path: root/fs/xfs/xfs_ialloc_btree.c
2011-07-13xfs: remove leftovers of the old btree tracing codeChristoph Hellwig
Remove various bits left over from the old kdb-only btree tracing code, but leave the actual trace point stubs in place to ease adding new event based btree tracing. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-10-18xfs: remove the ->kill_root btree operationChristoph Hellwig
The implementation os ->kill_root only differ by either simply zeroing out the now unused buffer in the btree cursor in the inode allocation btree or using xfs_btree_setbuf in the allocation btree. Initially both of them used xfs_btree_setbuf, but the use in the ialloc btree was removed early on because it interacted badly with xfs_trans_binval. In addition to zeroing out the buffer in the cursor xfs_btree_setbuf updates the bc_ra array in the btree cursor, and calls xfs_trans_brelse on the buffer previous occupying the slot. The bc_ra update should be done for the alloc btree updated too, although the lack of it does not cause serious problems. The xfs_trans_brelse call on the other hand is effectively a no-op in the end - it keeps decrementing the bli_recur refcount until it hits zero, and then just skips out because the buffer will always be dirty at this point. So removing it for the allocation btree is just fine. So unify the code and move it to xfs_btree.c. While we're at it also replace the call to xfs_btree_setbuf with a NULL bp argument in xfs_btree_del_cursor with a direct call to xfs_trans_brelse given that the cursor is beeing freed just after this and the state updates are superflous. After this xfs_btree_setbuf is only used with a non-NULL bp argument and can thus be simplified. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-07-26xfs: remove unneeded #include statementsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2010-07-26xfs: drop dmapi hooksChristoph Hellwig
Dmapi support was never merged upstream, but we still have a lot of hooks bloating XFS for it, all over the fast pathes of the filesystem. This patch drops over 700 lines of dmapi overhead. If we'll ever get HSM support in mainline at least the namespace events can be done much saner in the VFS instead of the individual filesystem, so it's not like this is much help for future work. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2009-03-29xfs: fix various typosMalcolm Parsons
Signed-off-by: Malcolm Parsons <malcolm.parsons@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2008-10-30[XFS] Always use struct xfs_btree_block instead of short / longformChristoph Hellwig
structures. Always use the generic xfs_btree_block type instead of the short / long structures. Add XFS_BTREE_SBLOCK_LEN / XFS_BTREE_LBLOCK_LEN defines for the length of a short / long form block. The rationale for this is that we will grow more btree block header variants to support CRCs and other RAS information, and always accessing them through the same datatype with unions for the short / long form pointers makes implementing this much easier. SGI-PV: 988146 SGI-Modid: xfs-linux-melb:xfs-kern:32300a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-10-30[XFS] Cleanup maxrecs calculation.Christoph Hellwig
Clean up the way the maximum and minimum records for the btree blocks are calculated. For the alloc and inobt btrees all the values are pre-calculated in xfs_mount_common, and we switch the current loop around the ugly generic macros that use cpp token pasting to generate type names to two small helpers in normal C code. For the bmbt and bmdr trees these helpers also exist, but can be called during runtime, too. Here we also kill various macros dealing with them and inline the logic into the get_minrecs / get_maxrecs / get_dmaxrecs methods in xfs_bmap_btree.c. Note that all these new helpers take an xfs_mount * argument which will be needed to determine the size of a btree block once we add support for extended btree blocks with CRCs and other RAS information. SGI-PV: 988146 SGI-Modid: xfs-linux-melb:xfs-kern:32292a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-10-30[XFS] add keys_inorder and recs_inorder btree methodsChristoph Hellwig
Add methods to check whether two keys/records are in the righ order. This replaces the xfs_btree_check_key and xfs_btree_check_rec methods. For the callers from xfs_bmap.c just opencode the bmbt-specific asserts. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32208a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_get_recChristoph Hellwig
Not really much reason to make it generic given that it's so small, but this is the last non-method in xfs_alloc_btree.c and xfs_ialloc_btree.c, so it makes the whole btree implementation more structured. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32206a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_delete/delrecChristoph Hellwig
Make the btree delete code generic. Based on a patch from David Chinner with lots of changes to follow the original btree implementations more closely. While this loses some of the generic helper routines for inserting/moving/removing records it also solves some of the one off bugs in the original code and makes it easier to verify. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32205a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] move xfs_bmbt_killroot to common codeChristoph Hellwig
xfs_bmbt_killroot is a mostly generic implementation of moving from a real block based root to an inode based root. So move it to xfs_btree.c where it can use all the nice infrastructure there and make it pointer size agnostic The new name for it is xfs_btree_kill_iroot, following the old naming but making it clear we're dealing with the root in inode case here, and to avoid confusion with xfs_btree_new_root which is used for the not inode rooted case. I've also added a comment describing what it does and why it's named the way it is. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32203a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_insert/insrecChristoph Hellwig
Make the btree insert code generic. Based on a patch from David Chinner with lots of changes to follow the original btree implementations more closely. While this loses some of the generic helper routines for inserting/moving/removing records it also solves some of the one off bugs in the original code and makes it easier to verify. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32202a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement semi-generic xfs_btree_new_rootChristoph Hellwig
From: Dave Chinner <dgc@sgi.com> Add a xfs_btree_new_root helper for the alloc and ialloc btrees. The bmap btree needs it's own version and is not converted. [hch: split out from bigger patch and minor adaptions] SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32200a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_splitChristoph Hellwig
Make the btree split code generic. Based on a patch from David Chinner with lots of changes to follow the original btree implementations more closely. While this loses some of the generic helper routines for inserting/moving/removing records it also solves some of the one off bugs in the original code and makes it easier to verify. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32198a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_lshiftChristoph Hellwig
Make the btree left shift code generic. Based on a patch from David Chinner with lots of changes to follow the original btree implementations more closely. While this loses some of the generic helper routines for inserting/moving/removing records it also solves some of the one off bugs in the original code and makes it easier to verify. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32197a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_rshiftChristoph Hellwig
Make the btree right shift code generic. Based on a patch from David Chinner with lots of changes to follow the original btree implementations more closely. While this loses some of the generic helper routines for inserting/moving/removing records it also solves some of the one off bugs in the original code and makes it easier to verify. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32196a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_updateChristoph Hellwig
From: Dave Chinner <dgc@sgi.com> The most complicated part here is the lastrec tracking for the alloc btree. Most logic is in the update_lastrec method which has to do some hopefully good enough dirty magic to maintain it. [hch: split out from bigger patch and a rework of the lastrec logic] SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32194a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_updkeyChristoph Hellwig
From: Dave Chinner <dgc@sgi.com> Note that there are many > 80 char lines introduced due to the xfs_btree_key casts. But the places where this happens is throw-away code once the whole btree code gets merged into a common implementation. The same is true for the temporary xfs_alloc_log_keys define to the new name. All old users will be gone after a few patches. [hch: split out from bigger patch and minor adaptions] SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32193a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_lookupChristoph Hellwig
From: Dave Chinner <dgc@sgi.com> [hch: split out from bigger patch and minor adaptions] SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32192a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_decrementChristoph Hellwig
From: Dave Chinner <dgc@sgi.com> [hch: split out from bigger patch and minor adaptions] SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32191a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_incrementChristoph Hellwig
From: Dave Chinner <dgc@sgi.com> Because this is the first major generic btree routine this patch includes some infrastrucure, first a few routines to deal with a btree block that can be either in short or long form, second xfs_btree_read_buf_block, which is the new central routine to read a btree block given a cursor, and third the new xfs_btree_ptr_addr routine to calculate the address for a given btree pointer record. [hch: split out from bigger patch and minor adaptions] SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32190a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] add helpers for addressing entities inside a btree blockChristoph Hellwig
Add new helpers in xfs_btree.c to find the record, key and block pointer entries inside a btree block. To implement this genericly the ->get_maxrecs methods and two new xfs_btree_ops entries for the key and record sizes are used. Also add a big comment describing how the addressing inside a btree block works. Note that these helpers are unused until users are introduced in the next patches and this patch will thus cause some harmless compiler warnings. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32189a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] add get_maxrecs btree operationChristoph Hellwig
Factor xfs_btree_maxrecs into a per-btree operation. The get_maxrecs method is based on a patch from Dave Chinner. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32188a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] make btree tracing genericChristoph Hellwig
Make the existing bmap btree tracing generic so that it applies to all btree types. Some fragments lifted from a patch by Dave Chinner. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32187a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] split up xfs_btree_init_cursorChristoph Hellwig
xfs_btree_init_cursor contains close to little shared code for the different btrees and will get even more non-common code in the future. Split it up into one routine per btree type. Because xfs_btree_dup_cursor needs to call the init routine for a generic btree cursor add a new btree operation vector that contains a dup_cursor method that initializes a new cursor based on an existing one. The btree operations vector is based on an idea and code from Dave Chinner and will grow more entries later during this series. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32176a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-08-13[XFS] Use the same btree_cur union member for alloc and inobt trees.Christoph Hellwig
The alloc and inobt btree use the same agbp/agno pair in the btree_cur union. Make them use the same bc_private.a union member so that code for these two short form btree implementations can be shared. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31788a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-13xfs: convert beX_add to beX_add_cpu (new common API)Marcin Slusarz
remove beX_add functions and replace all uses with beX_add_cpu Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Dave Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-28[XFS] use NULL for pointer initialisation instead of zero-cast-to-ptrNathan Scott
SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26562a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] remove left over INT_ comments in *alloc*.c We can verify endianessChristoph Hellwig
handling with sparse now, no need for comments. SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26557a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] endianess annotations for xfs_inobt_rec_t / xfs_inobt_key_tChristoph Hellwig
SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26556a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Endianess annotations for various allocator data structuresChristoph Hellwig
SGI-PV: 943272 SGI-Modid: xfs-linux:xfs-kern:201006a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] silence gcc4 warnings. the directory ones are wrong because ofChristoph Hellwig
information gcc could not find out (that a directory always has a .. entry), the others are outright gcc bugs. SGI-PV: 943511 SGI-Modid: xfs-linux:xfs-kern:200055a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
