patch 58d84c4ee0389ddeb86238d5d8359a982c9f7a5b upstream.
Currently we always redirty an inode that was attempted to be written out
synchronously but has been cleaned by an AIL pushed internall, which is
rather bogus. Fix that by doing the i_update_core check early on and
return 0 for it. Also include async calls for it, as doing any work for
those is just as pointless. While we're at it also fix the sign for the
EIO return in case of a filesystem shutdown, and fix the completely
non-sensical locking around xfs_log_inode.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
commit db3e74b582915d66e10b0c73a62763418f54c340 upstream
The doalloc arg in xfs_qm_dqattach_one() is a flag that indicates
whether a new area to handle quota information will be allocated
if needed. Originally, it was passed to xfs_qm_dqget(), but has
been removed by the following commit (probably by mistake):
commit 8e9b6e7fa4544ea8a0e030c8987b918509c8ff47
Author: Christoph Hellwig <hch@lst.de>
Date: Sun Feb 8 21:51:42 2009 +0100
xfs: remove the unused XFS_QMOPT_DQLOCK flag
As the result, xfs_qm_dqget() called from xfs_qm_dqattach_one()
never allocates the new area even if it is needed.
This patch gives the doalloc arg to xfs_qm_dqget() in
xfs_qm_dqattach_one() to fix this problem.
Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Alex Elder <aelder@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit b52a360b2aa1c59ba9970fb0f52bbb093fcc7a24 upstream.
Fixes a possible memory corruption when the link is larger than
MAXPATHLEN and XFS_DEBUG is not enabled. This also remove the
S_ISLNK assert, since the inode mode is checked previously in
xfs_readlink_by_handle() and via VFS.
Updated to address concerns raised by Ben Hutchings about the loose
attention paid to 32- vs 64-bit values, and the lack of handling a
potentially negative pathlen value:
- Changed type of "pathlen" to be xfs_fsize_t, to match that of
ip->i_d.di_size
- Added checking for a negative pathlen to the too-long pathlen
test, and generalized the message that gets reported in that case
to reflect the change
As a result, if a negative pathlen were encountered, this function
would return EFSCORRUPTED (and would fail an assertion for a debug
build)--just as would a too-long pathlen.
Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com>
commit 87c7bec7fc3377b3873eb3a0f4b603981ea16ebb upstream.
The code to flush buffers in the umount code is a bit iffy: we first
flush all delwri buffers out, but then might be able to queue up a
new one when logging the sb counts. On a normal shutdown that one
would get flushed out when doing the synchronous superblock write in
xfs_unmountfs_writesb, but we skip that one if the filesystem has
been shut down.
Fix this by moving the delwri list flushing until just before unmounting
the log, and while we're at it also remove the superflous delwri list
and buffer lru flusing for the rt and log device that can never have
cached or delwri buffers.
Reported-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
Tested-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
commit ed32201e65e15f3e6955cb84cbb544b08f81e5a5 upstream.
An attribute of inode can be fetched via xfs_vn_getattr() in XFS.
Currently it returns EIO, not negative value, when it failed. As a
result, the system call returns not negative value even though an
error occured. The stat(2), ls and mv commands cannot handle this
error and do not work correctly.
This patch fixes this bug, and returns -EIO, not EIO when an error
is detected in xfs_vn_getattr().
commit c58cb165bd44de8aaee9755a144136ae743be116 upstream.
Currently a buffered reader or writer can add pages to the pagecache
while we are waiting for the iolock in xfs_file_dio_aio_write. Prevent
this by re-checking mapping->nrpages after we got the iolock, and if
nessecary upgrade the lock to exclusive mode. To simplify this a bit
only take the ilock inside of xfs_file_aio_write_checks.
commit 0c38a2512df272b14ef4238b476a2e4f70da1479 upstream.
There is no need to grab the i_mutex of the IO lock in exclusive
mode if we don't need to invalidate the page cache. Taking these
locks on every direct IO effective serialises them as taking the IO
lock in exclusive mode has to wait for all shared holders to drop
the lock. That only happens when IO is complete, so effective it
prevents dispatch of concurrent direct IO reads to the same inode.
Fix this by taking the IO lock shared to check the page cache state,
and only then drop it and take the IO lock exclusively if there is
work to be done. Hence for the normal direct IO case, no exclusive
locking will occur.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Tested-by: Joern Engel <joern@logfs.org>
commit 866e4ed77448a0c311e1b055eb72ea05423fd799 upstream.
During umount we do not add a dirty inode to the lru and wait for it to
become clean first, but force writeback of data and metadata with
I_WILL_FREE set. Currently there is no way for XFS to detect that the
inode has been redirtied for metadata operations, as we skip the
mark_inode_dirty call during teardown. Fix this by setting i_update_core
nanually in that case, so that the inode gets flushed during inode reclaim.
Alternatively we could enable calling mark_inode_dirty for inodes in
I_WILL_FREE state, and let the VFS dirty tracking handle this. I decided
against this as we will get better I/O patterns from reclaim compared to
the synchronous writeout in write_inode_now, and always marking the inode
dirty in some way from xfs_mark_inode_dirty is a better safetly net in
either case.
If removed storage while synchronous buffer write underway,
"xfslogd" hangs.
Detailed log http://oss.sgi.com/archives/xfs/2011-07/msg00740.html
Related work bfc60177f8ab509bc225becbb58f7e53a0e33e81
"xfs: fix error handling for synchronous writes"
Given that xfs_bwrite actually does the shutdown already after
waiting for the b_iodone completion and given that we actually
found that calling xfs_force_shutdown from inside
xfs_buf_iodone_callbacks was a major contributor the problem
it better to drop this call.
Signed-off-by: Ajeet Yadav <ajeet.yadav.77@gmail.com>
commit 1788ea6e3b2a58cf4fb00206e362d9caff8d86a7 upstream.
commit d953126 changed how nfs_atomic_lookup handles an -EISDIR return
from an OPEN call. Prior to that patch, that caused the client to fall
back to doing a normal lookup. When that patch went in, the code began
returning that error to userspace. The d_revalidate codepath however
never had the corresponding change, so it was still possible to end up
with a NULL ctx->state pointer after that.
That patch caused a regression. When we attempt to open a directory that
does not have a cached dentry, that open now errors out with EISDIR. If
you attempt the same open with a cached dentry, it will succeed.
Fix this by reverting the change in nfs_atomic_lookup and allowing
attempts to open directories to fall back to a normal lookup
Also, add a NFSv4-specific f_ops->open routine that just returns
-ENOTDIR. This should never be called if things are working properly,
but if it ever is, then the dprintk may help in debugging.
To facilitate this, a new file_operations field is also added to the
nfs_rpc_ops struct.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit bc5b8a9003132ae44559edd63a1623b7b99dfb68 upstream.
On a corrupted file system the ->len field could be wrong leading to
a buffer overflow.
Reported-and-acked-by: Clement LECIGNE <clement.lecigne@netasq.com>
commit 8c0bec2151a47906bf779c6715a10ce04453ab77 upstream.
The i_mutex lock and flush_completed_IO() added by commit 2581fdc810
in ext4_evict_inode() causes lockdep complaining about potential
deadlock in several places. In most/all of these LOCKDEP complaints
it looks like it's a false positive, since many of the potential
circular locking cases can't take place by the time the
ext4_evict_inode() is called; but since at the very least it may mask
real problems, we need to address this.
This change removes the flush_completed_IO() and i_mutex lock in
ext4_evict_inode(). Instead, we take a different approach to resolve
the software lockup that commit 2581fdc810 intends to fix. Rather
than having ext4-dio-unwritten thread wait for grabing the i_mutex
lock of an inode, we use mutex_trylock() instead, and simply requeue
the work item if we fail to grab the inode's i_mutex lock.
This should speed up work queue processing in general and also
prevents the following deadlock scenario: During page fault,
shrink_icache_memory is called that in turn evicts another inode B.
Inode B has some pending io_end work so it calls ext4_ioend_wait()
that waits for inode B's i_ioend_count to become zero. However, inode
B's ioend work was queued behind some of inode A's ioend work on the
same cpu's ext4-dio-unwritten workqueue. As the ext4-dio-unwritten
thread on that cpu is processing inode A's ioend work, it tries to
grab inode A's i_mutex lock. Since the i_mutex lock of inode A is
still hold before the page fault happened, we enter a deadlock.
Signed-off-by: Jiaying Zhang <jiayingz@google.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit a3fbbde70a0cec017f2431e8f8de208708c76acc upstream.
Mountpoint crossing is similar to following procfs symlinks - we do
not get ->d_revalidate() called for dentry we have arrived at, with
unpleasant consequences for NFS4.
Simple way to reproduce the problem in mainline:
cat >/tmp/a.c <<'EOF'
#include <unistd.h>
#include <fcntl.h>
#include <stdio.h>
main()
struct flock fl = {.l_type = F_RDLCK, .l_whence = SEEK_SET, .l_len = 1};
if (fcntl(0, F_SETLK, &fl))
perror("setlk");
EOF
cc /tmp/a.c -o /tmp/test
then on nfs4:
mount --bind file1 file2
/tmp/test < file1 # ok
/tmp/test < file2 # spews "setlk: No locks available"...
What happens is the missing call of ->d_revalidate() after mountpoint
crossing and that's where NFS4 would issue OPEN request to server.
The fix is simple - treat mountpoint crossing the same way we deal with
following procfs-style symlinks. I.e. set LOOKUP_JUMPED...
commit 5c8a0fbba543d9428a486f0d1282bbcf3cf1d95a upstream.
No one in their right mind would expect statfs() to not work on a
automounter managed mount point. Fix it.
[ I'm not sure about the "no one in their right mind" part. It's not
mounted, and you didn't ask for it to be mounted. But nobody will
really care, and this probably makes it match previous semantics, so..
- Linus ]
This mirrors the fix made to the quota code in 815d405ceff0d69646.
Signed-off-by: Dan McGee <dpmcgee@gmail.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
commit f992ae801a7dec34a4ed99a6598bbbbfb82af4fb upstream.
The following command sequence triggers an oops.
# mount /dev/sdb1 /mnt
# echo 1 > /sys/class/scsi_device/0\:0\:1\:0/device/delete
# umount /mnt
general protection fault: 0000 [#1] PREEMPT SMP
CPU 2
Modules linked in:
Pid: 791, comm: umount Not tainted 3.1.0-rc3-work+ #8 Bochs Bochs
RIP: 0010:[<ffffffff810d0879>] [<ffffffff810d0879>] __lock_acquire+0x389/0x1d60
Call Trace:
[<ffffffff810d2845>] lock_acquire+0x95/0x140
[<ffffffff81aed87b>] _raw_spin_lock+0x3b/0x50
[<ffffffff811573bc>] bdi_lock_two+0x5c/0x70
[<ffffffff811c2f6c>] bdev_inode_switch_bdi+0x4c/0xf0
[<ffffffff811c3fcb>] __blkdev_put+0x11b/0x1d0
[<ffffffff811c4010>] __blkdev_put+0x160/0x1d0
[<ffffffff811c40df>] blkdev_put+0x5f/0x190
[<ffffffff8118f18d>] kill_block_super+0x4d/0x80
[<ffffffff8118f4a5>] deactivate_locked_super+0x45/0x70
[<ffffffff8119003a>] deactivate_super+0x4a/0x70
[<ffffffff811ac4ad>] mntput_no_expire+0xed/0x130
[<ffffffff811acf2e>] sys_umount+0x7e/0x3a0
[<ffffffff81aeeeab>] system_call_fastpath+0x16/0x1b
This is because bdev holds on to disk but disk doesn't pin the
associated queue. If a SCSI device is removed while the device is
still open, the sdev puts the base reference to the queue on release.
When the bdev is finally released, the associated queue is already
gone along with the bdi and bdev_inode_switch_bdi() ends up
dereferencing already freed bdi.
Even if it were not for this bug, disk not holding onto the associated
queue is very unusual and error-prone.
Fix it by making add_disk() take an extra reference to its queue and
put it on disk_release() and ensuring that disk and its fops owner are
put in that order after all accesses to the disk and queue are
complete.
commit 6d6a435190bdf2e04c9465cde5bdc3ac68cf11a4 upstream.
Ceph users reported that when using Ceph on ext4, the filesystem
would often become corrupted, containing inodes with incorrect
i_blocks counters.
I managed to reproduce this with a very hacked-up "streamtest"
binary from the Ceph tree.
Ceph is doing a lot of xattr writes, to out-of-inode blocks.
There is also another thread which does sync_file_range and close,
of the same files. The problem appears to happen due to this race:
sync/flush thread xattr-set thread
do_writepages ext4_xattr_set
ext4_da_writepages ext4_xattr_set_handle
mpage_da_map_blocks ext4_xattr_block_set
set DELALLOC_RESERVE
ext4_new_meta_blocks
ext4_mb_new_blocks
if (!i_delalloc_reserved_flag)
vfs_dq_alloc_block
ext4_get_blocks
down_write(i_data_sem)
set i_delalloc_reserved_flag
up_write(i_data_sem)
if (i_delalloc_reserved_flag)
vfs_dq_alloc_block_nofail
In other words, the sync/flush thread pops in and sets
i_delalloc_reserved_flag on the inode, which makes the xattr thread
think that it's in a delalloc path in ext4_new_meta_blocks(),
and add the block for a second time, after already having added
it once in the !i_delalloc_reserved_flag case in ext4_mb_new_blocks
The real problem is that we shouldn't be using the DELALLOC_RESERVED
state flag, and instead we should be passing
EXT4_GET_BLOCKS_DELALLOC_RESERVE down to ext4_map_blocks() instead of
using an inode state flag. We'll fix this for now with using
i_data_sem to prevent this race, but this is really not the right way
to fix things.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
commit 5930ea643805feb50a2f8383ae12eb6f10935e49 upstream.
ext4_dx_add_entry manipulates bh2 and frames[0].bh, which are two buffer_heads
that point to directory blocks assigned to the directory inode. However, the
function calls ext4_handle_dirty_metadata with the inode of the file that's
being added to the directory, not the directory inode itself. Therefore,
correct the code to dirty the directory buffers with the directory inode, not
the file inode.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
commit f9287c1f2d329f4d78a3bbc9cf0db0ebae6f146a upstream.
ext4_mkdir calls ext4_handle_dirty_metadata with dir_block and the inode "dir".
Unfortunately, dir_block belongs to the newly created directory (which is
"inode"), not the parent directory (which is "dir"). Fix the incorrect
association.
commit bcaa992975041e40449be8c010c26192b8c8b409 upstream.
When ext4_rename performs a directory rename (move), dir_bh is a
buffer that is modified to update the '..' link in the directory being
moved (old_inode). However, ext4_handle_dirty_metadata is called with
the old parent directory inode (old_dir) and dir_bh, which is
incorrect because dir_bh does not belong to the parent inode. Fix
this error.
commit 1cd9f0976aa4606db8d6e3dc3edd0aca8019372a upstream.
This doesn't make much sense, and it exposes a bug in the kernel where
attempts to create a new file in an append-only directory using
O_CREAT will fail (but still leave a zero-length file). This was
discovered when xfstests #79 was generalized so it could run on all
file systems.
commit 1117f72ea0217ba0cc19f05adbbd8b9a397f5ab7 upstream.
The CLOEXE bit is magical, and for performance (and semantic) reasons we
don't actually maintain it in the file descriptor itself, but in a
separate bit array. Which means that when we show f_flags, the CLOEXE
status is shown incorrectly: we show the status not as it is now, but as
it was when the file was opened.
Fix that by looking up the bit properly in the 'fdt->close_on_exec' bit
array.
Uli needs this in order to re-implement the pfiles program:
"For normal file descriptors (not sockets) this was the last piece of
information which wasn't available. This is all part of my 'give
Solaris users no reason to not switch' effort. I intend to offer the
code to the util-linux-ng maintainers."
Requested-by: Ulrich Drepper <drepper@akkadia.org>
commit a3defbe5c337dbc6da911f8cc49ae3cc3b49b453 upstream.
The case of address space randomization being disabled in runtime through
randomize_va_space sysctl is not treated properly in load_elf_binary(),
resulting in SIGKILL coming at exec() time for certain PIE-linked binaries
in case the randomization has been disabled at runtime prior to calling
exec().
Handle the randomize_va_space == 0 case the same way as if we were not
supporting .text randomization at all.
Based on original patch by H.J. Lu and Josh Boyer.
Cc: H.J. Lu <hongjiu.lu@intel.com>
Cc: <stable@kernel.org>
Tested-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Since we've now turned around and made LOOKUP_FOLLOW *not* force an
automount, we want to add the ability to force an automount event on
lookup even if we don't happen to have one of the other flags that force
it implicitly (LOOKUP_OPEN, LOOKUP_DIRECTORY, LOOKUP_PARENT..)
Most cases will never want to use this, since you'd normally want to
delay automounting as long as possible, which usually implies
LOOKUP_OPEN (when we open a file or directory, we really cannot avoid
the automount any more).
But Trond argued sufficiently forcefully that at a minimum bind mounting
a file and quotactl will want to force the automount lookup. Some other
cases (like nfs_follow_remote_path()) could use it too, although
LOOKUP_DIRECTORY would work there as well.
This commit just adds the flag and logic, no users yet, though. It also
doesn't actually touch the LOOKUP_NO_AUTOMOUNT flag that is related, and
was made irrelevant by the same change that made us not follow on
LOOKUP_FOLLOW.
Cc: Ian Kent <raven@themaw.net>
Cc: Jeff Layton <jlayton@redhat.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 815d405ceff0d6964683f033e18b9b23a88fba87 upstream.
The concensus seems to be that system calls such as stat() etc should
not trigger an automount. Neither should the l* versions.
This patch therefore adds a LOOKUP_AUTOMOUNT flag to tag those lookups
that _should_ trigger an automount on the last path element.
[ Edited to leave out the cases that are already covered by LOOKUP_OPEN,
LOOKUP_DIRECTORY and LOOKUP_CREATE - all of which also fundamentally
force automounting for their own reasons - Linus ]
commit 0ec26fd0698285b31248e34bf1abb022c00f23d6 upstream.
Prior to 2.6.38 automount would not trigger on either stat(2) or
lstat(2) on the automount point.
After 2.6.38, with the introduction of the ->d_automount()
infrastructure, stat(2) and others would start triggering automount
while lstat(2), etc. still would not. This is a regression and a
userspace ABI change.
Problem originally reported here:
http://thread.gmane.org/gmane.linux.kernel.autofs/6098
It appears that there was an attempt at fixing various userspace tools
to not trigger the automount. But since the stat system call is
rather common it is impossible to "fix" all userspace.
This patch reverts the original behavior, which is to not trigger on
stat(2) and other symlink following syscalls.
[ It's not really clear what the right behavior is. Apparently Solaris
does the "automount on stat, leave alone on lstat". And some programs
can get unhappy when "stat+open+fstat" ends up giving a different
result from the fstat than from the initial stat.
But the change in 2.6.38 resulted in problems for some people, so
we're going back to old behavior. Maybe we can re-visit this
discussion at some future date - Linus ]
Reported-by: Leonardo Chiquitto <leonardo.lists@gmail.com>
Acked-by: Ian Kent <raven@themaw.net>
commit 5a30d8a2b8ddd5102c440c7e5a7c8e1fd729c818 upstream.
[ backport for 3.0.x: LOOKUP_PARENT => LOOKUP_CONTINUE by Chuck Ebbert
<cebbert@redhat.com> ]
Autofs may set the DCACHE_NEED_AUTOMOUNT flag on negative dentries. These
need attention from the automounter daemon regardless of the LOOKUP_FOLLOW flag.
Cc: Chuck Ebbert <cebbert@redhat.com>
commit 1fa1e7f615f4d3ae436fa319af6e4eebdd4026a8 upstream.
Since the commit below which added O_PATH support to the *at() calls, the
error return for readlink/readlinkat for the empty pathname has switched
from ENOENT to EINVAL:
commit 65cfc6722361570bfe255698d9cd4dccaf47570d
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sun Mar 13 15:56:26 2011 -0400
readlinkat(), fchownat() and fstatat() with empty relative pathnames
This is both unexpected for userspace and makes readlink/readlinkat
inconsistant with all other interfaces; and inconsistant with our stated
return for these pathnames.
As the readlinkat call does not have a flags parameter we cannot use the
AT_EMPTY_PATH approach used in the other calls. Therefore expose whether
the original path is infact entry via a new user_path_at_empty() path
lookup function. Use this to determine whether to default to EINVAL or
ENOENT for failures.
Addresses http://bugs.launchpad.net/bugs/817187
[akpm@linux-foundation.org: remove unused getname_flags()]
Signed-off-by: Andy Whitcroft <apw@canonical.com>
commit fc360bd9cdcf875639a77f07fafec26699c546f3 upstream.
The display of the "huge" tag was accidentally removed in 29ea2f698 ("mm:
use walk_page_range() instead of custom page table walking code").
Reported-by: Stephen Hemminger <shemminger@vyatta.com>
Tested-by: Stephen Hemminger <shemminger@vyatta.com>
Reviewed-by: Stephen Wilson <wilsons@start.ca>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
commit a877ee03ac010ded434b77f7831f43cbb1fcc60f upstream.
nfsiostat was failing to find mounted filesystems on kernels after
2.6.38 because of changes to show_vfsstat() by commit
c7f404b40a3665d9f4e9a927cc5c1ee0479ed8f9. This patch adds back the
"device" tag before the nfs server entry so scripts can parse the
mountstats file correctly.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
commit d6b722aa383a467a43d09ee38e866981abba08ab upstream.
commit c30e92df30d7d5fe65262fbce5d1b7de675fe34e upstream.
We don't use WANT bits yet--and sending them can probably trigger a
BUG() further down.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 3d02fa29dec920c597dd7b7db608a4bc71f088ce upstream.
Yet another open-management regression:
- nfs4_file_downgrade() doesn't remove the BOTH access bit on
downgrade, so the server's idea of the stateid's access gets
out of sync with the client's. If we want to keep an O_RDWR
open in this case, we should do that in the file_put_access
logic rather than here.
- We forgot to convert v4 access to an open mode here.
This logic has proven too hard to get right. In the future we may
consider:
- reexamining the lock/openowner relationship (locks probably
don't really need to take their own references here).
- adding open upgrade/downgrade support to the vfs.
- removing the atomic operations. They're redundant as long as
this is all under some other lock.
Also, maybe some kind of additional static checking would help catch
O_/NFS4_SHARE_ACCESS confusion.
commit a043226bc140a2c1dde162246d68a67e5043e6b2 upstream.
A client that wants to execute a file must be able to read it. Read
opens over nfs are therefore implicitly allowed for executable files
even when those files are not readable.
NFSv2/v3 get this right by using a passed-in NFSD_MAY_OWNER_OVERRIDE on
read requests, but NFSv4 has gotten this wrong ever since
dc730e173785e29b297aa605786c94adaffe2544 "nfsd4: fix owner-override on
open", when we realized that the file owner shouldn't override
permissions on non-reclaim NFSv4 opens.
So we can't use NFSD_MAY_OWNER_OVERRIDE to tell nfsd_permission to allow
reads of executable files.
So, do the same thing we do whenever we encounter another weird NFS
permission nit: define yet another NFSD_MAY_* flag.
The industry's future standardization on 128-bit processors will be
motivated primarily by the need for integers with enough bits for all
the NFSD_MAY_* flags.
Reported-by: Leonardo Borda <leonardoborda@gmail.com>
commit 576163005de286bbd418fcb99cfd0971523a0c6d upstream.
The set of errors here does *not* agree with the set of errors specified
in the rfc!
While we're there, turn this macros into a function, for the usual
reasons, and move it to the one place where it's actually used.
commit 3e77246393c0a433247631a1f0e9ec98d3d78a1c upstream.
The server is returning nfserr_resource for both permanent errors and
for errors (like allocation failures) that might be resolved by retrying
later. Save nfserr_resource for the former and use delay/jukebox for
the latter.
commit 832023bffb4b493f230be901f681020caf3ed1f8 upstream.
Fan Yong <yong.fan@whamcloud.com> noticed setting
FMODE_32bithash wouldn't work with nfsd v4, as
nfsd4_readdir() checks for 32 bit cookies. However, according to RFC 3530
cookies have a 64 bit type and cookies are also defined as u64 in
'struct nfsd4_readdir'. So remove the test for >32-bit values.
Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
commit 2da956523526e440ef4f4dd174e26f5ac06fe011 upstream.
nfs_find_and_lock_request will take a reference to the nfs_page and
will then put it if the req is already locked. It's possible though
that the reference will be the last one. That put then can kick off
a whole series of reference puts:
nfs_page
nfs_open_context
dentry
inode
If the inode ends up being deleted, then the VFS will call
truncate_inode_pages. That function will try to take the page lock, but
it was already locked when migrate_page was called. The code
deadlocks.
Fix this by simply refusing the migration request if PagePrivate is
already set, indicating that the page is already associated with an
active read or write request.
We've had a customer test a backported version of this patch and
the preliminary results seem good.
Reported-by: Harshula Jayasuriya <harshula@redhat.com>
commit 3236c3e1adc0c7ec83eaff1de2d06746b7c5bb28 upstream.
commit 420e3646 allowed the kernel to reduce the number of unnecessary
commit calls by skipping the commit when there are a large number of
outstanding pages.
However, the current test in nfs_commit_unstable_pages does not handle
the edge condition properly. When ncommit == 0, then that means that the
kernel doesn't need to do anything more for the inode. The current test
though in the WB_SYNC_NONE case will return true, and the inode will end
up being marked dirty. Once that happens the inode will never be clean
until there's a WB_SYNC_ALL flush.
Fix this by immediately returning from nfs_commit_unstable_pages when
ncommit == 0.
Mike noticed this problem initially in RHEL5 (2.6.18-based kernel) which
has a backported version of 420e3646. The inode cache there was growing
very large. The inode cache was unable to be shrunk since the inodes
were all marked dirty. Calling sync() would essentially "fix" the
problem -- the WB_SYNC_ALL flush would result in the inodes all being
marked clean.
What I'm not clear on is how big a problem this is in mainline kernels
as the writeback code there is very different. Either way, it seems
incorrect to re-mark the inode dirty in this case.
Reported-by: Mike McLean <mikem@redhat.com>
syncing"
commit 59b7c05fffba030e5d9e72324691e2f99aa69b79 upstream.
This reverts commit b80c3cb628f0ebc241b02e38dd028969fb8026a2.
The reverted commit was rendered obsolete by a VFS fix: commit
5547e8aac6f71505d621a612de2fca0dd988b439 (writeback: Update dirty flags in
two steps). We now no longer need to worry about writeback_single_inode()
missing our marking the inode for COMMIT in 'do_writepages()' call.
Reverting this patch, fixes a performance regression in which the inode
would continuously get queued to the dirty list, causing the writeback
code to unnecessarily try to send a COMMIT.
Tested-by: Simon Kirby <sim@hostway.ca>
commit d8805e633e054c816c47cb6e727c81f156d9253d upstream.
epoll can acquire recursively acquire ep->mtx on multiple "struct
eventpoll"s at once in the case where one epoll fd is monitoring another
epoll fd. This is perfectly OK, since we're careful about the lock
ordering, but it causes spurious lockdep warnings. Annotate the recursion
using mutex_lock_nested, and add a comment explaining the nesting rules
for good measure.
Recent versions of systemd are triggering this, and it can also be
demonstrated with the following trivial test program:
--------------------8<--------------------
int main(void) {
int e1, e2;
struct epoll_event evt = {
.events = EPOLLIN
e1 = epoll_create1(0);
e2 = epoll_create1(0);
epoll_ctl(e1, EPOLL_CTL_ADD, e2, &evt);
return 0;
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Tested-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Nelson Elhage <nelhage@nelhage.com>
Acked-by: Jason Baron <jbaron@redhat.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Davide Libenzi <davidel@xmailserver.org>
commit 42274bb22afc3e877ae5abed787b0b09d7dede52 upstream.
We should call cifs_all_info_to_fattr in rc == 0 case only.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 94443f43404239c2a6dc4252a7cb9e77f5b1eb6e upstream.
..the length field has only 17 bits.
Acked-by: Jeff Layton <jlayton@samba.org>
commit f588c960fcaa6fa8bf82930bb819c9aca4eb9347 upstream.
Commit 6596528e391a ("hfsplus: ensure bio requests are not smaller than
the hardware sectors") changed the pointers used for volume header
allocations but failed to free the correct pointers in the error path
path of hfsplus_fill_super() and hfsplus_read_wrapper.
The second hunk came from a separate patch by Pavel Ivanov.
Reported-by: Pavel Ivanov <paivanof@gmail.com>
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
Signed-off-by: Christoph Hellwig <hch@tuxera.com>
commit 0030807c66f058230bcb20d2573bcaf28852e804 upstream
Currently we have a few issues with the way the workqueue code is used to
implement AIL pushing:
- it accidentally uses the same workqueue as the syncer action, and thus
can be prevented from running if there are enough sync actions active
in the system.
- it doesn't use the HIGHPRI flag to queue at the head of the queue of
work items
At this point I'm not confident enough in getting all the workqueue flags and
tweaks right to provide a perfectly reliable execution context for AIL
pushing, which is the most important piece in XFS to make forward progress
when the log fills.
Revert back to use a kthread per filesystem which fixes all the above issues
at the cost of having a task struct and stack around for each mounted
filesystem. In addition this also gives us much better ways to diagnose
any issues involving hung AIL pushing and removes a small amount of code.
Reported-by: Stefan Priebe <s.priebe@profihost.ag>
Tested-by: Stefan Priebe <s.priebe@profihost.ag>
commit 17b38471c3c07a49f0bbc2ecc2e92050c164e226 upstream
We need to check for pinned buffers even in .iop_pushbuf given that inode
items flush into the same buffers that may be pinned directly due operations
on the unlinked inode list operating directly on buffers. To do this add a
return value to .iop_pushbuf that tells the AIL push about this and use
the existing log force mechanisms to unpin it.
commit bc6e588a8971aa74c02e42db4d6e0248679f3738 upstream
If an item was locked we should not update xa_last_pushed_lsn and thus skip
it when restarting the AIL scan as we need to be able to lock and write it
out as soon as possible. Otherwise heavy lock contention might starve AIL
pushing too easily, especially given the larger backoff once we moved
xa_last_pushed_lsn all the way to the target lsn.
commit 1d8c95a363bf8cd4d4182dd19c01693b635311c2 upstream
xfs: use a cursor for bulk AIL insertion
Delayed logging can insert tens of thousands of log items into the
AIL at the same LSN. When the committing of log commit records
occur, we can get insertions occurring at an LSN that is not at the
end of the AIL. If there are thousands of items in the AIL on the
tail LSN, each insertion has to walk the AIL to find the correct
place to insert the new item into the AIL. This can consume large
amounts of CPU time and block other operations from occurring while
the traversals are in progress.
To avoid this repeated walk, use a AIL cursor to record
where we should be inserting the new items into the AIL without
having to repeat the walk. The cursor infrastructure already
provides this functionality for push walks, so is a simple extension
of existing code. While this will not avoid the initial walk, it
will avoid repeating it tens of thousands of times during a single
checkpoint commit.
This version includes logic improvements from Christoph Hellwig.
commit 2bcf6e970f5a88fa05dced5eeb0326e13d93c4a1 upstream
Start the periodic sync workers only after we have finished xfs_mountfs
and thus fully set up the filesystem structures. Without this we can
call into xfs_qm_sync before the quotainfo strucute is set up if the
mount takes unusually long, and probably hit other incomplete states
as well.
Also clean up the xfs_fs_fill_super error path by using consistent
label names, and removing an impossible to reach case.
Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Reviewed-by: Alex Elder <aelder@sgi.com>
commit 5b980b01212199833ee8023770fa4cbf1b85e9f4 upstream.
move it to the beginning of the loop.
Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
Cc: Josh Boyer <jwboyer@redhat.com>
commit 6596528e391ad978a6a120142cba97a1d7324cb6 upstream.
Currently all bio requests are 512 bytes, which may fail for media
whose physical sector size is larger than this. Ensure these
requests are not smaller than the block device logical block size.
BugLink: http://bugs.launchpad.net/bugs/734883
