commit 0e9a9a1ad619e7e987815d20262d36a2f95717ca upstream.
When trying to mount a file system which does not contain a journal,
but which does have a orphan list containing an inode which needs to
be truncated, the mount call with hang forever in
ext4_orphan_cleanup() because ext4_orphan_del() will return
immediately without removing the inode from the orphan list, leading
to an uninterruptible loop in kernel code which will busy out one of
the CPU's on the system.
This can be trivially reproduced by trying to mount the file system
found in tests/f_orphan_extents_inode/image.gz from the e2fsprogs
source tree. If a malicious user were to put this on a USB stick, and
mount it on a Linux desktop which has automatic mounts enabled, this
could be considered a potential denial of service attack. (Not a big
deal in practice, but professional paranoids worry about such things,
and have even been known to allocate CVE numbers for such problems.)
-js: This is a fix for CVE-2013-2015.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
Acked-by: Jan Kara <jack@suse.cz>
commit b6c60c8018c4e9beb2f83fc82c09f9d033766571 upstream.
Previously we only added blocks to the list to have their backrefs checked if
the level of the block is right above the one we are searching for. This is
because we want to make sure we don't add the entire path up to the root to the
lists to make sure we process things one at a time. This assumes that if any
blocks in the path to the root are going to be not checked (shared in other
words) then they will be in the level right above the current block on up. This
isn't quite right though since we can have blocks higher up the list that are
shared because they are attached to a reloc root. But we won't add this block
to be checked and then later on we will BUG_ON(!upper->checked). So instead
keep track of wether or not we've queued a block to be checked in this current
search, and if we haven't go ahead and queue it to be checked. This patch fixed
the panic I was seeing where we BUG_ON(!upper->checked). Thanks,
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
commit 047fe3605235888f3ebcda0c728cb31937eadfe6 upstream.
Dave Jones reported a kernel BUG at mm/slub.c:3474! triggered
by splice_shrink_spd() called from vmsplice_to_pipe()
commit 35f3d14dbbc5 (pipe: add support for shrinking and growing pipes)
added capability to adjust pipe->buffers.
Problem is some paths don't hold pipe mutex and assume pipe->buffers
doesn't change for their duration.
Fix this by adding nr_pages_max field in struct splice_pipe_desc, and
use it in place of pipe->buffers where appropriate.
splice_shrink_spd() loses its struct pipe_inode_info argument.
Reported-by: Dave Jones <davej@redhat.com>
Cc: Tom Herbert <therbert@google.com>
Cc: stable <stable@vger.kernel.org> # 2.6.35
Tested-by: Dave Jones <davej@redhat.com>
commit 03a1cec1f17ac1a6041996b3e40f96b5a2f90e1b upstream.
Boyd Yang reported a problem for the case that multiple threads of the same
thread group are waiting for a reponse for a permission event.
In this case it is possible that some of the threads are never woken up, even
if the response for the event has been received
(see http://marc.info/?l=linux-kernel&m=131822913806350&w=2).
The reason is that we are currently merging permission events if they belong to
the same thread group. But we are not prepared to wake up more than one waiter
for each event. We do
wait_event(group->fanotify_data.access_waitq, event->response ||
atomic_read(&group->fanotify_data.bypass_perm));
and after that
event->response = 0;
which is the reason that even if we woke up all waiters for the same event
some of them may see event->response being already set 0 again, then go back to
sleep and block forever.
With this patch we avoid that more than one thread is waiting for a response
by not merging permission events for the same thread group any more.
Reported-by: Boyd Yang <boyd.yang@gmail.com>
Signed-off-by: Lino Sanfilippo <LinoSanfilipp@gmx.de>
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Mihai Donțu <mihai.dontu@gmail.com>
commit d331a415aef98717393dda0be69b7947da08eba3 upstream.
Calls like setxattr and removexattr result in updation of ctime.
Therefore invalidate inode attributes to force a refresh.
Signed-off-by: Anand Avati <avati@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 4a4ac4eba1010ef9a804569058ab29e3450c0315 upstream.
The patch fixes a race between ftruncate(2), mmap-ed write and write(2):
1) An user makes a page dirty via mmap-ed write.
2) The user performs shrinking truncate(2) intended to purge the page.
3) Before fuse_do_setattr calls truncate_pagecache, the page goes to
writeback. fuse_writepage_locked fills FUSE_WRITE request and releases
the original page by end_page_writeback.
4) fuse_do_setattr() completes and successfully returns. Since now, i_mutex
is free.
5) Ordinary write(2) extends i_size back to cover the page. Note that
fuse_send_write_pages do wait for fuse writeback, but for another
page->index.
6) fuse_writepage_locked proceeds by queueing FUSE_WRITE request.
fuse_send_writepage is supposed to crop inarg->size of the request,
but it doesn't because i_size has already been extended back.
Moving end_page_writeback to the end of fuse_writepage_locked fixes the
race because now the fact that truncate_pagecache is successfully returned
infers that fuse_writepage_locked has already called end_page_writeback.
And this, in turn, infers that fuse_flush_writepages has already called
fuse_send_writepage, and the latter used valid (shrunk) i_size. write(2)
could not extend it because of i_mutex held by ftruncate(2).
Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com>
commit 17b7f7cf58926844e1dd40f5eb5348d481deca6a upstream.
Refuse RW mount of isofs filesystem. So far we just silently changed it
to RO mount but when the media is writeable, block layer won't notice
this change and thus will think device is used RW and will block eject
button of the drive. That is unexpected by users because for
non-writeable media eject button works just fine.
Userspace mount(8) command handles this just fine and retries mounting
with MS_RDONLY set so userspace shouldn't see any regression. Plus any
tool mounting isofs is likely confronted with the case of read-only
media where block layer already refuses to mount the filesystem without
MS_RDONLY set so our behavior shouldn't be anything new for it.
Reported-by: Hui Wang <hui.wang@canonical.com>
commit 28e8be31803b19d0d8f76216cb11b480b8a98bec upstream.
Call fiemap ioctl(2) with given start offset as well as an desired mapping
range should show extents if possible. However, we somehow figure out the
end offset of mapping via 'mapping_end -= cpos' before iterating the
extent records which would cause problems if the given fiemap length is
too small to a cluster size, e.g,
Cluster size 4096:
debugfs.ocfs2 1.6.3
Block Size Bits: 12 Cluster Size Bits: 12
The extended fiemap test utility From David:
https://gist.github.com/anonymous/6172331
# dd if=/dev/urandom of=/ocfs2/test_file bs=1M count=1000
# ./fiemap /ocfs2/test_file 4096 10
start: 4096, length: 10
File /ocfs2/test_file has 0 extents:
# Logical Physical Length Flags
^^^^^ <-- No extent is shown
In this case, at ocfs2_fiemap(): cpos == mapping_end == 1. Hence the
loop of searching extent records was not executed at all.
This patch remove the in question 'mapping_end -= cpos', and loops
until the cpos is larger than the mapping_end as usual.
File /ocfs2/test_file has 1 extents:
0: 0000000000000000 0000000056a01000 0000000006a00000 0000
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Reported-by: David Weber <wb@munzinger.de>
Tested-by: David Weber <wb@munzinger.de>
Cc: Sunil Mushran <sunil.mushran@gmail.com>
Cc: Mark Fashen <mfasheh@suse.de>
commit 73e216a8a42c0ef3d08071705c946c38fdbe12b0 upstream.
Oleksii reported that he had seen an oops similar to this:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000088
IP: [<ffffffff814dcc13>] sock_sendmsg+0x93/0xd0
PGD 0
Oops: 0000 [#1] PREEMPT SMP
Modules linked in: ipt_MASQUERADE xt_REDIRECT xt_tcpudp iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables x_tables carl9170 ath usb_storage f2fs nfnetlink_log nfnetlink md4 cifs dns_resolver hid_generic usbhid hid af_packet uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_core videodev rfcomm btusb bnep bluetooth qmi_wwan qcserial cdc_wdm usb_wwan usbnet usbserial mii snd_hda_codec_hdmi snd_hda_codec_realtek iwldvm mac80211 coretemp intel_powerclamp kvm_intel kvm iwlwifi snd_hda_intel cfg80211 snd_hda_codec xhci_hcd e1000e ehci_pci snd_hwdep sdhci_pci snd_pcm ehci_hcd microcode psmouse sdhci thinkpad_acpi mmc_core i2c_i801 pcspkr usbcore hwmon snd_timer snd_page_alloc snd ptp rfkill pps_core soundcore evdev usb_common vboxnetflt(O) vboxdrv(O)Oops#2 Part8
loop tun binfmt_misc fuse msr acpi_call(O) ipv6 autofs4
CPU: 0 PID: 21612 Comm: kworker/0:1 Tainted: G W O 3.10.1SIGN #28
Hardware name: LENOVO 2306CTO/2306CTO, BIOS G2ET92WW (2.52 ) 02/22/2013
Workqueue: cifsiod cifs_echo_request [cifs]
task: ffff8801e1f416f0 ti: ffff880148744000 task.ti: ffff880148744000
RIP: 0010:[<ffffffff814dcc13>] [<ffffffff814dcc13>] sock_sendmsg+0x93/0xd0
RSP: 0000:ffff880148745b00 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff880148745b78 RCX: 0000000000000048
RDX: ffff880148745c90 RSI: ffff880181864a00 RDI: ffff880148745b78
RBP: ffff880148745c48 R08: 0000000000000048 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff880181864a00
R13: ffff880148745c90 R14: 0000000000000048 R15: 0000000000000048
FS: 0000000000000000(0000) GS:ffff88021e200000(0000) knlGS:0000000000000000
CR2: 0000000000000088 CR3: 000000020c42c000 CR4: 00000000001407b0
Oops#2 Part7
Stack:
ffff880148745b30 ffffffff810c4af9 0000004848745b30 ffff880181864a00
ffffffff81ffbc40 0000000000000000 ffff880148745c90 ffffffff810a5aab
ffff880148745bc0 ffffffff81ffbc40 ffff880148745b60 ffffffff815a9fb8
Call Trace:
[<ffffffff810c4af9>] ? finish_task_switch+0x49/0xe0
[<ffffffff810a5aab>] ? lock_timer_base.isra.36+0x2b/0x50
[<ffffffff815a9fb8>] ? _raw_spin_unlock_irqrestore+0x18/0x40
[<ffffffff810a673f>] ? try_to_del_timer_sync+0x4f/0x70
[<ffffffff815aa38f>] ? _raw_spin_unlock_bh+0x1f/0x30
[<ffffffff814dcc87>] kernel_sendmsg+0x37/0x50
[<ffffffffa081a0e0>] smb_send_kvec+0xd0/0x1d0 [cifs]
[<ffffffffa081a263>] smb_send_rqst+0x83/0x1f0 [cifs]
[<ffffffffa081ab6c>] cifs_call_async+0xec/0x1b0 [cifs]
[<ffffffffa08245e0>] ? free_rsp_buf+0x40/0x40 [cifs]
Oops#2 Part6
[<ffffffffa082606e>] SMB2_echo+0x8e/0xb0 [cifs]
[<ffffffffa0808789>] cifs_echo_request+0x79/0xa0 [cifs]
[<ffffffff810b45b3>] process_one_work+0x173/0x4a0
[<ffffffff810b52a1>] worker_thread+0x121/0x3a0
[<ffffffff810b5180>] ? manage_workers.isra.27+0x2b0/0x2b0
[<ffffffff810bae00>] kthread+0xc0/0xd0
[<ffffffff810bad40>] ? kthread_create_on_node+0x120/0x120
[<ffffffff815b199c>] ret_from_fork+0x7c/0xb0
Code: 84 24 b8 00 00 00 4c 89 f1 4c 89 ea 4c 89 e6 48 89 df 4c 89 60 18 48 c7 40 28 00 00 00 00 4c 89 68 30 44 89 70 14 49 8b 44 24 28 <ff> 90 88 00 00 00 3d ef fd ff ff 74 10 48 8d 65 e0 5b 41 5c 41
RIP [<ffffffff814dcc13>] sock_sendmsg+0x93/0xd0
RSP <ffff880148745b00>
The client was in the middle of trying to send a frame when the
server->ssocket pointer got zeroed out. In most places, that we access
that pointer, the srv_mutex is held. There's only one spot that I see
that the server->ssocket pointer gets set and the srv_mutex isn't held.
This patch corrects that.
The upstream bug report was here:
https://bugzilla.kernel.org/show_bug.cgi?id=60557
Reported-by: Oleksii Shevchuk <alxchk@gmail.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 35dc248383bbab0a7203fca4d722875bc81ef091 upstream.
There is a nasty bug in the SCSI SG_IO ioctl that in some circumstances
leads to one process writing data into the address space of some other
random unrelated process if the ioctl is interrupted by a signal.
What happens is the following:
- A process issues an SG_IO ioctl with direction DXFER_FROM_DEV (ie the
underlying SCSI command will transfer data from the SCSI device to
the buffer provided in the ioctl)
- Before the command finishes, a signal is sent to the process waiting
in the ioctl. This will end up waking up the sg_ioctl() code:
result = wait_event_interruptible(sfp->read_wait,
(srp_done(sfp, srp) || sdp->detached));
but neither srp_done() nor sdp->detached is true, so we end up just
setting srp->orphan and returning to userspace:
srp->orphan = 1;
write_unlock_irq(&sfp->rq_list_lock);
return result; /* -ERESTARTSYS because signal hit process */
At this point the original process is done with the ioctl and
blithely goes ahead handling the signal, reissuing the ioctl, etc.
- Eventually, the SCSI command issued by the first ioctl finishes and
ends up in sg_rq_end_io(). At the end of that function, we run through:
write_lock_irqsave(&sfp->rq_list_lock, iflags);
if (unlikely(srp->orphan)) {
if (sfp->keep_orphan)
srp->sg_io_owned = 0;
else
done = 0;
srp->done = done;
write_unlock_irqrestore(&sfp->rq_list_lock, iflags);
if (likely(done)) {
/* Now wake up any sg_read() that is waiting for this
* packet.
wake_up_interruptible(&sfp->read_wait);
kill_fasync(&sfp->async_qp, SIGPOLL, POLL_IN);
kref_put(&sfp->f_ref, sg_remove_sfp);
} else {
INIT_WORK(&srp->ew.work, sg_rq_end_io_usercontext);
schedule_work(&srp->ew.work);
Since srp->orphan *is* set, we set done to 0 (assuming the
userspace app has not set keep_orphan via an SG_SET_KEEP_ORPHAN
ioctl), and therefore we end up scheduling sg_rq_end_io_usercontext()
to run in a workqueue.
- In workqueue context we go through sg_rq_end_io_usercontext() ->
sg_finish_rem_req() -> blk_rq_unmap_user() -> ... ->
bio_uncopy_user() -> __bio_copy_iov() -> copy_to_user().
The key point here is that we are doing copy_to_user() on a
workqueue -- that is, we're on a kernel thread with current->mm
equal to whatever random previous user process was scheduled before
this kernel thread. So we end up copying whatever data the SCSI
command returned to the virtual address of the buffer passed into
the original ioctl, but it's quite likely we do this copying into a
different address space!
As suggested by James Bottomley <James.Bottomley@hansenpartnership.com>,
add a check for current->mm (which is NULL if we're on a kernel thread
without a real userspace address space) in bio_uncopy_user(), and skip
the copy if we're on a kernel thread.
There's no reason that I can think of for any caller of bio_uncopy_user()
to want to do copying on a kernel thread with a random active userspace
address space.
Huge thanks to Costa Sapuntzakis <costa@purestorage.com> for the
original pointer to this bug in the sg code.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Tested-by: David Milburn <dmilburn@redhat.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
[lizf: backported to 3.4:
- Use __bio_for_each_segment() instead of bio_for_each_segment_all()]
Signed-off-by: Li Zefan <lizefan@huawei.com>
commit 44512449c0ab368889dd13ae0031fba74ee7e1d2 upstream.
NFSv4 reserves readdir cookie values 0-2 for special entries (. and ..),
but jfs allows a value of 2 for a non-special entry. This incompatibility
can result in the nfs client reporting a readdir loop.
This patch doesn't change the value stored internally, but adds one to
the value exposed to the iterate method.
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
[bwh: Backported to 3.2:
- Adjust context
- s/ctx->pos/filp->f_pos/]
Tested-by: Christian Kujau <lists@nerdbynature.de>
error detection
commit 4bf93b50fd04118ac7f33a3c2b8a0a1f9fa80bc9 upstream.
Fix the issue with improper counting number of flying bio requests for
BIO_EOPNOTSUPP error detection case.
The sb_nbio must be incremented exactly the same number of times as
complete() function was called (or will be called) because
nilfs_segbuf_wait() will call wail_for_completion() for the number of
times set to sb_nbio:
do {
wait_for_completion(&segbuf->sb_bio_event);
} while (--segbuf->sb_nbio > 0);
Two functions complete() and wait_for_completion() must be called the
same number of times for the same sb_bio_event. Otherwise,
wait_for_completion() will hang or leak.
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
error
commit 2df37a19c686c2d7c4e9b4ce1505b5141e3e5552 upstream.
Remove double call of bio_put() in nilfs_end_bio_write() for the case of
BIO_EOPNOTSUPP error detection. The issue was found by Dan Carpenter
and he suggests first version of the fix too.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit b911a6bdeef5848c468597d040e3407e0aee04ce upstream.
NFS appears to use d_obtain_alias() to create the root dentry rather than
d_make_root. This can cause 'prepend_path()' to complain that the root
has a weird name if an NFS filesystem is lazily unmounted. e.g. if
"/mnt" is an NFS mount then
{ cd /mnt; umount -l /mnt ; ls -l /proc/self/cwd; }
will cause a WARN message like
WARNING: at /home/git/linux/fs/dcache.c:2624 prepend_path+0x1d7/0x1e0()
Root dentry has weird name <>
to appear in kernel logs.
So change d_obtain_alias() to use "/" rather than "" as the anonymous
name.
Signed-off-by: NeilBrown <neilb@suse.de>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
[bwh: Backported to 3.2: use named initialisers instead of QSTR_INIT()]
commit b2a3ad9ca502169fc4c11296fa20f56059c7c031 upstream.
gcc-4.7.0 has started throwing these warnings when building cifs.ko.
CC [M] fs/cifs/cifssmb.o
fs/cifs/cifssmb.c: In function ‘CIFSSMBSetCIFSACL’:
fs/cifs/cifssmb.c:3905:9: warning: array subscript is above array bounds [-Warray-bounds]
fs/cifs/cifssmb.c: In function ‘CIFSSMBSetFileInfo’:
fs/cifs/cifssmb.c:5711:8: warning: array subscript is above array bounds [-Warray-bounds]
fs/cifs/cifssmb.c: In function ‘CIFSSMBUnixSetFileInfo’:
fs/cifs/cifssmb.c:6001:25: warning: array subscript is above array bounds [-Warray-bounds]
This patch cleans up the code a bit by using the offsetof macro instead
of the funky "&pSMB->hdr.Protocol" construct.
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 776164c1faac4966ab14418bb0922e1820da1d19 upstream.
debugfs_remove_recursive() is wrong,
1. it wrongly assumes that !list_empty(d_subdirs) means that this
dir should be removed.
This is not that bad by itself, but:
2. if d_subdirs does not becomes empty after __debugfs_remove()
it gives up and silently fails, it doesn't even try to remove
other entries.
However ->d_subdirs can be non-empty because it still has the
already deleted !debugfs_positive() entries.
3. simple_release_fs() is called even if __debugfs_remove() fails.
Suppose we have
dir1/
dir2/
file2
file1
and someone opens dir1/dir2/file2.
Now, debugfs_remove_recursive(dir1/dir2) succeeds, and dir1/dir2 goes
away.
But debugfs_remove_recursive(dir1) silently fails and doesn't remove
this directory. Because it tries to delete (the already deleted)
dir1/dir2/file2 again and then fails due to "Avoid infinite loop"
logic.
Test-case:
#!/bin/sh
cd /sys/kernel/debug/tracing
echo 'p:probe/sigprocmask sigprocmask' >> kprobe_events
sleep 1000 < events/probe/sigprocmask/id &
echo -n >| kprobe_events
[ -d events/probe ] && echo "ERR!! failed to rm probe"
And after that it is not possible to create another probe entry.
With this patch debugfs_remove_recursive() skips !debugfs_positive()
files although this is not strictly needed. The most important change
is that it does not try to make ->d_subdirs empty, it simply scans
the whole list(s) recursively and removes as much as possible.
Link: http://lkml.kernel.org/r/20130726151256.GC19472@redhat.com
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit de1e0c40aceb9d5bff09c3a3b97b2f1b178af53f upstream.
The ->reserved field isn't cleared so we leak one byte of stack
information to userspace.
Cc: Eric Paris <eparis@redhat.com>
Cc: Luis Henriques <luis.henriques@canonical.com>
commit acfec9a5a892f98461f52ed5770de99a3e571ae2 upstream.
Eric Sandeen has found a nasty livelock in sget() - take a mount(2) about
to fail. The superblock is on ->fs_supers, ->s_umount is held exclusive,
->s_active is 1. Along comes two more processes, trying to mount the same
thing; sget() in each is picking that superblock, bumping ->s_count and
trying to grab ->s_umount. ->s_active is 3 now. Original mount(2)
finally gets to deactivate_locked_super() on failure; ->s_active is 2,
superblock is still ->fs_supers because shutdown will *not* happen until
->s_active hits 0. ->s_umount is dropped and now we have two processes
chasing each other:
s_active = 2, A acquired ->s_umount, B blocked
A sees that the damn thing is stillborn, does deactivate_locked_super()
s_active = 1, A drops ->s_umount, B gets it
A restarts the search and finds the same superblock. And bumps it ->s_active.
s_active = 2, B holds ->s_umount, A blocked on trying to get it
... and we are in the earlier situation with A and B switched places.
The root cause, of course, is that ->s_active should not grow until we'd
got MS_BORN. Then failing ->mount() will have deactivate_locked_super()
shut the damn thing down. Fortunately, it's easy to do - the key point
is that grab_super() is called only for superblocks currently on ->fs_supers,
so it can bump ->s_count and grab ->s_umount first, then check MS_BORN and
bump ->s_active; we must never increment ->s_count for superblocks past
->kill_sb(), but grab_super() is never called for those.
The bug is pretty old; we would've caught it by now, if not for accidental
exclusion between sget() for block filesystems; the things like cgroup or
e.g. mtd-based filesystems don't have anything of that sort, so they get
bitten. The right way to deal with that is obviously to fix sget()...
commit 1c327d962fc420aea046c16215a552710bde8231 upstream.
In nlmsvc_retry_blocked, the check that the list is non-empty and acquiring
the pointer of the first entry is unprotected by any lock. This allows a rare
race condition when there is only one entry on the list. A function such as
nlmsvc_grant_callback() can be called, which will temporarily remove the entry
from the list. Between the list_empty() and list_entry(),the list may become
empty, causing an invalid pointer to be used as an nlm_block, leading to a
possible crash.
This patch adds the nlm_block_lock around these calls to prevent concurrent
use of the nlm_blocked list.
This was a regression introduced by
f904be9cc77f361d37d71468b13ff3d1a1823dea "lockd: Mostly remove BKL from
the server".
Signed-off-by: David Jeffery <djeffery@redhat.com>
Cc: Bryan Schumaker <bjschuma@netapp.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit a5faeaf9109578e65e1a32e2a3e76c8b47e7dcb6 upstream.
Code in blkdev.c moves a device inode to default_backing_dev_info when
the last reference to the device is put and moves the device inode back
to its bdi when the first reference is acquired. This includes moving to
wb.b_dirty list if the device inode is dirty. The code however doesn't
setup timer to wake corresponding flusher thread and while wb.b_dirty
list is non-empty __mark_inode_dirty() will not set it up either. Thus
periodic writeback is effectively disabled until a sync(2) call which can
lead to unexpected data loss in case of crash or power failure.
Fix the problem by setting up a timer for periodic writeback in case we
add the first dirty inode to wb.b_dirty list in bdev_inode_switch_bdi().
Reported-by: Bert De Jonghe <Bert.DeJonghe@amplidata.com>
commit 8af8eecc1331dbf5e8c662022272cf667e213da5 upstream.
The arithmetics adding delalloc blocks to the number of used blocks in
ext4_getattr() can easily overflow on 32-bit archs as we first multiply
number of blocks by blocksize and then divide back by 512. Make the
arithmetics more clever and also use proper type (unsigned long long
instead of unsigned long).
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit a60697f411eb365fb09e639e6f183fe33d1eb796 upstream.
On 32-bit architectures with 32-bit sector_t computation of data offset
in ext4_xattr_fiemap() can overflow resulting in reporting bogus data
location. Fix the problem by typing block number to proper type before
shifting.
commit ef962df057aaafd714f5c22ba3de1be459571fdf upstream.
Inlined xattr shared free space of inode block with inlined data or data
extent record, so the size of the later two should be adjusted when
inlined xattr is enabled. See ocfs2_xattr_ibody_init(). But this isn't
done well when reflink. For inode with inlined data, its max inlined
data size is adjusted in ocfs2_duplicate_inline_data(), no problem. But
for inode with data extent record, its record count isn't adjusted. Fix
it, or data extent record and inlined xattr may overwrite each other,
then cause data corruption or xattr failure.
One panic caused by this bug in our test environment is the following:
kernel BUG at fs/ocfs2/xattr.c:1435!
invalid opcode: 0000 [#1] SMP
Pid: 10871, comm: multi_reflink_t Not tainted 2.6.39-300.17.1.el5uek #1
RIP: ocfs2_xa_offset_pointer+0x17/0x20 [ocfs2]
RSP: e02b:ffff88007a587948 EFLAGS: 00010283
RAX: 0000000000000000 RBX: 0000000000000010 RCX: 00000000000051e4
RDX: ffff880057092060 RSI: 0000000000000f80 RDI: ffff88007a587a68
RBP: ffff88007a587948 R08: 00000000000062f4 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000010
R13: ffff88007a587a68 R14: 0000000000000001 R15: ffff88007a587c68
FS: 00007fccff7f06e0(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000000015cf000 CR3: 000000007aa76000 CR4: 0000000000000660
Process multi_reflink_t
Call Trace:
ocfs2_xa_reuse_entry+0x60/0x280 [ocfs2]
ocfs2_xa_prepare_entry+0x17e/0x2a0 [ocfs2]
ocfs2_xa_set+0xcc/0x250 [ocfs2]
ocfs2_xattr_ibody_set+0x98/0x230 [ocfs2]
__ocfs2_xattr_set_handle+0x4f/0x700 [ocfs2]
ocfs2_xattr_set+0x6c6/0x890 [ocfs2]
ocfs2_xattr_user_set+0x46/0x50 [ocfs2]
generic_setxattr+0x70/0x90
__vfs_setxattr_noperm+0x80/0x1a0
vfs_setxattr+0xa9/0xb0
setxattr+0xc3/0x120
sys_fsetxattr+0xa8/0xd0
system_call_fastpath+0x16/0x1b
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Jie Liu <jeff.liu@oracle.com>
Acked-by: Joel Becker <jlbec@evilplan.org>
Cc: Mark Fasheh <mfasheh@suse.com>
commit 64cb927371cd2ec43758d8a094a003d27bc3d0dc upstream.
Both ext3 and ext4 htree_dirblock_to_tree() is just filling the
in-core rbtree for use by call_filldir(). All updates of ->f_pos are
done by the latter; bumping it here (on error) is obviously wrong - we
might very well have it nowhere near the block we'd found an error in.
commit 39c04153fda8c32e85b51c96eb5511a326ad7609 upstream.
Once we decrement transaction->t_updates, if this is the last handle
holding the transaction from closing, and once we release the
t_handle_lock spinlock, it's possible for the transaction to commit
and be released. In practice with normal kernels, this probably won't
happen, since the commit happens in a separate kernel thread and it's
unlikely this could all happen within the space of a few CPU cycles.
On the other hand, with a real-time kernel, this could potentially
happen, so save the tid found in transaction->t_tid before we release
t_handle_lock. It would require an insane configuration, such as one
where the jbd2 thread was set to a very high real-time priority,
perhaps because a high priority real-time thread is trying to read or
write to a file system. But some people who use real-time kernels
have been known to do insane things, including controlling
laser-wielding industrial robots. :-)
commit 247500820ebd02ad87525db5d9b199e5b66f6636 upstream.
A freebsd NFSv4.0 client was getting rare IO errors expanding a tarball.
A network trace showed the server returning BAD_XDR on the final getattr
of a getattr+write+getattr compound. The final getattr started on a
page boundary.
I believe the Linux client ignores errors on the post-write getattr, and
that that's why we haven't seen this before.
Reported-by: Rick Macklem <rmacklem@uoguelph.ca>
commit 3ebacb05044f82c5f0bb456a894eb9dc57d0ed90 upstream.
The test if bitmap access is out of bound could errorneously pass if the
device size is divisible by 16384 sectors and we are asking for one bitmap
after the end.
Check for invalid size in the superblock. Invalid size could cause integer
overflows in the rest of the code.
Signed-off-by: Mikulas Patocka <mpatocka@artax.karlin.mff.cuni.cz>
commit 605c912bb843c024b1ed173dc427cd5c08e5d54d upstream.
Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no
mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are
in the middle of 'ubifs_readdir()'.
This means that 'file->private_data' can be freed while 'ubifs_readdir()' uses
it, and this is a very bad bug: not only 'ubifs_readdir()' can return garbage,
but this may corrupt memory and lead to all kinds of problems like crashes an
security holes.
This patch fixes the problem by using the 'file->f_version' field, which
'->llseek()' always unconditionally sets to zero. We set it to 1 in
'ubifs_readdir()' and whenever we detect that it became 0, we know there was a
seek and it is time to clear the state saved in 'file->private_data'.
I tested this patch by writing a user-space program which runds readdir and
seek in parallell. I could easily crash the kernel without these patches, but
could not crash it with these patches.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 33f1a63ae84dfd9ad298cf275b8f1887043ced36 upstream.
First of all, this means that 'file->private_data' can be freed while
'ubifs_readdir()' uses it. But this particular patch does not fix the problem.
This patch is only a preparation, and the fix will follow next.
In this patch we make 'ubifs_readdir()' stop using 'file->f_pos' directly,
because 'file->f_pos' can be changed by '->llseek()' at any point. This may
lead 'ubifs_readdir()' to returning inconsistent data: directory entry names
may correspond to incorrect file positions.
So here we introduce a local variable 'pos', read 'file->f_pose' once at very
the beginning, and then stick to 'pos'. The result of this is that when
'ubifs_dir_llseek()' changes 'file->f_pos' while we are in the middle of
'ubifs_readdir()', the latter "wins".
commit 2976b10f05bd7f6dab9f9e7524451ddfed656a89 upstream.
There was a a bug in setup_new_exec(), whereby
the test to disabled perf monitoring was not
correct because the new credentials for the
process were not yet committed and therefore
the get_dumpable() test was never firing.
The patch fixes the problem by moving the
perf_event test until after the credentials
are committed.
Signed-off-by: Stephane Eranian <eranian@google.com>
Tested-by: Jiri Olsa <jolsa@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit 92a49fb0f79f3300e6e50ddf56238e70678e4202 upstream.
Different versions of glibc are broken in different ways, but the short of
it is that for the time being, frsize should == bsize, and be used as the
multiple for the blocks, free, and available fields. This mirrors what is
done for NFS. The previous reporting of the page size for frsize meant
that newer glibc and df would report a very small value for the fs size.
Fixes http://tracker.ceph.com/issues/3793.
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Greg Farnum <greg@inktank.com>
commit 73aaa22d5ffb2630456bac2f9a4ed9b81d0d7271 upstream.
This patch fixes races uncovered by xfstests testcase 068.
One race is the result of jfs_sync() trying to write a sync point to the
journal after it has been frozen (or possibly in the process). Since
freezing sync's the journal, there is no need to write a sync point so
we simply want to return.
The second involves jfs_write_inode() being called on a deleted inode.
It calls jfs_flush_journal which is held up by the jfs_commit thread
doing the final iput on the same deleted inode, which itself is
waiting for the I_SYNC flag to be cleared. jfs_write_inode need not
do anything when i_nlink is zero, which is the easy fix.
Reported-by: Michael L. Semon <mlsemon35@gmail.com>
commit 166faf21bd14bc5c5295a44874bf7f3930c30b20 upstream.
Consider the case where we have a very short ip= string in the original
mount options, and when we chase a referral we end up with a very long
IPv6 address. Be sure to allow for that possibility when estimating the
size of the string to allocate.
commit 136e8770cd5d1fe38b3c613100dd6dc4db6d4fa6 upstream.
nilfs2: fix issue of nilfs_set_page_dirty for page at EOF boundary
DESCRIPTION:
There are use-cases when NILFS2 file system (formatted with block size
lesser than 4 KB) can be remounted in RO mode because of encountering of
"broken bmap" issue.
The issue was reported by Anthony Doggett <Anthony2486@interfaces.org.uk>:
"The machine I've been trialling nilfs on is running Debian Testing,
Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc
version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.35-2), but I've
also reproduced it (identically) with Debian Unstable amd64 and Debian
Experimental (using the 3.8-trunk kernel). The problematic partitions
were formatted with "mkfs.nilfs2 -b 1024 -B 8192"."
SYMPTOMS:
(1) System log contains error messages likewise:
[63102.496756] nilfs_direct_assign: invalid pointer: 0
[63102.496786] NILFS error (device dm-17): nilfs_bmap_assign: broken bmap (inode number=28)
[63102.496798]
[63102.524403] Remounting filesystem read-only
(2) The NILFS2 file system is remounted in RO mode.
REPRODUSING PATH:
(1) Create volume group with name "unencrypted" by means of vgcreate utility.
(2) Run script (prepared by Anthony Doggett <Anthony2486@interfaces.org.uk>):
----------------[BEGIN SCRIPT]--------------------
VG=unencrypted
lvcreate --size 2G --name ntest $VG
mkfs.nilfs2 -b 1024 -B 8192 /dev/mapper/$VG-ntest
mkdir /var/tmp/n
mkdir /var/tmp/n/ntest
mount /dev/mapper/$VG-ntest /var/tmp/n/ntest
mkdir /var/tmp/n/ntest/thedir
cd /var/tmp/n/ntest/thedir
sleep 2
date
darcs init
sleep 2
dmesg|tail -n 5
date
darcs whatsnew || true
date
sleep 2
dmesg|tail -n 5
----------------[END SCRIPT]--------------------
REPRODUCIBILITY: 100%
INVESTIGATION:
As it was discovered, the issue takes place during segment
construction after executing such sequence of user-space operations:
open("_darcs/index", O_RDWR|O_CREAT|O_NOCTTY, 0666) = 7
fstat(7, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
ftruncate(7, 60)
The error message "NILFS error (device dm-17): nilfs_bmap_assign: broken
bmap (inode number=28)" takes place because of trying to get block
number for third block of the file with logical offset #3072 bytes. As
it is possible to see from above output, the file has 60 bytes of the
whole size. So, it is enough one block (1 KB in size) allocation for
the whole file. Trying to operate with several blocks instead of one
takes place because of discovering several dirty buffers for this file
in nilfs_segctor_scan_file() method.
The root cause of this issue is in nilfs_set_page_dirty function which
is called just before writing to an mmapped page.
When nilfs_page_mkwrite function handles a page at EOF boundary, it
fills hole blocks only inside EOF through __block_page_mkwrite().
The __block_page_mkwrite() function calls set_page_dirty() after filling
hole blocks, thus nilfs_set_page_dirty function (=
a_ops->set_page_dirty) is called. However, the current implementation
of nilfs_set_page_dirty() wrongly marks all buffers dirty even for page
at EOF boundary.
As a result, buffers outside EOF are inconsistently marked dirty and
queued for write even though they are not mapped with nilfs_get_block
function.
FIX:
This modifies nilfs_set_page_dirty() not to mark hole blocks dirty.
Thanks to Vyacheslav Dubeyko for his effort on analysis and proposals
for this issue.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Reported-by: Anthony Doggett <Anthony2486@interfaces.org.uk>
Reported-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Vyacheslav Dubeyko <slava@dubeyko.com>
commit b4ca2b4b577c3530e34dcfaafccb2cc680ce95d1 upstream.
Last time we found there is lock/unlock bug in ocfs2_file_aio_write, and
then we did a thorough search for all lock resources in
ocfs2_inode_info, including rw, inode and open lockres and found this
bug. My kernel version is 3.0.13, and it is also in the lastest version
3.9. In ocfs2_fiemap, once ocfs2_get_clusters_nocache failed, it should
goto out_unlock instead of out, because we need release buffer head, up
read alloc sem and unlock inode.
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Acked-by: Sunil Mushran <sunil.mushran@gmail.com>
commit 7b92d03c3239f43e5b86c9cc9630f026d36ee995 upstream.
Intermediate value of fat_clusters can be overflowed on 32bits arch.
Reported-by: Krzysztof Strasburger <strasbur@chkw386.ch.pwr.wroc.pl>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
commit c2b93e0699723700f886ce17bb65ffd771195a6d upstream.
It's generally not safe to reset the inode ops once they've been set. In
the case where the inode was originally thought to be a directory and
then later found to be a DFS referral, this can lead to an oops when we
try to trigger an inode op on it after changing the ops to the blank
referral operations.
Reported-and-Tested-by: Sachin Prabhu <sprabhu@redhat.com>
commit 03b71c6ca6286625d8f1ed44aabab9b5bf5dac10 upstream.
The search ioctl skips items that are too large for a result buffer, but
inline items of a certain size occuring before any search result is
found would trigger an overflow and stop the search entirely.
Bug: https://bugzilla.kernel.org/show_bug.cgi?id=57641
Signed-off-by: Gabriel de Perthuis <g2p.code+btrfs@gmail.com>
commit e6155736ad76b2070652745f9e54cdea3f0d8567 upstream.
In the case where we are allocating for a non-extent file,
we must limit the groups we allocate from to those below
2^32 blocks, and ext4_mb_regular_allocator() attempts to
do this initially by putting a cap on ngroups for the
subsequent search loop.
However, the initial target group comes in from the
allocation context (ac), and it may already be beyond
the artificially limited ngroups. In this case,
the limit
if (group == ngroups)
group = 0;
at the top of the loop is never true, and the loop will
run away.
Catch this case inside the loop and reset the search to
start at group 0.
[sandeen@redhat.com: add commit msg & comments]
Signed-off-by: Lachlan McIlroy <lmcilroy@redhat.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
commit ce8a5dbdf9e709bdaf4618d7ef8cceb91e8adc69 upstream.
When checking if an autofs mount point is busy it isn't sufficient to
only check if it's a mount point.
For example, if the mount of an offset mountpoint in a tree is denied
for this host by its export and the dentry becomes a process working
directory the check incorrectly returns the mount as not in use at
expire.
This can happen since the default when mounting within a tree is
nostrict, which means ingnore mount fails on mounts within the tree and
continue. The nostrict option is meant to allow mounting in this case.
Signed-off-by: Ian Kent <raven@themaw.net>
commit 7f3e3c7cfcec148ccca9c0dd2dbfd7b00b7ac10f upstream.
Fox the Kconfig documentation for CONFIG_EXT4_DEBUG to match the
change made by commit a0b30c1229: ext4: use module parameters instead
of debugfs for mballoc_debug
commit bf8d909705e9d9bac31d9b8eac6734d2b51332a7 upstream.
The seconds field of an nfstime4 structure is 64bit, but we are assuming
that the first 32bits are zero-filled. So if the client tries to set
atime to a value before the epoch (touch -t 196001010101), then the
server will save the wrong value on disk.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
commit 0c7c3e67ab91ec6caa44bdf1fc89a48012ceb0c5 upstream.
Don't actually close any opens until we don't need them at all.
This means being left with write access when it's not really necessary,
but that's better than putting a file that might still have posix locks
held on it, as we have been.
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
commit 8b6cc4d6f841d31f72fe7478453759166d366274 upstream.
A server shouldn't normally return NFS4ERR_GRACE if the client holds a
delegation, since no conflicting lock reclaims can be granted, however
the spec does not require the server to grant the open in this
instance
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 1dfd89af8697a299e7982ae740d4695ecd917eef upstream.
After a server reboot, the reclaimer thread will recover all the existing
locks. For locks that are blocked, however, it will change the value
of block->b_status to nlm_lck_denied_grace_period in order to signal that
they need to wake up and resend the original blocking lock request.
Due to a bug, however, the block->b_status never gets reset after the
blocked locks have been woken up, and so the process goes into an
infinite loop of resends until the blocked lock is satisfied.
Reported-by: Marc Eshel <eshel@us.ibm.com>
commit ec686c9239b4d472052a271c505d04dae84214cc upstream.
There is a kernel memory leak observed when the proc file
/proc/fs/fscache/stats is read.
The reason is that in fscache_stats_open, single_open is called and the
respective release function is not called during release. Hence fix
with correct release function - single_release().
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=57101
Signed-off-by: Anurup m <anurup.m@huawei.com>
Cc: shyju pv <shyju.pv@huawei.com>
Cc: Sanil kumar <sanil.kumar@huawei.com>
Cc: Nataraj m <nataraj.m@huawei.com>
Cc: Li Zefan <lizefan@huawei.com>
commit 4bc4bee4595662d8bff92180d5c32e3313a704b0 upstream.
While trying to track down a tree log replay bug I noticed that fsck was always
complaining about nbytes not being right for our fsynced file. That is because
the new fsync stuff doesn't wait for ordered extents to complete, so the inodes
nbytes are not necessarily updated properly when we log it. So to fix this we
need to set nbytes to whatever it is on the inode that is on disk, so when we
replay the extents we can just add the bytes that are being added as we replay
the extent. This makes it work for the case that we have the wrong nbytes or
the case that we logged everything and nbytes is actually correct. With this
I'm no longer getting nbytes errors out of btrfsck.
Signed-off-by: Lingzhu Xiang <lxiang@redhat.com>
Reviewed-by: CAI Qian <caiqian@redhat.com>
This reverts commit 991f76f837bf22c5bb07261cfd86525a0a96650c in Linus'
tree which is f366c8f271888f48e15cc7c0ab70f184c220c8a4 in
linux-stable.git
It depends on ef3d0fd27e90f ("vfs: do (nearly) lockless generic_file_llseek")
which is available only in 3.2+.
When applied on 3.0 codebase, it causes A-A deadlock, whenever anyone does
seek() on sysfs, as both generic_file_llseek() and sysfs_dir_llseek() obtain
i_mutex.
Cc: Jiri Slaby <jslaby@suse.cz>
commit 12f267a20aecf8b84a2a9069b9011f1661c779b4 upstream.
Change a u32 to loff_t hfsplus_file_truncate().
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
Replace C division operators with div64_u64 for divides introduced in:
commit 503f4bdcc078e7abee273a85ce322de81b18a224
ext4: use atomic64_t for the per-flexbg free_clusters count
Specific to the 3.0-stable backport of the upstream patch.
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
Cc: Lukas Czerner <lczerner@redhat.com>
