path: root/fs/xfs/xfs_inode.h
2011-07-26xfs: get rid of open-coded S_ISREG(), etc.Al Viro
2011-07-08xfs: remove i_transpChristoph Hellwig
Remove the transaction pointer in the inode. It's only used to avoid passing down an argument in the bmap code, and for a few asserts in the transaction code right now. Also use the local variable ip in a few more places in xfs_inode_item_unlock, so that it isn't only used for debug builds after the above change. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-07-08xfs: split xfs_itruncate_finishChristoph Hellwig
Split the guts of xfs_itruncate_finish that loop over the existing extents and calls xfs_bunmapi on them into a new helper, xfs_itruncate_externs. Make xfs_attr_inactive call it directly instead of xfs_itruncate_finish, which allows to simplify the latter a lot, by only letting it deal with the data fork. As a result xfs_itruncate_finish is renamed to xfs_itruncate_data to make its use case more obvious. Also remove the sync parameter from xfs_itruncate_data, which has been unessecary since the introduction of the busy extent list in 2002, and completely dead code since 2003 when the XFS_BMAPI_ASYNC parameter was made a no-op. I can't actually see why the xfs_attr_inactive needs to set the transaction sync, but let's keep this patch simple and without changes in behaviour. Also avoid passing a useless argument to xfs_isize_check, and make it private to xfs_inode.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-07-08xfs: kill xfs_itruncate_startChristoph Hellwig
xfs_itruncate_start is a rather length wrapper that evaluates to a call to xfs_ioend_wait and xfs_tosspages, and only has two callers. Instead of using the complicated checks left over from IRIX where we can to truncate the pagecache just call xfs_tosspages (aka truncate_inode_pages) directly as we want to get rid of all data after i_size, and truncate_inode_pages handles incorrect alignments and too large offsets just fine. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-06-23xfs: reset inode per-lifetime state when recycling itDave Chinner
XFS inodes has several per-lifetime state fields that determine the behaviour of the inode. These state fields are not all reset when an inode is reused from the reclaimable state. This can lead to unexpected behaviour of the new inode such as speculative preallocation not being truncated away in the expected manner for local files until the inode is subsequently truncated, freed or cycles out of the cache. It can also lead to an inode being considered to be a filestream inode or having been truncated when that is not the case. Rework the reinitialisation of the inode when it is recycled to ensure that it is pristine before it is reused. While there, also fix the resetting of state flags in the recycling error paths so the inode does not become unreclaimable. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-05-25xfs: remove if_lastexChristoph Hellwig
The if_lastex field in struct xfs_ifork is only used as a temporary index during xfs_bmapi and xfs_bunmapi. Instead of using the inode fork to store it keep it local in the callchain. Fortunately this is very easy as we already pass a stack copy of it down the whole chain which can simplify be changed to be passed by reference. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-02-07xfs: add lockdep annotations for the rt inodesChristoph Hellwig
The rt bitmap and summary inodes do not participate in the normal inode locking protocol. Instead the rt bitmap inode can be locked in any transaction involving rt allocations, and the both of the rt inodes can be locked at the same time. Add specific lockdep subclasses for the rt inodes to prevent lockdep from blowing up. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-12-23xfs: don't truncate prealloc from frequently accessed inodesDave Chinner
A long standing problem for streaming writeѕ through the NFS server has been that the NFS server opens and closes file descriptors on an inode for every write. The result of this behaviour is that the ->release() function is called on every close and that results in XFS truncating speculative preallocation beyond the EOF. This has an adverse effect on file layout when multiple files are being written at the same time - they interleave their extents and can result in severe fragmentation. To avoid this problem, keep track of ->release calls made on a dirty inode. For most cases, an inode is only going to be opened once for writing and then closed again during it's lifetime in cache. Hence if there are multiple ->release calls when the inode is dirty, there is a good chance that the inode is being accessed by the NFS server. Hence set a flag the first time ->release is called while there are delalloc blocks still outstanding on the inode. If this flag is set when ->release is next called, then do no truncate away the speculative preallocation - leave it there so that subsequent writes do not need to reallocate the delalloc space. This will prevent interleaving of extents of different inodes written concurrently to the same AG. If we get this wrong, it is not a big deal as we truncate speculative allocation beyond EOF anyway in xfs_inactive() when the inode is thrown out of the cache. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-12-23xfs: provide a inode iolock lockdep classDave Chinner
The XFS iolock needs to be re-initialised to a new lock class before it enters reclaim to prevent lockdep false positives. Unfortunately, this is not sufficient protection as inodes in the XFS_IRECLAIMABLE state can be recycled and not re-initialised before being reused. We need to re-initialise the lock state when transfering out of XFS_IRECLAIMABLE state to XFS_INEW, but we need to keep the same class as if the inode was just allocated. Hence we need a specific lockdep class variable for the iolock so that both initialisations use the same class. While there, add a specific class for inodes in the reclaim state so that it is easy to tell from lockdep reports what state the inode was in that generated the report. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-18xfs: Extend project quotas to support 32bit project idsArkadiusz Mi?kiewicz
This patch adds support for 32bit project quota identifiers. On disk format is backward compatible with 16bit projid numbers. projid on disk is now kept in two 16bit values - di_projid_lo (which holds the same position as old 16bit projid value) and new di_projid_hi (takes existing padding) and converts from/to 32bit value on the fly. xfs_admin (for existing fs), mkfs.xfs (for new fs) needs to be used to enable PROJID32BIT support. Signed-off-by: Arkadiusz Miśkiewicz <arekm@maven.pl> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-10-18xfs: remove xfs_cred.hChristoph Hellwig
We're not actually passing around credentials inside XFS for a while now, so remove all xfs_cred.h with it's cred_t typedef and all instances of it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-10-18xfs: don't use vfs writeback for pure metadata modificationsDave Chinner
Under heavy multi-way parallel create workloads, the VFS struggles to write back all the inodes that have been changed in age order. The bdi flusher thread becomes CPU bound, spending 85% of it's time in the VFS code, mostly traversing the superblock dirty inode list to separate dirty inodes old enough to flush. We already keep an index of all metadata changes in age order - in the AIL - and continued log pressure will do age ordered writeback without any extra overhead at all. If there is no pressure on the log, the xfssyncd will periodically write back metadata in ascending disk address offset order so will be very efficient. Hence we can stop marking VFS inodes dirty during transaction commit or when changing timestamps during transactions. This will keep the inodes in the superblock dirty list to those containing data or unlogged metadata changes. However, the timstamp changes are slightly more complex than this - there are a couple of places that do unlogged updates of the timestamps, and the VFS need to be informed of these. Hence add a new function xfs_trans_ichgtime() for transactional changes, and leave xfs_ichgtime() for the non-transactional changes. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-07-26xfs: simplify and remove xfs_ireclaimDave Chinner
xfs_ireclaim has to get and put te pag structure because it is only called with the inode to reclaim. The one caller of this function already has a reference on the pag and a pointer to is, so move the radix tree delete to the caller and remove xfs_ireclaim completely. This avoids a xfs_perag_get/put on every inode being reclaimed. The overhead was noticed in a bug report at: https://bugzilla.kernel.org/show_bug.cgi?id=16348 Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2010-07-26xfs: remove xfs_iputChristoph Hellwig
xfs_iput is just a small wrapper for xfs_iunlock + IRELE. Having this out of line wrapper means the trace events in those two can't track their caller properly. So just remove the wrapper and opencode the unlock + rele in the few callers. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-07-26xfs: remove xfs_iput_newChristoph Hellwig
We never get an i_mode of 0 or a locked VFS inode until we pass in the XFS_IGET_CREATE flag to xfs_iget, which makes xfs_iput_new equivalent to xfs_iput for the only caller. In addition to that xfs_nfs_get_inode does not even need to lock the inode given that the generation never changes for a life inode, so just pass a 0 lock_flags to xfs_iget and release the inode using IRELE in the error path. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2010-06-24xfs: remove block number from inode lookup codeDave Chinner
The block number comes from bulkstat based inode lookups to shortcut the mapping calculations. We ar enot able to trust anything from bulkstat, so drop the block number as well so that the correct lookups and mappings are always done. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-06-24xfs: rename XFS_IGET_BULKSTAT to XFS_IGET_UNTRUSTEDDave Chinner
Inode numbers may come from somewhere external to the filesystem (e.g. file handles, bulkstat information) and so are inherently untrusted. Rename the flag we use for these lookups to make it obvious we are doing a lookup of an untrusted inode number and need to verify it completely before trying to read it from disk. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-03-01xfs: remove xfs_ipin/xfs_iunpinChristoph Hellwig
Inodes are only pinned/unpinned via the inode item methods, and lots of code relies on that fact. So remove the separate xfs_ipin/xfs_iunpin helpers and merge them into their only callers. This also fixes up various duplicate and/or incorrect comments. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-03-01xfs: implement optimized fdatasyncChristoph Hellwig
Allow us to track the difference between timestamp and size updates by using mark_inode_dirty from the I/O completion code, and checking the VFS inode flags in xfs_file_fsync. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-02-06xfs: Use delayed write for inodes rather than async V2Dave Chinner
We currently do background inode flush asynchronously, resulting in inodes being written in whatever order the background writeback issues them. Not only that, there are also blocking and non-blocking asynchronous inode flushes, depending on where the flush comes from. This patch completely removes asynchronous inode writeback. It removes all the strange writeback modes and replaces them with either a synchronous flush or a non-blocking delayed write flush. That is, inode flushes will only issue IO directly if they are synchronous, and background flushing may do nothing if the operation would block (e.g. on a pinned inode or buffer lock). Delayed write flushes will now result in the inode buffer sitting in the delwri queue of the buffer cache to be flushed by either an AIL push or by the xfsbufd timing out the buffer. This will allow accumulation of dirty inode buffers in memory and allow optimisation of inode cluster writeback at the xfsbufd level where we have much greater queue depths than the block layer elevators. We will also get adjacent inode cluster buffer IO merging for free when a later patch in the series allows sorting of the delayed write buffers before dispatch. This effectively means that any inode that is written back by background writeback will be seen as flush locked during AIL pushing, and will result in the buffers being pushed from there. This writeback path is currently non-optimal, but the next patch in the series will fix that problem. A side effect of this delayed write mechanism is that background inode reclaim will no longer directly flush inodes, nor can it wait on the flush lock. The result is that inode reclaim must leave the inode in the reclaimable state until it is clean. Hence attempts to reclaim a dirty inode in the background will simply skip the inode until it is clean and this allows other mechanisms (i.e. xfsbufd) to do more optimal writeback of the dirty buffers. As a result, the inode reclaim code has been rewritten so that it no longer relies on the ambiguous return values of xfs_iflush() to determine whether it is safe to reclaim an inode. Portions of this patch are derived from patches by Christoph Hellwig. Version 2: - cleanup reclaim code as suggested by Christoph - log background reclaim inode flush errors - just pass sync flags to xfs_iflush Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-02-06xfs: Make inode reclaim states explicitDave Chinner
A.K.A.: don't rely on xfs_iflush() return value in reclaim We have gradually been moving checks out of the reclaim code because they are duplicated in xfs_iflush(). We've had a history of problems in this area, and many of them stem from the overloading of the return values from xfs_iflush() and interaction with inode flush locking to determine if the inode is safe to reclaim. With the desire to move to delayed write flushing of inodes and non-blocking inode tree reclaim walks, the overloading of the return value of xfs_iflush makes it very difficult to determine the correct thing to do next. This patch explicitly re-adds the checks to the inode reclaim code, removing the reliance on the return value of xfs_iflush() to determine what to do next. It also means that we can clearly document all the inode states that reclaim must handle and hence we can easily see that we handled all the necessary cases. This also removes the need for the xfs_inode_clean() check in xfs_iflush() as all callers now check this first (safely). Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2009-12-14xfs: event tracing supportChristoph Hellwig
Convert the old xfs tracing support that could only be used with the out of tree kdb and xfsidbg patches to use the generic event tracer. To use it make sure CONFIG_EVENT_TRACING is enabled and then enable all xfs trace channels by: echo 1 > /sys/kernel/debug/tracing/events/xfs/enable or alternatively enable single events by just doing the same in one event subdirectory, e.g. echo 1 > /sys/kernel/debug/tracing/events/xfs/xfs_ihold/enable or set more complex filters, etc. In Documentation/trace/events.txt all this is desctribed in more detail. To reads the events do a cat /sys/kernel/debug/tracing/trace Compared to the last posting this patch converts the tracing mostly to the one tracepoint per callsite model that other users of the new tracing facility also employ. This allows a very fine-grained control of the tracing, a cleaner output of the traces and also enables the perf tool to use each tracepoint as a virtual performance counter, allowing us to e.g. count how often certain workloads git various spots in XFS. Take a look at http://lwn.net/Articles/346470/ for some examples. Also the btree tracing isn't included at all yet, as it will require additional core tracing features not in mainline yet, I plan to deliver it later. And the really nice thing about this patch is that it actually removes many lines of code while adding this nice functionality: fs/xfs/Makefile | 8 fs/xfs/linux-2.6/xfs_acl.c | 1 fs/xfs/linux-2.6/xfs_aops.c | 52 - fs/xfs/linux-2.6/xfs_aops.h | 2 fs/xfs/linux-2.6/xfs_buf.c | 117 +-- fs/xfs/linux-2.6/xfs_buf.h | 33 fs/xfs/linux-2.6/xfs_fs_subr.c | 3 fs/xfs/linux-2.6/xfs_ioctl.c | 1 fs/xfs/linux-2.6/xfs_ioctl32.c | 1 fs/xfs/linux-2.6/xfs_iops.c | 1 fs/xfs/linux-2.6/xfs_linux.h | 1 fs/xfs/linux-2.6/xfs_lrw.c | 87 -- fs/xfs/linux-2.6/xfs_lrw.h | 45 - fs/xfs/linux-2.6/xfs_super.c | 104 --- fs/xfs/linux-2.6/xfs_super.h | 7 fs/xfs/linux-2.6/xfs_sync.c | 1 fs/xfs/linux-2.6/xfs_trace.c | 75 ++ fs/xfs/linux-2.6/xfs_trace.h | 1369 +++++++++++++++++++++++++++++++++++++++++ fs/xfs/linux-2.6/xfs_vnode.h | 4 fs/xfs/quota/xfs_dquot.c | 110 --- fs/xfs/quota/xfs_dquot.h | 21 fs/xfs/quota/xfs_qm.c | 40 - fs/xfs/quota/xfs_qm_syscalls.c | 4 fs/xfs/support/ktrace.c | 323 --------- fs/xfs/support/ktrace.h | 85 -- fs/xfs/xfs.h | 16 fs/xfs/xfs_ag.h | 14 fs/xfs/xfs_alloc.c | 230 +----- fs/xfs/xfs_alloc.h | 27 fs/xfs/xfs_alloc_btree.c | 1 fs/xfs/xfs_attr.c | 107 --- fs/xfs/xfs_attr.h | 10 fs/xfs/xfs_attr_leaf.c | 14 fs/xfs/xfs_attr_sf.h | 40 - fs/xfs/xfs_bmap.c | 507 +++------------ fs/xfs/xfs_bmap.h | 49 - fs/xfs/xfs_bmap_btree.c | 6 fs/xfs/xfs_btree.c | 5 fs/xfs/xfs_btree_trace.h | 17 fs/xfs/xfs_buf_item.c | 87 -- fs/xfs/xfs_buf_item.h | 20 fs/xfs/xfs_da_btree.c | 3 fs/xfs/xfs_da_btree.h | 7 fs/xfs/xfs_dfrag.c | 2 fs/xfs/xfs_dir2.c | 8 fs/xfs/xfs_dir2_block.c | 20 fs/xfs/xfs_dir2_leaf.c | 21 fs/xfs/xfs_dir2_node.c | 27 fs/xfs/xfs_dir2_sf.c | 26 fs/xfs/xfs_dir2_trace.c | 216 ------ fs/xfs/xfs_dir2_trace.h | 72 -- fs/xfs/xfs_filestream.c | 8 fs/xfs/xfs_fsops.c | 2 fs/xfs/xfs_iget.c | 111 --- fs/xfs/xfs_inode.c | 67 -- fs/xfs/xfs_inode.h | 76 -- fs/xfs/xfs_inode_item.c | 5 fs/xfs/xfs_iomap.c | 85 -- fs/xfs/xfs_iomap.h | 8 fs/xfs/xfs_log.c | 181 +---- fs/xfs/xfs_log_priv.h | 20 fs/xfs/xfs_log_recover.c | 1 fs/xfs/xfs_mount.c | 2 fs/xfs/xfs_quota.h | 8 fs/xfs/xfs_rename.c | 1 fs/xfs/xfs_rtalloc.c | 1 fs/xfs/xfs_rw.c | 3 fs/xfs/xfs_trans.h | 47 + fs/xfs/xfs_trans_buf.c | 62 - fs/xfs/xfs_vnodeops.c | 8 70 files changed, 2151 insertions(+), 2592 deletions(-) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-14xfs: change the xfs_iext_insert / xfs_iext_removeChristoph Hellwig
Change the xfs_iext_insert / xfs_iext_remove prototypes to pass more information which will allow pushing the trace points from the callers into those functions. This includes folding the whichfork information into the state variable to minimize the addition stack footprint. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-10-08xfs: implement ->dirty_inode to fix timestamp handlingChristoph Hellwig
This is picking up on Felix's repost of Dave's patch to implement a .dirty_inode method. We really need this notification because the VFS keeps writing directly into the inode structure instead of going through methods to update this state. In addition to the long-known atime issue we now also have a caller in VM code that updates c/mtime that way for shared writeable mmaps. And I found another one that no one has noticed in practice in the FIFO code. So implement ->dirty_inode to set i_update_core whenever the inode gets externally dirtied, and switch the c/mtime handling to the same scheme we already use for atime (always picking up the value from the Linux inode). Note that this patch also removes the xfs_synchronize_atime call in xfs_reclaim it was superflous as we already synchronize the time when writing the inode via the log (xfs_inode_item_format) or the normal buffers (xfs_iflush_int). In addition also remove the I_CLEAR check before copying the Linux timestamps - now that we always have the Linux inode available we can always use the timestamps in it. Also switch to just using file_update_time for regular reads/writes - that will get us all optimization done to it for free and make sure we notice early when it breaks. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Felix Blyakher <felixb@sgi.com> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-09-01xfs: simplify xfs_trans_igetChristoph Hellwig
xfs_trans_iget is a wrapper for xfs_iget that adds the inode to the transaction after it is read. Except when the inode already is in the inode cache, in which case it returns the existing locked inode with increment lock recursion counts. Now, no one in the tree every decrements these lock recursion counts, so any user of this gets a potential double unlock when both the original owner of the inode and the xfs_trans_iget caller unlock it. When looking back in a git bisect in the historic XFS tree there was only one place that decremented these counts, xfs_trans_iput. Introduced in commit ca25df7a840f426eb566d52667b6950b92bb84b5 by Adam Sweeney in 1993, and removed in commit 19f899a3ab155ff6a49c0c79b06f2f61059afaf3 by Steve Lord in 2003. And as long as it didn't slip through git bisects cracks never actually used in that time frame. A quick audit of the callers of xfs_trans_iget shows that no caller really relies on this behaviour fortunately - xfs_ialloc allows this inode from disk so it must not be there before, and all the RT allocator routines only every add each RT bitmap inode once. In addition to removing lots of code and reducing the size of the inode item this patch also avoids the double inode cache lookup in each create/mkdir/mknod transaction. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2009-09-01xfs: merge fsync and O_SYNC handlingChristoph Hellwig
The guarantees for O_SYNC are exactly the same as the ones we need to make for an fsync call (and given that Linux O_SYNC is O_DSYNC the equivalent is fdadatasync, but we treat both the same in XFS), except with a range data writeout. Jan Kara has started unifying these two path for filesystems using the generic helpers, and I've started to look at XFS. The actual transaction commited by xfs_fsync and xfs_write_sync_logforce has a different transaction number, but actually is exactly the same. We'll only use the fsync transaction going forward. One major difference is that xfs_write_sync_logforce never issues a cache flush unless we commit a transaction causing that as a side-effect, which is an obvious bug in the O_SYNC handling. Second all the locking and i_update_size vs i_update_core changes from 978b7237123d007b9fa983af6e0e2fa8f97f9934 never made it to xfs_write_sync_logforce, so we add them back. To make xfs_fsync easily usable from the O_SYNC path, the filemap_fdatawait call is moved up to xfs_file_fsync, so that we don't wait on the whole file after we already waited for our portion in xfs_write. We'll also use a plain call to filemap_write_and_wait_range instead of the previous sync_page_rang which did it in two steps including an half-hearted inode write out that doesn't help us. Once we're done with this also remove the now useless i_update_size tracking. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Felix Blyakher <felixb@sgi.com> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2009-08-31xfs: add more statics & drop some unused functionsEric Sandeen
A lot more functions could be made static, but they need forward declarations; this does some easy ones, and also found a few unused functions in the process. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2009-08-07xfs: fix freeing of inodes not yet added to the inode cacheChristoph Hellwig
When freeing an inode that lost race getting added to the inode cache we must not call into ->destroy_inode, because that would delete the inode that won the race from the inode cache radix tree. This patch uses splits a new xfs_inode_free helper out of xfs_ireclaim and uses that plus __destroy_inode to make sure we really only free the memory allocted for the inode that lost the race, and not mess with the inode cache state. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net> Reported-by: Alex Samad <alex@samad.com.au> Reported-by: Andrew Randrianasulu <randrik@mail.ru> Reported-by: Stephane <sharnois@max-t.com> Reported-by: Tommy <tommy@news-service.com> Reported-by: Miah Gregory <mace@darksilence.net> Reported-by: Gabriel Barazer <gabriel@oxeva.fr> Reported-by: Leandro Lucarella <llucax@gmail.com> Reported-by: Daniel Burr <dburr@fami.com.au> Reported-by: Nickolay <newmail@spaces.ru> Reported-by: Michael Guntsche <mike@it-loops.com> Reported-by: Dan Carley <dan.carley+linuxkern-bugs@gmail.com> Reported-by: Michael Ole Olsen <gnu@gmx.net> Reported-by: Michael Weissenbacher <mw@dermichi.com> Reported-by: Martin Spott <Martin.Spott@mgras.net> Reported-by: Christian Kujau <lists@nerdbynature.de> Tested-by: Michael Guntsche <mike@it-loops.com> Tested-by: Dan Carley <dan.carley+linuxkern-bugs@gmail.com> Tested-by: Christian Kujau <lists@nerdbynature.de>
2009-06-24switch xfs to generic acl caching helpersAl Viro
2009-06-10xfs: use generic Posix ACL codeChristoph Hellwig
This patch rips out the XFS ACL handling code and uses the generic fs/posix_acl.c code instead. The ondisk format is of course left unchanged. This also introduces the same ACL caching all other Linux filesystems do by adding pointers to the acl and default acl in struct xfs_inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
2009-03-29xfs: fix various typosMalcolm Parsons
Signed-off-by: Malcolm Parsons <malcolm.parsons@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2008-12-29[XFS] Fix merge failuresLachlan McIlroy
Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: fs/xfs/linux-2.6/xfs_cred.h fs/xfs/linux-2.6/xfs_globals.h fs/xfs/linux-2.6/xfs_ioctl.c fs/xfs/xfs_vnodeops.h Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-11[XFS] resync headers with libxfsChristoph Hellwig
- xfs_sb.h add the XFS_SB_VERSION2_PARENTBIT features2 that has been around in userspace for some time - xfs_inode.h: move a few things out of __KERNEL__ that are needed by userspace - xfs_mount.h: only include xfs_sync.h under __KERNEL__ - xfs_inode.c: minor whitespace fixup. I accidentaly changes this when importing this file for use by userspace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-10[XFS] Remove unused tracing codeLachlan McIlroy
None of this code appears to be used anywhere so remove it. Reviewed-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-04move inode tracing out of xfs_vnode.Christoph Hellwig
Move the inode tracing into xfs_iget.c / xfs_inode.h and kill xfs_vnode.c now that it's empty. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-04kill dead inode flagsChristoph Hellwig
There are a few inode flags around that aren't used anywhere, so remove them. Also update xfsidbg to display all used inode flags correctly. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-04cleanup the inode reclaim pathChristoph Hellwig
Merge xfs_iextract and xfs_idestroy into xfs_ireclaim as they are never called individually. Also rewrite most comments in this area as they were severly out of date. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-04remove unused prototypes for xfs_ihash_init / xfs_ihash_freeChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-01[XFS] move inode allocation out xfs_ireadChristoph Hellwig
Allocate the inode in xfs_iget_cache_miss and pass it into xfs_iread. This simplifies the error handling and allows xfs_iread to be shared with userspace which already uses these semantics. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-01[XFS] kill the XFS_IMAP_BULKSTAT flagChristoph Hellwig
Just pass down the XFS_IGET_* flags all the way down to xfs_imap instead of translating them mid-way. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-01[XFS] embededd struct xfs_imap into xfs_inodeChristoph Hellwig
Most uses of struct xfs_imap are to map and inode to a buffer. To avoid copying around the inode location information we should just embedd a strcut xfs_imap into the xfs_inode. To make sure it doesn't bloat an inode the im_len is changed to a ushort, which is fine as that's what the users exepect anyway. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-01[XFS] merge xfs_imap into xfs_dilocateChristoph Hellwig
xfs_imap is the only caller of xfs_dilocate and doesn't add any significant value. Merge the two functions and document the various cases we have for inode cluster lookup in the new xfs_imap. Also remove the unused im_agblkno and im_ioffset fields from struct xfs_imap while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-01[XFS] remove dead code for old inode item recoveryChristoph Hellwig
We have removed the support for old-style inode items a while ago and xlog_recover_do_inode_trans is now only called for XFS_LI_INODE items. That means we can remove the call to xfs_imap there and with it the XFS_IMAP_LOOKUP that is set by all other callers. We can also mark xfs_imap static now. (First sent on October 21st) Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-01[XFS] stop using xfs_itobp in xfs_ireadChristoph Hellwig
The only caller of xfs_itobp that doesn't have i_blkno setup is now the initial inode read. It needs access to the whole xfs_imap so using xfs_inotobp is not an option. Instead opencode the buffer lookup in xfs_iread and kill all the functionality for the initial map from xfs_itobp. (First sent on October 21st) Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-01[XFS] kill xfs_dinode_core_tChristoph Hellwig
Now that we have a separate xfs_icdinode_t for the in-core inode which gets logged there is no need anymore for the xfs_dinode vs xfs_dinode_core split - the fact that part of the structure gets logged through the inode log item and a small part not can better be described in a comment. All sizeof operations on the dinode_core either really wanted the icdinode and are switched to that one, or had already added the size of the agi unlinked list pointer. Later both will be replaced with helpers once we get the larger CRC-enabled dinode. Removing the data and attribute fork unions also has the advantage that xfs_dinode.h doesn't need to pull in every header under the sun. While we're at it also add some more comments describing the dinode structure. (First sent on October 7th) Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-01[XFS] remove i_gen from incore inodeDave Chinner
i_gen is incremented in directory operations when the directory is changed. It is never read or otherwise used so it should be removed to help reduce the size of the struct xfs_inode. The patch also removes a duplicate logging of the directory inode core. We only need to do this once per transaction so kill the one associated with the i_gen increment. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-30[XFS] free partially initialized inodes using destroy_inodeChristoph Hellwig
To make sure we free the security data inodes need to be freed using the proper VFS helper (which we also need to export for this). We mark these inodes bad so we can skip the flush path for them. SGI-PV: 987246 SGI-Modid: xfs-linux-melb:xfs-kern:32398a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
