[ Upstream commit 98c4f78dcdd8cec112d1cbc5e9a792ee6e5ab7a6 ]
In xfs_ifree, we reset the data/attr forks to extents format without
bothering to free any inline data buffer that might still be around
after all the blocks have been truncated off the file. Prior to commit
43518812d2 ("xfs: remove support for inlining data/extents into the
inode fork") nobody noticed because the leftover inline data after
truncation was small enough to fit inside the inline buffer inside the
fork itself.
However, now that we've removed the inline buffer, we /always/ have to
free the inline data buffer or else we leak them like crazy. This test
was found by turning on kmemleak for generic/001 or generic/388.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
[ Upstream commit 962cc1ad6caddb5abbb9f0a43e5abe7131a71f18 ]
In commit f2e9ad21 ("xfs: check for race with xfs_reclaim_inode"), we
skip an inode if we're racing with freeing the inode via
xfs_reclaim_inode, but we forgot to release the rcu read lock when
dumping the inode, with the result that we exit to userspace with a lock
held. Don't do that; generic/320 with a 1k block size fails this
very occasionally.
WARNING: lock held when returning to user space!
4.14.0-rc6-djwong #4 Tainted: G W
rm/30466 is leaving the kernel with locks still held!
1 lock held by rm/30466:
#0: (rcu_read_lock){....}, at: [<ffffffffa01364d3>] xfs_ifree_cluster.isra.17+0x2c3/0x6f0 [xfs]
WARNING: CPU: 1 PID: 30466 at kernel/rcu/tree_plugin.h:329 rcu_note_context_switch+0x71/0x700
Modules linked in: deadline_iosched dm_snapshot dm_bufio ext4 mbcache jbd2 dm_flakey xfs libcrc32c dax_pmem device_dax nd_pmem sch_fq_codel af_packet [last unloaded: scsi_debug]
CPU: 1 PID: 30466 Comm: rm Tainted: G W 4.14.0-rc6-djwong #4
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS 1.10.2-1ubuntu1djwong0 04/01/2014
task: ffff880037680000 task.stack: ffffc90001064000
RIP: 0010:rcu_note_context_switch+0x71/0x700
RSP: 0000:ffffc90001067e50 EFLAGS: 00010002
RAX: 0000000000000001 RBX: ffff880037680000 RCX: ffff88003e73d200
RDX: 0000000000000002 RSI: ffffffff819e53e9 RDI: ffffffff819f4375
RBP: 0000000000000000 R08: 0000000000000000 R09: ffff880062c900d0
R10: 0000000000000000 R11: 0000000000000000 R12: ffff880037680000
R13: 0000000000000000 R14: ffffc90001067eb8 R15: ffff880037680690
FS: 00007fa3b8ce8700(0000) GS:ffff88003ec00000(0000) knlGS:0000000000000000
CR2: 00007f69bf77c000 CR3: 000000002450a000 CR4: 00000000000006e0
Call Trace:
__schedule+0xb8/0xb10
schedule+0x40/0x90
exit_to_usermode_loop+0x6b/0xa0
prepare_exit_to_usermode+0x7a/0x90
retint_user+0x8/0x20
RIP: 0033:0x7fa3b87fda87
RSP: 002b:00007ffe41206568 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff02
RAX: 0000000000000000 RBX: 00000000010e88c0 RCX: 00007fa3b87fda87
RDX: 0000000000000000 RSI: 00000000010e89c8 RDI: 0000000000000005
RBP: 0000000000000000 R08: 0000000000000003 R09: 0000000000000000
R10: 000000000000015e R11: 0000000000000246 R12: 00000000010c8060
R13: 00007ffe41206690 R14: 0000000000000000 R15: 0000000000000000
---[ end trace e88f83bf0cfbd07d ]---
Fixes: f2e9ad212def50bcf4c098c6288779dd97fff0f0
Cc: Omar Sandoval <osandov@fb.com>
Reviewed-by: Omar Sandoval <osandov@fb.com>
commit cc6f77710a6de6210f9feda7cd53e2f5ee7a7e69 upstream.
If we have speculative cow preallocations hanging around in the cow
fork, don't let a truncate operation clear the reflink flag because if
we do then there's a chance we'll forget to free those extents when we
destroy the incore inode.
Reported-by: Amir Goldstein <amir73il@gmail.com>
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
commit f2e9ad212def50bcf4c098c6288779dd97fff0f0 upstream.
After xfs_ifree_cluster() finds an inode in the radix tree and verifies
that the inode number is what it expected, xfs_reclaim_inode() can swoop
in and free it. xfs_ifree_cluster() will then happily continue working
on the freed inode. Most importantly, it will mark the inode stale,
which will probably be overwritten when the inode slab object is
reallocated, but if it has already been reallocated then we can end up
with an inode spuriously marked stale.
In 8a17d7ddedb4 ("xfs: mark reclaimed inodes invalid earlier") we added
a second check to xfs_iflush_cluster() to detect this race, but the
similar RCU lookup in xfs_ifree_cluster() needs the same treatment.
Signed-off-by: Omar Sandoval <osandov@fb.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
commit 56bdf855e676f1f2ed7033f288f57dfd315725ba upstream.
According to the commit that implemented per-inode DAX flag:
commit 58f88ca2df72 ("xfs: introduce per-inode DAX enablement")
the flag is supposed to act as "inherit flag".
Currently this only works in the situations where parent directory
already has a flag in di_flags set, otherwise inheritance does not
work. This is because setting the XFS_DIFLAG2_DAX flag is done in a
wrong branch designated for di_flags, not di_flags2.
Fix this by moving the code to branch designated for setting di_flags2,
which does test for flags in di_flags2.
Fixes: 58f88ca2df72 ("xfs: introduce per-inode DAX enablement")
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
commit 3b4683c294095b5f777c03307ef8c60f47320e12 upstream.
Lockdep complains about use of the iolock in inode reclaim context
because it doesn't understand that reclaim has the last reference to
the inode, and thus an iolock->reclaim->iolock deadlock is not
possible.
The iolock is technically not necessary in xfs_inactive() and was
only added to appease an assert in xfs_free_eofblocks(), which can
be called from other non-reclaim contexts. Therefore, just kill the
assert and drop the use of the iolock from reclaim context to quiet
lockdep.
Signed-off-by: Brian Foster <bfoster@redhat.com>
commit 78420281a9d74014af7616958806c3aba056319e upstream.
The inline directory verifiers should be called on the inode fork data,
which means after iformat_local on the read side, and prior to
ifork_flush on the write side. This makes the fork verifier more
consistent with the way buffer verifiers work -- i.e. they will operate
on the memory buffer that the code will be reading and writing directly.
Furthermore, revise the verifier function to return -EFSCORRUPTED so
that we don't flood the logs with corruption messages and assert
notices. This has been a particular problem with xfs/348, which
triggers the XFS_WANT_CORRUPTED_RETURN assertions, which halts the
kernel when CONFIG_XFS_DEBUG=y. Disk corruption isn't supposed to do
that, at least not in a verifier.
commit 630a04e79dd41ff746b545d4fc052e0abb836120 upstream.
When we're reading or writing the data fork of an inline directory,
check the contents to make sure we're not overflowing buffers or eating
garbage data. xfs/348 corrupts an inline symlink into an inline
directory, triggering a buffer overflow bug.
v2: add more checks consistent with _dir2_sf_check and make the verifier
usable from anywhere.
commit 3802a345321a08093ba2ddb1849e736f84e8d450 upstream.
We only want to reclaim preallocations from our periodic work item.
Currently this is archived by looking for a dirty inode, but that check
is rather fragile. Instead add a flag to xfs_reflink_cancel_cow_* so
that the caller can ask for just cancelling unwritten extents in the COW
fork.
[darrick: fix typos in commit message]
commit a36b926180cda375ac2ec89e1748b47137cfc51c upstream.
xfs_free_eofblocks() requires the IOLOCK_EXCL lock, but is called from
different contexts where the lock may or may not be held. The
need_iolock parameter exists for this reason, to indicate whether
xfs_free_eofblocks() must acquire the iolock itself before it can
proceed.
This is ugly and confusing. Simplify the semantics of
xfs_free_eofblocks() to require the caller to acquire the iolock
appropriately and kill the need_iolock parameter. While here, the mp
param can be removed as well as the xfs_mount is accessible from the
xfs_inode structure. This patch does not change behavior.
commit 76d771b4cbe33c581bd6ca2710c120be51172440 upstream.
Currently we try to rely on the global reserved block pool for block
allocations for the free inode btree, but I have customer reports
(fairly complex workload, need to find an easier reproducer) where that
is not enough as the AG where we free an inode that requires a new
finobt block is entirely full. This causes us to cancel a dirty
transaction and thus a file system shutdown.
I think the right way to guard against this is to treat the finot the same
way as the refcount btree and have a per-AG reservations for the possible
worst case size of it, and the patch below implements that.
Note that this could increase mount times with large finobt trees. In
an ideal world we would have added a field for the number of finobt
fields to the AGI, similar to what we did for the refcount blocks.
We should do add it next time we rev the AGI or AGF format by adding
new fields.
commit 200237d6746faaeaf7f4ff4abbf13f3917cee60a upstream.
We've missed properly setting the buffer type for
an AGI transaction in 3 spots now, so just move it
into xfs_read_agi() and set it if we are in a transaction
to avoid the problem in the future.
This is similar to how it is done in i.e. the dir3
and attr3 read functions.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs
< XFS has gained super CoW powers! >
\ ^__^
\ (oo)\_______
(__)\ )\/\
||----w |
Pull XFS support for shared data extents from Dave Chinner:
"This is the second part of the XFS updates for this merge cycle. This
pullreq contains the new shared data extents feature for XFS.
Given the complexity and size of this change I am expecting - like the
addition of reverse mapping last cycle - that there will be some
follow-up bug fixes and cleanups around the -rc3 stage for issues that
I'm sure will show up once the code hits a wider userbase.
What it is:
At the most basic level we are simply adding shared data extents to
XFS - i.e. a single extent on disk can now have multiple owners. To do
this we have to add new on-disk features to both track the shared
extents and the number of times they've been shared. This is done by
the new "refcount" btree that sits in every allocation group. When we
share or unshare an extent, this tree gets updated.
Along with this new tree, the reverse mapping tree needs to be updated
to track each owner or a shared extent. This also needs to be updated
ever share/unshare operation. These interactions at extent allocation
and freeing time have complex ordering and recovery constraints, so
there's a significant amount of new intent-based transaction code to
ensure that operations are performed atomically from both the runtime
and integrity/crash recovery perspectives.
We also need to break sharing when writes hit a shared extent - this
is where the new copy-on-write implementation comes in. We allocate
new storage and copy the original data along with the overwrite data
into the new location. We only do this for data as we don't share
metadata at all - each inode has it's own metadata that tracks the
shared data extents, the extents undergoing CoW and it's own private
extents.
Of course, being XFS, nothing is simple - we use delayed allocation
for CoW similar to how we use it for normal writes. ENOSPC is a
significant issue here - we build on the reservation code added in
4.8-rc1 with the reverse mapping feature to ensure we don't get
spurious ENOSPC issues part way through a CoW operation. These
mechanisms also help minimise fragmentation due to repeated CoW
operations. To further reduce fragmentation overhead, we've also
introduced a CoW extent size hint, which indicates how large a region
we should allocate when we execute a CoW operation.
With all this functionality in place, we can hook up .copy_file_range,
.clone_file_range and .dedupe_file_range and we gain all the
capabilities of reflink and other vfs provided functionality that
enable manipulation to shared extents. We also added a fallocate mode
that explicitly unshares a range of a file, which we implemented as an
explicit CoW of all the shared extents in a file.
As such, it's a huge chunk of new functionality with new on-disk
format features and internal infrastructure. It warns at mount time as
an experimental feature and that it may eat data (as we do with all
new on-disk features until they stabilise). We have not released
userspace suport for it yet - userspace support currently requires
download from Darrick's xfsprogs repo and build from source, so the
access to this feature is really developer/tester only at this point.
Initial userspace support will be released at the same time the kernel
with this code in it is released.
The new code causes 5-6 new failures with xfstests - these aren't
serious functional failures but things the output of tests changing
slightly due to perturbations in layouts, space usage, etc. OTOH,
we've added 150+ new tests to xfstests that specifically exercise this
new functionality so it's got far better test coverage than any
functionality we've previously added to XFS.
Darrick has done a pretty amazing job getting us to this stage, and
special mention also needs to go to Christoph (review, testing,
improvements and bug fixes) and Brian (caught several intricate bugs
during review) for the effort they've also put in.
Summary:
- unshare range (FALLOC_FL_UNSHARE) support for fallocate
- copy-on-write extent size hints (FS_XFLAG_COWEXTSIZE) for fsxattr
interface
- shared extent support for XFS
- copy-on-write support for shared extents
- copy_file_range support
- clone_file_range support (implements reflink)
- dedupe_file_range support
- defrag support for reverse mapping enabled filesystems"
* tag 'xfs-reflink-for-linus-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: (71 commits)
xfs: convert COW blocks to real blocks before unwritten extent conversion
xfs: rework refcount cow recovery error handling
xfs: clear reflink flag if setting realtime flag
xfs: fix error initialization
xfs: fix label inaccuracies
xfs: remove isize check from unshare operation
xfs: reduce stack usage of _reflink_clear_inode_flag
xfs: check inode reflink flag before calling reflink functions
xfs: implement swapext for rmap filesystems
xfs: refactor swapext code
xfs: various swapext cleanups
xfs: recognize the reflink feature bit
xfs: simulate per-AG reservations being critically low
xfs: don't mix reflink and DAX mode for now
xfs: check for invalid inode reflink flags
xfs: set a default CoW extent size of 32 blocks
xfs: convert unwritten status of reverse mappings for shared files
xfs: use interval query for rmap alloc operations on shared files
xfs: add shared rmap map/unmap/convert log item types
xfs: increase log reservations for reflink
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
If the admin doesn't set a CoW extent size or a regular extent size
hint, default to creating CoW reservations 32 blocks long to reduce
fragmentation.
Signed-off-by: DarricK J. Wong <darrick.wong@oracle.com>
Trim CoW reservations made on behalf of a cowextsz hint if they get too
old or we run low on quota, so long as we don't have dirty data awaiting
writeback or directio operations in progress.
Garbage collection of the cowextsize extents are kept separate from
prealloc extent reaping because setting the CoW prealloc lifetime to a
(much) higher value than the regular prealloc extent lifetime has been
useful for combatting CoW fragmentation on VM hosts where the VMs
experience bursty write behaviors and we can keep the utilization ratios
low enough that we don't start to run out of space. IOWs, it benefits
us to keep the CoW fork reservations around for as long as we can unless
we run out of blocks or hit inode reclaim.
Create a per-inode extent size allocator hint for copy-on-write. This
hint is separate from the existing extent size hint so that CoW can
take advantage of the fragmentation-reducing properties of extent size
hints without disabling delalloc for regular writes.
The extent size hint that's fed to the allocator during a copy on
write operation is the greater of the cowextsize and regular extsize
hint.
During reflink, if we're sharing the entire source file to the entire
destination file and the destination file doesn't already have a
cowextsize hint, propagate the source file's cowextsize hint to the
destination file.
Furthermore, zero the bulkstat buffer prior to setting the fields
so that we don't copy kernel memory contents into userspace.
When we're freeing blocks (truncate, punch, etc.), clear all CoW
reservations in the range being freed. If the file block count
drops to zero, also clear the inode reflink flag.
Log recovery will iget an inode to replay BUI items and iput the inode
when it's done. Unfortunately, if the inode was unlinked, the iput
will see that i_nlink == 0 and decide to truncate & free the inode,
which prevents us from replaying subsequent BUIs. We can't skip the
BUIs because we have to replay all the redo items to ensure that
atomic operations complete.
Since unlinked inode recovery will reap the inode anyway, we can
safely introduce a new inode flag to indicate that an inode is in this
'unlinked recovery' state and should not be auto-reaped in the
drop_inode path.
current_fs_time() uses struct super_block* as an argument.
As per Linus's suggestion, this is changed to take struct
inode* as a parameter instead. This is because the function
is primarily meant for vfs inode timestamps.
Also the function was renamed as per Arnd's suggestion.
Change all calls to current_fs_time() to use the new
current_time() function instead. current_fs_time() will be
deleted.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
To avoid clearing of capabilities or security related extended
attributes too early, inode_change_ok() will need to take dentry instead
of inode. Propagate dentry down to functions calling inode_change_ok().
This is rather straightforward except for xfs_set_mode() function which
does not have dentry easily available. Luckily that function does not
call inode_change_ok() anyway so we just have to do a little dance with
function prototypes.
Acked-by: Dave Chinner <dchinner@redhat.com>
Mechanical change of flist/free_list to dfops, since they're now
deferred ops, not just a freeing list.
Drop the compatibility shims that we were using to integrate the new
deferred operation mechanism into the existing code. No new code.
Restructure everything that used xfs_bmap_free to use xfs_defer_ops
instead. For now we'll just remove the old symbols and play some
cpp magic to make it work; in the next patch we'll actually rename
everything.
Al Viro noticed that xfs_lock_inodes should be static, and
that led to ... a few more.
These are just the easy ones, others require moving functions
higher in source files, so that's not done here to keep
this review simple.
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
The cluster inode variable uses unconventional naming - iq - which
makes it hard to distinguish it between the inode passed into the
function - ip - and that is a vector for mistakes to be made.
Rename all the cluster inode variables to use a more conventional
prefixes to reduce potential future confusion (cilist, cilist_size,
cip).
Signed-off-by: Dave Chinner <dchinner@redhat.com>
xfs_iflush_cluster() does a gang lookup on the radix tree, meaning
it can find inodes beyond the current cluster if there is sparse
cache population. gang lookups return results in ascending index
order, so stop trying to cluster inodes once the first inode outside
the cluster mask is detected.
The last thing we do before using call_rcu() on an xfs_inode to be
freed is mark it as invalid. This means there is a window between
when we know for certain that the inode is going to be freed and
when we do actually mark it as "freed".
This is important in the context of RCU lookups - we can look up the
inode, find that it is valid, and then use it as such not realising
that it is in the final stages of being freed.
As such, mark the inode as being invalid the moment we know it is
going to be reclaimed. This can be done while we still hold the
XFS_ILOCK_EXCL and the flush lock in xfs_inode_reclaim, meaning that
it occurs well before we remove it from the radix tree, and that
the i_flags_lock, the XFS_ILOCK and the inode flush lock all act as
synchronisation points for detecting that an inode is about to go
away.
For defensive purposes, this allows us to add a further check to
xfs_iflush_cluster to ensure we skip inodes that are being freed
after we grab the XFS_ILOCK_SHARED and the flush lock - we know that
if the inode number if valid while we have these locks held we know
that it has not progressed through reclaim to the point where it is
clean and is about to be freed.
[bfoster: fixed __xfs_inode_clear_reclaim() using ip->i_ino after it
had already been zeroed.]
We don't write back stale inodes so we should skip them in
xfs_iflush_cluster, too.
cc: <stable@vger.kernel.org> # 3.10.x-
Some careless idiot(*) wrote crap code in commit 1a3e8f3 ("xfs:
convert inode cache lookups to use RCU locking") back in late 2010,
and so xfs_iflush_cluster checks the wrong inode for whether it is
still valid under RCU protection. Fix it to lock and check the
correct inode.
(*) Careless-idiot: Dave Chinner <dchinner@redhat.com>
Discovered-by: Brain Foster <bfoster@redhat.com>
When a failure due to an inode buffer occurs, the error handling
fails to abort the inode writeback correctly. This can result in the
inode being reclaimed whilst still in the AIL, leading to
use-after-free situations as well as filesystems that cannot be
unmounted as the inode log items left in the AIL never get removed.
Fix this by ensuring fatal errors from xfs_imap_to_bp() result in
the inode flush being aborted correctly.
Reported-by: Shyam Kaushik <shyam@zadarastorage.com>
Diagnosed-by: Shyam Kaushik <shyam@zadarastorage.com>
Tested-by: Shyam Kaushik <shyam@zadarastorage.com>
These three warnings are fixed:
fs/xfs/xfs_inode.c:1033:44: warning: Using plain integer as NULL pointer
fs/xfs/xfs_inode_item.c:525:20: warning: context imbalance in 'xfs_inode_item_push' - unexpected unlock
fs/xfs/xfs_dquot.c:696:1: warning: symbol 'xfs_dq_get_next_id' was not declared. Should it be static?
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
Merge xfs_trans_reserve and xfs_trans_alloc into a single function call
that returns a transaction with all the required log and block reservations,
and which allows passing transaction flags directly to avoid the cumbersome
_xfs_trans_alloc interface.
While we're at it we also get rid of the transaction type argument that has
been superflous since we stopped supporting the non-CIL logging mode. The
guts of it will be removed in another patch.
[dchinner: fixed transaction leak in error path in xfs_setattr_nonsize]
Reviewed-by: Dave Chinner <dchinner@redhat.com>
In the next patch we'll set up different inode operations for inline vs
out of line symlinks, for that we need to make sure the flags are already
set up properly.
[dchinner: added xfs_setup_iops() call to xfs_rename_alloc_whiteout()]
They only set/clear/check a flag, no need for obfuscating this
with a macro.
Move the di_mode value from the xfs_icdinode to the VFS inode, reducing
the xfs_icdinode byte another 2 bytes and collapsing another 2 byte hole
in the structure.
We can store the di_changecount in the i_version field of the VFS
inode and remove another 8 bytes from the xfs_icdinode.
Pull another 4 bytes out of the xfs_icdinode.
The VFS tracks the inode nlink just like the xfs_icdinode. We can
remove the variable from the icdinode and use the VFS inode variable
everywhere, reducing the size of the xfs_icdinode by a further 4
bytes.
So we don't have to carry an di_onlink variable around anymore, move
the inode conversion from v1 inode format to v2 inode format into
xfs_inode_from_disk(). This means we can remove the di_onlink fields
from the struct xfs_icdinode.
Now that the struct xfs_icdinode is not directly related to the
on-disk format, we can cull things in it we really don't need to
store:
- magic number never changes
- padding is not necessary
- next_unlinked is never used
- inode number is redundant
- uuid is redundant
- lsn is accessed directly from dinode
- inode CRC is only accessed directly from dinode
Hence we can remove these from the struct xfs_icdinode and redirect
the code that uses them to the xfs_dinode appripriately. This
reduces the size of the struct icdinode from 152 bytes to 88 bytes,
and removes a fair chunk of unnecessary code, too.
The struct xfs_inode has two copies of the current timestamps in it,
one in the vfs inode and one in the struct xfs_icdinode. Now that we
no longer log the struct xfs_icdinode directly, we don't need to
keep the timestamps in this structure. instead we can copy them
straight out of the VFS inode when formatting the inode log item or
the on-disk inode.
This reduces the struct xfs_inode in size by 24 bytes.
Calls to xfs_bmap_finish() and xfs_trans_ijoin(), and the
associated comments were replicated several times across
the attribute code, all dealing with what to do if the
transaction was or wasn't committed.
And in that replicated code, an ASSERT() test of an
uninitialized variable occurs in several locations:
error = xfs_attr_thing(&args);
if (!error) {
error = xfs_bmap_finish(&args.trans, args.flist,
&committed);
if (error) {
ASSERT(committed);
If the first xfs_attr_thing() failed, we'd skip the xfs_bmap_finish,
never set "committed", and then test it in the ASSERT.
Fix this up by moving the committed state internal to xfs_bmap_finish,
and add a new inode argument. If an inode is passed in, it is passed
through to __xfs_trans_roll() and joined to the transaction there if
the transaction was committed.
xfs_qm_dqalloc() was a little unique in that it called bjoin rather
than ijoin, but as Dave points out we can detect the committed state
but checking whether (*tpp != tp).
Addresses-Coverity-Id: 102360
Addresses-Coverity-Id: 102361
Addresses-Coverity-Id: 102363
Addresses-Coverity-Id: 102364
Rather than just being able to turn DAX on and off via a mount
option, some applications may only want to enable DAX for certain
performance critical files in a filesystem.
This patch introduces a new inode flag to enable DAX in the v3 inode
di_flags2 field. It adds support for setting and clearing flags in
the di_flags2 field via the XFS_IOC_FSSETXATTR ioctl, and sets the
S_DAX inode flag appropriately when it is seen.
When this flag is set on a directory, it acts as an "inherit flag".
That is, inodes created in the directory will automatically inherit
the on-disk inode DAX flag, enabling administrators to set up
directory heirarchies that automatically use DAX. Setting this flag
on an empty root directory will make the entire filesystem use DAX
by default.
Now that the ioctls have been hoisted up to the VFS level, use
the VFs definitions directly and remove the XFS specific definitions
completely. Userspace is going to have to handle the change of this
interface separately, so removing the definitions from xfs_fs.h is
not an issue here at all.
