commit af24ee9ea8d532e16883251a6684dfa1be8eec29 upstream.
Commit 493f3358cb289ccf716c5a14fa5bb52ab75943e5 added this call to
xfs_fs_geometry() in order to avoid passing kernel stack data back
to user space:
+ memset(geo, 0, sizeof(*geo));
Unfortunately, one of the callers of that function passes the
address of a smaller data type, cast to fit the type that
xfs_fs_geometry() requires. As a result, this can happen:
Kernel panic - not syncing: stack-protector: Kernel stack is corrupted
in: f87aca93
Pid: 262, comm: xfs_fsr Not tainted 2.6.38-rc6-493f3358cb2+ #1
Call Trace:
[<c12991ac>] ? panic+0x50/0x150
[<c102ed71>] ? __stack_chk_fail+0x10/0x18
[<f87aca93>] ? xfs_ioc_fsgeometry_v1+0x56/0x5d [xfs]
Fix this by fixing that one caller to pass the right type and then
copy out the subset it is interested in.
Note: This patch is an alternative to one originally proposed by
Eric Sandeen.
Reported-by: Jeffrey Hundstad <jeffrey.hundstad@mnsu.edu>
Signed-off-by: Alex Elder <aelder@sgi.com>
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
Tested-by: Jeffrey Hundstad <jeffrey.hundstad@mnsu.edu>
commit 114279be2120a916e8a04feeb2ac976a10016f2f upstream.
Note: this patch targets 2.6.37 and tries to be as simple as possible.
That is why it adds more copy-and-paste horror into fs/compat.c and
uglifies fs/exec.c, this will be cleanuped later.
compat_copy_strings() plays with bprm->vma/mm directly and thus has
two problems: it lacks the RLIMIT_STACK check and argv/envp memory
is not visible to oom killer.
Export acct_arg_size() and get_arg_page(), change compat_copy_strings()
to use get_arg_page(), change compat_do_execve() to do acct_arg_size(0)
as do_execve() does.
Add the fatal_signal_pending/cond_resched checks into compat_count() and
compat_copy_strings(), this matches the code in fs/exec.c and certainly
makes sense.
Cc: Moritz Muehlenhoff <jmm@debian.org>
commit 3c77f845722158206a7209c45ccddc264d19319c upstream.
Brad Spengler published a local memory-allocation DoS that
evades the OOM-killer (though not the virtual memory RLIMIT):
http://www.grsecurity.net/~spender/64bit_dos.c
execve()->copy_strings() can allocate a lot of memory, but
this is not visible to oom-killer, nobody can see the nascent
bprm->mm and take it into account.
With this patch get_arg_page() increments current's MM_ANONPAGES
counter every time we allocate the new page for argv/envp. When
do_execve() succeds or fails, we change this counter back.
Technically this is not 100% correct, we can't know if the new
page is swapped out and turn MM_ANONPAGES into MM_SWAPENTS, but
I don't think this really matters and everything becomes correct
once exec changes ->mm or fails.
Reported-by: Brad Spengler <spender@grsecurity.net>
Reviewed-and-discussed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit 954032d2527f2fce7355ba70709b5e143d6b686f upstream.
This was noticed by users who performed more than 2^32 lock operations
and hence made this counter overflow (eventually leading to
use-after-free's). Setting rq_client to NULL here means that it won't
later get auth_domain_put() when it should be.
Appears to have been introduced in 2.5.42 by "[PATCH] kNFSd: Move auth
domain lookup into svcauth" which moved most of the rq_client handling
to common svcauth code, but left behind this one line.
Cc: Neil Brown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 5b41395fcc0265fc9f193aef9df39ce49d64677c upstream.
When writing a contiguous set of blocks, two indirect blocks could be
needed depending on how the blocks are aligned, so we need to increase
the number of credits needed by one.
[ Also fixed a another bug which could further underestimate the
number of journal credits needed by 1; the code was using integer
division instead of DIV_ROUND_UP() -- tytso]
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 44cff8a9ee8a974f9e931df910688e7fc1f0b0f9 upstream.
Handle the rare case where a directory metadata block is uncompressed and
corrupted, leading to a kernel oops in directory scanning (memcpy).
Normally corruption is detected at the decompression stage and dealt with
then, however, this will not happen if:
- metadata isn't compressed (users can optionally request no metadata
compression), or
- the compressed metadata block was larger than the original, in which
case the uncompressed version was used, or
- the data was corrupt after decompression
This patch fixes this by adding some sanity checks against known maximum
values.
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
commit 272b62c1f0f6f742046e45b50b6fec98860208a0 upstream.
When a hole spans across page boundaries, the next write forces
a read of the block. This could end up reading existing garbage
data from the disk in ocfs2_map_page_blocks. This leads to
non-zero holes. In order to avoid this, mark the writes as new
when the holes span across page boundaries.
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de>
Signed-off-by: jlbec <jlbec@evilplan.org>
commit b03f24567ce7caf2420b8be4c6eb74c191d59a91 upstream.
There's no reason to write quota info in dquot_commit(). The writing is a
relict from the old days when we didn't have dquot_acquire() and
dquot_release() and thus dquot_commit() could have created / removed quota
structures from the file. These days dquot_commit() only updates usage counters
/ limits in quota structure and thus there's no need to write quota info.
This also fixes an issue with journaling filesystem which didn't reserve
enough space in the transaction for write of quota info (it could have been
dirty at the time of dquot_commit() because of a race with other operation
changing it).
Reported-and-tested-by: Lukas Czerner <lczerner@redhat.com>
commit 7da6443aca9be29c6948dcbd636ad50154d0bc0c upstream.
This patch fixes a debugging failure with which looks like this:
UBIFS error (pid 32313): dbg_check_space_info: free space changed from 6019344 to 6022654
The reason for this failure is described in the comment this patch adds
to the code. But in short - 'c->freeable_cnt' may be different before
and after re-mounting, and this is normal. So the debugging code should
make sure that free space calculations do not depend on 'c->freeable_cnt'.
A similar issue has been reported here:
http://lists.infradead.org/pipermail/linux-mtd/2011-April/034647.html
This patch should fix it.
For the -stable guys: this patch is only relevant for kernels 2.6.30
onwards.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit 54acbaaa523ca0bd284a18f67ad213c379679e86 upstream.
Thanks to coverity which spotted that UBIFS will oops if 'kmalloc()'
in 'read_pnode()' fails and we dereference a NULL 'pnode' pointer
when we 'goto out'.
commit 8b229c76765816796eec7ccd428f03bd8de8b525 upstream.
This fix makes the 'dbg_check_old_index()' function return
immediately if debugging is disabled, instead of executing
incorrect 'goto out' which causes UBIFS to:
1. Allocate memory
2. Read the flash
On every commit. OK, we do not commit that often, but it is
still silly to do unneeded I/O anyway.
Credits to coverity for spotting this silly issue.
commit 08fe4db170b4193603d9d31f40ebaf652d07ac9c upstream.
root_item->flags and root_item->byte_limit are not initialized when
a subvolume is created. This bug is not revealed until we added
readonly snapshot support - now you mount a btrfs filesystem and you
may find the subvolumes in it are readonly.
To work around this problem, we steal a bit from root_item->inode_item->flags,
and use it to indicate if those fields have been properly initialized.
When we read a tree root from disk, we check if the bit is set, and if
not we'll set the flag and initialize the two fields of the root item.
Reported-by: Andreas Philipp <philipp.andreas@gmail.com>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Tested-by: Andreas Philipp <philipp.andreas@gmail.com>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
commit 34094537943113467faee98fe67c8a3d3f9a0a8b upstream.
From the result of a function test of mmap, mmap write to shared pages
turned out to be broken for hole blocks. It doesn't write out filled
blocks and the data will be lost after umount. This is due to a bug
that the target file is not queued for log writer when filling hole
blocks.
Also, nilfs_page_mkwrite function exits normal code path even after
successfully filled hole blocks due to a change of block_page_mkwrite
function; just after nilfs was merged into the mainline,
block_page_mkwrite() started to return VM_FAULT_LOCKED instead of zero
by the patch "mm: close page_mkwrite races" (commit:
b827e496c893de0c). The current nilfs_page_mkwrite() is not handling
this value properly.
This corrects nilfs_page_mkwrite() and will resolve the data loss
problem in mmap write.
[This should be applied to every kernel since 2.6.30 but a fix is
needed for 2.6.37 and prior kernels]
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
commit c4d0c3b097f7584772316ee4d64a09fe0e4ddfca upstream.
The FSGEOMETRY_V1 ioctl (and its compat equivalent) calls out to
xfs_fs_geometry() with a version number of 3. This code path does not
fill in the logsunit member of the passed xfs_fsop_geom_t, leading to
the leaking of four bytes of uninitialized stack data to potentially
unprivileged callers.
v2 switches to memset() to avoid future issues if structure members
change, on suggestion of Dave Chinner.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Reviewed-by: Eugene Teo <eugeneteo@kernel.org>
commit 1821df040ac3cd6a57518739f345da6d50ea9d3f upstream.
The pointer '(*auth_tok_key)' is set to NULL in case request_key()
fails, in order to prevent its use by functions calling
ecryptfs_keyring_auth_tok_for_sig().
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 50f198ae16ac66508d4b8d5a40967a8507ad19ee upstream.
Unlock the page in error path of ecryptfs_write_begin(). This may
happen, for example, if decryption fails while bring the page
up-to-date.
commit 24ff6663ccfdaf088dfa7acae489cb11ed4f43c4 upstream.
While trying to track down some NFS problems with BTRFS, I kept noticing I was
getting -EACCESS for no apparent reason. Eric Paris and printk() helped me
figure out that it was SELinux that was giving me grief, with the following
denial
type=AVC msg=audit(1290013638.413:95): avc: denied { 0x800000 } for pid=1772
comm="nfsd" name="" dev=sda1 ino=256 scontext=system_u:system_r:kernel_t:s0
tcontext=system_u:object_r:unlabeled_t:s0 tclass=file
Turns out this is because in d_obtain_alias if we can't find an alias we create
one and do all the normal instantiation stuff, but we don't do the
security_d_instantiate.
Usually we are protected from getting a hashed dentry that hasn't yet run
security_d_instantiate() by the parent's i_mutex, but obviously this isn't an
option there, so in order to deal with the case that a second thread comes in
and finds our new dentry before we get to run security_d_instantiate(), we go
ahead and call it if we find a dentry already. Eric assures me that this is ok
as the code checks to see if the dentry has been initialized already so calling
security_d_instantiate() against the same dentry multiple times is ok. With
this patch I'm no longer getting errant -EACCESS values.
Signed-off-by: Josef Bacik <josef@redhat.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit 5a02ab7c3c4580f94d13c683721039855b67cda6 upstream.
We must not use dummy for index.
After the first index, READ32(dummy) will change dummy!!!!
Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com>
[bfields@redhat.com: Trond points out READ_BUF alone is sufficient.]
commit 5ece3cafbd88d4da5c734e1810c4a2e6474b57b2 upstream.
The members of nfsd4_op_flags, (ALLOWED_WITHOUT_FH | ALLOWED_ON_ABSENT_FS)
equals to ALLOWED_AS_FIRST_OP, maybe that's not what we want.
OP_PUTROOTFH with op_flags = ALLOWED_WITHOUT_FH | ALLOWED_ON_ABSENT_FS,
can't appears as the first operation with out SEQUENCE ops.
This patch modify the wrong value of ALLOWED_WITHOUT_FH etc which
was introduced by f9bb94c4.
Reviewed-by: Benny Halevy <bhalevy@panasas.com>
commit 5883f57ca0008ffc93e09cbb9847a1928e50c6f3 upstream.
While mm->start_stack was protected from cross-uid viewing (commit
f83ce3e6b02d5 ("proc: avoid information leaks to non-privileged
processes")), the start_code and end_code values were not. This would
allow the text location of a PIE binary to leak, defeating ASLR.
Note that the value "1" is used instead of "0" for a protected value since
"ps", "killall", and likely other readers of /proc/pid/stat, take
start_code of "0" to mean a kernel thread and will misbehave. Thanks to
Brad Spengler for pointing this out.
Addresses CVE-2011-0726
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Eugene Teo <eugeneteo@kernel.sg>
Cc: Brad Spengler <spender@grsecurity.net>
commit 0db0c01b53a1a421513f91573241aabafb87802a upstream.
The current code fails to print the "[heap]" marking if the heap is split
into multiple mappings.
Fix the check so that the marking is displayed in all possible cases:
1. vma matches exactly the heap
2. the heap vma is merged e.g. with bss
3. the heap vma is splitted e.g. due to locked pages
Test cases. In all cases, the process should have mapping(s) with
[heap] marking:
(1) vma matches exactly the heap
#include <stdio.h>
#include <unistd.h>
#include <sys/types.h>
int main (void)
if (sbrk(4096) != (void *)-1) {
printf("check /proc/%d/maps\n", (int)getpid());
while (1)
sleep(1);
return 0;
# ./test1
check /proc/553/maps
[1] + Stopped ./test1
# cat /proc/553/maps | head -4
00008000-00009000 r-xp 00000000 01:00 3113640 /test1
00010000-00011000 rw-p 00000000 01:00 3113640 /test1
00011000-00012000 rw-p 00000000 00:00 0 [heap]
4006f000-40070000 rw-p 00000000 00:00 0
(2) the heap vma is merged
#include <stdio.h>
#include <unistd.h>
char foo[4096] = "foo";
char bar[4096];
int main (void)
while (1)
sleep(1);
return 0;
# ./test2
check /proc/556/maps
[2] + Stopped ./test2
# cat /proc/556/maps | head -4
00008000-00009000 r-xp 00000000 01:00 3116312 /test2
00010000-00012000 rw-p 00000000 01:00 3116312 /test2
00012000-00014000 rw-p 00000000 00:00 0 [heap]
4004a000-4004b000 rw-p 00000000 00:00 0
(3) the heap vma is splitted (this fails without the patch)
#include <stdio.h>
#include <unistd.h>
#include <sys/mman.h>
int main (void)
if ((sbrk(4096) != (void *)-1) && !mlockall(MCL_FUTURE) &&
(sbrk(4096) != (void *)-1)) {
while (1)
sleep(1);
return 0;
# ./test3
check /proc/559/maps
[1] + Stopped ./test3
# cat /proc/559/maps|head -4
00008000-00009000 r-xp 00000000 01:00 3119108 /test3
00010000-00011000 rw-p 00000000 01:00 3119108 /test3
00012000-00013000 rw-p 00000000 00:00 0 [heap]
It looks like the bug has been there forever, and since it only results in
some information missing from a procfile, it does not fulfil the -stable
"critical issue" criteria.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit ce654b37f87980d95f339080e4c3bdb2370bdf22 upstream.
Orphan cleanup is currently executed even if the file system has some
number of unknown ROCOMPAT features, which deletes inodes and frees
blocks, which could be very bad for some RO_COMPAT features.
This patch skips the orphan cleanup if it contains readonly compatible
features not known by this ext3 implementation, which would prevent
the fs from being mounted (or remounted) readwrite.
Signed-off-by: Amir Goldstein <amir73il@users.sf.net>
commit e91f90bb0bb10be9cc8efd09a3cf4ecffcad0db1 upstream.
The test program below will hang because io_getevents() uses
add_wait_queue_exclusive(), which means the wake_up() in io_destroy() only
wakes up one of the threads. Fix this by using wake_up_all() in the aio
code paths where we want to make sure no one gets stuck.
// t.c -- compile with gcc -lpthread -laio t.c
#include <libaio.h>
#include <pthread.h>
#include <stdio.h>
#include <unistd.h>
static const int nthr = 2;
void *getev(void *ctx)
struct io_event ev;
io_getevents(ctx, 1, 1, &ev, NULL);
printf("io_getevents returned\n");
return NULL;
int main(int argc, char *argv[])
io_context_t ctx = 0;
pthread_t thread[nthr];
int i;
io_setup(1024, &ctx);
for (i = 0; i < nthr; ++i)
pthread_create(&thread[i], NULL, getev, ctx);
sleep(1);
io_destroy(ctx);
pthread_join(thread[i], NULL);
return 0;
Signed-off-by: Roland Dreier <roland@purestorage.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
commit d7433142b63d727b5a217c37b1a1468b116a9771 upstream.
(crossport of 1f7bebb9e911d870fa8f997ddff838e82b5715ea
by Andreas Schlick <schlick@lavabit.com>)
When ext3_dx_add_entry() has to split an index node, it has to ensure that
name_len of dx_node's fake_dirent is also zero, because otherwise e2fsck
won't recognise it as an intermediate htree node and consider the htree to
be corrupted.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
commit 3ec07aa9522e3d5e9d5ede7bef946756e623a0a0 upstream.
Index i was already used in the outer loop
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
commit 12fed00de963433128b5366a21a55808fab2f756 upstream.
When we get oplock break notification we should set the appropriate
value of OplockLevel field in oplock break acknowledge according to
the oplock level held by the client in this time. As we only can have
level II oplock or no oplock in the case of oplock break, we should be
aware only about clientCanCacheRead field in cifsInodeInfo structure.
Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit e8a80c6f769dd4622d8b211b398452158ee60c0b upstream.
vfs_rename_other() does not lock renamed inode with i_mutex. Thus changing
i_nlink in a non-atomic manner (which happens in ext2_rename()) can corrupt
it as reported and analyzed by Josh.
In fact, there is no good reason to mess with i_nlink of the moved file.
We did it presumably to simulate linking into the new directory and unlinking
from an old one. But the practical effect of this is disputable because fsck
can possibly treat file as being properly linked into both directories without
writing any error which is confusing. So we just stop increment-decrement
games with i_nlink which also fixes the corruption.
CC: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Josh Hunt <johunt@akamai.com>
commit 5a18ec176c934ca1bc9dc61580a5e0e90a9b5733 upstream.
Single threaded NTFS-3G could get stuck if a delayed RELEASE reply
triggered a DESTROY request via path_put().
Fix this by
a) making RELEASE requests synchronous, whenever possible, on fuseblk
filesystems
b) if not possible (triggered by an asynchronous read/write) then do
the path_put() in a separate thread with schedule_work().
Reported-by: Oliver Neukum <oneukum@suse.de>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
right number.
commit acf3bb007e5636ef4c17505affb0974175108553 upstream.
Current refcounttree codes actually didn't writeback the new pages out in
write-back mode, due to a bug of always passing a ZERO number of clusters
to 'ocfs2_cow_sync_writeback', the patch tries to pass a proper one in.
Signed-off-by: Tristan Ye <tristan.ye@oracle.com>
Signed-off-by: Joel Becker <jlbec@evilplan.org>
commit 294f6cf48666825d23c9372ef37631232746e40d upstream.
The kernel automatically evaluates partition tables of storage devices.
The code for evaluating LDM partitions (in fs/partitions/ldm.c) contains
a bug that causes a kernel oops on certain corrupted LDM partitions. A
kernel subsystem seems to crash, because, after the oops, the kernel no
longer recognizes newly connected storage devices.
The patch changes ldm_parse_vmdb() to Validate the value of vblk_size.
Signed-off-by: Timo Warns <warns@pre-sense.de>
Acked-by: Richard Russon <ldm@flatcap.org>
Cc: Harvey Harrison <harvey.harrison@gmail.com>
commit 22bacca48a1755f79b7e0f192ddb9fbb7fc6e64e upstream.
In several places, an epoll fd can call another file's ->f_op->poll()
method with ep->mtx held. This is in general unsafe, because that other
file could itself be an epoll fd that contains the original epoll fd.
The code defends against this possibility in its own ->poll() method using
ep_call_nested, but there are several other unsafe calls to ->poll
elsewhere that can be made to deadlock. For example, the following simple
program causes the call in ep_insert recursively call the original fd's
->poll, leading to deadlock:
#include <unistd.h>
#include <sys/epoll.h>
int main(void) {
int e1, e2, p[2];
struct epoll_event evt = {
.events = EPOLLIN
e1 = epoll_create(1);
e2 = epoll_create(2);
pipe(p);
epoll_ctl(e2, EPOLL_CTL_ADD, e1, &evt);
epoll_ctl(e1, EPOLL_CTL_ADD, p[0], &evt);
write(p[1], p, sizeof p);
epoll_ctl(e1, EPOLL_CTL_ADD, e2, &evt);
return 0;
On insertion, check whether the inserted file is itself a struct epoll,
and if so, do a recursive walk to detect whether inserting this file would
create a loop of epoll structures, which could lead to deadlock.
[nelhage@ksplice.com: Use epmutex to serialize concurrent inserts]
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Signed-off-by: Nelson Elhage <nelhage@ksplice.com>
Reported-by: Nelson Elhage <nelhage@ksplice.com>
Tested-by: Nelson Elhage <nelhage@ksplice.com>
commit 55f9cf6bbaa682958a7dd2755f883b768270c3ce upstream.
The lower filesystem may do some type of inode revalidation during a
getattr call. eCryptfs should take advantage of that by copying the
lower inode attributes to the eCryptfs inode after a call to
vfs_getattr() on the lower inode.
I originally wrote this fix while working on eCryptfs on nfsv3 support,
but discovered it also fixed an eCryptfs on ext4 nanosecond timestamp
bug that was reported.
https://bugs.launchpad.net/bugs/613873
commit fa7ea87a057958a8b7926c1a60a3ca6d696328ed upstream.
Validate number of blocks in map and remove redundant variable.
commit 261cd298a8c363d7985e3482946edb4bfedacf98 upstream.
task_show_regs used to be a debugging aid in the early bringup days
of Linux on s390. /proc/<pid>/status is a world readable file, it
is not a good idea to show the registers of a process. The only
correct fix is to remove task_show_regs.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Upstream commit: 4536f2ad8b330453d7ebec0746c4374eadd649b1
Commit 7124fe0a5b619d65b739477b3b55a20bf805b06d ("xfs: validate untrusted inode
numbers during lookup") changes the inode lookup code to do btree lookups for
untrusted inode numbers. This change made an invalid assumption about the
alignment of inodes and hence incorrectly calculated the first inode in the
cluster. As a result, some inode numbers were being incorrectly considered
invalid when they were actually valid.
The issue was not picked up by the xfstests suite because it always runs fsr
and dump (the two utilities that utilise the bulkstat interface) on cache hot
inodes and hence the lookup code in the cold cache path was not sufficiently
exercised to uncover this intermittent problem.
Fix the issue by relaxing the btree lookup criteria and then checking if the
record returned contains the inode number we are lookup for. If it we get an
incorrect record, then the inode number is invalid.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
[dannf: Backported to 2.6.32.y]
Cc: dann frazier <dannf@debian.org>
Upstream commit: 7b6259e7a83647948fa33a736cc832310c8d85aa
The block number comes from bulkstat based inode lookups to shortcut
the mapping calculations. We ar enot able to trust anything from
bulkstat, so drop the block number as well so that the correct
lookups and mappings are always done.
Upstream commit: 1920779e67cbf5ea8afef317777c5bf2b8096188
Inode numbers may come from somewhere external to the filesystem
(e.g. file handles, bulkstat information) and so are inherently
untrusted. Rename the flag we use for these lookups to make it
obvious we are doing a lookup of an untrusted inode number and need
to verify it completely before trying to read it from disk.
[dannf: backported to 2.6.32.y]
Upstream commit: 7124fe0a5b619d65b739477b3b55a20bf805b06d
When we decode a handle or do a bulkstat lookup, we are using an
inode number we cannot trust to be valid. If we are deleting inode
chunks from disk (default noikeep mode), then we cannot trust the on
disk inode buffer for any given inode number to correctly reflect
whether the inode has been unlinked as the di_mode nor the
generation number may have been updated on disk.
This is due to the fact that when we delete an inode chunk, we do
not write the clusters back to disk when they are removed - instead
we mark them stale to avoid them being written back potentially over
the top of something that has been subsequently allocated at that
location. The result is that we can have locations of disk that look
like they contain valid inodes but in reality do not. Hence we
cannot simply convert the inode number to a block number and read
the location from disk to determine if the inode is valid or not.
As a result, and XFS_IGET_BULKSTAT lookup needs to actually look the
inode up in the inode allocation btree to determine if the inode
number is valid or not.
It should be noted even on ikeep filesystems, there is the
possibility that blocks on disk may look like valid inode clusters.
e.g. if there are filesystem images hosted on the filesystem. Hence
even for ikeep filesystems we really need to validate that the inode
number is valid before issuing the inode buffer read.
Upstream commit: 7dce11dbac54fce777eea0f5fb25b2694ccd7900
The non-coherent bulkstat versionsthat look directly at the inode
buffers causes various problems with performance optimizations that
make increased use of just logging inodes. This patch makes bulkstat
always use iget, which should be fast enough for normal use with the
radix-tree based inode cache introduced a while ago.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
commit 47c85291d3dd1a51501555000b90f8e281a0458e upstream.
These functions return an nfs status, not a host_err. So don't
try to convert before returning.
This is a regression introduced by
3c726023402a2f3b28f49b9d90ebf9e71151157d; I fixed up two of the callers,
but missed these two.
Reported-by: Herbert Poetzl <herbert@13thfloor.at>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 07ccb7bf2c928fef4fea2cda69ba2e23479578db upstream.
This patch solves a corner case during allocation which occurs if both
metadata (indirect) and data blocks are required but there is an
obstacle in the filesystem (e.g. a resource group header or another
allocated block) such that when the allocation is requested only
enough blocks for the metadata are returned.
By changing the exit condition of this loop, we ensure that a
minimum of one data block will always be returned.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Cc: maximilian attems <max@stro.at>
commit 0702099bd86c33c2dcdbd3963433a61f3f503901 upstream.
By the commit af7fa16 2010-08-03 NFS: Fix up the fsync code
close(2) became returning the non-zero value even if it went well.
nfs_file_fsync() should return 0 when "status" is positive.
Signed-off-by: J. R. Okajima <hooanon05@yahoo.co.jp>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit cc56f7de7f00d188c7c4da1e9861581853b9e92f upstream.
sendfile(2) was reworked with the splice infrastructure, but it still
checks f_op.sendpage() instead of f_op.splice_write() wrongly. Although
if f_op.sendpage() exists, f_op.splice_write() always exists at the same
time currently, the assumption will be broken in future silently. This
patch also brings a side effect: sendfile(2) can work with any output
file. Some security checks related to f_op are added too.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Cc: Przemyslaw Pawelczyk <przemyslaw@pawelczyk.it>
commit 78d2978874e4e10e97dfd4fd79db45bdc0748550 upstream.
In get_empty_filp() since 2.6.29, file_free(f) is called with f->f_cred == NULL
when security_file_alloc() returned an error. As a result, kernel will panic()
due to put_cred(NULL) call within RCU callback.
Fix this bug by assigning f->f_cred before calling security_file_alloc().
commit de09a9771a5346029f4d11e4ac886be7f9bfdd75 upstream.
It's possible for get_task_cred() as it currently stands to 'corrupt' a set of
credentials by incrementing their usage count after their replacement by the
task being accessed.
What happens is that get_task_cred() can race with commit_creds():
TASK_1 TASK_2 RCU_CLEANER
-->get_task_cred(TASK_2)
rcu_read_lock()
__cred = __task_cred(TASK_2)
-->commit_creds()
old_cred = TASK_2->real_cred
TASK_2->real_cred = ...
put_cred(old_cred)
call_rcu(old_cred)
[__cred->usage == 0]
get_cred(__cred)
[__cred->usage == 1]
rcu_read_unlock()
-->put_cred_rcu()
panic()
However, since a tasks credentials are generally not changed very often, we can
reasonably make use of a loop involving reading the creds pointer and using
atomic_inc_not_zero() to attempt to increment it if it hasn't already hit zero.
If successful, we can safely return the credentials in the knowledge that, even
if the task we're accessing has released them, they haven't gone to the RCU
cleanup code.
We then change task_state() in procfs to use get_task_cred() rather than
calling get_cred() on the result of __task_cred(), as that suffers from the
same problem.
Without this change, a BUG_ON in __put_cred() or in put_cred_rcu() can be
tripped when it is noticed that the usage count is not zero as it ought to be,
for example:
kernel BUG at kernel/cred.c:168!
invalid opcode: 0000 [#1] SMP
last sysfs file: /sys/kernel/mm/ksm/run
CPU 0
Pid: 2436, comm: master Not tainted 2.6.33.3-85.fc13.x86_64 #1 0HR330/OptiPlex
745
RIP: 0010:[<ffffffff81069881>] [<ffffffff81069881>] __put_cred+0xc/0x45
RSP: 0018:ffff88019e7e9eb8 EFLAGS: 00010202
RAX: 0000000000000001 RBX: ffff880161514480 RCX: 00000000ffffffff
RDX: 00000000ffffffff RSI: ffff880140c690c0 RDI: ffff880140c690c0
RBP: ffff88019e7e9eb8 R08: 00000000000000d0 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000040 R12: ffff880140c690c0
R13: ffff88019e77aea0 R14: 00007fff336b0a5c R15: 0000000000000001
FS: 00007f12f50d97c0(0000) GS:ffff880007400000(0000) knlGS:0000000000000000
CR2: 00007f8f461bc000 CR3: 00000001b26ce000 CR4: 00000000000006f0
Process master (pid: 2436, threadinfo ffff88019e7e8000, task ffff88019e77aea0)
Stack:
ffff88019e7e9ec8 ffffffff810698cd ffff88019e7e9ef8 ffffffff81069b45
<0> ffff880161514180 ffff880161514480 ffff880161514180 0000000000000000
<0> ffff88019e7e9f28 ffffffff8106aace 0000000000000001 0000000000000246
Call Trace:
[<ffffffff810698cd>] put_cred+0x13/0x15
[<ffffffff81069b45>] commit_creds+0x16b/0x175
[<ffffffff8106aace>] set_current_groups+0x47/0x4e
[<ffffffff8106ac89>] sys_setgroups+0xf6/0x105
[<ffffffff81009b02>] system_call_fastpath+0x16/0x1b
Code: 48 8d 71 ff e8 7e 4e 15 00 85 c0 78 0b 8b 75 ec 48 89 df e8 ef 4a 15 00
48 83 c4 18 5b c9 c3 55 8b 07 8b 07 48 89 e5 85 c0 74 04 <0f> 0b eb fe 65 48 8b
04 25 00 cc 00 00 48 3b b8 58 04 00 00 75
RIP [<ffffffff81069881>] __put_cred+0xc/0x45
RSP <ffff88019e7e9eb8>
---[ end trace df391256a100ebdd ]---
Acked-by: Jiri Olsa <jolsa@redhat.com>
commit 226291aa4641fa13cb5dec3bcb3379faa83009e2 upstream.
If ocfs2_live_connection_list is empty, ocfs2_connection_find() will return
a pointer to the LIST_HEAD, cast as a ocfs2_live_connection. This can cause
an oops when ocfs2_control_send_down() dereferences c->oc_conn:
Call Trace:
[<ffffffffa00c2a3c>] ocfs2_control_message+0x28c/0x2b0 [ocfs2_stack_user]
[<ffffffffa00c2a95>] ocfs2_control_write+0x35/0xb0 [ocfs2_stack_user]
[<ffffffff81143a88>] vfs_write+0xb8/0x1a0
[<ffffffff8155cc13>] ? do_page_fault+0x153/0x3b0
[<ffffffff811442f1>] sys_write+0x51/0x80
[<ffffffff810121b2>] system_call_fastpath+0x16/0x1b
Fix by explicitly returning NULL if no match is found.
Signed-off-by: dann frazier <dann.frazier@canonical.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
commit 3aa6e0aa8ab3e64bbfba092c64d42fd1d006b124 upstream.
If nfsd fails to find an exported via NFS file in the readahead cache, it
should increment corresponding nfsdstats counter (ra_depth[10]), but due to a
bug it may instead write to ra_depth[11], corrupting the following field.
In a kernel with NFSDv4 compiled in the corruption takes the form of an
increment of a counter of the number of NFSv4 operation 0's received; since
there is no operation 0, this is harmless.
In a kernel with NFSDv4 disabled it corrupts whatever happens to be in the
memory beyond nfsdstats.
Signed-off-by: Konstantin Khorenko <khorenko@openvz.org>
commit 839f7ad6932d95f4d5ae7267b95c574714ff3d5b upstream.
Nick Piggin reports:
> I'm getting use after frees in aio code in NFS
> [ 2703.396766] Call Trace:
> [ 2703.396858] [<ffffffff8100b057>] ? native_sched_clock+0x27/0x80
> [ 2703.396959] [<ffffffff8108509e>] ? put_lock_stats+0xe/0x40
> [ 2703.397058] [<ffffffff81088348>] ? lock_release_holdtime+0xa8/0x140
> [ 2703.397159] [<ffffffff8108a2a5>] lock_acquire+0x95/0x1b0
> [ 2703.397260] [<ffffffff811627db>] ? aio_put_req+0x2b/0x60
> [ 2703.397361] [<ffffffff81039701>] ? get_parent_ip+0x11/0x50
> [ 2703.397464] [<ffffffff81612a31>] _raw_spin_lock_irq+0x41/0x80
> [ 2703.397564] [<ffffffff811627db>] ? aio_put_req+0x2b/0x60
> [ 2703.397662] [<ffffffff811627db>] aio_put_req+0x2b/0x60
> [ 2703.397761] [<ffffffff811647fe>] do_io_submit+0x2be/0x7c0
> [ 2703.397895] [<ffffffff81164d0b>] sys_io_submit+0xb/0x10
> [ 2703.397995] [<ffffffff8100307b>] system_call_fastpath+0x16/0x1b
> Adding some tracing, it is due to nfs completing the request then
> returning something other than -EIOCBQUEUED, so aio.c
> also completes the request.
To address this, prevent the NFS direct I/O engine from completing
async iocbs when the forward path returns an error without starting
any I/O.
This fix appears to survive ^C during both "xfstest no. 208" and "fsx
-Z."
It's likely this bug has existed for a very long while, as we are seeing
very similar symptoms in OEL 5. Copying stable.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
commit 462e635e5b73ba9a4c03913b77138cd57ce4b050 upstream.
The install_special_mapping routine (used, for example, to setup the
vdso) skips the security check before insert_vm_struct, allowing a local
attacker to bypass the mmap_min_addr security restriction by limiting
the available pages for special mappings.
bprm_mm_init() also skips the check, and although I don't think this can
be used to bypass any restrictions, I don't see any reason not to have
the security check.
$ uname -m
x86_64
$ cat /proc/sys/vm/mmap_min_addr
65536
$ cat install_special_mapping.s
section .bss
resb BSS_SIZE
section .text
global _start
_start:
mov eax, __NR_pause
int 0x80
$ nasm -D__NR_pause=29 -DBSS_SIZE=0xfffed000 -f elf -o install_special_mapping.o install_special_mapping.s
$ ld -m elf_i386 -Ttext=0x10000 -Tbss=0x11000 -o install_special_mapping install_special_mapping.o
$ ./install_special_mapping &
[1] 14303
$ cat /proc/14303/maps
0000f000-00010000 r-xp 00000000 00:00 0 [vdso]
00010000-00011000 r-xp 00001000 00:19 2453665 /home/taviso/install_special_mapping
00011000-ffffe000 rwxp 00000000 00:00 0 [stack]
It's worth noting that Red Hat are shipping with mmap_min_addr set to
4096.
Signed-off-by: Tavis Ormandy <taviso@google.com>
Acked-by: Kees Cook <kees@ubuntu.com>
Acked-by: Robert Swiecki <swiecki@google.com>
[ Changed to not drop the error code - akpm ]
Reviewed-by: James Morris <jmorris@namei.org>
commit 21ac19d484a8ffb66f64487846c8d53afef04d2b upstream.
The commit 129a84de2347002f09721cda3155ccfd19fade40 (locks: fix F_GETLK
regression (failure to find conflicts)) fixed the posix_test_lock()
function by itself, however, its usage in NFS changed by the commit
9d6a8c5c213e34c475e72b245a8eb709258e968c (locks: give posix_test_lock
same interface as ->lock) remained broken - subsequent NFS-specific
locking code received F_UNLCK instead of the user-specified lock type.
To fix the problem, fl->fl_type needs to be saved before the
posix_test_lock() call and restored if no local conflicts were reported.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=23892
Tested-by: Alexander Morozov <amorozov@etersoft.ru>
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
