path: root/fs/xfs/xfs_trans_ail.c
2010-02-02xfs: Don't issue buffer IO direct from AIL push V2Dave Chinner
All buffers logged into the AIL are marked as delayed write. When the AIL needs to push the buffer out, it issues an async write of the buffer. This means that IO patterns are dependent on the order of buffers in the AIL. Instead of flushing the buffer, promote the buffer in the delayed write list so that the next time the xfsbufd is run the buffer will be flushed by the xfsbufd. Return the state to the xfsaild that the buffer was promoted so that the xfsaild knows that it needs to cause the xfsbufd to run to flush the buffers that were promoted. Using the xfsbufd for issuing the IO allows us to dispatch all buffer IO from the one queue. This means that we can make much more enlightened decisions on what order to flush buffers to disk as we don't have multiple places issuing IO. Optimisations to xfsbufd will be in a future patch. Version 2 - kill XFS_ITEM_FLUSHING as it is now unused. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-01-21xfs: cleanup up xfs_log_force calling conventionsChristoph Hellwig
Remove the XFS_LOG_FORCE argument which was always set, and the XFS_LOG_URGE define, which was never used. Split xfs_log_force into a two helpers - xfs_log_force which forces the whole log, and xfs_log_force_lsn which forces up to the specified LSN. The underlying implementations already were entirely separate, as were the users. Also re-indent the new _xfs_log_force/_xfs_log_force which previously had a weird coding style. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-01-15xfs: Don't wake the aild once per secondDave Chinner
Now that the AIL push algorithm is traversal safe, we don't need a watchdog function in the xfsaild to catch pushes that fail to make progress. Remove the watchdog timeout and make pushes purely driven by demand. This will remove the once-per-second wakeup that is seen when the filesystem is idle and make laptop power misers happy. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-11-17xfs: copy li_lsn before dropping AIL lockNathaniel W. Turner
Access to log items on the AIL is generally protected by m_ail_lock; this is particularly needed when we're getting or setting the 64-bit li_lsn on a 32-bit platform. This patch fixes a couple places where we were accessing the log item after dropping the AIL lock on 32-bit machines. This can result in a partially-zeroed log->l_tail_lsn if xfs_trans_ail_delete is racing with xfs_trans_ail_update, and in at least some cases, this can leave the l_tail_lsn with a zero cycle number, which means xlog_space_left will think the log is full (unless CONFIG_XFS_DEBUG is set, in which case we'll trip an ASSERT), leading to processes stuck forever in xlog_grant_log_space. Thanks to Adrian VanderSpek for first spotting the race potential and to Dave Chinner for debug assistance. Signed-off-by: Nathaniel W. Turner <nate@houseofnate.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-03-29xfs: fix various typosMalcolm Parsons
Signed-off-by: Malcolm Parsons <malcolm.parsons@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2008-10-30[XFS] correctly select first log item to pushDavid Chinner
Under heavy metadata load we are seeing log hangs. The AIL has items in it ready to be pushed, and they are within the push target window. However, we are not pushing them when the last pushed LSN is less than the LSN of the first log item on the AIL. This is a regression introduced by the AIL push cursor modifications. SGI-PV: 987246 SGI-Modid: xfs-linux-melb:xfs-kern:32409a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-10-30[XFS] Finish removing the mount pointer from the AIL APIDavid Chinner
Change all the remaining AIL API functions that are passed struct xfs_mount pointers to pass pointers directly to the struct xfs_ail being used. With this conversion, all external access to the AIL is via the struct xfs_ail. Hence the operation and referencing of the AIL is almost entirely independent of the xfs_mount that is using it - it is now much more tightly tied to the log and the items it is tracking in the log than it is tied to the xfs_mount. SGI-PV: 988143 SGI-Modid: xfs-linux-melb:xfs-kern:32353a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-10-30[XFS] Move the AIL lock into the struct xfs_ailDavid Chinner
Bring the ail lock inside the struct xfs_ail. This means the AIL can be entirely manipulated via the struct xfs_ail rather than needing both the struct xfs_mount and the struct xfs_ail. SGI-PV: 988143 SGI-Modid: xfs-linux-melb:xfs-kern:32350a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-10-30[XFS] move the AIl traversal over to a consistent interfaceDavid Chinner
With the new cursor interface, it makes sense to make all the traversing code use the cursor interface and make the old one go away. This means more of the AIL interfacing is done by passing struct xfs_ail pointers around the place instead of struct xfs_mount pointers. We can replace the use of xfs_trans_first_ail() in xfs_log_need_covered() as it is only checking if the AIL is empty. We can do that with a call to xfs_trans_ail_tail() instead, where a zero LSN returned indicates and empty AIL... SGI-PV: 988143 SGI-Modid: xfs-linux-melb:xfs-kern:32348a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-10-30[XFS] Use a cursor for AIL traversal.David Chinner
To replace the current generation number ensuring sanity of the AIL traversal, replace it with an external cursor that is linked to the AIL. Basically, we store the next item in the cursor whenever we want to drop the AIL lock to do something to the current item. When we regain the lock. the current item may already be free, so we can't reference it, but the next item in the traversal is already held in the cursor. When we move or delete an object, we search all the active cursors and if there is an item match we clear the cursor(s) that point to the object. This forces the traversal to restart transparently. We don't invalidate the cursor on insert because the cursor still points to a valid item. If the intem is inserted between the current item and the cursor it does not matter; the traversal is considered to be past the insertion point so it will be picked up in the next traversal. Hence traversal restarts pretty much disappear altogether with this method of traversal, which should substantially reduce the overhead of pushing on a busy AIL. Version 2 o add restart logic o comment cursor interface o minor cleanups SGI-PV: 988143 SGI-Modid: xfs-linux-melb:xfs-kern:32347a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-10-30[XFS] Allocate the struct xfs_ailDavid Chinner
Rather than embedding the struct xfs_ail in the struct xfs_mount, allocate it during AIL initialisation. Add a back pointer to the struct xfs_ail so that we can pass around the xfs_ail and still be able to access the xfs_mount if need be. This is th first step involved in isolating the AIL implementation from the surrounding filesystem code. SGI-PV: 988143 SGI-Modid: xfs-linux-melb:xfs-kern:32346a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-04-18[XFS] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30775a Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Replace custom AIL linked-list code with struct list_headJosef 'Jeff' Sipek
Replace the xfs_ail_entry_t with a struct list_head and clean the surrounding code up. Also fixes a livelock in xfs_trans_first_push_ail() by terminating the loop at the head of the list correctly. SGI-PV: 978682 SGI-Modid: xfs-linux-melb:xfs-kern:30636a Signed-off-by: Josef 'Jeff' Sipek <jeffpc@josefsipek.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-03-06[XFS] 977545 977545 977545 977545 977545 977545 xfsaild causing too manyDavid Chinner
wakeups Idle state is not being detected properly by the xfsaild push code. The current idle state is detected by an empty list which may never happen with mostly idle filesystem or one using lazy superblock counters. A single dirty item in the list that exists beyond the push target can result repeated looping attempting to push up to the target because it fails to check if the push target has been acheived or not. Fix by considering a dirty list with everything past the target as an idle state and set the timeout appropriately. SGI-PV: 977545 SGI-Modid: xfs-linux-melb:xfs-kern:30532a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Make xfs_ail_check check less by defaultDavid Chinner
Checking the entire AIL on every insert and remove is prohibitively expensive - the sustained sequntial create rate on a single disk drops from about 1800/s to 60/s because of this checking resulting in the xfslogd becoming cpu bound. By default on debug builds, only check the next and previous entries in the list to ensure they are ordered correctly. If you really want, define XFS_TRANS_DEBUG to use the old behaviour. SGI-PV: 972759 SGI-Modid: xfs-linux-melb:xfs-kern:30372a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Move AIL pushing into it's own threadDavid Chinner
When many hundreds to thousands of threads all try to do simultaneous transactions and the log is in a tail-pushing situation (i.e. full), we can get multiple threads walking the AIL list and contending on the AIL lock. The AIL push is, in effect, a simple I/O dispatch algorithm complicated by the ordering constraints placed on it by the transaction subsystem. It really does not need multiple threads to push on it - even when only a single CPU is pushing the AIL, it can push the I/O out far faster that pretty much any disk subsystem can handle. So, to avoid contention problems stemming from multiple list walkers, move the list walk off into another thread and simply provide a "target" to push to. When a thread requires a push, it sets the target and wakes the push thread, then goes to sleep waiting for the required amount of space to become available in the log. This mechanism should also be a lot fairer under heavy load as the waiters will queue in arrival order, rather than queuing in "who completed a push first" order. Also, by moving the pushing to a separate thread we can do more effectively overload detection and prevention as we can keep context from loop iteration to loop iteration. That is, we can push only part of the list each loop and not have to loop back to the start of the list every time we run. This should also help by reducing the number of items we try to lock and/or push items that we cannot move. Note that this patch is not intended to solve the inefficiencies in the AIL structure and the associated issues with extremely large list contents. That needs to be addresses separately; parallel access would cause problems to any new structure as well, so I'm only aiming to isolate the structure from unbounded parallelism here. SGI-PV: 972759 SGI-Modid: xfs-linux-melb:xfs-kern:30371a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Unwrap AIL_LOCKDonald Douwsma
SGI-PV: 970382 SGI-Modid: xfs-linux-melb:xfs-kern:29739a Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] Radix tree based inode cachingDavid Chinner
One of the perpetual scaling problems XFS has is indexing it's incore inodes. We currently uses hashes and the default hash sizes chosen can only ever be a tradeoff between memory consumption and the maximum realistic size of the cache. As a result, anyone who has millions of inodes cached on a filesystem needs to tunes the size of the cache via the ihashsize mount option to allow decent scalability with inode cache operations. A further problem is the separate inode cluster hash, whose size is based on the ihashsize but is smaller, and so under certain conditions (sparse cluster cache population) this can become a limitation long before the inode hash is causing issues. The following patchset removes the inode hash and cluster hash and replaces them with radix trees to avoid the scalability limitations of the hashes. It also reduces the size of the inodes by 3 pointers.... SGI-PV: 969561 SGI-Modid: xfs-linux-melb:xfs-kern:29481a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Workaround log space issue by increasing XFS_TRANS_PUSH_AIL_RESTARTSVlad Apostolov
SGI-PV: 959264 SGI-Modid: xfs-linux-melb:xfs-kern:27750a Signed-off-by: Vlad Apostolov <vapo@sgi.com> Signed-off-by: David Chatterton <chatz@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Add lock annotations to xfs_trans_update_ail andJosh Triplett
xfs_trans_delete_ail xfs_trans_update_ail and xfs_trans_delete_ail get called with the AIL lock held, and release it. Add lock annotations to these two functions so that sparse can check callers for lock pairing, and so that sparse will not complain about these functions since they intentionally use locks in this manner. SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26807a Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Shutdown the filesystem if all device paths have gone. MadeNathan Scott
shutdown vop flags consistent with sync vop flags declarations too. SGI-PV: 939911 SGI-Modid: xfs-linux-melb:xfs-kern:26096a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-02[XFS] Need to unlock the AIL before calling xfs_force_shutdown() becauseTim Shimmin
when it goes to force out the log, and get the tail lsn, it will want to get the AIL lock. SGI-PV: 940076 SGI-Modid: xfs-linux:xfs-kern:23260a Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
