xfs_mount.c | 2 fs/xfs/xfs_quota.h | 8 fs/xfs/xfs_rename.c | 1 fs/xfs/xfs_rtalloc.c | 1 fs/xfs/xfs_rw.c | 3 fs/xfs/xfs_trans.h | 47 + fs/xfs/xfs_trans_buf.c | 62 - fs/xfs/xfs_vnodeops.c | 8 70 files changed, 2151 insertions(+), 2592 deletions(-) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-08-12xfs: switch to NOFS allocation under i_lock in xfs_da_buf_makeChristoph Hellwig
i_lock is taken in the reclaim context so all allocations under it must avoid recursions into the filesystem. Reported by the new reclaim context tracing in lockdep. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Felix Blyakher <felixb@sgi.com> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2009-08-12xfs: switch to NOFS allocation under i_lock in xfs_da_state_allocChristoph Hellwig
xfs_da_state_alloc is always called with i_lock held, but i_lock is taken in reclaim context so all allocations under it must avoid recursions into the filesystem. Reported by the new reclaim context tracing in lockdep. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Felix Blyakher <felixb@sgi.com> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2009-02-09xfs: remove uchar_t/ushort_t/uint_t/ulong_t typesChristoph Hellwig
Just another set of types obsfucating the code, remove them. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2009-01-16[XFS] Remove the rest of the macro-to-function indirections.Eric Sandeen
Remove the last of the macros-defined-to-static-functions. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-10-30[XFS] Account for allocated blocks when expanding directoriesDavid Chinner
When we create a directory, we reserve a number of blocks for the maximum possible expansion of of the directory due to various btree splits, freespace allocation, etc. Unfortunately, each allocation is not reflected in the total number of blocks still available to the transaction, so the maximal reservation is used over and over again. This leads to problems where an allocation group has only enough blocks for *some* of the allocations required for the directory modification. After the first N allocations, the remaining blocks in the allocation group drops below the total reservation, and subsequent allocations fail because the allocator will not allow the allocation to proceed if the AG does not have the enough blocks available for the entire allocation total. This results in an ENOSPC occurring after an allocation has already occurred. This results in aborting the directory operation (leaving the directory in an inconsistent state) and cancelling a dirty transaction, which results in a filesystem shutdown. Avoid the problem by reflecting the number of blocks allocated in any directory expansion in the total number of blocks available to the modification in progress. This prevents a directory modification from being aborted part way through with an ENOSPC. SGI-PV: 988144 SGI-Modid: xfs-linux-melb:xfs-kern:32340a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] streamline init/exit pathChristoph Hellwig
Currently the xfs module init/exit code is a mess. It's farmed out over a lot of function with very little error checking. This patch makes sure we propagate all initialization failures properly and clean up after them. Various runtime initializations are replaced with compile-time initializations where possible to make this easier. The exit path is similarly consolidated. There's now split out function to create/destroy the kmem zones and alloc/free the trace buffers. I've also changed the ktrace allocations to KM_MAYFAIL and handled errors resulting from that. And yes, we really should replace the XFS_*_TRACE ifdefs with a single XFS_TRACE.. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:31354a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Add op_flags field and helpers to xfs_da_argsBarry Naujok
The end of the xfs_da_args structure has 4 unsigned char fields for true/false information on directory and attr operations using the xfs_da_args structure. The following converts these 4 into a op_flags field that uses the first 4 bits for these fields and allows expansion for future operation information (eg. case-insensitive lookup request). SGI-PV: 981520 SGI-Modid: xfs-linux-melb:xfs-kern:31206a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Name operation vector for hash and compareBarry Naujok
Adds two pieces of functionality for the basis of case-insensitive support in XFS: 1. A comparison result enumerated type: xfs_dacmp. It represents an exact match, case-insensitive match or no match at all. This patch only implements different and exact results. 2. xfs_nameops vector for specifying how to perform the hash generation of filenames and comparision methods. In this patch the hash vector points to the existing xfs_da_hashname function and the comparison method does a length compare, and if the same, does a memcmp and return the xfs_dacmp result. All filename functions that use the hash (create, lookup remove, rename, etc) now use the xfs_nameops.hashname function and all directory lookup functions also use the xfs_nameops.compname function. The lookup functions also handle case-insensitive results even though the default comparison function cannot return that. And important aspect of the lookup functions is that an exact match always has precedence over a case-insensitive. So while a case-insensitive match is found, we have to keep looking just in case there is an exact match. In the meantime, the info for the first case-insensitive match is retained if no exact match is found. SGI-PV: 981519 SGI-Modid: xfs-linux-melb:xfs-kern:31205a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Remove unused arg from kmem_free()Denys Vlasenko
kmem_free() function takes (ptr, size) arguments but doesn't actually use second one. This patch removes size argument from all callsites. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31050a Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-13xfs: convert beX_add to beX_add_cpu (new common API)Marcin Slusarz
remove beX_add functions and replace all uses with beX_add_cpu Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Dave Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07[XFS] Unwrap xfs_dabuf_global_lockEric Sandeen
Un-obfuscate dabuf_global_lock, remove mutex_lock->spin_lock macros, call spin_lock directly, remove extraneous cookie holdover from old xfs code, and change lock type to spinlock_t. SGI-PV: 970382 SGI-Modid: xfs-linux-melb:xfs-kern:29744a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-09-05[XFS] fix sparse shadowed variable warningsChristoph Hellwig
- in xfs_probe_cluster rename the inner len to pg_len. There's no harm here because the outer len isn't used after the inner len comes into existence but it keeps the code clean. - in xfs_da_do_buf remove the inner i because they don't overlap and they are both the same type. SGI-PV: 968555 SGI-Modid: xfs-linux-melb:xfs-kern:29311a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove a bunch of unused functions from XFS.Eric Sandeen
Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960897 SGI-Modid: xfs-linux-melb:xfs-kern:28038a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] fix sparse warning in xfs_da_btree.cLachlan McIlroy
SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:27702a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Minor code rearranging and cleanup to prevent some coverity falseNathan Scott
positives. SGI-PV: 955502 SGI-Modid: xfs-linux-melb:xfs-kern:26805a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] endianess annotations for xfs_dir_leaf_entry_t Christoph Hellwig
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25808a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] endianess annotations for xfs_dir_leaf_hdr_t Christoph Hellwig
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25807a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Add parameters to xfs_bmapi() and xfs_bunmapi() to have them reportOlaf Weber
the range spanned by modifications to the in-core extent map. Add XFS_BUNMAPI() and XFS_SWAP_EXTENTS() macros that call xfs_bunmapi() and xfs_swap_extents() via the ioops vector. Change all calls that may modify the in-core extent map for the data fork to go through the ioops vector. This allows a cache of extent map data to be kept in sync. SGI-PV: 947615 SGI-Modid: xfs-linux-melb:xfs-kern:209226a Signed-off-by: Olaf Weber <olaf@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_node_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25505a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_node_entry_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25504a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_blkinfo_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25495a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_dir2_leaf_entry_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25493a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_dir2_leaf_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25492a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_dir2_free_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25485a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_dir2_data_hdr structure.Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25484a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-03[XFS] Fixed the inconsistency between attribute b-tree intermidiate nodeYingping Lu
and leaf blocks. The problem cam from xfsqa test 117. SGI-PV: 940655 SGI-Modid: xfs-linux:xfs-kern:201527a Signed-off-by: Yingping Lu <yingping@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove an unhelpful ifdef, the comment above the routine explainsNathan Scott
the purpose well enough here. SGI-PV: 944821 SGI-Modid: xfs-linux:xfs-kern:24214a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Make some extended attributes routines take const parameters, forNathan Scott
the FreeBSD porters. SGI-PV: 942906 SGI-Modid: xfs-linux:xfs-kern:23845a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Move some code around to prepare for the upcoming extendedNathan Scott
attributes format change (attr2). SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23833a Signed-off-by: Nathan Scott <nathans@sgi.com>
