The inode unlinked list manipulations operate directly on the inode
buffer, and so bypass the inode CRC calculation mechanisms. Hence an
inode on the unlinked list has an invalid CRC. Fix this by
recalculating the CRC whenever we modify an unlinked list pointer in
an inode, ncluding during log recovery. This is trivial to do and
results in unlinked list operations always leaving a consistent
inode in the buffer.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
(cherry picked from commit 0a32c26e720a8b38971d0685976f4a7d63f9e2ef)
Running a CONFIG_XFS_DEBUG kernel in production environments is not
the best idea as it introduces significant overhead, can change
the behaviour of algorithms (such as allocation) to improve test
coverage, and (most importantly) panic the machine on non-fatal
errors.
There are many cases where all we want to do is run a
kernel with more bounds checking enabled, such as is provided by the
ASSERT() statements throughout the code, but without all the
potential overhead and drawbacks.
This patch converts all the ASSERT statements to evaluate as
WARN_ON(1) statements and hence if they fail dump a warning and a
stack trace to the log. This has minimal overhead and does not
change any algorithms, and will allow us to find strange "out of
bounds" problems more easily on production machines.
There are a few places where assert statements contain debug only
code. These are converted to be debug-or-warn only code so that we
still get all the assert checks in the code.
Reviewed-by: Brian Foster <bfoster@redhat.com>
Add a new inode version with a larger core. The primary objective is
to allow for a crc of the inode, and location information (uuid and ino)
to verify it was written in the right place. We also extend it by:
a creation time (for Samba);
a changecount (for NFSv4);
a flush sequence (in LSN format for recovery);
an additional inode flags field; and
some additional padding.
These additional fields are not implemented yet, but already laid
out in the structure.
[dchinner@redhat.com] Added LSN and flags field, some factoring and rework to
capture all the necessary information in the crc calculation.
Reviewed-by: Ben Myers <bpm@sgi.com>
Add support for larger btree blocks that contains a CRC32C checksum,
a filesystem uuid and block number for detecting filesystem
consistency and out of place writes.
[dchinner@redhat.com] Also include an owner field to allow reverse
mappings to be implemented for improved repairability and a LSN
field to so that log recovery can easily determine the last
modification that made it to disk for each buffer.
[dchinner@redhat.com] Add buffer log format flags to indicate the
type of buffer to recovery so that we don't have to do blind magic
number tests to determine what the buffer is.
[dchinner@redhat.com] Modified to fit into the verifier structure.
Remove the XFS_TRANS_DEBUG routines. They are no longer appropriate
and have not been used in years
Signed-off-by: Mark Tinguely <tinguely@sgi.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
To separate the verifiers from iodone functions and associate read
and write verifiers at the same time, introduce a buffer verifier
operations structure to the xfs_buf.
This avoids the need for assigning the write verifier, clearing the
iodone function and re-running ioend processing in the read
verifier, and gets rid of the nasty "b_pre_io" name for the write
verifier function pointer. If we ever need to, it will also be
easier to add further content specific callbacks to a buffer with an
ops structure in place.
We also avoid needing to export verifier functions, instead we
can simply export the ops structures for those that are needed
outside the function they are defined in.
This patch also fixes a directory block readahead verifier issue
it exposed.
This patch also adds ops callbacks to the inode/alloc btree blocks
initialised by growfs. These will need more work before they will
work with CRCs.
Reviewed-by: Phil White <pwhite@sgi.com>
Metadata buffers that are read from disk have write verifiers
already attached to them, but newly allocated buffers do not. Add
appropriate write verifiers to all new metadata buffers.
These verifiers are essentially the same code as the read verifiers,
but do not require ioend processing. Hence factor the read verifier
functions and add a new write verifier wrapper that is used as the
callback.
This is done as one large patch for all verifiers rather than one
patch per verifier as the change is largely mechanical. This
includes hooking up the write verifier via the read verifier
function.
Hooking up the write verifier for buffers obtained via
xfs_trans_get_buf() will be done in a separate patch as that touches
code in many different places rather than just the verifier
functions.
Add an btree block verify callback function and pass it into the
buffer read functions. Because each different btree block type
requires different verification, add a function to the ops structure
that is called from the generic code.
Also, propagate the verification callback functions through the
readahead functions, and into the external bmap and bulkstat inode
readahead code that uses the generic btree buffer read functions.
Add an inode buffer verify callback function and pass it into the
buffer read functions. Inodes are special in that the verbose checks
will be done when reading the inode, but we still need to sanity
check the buffer when that is first read. Always verify the magic
numbers in all inodes in the buffer, rather than jus ton debug
kernels.
Add a verifier function callback capability to the buffer read
interfaces. This will be used by the callers to supply a function
that verifies the contents of the buffer when it is read from disk.
This patch does not provide callback functions, but simply modifies
the interfaces to allow them to be called.
The reason for adding this to the read interfaces is that it is very
difficult to tell fom the outside is a buffer was just read from
disk or whether we just pulled it out of cache. Supplying a callbck
allows the buffer cache to use it's internal knowledge of the buffer
to execute it only when the buffer is read from disk.
It is intended that the verifier functions will mark the buffer with
an EFSCORRUPTED error when verification fails. This allows the
reading context to distinguish a verification error from an IO
error, and potentially take further actions on the buffer (e.g.
attempt repair) based on the error reported.
This check is used in multiple places to determine whether we
should check for (and potentially free) post EOF blocks on an
inode. Add a helper to consolidate the check.
Note that when we remove an inode from the cache (xfs_inactive()),
we are required to trim post-EOF blocks even if the inode is marked
preallocated or append-only to maintain correct space accounting.
The 'force' parameter to xfs_can_free_eofblocks() specifies whether
we should ignore the prealloc/append-only status of the inode.
Signed-off-by: Brian Foster <bfoster@redhat.com>
Inode buffers do not need to be mapped as inodes are read or written
directly from/to the pages underlying the buffer. This fixes a
regression introduced by commit 611c994 ("xfs: make XBF_MAPPED the
default behaviour").
I found some out of date comments while studying the inode allocation
code, so I believe it's worth to have these comments updated.
It basically rewrites the comment regarding to "call_again" variable,
which is not used anymore, but instead, callers of xfs_ialloc() decides
if it needs to be called again relying only if ialloc_context is NULL or
not.
Also did some small changes in another comment that I thought to be
pertinent to the current behaviour of these functions and some alignment
on both comments.
Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com>
The inode cache functions remaining in xfs_iget.c can be moved to xfs_icache.c
along with the other inode cache functions. This removes all functionality from
xfs_iget.c, so the file can simply be removed.
This move results in various functions now only having the scope of a single
file (e.g. xfs_inode_free()), so clean up all the definitions and exported
prototypes in xfs_icache.[ch] and xfs_inode.h appropriately.
xfs_ilock() and friends really aren't related to the inode cache in
any way, so move them to xfs_inode.c with all the other inode
related functionality.
While doing this move, move the xfs_ilock() tracepoints to *before*
the lock is taken so that when a hang on a lock occurs we have
events to indicate which process and what inode we were trying to
lock when the hang occurred. This is much better than the current
silence we get on a hang...
An inode that enters xfs_inactive has been removed from all global
lists but the inode hash, and can't be recycled in xfs_iget before
it has been marked reclaimable. Thus taking the iolock in here
is not nessecary at all, and given the amount of lockdep false
positives it has triggered already I'd rather remove the locking.
The only change outside of xfs_inactive is relaxing an assert in
xfs_itruncate_extents.
Reviewed-by: Rich Johnston <rjohnston@sgi.com>
We can simplify check the IO_agbp pointer for being non-NULL instead of
passing another argument through two layers of function calls.
There is no need to keep this helper around, opencoding it in the only
caller is just as clear.
All callers of xfs_imap_to_bp want the dinode pointer, so let's calculate it
inside xfs_imap_to_bp. Once that is done xfs_itobp becomes a fairly pointless
wrapper which can be replaced with direct calls to xfs_imap_to_bp.
XFS_MAXIOFFSET() is just a simple macro that resolves to
mp->m_maxioffset. It doesn't need to exist, and it just makes the
code unnecessarily loud and shouty.
Make it quiet and easy to read.
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
Rather than specifying XBF_MAPPED for almost all buffers, introduce
XBF_UNMAPPED for the couple of users that use unmapped buffers.
With the removal of xfs_rw.h and other changes over time, xfs_bit.h
is being included in many files that don't actually need it. Clean
up the includes as necessary.
Also move the only-used-once xfs_ialloc_find_free() static inline
function out of a header file that is widely included to reduce
the number of needless dependencies on xfs_bit.h.
The only thing left in xfs_rw.h is a function prototype for an inode
function. Move that to xfs_inode.h, and kill xfs_rw.h.
Also move the function implementing the prototype from xfs_rw.c to
xfs_inode.c so we only have one function left in xfs_rw.c
Buffers are always returned locked from the lookup routines. Hence
we don't need to tell the lookup routines to return locked buffers,
on to try and lock them. Remove XBF_LOCK from all the callers and
from internal buffer cache usage.
xfs_trans_ail_delete_bulk() can be called from different contexts so
if the item is not in the AIL we need different shutdown for each
context. Pass in the shutdown method needed so the correct action
can be taken.
Queue delwri buffers on a local on-stack list instead of a per-buftarg one,
and write back the buffers per-process instead of by waking up xfsbufd.
This is now easily doable given that we have very few places left that write
delwri buffers:
- log recovery:
Only done at mount time, and already forcing out the buffers
synchronously using xfs_flush_buftarg
- quotacheck:
Same story.
- dquot reclaim:
Writes out dirty dquots on the LRU under memory pressure. We might
want to look into doing more of this via xfsaild, but it's already
more optimal than the synchronous inode reclaim that writes each
buffer synchronously.
- xfsaild:
This is the main beneficiary of the change. By keeping a local list
of buffers to write we reduce latency of writing out buffers, and
more importably we can remove all the delwri list promotions which
were hitting the buffer cache hard under sustained metadata loads.
The implementation is very straight forward - xfs_buf_delwri_queue now gets
a new list_head pointer that it adds the delwri buffers to, and all callers
need to eventually submit the list using xfs_buf_delwi_submit or
xfs_buf_delwi_submit_nowait. Buffers that already are on a delwri list are
skipped in xfs_buf_delwri_queue, assuming they already are on another delwri
list. The biggest change to pass down the buffer list was done to the AIL
pushing. Now that we operate on buffers the trylock, push and pushbuf log
item methods are merged into a single push routine, which tries to lock the
item, and if possible add the buffer that needs writeback to the buffer list.
This leads to much simpler code than the previous split but requires the
individual IOP_PUSH instances to unlock and reacquire the AIL around calls
to blocking routines.
Given that xfsailds now also handle writing out buffers, the conditions for
log forcing and the sleep times needed some small changes. The most
important one is that we consider an AIL busy as long we still have buffers
to push, and the other one is that we do increment the pushed LSN for
buffers that are under flushing at this moment, but still count them towards
the stuck items for restart purposes. Without this we could hammer on stuck
items without ever forcing the log and not make progress under heavy random
delete workloads on fast flash storage devices.
[ Dave Chinner:
- rebase on previous patches.
- improved comments for XBF_DELWRI_Q handling
- fix XBF_ASYNC handling in queue submission (test 106 failure)
- rename delwri submit function buffer list parameters for clarity
- xfs_efd_item_push() should return XFS_ITEM_PINNED ]
Instead of writing the buffer directly from inside xfs_iflush return it to
the caller and let the caller decide what to do with the buffer. Also
remove the pincount check in xfs_iflush that all non-blocking callers already
implement and the now unused flags parameter.
If a filesystem has been forced shutdown we are never going to write inodes
to disk, which means the inode items will stay in the AIL until we free
the inode. Currently that is not a problem, but a pending change requires us
to empty the AIL before shutting down the filesystem. In that case leaving
the inode in the AIL is lethal. Make sure to remove the log item from the AIL
to allow emptying the AIL on shutdown filesystems.
Add a new ili_fields member to the inode log item to isolate the in-memory
flags from the ones that actually go to the log. This will allow tracking
timestamp-only updates for fdatasync and O_DSYNC in the next patch and
prepares for divorcing the on-disk log format from the in-memory log item
a little further down the road.
Timestamps on regular files are the last metadata that XFS does not update
transactionally. Now that we use the delaylog mode exclusively and made
the log scode scale extremly well there is no need to bypass that code for
timestamp updates. Logging all updates allows to drop a lot of code, and
will allow for further performance improvements later on.
Note that this patch drops optimized handling of fdatasync - it will be
added back in a separate commit.
There is no fundamental need to keep an in-memory inode size copy in the XFS
inode. We already have the on-disk value in the dinode, and the separate
in-memory copy that we need for regular files only in the XFS inode.
Remove the xfs_inode i_size field and change the XFS_ISIZE macro to use the
VFS inode i_size field for regular files. Switch code that was directly
accessing the i_size field in the xfs_inode to XFS_ISIZE, or in cases where
we are limited to regular files direct access of the VFS inode i_size field.
This also allows dropping some fairly complicated code in the write path
which dealt with keeping the xfs_inode i_size uptodate with the VFS i_size
that is getting updated inside ->write_end.
Note that we do not bother resetting the VFS i_size when truncating a file
that gets freed to zero as there is no point in doing so because the VFS inode
is no longer in use at this point. Just relax the assert in xfs_ifree to
only check the on-disk size instead.
Replace i_pin_wait, which is only used during synchronous inode flushing
with a bit waitqueue. This trades off a much smaller inode against
slightly slower wakeup performance, and saves 12 (32-bit) or 20 (64-bit)
bytes in the XFS inode.
Reviewed-by: Alex Elder <aelder@sgi.com>
We almost never block on i_flock, the exception is synchronous inode
flushing. Instead of bloating the inode with a 16/24-byte completion
that we abuse as a semaphore just implement it as a bitlock that uses
a bit waitqueue for the rare sleeping path. This primarily is a
tradeoff between a much smaller inode and a faster non-blocking
path vs faster wakeups, and we are much better off with the former.
A small downside is that we will lose lockdep checking for i_flock, but
given that it's always taken inside the ilock that should be acceptable.
Note that for example the inode writeback locking is implemented in a
very similar way.
We spent a lot of effort to maintain this field, but it always equals to the
fork size divided by the constant size of an extent. The prime use of it is
to assert that the two stay in sync. Just divide the fork size by the extent
size in the few places that we actually use it and remove the overhead
of maintaining it. Also introduce a few helpers to consolidate the places
where we actually care about the value.
This wrapper isn't overly useful, not to say rather confusing.
Around the call to xfs_itruncate_extents it does:
- add tracing
- add a few asserts in debug builds
- conditionally update the inode size in two places
- log the inode
Both the tracing and the inode logging can be moved to xfs_itruncate_extents
as they are useful for the attribute fork as well - in fact the attr code
already does an equivalent xfs_trans_log_inode call just after calling
xfs_itruncate_extents. The conditional size updates are a mess, and there
was no reason to do them in two places anyway, as the first one was
conditional on the inode having extents - but without extents we
xfs_itruncate_extents would be a no-op and the placement wouldn't matter
anyway. Instead move the size assignments and the asserts that make sense
to the callers that want it.
As a side effect of this clean up xfs_setattr_size by introducing variables
for the old and new inode size, and moving the size updates into a common
place.
If we are doing synchronous inode reclaim we block the VM from making
progress in memory reclaim. So if we encouter a flush locked inode
promote it in the delwri list and wake up xfsbufd to write it out now.
Without this we can get hangs of up to 30 seconds during workloads hitting
synchronous inode reclaim.
The scheme is copied from what we do for dquot reclaims.
Reported-by: Simon Kirby <sim@hostway.ca>
Tested-by: Simon Kirby <sim@hostway.ca>
Signed-off-by: Alex Elder <aelder@sgi.com>
There is no reason to keep a reference to the inode even if we unlock
it during transaction commit because we never drop a reference between
the ijoin and commit. Also use this fact to merge xfs_trans_ijoin_ref
back into xfs_trans_ijoin - the third argument decides if an unlock
is needed now.
I'm actually starting to wonder if allowing inodes to be unlocked
at transaction commit really is worth the effort. The only real
benefit is that they can be unlocked earlier when commiting a
synchronous transactions, but that could be solved by doing the
log force manually after the unlock, too.
xfs_bmapi() currently handles both extent map reading and
allocation. As a result, the code is littered with "if (wr)"
branches to conditionally do allocation operations if required.
This makes the code much harder to follow and causes significant
indent issues with the code.
Given that read mapping is much simpler than allocation, we can
split out read mapping from xfs_bmapi() and reuse the logic that
we have already factored out do do all the hard work of handling the
extent map manipulations. The results in a much simpler function for
the common extent read operations, and will allow the allocation
code to be simplified in another commit.
Once xfs_bmapi_read() is implemented, convert all the callers of
xfs_bmapi() that are only reading extents to use the new function.
Check the return value of xfs_trans_get_buf() and fail
appropriately.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Remove the xfs_buf_relse from xfs_bwrite and let the caller handle it to
mirror the delwri and read paths.
Also remove the mount pointer passed to xfs_bwrite, which is superflous now
that we have a mount pointer in the buftarg.
Unify the ways we add buffers to the delwri queue by always calling
xfs_buf_delwri_queue directly. The xfs_bdwrite functions is removed and
opencoded in its callers, and the two places setting XBF_DELWRI while a
buffer is locked and expecting xfs_buf_unlock to pick it up are converted
to call xfs_buf_delwri_queue directly, too. Also replace the
XFS_BUF_UNDELAYWRITE macro with direct calls to xfs_buf_delwri_dequeue
to make the explicit queuing/dequeuing more obvious.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
Replace the macro XFS_BUF_ISPINNED with an inline helper function
xfs_buf_ispinned, and change all its usages.
Remove the definitions and usage of the macros XFS_BUF_ERROR,
XFS_BUF_GETERROR and XFS_BUF_ISERROR.
Remove various bits left over from the old kdb-only btree tracing code, but
leave the actual trace point stubs in place to ease adding new event based
btree tracing.
