commit b52a360b2aa1c59ba9970fb0f52bbb093fcc7a24 upstream.
Fixes a possible memory corruption when the link is larger than
MAXPATHLEN and XFS_DEBUG is not enabled. This also remove the
S_ISLNK assert, since the inode mode is checked previously in
xfs_readlink_by_handle() and via VFS.
Updated to address concerns raised by Ben Hutchings about the loose
attention paid to 32- vs 64-bit values, and the lack of handling a
potentially negative pathlen value:
- Changed type of "pathlen" to be xfs_fsize_t, to match that of
ip->i_d.di_size
- Added checking for a negative pathlen to the too-long pathlen
test, and generalized the message that gets reported in that case
to reflect the change
As a result, if a negative pathlen were encountered, this function
would return EFSCORRUPTED (and would fail an assertion for a debug
build)--just as would a too-long pathlen.
Signed-off-by: Alex Elder <aelder@sgi.com>
Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com>
Cc: Ben Myers <bpm@sgi.com>
commit 87c7bec7fc3377b3873eb3a0f4b603981ea16ebb upstream.
The code to flush buffers in the umount code is a bit iffy: we first
flush all delwri buffers out, but then might be able to queue up a
new one when logging the sb counts. On a normal shutdown that one
would get flushed out when doing the synchronous superblock write in
xfs_unmountfs_writesb, but we skip that one if the filesystem has
been shut down.
Fix this by moving the delwri list flushing until just before unmounting
the log, and while we're at it also remove the superflous delwri list
and buffer lru flusing for the rt and log device that can never have
cached or delwri buffers.
Reported-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
Tested-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
commit ed32201e65e15f3e6955cb84cbb544b08f81e5a5 upstream.
An attribute of inode can be fetched via xfs_vn_getattr() in XFS.
Currently it returns EIO, not negative value, when it failed. As a
result, the system call returns not negative value even though an
error occured. The stat(2), ls and mv commands cannot handle this
error and do not work correctly.
This patch fixes this bug, and returns -EIO, not EIO when an error
is detected in xfs_vn_getattr().
Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
commit c58cb165bd44de8aaee9755a144136ae743be116 upstream.
Currently a buffered reader or writer can add pages to the pagecache
while we are waiting for the iolock in xfs_file_dio_aio_write. Prevent
this by re-checking mapping->nrpages after we got the iolock, and if
nessecary upgrade the lock to exclusive mode. To simplify this a bit
only take the ilock inside of xfs_file_aio_write_checks.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
commit 0c38a2512df272b14ef4238b476a2e4f70da1479 upstream.
There is no need to grab the i_mutex of the IO lock in exclusive
mode if we don't need to invalidate the page cache. Taking these
locks on every direct IO effective serialises them as taking the IO
lock in exclusive mode has to wait for all shared holders to drop
the lock. That only happens when IO is complete, so effective it
prevents dispatch of concurrent direct IO reads to the same inode.
Fix this by taking the IO lock shared to check the page cache state,
and only then drop it and take the IO lock exclusively if there is
work to be done. Hence for the normal direct IO case, no exclusive
locking will occur.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Tested-by: Joern Engel <joern@logfs.org>
Currently we have a few issues with the way the workqueue code is used to
implement AIL pushing:
- it accidentally uses the same workqueue as the syncer action, and thus
can be prevented from running if there are enough sync actions active
in the system.
- it doesn't use the HIGHPRI flag to queue at the head of the queue of
work items
At this point I'm not confident enough in getting all the workqueue flags and
tweaks right to provide a perfectly reliable execution context for AIL
pushing, which is the most important piece in XFS to make forward progress
when the log fills.
Revert back to use a kthread per filesystem which fixes all the above issues
at the cost of having a task struct and stack around for each mounted
filesystem. In addition this also gives us much better ways to diagnose
any issues involving hung AIL pushing and removes a small amount of code.
Reported-by: Stefan Priebe <s.priebe@profihost.ag>
Tested-by: Stefan Priebe <s.priebe@profihost.ag>
We need to check for pinned buffers even in .iop_pushbuf given that inode
items flush into the same buffers that may be pinned directly due operations
on the unlinked inode list operating directly on buffers. To do this add a
return value to .iop_pushbuf that tells the AIL push about this and use
the existing log force mechanisms to unpin it.
If an item was locked we should not update xa_last_pushed_lsn and thus skip
it when restarting the AIL scan as we need to be able to lock and write it
out as soon as possible. Otherwise heavy lock contention might starve AIL
pushing too easily, especially given the larger backoff once we moved
xa_last_pushed_lsn all the way to the target lsn.
There is a window in which the ioend that we call inode_dio_wake on
in xfs_end_io_direct_write is already free. Fix this by storing
the inode pointer in a local variable.
This is a fix for the regression introduced in 3.1-rc by
"fs: move inode_dio_done to the end_io handler".
Currently we always redirty an inode that was attempted to be written out
synchronously but has been cleaned by an AIL pushed internall, which is
rather bogus. Fix that by doing the i_update_core check early on and
return 0 for it. Also include async calls for it, as doing any work for
those is just as pointless. While we're at it also fix the sign for the
EIO return in case of a filesystem shutdown, and fix the completely
non-sensical locking around xfs_log_inode.
(cherry picked from commit 297db93bb74cf687510313eb235a7aec14d67e97)
During umount we do not add a dirty inode to the lru and wait for it to
become clean first, but force writeback of data and metadata with
I_WILL_FREE set. Currently there is no way for XFS to detect that the
inode has been redirtied for metadata operations, as we skip the
mark_inode_dirty call during teardown. Fix this by setting i_update_core
nanually in that case, so that the inode gets flushed during inode reclaim.
Alternatively we could enable calling mark_inode_dirty for inodes in
I_WILL_FREE state, and let the VFS dirty tracking handle this. I decided
against this as we will get better I/O patterns from reclaim compared to
the synchronous writeout in write_inode_now, and always marking the inode
dirty in some way from xfs_mark_inode_dirty is a better safetly net in
either case.
(cherry picked from commit da6742a5a4cc844a9982fdd936ddb537c0747856)
The code really requires the current source directory to be in the
header search path. We already do this if building with an object
tree separate from the source, but it needs to be added manually
if building inside the source. The cflags addition for it accidentally
got removed when collapsing the xfs directory structure.
Reviewed-by: Dave Chinner <david@fromorbit.com>
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the
annoying subdirectories in the XFS source code. Besides the large
amount of file rename the only changes are to the Makefile, a few
files including headers with the subdirectory prefix, and the binary
sysctl compat code that includes a header under fs/xfs/ from
kernel/.
Fix up some #include directives in preparation for moving a few
header files out of xfs source subdirectories.
Note that "xfs_linux.h" also got its quoting convention for included
files switched.
Since we just checked bp for NULL, it is ok to replace
xfs_buf_geterror() with bp->b_error in these places.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Check the return value of xfs_buf_read() for NULL and return ENOMEM
if it is NULL. This is necessary in a few spots to avoid subsequent
code blindly dereferencing the null buffer pointer.
xfs: fix for hang during synchronous buffer write error
If removed storage while synchronous buffer write underway,
"xfslogd" hangs.
Detailed log http://oss.sgi.com/archives/xfs/2011-07/msg00740.html
Related work bfc60177f8ab509bc225becbb58f7e53a0e33e81
"xfs: fix error handling for synchronous writes"
Given that xfs_bwrite actually does the shutdown already after
waiting for the b_iodone completion and given that we actually
found that calling xfs_force_shutdown from inside
xfs_buf_iodone_callbacks was a major contributor the problem
it better to drop this call.
Signed-off-by: Ajeet Yadav <ajeet.yadav.77@gmail.com>
In xfs_ail_splice(), if a cursor is provided it is updated to
point to the last item on the list being spliced into the AIL.
But if the AIL was found to be empty, the cursor (if provided)
is just initialized instead.
There is no reason the empty AIL case needs to be treated any
differently. And treating it the same way allows this code
to be rearranged a bit, with a somewhat tidier result.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
xfs: Fix build breakage in xfs_iops.c when CONFIG_FS_POSIX_ACL is not set
VFS: Reorganise shrink_dcache_for_umount_subtree() after demise of dcache_lock
VFS: Remove dentry->d_lock locking from shrink_dcache_for_umount_subtree()
VFS: Remove detached-dentry counter from shrink_dcache_for_umount_subtree()
switch posix_acl_chmod() to umode_t
switch posix_acl_from_mode() to umode_t
switch posix_acl_equiv_mode() to umode_t *
switch posix_acl_create() to umode_t *
block: initialise bd_super in bdget()
vfs: avoid call to inode_lru_list_del() if possible
vfs: avoid taking inode_hash_lock on pipes and sockets
vfs: conditionally call inode_wb_list_del()
VFS: Fix automount for negative autofs dentries
Btrfs: load the key from the dir item in readdir into a fake dentry
devtmpfs: missing initialialization in never-hit case
hppfs: missing include
commit 4e34e719e45, that takes the ACL checks to common code,
accidentely broke the build when CONFIG_FS_POSIX_ACL is not set:
CC fs/xfs/linux-2.6/xfs_iops.o
fs/xfs/linux-2.6/xfs_iops.c:1025:14: error: ‘xfs_get_acl’ undeclared here (not in a function)
Fix this by declaring xfs_get_acl a static inline function.
Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de>
... so that &inode->i_mode could be passed to it
so we can pass &inode->i_mode to it
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: optimize the negative xattr caching
xfs: prevent against ioend livelocks in xfs_file_fsync
xfs: flag all buffers as metadata
xfs: encapsulate a block of debug code
Since the addition of file capabilities every write needs to read xattrs to
check if we have any capabilities to clear. In Linux 3.0 Andi Kleen added
a flag to cache the fact that we do not have any attributes on an inode.
Make sure to already mark a file as not having any attributes when reading
it from disk in case it doesn't even have an attribute fork. Based on an
earlier patch from Andi Kleen.
We need to take some locks to prevent new ioends from coming in when we wait
for all existing ones to go away. Up to Linux 3.0 that was done using the
i_mutex held by the VFS fsync code, but now that we are called without
it we need to take care of it ourselves. Use the I/O lock instead of
i_mutex just like we do in other places.
Now that REQ_META bios aren't treated specially in the CFQ I/O schedule
anymore, we can tag all buffers as metadata to make blktrace traces more
meaningful. Note that we use buffers also to zero out partial blocks
in the preallocation / hole punching code, and while they operate on
data blocks the zeros written certainly aren't data. I think this case
is borderline metadata enough to not bother special casing it.
Pull into a helper function some debug-only code that validates a
xfs_da_blkinfo structure that's been read from disk.
Reviewed-by: Christoph Hellwig <hch@infradead.org>
mode_t is not a bitmap...
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
Remove the definition and usages of the macro XFS_BUFTARG_NAME.
Remove the definition and usages of the macro XFS_BUF_TARGET
Remove the macro XFS_BUF_SET_TARGET.
hch: As all the buffer allocator already set ->b_target it should be safe
to simply remove these calls.
Replace the macro XFS_BUF_ISPINNED with an inline helper function
xfs_buf_ispinned, and change all its usages.
Remove the definition and usages of the macro XFS_BUF_SET_PTR.
Remove the definition and usages of the macro XFS_BUF_PTR.
Remove the definition and usage of the macro XFS_BUF_SET_START.
Remove the definition and usage of the macro XFS_BUF_HOLD
Remove the definitions and uses of the macros XFS_BUF_BUSY,
XFS_BUF_UNBUSY, and XFS_BUF_ISBUSY.
Remove the definitions and usage of the macros XFS_BUF_ERROR,
XFS_BUF_GETERROR and XFS_BUF_ISERROR.
Remove the definition of the macro XFS_BUF_BFLAGS and its usage.
Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with
modified clone, on failure releases acl and replaces with NULL.
Returns 0 or -ve on error. All callers of posix_acl_create_masq()
switched.
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified
clone or with NULL if that has failed; returns 0 or -ve on error. All
callers of posix_acl_chmod_masq() switched to that - they'd been doing
exactly the same thing.
Always set up a negative ACL cache entry if the inode doesn't have an
attribute fork. That behaves much better than doing this check inside
->check_acl.
This moves logic for checking the cached ACL values from low-level
filesystems into generic code. The end result is a streamlined ACL
check that doesn't need to load the inode->i_op->check_acl pointer at
all for the common cached case.
The filesystems also don't need to check for a non-blocking RCU walk
case in their acl_check() functions, because that is all handled at a
VFS layer.
The fsync prototype change commit 02c24a82187d accidentally overwrote
the ssize_t return value of xfs_file_aio_write with 0 for SYNC type
writes. Fix this by checking if an error occured when calling
xfs_file_fsync and only change the return value in this case.
In addition xfs_file_fsync actually returns a normal negative error, so
fix this, too.
Tested-by: Christoph Hellwig <hch@lst.de>
