commit 45c72cd73c788dd18c8113d4a404d6b4a01decf1 upstream.
Now we store attr->ino at inode->i_ino, return attr->ino at the
first time and then return inode->i_ino if the attribute timeout
isn't expired. That's wrong on 32 bit platforms because attr->ino
is 64 bit and inode->i_ino is 32 bit in this case.
Fix this by saving 64 bit ino in fuse_inode structure and returning
it every time we call getattr. Also squash attr->ino into inode->i_ino
explicitly.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 9fe79d7600497ed8a95c3981cbe5b73ab98222f0 upstream.
If the first attempt at opening the lower file read/write fails,
eCryptfs will retry using a privileged kthread. However, the privileged
retry should not happen if the lower file's inode is read-only because a
read/write open will still be unsuccessful.
The check for determining if the open should be retried was intended to
be based on the access mode of the lower file's open flags being
O_RDONLY, but the check was incorrectly performed. This would cause the
open to be retried by the privileged kthread, resulting in a second
failed open of the lower file. This patch corrects the check to
determine if the open request should be handled by the privileged
kthread.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Dan Carpenter <dan.carpenter@oracle.com>
commit fb6ccff667712c46b4501b920ea73a326e49626a upstream.
Commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 attempted to verify that
the total iovec from the client doesn't overflow iov_length() but it
only checked the first element. The iovec could still overflow by
starting with a small element. The obvious fix is to check all the
elements.
The overflow case doesn't look dangerous to the kernel as the copy is
limited by the length after the overflow. This fix restores the
intention of returning an error instead of successfully copying less
than the iovec represented.
I found this by code inspection. I built it but don't have a test case.
I'm cc:ing stable because the initial commit did as well.
Signed-off-by: Zach Brown <zab@redhat.com>
commit 0e665d5d1125f9f4ccff56a75e814f10f88861a2 upstream.
compat_sys_{read,write}v() need the same "pass a copy of file->f_pos" thing
as sys_{read,write}{,v}().
commit 68766a2edcd5cd744262a70a2f67a320ac944760 upstream.
In case we detect a problem and bail out, we fail to set "ret" to a
nonzero value, and udf_load_logicalvol will mistakenly report success.
Signed-off-by: Nikola Pajkovsky <npajkovs@redhat.com>
commit 9c2fc0de1a6e638fe58c354a463f544f42a90a09 upstream.
When a file is stored in ICB (inode), we overwrite part of the file, and
the page containing file's data is not in page cache, we end up corrupting
file's data by overwriting them with zeros. The problem is we use
simple_write_begin() which simply zeroes parts of the page which are not
written to. The problem has been introduced by be021ee4 (udf: convert to
new aops).
Fix the problem by providing a ->write_begin function which makes the page
properly uptodate.
Reported-by: Ian Abbott <abbotti@mev.co.uk>
commit 89b1f39eb4189de745fae554b0d614d87c8d5c63 upstream.
For large UDF filesystems with 512-byte blocks the number of necessary
bitmap blocks is larger than 2^16 so s_nr_groups in udf_bitmap overflows
(the number will overflow for filesystems larger than 128 GB with
512-byte blocks). That results in ENOSPC errors despite the filesystem
has plenty of free space.
Fix the problem by changing s_nr_groups' type to 'int'. That is enough
even for filesystems 2^32 blocks (UDF maximum) and 512-byte blocksize.
Reported-and-tested-by: v10lator@myway.de
commit 0143fc5e9f6f5aad4764801015bc8d4b4a278200 upstream.
For type 0x51 the udf.parent_partref member in struct fid gets copied
uninitialized to userland. Fix this by initializing it to 0.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 2fb7d99d0de3fd8ae869f35ab682581d8455887a upstream.
Need to brelse the buffer_head stored in cur_epos and next_epos.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Ashish Sangwan <a.sangwan@samsung.com>
commit e9fbcb42201c862fd6ab45c48ead4f47bb2dea9d upstream.
Each ordered operation has a free callback, and this was called with the
worker spinlock held. Josef made the free callback also call iput,
which we can't do with the spinlock.
This drops the spinlock for the free operation and grabs it again before
moving through the rest of the list. We'll circle back around to this
and find a cleaner way that doesn't bounce the lock around so much.
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
commit bc178622d40d87e75abc131007342429c9b03351 upstream.
Doing this would reliably fail with -EBUSY for me:
# mount /dev/sdb2 /mnt/scratch; umount /mnt/scratch; mkfs.btrfs -f /dev/sdb2
unable to open /dev/sdb2: Device or resource busy
because mkfs.btrfs tries to open the device O_EXCL, and somebody still has it.
Using systemtap to track bdev gets & puts shows a kworker thread doing a
blkdev put after mkfs attempts a get; this is left over from the unmount
path:
btrfs_close_devices
__btrfs_close_devices
call_rcu(&device->rcu, free_device);
free_device
INIT_WORK(&device->rcu_work, __free_device);
schedule_work(&device->rcu_work);
so unmount might complete before __free_device fires & does its blkdev_put.
Adding an rcu_barrier() to btrfs_close_devices() causes unmount to wait
until all blkdev_put()s are done, and the device is truly free once
unmount completes.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
commit acd6ad83517639e8f09a8c5525b1dccd81cd2a10 upstream.
When insert_inode_locked() fails in ext4_new_inode() it most likely means inode
bitmap got corrupted and we allocated again inode which is already in use. Also
doing unlock_new_inode() during error recovery is wrong since the inode does
not have I_NEW set. Fix the problem by jumping to fail: (instead of fail_drop:)
which declares filesystem error and does not call unlock_new_inode().
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 0e9a9a1ad619e7e987815d20262d36a2f95717ca upstream.
When trying to mount a file system which does not contain a journal,
but which does have a orphan list containing an inode which needs to
be truncated, the mount call with hang forever in
ext4_orphan_cleanup() because ext4_orphan_del() will return
immediately without removing the inode from the orphan list, leading
to an uninterruptible loop in kernel code which will busy out one of
the CPU's on the system.
This can be trivially reproduced by trying to mount the file system
found in tests/f_orphan_extents_inode/image.gz from the e2fsprogs
source tree. If a malicious user were to put this on a USB stick, and
mount it on a Linux desktop which has automatic mounts enabled, this
could be considered a potential denial of service attack. (Not a big
deal in practice, but professional paranoids worry about such things,
and have even been known to allocate CVE numbers for such problems.)
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
commit c9b92530a723ac5ef8e352885a1862b18f31b2f5 upstream.
Instead of checking whether the handle is valid, we check if journal
is enabled. This avoids taking the s_orphan_lock mutex in all cases
when there is no journal in use, including the error paths where
ext4_orphan_del() is called with a handle set to NULL.
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
commit e6155736ad76b2070652745f9e54cdea3f0d8567 upstream.
In the case where we are allocating for a non-extent file,
we must limit the groups we allocate from to those below
2^32 blocks, and ext4_mb_regular_allocator() attempts to
do this initially by putting a cap on ngroups for the
subsequent search loop.
However, the initial target group comes in from the
allocation context (ac), and it may already be beyond
the artificially limited ngroups. In this case,
the limit
if (group == ngroups)
group = 0;
at the top of the loop is never true, and the loop will
run away.
Catch this case inside the loop and reset the search to
start at group 0.
[sandeen@redhat.com: add commit msg & comments]
Signed-off-by: Lachlan McIlroy <lmcilroy@redhat.com>
commit f1167009711032b0d747ec89a632a626c901a1ad upstream.
In ext4_mb_add_n_trim(), lg_prealloc_lock should be taken when
changing the lg_prealloc_list.
Signed-off-by: Niu Yawei <yawei.niu@intel.com>
commit 721e3eba21e43532e438652dd8f1fcdfce3187e7 upstream.
Commit c278531d39 added a warning when ext4_flush_unwritten_io() is
called without i_mutex being taken. It had previously not been taken
during orphan cleanup since races weren't possible at that point in
the mount process, but as a result of this c278531d39, we will now see
a kernel WARN_ON in this case. Take the i_mutex in
ext4_orphan_cleanup() to suppress this warning.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
commit b71fc079b5d8f42b2a52743c8d2f1d35d655b1c5 upstream.
Code tracking when transaction needs to be committed on fdatasync(2) forgets
to handle a situation when only inode's i_size is changed. Thus in such
situations fdatasync(2) doesn't force transaction with new i_size to disk
and that can result in wrong i_size after a crash.
Fix the issue by updating inode's i_datasync_tid whenever its size is
updated.
Reported-by: Kristian Nielsen <knielsen@knielsen-hq.org>
commit 6a08f447facb4f9e29fcc30fb68060bb5a0d21c2 upstream.
ext4_special_inode_operations have their own ifdef CONFIG_EXT4_FS_XATTR
to mask those methods. And ext4_iget also always sets it, so there is
an inconsistency.
Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
commit f066055a3449f0e5b0ae4f3ceab4445bead47638 upstream.
Proper block swap for inodes with full journaling enabled is
truly non obvious task. In order to be on a safe side let's
explicitly disable it for now.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit 24ec19b0ae83a385ad9c55520716da671274b96c upstream.
In ext4_xattr_set_acl(), if ext4_journal_start() returns an error,
posix_acl_release() will not be called for 'acl' which may result in a
memory leak.
This patch fixes that.
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: Eugene Shatokhin <eugene.shatokhin@rosalab.ru>
commit 6976a6f2acde2b0443cd64f1d08af90630e4ce81 upstream.
Fix for a null pointer bug found while running punch hole tests
Signed-off-by: Allison Henderson <achender@us.ibm.com>
commit 7ad8e4e6ae2a7c95445ee1715b1714106fb95037 upstream.
When make_indexed_dir() fails (e.g. because of ENOSPC) after it has
allocated block for index tree root, we did not properly mark all
changed buffers dirty. This lead to only some of these buffers being
written out and thus effectively corrupting the directory.
Fix the issue by marking all changed data dirty even in the error
failure case.
commit 97795d2a5b8d3c8dc4365d4bd3404191840453ba upstream.
If we hit a condition where we have allocated metadata blocks that
were not appropriately reserved, we risk underflow of
ei->i_reserved_meta_blocks. In turn, this can throw
sbi->s_dirtyclusters_counter significantly out of whack and undermine
the nondelalloc fallback logic in ext4_nonda_switch(). Warn if this
occurs and set i_allocated_meta_blocks to avoid this problem.
This condition is reproduced by xfstests 270 against ext2 with
delalloc enabled:
Mar 28 08:58:02 localhost kernel: [ 171.526344] EXT4-fs (loop1): delayed block allocation failed for inode 14 at logical offset 64486 with max blocks 64 with error -28
Mar 28 08:58:02 localhost kernel: [ 171.526346] EXT4-fs (loop1): This should not happen!! Data will be lost
270 ultimately fails with an inconsistent filesystem and requires an
fsck to repair. The cause of the error is an underflow in
ext4_da_update_reserve_space() due to an unreserved meta block
allocation.
Signed-off-by: Brian Foster <bfoster@redhat.com>
commit 1415dd8705394399d59a3df1ab48d149e1e41e77 upstream.
When insert_inode_locked() fails in ext3_new_inode() it most likely
means inode bitmap got corrupted and we allocated again inode which
is already in use. Also doing unlock_new_inode() during error recovery
is wrong since inode does not have I_NEW set. Fix the problem by jumping
to fail: (instead of fail_drop:) which declares filesystem error and
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
commit 156bddd8e505b295540f3ca0e27dda68cb0d49aa upstream.
updated.
commit 545d680938be1e86a6c5250701ce9abaf360c495 upstream.
After passing through a ->setxattr() call, eCryptfs needs to copy the
inode attributes from the lower inode to the eCryptfs inode, as they
may have changed in the lower filesystem's ->setxattr() path.
One example is if an extended attribute containing a POSIX Access
Control List is being set. The new ACL may cause the lower filesystem to
modify the mode of the lower inode and the eCryptfs inode would need to
be updated to reflect the new mode.
https://launchpad.net/bugs/926292
Reported-by: Sebastien Bacher <seb128@ubuntu.com>
Cc: John Johansen <john.johansen@canonical.com>
commit 48b512e6857139393cdfce26348c362b87537018 upstream.
Ecryptfs is a stackable filesystem which relies on lower filesystems the
ability of setting/getting extended attributes.
If there is a security module enabled on the system it updates the
'security' field of inodes according to the owned extended attribute set
with the function vfs_setxattr(). When this function is performed on a
ecryptfs filesystem the 'security' field is not updated for the lower
filesystem since the call security_inode_post_setxattr() is missing for
the lower inode.
Further, the call security_inode_setxattr() is missing for the lower inode,
leading to policy violations in the security module because specific
checks for this hook are not performed (i. e. filesystem
'associate' permission on SELinux is not checked for the lower filesystem).
This patch replaces the call of the setxattr() method of the lower inode
in the function ecryptfs_setxattr() with vfs_setxattr().
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Cc: Dustin Kirkland <kirkland@canonical.com>
Acked-by: James Morris <jmorris@namei.org>
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 15291164b22a357cb211b618adfef4fa82fc0de3 upstream.
journal_unmap_buffer()'s zap_buffer: code clears a lot of buffer head
state ala discard_buffer(), but does not touch _Delay or _Unwritten as
discard_buffer() does.
This can be problematic in some areas of the ext4 code which assume
that if they have found a buffer marked unwritten or delay, then it's
a live one. Perhaps those spots should check whether it is mapped
as well, but if jbd2 is going to tear down a buffer, let's really
tear it down completely.
Without this I get some fsx failures on sub-page-block filesystems
up until v3.2, at which point 4e96b2dbbf1d7e81f22047a50f862555a6cb87cb
and 189e868fa8fdca702eb9db9d8afc46b5cb9144c9 make the failures go
away, because buried within that large change is some more flag
clearing. I still think it's worth doing in jbd2, since
->invalidatepage leads here directly, and it's the right place
to clear away these flags.
commit 25389bb207987b5774182f763b9fb65ff08761c8 upstream.
Commit 09e05d48 introduced a wait for transaction commit into
journal_unmap_buffer() in the case we are truncating a buffer undergoing commit
in the page stradding i_size on a filesystem with blocksize < pagesize. Sadly
we forgot to drop buffer lock before waiting for transaction commit and thus
deadlock is possible when kjournald wants to lock the buffer.
Fix the problem by dropping the buffer lock before waiting for transaction
commit. Since we are still holding page lock (and that is OK), buffer cannot
disappear under us.
commit 09e05d4805e6c524c1af74e524e5d0528bb3fef3 upstream.
ext3 users of data=journal mode with blocksize < pagesize were occasionally
hitting assertion failure in journal_commit_transaction() checking whether the
transaction has at least as many credits reserved as buffers attached. The
core of the problem is that when a file gets truncated, buffers that still need
checkpointing or that are attached to the committing transaction are left with
buffer_mapped set. When this happens to buffers beyond i_size attached to a
page stradding i_size, subsequent write extending the file will see these
buffers and as they are mapped (but underlying blocks were freed) things go
awry from here.
The assertion failure just coincidentally (and in this case luckily as we would
start corrupting filesystem) triggers due to journal_head not being properly
cleaned up as well.
Under some rare circumstances this bug could even hit data=ordered mode users.
There the assertion won't trigger and we would end up corrupting the
filesystem.
We fix the problem by unmapping buffers if possible (in lots of cases we just
need a buffer attached to a transaction as a place holder but it must not be
written out anyway). And in one case, we just have to bite the bullet and wait
for transaction commit to finish.
Reviewed-by: Josef Bacik <jbacik@fusionio.com>
commit fe685aabf7c8c9f138e5ea900954d295bf229175 upstream.
For type 1 the parent_offset member in struct isofs_fid gets copied
commit 10b8c7dff5d3633b69e77f57d404dab54ead3787 upstream.
When it goes to error through line 144, the memory allocated to *devname is
not freed, and the caller doesn't free it either in line 250. So we free the
memroy of *devname in function cifs_compose_mount_options() when it goes to
error.
Signed-off-by: Cong Ding <dinggnu@gmail.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 66081a72517a131430dcf986775f3268aafcb546 upstream.
The warning check for duplicate sysfs entries can cause a buffer overflow
when printing the warning, as strcat() doesn't check buffer sizes.
Use strlcat() instead.
Since strlcat() doesn't return a pointer to the passed buffer, unlike
strcat(), I had to convert the nested concatenation in sysfs_add_one() to
an admittedly more obscure comma operator construct, to avoid emitting code
for the concatenation if CONFIG_BUG is disabled.
commit ec686c9239b4d472052a271c505d04dae84214cc upstream.
There is a kernel memory leak observed when the proc file
/proc/fs/fscache/stats is read.
The reason is that in fscache_stats_open, single_open is called and the
respective release function is not called during release. Hence fix
with correct release function - single_release().
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=57101
Signed-off-by: Anurup m <anurup.m@huawei.com>
Cc: shyju pv <shyju.pv@huawei.com>
Cc: Sanil kumar <sanil.kumar@huawei.com>
Cc: Nataraj m <nataraj.m@huawei.com>
Cc: Li Zefan <lizefan@huawei.com>
commit 12176503366885edd542389eed3aaf94be163fdb upstream.
The compat ioctl for VIDEO_SET_SPU_PALETTE was missing an error check
while converting ioctl arguments. This could lead to leaking kernel
stack contents into userspace.
Patch extracted from existing fix in grsecurity.
Cc: Brad Spengler <spender@grsecurity.net>
Cc: PaX Team <pageexec@freemail.hu>
commit 128dd1759d96ad36c379240f8b9463e8acfd37a1 upstream.
EPOLL_CTL_MOD sets the interest mask before calling f_op->poll() to
ensure events are not missed. Since the modifications to the interest
mask are not protected by the same lock as ep_poll_callback, we need to
ensure the change is visible to other CPUs calling ep_poll_callback.
We also need to ensure f_op->poll() has an up-to-date view of past
events which occured before we modified the interest mask. So this
barrier also pairs with the barrier in wq_has_sleeper().
This should guarantee either ep_poll_callback or f_op->poll() (or both)
will notice the readiness of a recently-ready/modified item.
This issue was encountered by Andreas Voellmy and Junchang(Jason) Wang in:
http://thread.gmane.org/gmane.linux.kernel/1408782/
Signed-off-by: Eric Wong <normalperson@yhbt.net>
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Andreas Voellmy <andreas.voellmy@yale.edu>
Tested-by: "Junchang(Jason) Wang" <junchang.wang@yale.edu>
Cc: netdev@vger.kernel.org
Cc: linux-fsdevel@vger.kernel.org
commit f34f9d186df35e5c39163444c43b4fc6255e39c5 upstream.
In !CORE_DUMP_USE_REGSET case, if elf_note_info_init fails to allocate
memory for info->fields, it frees already allocated stuff and returns
error to its caller, fill_note_info. Which in turn returns error to its
caller, elf_core_dump. Which jumps to cleanup label and calls
free_note_info, which will happily try to free all info->fields again.
BOOM.
This is the fix.
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
Cc: Venu Byravarasu <vbyravarasu@nvidia.com>
commit d740269867021faf4ce38a449353d2b986c34a67 upstream.
To avoid an explosion of request_module calls on a chain of abusive
scripts, fail maximum recursion with -ELOOP instead of -ENOEXEC. As soon
as maximum recursion depth is hit, the error will fail all the way back
up the chain, aborting immediately.
This also has the side-effect of stopping the user's shell from attempting
to reexecute the top-level file as a shell script. As seen in the
dash source:
if (cmd != path_bshell && errno == ENOEXEC) {
*argv-- = cmd;
*argv = cmd = path_bshell;
goto repeat;
The above logic was designed for running scripts automatically that lacked
the "#!" header, not to re-try failed recursion. On a legitimate -ENOEXEC,
things continue to behave as the shell expects.
Additionally, when tracking recursion, the binfmt handlers should not be
involved. The recursion being tracked is the depth of calls through
search_binary_handler(), so that function should be exclusively responsible
for tracking the depth.
Cc: halfdog <me@halfdog.net>
Cc: P J P <ppandit@redhat.com>
commit b66c5984017533316fd1951770302649baf1aa33 upstream.
If a series of scripts are executed, each triggering module loading via
unprintable bytes in the script header, kernel stack contents can leak
into the command line.
Normally execution of binfmt_script and binfmt_misc happens recursively.
However, when modules are enabled, and unprintable bytes exist in the
bprm->buf, execution will restart after attempting to load matching
binfmt modules. Unfortunately, the logic in binfmt_script and
binfmt_misc does not expect to get restarted. They leave bprm->interp
pointing to their local stack. This means on restart bprm->interp is
left pointing into unused stack memory which can then be copied into the
userspace argv areas.
After additional study, it seems that both recursion and restart remains
the desirable way to handle exec with scripts, misc, and modules. As
such, we need to protect the changes to interp.
This changes the logic to require allocation for any changes to the
bprm->interp. To avoid adding a new kmalloc to every exec, the default
value is left as-is. Only when passing through binfmt_script or
binfmt_misc does an allocation take place.
For a proof of concept, see DoTest.sh from:
http://www.halfdog.net/Security/2012/LinuxKernelBinfmtScriptStackDataDisclosure/
commit 12f267a20aecf8b84a2a9069b9011f1661c779b4 upstream.
Change a u32 to loff_t hfsplus_file_truncate().
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
This is a shorter (and more appropriate for stable kernels) analog to
the following upstream commit:
commit 6926afd1925a54a13684ebe05987868890665e2b
Author: Trond Myklebust <Trond.Myklebust@netapp.com>
Date: Sat Jan 7 13:22:46 2012 -0500
NFSv4: Save the owner/group name string when doing open
...so that we can do the uid/gid mapping outside the asynchronous RPC
context.
This fixes a bug in the current NFSv4 atomic open code where the client
isn't able to determine what the true uid/gid fields of the file are,
(because the asynchronous nature of the OPEN call denies it the ability
to do an upcall) and so fills them with default values, marking the
inode as needing revalidation.
Unfortunately, in some cases, the VFS will do some additional sanity
checks on the file, and may override the server's decision to allow
the open because it sees the wrong owner/group fields.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Without this patch, logging into two different machines with home
directories mounted over NFS4 and then running "vim" and typing ":q"
in each reliably produces the following error on the second machine:
E137: Viminfo file is not writable: /users/system/rtheys/.viminfo
This regression was introduced by 80e52aced138 ("NFSv4: Don't do
idmapper upcalls for asynchronous RPC calls", merged during the 2.6.32
cycle) --- after the OPEN call, .viminfo has the default values for
st_uid and st_gid (0xfffffffe) cached because we do not want to let
rpciod wait for an idmapper upcall to fill them in.
The fix used in mainline is to save the owner and group as strings and
perform the upcall in _nfs4_proc_open outside the rpciod context,
which takes about 600 lines. For stable, we can do something similar
with a one-liner: make open check for the stale fields and make a
(synchronous) GETATTR call to fill them when needed.
Trond dictated the patch, I typed it in, and Rik tested it.
Addresses http://bugs.debian.org/659111 and
https://bugzilla.redhat.com/789298
Reported-by: Rik Theys <Rik.Theys@esat.kuleuven.be>
Explained-by: David Flyn <davidf@rd.bbc.co.uk>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Tested-by: Rik Theys <Rik.Theys@esat.kuleuven.be>
[PG: commit 19165bdbb3622cfca0ff66e8b30248d469b849d6 in v3.0.32]
commit 086600430493e04b802bee6e5b3ce0458e4eb77f upstream.
If the rpc call to NFS3PROC_FSINFO fails, then we need to report that
error so that the mount fails. Otherwise we can end up with a
superblock with completely unusable values for block sizes, maxfilesize,
etc.
Reported-by: Yuanming Chen <hikvision_linux@163.com>
commit d5f50b0c290431c65377c4afa1c764e2c3fe5305 upstream.
If the argument and reply together exceed the maximum payload size, then
a reply with a read-like operation can overlow the rq_pages array.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit ae62ca7b03217be5e74759dc6d7698c95df498b3 upstream.
commit 35f9c09fe9c72e (tcp: tcp_sendpages() should call tcp_push() once)
added an internal flag : MSG_SENDPAGE_NOTLAST meant to be set on all
frags but the last one for a splice() call.
The condition used to set the flag in pipe_to_sendpage() relied on
splice() user passing the exact number of bytes present in the pipe,
or a smaller one.
But some programs pass an arbitrary high value, and the test fails.
The effect of this bug is a lack of tcp_push() at the end of a
splice(pipe -> socket) call, and possibly very slow or erratic TCP
sessions.
We should both test sd->total_len and fact that another fragment
is in the pipe (pipe->nrbufs > 1)
Many thanks to Willy for providing very clear bug report, bisection
and test programs.
Reported-by: Willy Tarreau <w@1wt.eu>
Bisected-by: Willy Tarreau <w@1wt.eu>
Tested-by: Willy Tarreau <w@1wt.eu>
commit 35f9c09fe9c72eb8ca2b8e89a593e1c151f28fc2 upstream.
commit 2f533844242 (tcp: allow splice() to build full TSO packets) added
a regression for splice() calls using SPLICE_F_MORE.
We need to call tcp_flush() at the end of the last page processed in
tcp_sendpages(), or else transmits can be deferred and future sends
stall.
Add a new internal flag, MSG_SENDPAGE_NOTLAST, acting like MSG_MORE, but
with different semantic.
For all sendpage() providers, its a transparent change. Only
sock_sendpage() and tcp_sendpages() can differentiate the two different
flags provided by pipe_to_sendpage()
Reported-by: Tom Herbert <therbert@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: H.K. Jerry Chu <hkchu@google.com>
Cc: Maciej Żenczykowski <maze@google.com>
Cc: Mahesh Bandewar <maheshb@google.com>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
commit 8762202dd0d6e46854f786bdb6fb3780a1625efe upstream.
I hit a J_ASSERT(blocknr != 0) failure in cleanup_journal_tail() when
mounting a fsfuzzed ext3 image. It turns out that the corrupted ext3
image has s_first = 0 in journal superblock, and the 0 is passed to
journal->j_head in journal_reset(), then to blocknr in
cleanup_journal_tail(), in the end the J_ASSERT failed.
So validate s_first after reading journal superblock from disk in
journal_get_superblock() to ensure s_first is valid.
The following script could reproduce it:
fstype=ext3
blocksize=1024
img=$fstype.img
offset=0
found=0
magic="c0 3b 39 98"
dd if=/dev/zero of=$img bs=1M count=8
mkfs -t $fstype -b $blocksize -F $img
filesize=`stat -c %s $img`
while [ $offset -lt $filesize ]
do
if od -j $offset -N 4 -t x1 $img | grep -i "$magic";then
echo "Found journal: $offset"
found=1
break
fi
offset=`echo "$offset+$blocksize" | bc`
done
if [ $found -ne 1 ];then
echo "Magic \"$magic\" not found"
exit 1
fi
dd if=/dev/zero of=$img seek=$(($offset+23)) conv=notrunc bs=1 count=1
mkdir -p ./mnt
mount -o loop $img ./mnt
Cc: Jan Kara <jack@suse.cz>
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit 2cb33cac622afde897aa02d3dcd9fbba8bae839e upstream.
A malicious monitor can craft an auth reply message that could cause a
NULL function pointer dereference in the client's kernel.
To prevent this, the auth_none protocol handler needs an empty
ceph_auth_client_ops->build_request() function.
CVE-2013-1059
Reported-by: Chanam Park <chanam.park@hkpco.kr>
Reviewed-by: Seth Arnold <seth.arnold@canonical.com>
Reviewed-by: Sage Weil <sage@inktank.com>
[PG: in v2.6.34, file is fs/ceph and not net/ceph]
commit d0de4dc584ec6aa3b26fffea320a8457827768fc upstream.
On an error path in inotify_init1 a normal user can trigger a double
free of struct user. This is a regression introduced by a2ae4cc9a16e
("inotify: stop kernel memory leak on file creation failure").
We fix this by making sure that if a group exists the user reference is
dropped when the group is cleaned up. We should not explictly drop the
reference on error and also drop the reference when the group is cleaned
up.
The new lifetime rules are that an inotify group lives from
inotify_new_group to the last fsnotify_put_group. Since the struct user
and inotify_devs are directly tied to this lifetime they are only
changed/updated in those two locations. We get rid of all special
casing of struct user or user->inotify_devs.
Signed-off-by: Eric Paris <eparis@redhat.com>
The v2.6.34.14 commit "d7542a6 udf: Avoid run away loop when partition
table length is corrupted" introduced the following build warning due
to a change in the number of args in udf_error/udf_err for v2.6.34.14:
CC fs/udf/super.o
fs/udf/super.c: In function 'udf_load_sparable_map':
fs/udf/super.c:1259: warning: passing argument 3 of 'udf_error' makes pointer from integer without a cast
fs/udf/super.c:1265: warning: passing argument 3 of 'udf_error' makes pointer from integer without a cast
fs/udf/super.c: In function 'udf_load_logicalvol':
fs/udf/super.c:1313: warning: passing argument 3 of 'udf_error' makes pointer from integer without a cast
The above warnings are due to a missing __func__ argument in the above
udf_error function calls. This is because of commit 8076c363da15e7
("udf: Rename udf_error to udf_err") which removed the __func__ arg.
Restore the missing __func__ argument to fix the build warnings.
Signed-off-by: George G. Davis <george_davis@mentor.com>
