path: root/fs/xfs/xfs_vnodeops.c
2013-08-12xfs: kill xfs_vnodeops.[ch]Dave Chinner
Now we have xfs_inode.c for holding kernel-only XFS inode operations, move all the inode operations from xfs_vnodeops.c to this new file as it holds another set of kernel-only inode operations. The name of this file traces back to the days of Irix and it's vnodes which we don't have anymore. Essentially this move consolidates the inode locking functions and a bunch of XFS inode operations into the one file. Eventually the high level functions will be merged into the VFS interface functions in xfs_iops.c. This leaves only internal preallocation, EOF block manipulation and hole punching functions in vnodeops.c. Move these to xfs_bmap_util.c where we are already consolidating various in-kernel physical extent manipulation and querying functions. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: create xfs_bmap_util.[ch]Dave Chinner
There is a bunch of code in xfs_bmap.c that is kernel specific and not shared with userspace. To minimise the difference between the kernel and userspace code, shift this unshared code to xfs_bmap_util.c, and the declarations to xfs_bmap_util.h. The biggest issue here is xfs_bmap_finish() - userspace has it's own definition of this function, and so we need to move it out of xfs_bmap.[ch]. This means several other files need to include xfs_bmap_util.h as well. It also introduces and interesting dance for the stack switching code in xfs_bmapi_allocate(). The stack switching/workqueue code is actually moved to xfs_bmap_util.c, so that userspace can simply use a #define in a header file to connect the dots without needing to know about the stack switch code at all. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: reshuffle dir2 definitions around for userspaceDave Chinner
Many of the definitions within xfs_dir2_priv.h are needed in userspace outside libxfs. Definitions within xfs_dir2_priv.h are wholly contained within libxfs, so we need to shuffle some of the definitions around to keep consistency across files shared between user and kernel space. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: separate dquot on disk format definitions out of xfs_quota.hDave Chinner
The on disk format definitions of the on-disk dquot, log formats and quota off log formats are all intertwined with other definitions for quotas. Separate them out into their own header file so they can easily be shared with userspace. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-07-11xfs: Add pquota fields where gquota is used.Chandra Seetharaman
Add project quota changes to all the places where group quota field is used: * add separate project quota members into various structures * split project quota and group quotas so that instead of overriding the group quota members incore, the new project quota members are used instead * get rid of usage of the OQUOTA flag incore, in favor of separate group and project quota flags. * add a project dquot argument to various functions. Not using the pquotino field from superblock yet. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-06-19xfs: fix the symbolic link assert in xfs_ifreeMark Tinguely
Adding an extended attribute to a symbolic link can force that link to an remote extent. xfs_inactive() incorrectly assumes that any symbolic link small enough to be in the inode core is incore, resulting in the remote extent to not be removed. xfs_ifree() will assert on presence of this leaked remote extent. Signed-off-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-05-20xfs: fix rounding in xfs_free_file_spaceDave Chinner
The offset passed into xfs_free_file_space() needs to be rounded down to a certain size, but the rounding mask is built by a 32 bit variable. Hence the mask will always mask off the upper 32 bits of the offset and lead to incorrect writeback and invalidation ranges. This is not actually exposed as a bug because we writeback and invalidate from the rounded offset to the end of the file, and hence the offset we are actually punching a hole out of will always be covered by the code. This needs fixing, however, if we ever want to use exact ranges for writeback/invalidation here... Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-04-21xfs: split out symlink code into it's own file.Dave Chinner
The symlink code is about to get more complicated when CRCs are added for remote symlink blocks. The symlink management code is mostly self contained, so move it to it's own files so that all the new code and the existing symlink code will not be intermingled with other unrelated code. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-03-14xfs: take inode version into account in XFS_LITINOChristoph Hellwig
Add a version argument to XFS_LITINO so that it can return different values depending on the inode version. This is required for the upcoming v3 inodes with a larger fixed layout dinode. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-17xfs: Remove boolean_t typedef completely.Thiago Farina
Since we are using C99 we have one builtin defined in include/linux/types.h, use that instead. v2: you missed one in fs/xfs/xfs_qm_bhv.c, cleaned up. -bpm Signed-off-by: Thiago Farina <tfarina@chromium.org> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-29xfs: byte range granularity for XFS_IOC_ZERO_RANGEDave Chinner
XFS_IOC_ZERO_RANGE simply does not work properly for non page cache aligned ranges. Neither test 242 or 290 exercise this correctly, so the behaviour is completely busted even though the tests pass. Fix it to support full byte range granularity as was originally intended for this ioctl. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-15xfs: make buffer read verication an IO completion functionDave Chinner
Add a verifier function callback capability to the buffer read interfaces. This will be used by the callers to supply a function that verifies the contents of the buffer when it is read from disk. This patch does not provide callback functions, but simply modifies the interfaces to allow them to be called. The reason for adding this to the read interfaces is that it is very difficult to tell fom the outside is a buffer was just read from disk or whether we just pulled it out of cache. Supplying a callbck allows the buffer cache to use it's internal knowledge of the buffer to execute it only when the buffer is read from disk. It is intended that the verifier functions will mark the buffer with an EFSCORRUPTED error when verification fails. This allows the reading context to distinguish a verification error from an IO error, and potentially take further actions on the buffer (e.g. attempt repair) based on the error reported. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Phil White <pwhite@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-14xfs: remove xfs_flushinval_pagesDave Chinner
It's just a simple wrapper around VFS functionality, and is actually bugging in that it doesn't remove mappings before invalidating the page cache. Remove it and replace it with the correct VFS functionality. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Andrew Dahl <adahl@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-14xfs: remove xfs_flush_pagesDave Chinner
It is a complex wrapper around VFS functions, but there are VFS functions that provide exactly the same functionality. Call the VFS functions directly and remove the unnecessary indirection and complexity. We don't need to care about clearing the XFS_ITRUNCATED flag, as that is done during .writepages. Hence is cleared by the VFS writeback path if there is anything to write back during the flush. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Andrew Dahl <adahl@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-14xfs: reverse the check on XFS_IOC_ZERO_RANGEAndrew Dahl
Reversing the check on XFS_IOC_ZERO_RANGE. Range should be zeroed if the start is less than or equal to the end. Signed-off-by: Andrew Dahl <adahl@sgi.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-14xfs: remove xfs_tosspagesDave Chinner
It's a buggy, unnecessary wrapper that is duplicating truncate_pagecache_range(). When replacing the call in xfs_change_file_space(), also ensure that the length being allocated/freed is always positive before making any changes. These checks are done in the lower extent manipulation functions, too, but we need to do them before any page cache operations. Reported-by: Andrew Dahl <adahl@sgi.com> Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-By: Andrew Dahl <adahl@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-08xfs: make xfs_free_eofblocks() non-static, return EAGAIN on trylock failureBrian Foster
Turn xfs_free_eofblocks() into a non-static function, return EAGAIN to indicate trylock failure and make sure this error is not propagated in xfs_release(). Signed-off-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-08xfs: create helper to check whether to free eofblocks on inodeBrian Foster
This check is used in multiple places to determine whether we should check for (and potentially free) post EOF blocks on an inode. Add a helper to consolidate the check. Note that when we remove an inode from the cache (xfs_inactive()), we are required to trim post-EOF blocks even if the inode is marked preallocated or append-only to maintain correct space accounting. The 'force' parameter to xfs_can_free_eofblocks() specifies whether we should ignore the prealloc/append-only status of the inode. Signed-off-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-08xfs: add EOFBLOCKS inode tagging/untaggingBrian Foster
Add the XFS_ICI_EOFBLOCKS_TAG inode tag to identify inodes with speculatively preallocated blocks beyond EOF. An inode is tagged when speculative preallocation occurs and untagged either via truncate down or when post-EOF blocks are freed via release or reclaim. The tag management is intentionally not aggressive to prefer simplicity over the complexity of handling all the corner cases under which post-EOF blocks could be freed (i.e., forward truncation, fallocate, write error conditions, etc.). This means that a tagged inode may or may not have post-EOF blocks after a period of time. The tag is eventually cleared when the inode is released or reclaimed. Signed-off-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-10-17xfs: remove xfs_iget.cDave Chinner
The inode cache functions remaining in xfs_iget.c can be moved to xfs_icache.c along with the other inode cache functions. This removes all functionality from xfs_iget.c, so the file can simply be removed. This move results in various functions now only having the scope of a single file (e.g. xfs_inode_free()), so clean up all the definitions and exported prototypes in xfs_icache.[ch] and xfs_inode.h appropriately. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-10-17xfs: xfs_sync_data is redundant.Dave Chinner
We don't do any data writeback from XFS any more - the VFS is completely responsible for that, including for freeze. We can replace the remaining caller with a VFS level function that achieves the same thing, but without conflicting with current writeback work. This means we can remove the flush_work and xfs_flush_inodes() - the VFS functionality completely replaces the internal flush queue for doing this writeback work in a separate context to avoid stack overruns. This does have one complication - it cannot be called with page locks held. Hence move the flushing of delalloc space when ENOSPC occurs back up into xfs_file_aio_buffered_write when we don't hold any locks that will stall writeback. Unfortunately, writeback_inodes_sb_if_idle() is not sufficient to trigger delalloc conversion fast enough to prevent spurious ENOSPC whent here are hundreds of writers, thousands of small files and GBs of free RAM. Hence we need to use sync_sb_inodes() to block callers while we wait for writeback like the previous xfs_flush_inodes implementation did. That means we have to hold the s_umount lock here, but because this call can nest inside i_mutex (the parent directory in the create case, held by the VFS), we have to use down_read_trylock() to avoid potential deadlocks. In practice, this trylock will succeed on almost every attempt as unmount/remount type operations are exceedingly rare. Note: we always need to pass a count of zero to generic_file_buffered_write() as the previously written byte count. We only do this by accident before this patch by the virtue of ret always being zero when there are no errors. Make this explicit rather than needing to specifically zero ret in the ENOSPC retry case. Signed-off-by: Dave Chinner <dchinner@redhat.com> Tested-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-07-29xfs: avoid the iolock in xfs_free_eofblocks for evicted inodesChristoph Hellwig
Same rational as the last patch - these inodes are not reachable, so don't bother with locking. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Rich Johnston <rjohnston@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-07-29xfs: do not take the iolock in xfs_inactiveChristoph Hellwig
An inode that enters xfs_inactive has been removed from all global lists but the inode hash, and can't be recycled in xfs_iget before it has been marked reclaimable. Thus taking the iolock in here is not nessecary at all, and given the amount of lockdep false positives it has triggered already I'd rather remove the locking. The only change outside of xfs_inactive is relaxing an assert in xfs_itruncate_extents. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Rich Johnston <rjohnston@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-07-29xfs: remove xfs_inactive_attrsChristoph Hellwig
Remove this helper as the code flow is a lot more obvious when it gets merged into its only caller. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Rich Johnston <rjohnston@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-07-29xfs: clean up xfs_inactiveChristoph Hellwig
The code to reserve log space and join the inode to the transaction is common for all cases, so don't duplicate it. Also remove the trivial xfs_inactive_symlink_local helper which can simply be opencode now. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Rich Johnston <rjohnston@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-06-14xfs: make largest supported offset less shoutyDave Chinner
XFS_MAXIOFFSET() is just a simple macro that resolves to mp->m_maxioffset. It doesn't need to exist, and it just makes the code unnecessarily loud and shouty. Make it quiet and easy to read. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-21xfs: fix delalloc quota accounting on failureDave Chinner
xfstest 270 was causing quota reservations way beyond what was sane (ten to hundreds of TB) for a 4GB filesystem. There's a sign problem in the error handling path of xfs_bmapi_reserve_delalloc() because xfs_trans_unreserve_quota_nblks() simple negates the value passed - which doesn't work for an unsigned variable. This causes reservations of close to 2^32 block instead of removing a reservation of a handful of blocks. Fix the same problem in the other xfs_trans_unreserve_quota_nblks() callers where unsigned integer variables are used, too. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-14xfs: make XBF_MAPPED the default behaviourDave Chinner
Rather than specifying XBF_MAPPED for almost all buffers, introduce XBF_UNMAPPED for the couple of users that use unmapped buffers. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-14xfs: move xfs_get_extsz_hint() and kill xfs_rw.hDave Chinner
The only thing left in xfs_rw.h is a function prototype for an inode function. Move that to xfs_inode.h, and kill xfs_rw.h. Also move the function implementing the prototype from xfs_rw.c to xfs_inode.c so we only have one function left in xfs_rw.c Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-14xfs: move xfsagino_t to xfs_types.hDave Chinner
Untangle the header file includes a bit by moving the definition of xfs_agino_t to xfs_types.h. This removes the dependency that xfs_ag.h has on xfs_inum.h, meaning we don't need to include xfs_inum.h everywhere we include xfs_ag.h. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-14xfs: use iolock on XFS_IOC_ALLOCSP callsDave Chinner
fsstress has a particular effective way of stopping debug XFS kernels. We keep seeing assert failures due finding delayed allocation extents where there should be none. This shows up when extracting extent maps and we are holding all the locks we should be to prevent races, so this really makes no sense to see these errors. After checking that fsstress does not use mmap, it occurred to me that fsstress uses something that no sane application uses - the XFS_IOC_ALLOCSP ioctl interfaces for preallocation. These interfaces do allocation of blocks beyond EOF without using preallocation, and then call setattr to extend and zero the allocated blocks. THe problem here is this is a buffered write, and hence the allocation is a delayed allocation. Unlike the buffered IO path, the allocation and zeroing are not serialised using the IOLOCK. Hence the ALLOCSP operation can race with operations holding the iolock to prevent buffered IO operations from occurring. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-14xfs: kill XBF_DONTBLOCKDave Chinner
Just about all callers of xfs_buf_read() and xfs_buf_get() use XBF_DONTBLOCK. This is used to make memory allocation use GFP_NOFS rather than GFP_KERNEL to avoid recursion through memory reclaim back into the filesystem. All the blocking get calls in growfs occur inside a transaction, even though they are no part of the transaction, so all allocation will be GFP_NOFS due to the task flag PF_TRANS being set. The blocking read calls occur during log recovery, so they will probably be unaffected by converting to GFP_NOFS allocations. Hence make XBF_DONTBLOCK behaviour always occur for buffers and kill the flag. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-14xfs: kill XBF_LOCKDave Chinner
Buffers are always returned locked from the lookup routines. Hence we don't need to tell the lookup routines to return locked buffers, on to try and lock them. Remove XBF_LOCK from all the callers and from internal buffer cache usage. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-05-14xfs: clean up buffer get/read call APIDave Chinner
The xfs_buf_get/read API is not consistent in the units it uses, and does not use appropriate or consistent units/types for the variables. Convert the API to use disk addresses and block counts for all buffer get and read calls. Use consistent naming for all the functions and their declarations, and convert the internal functions to use disk addresses and block counts to avoid need to convert them from one type to another and back again. Fix all the callers to use disk addresses and block counts. In many cases, this removes an additional conversion from the function call as the callers already have a block count. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-03-20vfs: check i_nlink limits in vfs_{mkdir,rename_dir,link}Al Viro
New field of struct super_block - ->s_max_links. Maximal allowed value of ->i_nlink or 0; in the latter case all checks still need to be done in ->link/->mkdir/->rename instances. Note that this limit applies both to directoris and to non-directories. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-25xfs: Fix missing xfs_iunlock() on error recovery path in xfs_readlink()Jan Kara
Commit b52a360b forgot to call xfs_iunlock() when it detected corrupted symplink and bailed out. Fix it by jumping to 'out' instead of doing return. CC: stable@kernel.org CC: Carlos Maiolino <cmaiolino@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Alex Elder <elder@kernel.org> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-01-17xfs: remove the i_size field in struct xfs_inodeChristoph Hellwig
There is no fundamental need to keep an in-memory inode size copy in the XFS inode. We already have the on-disk value in the dinode, and the separate in-memory copy that we need for regular files only in the XFS inode. Remove the xfs_inode i_size field and change the XFS_ISIZE macro to use the VFS inode i_size field for regular files. Switch code that was directly accessing the i_size field in the xfs_inode to XFS_ISIZE, or in cases where we are limited to regular files direct access of the VFS inode i_size field. This also allows dropping some fairly complicated code in the write path which dealt with keeping the xfs_inode i_size uptodate with the VFS i_size that is getting updated inside ->write_end. Note that we do not bother resetting the VFS i_size when truncating a file that gets freed to zero as there is no point in doing so because the VFS inode is no longer in use at this point. Just relax the assert in xfs_ifree to only check the on-disk size instead. Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-01-13xfs: remove xfs_itruncate_dataChristoph Hellwig
This wrapper isn't overly useful, not to say rather confusing. Around the call to xfs_itruncate_extents it does: - add tracing - add a few asserts in debug builds - conditionally update the inode size in two places - log the inode Both the tracing and the inode logging can be moved to xfs_itruncate_extents as they are useful for the attribute fork as well - in fact the attr code already does an equivalent xfs_trans_log_inode call just after calling xfs_itruncate_extents. The conditional size updates are a mess, and there was no reason to do them in two places anyway, as the first one was conditional on the inode having extents - but without extents we xfs_itruncate_extents would be a no-op and the placement wouldn't matter anyway. Instead move the size assignments and the asserts that make sense to the callers that want it. As a side effect of this clean up xfs_setattr_size by introducing variables for the old and new inode size, and moving the size updates into a common place. Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-01-03xfs: propagate umode_tAl Viro
2011-11-08xfs: Fix possible memory corruption in xfs_readlinkCarlos Maiolino
Fixes a possible memory corruption when the link is larger than MAXPATHLEN and XFS_DEBUG is not enabled. This also remove the S_ISLNK assert, since the inode mode is checked previously in xfs_readlink_by_handle() and via VFS. Updated to address concerns raised by Ben Hutchings about the loose attention paid to 32- vs 64-bit values, and the lack of handling a potentially negative pathlen value: - Changed type of "pathlen" to be xfs_fsize_t, to match that of ip->i_d.di_size - Added checking for a negative pathlen to the too-long pathlen test, and generalized the message that gets reported in that case to reflect the change As a result, if a negative pathlen were encountered, this function would return EFSCORRUPTED (and would fail an assertion for a debug build)--just as would a too-long pathlen. Signed-off-by: Alex Elder <aelder@sgi.com> Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-10-11xfs: clean up xfs_ioerror_alertChristoph Hellwig
Instead of passing the block number and mount structure explicitly get them off the bp and fix make the argument order more natural. Also move it to xfs_buf.c and stop printing the device name given that we already get the fs name as part of xfs_alert, and we know what device is operates on because of the caller that gets printed, finally rename it to xfs_buf_ioerror_alert and pass __func__ as argument where it makes sense. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-10-11xfs: simplify xfs_trans_ijoin* againChristoph Hellwig
There is no reason to keep a reference to the inode even if we unlock it during transaction commit because we never drop a reference between the ijoin and commit. Also use this fact to merge xfs_trans_ijoin_ref back into xfs_trans_ijoin - the third argument decides if an unlock is needed now. I'm actually starting to wonder if allowing inodes to be unlocked at transaction commit really is worth the effort. The only real benefit is that they can be unlocked earlier when commiting a synchronous transactions, but that could be solved by doing the log force manually after the unlock, too. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-10-11xfs: unlock the inode before log force in xfs_change_file_spaceChristoph Hellwig
Let the transaction commit unlock the inode before it potentially causes a synchronous log force. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-10-11xfs: rename xfs_bmapi to xfs_bmapi_writeDave Chinner
Now that all the read-only users of xfs_bmapi have been converted to use xfs_bmapi_read(), we can remove all the read-only handling cases from xfs_bmapi(). Once this is done, rename xfs_bmapi to xfs_bmapi_write to reflect the fact it is for allocation only. This enables us to kill the XFS_BMAPI_WRITE flag as well. Also clean up xfs_bmapi_write to the style used in the newly added xfs_bmapi_read/delay functions. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-10-11xfs: introduce xfs_bmapi_read()Dave Chinner
xfs_bmapi() currently handles both extent map reading and allocation. As a result, the code is littered with "if (wr)" branches to conditionally do allocation operations if required. This makes the code much harder to follow and causes significant indent issues with the code. Given that read mapping is much simpler than allocation, we can split out read mapping from xfs_bmapi() and reuse the logic that we have already factored out do do all the hard work of handling the extent map manipulations. The results in a much simpler function for the common extent read operations, and will allow the allocation code to be simplified in another commit. Once xfs_bmapi_read() is implemented, convert all the callers of xfs_bmapi() that are only reading extents to use the new function. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-10-11xfs: Check the return value of xfs_trans_get_buf()Chandra Seetharaman
Check the return value of xfs_trans_get_buf() and fail appropriately. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-10-11xfs: remove i_iocountChristoph Hellwig
We now have an i_dio_count filed and surrounding infrastructure to wait for direct I/O completion instead of i_icount, and we have never needed to iocount waits for buffered I/O given that we only set the page uptodate after finishing all required work. Thus remove i_iocount, and replace the actually needed waits with calls to inode_dio_wait. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: replace xfs_buf_geterror() with bp->b_errorChandra Seetharaman
Since we just checked bp for NULL, it is ok to replace xfs_buf_geterror() with bp->b_error in these places. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: Check the return value of xfs_buf_read() for NULLChandra Seetharaman
Check the return value of xfs_buf_read() for NULL and return ENOMEM if it is NULL. This is necessary in a few spots to avoid subsequent code blindly dereferencing the null buffer pointer. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-08Merge branch 'master' of ↵Alex Elder
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
