path: root/fs/xfs/xfs_trans_buf.c
2010-05-24xfs: Ensure inode allocation buffers are fully replayedDave Chinner
With delayed logging, we can get inode allocation buffers in the same transaction inode unlink buffers. We don't currently mark inode allocation buffers in the log, so inode unlink buffers take precedence over allocation buffers. The result is that when they are combined into the same checkpoint, only the unlinked inode chain fields are replayed, resulting in uninitialised inode buffers being detected when the next inode modification is replayed. To fix this, we need to ensure that we do not set the inode buffer flag in the buffer log item format flags if the inode allocation has not already hit the log. To avoid requiring a change to log recovery, we really need to make this a modification that relies only on in-memory sate. We can do this by checking during buffer log formatting (while the CIL cannot be flushed) if we are still in the same sequence when we commit the unlink transaction as the inode allocation transaction. If we are, then we do not add the inode buffer flag to the buffer log format item flags. This means the entire buffer will be replayed, not just the unlinked fields. We do this while CIL flusheѕ are locked out to ensure that we don't race with the sequence numbers changing and hence fail to put the inode buffer flag in the buffer format flags when we really need to. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-05-24xfs: Clean up XFS_BLI_* flag namespaceDave Chinner
Clean up the buffer log format (XFS_BLI_*) flags because they have a polluted namespace. They XFS_BLI_ prefix is used for both in-memory and on-disk flag feilds, but have overlapping values for different flags. Rename the buffer log format flags to use the XFS_BLF_* prefix to avoid confusing them with the in-memory XFS_BLI_* prefixed flags. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-05-19xfs: simplify buffer to transaction matchingChristoph Hellwig
We currenly have a routine xfs_trans_buf_item_match_all which checks if any log item in a transaction contains a given buffer, and a second one that only does this check for the first, embedded chunk of log items. We only use the second routine if we know we only have that log item chunk, so get rid of the limited routine and always use the more complete one. Also rename the old xfs_trans_buf_item_match_all to xfs_trans_buf_item_match and update various surrounding comments, and move the remaining xfs_trans_buf_item_match on top of the file to avoid a forward prototype. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-05-19xfs: remove stale parameter from ->iop_unpin methodDave Chinner
The staleness of a object being unpinned can be directly derived from the object itself - there is no need to extract it from the object then pass it as a parameter into IOP_UNPIN(). This means we can kill the XFS_LID_BUF_STALE flag - it is set, checked and cleared in the same places XFS_BLI_STALE flag in the xfs_buf_log_item so it is now redundant and hence safe to remove. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-03-01xfs: factor common xfs_trans_bjoin codeChristoph Hellwig
Most of xfs_trans_bjoin is duplicated in xfs_trans_get_buf, xfs_trans_getsb and xfs_trans_read_buf. Add a new _xfs_trans_bjoin which can be called by all four functions. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-01-21xfs: remove duplicate buffer flagsChristoph Hellwig
Currently we define aliases for the buffer flags in various namespaces, which only adds confusion. Remove all but the XBF_ flags to clean this up a bit. Note that we still abuse XFS_B_ASYNC/XBF_ASYNC for some non-buffer uses, but I'll clean that up later. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-14xfs: event tracing supportChristoph Hellwig
Convert the old xfs tracing support that could only be used with the out of tree kdb and xfsidbg patches to use the generic event tracer. To use it make sure CONFIG_EVENT_TRACING is enabled and then enable all xfs trace channels by: echo 1 > /sys/kernel/debug/tracing/events/xfs/enable or alternatively enable single events by just doing the same in one event subdirectory, e.g. echo 1 > /sys/kernel/debug/tracing/events/xfs/xfs_ihold/enable or set more complex filters, etc. In Documentation/trace/events.txt all this is desctribed in more detail. To reads the events do a cat /sys/kernel/debug/tracing/trace Compared to the last posting this patch converts the tracing mostly to the one tracepoint per callsite model that other users of the new tracing facility also employ. This allows a very fine-grained control of the tracing, a cleaner output of the traces and also enables the perf tool to use each tracepoint as a virtual performance counter, allowing us to e.g. count how often certain workloads git various spots in XFS. Take a look at http://lwn.net/Articles/346470/ for some examples. Also the btree tracing isn't included at all yet, as it will require additional core tracing features not in mainline yet, I plan to deliver it later. And the really nice thing about this patch is that it actually removes many lines of code while adding this nice functionality: fs/xfs/Makefile | 8 fs/xfs/linux-2.6/xfs_acl.c | 1 fs/xfs/linux-2.6/xfs_aops.c | 52 - fs/xfs/linux-2.6/xfs_aops.h | 2 fs/xfs/linux-2.6/xfs_buf.c | 117 +-- fs/xfs/linux-2.6/xfs_buf.h | 33 fs/xfs/linux-2.6/xfs_fs_subr.c | 3 fs/xfs/linux-2.6/xfs_ioctl.c | 1 fs/xfs/linux-2.6/xfs_ioctl32.c | 1 fs/xfs/linux-2.6/xfs_iops.c | 1 fs/xfs/linux-2.6/xfs_linux.h | 1 fs/xfs/linux-2.6/xfs_lrw.c | 87 -- fs/xfs/linux-2.6/xfs_lrw.h | 45 - fs/xfs/linux-2.6/xfs_super.c | 104 --- fs/xfs/linux-2.6/xfs_super.h | 7 fs/xfs/linux-2.6/xfs_sync.c | 1 fs/xfs/linux-2.6/xfs_trace.c | 75 ++ fs/xfs/linux-2.6/xfs_trace.h | 1369 +++++++++++++++++++++++++++++++++++++++++ fs/xfs/linux-2.6/xfs_vnode.h | 4 fs/xfs/quota/xfs_dquot.c | 110 --- fs/xfs/quota/xfs_dquot.h | 21 fs/xfs/quota/xfs_qm.c | 40 - fs/xfs/quota/xfs_qm_syscalls.c | 4 fs/xfs/support/ktrace.c | 323 --------- fs/xfs/support/ktrace.h | 85 -- fs/xfs/xfs.h | 16 fs/xfs/xfs_ag.h | 14 fs/xfs/xfs_alloc.c | 230 +----- fs/xfs/xfs_alloc.h | 27 fs/xfs/xfs_alloc_btree.c | 1 fs/xfs/xfs_attr.c | 107 --- fs/xfs/xfs_attr.h | 10 fs/xfs/xfs_attr_leaf.c | 14 fs/xfs/xfs_attr_sf.h | 40 - fs/xfs/xfs_bmap.c | 507 +++------------ fs/xfs/xfs_bmap.h | 49 - fs/xfs/xfs_bmap_btree.c | 6 fs/xfs/xfs_btree.c | 5 fs/xfs/xfs_btree_trace.h | 17 fs/xfs/xfs_buf_item.c | 87 -- fs/xfs/xfs_buf_item.h | 20 fs/xfs/xfs_da_btree.c | 3 fs/xfs/xfs_da_btree.h | 7 fs/xfs/xfs_dfrag.c | 2 fs/xfs/xfs_dir2.c | 8 fs/xfs/xfs_dir2_block.c | 20 fs/xfs/xfs_dir2_leaf.c | 21 fs/xfs/xfs_dir2_node.c | 27 fs/xfs/xfs_dir2_sf.c | 26 fs/xfs/xfs_dir2_trace.c | 216 ------ fs/xfs/xfs_dir2_trace.h | 72 -- fs/xfs/xfs_filestream.c | 8 fs/xfs/xfs_fsops.c | 2 fs/xfs/xfs_iget.c | 111 --- fs/xfs/xfs_inode.c | 67 -- fs/xfs/xfs_inode.h | 76 -- fs/xfs/xfs_inode_item.c | 5 fs/xfs/xfs_iomap.c | 85 -- fs/xfs/xfs_iomap.h | 8 fs/xfs/xfs_log.c | 181 +---- fs/xfs/xfs_log_priv.h | 20 fs/xfs/xfs_log_recover.c | 1 fs/xfs/xfs_mount.c | 2 fs/xfs/xfs_quota.h | 8 fs/xfs/xfs_rename.c | 1 fs/xfs/xfs_rtalloc.c | 1 fs/xfs/xfs_rw.c | 3 fs/xfs/xfs_trans.h | 47 + fs/xfs/xfs_trans_buf.c | 62 - fs/xfs/xfs_vnodeops.c | 8 70 files changed, 2151 insertions(+), 2592 deletions(-) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: simplify xfs_buf_get / xfs_buf_read interfacesChristoph Hellwig
Currently the low-level buffer cache interfaces are highly confusing as we have a _flags variant of each that does actually respect the flags, and one without _flags which has a flags argument that gets ignored and overriden with a default set. Given that very few places use the default arguments get rid of the duplication and convert all callers to pass the flags explicitly. Also remove the now confusing _flags postfix. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-08-31fs/xfs: Correct redundant testJulia Lawall
bp was tested for NULL a few lines before, followed by a return, and there is no intervening modification of its value. A simplified version of the semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; expression E; position p1,p2; @@ if (x == NULL || ...) { ... when forall return ...; } ... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\) ( *x == NULL | *x != NULL ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Felix Blyakher <felixb@sgi.com> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2008-10-30[XFS] Finish removing the mount pointer from the AIL APIDavid Chinner
Change all the remaining AIL API functions that are passed struct xfs_mount pointers to pass pointers directly to the struct xfs_ail being used. With this conversion, all external access to the AIL is via the struct xfs_ail. Hence the operation and referencing of the AIL is almost entirely independent of the xfs_mount that is using it - it is now much more tightly tied to the log and the items it is tracking in the log than it is tied to the xfs_mount. SGI-PV: 988143 SGI-Modid: xfs-linux-melb:xfs-kern:32353a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-08-13[XFS] remove shouting-indirection macros from xfs_trans.hEric Sandeen
SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31758a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Ensure errors from xfs_bdstrat() are correctly checked.David Chinner
xfsbdstrat() is declared to return an error. That is never checked because the error is propagated by the xfs_buf_t that is passed through the function. Mark xfsbdstrat() as returning void and comment the prototype on the methods needed for error checking. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30823a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Don't block pdflush when writing back inodesDavid Chinner
When pdflush is writing back inodes, it can get stuck on inode cluster buffers that are currently under I/O. This occurs when we write data to multiple inodes in the same inode cluster at the same time. Effectively, delayed allocation marks the inode dirty during the data writeback. Hence if the inode cluster was flushed during the writeback of the first inode, the writeback of the second inode will block waiting for the inode cluster write to complete before writing it again for the newly dirtied inode. Basically, we want to avoid this from happening so we don't block pdflush and slow down all of writeback. Hence we introduce a non-blocking async inode flush flag that pdflush uses. If this flag is set, we use non-blocking operations (e.g. try locks) whereever we can to avoid blocking or extra I/O being issued. SGI-PV: 970925 SGI-Modid: xfs-linux-melb:xfs-kern:30501a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-10-01Revert "[XFS] Avoid replaying inode buffer initialisation log items if ↵Tim Shimmin
on-disk version is newer." This reverts commit b394e43e995d08821588a22561c6a71a63b4ff27. Lachlan McIlroy says: It tried to fix an issue where log replay is replaying an inode cluster initialisation transaction that should not be replayed because the inode cluster on disk is more up to date. Since we don't log file sizes (we rely on inode flushing to get them to disk) then we can't just replay all the transations in the log and expect the inode to be completely restored. We lose file size updates. Unfortunately this fix is causing more (serious) problems than it is fixing. SGI-PV: 969656 SGI-Modid: xfs-linux-melb:xfs-kern:29804a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-09-18[XFS] Avoid replaying inode buffer initialisation log items if on-disk ↵Lachlan McIlroy
version is newer. SGI-PV: 969656 SGI-Modid: xfs-linux-melb:xfs-kern:29676a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Portability changes: remove prdev, stick to one diagnosticNathan Scott
interface. SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26103a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Shutdown the filesystem if all device paths have gone. MadeNathan Scott
shutdown vop flags consistent with sync vop flags declarations too. SGI-PV: 939911 SGI-Modid: xfs-linux-melb:xfs-kern:26096a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-05[XFS] Fixes a bug in the quota code when allocating a new dquot recordTim Shimmin
which can cause an extent hole to be filled and a free extent to be processed. In this case, we make a few mistakes: forget to pass back the transaction, forget to put a hold on the buffer and forget to add the buf to the new transaction. SGI-PV: 940366 SGI-Modid: xfs-linux:xfs-kern:23594a Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] Add support for project quota, based on Dan Knappes earlier work.Nathan Scott
SGI-PV: 932952 SGI-Modid: xfs-linux:xfs-kern:22805a Signed-off-by: Nathan Scott <nathans@sgi.com>
