The ticket ID is needed to uniquely identify transactions when doing busy
extent matching. Delayed logging changes the lifecycle of busy extents with
respect to the transaction structure lifecycle. Hence we can no longer use
the transaction structure as a means of determining the owner of the busy
extent as it may be freed and reused while the busy extent is still active.
This commit provides the infrastructure to access the xlog_tid_t held in the
ticket from a transaction handle. This avoids the need for callers to peek
into the transaction and log structures to find this out.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
Convert the struct xfs_name to use unsigned chars for the name
strings to match both what is stored on disk (__uint8_t) and what
the VFS expects (unsigned char).
Signed-off-by: Dave Chinner <david@fromorbit.com>
Just another set of types obsfucating the code, remove them.
Reviewed-by: Dave Chinner <david@fromorbit.com>
Currently xfs_ino_t is defined as a u64 which can either be an unsigned
long long or on some 64 bit platforms and unsigned long. Just making
it and unsigned long long mean's it's still always 64 bits wide, but we
don't need to resort to cases to print it.
Fixes a warning regression on 64 bit powerpc in current git.
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
Reviewed-by: Christoph Hellwig <hch@infradead.org>
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30804a
Signed-off-by: Barry Naujok <bnaujok@sgi.com>
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Currently xfs has a rather complicated internal scheme to allow for
different directory formats in IRIX. This patch rips all code related to
this out and pushes useage of the Linux filldir callback into the lowlevel
directory code. This does not make the code any less portable because
filldir can be used to create dirents of all possible variations
(including the IRIX ones as proved by the IRIX binary emulation code under
arch/mips/).
This patch get rid of an unessecary copy in the readdir path, about 400
lines of code and one of the last two users of the uio structure.
This version is updated to deal with dmapi aswell which greatly simplifies
the get_dirattrs code. The dmapi part has been tested using the
get_dirattrs tools from the xfstest dmapi suite1 with various small and
large directories.
SGI-PV: 968563
SGI-Modid: xfs-linux-melb:xfs-kern:29478a
Signed-off-by: David Chinner <dgc@sgi.com>
Signed-off-by: Tim Shimmin <tes@sgi.com>
boilerplate.
SGI-PV: 913862
SGI-Modid: xfs-linux:xfs-kern:23903a
Signed-off-by: Nathan Scott <nathans@sgi.com>
the data/attr forks now grow up/down from either end of the literal area,
rather than dividing the literal area into two chunks and growing both
upward. Means we can now make much more efficient use of the attribute
space, incl. fitting DMF attributes inline in 256 byte inodes, and large
jumps in dbench3 performance numbers. It is self enabling, but can be
forced on/off via the attr2/noattr2 mount options.
SGI-PV: 941645
SGI-Modid: xfs-linux:xfs-kern:23835a
SGI-PV: 932952
SGI-Modid: xfs-linux:xfs-kern:21938a
some platforms
SGI Modid: xfs-linux:xfs-kern:22032a
Signed-off-by: Christoph Hellwig <hch@sgi.com>
infrastructure for it.
Let it rip!
