path: root/fs/xfs/xfs_da_btree.h
2010-01-20xfs: convert dirnameops to unsigned char namesDave Chinner
To be consistent across the codebase, convert the dirnameops to pass the directory names by unsigned char strings. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2009-12-14xfs: event tracing supportChristoph Hellwig
Convert the old xfs tracing support that could only be used with the out of tree kdb and xfsidbg patches to use the generic event tracer. To use it make sure CONFIG_EVENT_TRACING is enabled and then enable all xfs trace channels by: echo 1 > /sys/kernel/debug/tracing/events/xfs/enable or alternatively enable single events by just doing the same in one event subdirectory, e.g. echo 1 > /sys/kernel/debug/tracing/events/xfs/xfs_ihold/enable or set more complex filters, etc. In Documentation/trace/events.txt all this is desctribed in more detail. To reads the events do a cat /sys/kernel/debug/tracing/trace Compared to the last posting this patch converts the tracing mostly to the one tracepoint per callsite model that other users of the new tracing facility also employ. This allows a very fine-grained control of the tracing, a cleaner output of the traces and also enables the perf tool to use each tracepoint as a virtual performance counter, allowing us to e.g. count how often certain workloads git various spots in XFS. Take a look at http://lwn.net/Articles/346470/ for some examples. Also the btree tracing isn't included at all yet, as it will require additional core tracing features not in mainline yet, I plan to deliver it later. And the really nice thing about this patch is that it actually removes many lines of code while adding this nice functionality: fs/xfs/Makefile | 8 fs/xfs/linux-2.6/xfs_acl.c | 1 fs/xfs/linux-2.6/xfs_aops.c | 52 - fs/xfs/linux-2.6/xfs_aops.h | 2 fs/xfs/linux-2.6/xfs_buf.c | 117 +-- fs/xfs/linux-2.6/xfs_buf.h | 33 fs/xfs/linux-2.6/xfs_fs_subr.c | 3 fs/xfs/linux-2.6/xfs_ioctl.c | 1 fs/xfs/linux-2.6/xfs_ioctl32.c | 1 fs/xfs/linux-2.6/xfs_iops.c | 1 fs/xfs/linux-2.6/xfs_linux.h | 1 fs/xfs/linux-2.6/xfs_lrw.c | 87 -- fs/xfs/linux-2.6/xfs_lrw.h | 45 - fs/xfs/linux-2.6/xfs_super.c | 104 --- fs/xfs/linux-2.6/xfs_super.h | 7 fs/xfs/linux-2.6/xfs_sync.c | 1 fs/xfs/linux-2.6/xfs_trace.c | 75 ++ fs/xfs/linux-2.6/xfs_trace.h | 1369 +++++++++++++++++++++++++++++++++++++++++ fs/xfs/linux-2.6/xfs_vnode.h | 4 fs/xfs/quota/xfs_dquot.c | 110 --- fs/xfs/quota/xfs_dquot.h | 21 fs/xfs/quota/xfs_qm.c | 40 - fs/xfs/quota/xfs_qm_syscalls.c | 4 fs/xfs/support/ktrace.c | 323 --------- fs/xfs/support/ktrace.h | 85 -- fs/xfs/xfs.h | 16 fs/xfs/xfs_ag.h | 14 fs/xfs/xfs_alloc.c | 230 +----- fs/xfs/xfs_alloc.h | 27 fs/xfs/xfs_alloc_btree.c | 1 fs/xfs/xfs_attr.c | 107 --- fs/xfs/xfs_attr.h | 10 fs/xfs/xfs_attr_leaf.c | 14 fs/xfs/xfs_attr_sf.h | 40 - fs/xfs/xfs_bmap.c | 507 +++------------ fs/xfs/xfs_bmap.h | 49 - fs/xfs/xfs_bmap_btree.c | 6 fs/xfs/xfs_btree.c | 5 fs/xfs/xfs_btree_trace.h | 17 fs/xfs/xfs_buf_item.c | 87 -- fs/xfs/xfs_buf_item.h | 20 fs/xfs/xfs_da_btree.c | 3 fs/xfs/xfs_da_btree.h | 7 fs/xfs/xfs_dfrag.c | 2 fs/xfs/xfs_dir2.c | 8 fs/xfs/xfs_dir2_block.c | 20 fs/xfs/xfs_dir2_leaf.c | 21 fs/xfs/xfs_dir2_node.c | 27 fs/xfs/xfs_dir2_sf.c | 26 fs/xfs/xfs_dir2_trace.c | 216 ------ fs/xfs/xfs_dir2_trace.h | 72 -- fs/xfs/xfs_filestream.c | 8 fs/xfs/xfs_fsops.c | 2 fs/xfs/xfs_iget.c | 111 --- fs/xfs/xfs_inode.c | 67 -- fs/xfs/xfs_inode.h | 76 -- fs/xfs/xfs_inode_item.c | 5 fs/xfs/xfs_iomap.c | 85 -- fs/xfs/xfs_iomap.h | 8 fs/xfs/xfs_log.c | 181 +---- fs/xfs/xfs_log_priv.h | 20 fs/xfs/xfs_log_recover.c | 1 fs/xfs/xfs_mount.c | 2 fs/xfs/xfs_quota.h | 8 fs/xfs/xfs_rename.c | 1 fs/xfs/xfs_rtalloc.c | 1 fs/xfs/xfs_rw.c | 3 fs/xfs/xfs_trans.h | 47 + fs/xfs/xfs_trans_buf.c | 62 - fs/xfs/xfs_vnodeops.c | 8 70 files changed, 2151 insertions(+), 2592 deletions(-) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-03-29xfs: fix various typosMalcolm Parsons
Signed-off-by: Malcolm Parsons <malcolm.parsons@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2009-03-06xfs: move declaration to header fileHannes Eder
Fix this sparse warning: fs/xfs/xfs_da_btree.c:1550:26: warning: symbol 'xfs_default_nameops' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2009-02-09xfs: remove uchar_t/ushort_t/uint_t/ulong_t typesChristoph Hellwig
Just another set of types obsfucating the code, remove them. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2008-10-30[XFS] Sync up kernel and user-space headersBarry Naujok
SGI-PV: 986558 SGI-Modid: xfs-linux-melb:xfs-kern:32231a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-10-30[XFS] Remove final remnants of dirv1 macros and other stuffBarry Naujok
SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:32002a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Return case-insensitive match for dentry cacheBarry Naujok
This implements the code to store the actual filename found during a lookup in the dentry cache and to avoid multiple entries in the dcache pointing to the same inode. To avoid polluting the dcache, we implement a new directory inode operations for lookup. xfs_vn_ci_lookup() stores the correct case name in the dcache. The "actual name" is only allocated and returned for a case- insensitive match and not an actual match. Another unusual interaction with the dcache is not storing negative dentries like other filesystems doing a d_add(dentry, NULL) when an ENOENT is returned. During the VFS lookup, if a dentry returned has no inode, dput is called and ENOENT is returned. By not doing a d_add, this actually removes it completely from the dcache to be reused. create/rename have to be modified to support unhashed dentries being passed in. SGI-PV: 981521 SGI-Modid: xfs-linux-melb:xfs-kern:31208a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Add op_flags field and helpers to xfs_da_argsBarry Naujok
The end of the xfs_da_args structure has 4 unsigned char fields for true/false information on directory and attr operations using the xfs_da_args structure. The following converts these 4 into a op_flags field that uses the first 4 bits for these fields and allows expansion for future operation information (eg. case-insensitive lookup request). SGI-PV: 981520 SGI-Modid: xfs-linux-melb:xfs-kern:31206a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Name operation vector for hash and compareBarry Naujok
Adds two pieces of functionality for the basis of case-insensitive support in XFS: 1. A comparison result enumerated type: xfs_dacmp. It represents an exact match, case-insensitive match or no match at all. This patch only implements different and exact results. 2. xfs_nameops vector for specifying how to perform the hash generation of filenames and comparision methods. In this patch the hash vector points to the existing xfs_da_hashname function and the comparison method does a length compare, and if the same, does a memcmp and return the xfs_dacmp result. All filename functions that use the hash (create, lookup remove, rename, etc) now use the xfs_nameops.hashname function and all directory lookup functions also use the xfs_nameops.compname function. The lookup functions also handle case-insensitive results even though the default comparison function cannot return that. And important aspect of the lookup functions is that an exact match always has precedence over a case-insensitive. So while a case-insensitive match is found, we have to keep looking just in case there is an exact match. In the meantime, the info for the first case-insensitive match is retained if no exact match is found. SGI-PV: 981519 SGI-Modid: xfs-linux-melb:xfs-kern:31205a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-02-07[XFS] Fix up sparse warnings.David Chinner
These are mostly locking annotations, marking things static, casts where needed and declaring stuff in header files. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30002a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-02-10[XFS] Remove a bunch of unused functions from XFS.Eric Sandeen
Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960897 SGI-Modid: xfs-linux-melb:xfs-kern:28038a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_node_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25505a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_node_entry_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25504a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_blkinfo_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25495a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Make some extended attributes routines take const parameters, forNathan Scott
the FreeBSD porters. SGI-PV: 942906 SGI-Modid: xfs-linux:xfs-kern:23845a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] mark various symbols static Patch from Adrian BunkChristoph Hellwig
SGI-PV: 936255 SGI-Modid: xfs-linux:xfs-kern:192760a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
