path: root/fs/xfs
2011-09-14xfs: fix a use after free in xfs_end_io_direct_writeChristoph Hellwig
There is a window in which the ioend that we call inode_dio_wake on in xfs_end_io_direct_write is already free. Fix this by storing the inode pointer in a local variable. This is a fix for the regression introduced in 3.1-rc by "fs: move inode_dio_done to the end_io handler". Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-09-01xfs: fix ->write_inode return valuesChristoph Hellwig
Currently we always redirty an inode that was attempted to be written out synchronously but has been cleaned by an AIL pushed internall, which is rather bogus. Fix that by doing the i_update_core check early on and return 0 for it. Also include async calls for it, as doing any work for those is just as pointless. While we're at it also fix the sign for the EIO return in case of a filesystem shutdown, and fix the completely non-sensical locking around xfs_log_inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com> (cherry picked from commit 297db93bb74cf687510313eb235a7aec14d67e97) Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-31xfs: fix xfs_mark_inode_dirty during umountChristoph Hellwig
During umount we do not add a dirty inode to the lru and wait for it to become clean first, but force writeback of data and metadata with I_WILL_FREE set. Currently there is no way for XFS to detect that the inode has been redirtied for metadata operations, as we skip the mark_inode_dirty call during teardown. Fix this by setting i_update_core nanually in that case, so that the inode gets flushed during inode reclaim. Alternatively we could enable calling mark_inode_dirty for inodes in I_WILL_FREE state, and let the VFS dirty tracking handle this. I decided against this as we will get better I/O patterns from reclaim compared to the synchronous writeout in write_inode_now, and always marking the inode dirty in some way from xfs_mark_inode_dirty is a better safetly net in either case. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com> (cherry picked from commit da6742a5a4cc844a9982fdd936ddb537c0747856) Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-25xfs: deprecate the nodelaylog mount optionChristoph Hellwig
2011-08-22xfs: fix tracing builds inside the source treeChristoph Hellwig
The code really requires the current source directory to be in the header search path. We already do this if building with an object tree separate from the source, but it needs to be added manually if building inside the source. The cflags addition for it accidentally got removed when collapsing the xfs directory structure. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: remove subdirectoriesChristoph Hellwig
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the annoying subdirectories in the XFS source code. Besides the large amount of file rename the only changes are to the Makefile, a few files including headers with the subdirectory prefix, and the binary sysctl compat code that includes a header under fs/xfs/ from kernel/. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: don't expect xfs headers to be in subdirectoriesAlex Elder
Fix up some #include directives in preparation for moving a few header files out of xfs source subdirectories. Note that "xfs_linux.h" also got its quoting convention for included files switched. Signed-off-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-08-12xfs: replace xfs_buf_geterror() with bp->b_errorChandra Seetharaman
Since we just checked bp for NULL, it is ok to replace xfs_buf_geterror() with bp->b_error in these places. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: Check the return value of xfs_buf_read() for NULLChandra Seetharaman
Check the return value of xfs_buf_read() for NULL and return ENOMEM if it is NULL. This is necessary in a few spots to avoid subsequent code blindly dereferencing the null buffer pointer. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-10"xfs: fix error handling for synchronous writes" revisitedAjeet Yadav
xfs: fix for hang during synchronous buffer write error If removed storage while synchronous buffer write underway, "xfslogd" hangs. Detailed log http://oss.sgi.com/archives/xfs/2011-07/msg00740.html Related work bfc60177f8ab509bc225becbb58f7e53a0e33e81 "xfs: fix error handling for synchronous writes" Given that xfs_bwrite actually does the shutdown already after waiting for the b_iodone completion and given that we actually found that calling xfs_force_shutdown from inside xfs_buf_iodone_callbacks was a major contributor the problem it better to drop this call. Signed-off-by: Ajeet Yadav <ajeet.yadav.77@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-09xfs: set cursor in xfs_ail_splice() even when AIL was emptyAlex Elder
In xfs_ail_splice(), if a cursor is provided it is updated to point to the last item on the list being spliced into the AIL. But if the AIL was found to be empty, the cursor (if provided) is just initialized instead. There is no reason the empty AIL case needs to be treated any differently. And treating it the same way allows this code to be rearranged a bit, with a somewhat tidier result. Signed-off-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-08-08Merge branch 'master' of ↵Alex Elder
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
2011-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: xfs: Fix build breakage in xfs_iops.c when CONFIG_FS_POSIX_ACL is not set VFS: Reorganise shrink_dcache_for_umount_subtree() after demise of dcache_lock VFS: Remove dentry->d_lock locking from shrink_dcache_for_umount_subtree() VFS: Remove detached-dentry counter from shrink_dcache_for_umount_subtree() switch posix_acl_chmod() to umode_t switch posix_acl_from_mode() to umode_t switch posix_acl_equiv_mode() to umode_t * switch posix_acl_create() to umode_t * block: initialise bd_super in bdget() vfs: avoid call to inode_lru_list_del() if possible vfs: avoid taking inode_hash_lock on pipes and sockets vfs: conditionally call inode_wb_list_del() VFS: Fix automount for negative autofs dentries Btrfs: load the key from the dir item in readdir into a fake dentry devtmpfs: missing initialialization in never-hit case hppfs: missing include
2011-08-01xfs: Fix build breakage in xfs_iops.c when CONFIG_FS_POSIX_ACL is not setMarkus Trippelsdorf
commit 4e34e719e45, that takes the ACL checks to common code, accidentely broke the build when CONFIG_FS_POSIX_ACL is not set: CC fs/xfs/linux-2.6/xfs_iops.o fs/xfs/linux-2.6/xfs_iops.c:1025:14: error: ‘xfs_get_acl’ undeclared here (not in a function) Fix this by declaring xfs_get_acl a static inline function. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_equiv_mode() to umode_t *Al Viro
... so that &inode->i_mode could be passed to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_create() to umode_t *Al Viro
so we can pass &inode->i_mode to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-29xfs: Fix build breakage in xfs_iops.c when CONFIG_FS_POSIX_ACL is not setMarkus Trippelsdorf
commit 4e34e719e45, that takes the ACL checks to common code, accidentely broke the build when CONFIG_FS_POSIX_ACL is not set: CC fs/xfs/linux-2.6/xfs_iops.o fs/xfs/linux-2.6/xfs_iops.c:1025:14: error: ‘xfs_get_acl’ undeclared here (not in a function) Fix this by declaring xfs_get_acl a static inline function. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-27Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: optimize the negative xattr caching xfs: prevent against ioend livelocks in xfs_file_fsync xfs: flag all buffers as metadata xfs: encapsulate a block of debug code
2011-07-26xfs: optimize the negative xattr cachingChristoph Hellwig
Since the addition of file capabilities every write needs to read xattrs to check if we have any capabilities to clear. In Linux 3.0 Andi Kleen added a flag to cache the fact that we do not have any attributes on an inode. Make sure to already mark a file as not having any attributes when reading it from disk in case it doesn't even have an attribute fork. Based on an earlier patch from Andi Kleen. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-26xfs: prevent against ioend livelocks in xfs_file_fsyncChristoph Hellwig
We need to take some locks to prevent new ioends from coming in when we wait for all existing ones to go away. Up to Linux 3.0 that was done using the i_mutex held by the VFS fsync code, but now that we are called without it we need to take care of it ourselves. Use the I/O lock instead of i_mutex just like we do in other places. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-26xfs: flag all buffers as metadataChristoph Hellwig
Now that REQ_META bios aren't treated specially in the CFQ I/O schedule anymore, we can tag all buffers as metadata to make blktrace traces more meaningful. Note that we use buffers also to zero out partial blocks in the preallocation / hole punching code, and while they operate on data blocks the zeros written certainly aren't data. I think this case is borderline metadata enough to not bother special casing it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-26xfs: encapsulate a block of debug codeAlex Elder
Pull into a helper function some debug-only code that validates a xfs_da_blkinfo structure that's been read from disk. Signed-off-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@infradead.org>
2011-07-26xfs: fix misspelled S_IS...()Al Viro
mode_t is not a bitmap... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-26xfs: get rid of open-coded S_ISREG(), etc.Al Viro
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-25xfs: Remove the macro XFS_BUFTARG_NAMEChandra Seetharaman
Remove the definition and usages of the macro XFS_BUFTARG_NAME. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25xfs: Remove the macro XFS_BUF_TARGETChandra Seetharaman
Remove the definition and usages of the macro XFS_BUF_TARGET Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25xfs: Remove the macro XFS_BUF_SET_TARGETChandra Seetharaman
Remove the macro XFS_BUF_SET_TARGET. hch: As all the buffer allocator already set ->b_target it should be safe to simply remove these calls. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25Replace the macro XFS_BUF_ISPINNED with helper xfs_buf_ispinnedChandra Seetharaman
Replace the macro XFS_BUF_ISPINNED with an inline helper function xfs_buf_ispinned, and change all its usages. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25xfs: Remove the macro XFS_BUF_SET_PTRChandra Seetharaman
Remove the definition and usages of the macro XFS_BUF_SET_PTR. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25xfs: Remove the macro XFS_BUF_PTRChandra Seetharaman
Remove the definition and usages of the macro XFS_BUF_PTR. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25xfs: Remove macro XFS_BUF_SET_STARTChandra Seetharaman
Remove the definition and usage of the macro XFS_BUF_SET_START. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25xfs: Remove macro XFS_BUF_HOLDChandra Seetharaman
Remove the definition and usage of the macro XFS_BUF_HOLD Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25xfs: Remove macro XFS_BUF_BUSY and familyChandra Seetharaman
Remove the definitions and uses of the macros XFS_BUF_BUSY, XFS_BUF_UNBUSY, and XFS_BUF_ISBUSY. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25xfs: Remove the macro XFS_BUF_ERROR and familyChandra Seetharaman
Remove the definitions and usage of the macros XFS_BUF_ERROR, XFS_BUF_GETERROR and XFS_BUF_ISERROR. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25xfs: Remove the macro XFS_BUF_BFLAGSChandra Seetharaman
Remove the definition of the macro XFS_BUF_BFLAGS and its usage. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplates around posix_acl_create_masq()Al Viro
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with modified clone, on failure releases acl and replaces with NULL. Returns 0 or -ve on error. All callers of posix_acl_create_masq() switched. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplate around posix_acl_chmod_masq()Al Viro
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified clone or with NULL if that has failed; returns 0 or -ve on error. All callers of posix_acl_chmod_masq() switched to that - they'd been doing exactly the same thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25xfs: cache negative ACLs if there is no attribute forkChristoph Hellwig
Always set up a negative ACL cache entry if the inode doesn't have an attribute fork. That behaves much better than doing this check inside ->check_acl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25vfs: move ACL cache lookup into generic codeLinus Torvalds
This moves logic for checking the cached ACL values from low-level filesystems into generic code. The end result is a streamlined ACL check that doesn't need to load the inode->i_op->check_acl pointer at all for the common cached case. The filesystems also don't need to check for a non-blocking RCU walk case in their acl_check() functions, because that is all handled at a VFS layer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25xfs: Fix wrong return value of xfs_file_aio_writeMarkus Trippelsdorf
The fsync prototype change commit 02c24a82187d accidentally overwrote the ssize_t return value of xfs_file_aio_write with 0 for SYNC type writes. Fix this by checking if an error occured when calling xfs_file_fsync and only change the return value in this case. In addition xfs_file_fsync actually returns a normal negative error, so fix this, too. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-22fs: Merge split stringsJean Delvare
No idea why these were split in the first place... Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: move inode_dio_done to the end_io handlerChristoph Hellwig
For filesystems that delay their end_io processing we should keep our i_dio_count until the the processing is done. Enable this by moving the inode_dio_done call to the end_io handler if one exist. Note that the actual move to the workqueue for ext4 and XFS is not done in this patch yet, but left to the filesystem maintainers. At least for XFS it's not needed yet either as XFS has an internal equivalent to i_dio_count. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20xfs: make use of new shrinker callout for the inode cacheDave Chinner
Convert the inode reclaim shrinker to use the new per-sb shrinker operations. This allows much bigger reclaim batches to be used, and allows the XFS inode cache to be shrunk in proportion with the VFS dentry and inode caches. This avoids the problem of the VFS caches being shrunk significantly before the XFS inode cache is shrunk resulting in imbalances in the caches during reclaim. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20xfs: add size update tracepoint to IO completionDave Chinner
For improving insight into IO completion behaviour. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-20xfs: convert AIL cursors to use struct list_headDave Chinner
The list of active AIL cursors uses a roll-your-own linked list with special casing for the AIL push cursor. Simplify this code by replacing the list with standard struct list_head lists, and use a separate list_head to track the active cursors. This allows us to treat the AIL push cursor as a generic cursor rather than as a special case, further simplifying the code. Further, fix the duplicate push cursor initialisation that the special case handling was hiding, and clean up all the comments around the active cursor list handling. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-20xfs: remove confusing ail cursor wrapperDave Chinner
xfs_trans_ail_cursor_set() doesn't set the cursor to the current log item, it sets it to the next item. There is already a function for doing this - xfs_trans_ail_cursor_next() - and the _set function is simply a two line wrapper. Remove it and open code the setting of the cursor in the two locations that call it to remove the confusion. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
