Local variable `i' is a byte-counter. Don't use it as an index into an array
of le32's.
Reported-by: "young dave" <hidave.darkstar@gmail.com>
Cc: "Christoph Lameter" <clameter@sgi.com>
Acked-by: Anton Altaparmakov <aia21@cantab.net>
Cc: <stable@kernel.org>
Cc: Adrian Bunk <bunk@stusta.de>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
The wrong lookup flag was tested in ->create() causing havoc (error or
Oops) when a regular file was created with mknod() in a fuse
filesystem.
Thanks to J. Cameijo Cerdeira for the report.
Kernels 2.6.18 onward are affected. Please apply to -stable as well.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
It's possible for a journal I/O request to be added to the log_redrive
queue and the jfsIO thread to be awakened after the thread releases
log_redrive_lock but before it sets its state to TASK_INTERRUPTIBLE.
The jfsIO thread should set the state before giving up the spinlock, so
the waking thread will really wake it.
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
The listxattr() and getxattr() operations are only protected by a read
lock. As a result, if either of these operations run in parallel, a race
condition exists where the xattr_root will end up being cached twice, which
results in the leaking of a reference and a BUG() on umount.
This patch refactors get_xa_root(), __get_xa_root(), and create_xa_root(),
into one get_xa_root() function that takes the appropriate locking around
the entire critical section.
Reported, diagnosed and tested by Andrea Righi <a.righi@cineca.it>
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Cc: Andrea Righi <a.righi@cineca.it>
Cc: "Vladimir V. Saveliev" <vs@namesys.com>
Cc: Edward Shishkin <edward@namesys.com>
Cc: Alex Zarochentsev <zam@namesys.com>
NFS: Fix an Oops in nfs_setattr()
It looks like nfs_setattr() and nfs_rename() also need to test whether the
target is a regular file before calling nfs_wb_all()...
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
exec.c: fix coredump to pipe problem and obscure "security hole"
The patch checks for "|" in the pattern not the output and doesn't nail a
pid on to a piped name (as it is a program name not a file)
Also fixes a very very obscure security corner case. If you happen to have
decided on a core pattern that starts with the program name then the user
can run a program called "|myevilhack" as it stands. I doubt anyone does
this.
Signed-off-by: Alan Cox <alan@redhat.com>
Confirmed-by: Christopher S. Aker <caker@theshore.net>
When the dump cannot occur most likely because of a full file system and
the page to be written is the zero page, the call to page_cache_release()
is missed.
Signed-off-by: Brian Pomerantz <bapper@mvista.com>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Revert b46be05004abb419e303e66e143eed9f8a6e9f3f. Same reasoning as for ext3.
Cc: Kirill Korotaev <dev@openvz.org>
Cc: Ken Chen <kenneth.w.chen@intel.com>
Cc: Andrey Savochkin <saw@sw.ru>
Cc: <linux-ext4@vger.kernel.org>
Cc: Dmitriy Monakhov <dmonakhov@openvz.org>
Revert e92a4d595b464c4aae64be39ca61a9ffe9c8b278.
Dmitry points out
"When we block_prepare_write() failed while ext3_prepare_write() we jump to
"failure" label and call ext3_prepare_failure() witch search last mapped bh
and invoke commit_write untill it. This is wrong!! because some bh from
begining to the last mapped bh may be not uptodate. As a result we commit to
disk not uptodate page content witch contains garbage from previous usage."
and
"Unexpected file size increasing."
Call trace the same as it was in first issue but result is different.
For example we have file with i_size is zero. we want write two blocks ,
but fs has only one free block.
->ext3_prepare_write(...from == 0, to == 2048)
retry:
->block_prepare_write() == -ENOSPC# we failed but allocated one block here.
->ext3_prepare_failure()
->commit_write( from == 0, to == 1024) # after this i_size becomes 1024 :)
if (ret == -ENOSPC && ext3_should_retry_alloc(inode->i_sb, &retries))
goto retry;
Finally when all retries will be spended ext3_prepare_failure return
-ENOSPC, but i_size was increased and later block trimm procedures can't
help here.
We don't appear to have the horsepower to fix these issues, so let's put
things back the way they were for now.
From Neil Brown <neilb@suse.de>
[PATCH] knfsd: allow nfsd READDIR to return 64bit cookies
->readdir passes lofft_t offsets (used as nfs cookies) to
nfs3svc_encode_entry{,_plus}, but when they pass it on to encode_entry it
becomes an 'off_t', which isn't good.
So filesystems that returned 64bit offsets would lose.
Signed-off-by: Neil Brown <neilb@suse.de>
[CIFS] reset mode when client notices that ATTR_READONLY is no longer set
[<cebbert@redhat.com>: removed changelog part of patch]
Signed-off-by: Alan Tyso <atyson@hp.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
[CIFS] Allow reset of file to ATTR_NORMAL when archive bit not set
When a file had a dos attribute of 0x1 (readonly - but dos attribute
of archive was not set) - doing chmod 0777 or equivalent would
try to set a dos attribute of 0 (which some servers ignore)
rather than ATTR_NORMAL (0x20) which most servers accept.
Does not affect servers which support the CIFS Unix Extensions.
Acked-by: Prasad Potluri <pvp@us.ibm.com>
Acked-by: Shirish Pargaonkar <shirishp@us.ibm.com>
Looks like we need a check in nfs_getattr() for a regular file. It makes
no sense to call nfs_sync_mapping_range() on anything else. I think that
should fix your problem: it will stop the NFS client from interfering
with dirty pages on that inode's mapping.
Acked-by: Olof Johansson <olof@lixom.net>
Fix a locking mistake in the quota code, we do a mutex_lock instead of a
mutex_unlock.
Signed-off-by: Josef Whiter <jwhiter@redhat.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
unlock_buffer(), like unlock_page(), must not clear the lock without
ensuring that the critical section is closed.
Mingming later sent the same patch, saying:
We are running SDET benchmark and saw double free issue for ext3 extended
attributes block, which complains the same xattr block already being freed (in
ext3_xattr_release_block()). The problem could also been triggered by
multiple threads loop untar/rm a kernel tree.
The race is caused by missing a memory barrier at unlock_buffer() before the
lock bit being cleared, resulting in possible concurrent h_refcounter update.
That causes a reference counter leak, then later leads to the double free that
we have seen.
Inside unlock_buffer(), there is a memory barrier is placed *after* the lock
bit is being cleared, however, there is no memory barrier *before* the bit is
cleared. On some arch the h_refcount update instruction and the clear bit
instruction could be reordered, thus leave the critical section re-entered.
The race is like this: For example, if the h_refcount is initialized as 1,
cpu 0: cpu1
__unmap_hugepage_range() is buggy that it does not preserve dirty state of
huge_pte when unmapping hugepage range. It causes data corruption in the
event of dop_caches being used by sys admin. For example, an application
creates a hugetlb file, modify pages, then unmap it. While leaving the
hugetlb file alive, comes along sys admin doing a "echo 3 >
/proc/sys/vm/drop_caches".
drop_pagecache_sb() will happily free all pages that aren't marked dirty if
there are no active mapping. Later when application remaps the hugetlb
file back and all data are gone, triggering catastrophic flip over on
application.
Not only that, the internal resv_huge_pages count will also get all messed
up. Fix it up by marking page dirty appropriately.
Signed-off-by: Ken Chen <kenchen@google.com>
Cc: "Nish Aravamudan" <nish.aravamudan@gmail.com>
Cc: Adam Litke <agl@us.ibm.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
Acked-by: William Irwin <bill.irwin@oracle.com>
Fix a double free of "dfid" introduced by commit
da977b2c7eb4d6312f063a7b486f2aad99809710 and spotted by the Coverity
checker.
Cc: Eric Van Hensbergen <ericvh@gmail.com>
This is a fix of regression, which triggered by ~2.6.16.
Patch with name ufs-directory-and-page-cache-from-blocks-to-pages.patch: in
additional to conversation from block to page cache mechanism added new
checks of directory integrity, one of them that directory entry do not
across directory chunks.
But some kinds of UFS: OpenStep UFS and Apple UFS (looks like these are the
same filesystems) have different directory chunk size, then common
UFSes(BSD and Solaris UFS).
So this patch adds ability to works with variable size of directory chunks,
and set it for ufstype=openstep to right size.
Tested on darwin ufs.
Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru>
rpc_call_async() will always call rpc_release_calldata(), so it is an
error for __nlm_async_call() to do so as well.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=7923
Cc: Jan "Yenya" Kasprzak <kas@fi.muni.cz>
Cc: Neil Brown <neilb@suse.de>
Fix insecure default behaviour reported by Tigran Aivazian: if an ext2
or ext3 or ext4 filesystem is tuned to mount with "acl", but mounted by
a kernel built without ACL support, then umask was ignored when creating
inodes - though root or user has umask 022, touch creates files as 0666,
and mkdir creates directories as 0777.
This appears to have worked right until 2.6.11, when a fix to the default
mode on symlinks (always 0777) assumed VFS applies umask: which it does,
unless the mount is marked for ACLs; but ext[234] set MS_POSIXACL in
s_flags according to s_mount_opt set according to def_mount_opts.
We could revert to the 2.6.10 ext[234]_init_acl (adding an S_ISLNK test);
but other filesystems only set MS_POSIXACL when ACLs are configured. We
could fix this at another level; but it seems most robust to avoid setting
the s_mount_opt flag in the first place (at the expense of more ifdefs).
Likewise don't set the XATTR_USER flag when built without XATTR support.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Acked-by: Andreas Gruenbacher <agruen@suse.de>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
x86: Don't require the vDSO for handling a.out signals
and in other strange binfmts. vDSO is not necessarily mapped there.
This fixes signals in a.out programs
Signed-off-by: Andi Kleen <ak@suse.de>
Commit 592282cf2eaa33409c6511ddd3f3ecaa57daeaaa fixed some missing directory
c/mtime updates in part by introducing a dinode update in ocfs2_add_entry().
Unfortunately, ocfs2_link() (which didn't update the directory inode before)
is now missing a single journal credit. Fix this by doubling the number of
inode updates expected during hard link creation.
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
Due to type confusion, when an nfsacl verison 2 'ACCESS' request
finishes and tries to clean up, it calls fh_put on entiredly the
wrong thing and this can cause an oops.
Andrew Vasquez is reporting as-iosched oopses and a 65% throughput
slowdown due to the recent special-casing of direct-io against
blockdevs. We don't know why either of these things are occurring.
The patch minimally reverts us back to the 2.6.19 code for a 2.6.20
release.
Cc: Andrew Vasquez <andrew.vasquez@qlogic.com>
Cc: Ken Chen <kenchen@google.com>
An AIO bug was reported that sleeping function is being called in softirq
context:
BUG: warning at kernel/mutex.c:132/__mutex_lock_common()
Call Trace:
[<a000000100577b00>] __mutex_lock_slowpath+0x640/0x6c0
[<a000000100577ba0>] mutex_lock+0x20/0x40
[<a0000001000a25b0>] flush_workqueue+0xb0/0x1a0
[<a00000010018c0c0>] __put_ioctx+0xc0/0x240
[<a00000010018d470>] aio_complete+0x2f0/0x420
[<a00000010019cc80>] finished_one_bio+0x200/0x2a0
[<a00000010019d1c0>] dio_bio_complete+0x1c0/0x200
[<a00000010019d260>] dio_bio_end_aio+0x60/0x80
[<a00000010014acd0>] bio_endio+0x110/0x1c0
[<a0000001002770e0>] __end_that_request_first+0x180/0xba0
[<a000000100277b90>] end_that_request_chunk+0x30/0x60
[<a0000002073c0c70>] scsi_end_request+0x50/0x300 [scsi_mod]
[<a0000002073c1240>] scsi_io_completion+0x200/0x8a0 [scsi_mod]
[<a0000002074729b0>] sd_rw_intr+0x330/0x860 [sd_mod]
[<a0000002073b3ac0>] scsi_finish_command+0x100/0x1c0 [scsi_mod]
[<a0000002073c2910>] scsi_softirq_done+0x230/0x300 [scsi_mod]
[<a000000100277d20>] blk_done_softirq+0x160/0x1c0
[<a000000100083e00>] __do_softirq+0x200/0x240
[<a000000100083eb0>] do_softirq+0x70/0xc0
See report: http://marc.theaimsgroup.com/?l=linux-kernel&m=116599593200888&w=2
flush_workqueue() is not allowed to be called in the softirq context.
However, aio_complete() called from I/O interrupt can potentially call
put_ioctx with last ref count on ioctx and triggers bug. It is simply
incorrect to perform ioctx freeing from aio_complete.
The bug is trigger-able from a race between io_destroy() and aio_complete().
A possible scenario:
cpu0 cpu1
io_destroy aio_complete
wait_for_all_aios { __aio_put_req
... ctx->reqs_active--;
if (!ctx->reqs_active)
return;
put_ioctx(ioctx)
put_ioctx(ctx);
__put_ioctx
bam! Bug trigger!
The real problem is that the condition check of ctx->reqs_active in
wait_for_all_aios() is incorrect that access to reqs_active is not
being properly protected by spin lock.
This patch adds that protective spin lock, and at the same time removes
all duplicate ref counting for each kiocb as reqs_active is already used
as a ref count for each active ioctx. This also ensures that buggy call
to flush_workqueue() in softirq context is eliminated.
Signed-off-by: "Ken Chen" <kenchen@google.com>
Cc: Zach Brown <zach.brown@oracle.com>
Cc: Suparna Bhattacharya <suparna@in.ibm.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Listing /proc/PID/task were PID is not a TGID should not result in
duplicated entries.
[g ~]$ pidof thunderbird-bin
2751
[g ~]$ ls /proc/2751/task
2751 2770 2771 2824 2826 2834 2835 2851 2853
[g ~]$ ls /proc/2770/task
[g ~]$
Signed-off-by: Guillaume Chazarain <guichaz@yahoo.fr>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
The KM_BIO_SRC_IRQ kmap slot requires local irq protection.
But keep it as a dprintk
The message can be generated in a quite normal situation:
If a 'lock' request is interrupted, then the lock client needs to
record that the server has the lock, incase it does.
When we come the unlock, the server might say it doesn't, even
though we think it does (or might) and this generates the message.
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
In blocks reallocation function sometimes does not update some of
buffer_head::b_blocknr, which may and cause data damage.
During ufs_trunc_direct which is subroutine of ufs::truncate, we try the first
of all free parts of block and then whole blocks. But we calculate size of
block's part to free in the wrong way.
This may cause bad update of used blocks and fragments statistic, and you can
got report that you have free 32T on 1Gb partition.
These series of patches result of UFS1 write support stress testing, like
running fsx-linux, untar and build linux kernel etc
We pass from ufs::get_block_t to levels below: pointer to the current page, to
make possible things like reallocation of blocks on the fly, and we also uses
this pointer for indication, what actually we allocate data block or meta data
block, but currently we make decision about what we allocate on the wrong
level, this may and cause oops if we allocate blocks in some special order.
The BUG in fuse_ctl_add_dentry() could be triggered if the control
filesystem was unmounted and mounted again while one or more fuse
filesystems were present.
The fix is to reset the dentry counter in fuse_ctl_kill_sb().
Bug reported by Florent Mertens.
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
events
Also remove {NFSD,RPC}_PARANOIA as having the defines doesn't really add
anything.
The printks covered by RPC_PARANOIA were triggered by badly formatted
packets and so should be ratelimited.
This patch adds missing newlines to dprintk's.
Fix UML hostfs mknod(): userspace has differernt dev_t size and encoding
than kernel, so extract major/minor and reencode using glibc makedev()
macro.
Signed-off-by: Johannes Stezenbach <js@linuxtv.org>
Acked-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Jeff Dike <jdike@addtoit.com>
Fix commit ecdfc9787fe527491baefc22dce8b2dbd5b2908d
Not to put too fine a point on it, but in a nutshell...
__set_page_dirty_buffers() | try_to_free_buffers()
| spin_lock(private_lock);
| drop_bufers()
| spin_unlock(private_lock);
spin_lock(private_lock) |
!page_has_buffers() |
spin_unlock(private_lock) |
SetPageDirty() |
| cancel_dirty_page()
oops!
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Andrew Morton <akpm@osdl.org>
Fix a bug which was introduced when I synced up ocfs2_fs.h with ocfs2-tools.
We can't do u64/u32 in kernel.
Proposed patch to fix #5 in
http://www.isec.pl/vulnerabilities/isec-0017-binfmt_elf.txt
aka
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2004-1073
To reproduce, do
* grab poc at the end of advisory.
* add line "eph.p_memsz = 4096;" after "eph.p_filesz = 4096;"
where first "4096" is something equal to or greater than 4096.
* ./poc /usr/bin/sudo && ls -l
Here I get with 2.6.20-rc5:
-rw------- 1 ad ad 102400 2007-01-15 19:17 core
---s--x--x 2 root root 101820 2007-01-15 19:15 /usr/bin/sudo
Check for MAY_READ like binfmt_misc.c does.
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
nfsd defines a type 'encode_dent_fn' which is much like 'filldir_t' except
that the first pointer is 'struct readdir_cd *' rather than 'void *'. It
then casts encode_dent_fn points to 'filldir_t' as needed. This hides any
other type mismatches between the two such as the fact that the 'ino' arg
recently changed from ino_t to u64.
So: get rid of 'encode_dent_fn', get rid of the cast of the function type,
change the first arg of various functions from 'struct readdir_cd *' to
'void *', and live with the fact that we have a little less type checking
on the calling of these functions now. Less internal (to nfsd) checking
offset by more external checking, which is more important.
Thanks to Gabriel Paubert <paubert@iram.es> for discovering this and
providing an initial patch.
Signed-off-by: Gabriel Paubert <paubert@iram.es>
We weren't properly NULL terminating protocol error strings for our debug
printk resulting in garbage being included in the output when debug was
enabled.
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
Running dbench multithreaded exposed a race condition where fid structures
were removed while in use. This patch adds semaphores to meta-data operations
to protect the fid structure. Some cleanup of error-case handling in the
inode operations is also included.
9p doesn't handle renames between directories -- however, we were returning
EPERM instead of EXDEV when we detected this case.
Signed-off-by: Eric Van Hensbergren <ericvh@gmail.com>
There is a simple logic error in init_v9fs - the return code checks are
reversed. This patch fixes the return code and adds some messages to prevent
module initialization from failing silently.
NFS V3 (and V4) support exclusive create by passing a 'cookie' which can get
stored with the file. If the file exists but has exactly the right cookie
stored, then we assume this is a retransmit and the exclusive create was
successful.
The cookie is 64bits and is traditionally stored in the mtime and atime
fields. This causes a problem with Solaris7 as negative mtime or atime
confuse it. So we moved two bits into the mode word instead.
But inherited ACLs sometimes overwrite the mode word on create, so this is a
problem.
So we give up and just store 62 of the 64 bits and assume that is close
enough.
NFSd assumes that largest number of pages that will be needed for a
request+response is 2+N where N pages is the size of the largest permitted
read/write request. The '2' are 1 for the non-data part of the request, and 1
for the non-data part of the reply.
However, when a read request is not page-aligned, and we choose to use
->sendfile to send it directly from the page cache, we may need N+1 pages to
hold the whole reply. This can overflow and array and cause an Oops.
This patch increases size of the array for holding pages by one and makes sure
that entry is NULL when it is not in use.
Due to silly typos, if the nfs versions are explicitly set, no NFSACL versions
get enabled.
Also improve an error message that would have made this bug a little easier to
find.
/proc/*/mounstats was fixed, all right, but...
To reproduce:
while true; do
find /proc -type f 2>/dev/null | xargs cat 1>/dev/null 2>/dev/null;
done
BUG: unable to handle kernel NULL pointer dereference at virtual address 0000000c
printing eip:
c01754df
*pde = 00000000
Oops: 0000 [#28]
Modules linked in: af_packet ohci_hcd e1000 ehci_hcd uhci_hcd usbcore xfs
CPU: 0
EIP: 0060:[<c01754df>] Not tainted VLI
EFLAGS: 00010286 (2.6.20-rc5 #1)
EIP is at mounts_open+0x1c/0xac
eax: 00000000 ebx: d5898ac0 ecx: d1d27b18 edx: d1d27a50
esi: e6083e10 edi: d3c87f38 ebp: d5898ac0 esp: d3c87ef0
ds: 007b es: 007b ss: 0068
Process cat (pid: 18071, ti=d3c86000 task=f7d5f070 task.ti=d3c86000)
Stack: d5898ac0 e6083e10 d3c87f38 c01754c3 c0147c91 c18c52c0 d343f314 d5898ac0
00008000 d3c87f38 ffffff9c c0147e09 d5898ac0 00000000 00000000 c0147e4b
00000000 d3c87f38 d343f314 c18c52c0 c015e53e 00001000 08051000 00000101
Call Trace:
[<c01754c3>] mounts_open+0x0/0xac
[<c0147c91>] __dentry_open+0xa1/0x18c
[<c0147e09>] nameidata_to_filp+0x31/0x3a
[<c0147e4b>] do_filp_open+0x39/0x40
[<c015e53e>] seq_read+0x128/0x2aa
[<c0147e8c>] do_sys_open+0x3a/0x6d
[<c0147efa>] sys_open+0x1c/0x20
[<c0102b76>] sysenter_past_esp+0x5f/0x85
[<c02a0033>] unix_stream_recvmsg+0x3bf/0x4bf
Code: 5d c3 89 d8 e8 06 e0 f9 ff eb bd 0f 0b eb fe 55 57 56 53 89 d5 8b 40 f0 31 d2 e8 02 c1 fa ff 89 c2 85 c0 74 5c 8b 80 48 04 00 00 <8b> 58 0c 85 db 74 02 ff 03 ff 4a 08 0f 94 c0 84 c0 75 74 85 db
EIP: [<c01754df>] mounts_open+0x1c/0xac SS:ESP 0068:d3c87ef0
A race with do_exit()'s call to exit_namespaces().
Acked-by: Serge Hallyn <serue@us.ibm.com>
This patch fixes core dumps to include the vDSO vma, which is left out now.
It removes the special-case core writing macros, which were not doing the
right thing for the vDSO vma anyway. Instead, it uses VM_ALWAYSDUMP in the
vma; there is no need for the fixmap page to be installed. It handles the
CONFIG_COMPAT_VDSO case by making elf_core_dump use the fake vma from
get_gate_vma after real vmas in the same way the /proc/PID/maps code does.
This changes core dumps so they no longer include the non-PT_LOAD phdrs from
the vDSO. I made the change to add them in the first place, but in turned out
that nothing ever wanted them there since the advent of NT_AUXV. It's cleaner
to leave them out, and just let the phdrs inside the vDSO image speak for
themselves.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: Andi Kleen <ak@suse.de>
This patch adds the VM_ALWAYSDUMP flag for vm_flags in vm_area_struct. This
provides a clean explicit way to have a vma always included in core dumps, as
is needed for vDSO's.
