path: root/fs
2008-05-21ocfs2 endianness fixesAl Viro
2008-05-21ecryptfs fixesAl Viro
memcpy() from userland pointer is a Bad Thing(tm) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21fix hppfs Makefile breakageAl Viro
Fallout from commit 46d7b522ebf486edbd096965d534cc6465e9e309 ("uml: move hppfs_kern.c to hppfs.c") Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: (21 commits) [CIFS] Remove debug statement Fix possible access to undefined memory region. [CIFS] Enable DFS support for Windows query path info [CIFS] Enable DFS support for Unix query path info [CIFS] add missing seq_printf to cifs_show_options for hard mount option [CIFS] add more complete mount options to cifs_show_options [CIFS] Add missing defines for DFS CIFSGetDFSRefer cleanup + dfs_referral_level_3 fixed to conform REFERRAL_V3 the MS-DFSC spec. Fixed DFS code to work with new 'build_path_from_dentry', that returns full path if share in the dfs, now. [CIFS] enable parsing for transport encryption mount parm [CIFS] Finishup DFS code [CIFS] BKL-removal: convert CIFS over to unlocked_ioctl [CIFS] suppress duplicate warning [CIFS] Fix paths when share is in DFS to include proper prefix add function to convert access flags to legacy open mode clarify return value of cifs_convert_flags() [CIFS] don't explicitly do a FindClose on rewind when directory search has ended [CIFS] cleanup old checkpatch warnings [CIFS] CIFSSMBPosixLock should return -EINVAL on error fix memory leak in CIFSFindNext ...
2008-05-21[CIFS] Remove debug statementSteve French
Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-21Fix possible access to undefined memory region.Igor Mammedov
Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-20Merge branch 'for-2.6.26' of git://linux-nfs.org/~bfields/linuxtip-x86-xsave-2008-05-26_08_54_Montip-x86-cpu-2008-05-26_08_53_MonLinus Torvalds
* 'for-2.6.26' of git://linux-nfs.org/~bfields/linux: (25 commits) svcrdma: Verify read-list fits within RPCSVC_MAXPAGES svcrdma: Change svc_rdma_send_error return type to void svcrdma: Copy transport address and arm CQ before calling rdma_accept svcrdma: Set rqstp transport address in rdma_read_complete function svcrdma: Use ib verbs version of dma_unmap svcrdma: Cleanup queued, but unprocessed I/O in svc_rdma_free svcrdma: Move the QP and cm_id destruction to svc_rdma_free svcrdma: Add reference for each SQ/RQ WR svcrdma: Move destroy to kernel thread svcrdma: Shrink scope of spinlock on RQ CQ svcrdma: Use standard Linux lists for context cache svcrdma: Simplify RDMA_READ deferral buffer management svcrdma: Remove unused READ_DONE context flags bit svcrdma: Return error from rdma_read_xdr so caller knows to free context svcrdma: Fix error handling during listening endpoint creation svcrdma: Free context on post_recv error in send_reply svcrdma: Free context on ib_post_recv error svcrdma: Add put of connection ESTABLISHED reference in rdma_cma_handler svcrdma: Fix return value in svc_rdma_send svcrdma: Fix race with dto_tasklet in svc_rdma_send ...
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) pktgen: make sure that pktgen_thread_worker has been executed [VLAN]: Propagate selected feature bits to VLAN devices drivers/atm/: remove CVS keywords vlan: Correctly handle device notifications for layered VLAN devices net: Fix call to ->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags() net_sched: cls_api: fix return value for non-existant classifiers ipsec: Use the correct ip_local_out function ipv6 addrconf: Allow infinite prefix lifetime. ipv6 route: Fix lifetime in netlink. ipv6 addrconf: Fix route lifetime setting in corner case. ndisc: Add missing strategies for per-device retrans timer/reachable time settings. ipv6: Move <linux/in6.h> from header-y to unifdef-y. l2tp: avoid skb truesize bug if headroom is increased wireless: Create 'device' symlink in sysfs wireless, airo: waitbusy() won't delay libertas: fix command timeout after firmware failure mac80211: Add RTNL version of ieee80211_iterate_active_interfaces mac80211 : Association with 11n hidden ssid ap. hostap: fix "registers" registration in procfs isdn/capi: Return proper errnos on module init. ...
2008-05-20[CIFS] Enable DFS support for Windows query path infoSteve French
Final piece for handling DFS in query_path_info, constructing a fake inode for the junction directory which the submount will cover. This handles the non-Unix (Windows etc.) code path. Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-20[CIFS] Enable DFS support for Unix query path infoSteve French
Final piece for handling DFS in unix_query_path_info, constructing a fake inode for the junction directory which the submount will cover. Acked-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes: [GFS2] Prefer strlcpy() over snprintf() [GFS2] Fix cast from unsigned int to s64 [GFS2] filesystem consistency error from do_strip
2008-05-19Merge branch 'audit.b51' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b51' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: [PATCH] list_for_each_rcu must die: audit [patch 1/1] audit_send_reply(): fix error-path memory leak [PATCH] open sessionid permissions
2008-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] return to old errno choice in mkdir() et.al. [Patch] fs/binfmt_elf.c: fix wrong return values [PATCH] get rid of leak in compat_execve() [Patch] fs/binfmt_elf.c: fix a wrong free [PATCH] avoid multiplication overflows and signedness issues for max_fds [PATCH] dup_fd() part 4 - race fix [PATCH] dup_fd() - part 3 [PATCH] dup_fd() part 2 [PATCH] dup_fd() fixes, part 1 [PATCH] take init_files to fs/file.c
2008-05-19[CIFS] add missing seq_printf to cifs_show_options for hard mount optionSteve French
Also Kari Hurtta noticed a missing check in the same function which is now fixed. CC: Kari Hurtta <hurtta+gmane@siilo.fmi.fi> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-19dlm: fix plock dev_write return valueDavid Teigland
The return value on writes to the plock device should be the number of bytes written. It was returning 0 instead when an nfs lock callback was involved. Reported-by: Nathan Straz <nstraz@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-05-19dlm: tcp_connect_to_sock should check for -EINVAL, not EINVALMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Christine Caulfield <ccaulfie@redhat.com> Cc: David Teigland <teigland@redhat.com> Cc: cluster-devel@redhat.com Signed-off-by: David Teigland <teigland@redhat.com>
2008-05-19dlm: section mismatch warning fixLeonardo Potenza
Removed the section mismatch message: WARNING: fs/dlm/dlm.o(.init.text+0x132): Section mismatch in reference from the function init_module() to the function .exit.text:dlm_netlink_exit() Since dlm_netlink_exit() is called in the init_dlm() error handling, the __exit annotation has been removed. Signed-off-by: Leonardo Potenza <lpotenza@inwind.it> Signed-off-by: David Teigland <teigland@redhat.com>
2008-05-19dlm: convert connections_lock in a mutexMatthias Kaehlcke
The semaphore connections_lock is used as a mutex. Convert it to the mutex API. Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Christine Caulfield <ccaulfie@redhat.com> Cc: David Teigland <teigland@redhat.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Teigland <teigland@redhat.com>
2008-05-18nfsd: reorder printk in do_probe_callback to avoid use-after-freeJ. Bruce Fields
We're currently dereferencing the client after we drop our reference count to it. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-05-18Merge branch 'hotfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'hotfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: SUNRPC: AUTH_SYS "machine creds" shouldn't use negative valued uid/gid nfs: make nfs4_drop_state_owner() static nfs: path_{get,put}() cleanups nfs: replace remaining __FUNCTION__ occurrences nfs/lsm: make NFSv4 set LSM mount options NFSv4: Check the return value of decode_compound_hdr_arg() nfs: fix race in nfs_dirty_request NFS: Ensure that 'noac' and/or 'actimeo=0' turn off attribute caching
2008-05-17[PATCH] open sessionid permissionsSteve Grubb
The current permissions on sessionid are a little too restrictive. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-17[CIFS] add more complete mount options to cifs_show_optionsSteve French
adds various options to cifs_show_options (displayed when you cat /proc/mounts with a cifs mount). I limited the new ones to values that are associated with the mount with the exception of "seal" (which is a per tree connection property, but I thought was important enough to show through). Eventually cifs's parse_mount_options also needs to be rewritten to use the match_token API but that would be a big enough change that I would prefer that changing parse_mount_options wait until next release. Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-16[PATCH] return to old errno choice in mkdir() et.al.Al Viro
In case when both EEXIST and EROFS would apply we used to return the former in mkdir(2) and friends. Lest anyone suspects us of being consistent, in the same situation knfsd gave clients nfs_erofs... ro-bind series had switched the syscall side of things to returning -EROFS and immediately broke an application - namely, mkdir -p. Patch restores the original behaviour... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-16[Patch] fs/binfmt_elf.c: fix wrong return valuesWANG Cong
create_elf_tables() returns 0 on success. But when strnlen_user() "fails", it returns 0 directly. So this is wrong. Signed-off-by: WANG Cong <wangcong@zeuux.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-16[PATCH] get rid of leak in compat_execve()Al Viro
Even though copy_compat_strings() doesn't cache the pages, copy_strings_kernel() and stuff indirectly called by e.g. ->load_binary() is doing that, so we need to drop the cache contents in the end. [found by WANG Cong <wangcong@zeuux.org>] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-16[Patch] fs/binfmt_elf.c: fix a wrong freeWANG Cong
In kmalloc failing path, we shouldn't free pointers in 'info', because the struct 'info' is uninitilized when kmalloc is called. And when kmalloc returns NULL, it's needless to kfree it. Signed-off-by: WANG Cong <wangcong@zeuux.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> -- Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-16[PATCH] avoid multiplication overflows and signedness issues for max_fdsAl Viro
Limit sysctl_nr_open - we don't want ->max_fds to exceed MAX_INT and we don't want size calculation for ->fd[] to overflow. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-16[PATCH] dup_fd() part 4 - race fixAl Viro
Parent _can_ be a clone task, contrary to the comment. Moreover, more files could be opened while we allocate a copy, in which case we end up copying only part into new descriptor table. Since what we get _is_ affected by all changes in the old range, we can get rather weird effects - e.g. dup2(0, 1024); close(0); in parallel with fork() resulting in child that sees the effect of close(), but not that of dup2() done just before that close(). What we need is to recalculate the open_count after having reacquired ->file_lock and if external fdtable we'd just allocated is too small for it, free the sucker and redo allocation. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-16[PATCH] dup_fd() - part 3Al Viro
merge alloc_files() into dup_fd(), leave setting newf->fdt until the end Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-16[PATCH] dup_fd() part 2Al Viro
use alloc_fdtable() instead of expand_files(), get rid of pointless grabbing newf->file_lock, kill magic in copy_fdtable() that used to be there only to skip copying when called from dup_fd(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-16[PATCH] dup_fd() fixes, part 1Al Viro
Move the sucker to fs/file.c in preparation to the rest Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-05-16byteorder: don't directly include linux/byteorder/generic.hHarvey Harrison
Use asm/byteorder.h instead. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-16[CIFS] Add missing defines for DFSSteve French
Also has minor cleanup of previous patch CC: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-16CIFSGetDFSRefer cleanup + dfs_referral_level_3 fixed to conform REFERRAL_V3 ↵Igor Mammedov
the MS-DFSC spec. Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-16nfs: make nfs4_drop_state_owner() staticAdrian Bunk
nfs4_drop_state_owner() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16nfs: path_{get,put}() cleanupsJan Blunck
Here are some more places where path_{get,put}() can be used instead of dput()/mntput() pair. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16nfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16nfs/lsm: make NFSv4 set LSM mount optionsEric Paris
NFSv3 get_sb operations call into the LSM layer to set security options passed from userspace. NFSv4 hooks were not originally added since it was reasonably late in the merge window and NFSv3 was the only thing that had regressed (v4 has never supported any LSM options) This patch makes NFSv4 call into the LSM to set security options rather than just blindly dropping them with no notice to the user as happens today. This patch was tested in a simple NFSv4 environment with the context= option and appeared to work as expected. Signed-off-by: Eric Paris <eparis@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16NFSv4: Check the return value of decode_compound_hdr_arg()Trond Myklebust
If decode_compound_hdr_arg() returns a resource error, then we cannot proceed to process the callback. Return a 'GARBAGE_ARGS' rpc-level error to the caller instead. If, however, the minor version field is incorrect, then we need to propagate the resulting NFS4ERR_MINOR_VERS_MISMATCH error back as the compound status field (setting the nops field to 0). Finally, if encode_compound_hdr_res() returns an error, we need to return an RPC_SYSTEM_ERR to the caller. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16nfs: fix race in nfs_dirty_requestFred Isaman
When called from nfs_flush_incompatible, the req is not locked, so req->wb_page might be set to NULL before it is used by PageWriteback. Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16NFS: Ensure that 'noac' and/or 'actimeo=0' turn off attribute cachingTrond Myklebust
Both the 'noac' and 'actimeo=0' mount options should ensure that attributes are not cached, however a bug in nfs_attribute_timeout() means that currently, the attributes may in fact get cached for up to one jiffy. This has been seen to cause corruption in some applications. The reason for the bug is that the time_in_range() test returns 'true' as long as the current time lies between nfsi->read_cache_jiffies and nfsi->read_cache_jiffies + nfsi->attrtimeo. In other words, if jiffies equals nfsi->read_cache_jiffies, then we still cache the attribute data. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16Fixed DFS code to work with new 'build_path_from_dentry', that returns full ↵Igor Mammedov
path if share in the dfs, now. Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-15jbd2: update transaction t_state to T_COMMIT fixMingming Cao
Updating the current transaction's t_state is protected by j_state_lock. We need to do the same when updating the t_state to T_COMMIT. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-05-15ext4: Retry block allocation if new blocks are allocated from system zone.Aneesh Kumar K.V
If the block allocator gets blocks out of system zone ext4 calls ext4_error. But if the file system is mounted with errors=continue retry block allocation. We need to mark the system zone blocks as in use to make sure retry don't pick them again System zone is the block range mapping block bitmap, inode bitmap and inode table. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-05-15[CIFS] enable parsing for transport encryption mount parmSteve French
Samba now supports transport encryption on particular exports (mounted tree ids can be encrypted for servers which support the unix extensions). This adds parsing support to cifs mount option parsing for this. Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-15[CIFS] Finishup DFS codeSteve French
Fixup GetDFSRefer to prepare for cleanup of SMB response processing Fix build warning in link.c Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-15[CIFS] BKL-removal: convert CIFS over to unlocked_ioctlSteve French
cifs_ioctl doesn't seem to need the BKL for anything, so convert it over to use unlocked_ioctl. Signed-off-by: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-15[CIFS] suppress duplicate warningSteve French
fs/cifs/dir.c: In function 'cifs_ci_compare': fs/cifs/dir.c:582: warning: passing argument 1 of 'memcpy' discards qualifiers from pointer target type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-14sysfs: remove error messages for -EEXIST caseStephen Hemminger
It is possible that the entry in sysfs already exists, one case of this is when a network device is renamed to bonding_masters. Anyway, in this case the proper error path is for device_rename to return an error code, not to generate bogus backtrace and errors. Also, to avoid possible races, the create link should be done before the remove link. This makes a device rename atomic operation like other renames. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
