path: root/fs/xfs/xfs_sync.h
2012-03-13xfs: log timestamp updatesChristoph Hellwig
Timestamps on regular files are the last metadata that XFS does not update transactionally. Now that we use the delaylog mode exclusively and made the log scode scale extremly well there is no need to bypass that code for timestamp updates. Logging all updates allows to drop a lot of code, and will allow for further performance improvements later on. Note that this patch drops optimized handling of fdatasync - it will be added back in a separate commit. Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2011-12-23xfs: log all dirty inodes in xfs_fs_sync_fsChristoph Hellwig
Since Linux 2.6.36 the writeback code has introduces various measures for live lock prevention during sync(). Unfortunately some of these are actively harmful for the XFS model, where the inode gets marked dirty for metadata from the data I/O handler. The older_than_this checks that are now more strictly enforced since writeback: avoid livelocking WB_SYNC_ALL writeback by only calling into __writeback_inodes_sb and thus only sampling the current cut off time once. But on a slow enough devices the previous asynchronous sync pass might not have fully completed yet, and thus XFS might mark metadata dirty only after that sampling of the cut off time for the blocking pass already happened. I have not myself reproduced this myself on a real system, but by introducing artificial delay into the XFS I/O completion workqueues it can be reproduced easily. Fix this by iterating over all XFS inodes in ->sync_fs and log all that are dirty. This might log inode that only got redirtied after the previous pass, but given how cheap delayed logging of inodes is it isn't a major concern for performance. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Tested-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2011-08-12xfs: remove subdirectoriesChristoph Hellwig
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the annoying subdirectories in the XFS source code. Besides the large amount of file rename the only changes are to the Makefile, a few files including headers with the subdirectory prefix, and the binary sysctl compat code that includes a header under fs/xfs/ from kernel/. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
