path: root/fs/xfs/xfs_dir2.c
2011-07-26xfs: get rid of open-coded S_ISREG(), etc.Al Viro
2011-07-13xfs: factor out xfs_da_grow_inode_intChristoph Hellwig
xfs_da_grow_inode and xfs_dir2_grow_inode are mostly duplicate code. Factor the meat of those two functions into a new common helper. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-07-13xfs: reshuffle dir2 headersChristoph Hellwig
Replace the current mess of dir2 headers with just three that have a clear purpose: - xfs_dir2_format.h for all format definitions, including the inline helpers to access our variable size structures - xfs_dir2_priv.h for all prototypes that are internal to the dir2 code and not needed by anything outside of the directory code. For this purpose xfs_da_btree.c, and phase6.c in xfs_repair are considered part of the directory code. - xfs_dir2.h for the public interface to the directory code In addition to the reshuffle I have also update the comments to not only match the new file structure, but also to describe the directory format better. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-07-08xfs: kill struct xfs_dir2_sfChristoph Hellwig
The list field of it is never cactually used, so all uses can simply be replaced with the xfs_dir2_sf_hdr_t type that it has as first member. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-03-07xfs: convert xfs_fs_cmn_err to new error logging APIDave Chinner
Continue to clean up the error logging code by converting all the callers of xfs_fs_cmn_err() to the new API. Once done, remove the unused old API function. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-07-26xfs: split xfs_itrace_entryChristoph Hellwig
Replace the xfs_itrace_entry catchall with specific trace points. For most simple callers we now use the simple inode class, which used to be the iget class, but add more details tracing for namespace events, which now includes the name of the directory entries manipulated. Remove the xfs_inactive trace point, which is a duplicate of the clear_inode one, and the xfs_change_file_space trace point, which is immediately followed by the more specific alloc/free space trace points. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-07-26xfs: remove unused delta tracking code in xfs_bmapiChristoph Hellwig
This code was introduced four years ago in commit 3e57ecf640428c01ba1ed8c8fc538447ada1715b without any review and has been unused since. Remove it just as the rest of the code introduced in that commit to reduce that stack usage and complexity in this central piece of code. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-07-26xfs: remove unneeded #include statementsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2010-07-26xfs: drop dmapi hooksChristoph Hellwig
Dmapi support was never merged upstream, but we still have a lot of hooks bloating XFS for it, all over the fast pathes of the filesystem. This patch drops over 700 lines of dmapi overhead. If we'll ever get HSM support in mainline at least the namespace events can be done much saner in the VFS instead of the individual filesystem, so it's not like this is much help for future work. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-01-20xfs: clean up sign warnings in dir2 codeDave Chinner
We are now consistently using unsigned char strings for names so fix up the remaining warnings in the dir2 code to complete the cleanup. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-01-20xfs: make xfs_dir_cilookup_result use unsigned charDave Chinner
For consistency with the result of the code. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-01-20xfs: convert dirnameops to unsigned char namesDave Chinner
To be consistent across the codebase, convert the dirnameops to pass the directory names by unsigned char strings. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2009-12-14xfs: event tracing supportChristoph Hellwig
Convert the old xfs tracing support that could only be used with the out of tree kdb and xfsidbg patches to use the generic event tracer. To use it make sure CONFIG_EVENT_TRACING is enabled and then enable all xfs trace channels by: echo 1 > /sys/kernel/debug/tracing/events/xfs/enable or alternatively enable single events by just doing the same in one event subdirectory, e.g. echo 1 > /sys/kernel/debug/tracing/events/xfs/xfs_ihold/enable or set more complex filters, etc. In Documentation/trace/events.txt all this is desctribed in more detail. To reads the events do a cat /sys/kernel/debug/tracing/trace Compared to the last posting this patch converts the tracing mostly to the one tracepoint per callsite model that other users of the new tracing facility also employ. This allows a very fine-grained control of the tracing, a cleaner output of the traces and also enables the perf tool to use each tracepoint as a virtual performance counter, allowing us to e.g. count how often certain workloads git various spots in XFS. Take a look at http://lwn.net/Articles/346470/ for some examples. Also the btree tracing isn't included at all yet, as it will require additional core tracing features not in mainline yet, I plan to deliver it later. And the really nice thing about this patch is that it actually removes many lines of code while adding this nice functionality: fs/xfs/Makefile | 8 fs/xfs/linux-2.6/xfs_acl.c | 1 fs/xfs/linux-2.6/xfs_aops.c | 52 - fs/xfs/linux-2.6/xfs_aops.h | 2 fs/xfs/linux-2.6/xfs_buf.c | 117 +-- fs/xfs/linux-2.6/xfs_buf.h | 33 fs/xfs/linux-2.6/xfs_fs_subr.c | 3 fs/xfs/linux-2.6/xfs_ioctl.c | 1 fs/xfs/linux-2.6/xfs_ioctl32.c | 1 fs/xfs/linux-2.6/xfs_iops.c | 1 fs/xfs/linux-2.6/xfs_linux.h | 1 fs/xfs/linux-2.6/xfs_lrw.c | 87 -- fs/xfs/linux-2.6/xfs_lrw.h | 45 - fs/xfs/linux-2.6/xfs_super.c | 104 --- fs/xfs/linux-2.6/xfs_super.h | 7 fs/xfs/linux-2.6/xfs_sync.c | 1 fs/xfs/linux-2.6/xfs_trace.c | 75 ++ fs/xfs/linux-2.6/xfs_trace.h | 1369 +++++++++++++++++++++++++++++++++++++++++ fs/xfs/linux-2.6/xfs_vnode.h | 4 fs/xfs/quota/xfs_dquot.c | 110 --- fs/xfs/quota/xfs_dquot.h | 21 fs/xfs/quota/xfs_qm.c | 40 - fs/xfs/quota/xfs_qm_syscalls.c | 4 fs/xfs/support/ktrace.c | 323 --------- fs/xfs/support/ktrace.h | 85 -- fs/xfs/xfs.h | 16 fs/xfs/xfs_ag.h | 14 fs/xfs/xfs_alloc.c | 230 +----- fs/xfs/xfs_alloc.h | 27 fs/xfs/xfs_alloc_btree.c | 1 fs/xfs/xfs_attr.c | 107 --- fs/xfs/xfs_attr.h | 10 fs/xfs/xfs_attr_leaf.c | 14 fs/xfs/xfs_attr_sf.h | 40 - fs/xfs/xfs_bmap.c | 507 +++------------ fs/xfs/xfs_bmap.h | 49 - fs/xfs/xfs_bmap_btree.c | 6 fs/xfs/xfs_btree.c | 5 fs/xfs/xfs_btree_trace.h | 17 fs/xfs/xfs_buf_item.c | 87 -- fs/xfs/xfs_buf_item.h | 20 fs/xfs/xfs_da_btree.c | 3 fs/xfs/xfs_da_btree.h | 7 fs/xfs/xfs_dfrag.c | 2 fs/xfs/xfs_dir2.c | 8 fs/xfs/xfs_dir2_block.c | 20 fs/xfs/xfs_dir2_leaf.c | 21 fs/xfs/xfs_dir2_node.c | 27 fs/xfs/xfs_dir2_sf.c | 26 fs/xfs/xfs_dir2_trace.c | 216 ------ fs/xfs/xfs_dir2_trace.h | 72 -- fs/xfs/xfs_filestream.c | 8 fs/xfs/xfs_fsops.c | 2 fs/xfs/xfs_iget.c | 111 --- fs/xfs/xfs_inode.c | 67 -- fs/xfs/xfs_inode.h | 76 -- fs/xfs/xfs_inode_item.c | 5 fs/xfs/xfs_iomap.c | 85 -- fs/xfs/xfs_iomap.h | 8 fs/xfs/xfs_log.c | 181 +---- fs/xfs/xfs_log_priv.h | 20 fs/xfs/xfs_log_recover.c | 1 fs/xfs/xfs_mount.c | 2 fs/xfs/xfs_quota.h | 8 fs/xfs/xfs_rename.c | 1 fs/xfs/xfs_rtalloc.c | 1 fs/xfs/xfs_rw.c | 3 fs/xfs/xfs_trans.h | 47 + fs/xfs/xfs_trans_buf.c | 62 - fs/xfs/xfs_vnodeops.c | 8 70 files changed, 2151 insertions(+), 2592 deletions(-) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-08-12xfs: switch to NOFS allocation under i_lock in xfs_dir_cilookup_resultChristoph Hellwig
xfs_dir_cilookup_result is always called with i_lock held, but i_lock is taken in reclaim context so all allocations under it must avoid recursions into the filesystem. Reported by the new reclaim context tracing in lockdep. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Felix Blyakher <felixb@sgi.com> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2009-03-06xfs: move declaration to header fileHannes Eder
Fix this sparse warning: fs/xfs/xfs_da_btree.c:1550:26: warning: symbol 'xfs_default_nameops' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2008-10-30[XFS] Account for allocated blocks when expanding directoriesDavid Chinner
When we create a directory, we reserve a number of blocks for the maximum possible expansion of of the directory due to various btree splits, freespace allocation, etc. Unfortunately, each allocation is not reflected in the total number of blocks still available to the transaction, so the maximal reservation is used over and over again. This leads to problems where an allocation group has only enough blocks for *some* of the allocations required for the directory modification. After the first N allocations, the remaining blocks in the allocation group drops below the total reservation, and subsequent allocations fail because the allocator will not allow the allocation to proceed if the AG does not have the enough blocks available for the entire allocation total. This results in an ENOSPC occurring after an allocation has already occurred. This results in aborting the directory operation (leaving the directory in an inconsistent state) and cancelling a dirty transaction, which results in a filesystem shutdown. Avoid the problem by reflecting the number of blocks allocated in any directory expansion in the total number of blocks available to the modification in progress. This prevents a directory modification from being aborted part way through with an ENOSPC. SGI-PV: 988144 SGI-Modid: xfs-linux-melb:xfs-kern:32340a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Zero uninitialised xfs_da_args structure in xfs_dir2.cBarry Naujok
Fixes a problem in the xfs_dir2_remove and xfs_dir2_replace paths which intenally call directory format specific lookup funtions that assume args->cmpresult is zeroed. SGI-PV: 982606 SGI-Modid: xfs-linux-melb:xfs-kern:31268a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] XFS: ASCII case-insensitive supportBarry Naujok
Implement ASCII case-insensitive support. It's primary purpose is for supporting existing filesystems that already use this case-insensitive mode migrated from IRIX. But, if you only need ASCII-only case-insensitive support (ie. English only) and will never use another language, then this mode is perfectly adequate. ASCII-CI is implemented by generating hashes based on lower-case letters and doing lower-case compares. It implements a new xfs_nameops vector for doing the hashes and comparisons for all filename operations. To create a filesystem with this CI mode, use: # mkfs.xfs -n version=ci <device> SGI-PV: 981516 SGI-Modid: xfs-linux-melb:xfs-kern:31209a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Return case-insensitive match for dentry cacheBarry Naujok
This implements the code to store the actual filename found during a lookup in the dentry cache and to avoid multiple entries in the dcache pointing to the same inode. To avoid polluting the dcache, we implement a new directory inode operations for lookup. xfs_vn_ci_lookup() stores the correct case name in the dcache. The "actual name" is only allocated and returned for a case- insensitive match and not an actual match. Another unusual interaction with the dcache is not storing negative dentries like other filesystems doing a d_add(dentry, NULL) when an ENOENT is returned. During the VFS lookup, if a dentry returned has no inode, dput is called and ENOENT is returned. By not doing a d_add, this actually removes it completely from the dcache to be reused. create/rename have to be modified to support unhashed dentries being passed in. SGI-PV: 981521 SGI-Modid: xfs-linux-melb:xfs-kern:31208a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Add op_flags field and helpers to xfs_da_argsBarry Naujok
The end of the xfs_da_args structure has 4 unsigned char fields for true/false information on directory and attr operations using the xfs_da_args structure. The following converts these 4 into a op_flags field that uses the first 4 bits for these fields and allows expansion for future operation information (eg. case-insensitive lookup request). SGI-PV: 981520 SGI-Modid: xfs-linux-melb:xfs-kern:31206a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Name operation vector for hash and compareBarry Naujok
Adds two pieces of functionality for the basis of case-insensitive support in XFS: 1. A comparison result enumerated type: xfs_dacmp. It represents an exact match, case-insensitive match or no match at all. This patch only implements different and exact results. 2. xfs_nameops vector for specifying how to perform the hash generation of filenames and comparision methods. In this patch the hash vector points to the existing xfs_da_hashname function and the comparison method does a length compare, and if the same, does a memcmp and return the xfs_dacmp result. All filename functions that use the hash (create, lookup remove, rename, etc) now use the xfs_nameops.hashname function and all directory lookup functions also use the xfs_nameops.compname function. The lookup functions also handle case-insensitive results even though the default comparison function cannot return that. And important aspect of the lookup functions is that an exact match always has precedence over a case-insensitive. So while a case-insensitive match is found, we have to keep looking just in case there is an exact match. In the meantime, the info for the first case-insensitive match is retained if no exact match is found. SGI-PV: 981519 SGI-Modid: xfs-linux-melb:xfs-kern:31205a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Remove unused arg from kmem_free()Denys Vlasenko
kmem_free() function takes (ptr, size) arguments but doesn't actually use second one. This patch removes size argument from all callsites. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31050a Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] remove bhv_vname_t and xfs_rename codeBarry Naujok
SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30804a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-10[XFS] remove shouting-indirection macros from xfs_sb.hEric Sandeen
Remove macro-to-small-function indirection from xfs_sb.h, and remove some which are completely unused. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30528a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Fix up sparse warnings.David Chinner
These are mostly locking annotations, marking things static, casts where needed and declaring stuff in header files. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30002a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] clean up vnode/inode tracingLachlan McIlroy
Simplify vnode tracing calls by embedding function name & return addr in the calling macro. Also do a lot of vnode->inode renaming for consistency, while we're at it. SGI-PV: 970335 SGI-Modid: xfs-linux-melb:xfs-kern:29650a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] move v_trace from bhv_vnode to xfs_inodeChristoph Hellwig
struct bhv_vnode is on it's way out, so move the trace buffer to the XFS inode. Note that this makes the tracing macros rather misnamed, but this kind of fallout will be fixed up incrementally later on. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29498a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] decontaminate vnode operations from behavior detailsChristoph Hellwig
All vnode ops now take struct xfs_inode pointers and the behaviour related glue is split out into methods of it's own. This required fixing xfs_create/mkdir/symlink to not mess with the inode pointer but rather use a separate boolean for error handling. Thanks to Dave Chinner for that fix. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29492a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] use filldir internallyChristoph Hellwig
Currently xfs has a rather complicated internal scheme to allow for different directory formats in IRIX. This patch rips all code related to this out and pushes useage of the Linux filldir callback into the lowlevel directory code. This does not make the code any less portable because filldir can be used to create dirents of all possible variations (including the IRIX ones as proved by the IRIX binary emulation code under arch/mips/). This patch get rid of an unessecary copy in the readdir path, about 400 lines of code and one of the last two users of the uio structure. This version is updated to deal with dmapi aswell which greatly simplifies the get_dirattrs code. The dmapi part has been tested using the get_dirattrs tools from the xfstest dmapi suite1 with various small and large directories. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29478a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] Reduce shouting by removing unnecessary macros from dir2 code.Christoph Hellwig
SGI-PV: 966505 SGI-Modid: xfs-linux-melb:xfs-kern:28947a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-11-11[XFS] rename uio_read() to xfs_uio_read()Vlad Apostolov
SGI-PV: 957004 SGI-Modid: xfs-linux-melb:xfs-kern:27231a Signed-off-by: Vlad Apostolov <vapo@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Add parameters to xfs_bmapi() and xfs_bunmapi() to have them reportOlaf Weber
the range spanned by modifications to the in-core extent map. Add XFS_BUNMAPI() and XFS_SWAP_EXTENTS() macros that call xfs_bunmapi() and xfs_swap_extents() via the ioops vector. Change all calls that may modify the in-core extent map for the data fork to go through the ioops vector. This allows a cache of extent map data to be kept in sync. SGI-PV: 947615 SGI-Modid: xfs-linux-melb:xfs-kern:209226a Signed-off-by: Olaf Weber <olaf@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
