Change-Id: I39a97308050fd36bbcf4e9b909e3087172438f8b
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/108071
Reviewed-by: Ryan Wong <ryanw@nvidia.com>
Tested-by: Ryan Wong <ryanw@nvidia.com>
Remove FAT Directory Bread message which is
causing timing issues.
Bug 992496
Change-Id: Ieb58e38bf8ac81f6c0558361f9f296a8e9071b33
Signed-off-by: venkata jagadish <vjagadish@nvidia.com>
Reviewed-on: http://git-master/r/107576
Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
Reviewed-by: Manish Tuteja <mtuteja@nvidia.com>
commit b1c770c273a4787069306fc82aab245e9ac72e9d upstream
When finding the longest extent in an AG, we read the value directly
out of the AGF buffer without endian conversion. This will give an
incorrect length, resulting in FITRIM operations potentially not
trimming everything that it should.
Note, for 3.0-stable this has been modified to apply to
fs/xfs/linux-2.6/xfs_discard.c instead of fs/xfs/xfs_discard.c. -bpm
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
Change-Id: Iad84b2bb82ee0d410cdb64eeea3a8431c5a0a7ad
Reviewed-on: http://git-master/r/79660
commit 9b025eb3a89e041bab6698e3858706be2385d692 upstream.
Commit b52a360b forgot to call xfs_iunlock() when it detected corrupted
symplink and bailed out. Fix it by jumping to 'out' instead of doing return.
CC: Carlos Maiolino <cmaiolino@redhat.com>
Reviewed-by: Alex Elder <elder@kernel.org>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Change-Id: Ie83d93a6bbe0997f8a41afa9e3bf6f12cee476c6
Reviewed-on: http://git-master/r/79655
commit 58ded24f0fcb85bddb665baba75892f6ad0f4b8a upstream.
If pages passed to the eCryptfs extent-based crypto functions are not
mapped and the module parameter ecryptfs_verbosity=1 was specified at
loading time, a NULL pointer dereference will occur.
Note that this wouldn't happen on a production system, as you wouldn't
pass ecryptfs_verbosity=1 on a production system. It leaks private
information to the system logs and is for debugging only.
The debugging info printed in these messages is no longer very useful
and rather than doing a kmap() in these debugging paths, it will be
better to simply remove the debugging paths completely.
https://launchpad.net/bugs/913651
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Change-Id: Icbb95db933d5fa76938982fcf69cacea85ecbecc
Reviewed-on: http://git-master/r/79652
commit a261a03904849c3df50bd0300efb7fb3f865137d upstream.
Most filesystems call inode_change_ok() very early in ->setattr(), but
eCryptfs didn't call it at all. It allowed the lower filesystem to make
the call in its ->setattr() function. Then, eCryptfs would copy the
appropriate inode attributes from the lower inode to the eCryptfs inode.
This patch changes that and actually calls inode_change_ok() on the
eCryptfs inode, fairly early in ecryptfs_setattr(). Ideally, the call
would happen earlier in ecryptfs_setattr(), but there are some possible
inode initialization steps that must happen first.
Since the call was already being made on the lower inode, the change in
functionality should be minimal, except for the case of a file extending
truncate call. In that case, inode_newsize_ok() was never being
called on the eCryptfs inode. Rather than inode_newsize_ok() catching
maximum file size errors early on, eCryptfs would encrypt zeroed pages
and write them to the lower filesystem until the lower filesystem's
write path caught the error in generic_write_checks(). This patch
introduces a new function, called ecryptfs_inode_newsize_ok(), which
checks if the new lower file size is within the appropriate limits when
the truncate operation will be growing the lower file.
In summary this change prevents eCryptfs truncate operations (and the
resulting page encryptions), which would exceed the lower filesystem
limits or FSIZE rlimits, from ever starting.
Reviewed-by: Li Wang <liwang@nudt.edu.cn>
Change-Id: Idbfa207399bf0f50ce92b4d6fb8ef43896c771d5
Reviewed-on: http://git-master/r/79651
commit 5e6f0d769017cc49207ef56996e42363ec26c1f0 upstream.
ecryptfs_write() handles the truncation of eCryptfs inodes. It grabs a
page, zeroes out the appropriate portions, and then encrypts the page
before writing it to the lower filesystem. It was unkillable and due to
the lack of sparse file support could result in tying up a large portion
of system resources, while encrypting pages of zeros, with no way for
the truncate operation to be stopped from userspace.
This patch adds the ability for ecryptfs_write() to detect a pending
fatal signal and return as gracefully as possible. The intent is to
leave the lower file in a useable state, while still allowing a user to
break out of the encryption loop. If a pending fatal signal is detected,
the eCryptfs inode size is updated to reflect the modified inode size
and then -EINTR is returned.
Change-Id: I80e83c16c58586c700df081500b6c3e2a4a06270
Reviewed-on: http://git-master/r/79650
commit 30373dc0c87ffef68d5628e77d56ffb1fa22e1ee upstream.
Print inode on metadata read failure. The only real
way of dealing with metadata read failures is to delete
the underlying file system file. Having the inode
allows one to 'find . -inum INODE`.
[tyhicks@canonical.com: Removed some minor not-for-stable parts]
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Change-Id: I0460c59fe4a6490683b1cf6f993945b3f05e8aca
Reviewed-on: http://git-master/r/79649
commit db10e556518eb9d21ee92ff944530d84349684f4 upstream.
A malicious count value specified when writing to /dev/ecryptfs may
result in a a very large kernel memory allocation.
This patch peeks at the specified packet payload size, adds that to the
size of the packet headers and compares the result with the write count
value. The resulting maximum memory allocation size is approximately 532
bytes.
Change-Id: I4fe5831fb58f9de76c81aa4b60efa93cb100dab8
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Reviewed-on: http://git-master/r/79648
This reverts commit 198214a7ee50375fa71a65e518341980cfd4b2f0.
(cherry picked from commit dac306d896642f3dfcd878ab6a0a5b8c123722f3 from
android.googlesource.com/common.git)
Change-Id: Ia8947a59125e9318f1c51cb63ceb15a6e136aad9
Reviewed-on: http://git-master/r/78884
Linux 3.1.10
Change-Id: I465d184c492e8041dd0cd90f2cb70fde17ba7118
commit 8a0d551a59ac92d8ff048d6cb29d3a02073e81e8 upstream.
Setting the security context of a NFSv4 mount via the context= mount
option is currently broken. The NFSv4 codepath allocates a parsed
options struct, and then parses the mount options to fill it. It
eventually calls nfs4_remote_mount which calls security_init_mnt_opts.
That clobbers the lsm_opts struct that was populated earlier. This bug
also looks like it causes a small memory leak on each v4 mount where
context= is used.
Fix this by moving the initialization of the lsm_opts into
nfs_alloc_parsed_mount_data. Also, add a destructor for
nfs_parsed_mount_data to make it easier to free all of the allocations
hanging off of it, and to ensure that the security_free_mnt_opts is
called whenever security_init_mnt_opts is.
I believe this regression was introduced quite some time ago, probably
by commit c02d7adf.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit bf118a342f10dafe44b14451a1392c3254629a1f upstream.
The NFSv4 bitmap size is unbounded: a server can return an arbitrary
sized bitmap in an FATTR4_WORD0_ACL request. Replace using the
nfs4_fattr_bitmap_maxsz as a guess to the maximum bitmask returned by a server
with the inclusion of the bitmap (xdr length plus bitmasks) and the acl data
xdr length to the (cached) acl page data.
This is a general solution to commit e5012d1f "NFSv4.1: update
nfs4_fattr_bitmap_maxsz" and fixes hitting a BUG_ON in xdr_shrink_bufhead
when getting ACLs.
Fix a bug in decode_getacl that returned -EINVAL on ACLs > page when getxattr
was called with a NULL buffer, preventing ACL > PAGE_SIZE from being retrieved.
Signed-off-by: Andy Adamson <andros@netapp.com>
commit 2edb6bc3852c681c0d948245bd55108dc6407604 upstream.
From c6d615d2b97fe305cbf123a8751ced859dca1d5e Mon Sep 17 00:00:00 2001
Date: Wed, 16 Nov 2011 09:39:05 +1100
Subject: NFS - fix recent breakage to NFS error handling.
commit 02c24a82187d5a628c68edfe71ae60dc135cd178 made a small and
presumably unintended change to write error handling in NFS.
Previously an error from filemap_write_and_wait_range would only be of
interest if nfs_file_fsync did not return an error. After this commit,
an error from filemap_write_and_wait_range would mean that (the rest of)
nfs_file_fsync would not even be called.
This means that:
1/ you are more likely to see EIO than e.g. EDQUOT or ENOSPC.
2/ NFS_CONTEXT_ERROR_WRITE remains set for longer so more writes are
synchronous.
This patch restores previous behaviour.
Cc: Josef Bacik <josef@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 61f2e5106582d02f30b6807e3f9c07463c572ccb upstream.
commit d50f2ab6f050311dbf7b8f5501b25f0bf64a439b upstream.
Commit 503358ae01b70ce6909d19dd01287093f6b6271c ("ext4: avoid divide by
zero when trying to mount a corrupted file system") fixes CVE-2009-4307
by performing a sanity check on s_log_groups_per_flex, since it can be
set to a bogus value by an attacker.
sbi->s_log_groups_per_flex = sbi->s_es->s_log_groups_per_flex;
groups_per_flex = 1 << sbi->s_log_groups_per_flex;
if (groups_per_flex < 2) { ... }
This patch fixes two potential issues in the previous commit.
1) The sanity check might only work on architectures like PowerPC.
On x86, 5 bits are used for the shifting amount. That means, given a
large s_log_groups_per_flex value like 36, groups_per_flex = 1 << 36
is essentially 1 << 4 = 16, rather than 0. This will bypass the check,
leaving s_log_groups_per_flex and groups_per_flex inconsistent.
2) The sanity check relies on undefined behavior, i.e., oversized shift.
A standard-confirming C compiler could rewrite the check in unexpected
ways. Consider the following equivalent form, assuming groups_per_flex
is unsigned for simplicity.
if (groups_per_flex == 0 || groups_per_flex == 1) {
We compile the code snippet using Clang 3.0 and GCC 4.6. Clang will
completely optimize away the check groups_per_flex == 0, leaving the
patched code as vulnerable as the original. GCC keeps the check, but
there is no guarantee that future versions will do the same.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Linux 3.1.9
Makefile
Change-Id: I22227ab33ba7ddaba8e6fe049393c58a83d73648
commit 093019cf1b18dd31b2c3b77acce4e000e2cbc9ce upstream.
Commit fa8b18ed didn't prevent the integer overflow and possible
memory corruption. "count" can go negative and bypass the check.
commit fa8b18edd752a8b4e9d1ee2cd615b82c93cf8bba upstream.
This prevents in-memory corruption and possible panics if the on-disk
ACL is badly corrupted.
commit d2eb8c359309ec45d6bf5b147303ab8e13be86ea upstream.
During BKL removal in 2.6.38, conversion of files from in-ICB format to normal
format got broken. We call ->writepage with i_data_sem held but udf_get_block()
also acquires i_data_sem thus creating A-A deadlock.
We fix the problem by dropping i_data_sem before calling ->writepage() which is
safe since i_mutex still protects us against any changes in the file. Also fix
pagelock - i_data_sem lock inversion in udf_expand_file_adinicb() by dropping
i_data_sem before calling find_or_create_page().
Reported-by: Matthias Matiak <netzpython@mail-on.us>
Tested-by: Matthias Matiak <netzpython@mail-on.us>
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
commit 33c104d415e92a51aaf638dc3d93920cfa601e5c upstream.
WARN_ON_ONCE(IS_RDONLY(inode)) tends to trip when filesystem hits error and is
remounted read-only. This unnecessarily scares users (well, they should be
scared because of filesystem error, but the stack trace distracts them from the
right source of their fear ;-). We could as well just remove the WARN_ON but
it's not hard to fix it to not trip on filesystem with errors and not use more
cycles in the common case so that's what we do.
commit a9e36da655e54545c3289b2a0700b5c443de0edd upstream.
This patch fixes a crash in reiserfs_delete_xattrs during umount.
When shrink_dcache_for_umount clears the dcache from
generic_shutdown_super, delayed evictions are forced to disk. If an
evicted inode has extended attributes associated with it, it will
need to walk the xattr tree to locate and remove them.
But since shrink_dcache_for_umount will BUG if it encounters active
dentries, the xattr tree must be released before it's called or it will
crash during every umount.
This patch forces the evictions to occur before generic_shutdown_super
by calling shrink_dcache_sb first. The additional evictions caused
by the removal of each associated xattr file and dir will be automatically
handled as they're added to the LRU list.
CC: reiserfs-devel@vger.kernel.org
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit a06d789b424190e9f59da391681f908486db2554 upstream.
When jqfmt mount option is not specified on remount, we mistakenly clear
s_jquota_fmt value stored in superblock. Fix the problem.
commit 695c60f21c69e525a89279a5f35bae4ff237afbc upstream.
commit 828b1c50ae ("nilfs2: add compat ioctl") incidentally broke all
other NILFS compat ioctls. Make them work again.
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Change-Id: I125655948842b824d2c0c0032578e41071d952b6
Reviewed-on: http://git-master/r/74183
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
commit 111d489f0fb431f4ae85d96851fbf8d3248c09d8 upstream.
Currently, the code assumes that the SEQUENCE status bits are mutually
exclusive. They are not...
Change-Id: Idd21b5590495d004dd965433df6a089f46f682bd
Reviewed-on: http://git-master/r/74180
commit 6c52961743f38747401b47127b82159ab6d8a7a4 upstream.
After commit 06222e491e663dac939f04b125c9dc52126a75c4 (fs: handle
SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek)
the behaviour of llseek() was changed so that it always revalidates
the file size. The bug appears to be due to a logic error in the
afore-mentioned commit, which always evaluates to 'true'.
Reported-by: Roel Kluin <roel.kluin@gmail.com>
Change-Id: I4030564c1503d782139279e6741c819acbb0fb8f
Reviewed-on: http://git-master/r/74179
Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
commit b48c6af2086ab2ba8a9c9b6ce9ecb34592ce500c upstream.
The test in fuse_file_llseek() "not SEEK_CUR or not SEEK_SET" always evaluates
to true.
This was introduced in 3.1 by commit 06222e49 (fs: handle SEEK_HOLE/SEEK_DATA
properly in all fs's that define their own llseek) and changed the behavior of
SEEK_CUR and SEEK_SET to always retrieve the file attributes. This is a
performance regression.
Fix the test so that it makes sense.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
CC: Josef Bacik <josef@redhat.com>
CC: Al Viro <viro@zeniv.linux.org.uk>
commit 48706d0a91583d08c56e7ef2a7602d99c8d4133f upstream.
Fix two bugs in fuse_retrieve():
- retrieving more than one page would yield repeated instances of the
first page
- if more than FUSE_MAX_PAGES_PER_REQ pages were requested than the
request page array would overflow
fuse_retrieve() was added in 2.6.36 and these bugs had been there since the
beginning.
commit 5a0dc7365c240795bf190766eba7a27600be3b3e upstream.
We need to zero out part of a page which beyond EOF before setting uptodate,
otherwise, mapread or write will see non-zero data beyond EOF.
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
commit 13a79a4741d37fda2fbafb953f0f301dc007928f upstream.
If there is an unwritten but clean buffer in a page and there is a
dirty buffer after the buffer, then mpage_submit_io does not write the
dirty buffer out. As a result, da_writepages loops forever.
This patch fixes the problem by checking dirty flag.
commit ea51d132dbf9b00063169c1159bee253d9649224 upstream.
If the pte mapping in generic_perform_write() is unmapped between
iov_iter_fault_in_readable() and iov_iter_copy_from_user_atomic(), the
"copied" parameter to ->end_write can be zero. ext4 couldn't cope with
it with delayed allocations enabled. This skips the i_disksize
enlargement logic if copied is zero and no new data was appeneded to
the inode.
gdb> bt
#0 0xffffffff811afe80 in ext4_da_should_update_i_disksize (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x1\
08000, len=0x1000, copied=0x0, page=0xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2467
#1 ext4_da_write_end (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x108000, len=0x1000, copied=0x0, page=0\
xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2512
#2 0xffffffff810d97f1 in generic_perform_write (iocb=<value optimized out>, iov=<value optimized out>, nr_segs=<value o\
ptimized out>, pos=0x108000, ppos=0xffff88001e26be40, count=<value optimized out>, written=0x0) at mm/filemap.c:2440
#3 generic_file_buffered_write (iocb=<value optimized out>, iov=<value optimized out>, nr_segs=<value optimized out>, p\
os=0x108000, ppos=0xffff88001e26be40, count=<value optimized out>, written=0x0) at mm/filemap.c:2482
#4 0xffffffff810db5d1 in __generic_file_aio_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=0x1, ppos=0\
xffff88001e26be40) at mm/filemap.c:2600
#5 0xffffffff810db853 in generic_file_aio_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=<value optimi\
zed out>, pos=<value optimized out>) at mm/filemap.c:2632
#6 0xffffffff811a71aa in ext4_file_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=0x1, pos=0x108000) a\
t fs/ext4/file.c:136
#7 0xffffffff811375aa in do_sync_write (filp=0xffff88003f606a80, buf=<value optimized out>, len=<value optimized out>, \
ppos=0xffff88001e26bf48) at fs/read_write.c:406
#8 0xffffffff81137e56 in vfs_write (file=0xffff88003f606a80, buf=0x1ec2960 <Address 0x1ec2960 out of bounds>, count=0x4\
000, pos=0xffff88001e26bf48) at fs/read_write.c:435
#9 0xffffffff8113816c in sys_write (fd=<value optimized out>, buf=0x1ec2960 <Address 0x1ec2960 out of bounds>, count=0x\
4000) at fs/read_write.c:487
#10 <signal handler called>
#11 0x00007f120077a390 in __brk_reservation_fn_dmi_alloc__ ()
#12 0x0000000000000000 in ?? ()
gdb> print offset
$22 = 0xffffffffffffffff
gdb> print idx
$23 = 0xffffffff
gdb> print inode->i_blkbits
$24 = 0xc
gdb> up
2512 if (ext4_da_should_update_i_disksize(page, end)) {
gdb> print start
$25 = 0x0
gdb> print end
$26 = 0xffffffffffffffff
gdb> print pos
$27 = 0x108000
gdb> print new_i_size
$28 = 0x108000
gdb> print ((struct ext4_inode_info *)((char *)inode-((int)(&((struct ext4_inode_info *)0)->vfs_inode))))->i_disksize
$29 = 0xd9000
gdb> down
2467 for (i = 0; i < idx; i++)
gdb> print i
$30 = 0xd44acbee
This is 100% reproducible with some autonuma development code tuned in
a very aggressive manner (not normal way even for knumad) which does
"exotic" changes to the ptes. It wouldn't normally trigger but I don't
see why it can't happen normally if the page is added to swap cache in
between the two faults leading to "copied" being zero (which then
hangs in ext4). So it should be fixed. Especially possible with lumpy
reclaim (albeit disabled if compaction is enabled) as that would
ignore the young bits in the ptes.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
commit fc6cb1cda5db7b2d24bf32890826214b857c728e upstream.
/proc/mounts was showing the mount option [no]init_inode_table when
the correct mount option that will be accepted by parse_options() is
[no]init_itable.
commit b5a7e97039a80fae673ccc115ce595d5b88fb4ee upstream.
We need to make sure iocb->private is cleared *before* we put the
io_end structure on i_completed_io_list. Otherwise fsync() could
potentially run on another CPU and free the iocb structure out from
under us.
Reported-by: Kent Overstreet <koverstreet@google.com>
commit 434a964daa14b9db083ce20404a4a2add54d037a upstream.
Clement Lecigne reports a filesystem which causes a kernel oops in
hfs_find_init() trying to dereference sb->ext_tree which is NULL.
This proves to be because the filesystem has a corrupted MDB extent
record, where the extents file does not fit into the first three extents
in the file record (the first blocks).
In hfs_get_block() when looking up the blocks for the extent file
(HFS_EXT_CNID), it fails the first blocks special case, and falls
through to the extent code (which ultimately calls hfs_find_init())
which is in the process of being initialised.
Hfs avoids this scenario by always having the extents b-tree fitting
into the first blocks (the extents B-tree can't have overflow extents).
The fix is to check at mount time that the B-tree fits into first
blocks, i.e. fail if HFS_I(inode)->alloc_blocks >=
HFS_I(inode)->first_blocks
Note, the existing commit 47f365eb57573 ("hfs: fix oops on mount with
corrupted btree extent records") becomes subsumed into this as a special
case, but only for the extents B-tree (HFS_EXT_CNID), it is perfectly
acceptable for the catalog B-Tree file to grow beyond three extents,
with the remaining extent descriptors in the extents overfow.
This fixes CVE-2011-2203
Reported-by: Clement LECIGNE <clement.lecigne@netasq.com>
Signed-off-by: Phillip Lougher <plougher@redhat.com>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Moritz Mühlenhoff <jmm@inutil.org>
commit 8762202dd0d6e46854f786bdb6fb3780a1625efe upstream.
I hit a J_ASSERT(blocknr != 0) failure in cleanup_journal_tail() when
mounting a fsfuzzed ext3 image. It turns out that the corrupted ext3
image has s_first = 0 in journal superblock, and the 0 is passed to
journal->j_head in journal_reset(), then to blocknr in
cleanup_journal_tail(), in the end the J_ASSERT failed.
So validate s_first after reading journal superblock from disk in
journal_get_superblock() to ensure s_first is valid.
The following script could reproduce it:
fstype=ext3
blocksize=1024
img=$fstype.img
offset=0
found=0
magic="c0 3b 39 98"
dd if=/dev/zero of=$img bs=1M count=8
mkfs -t $fstype -b $blocksize -F $img
filesize=`stat -c %s $img`
while [ $offset -lt $filesize ]
do
if od -j $offset -N 4 -t x1 $img | grep -i "$magic";then
echo "Found journal: $offset"
found=1
break
fi
offset=`echo "$offset+$blocksize" | bc`
done
if [ $found -ne 1 ];then
echo "Magic \"$magic\" not found"
exit 1
fi
dd if=/dev/zero of=$img seek=$(($offset+23)) conv=notrunc bs=1 count=1
mkdir -p ./mnt
mount -o loop $img ./mnt
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit 7023676f9ee851d94f0942e879243fc1f9081c47 upstream.
Prior to commit eaf35b1, cifs_save_resume_key had some NULL pointer
checks at the top. It turns out that at least one of those NULL
pointer checks is needed after all.
When the LastNameOffset in a FIND reply appears to be beyond the end of
the buffer, CIFSFindFirst and CIFSFindNext will set srch_inf.last_entry
to NULL. Since eaf35b1, the code will now oops in this situation.
Fix this by having the callers check for a NULL last entry pointer
before calling cifs_save_resume_key. No change is needed for the
call site in cifs_readdir as it's not reachable with a NULL
current_entry pointer.
This should fix:
https://bugzilla.redhat.com/show_bug.cgi?id=750247
Reported-by: Adam G. Metzler <adamgmetzler@gmail.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 02125a826459a6ad142f8d91c5b6357562f96615 upstream.
__d_path() API is asking for trouble and in case of apparmor d_namespace_path()
getting just that. The root cause is that when __d_path() misses the root
it had been told to look for, it stores the location of the most remote ancestor
in *root. Without grabbing references. Sure, at the moment of call it had
been pinned down by what we have in *path. And if we raced with umount -l, we
could have very well stopped at vfsmount/dentry that got freed as soon as
prepend_path() dropped vfsmount_lock.
It is safe to compare these pointers with pre-existing (and known to be still
alive) vfsmount and dentry, as long as all we are asking is "is it the same
address?". Dereferencing is not safe and apparmor ended up stepping into
that. d_namespace_path() really wants to examine the place where we stopped,
even if it's not connected to our namespace. As the result, it looked
at ->d_sb->s_magic of a dentry that might've been already freed by that point.
All other callers had been careful enough to avoid that, but it's really
a bad interface - it invites that kind of trouble.
The fix is fairly straightforward, even though it's bigger than I'd like:
* prepend_path() root argument becomes const.
* __d_path() is never called with NULL/NULL root. It was a kludge
to start with. Instead, we have an explicit function - d_absolute_root().
Same as __d_path(), except that it doesn't get root passed and stops where
it stops. apparmor and tomoyo are using it.
* __d_path() returns NULL on path outside of root. The main
caller is show_mountinfo() and that's precisely what we pass root for - to
skip those outside chroot jail. Those who don't want that can (and do)
use d_path().
* __d_path() root argument becomes const. Everyone agrees, I hope.
* apparmor does *NOT* try to use __d_path() or any of its variants
when it sees that path->mnt is an internal vfsmount. In that case it's
definitely not mounted anywhere and dentry_path() is exactly what we want
there. Handling of sysctl()-triggered weirdness is moved to that place.
* if apparmor is asked to do pathname relative to chroot jail
and __d_path() tells it we it's not in that jail, the sucker just calls
d_absolute_path() instead. That's the other remaining caller of __d_path(),
BTW.
* seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway -
the normal seq_file logics will take care of growing the buffer and redoing
the call of ->show() just fine). However, if it gets path not reachable
from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped
ignoring the return value as it used to do).
Reviewed-by: John Johansen <john.johansen@canonical.com>
ACKed-by: John Johansen <john.johansen@canonical.com>
commit b53fc7c2974a50913f49e1d800fe904a28c338e3 upstream.
Fix the error message "directives may not be used inside a macro argument"
which appears when the kernel is compiled for the cris architecture.
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
commit db3e74b582915d66e10b0c73a62763418f54c340 upstream.
The doalloc arg in xfs_qm_dqattach_one() is a flag that indicates
whether a new area to handle quota information will be allocated
if needed. Originally, it was passed to xfs_qm_dqget(), but has
been removed by the following commit (probably by mistake):
commit 8e9b6e7fa4544ea8a0e030c8987b918509c8ff47
Author: Christoph Hellwig <hch@lst.de>
Date: Sun Feb 8 21:51:42 2009 +0100
xfs: remove the unused XFS_QMOPT_DQLOCK flag
As the result, xfs_qm_dqget() called from xfs_qm_dqattach_one()
never allocates the new area even if it is needed.
This patch gives the doalloc arg to xfs_qm_dqget() in
xfs_qm_dqattach_one() to fix this problem.
Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Alex Elder <aelder@sgi.com>
commit b52a360b2aa1c59ba9970fb0f52bbb093fcc7a24 upstream.
Fixes a possible memory corruption when the link is larger than
MAXPATHLEN and XFS_DEBUG is not enabled. This also remove the
S_ISLNK assert, since the inode mode is checked previously in
xfs_readlink_by_handle() and via VFS.
Updated to address concerns raised by Ben Hutchings about the loose
attention paid to 32- vs 64-bit values, and the lack of handling a
potentially negative pathlen value:
- Changed type of "pathlen" to be xfs_fsize_t, to match that of
ip->i_d.di_size
- Added checking for a negative pathlen to the too-long pathlen
test, and generalized the message that gets reported in that case
to reflect the change
As a result, if a negative pathlen were encountered, this function
would return EFSCORRUPTED (and would fail an assertion for a debug
build)--just as would a too-long pathlen.
Signed-off-by: Alex Elder <aelder@sgi.com>
Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com>
Cc: Ben Myers <bpm@sgi.com>
commit 87c7bec7fc3377b3873eb3a0f4b603981ea16ebb upstream.
The code to flush buffers in the umount code is a bit iffy: we first
flush all delwri buffers out, but then might be able to queue up a
new one when logging the sb counts. On a normal shutdown that one
would get flushed out when doing the synchronous superblock write in
xfs_unmountfs_writesb, but we skip that one if the filesystem has
been shut down.
Fix this by moving the delwri list flushing until just before unmounting
the log, and while we're at it also remove the superflous delwri list
and buffer lru flusing for the rt and log device that can never have
cached or delwri buffers.
Reported-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
Tested-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
commit ed32201e65e15f3e6955cb84cbb544b08f81e5a5 upstream.
An attribute of inode can be fetched via xfs_vn_getattr() in XFS.
Currently it returns EIO, not negative value, when it failed. As a
result, the system call returns not negative value even though an
error occured. The stat(2), ls and mv commands cannot handle this
error and do not work correctly.
This patch fixes this bug, and returns -EIO, not EIO when an error
is detected in xfs_vn_getattr().
commit c58cb165bd44de8aaee9755a144136ae743be116 upstream.
Currently a buffered reader or writer can add pages to the pagecache
while we are waiting for the iolock in xfs_file_dio_aio_write. Prevent
this by re-checking mapping->nrpages after we got the iolock, and if
nessecary upgrade the lock to exclusive mode. To simplify this a bit
only take the ilock inside of xfs_file_aio_write_checks.
commit 0c38a2512df272b14ef4238b476a2e4f70da1479 upstream.
There is no need to grab the i_mutex of the IO lock in exclusive
mode if we don't need to invalidate the page cache. Taking these
locks on every direct IO effective serialises them as taking the IO
lock in exclusive mode has to wait for all shared holders to drop
the lock. That only happens when IO is complete, so effective it
prevents dispatch of concurrent direct IO reads to the same inode.
Fix this by taking the IO lock shared to check the page cache state,
and only then drop it and take the IO lock exclusively if there is
work to be done. Hence for the normal direct IO case, no exclusive
locking will occur.
Tested-by: Joern Engel <joern@logfs.org>
commit 4c81f045c0bd2cbb78cc6446a4cd98038fe11a2e upstream.
ext4_end_io_dio() queues io_end->work and then clears iocb->private;
however, io_end->work calls aio_complete() which frees the iocb
object. If that slab object gets reallocated, then ext4_end_io_dio()
can end up clearing someone else's iocb->private, this use-after-free
can cause a leak of a struct ext4_io_end_t structure.
Detected and tested with slab poisoning.
[ Note: Can also reproduce using 12 fio's against 12 file systems with the
following configuration file:
[global]
direct=1
ioengine=libaio
iodepth=1
bs=4k
ba=4k
size=128m
[create]
filename=${TESTDIR}
rw=write
-- tytso ]
Google-Bug-Id: 5354697
Tested-by: Kent Overstreet <koverstreet@google.com>
