path: root/fs
2013-01-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) New sysctl ndisc_notify needs some documentation, from Hanns Frederic Sowa. 2) Netfilter REJECT target doesn't set transport header of SKB correctly, from Mukund Jampala. 3) Forcedeth driver needs to check for DMA mapping failures, from Larry Finger. 4) brcmsmac driver can't use usleep_range while holding locks, use udelay instead. From Niels Ole Salscheider. 5) Fix unregister of netlink bridge multicast database handlers, from Vlad Yasevich and Rami Rosen. 6) Fix checksum calculations in netfilter's ipv6 network prefix translation module. 7) Fix high order page allocation failures in netfilter xt_recent, from Eric Dumazet. 8) mac802154 needs to use netif_rx_ni() instead of netif_rx() because mac802154_process_data() can execute in process rather than interrupt context. From Alexander Aring. 9) Fix splice handling of MSG_SENDPAGE_NOTLAST, otherwise we elide one tcp_push() too many. From Eric Dumazet and Willy Tarreau. 10) Fix skb->truesize tracking in XEN netfront driver, from Ian Campbell. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (46 commits) xen/netfront: improve truesize tracking ipv4: fix NULL checking in devinet_ioctl() tcp: fix MSG_SENDPAGE_NOTLAST logic net/ipv4/ipconfig: really display the BOOTP/DHCP server's address. ip-sysctl: fix spelling errors mac802154: fix NOHZ local_softirq_pending 08 warning ipv6: document ndisc_notify in networking/ip-sysctl.txt ath9k: Fix Kconfig for ATH9K_HTC netfilter: xt_recent: avoid high order page allocations netfilter: fix missing dependencies for the NOTRACK target netfilter: ip6t_NPT: fix IPv6 NTP checksum calculation bridge: add empty br_mdb_init() and br_mdb_uninit() definitions. vxlan: allow live mac address change bridge: Correctly unregister MDB rtnetlink handlers brcmfmac: fix parsing rsn ie for ap mode. brcmsmac: add copyright information for Canonical rtlwifi: rtl8723ae: Fix warning for unchecked pci_map_single() call rtlwifi: rtl8192se: Fix warning for unchecked pci_map_single() call rtlwifi: rtl8192de: Fix warning for unchecked pci_map_single() call rtlwifi: rtl8192ce: Fix warning for unchecked pci_map_single() call ...
2013-01-07Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Misc small cifs fixes" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: CIFS: Don't let read only caching for mandatory byte-range locked files CIFS: Fix write after setting a read lock for read oplock files Revert "CIFS: Fix write after setting a read lock for read oplock files" cifs: adjust sequence number downward after signing NT_CANCEL request cifs: move check for NULL socket into smb_send_rqst
2013-01-07Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 regression fixes from Ted Ts'o: "Bug fixes, including two regressions introduced in v3.8. The most serious of these regressions is a buffer cache leak." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: remove duplicate call to ext4_bread() in ext4_init_new_dir() ext4: release buffer in failed path in dx_probe() ext4: fix configuration dependencies for ext4 ACLs and security labels
2013-01-07Merge tag 'nfs-for-3.8-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: - Fix a permissions problem when opening NFSv4 files that only have the exec bit set. - Fix a couple of typos in pNFS (inverted logic), and the mount parsing (missing pointer dereference). - Work around a series of deadlock issues due to workqueues using struct work_struct pointer address comparisons in the re-entrancy tests. Ensure that we don't free struct work_struct prematurely if our work function involves waiting for completion of other work items (e.g. by calling rpc_shutdown_client). - Revert the part of commit 168e4b3 that is causing unnecessary warnings to be issued in the nfsd callback code. * tag 'nfs-for-3.8-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: nfs: avoid dereferencing null pointer in initiate_bulk_draining SUNRPC: Partial revert of commit 168e4b39d1afb79a7e3ea6c3bb246b4c82c6bdb9 NFS: Ensure that we free the rpc_task after read and write cleanups are done SUNRPC: Ensure that we free the rpc_task after cleanups are done nfs: fix null checking in nfs_get_option_str() pnfs: Increase the refcount when LAYOUTGET fails the first time NFS: Fix access to suid/sgid executables
2013-01-06tcp: fix MSG_SENDPAGE_NOTLAST logicEric Dumazet
commit 35f9c09fe9c72e (tcp: tcp_sendpages() should call tcp_push() once) added an internal flag : MSG_SENDPAGE_NOTLAST meant to be set on all frags but the last one for a splice() call. The condition used to set the flag in pipe_to_sendpage() relied on splice() user passing the exact number of bytes present in the pipe, or a smaller one. But some programs pass an arbitrary high value, and the test fails. The effect of this bug is a lack of tcp_push() at the end of a splice(pipe -> socket) call, and possibly very slow or erratic TCP sessions. We should both test sd->total_len and fact that another fragment is in the pipe (pipe->nrbufs > 1) Many thanks to Willy for providing very clear bug report, bisection and test programs. Reported-by: Willy Tarreau <w@1wt.eu> Bisected-by: Willy Tarreau <w@1wt.eu> Tested-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-06ext4: remove duplicate call to ext4_bread() in ext4_init_new_dir()Guo Chao
This fixes a buffer cache leak when creating a directory, introduced in commit a774f9c20. Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Tao Ma <boyu.mt@taobao.com>
2013-01-06ext4: release buffer in failed path in dx_probe()Guo Chao
If checksum fails, we should also release the buffer read from previous iteration. Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>- Cc: stable@vger.kernel.org -- fs/ext4/namei.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
2013-01-06ext4: fix configuration dependencies for ext4 ACLs and security labelsValerie Aurora
Commit "ext4: Remove CONFIG_EXT4_FS_XATTR" removed the configuration dependencies for ext4 xattrs from the ext4 ACLs and security labels configuration options, but did not replace them with a dependency on ext4 itself. Add back the dependency on ext4 so the options only show up if ext4 is enabled. Signed-off-by: Valerie Aurora <val@vaaconsulting.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Tao Ma <boyu.mt@taobao.com>
2013-01-05nfs: avoid dereferencing null pointer in initiate_bulk_drainingNickolai Zeldovich
Fix an inverted null pointer check in initiate_bulk_draining(). Signed-off-by: Nickolai Zeldovich <nickolai@csail.mit.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org [>= 3.7]
2013-01-04NFS: Ensure that we free the rpc_task after read and write cleanups are doneTrond Myklebust
This patch ensures that we free the rpc_task after the cleanup callbacks are done in order to avoid a deadlock problem that can be triggered if the callback needs to wait for another workqueue item to complete. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Weston Andros Adamson <dros@netapp.com> Cc: Tejun Heo <tj@kernel.org> Cc: Bruce Fields <bfields@fieldses.org> Cc: stable@vger.kernel.org [>= 3.5]
2013-01-04nfs: fix null checking in nfs_get_option_str()Xi Wang
The following null pointer check is broken. *option = match_strdup(args); return !option; The pointer `option' must be non-null, and thus `!option' is always false. Use `!*option' instead. The bug was introduced in commit c5cb09b6f8 ("Cleanup: Factor out some cut-and-paste code."). Signed-off-by: Xi Wang <xi.wang@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-01-04pnfs: Increase the refcount when LAYOUTGET fails the first timeYanchuan Nian
The layout will be set unusable if LAYOUTGET fails. Is it reasonable to increase the refcount iff LAYOUTGET fails the first time? Signed-off-by: Yanchuan Nian <ycnian@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org [>= 3.7]
2013-01-03Merge tag 'driver-core-3.8-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core __dev* removal patches - take 3 - from Greg Kroah-Hartman: "Here are the remaining __dev* removal patches against the 3.8-rc2 tree. All of these patches were previously sent to the subsystem maintainers, most of them were picked up and pushed to you, but there were a number that fell through the cracks, and new drivers were added during the merge window, so this series cleans up the rest of the instances of these markings. Third time's the charm... Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflict with the pinctrl pull in pinctrl-sirf.c. * tag 'driver-core-3.8-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (54 commits) misc: remove __dev* attributes. include: remove __dev* attributes. Documentation: remove __dev* attributes. Drivers: misc: remove __dev* attributes. Drivers: block: remove __dev* attributes. Drivers: bcma: remove __dev* attributes. Drivers: char: remove __dev* attributes. Drivers: clocksource: remove __dev* attributes. Drivers: ssb: remove __dev* attributes. Drivers: dma: remove __dev* attributes. Drivers: gpu: remove __dev* attributes. Drivers: infinband: remove __dev* attributes. Drivers: memory: remove __dev* attributes. Drivers: mmc: remove __dev* attributes. Drivers: iommu: remove __dev* attributes. Drivers: power: remove __dev* attributes. Drivers: message: remove __dev* attributes. Drivers: macintosh: remove __dev* attributes. Drivers: mfd: remove __dev* attributes. pstore: remove __dev* attributes. ...
2013-01-03misc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the last of the __dev* markings from the kernel from a variety of different, tiny, places. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03pstore: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit from the pstore filesystem. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Anton Vorontsov <cbouatmailru@gmail.com> Cc: Colin Cross <ccross@android.com> Cc: Kees Cook <keescook@chromium.org> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03NFS: Fix access to suid/sgid executablesWeston Andros Adamson
nfs_open_permission_mask() should only check MAY_EXEC for files that are opened with __FMODE_EXEC. Also fix NFSv4 access-in-open path in a similar way -- openflags must be used because fmode will not always have FMODE_EXEC set. This patch fixes https://bugzilla.kernel.org/show_bug.cgi?id=49101 Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org
2013-01-03Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs bug fixes from Jaegeuk Kim: "This patch-set includes two major bug fixes: - incorrect IUsed provided by *df -i*, and - lookup failure of parent inodes in corner cases. [Other Bug Fixes] - Fix error handling routines - Trigger recovery process correctly - Resolve build failures due to missing header files [Etc] - Add a MAINTAINERS entry for f2fs - Fix and clean up variables, functions, and equations - Avoid warnings during compilation" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: f2fs: unify string length declarations and usage f2fs: clean up unused variables and return values f2fs: clean up the start_bidx_of_node function f2fs: remove unneeded variable from f2fs_sync_fs f2fs: fix fsync_inode list addition logic and avoid invalid access to memory f2fs: remove unneeded initialization of nr_dirty in dirty_seglist_info f2fs: handle error from f2fs_iget_nowait f2fs: fix equation of has_not_enough_free_secs() f2fs: add MAINTAINERS entry f2fs: return a default value for non-void function f2fs: invalidate the node page if allocation is failed f2fs: add missing #include <linux/prefetch.h> f2fs: do f2fs_balance_fs in front of dir operations f2fs: should recover orphan and fsync data f2fs: fix handling errors got by f2fs_write_inode f2fs: fix up f2fs_get_parent issue to retrieve correct parent inode number f2fs: fix wrong calculation on f_files in statfs f2fs: remove set_page_dirty for atomic f2fs_end_io_write
2013-01-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixesLinus Torvalds
Pull GFS2 fixes from Steven Whitehouse: "Here are four small bug fixes for GFS2. There is no common theme here really, just a few items that were fixed recently. The first fixes lock name generation when the glock number is 0. The second fixes a race allocating reservation structures and the final two fix a performance issue by making small changes in the allocation code." * git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes: GFS2: Reset rd_last_alloc when it reaches the end of the rgrp GFS2: Stop looking for free blocks at end of rgrp GFS2: Fix race in gfs2_rs_alloc GFS2: Initialize hex string to '0'
2013-01-02Merge tag 'ecryptfs-3.8-rc2-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull ecryptfs fixes from Tyler Hicks: "Two self-explanatory fixes and a third patch which improves performance: when overwriting a full page in the eCryptfs page cache, skip reading in and decrypting the corresponding lower page." * tag 'ecryptfs-3.8-rc2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: fs/ecryptfs/crypto.c: make ecryptfs_encode_for_filename() static eCryptfs: fix to use list_for_each_entry_safe() when delete items eCryptfs: Avoid unnecessary disk read and data decryption during writing
2013-01-02Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 bug fixes from Ted Ts'o: "Various bug fixes for ext4. Perhaps the most serious bug fixed is one which could cause file system corruptions when performing file punch operations." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: avoid hang when mounting non-journal filesystems with orphan list ext4: lock i_mutex when truncating orphan inodes ext4: do not try to write superblock on ro remount w/o journal ext4: include journal blocks in df overhead calcs ext4: remove unaligned AIO warning printk ext4: fix an incorrect comment about i_mutex ext4: fix deadlock in journal_unmap_buffer() ext4: split off ext4_journalled_invalidatepage() jbd2: fix assertion failure in jbd2_journal_flush() ext4: check dioread_nolock on remount ext4: fix extent tree corruption caused by hole punch
2013-01-02mempolicy: remove arg from mpol_parse_str, mpol_to_strHugh Dickins
Remove the unused argument (formerly no_context) from mpol_parse_str() and from mpol_to_str(). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-02epoll: prevent missed events on EPOLL_CTL_MODEric Wong
EPOLL_CTL_MOD sets the interest mask before calling f_op->poll() to ensure events are not missed. Since the modifications to the interest mask are not protected by the same lock as ep_poll_callback, we need to ensure the change is visible to other CPUs calling ep_poll_callback. We also need to ensure f_op->poll() has an up-to-date view of past events which occured before we modified the interest mask. So this barrier also pairs with the barrier in wq_has_sleeper(). This should guarantee either ep_poll_callback or f_op->poll() (or both) will notice the readiness of a recently-ready/modified item. This issue was encountered by Andreas Voellmy and Junchang(Jason) Wang in: http://thread.gmane.org/gmane.linux.kernel/1408782/ Signed-off-by: Eric Wong <normalperson@yhbt.net> Cc: Hans Verkuil <hans.verkuil@cisco.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Voellmy <andreas.voellmy@yale.edu> Tested-by: "Junchang(Jason) Wang" <junchang.wang@yale.edu> Cc: netdev@vger.kernel.org Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-02GFS2: Reset rd_last_alloc when it reaches the end of the rgrpBob Peterson
In function rg_mblk_search, it's searching for multiple blocks in a given state (e.g. "free"). If there's an active block reservation its goal is the next free block of that. If the resource group contains the dinode's goal block, that's used for the search. But if neither is the case, it uses the rgrp's last allocated block. That way, consecutive allocations appear after one another on media. The problem comes in when you hit the end of the rgrp; it would never start over and search from the beginning. This became a problem, since if you deleted all the files and data from the rgrp, it would never start over and find free blocks. So it had to keep searching further out on the media to allocate blocks. This patch resets the rd_last_alloc after it does an unsuccessful search at the end of the rgrp. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-01-02GFS2: Stop looking for free blocks at end of rgrpBob Peterson
This patch adds a return code check after calling function gfs2_rbm_from_block while determining the free extent size. That way, when the end of an rgrp is reached, it won't try to process unaligned blocks after the end. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-01-02GFS2: Fix race in gfs2_rs_allocAbhijith Das
QE aio tests uncovered a race condition in gfs2_rs_alloc where it's possible to come out of the function with a valid ip->i_res allocation but it gets freed before use resulting in a NULL ptr dereference. This patch envelopes the initial short-circuit check for non-NULL ip->i_res into the mutex lock. With this patch, I was able to successfully run the reproducer test multiple times. Resolves: rhbz#878476 Signed-off-by: Abhi Das <adas@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-01-02GFS2: Initialize hex string to '0'Nathan Straz
When generating the DLM lock name, a value of 0 would skip the loop and leave the string unchanged. This left locks with a value of 0 unlabeled. Initializing the string to '0' fixes this. Signed-off-by: Nathan Straz <nstraz@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-01-01CIFS: Don't let read only caching for mandatory byte-range locked filesPavel Shilovsky
If we have mandatory byte-range locks on a file we can't cache reads because pagereading may have conflicts with these locks on the server. That's why we should allow level2 oplocks for files without mandatory locks only. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-01-01CIFS: Fix write after setting a read lock for read oplock filesPavel Shilovsky
If we have a read oplock and set a read lock in it, we can't write to the locked area - so, filemap_fdatawrite may fail with a no information for a userspace application even if we request a write to non-locked area. Fix this by writing directly to the server and then breaking oplock level from level2 to None. Also remove CONFIG_CIFS_SMB2 ifdefs because it's suitable for both CIFS and SMB2 protocols. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-01-01Revert "CIFS: Fix write after setting a read lock for read oplock files"Pavel Shilovsky
that solution has data races and can end up two identical writes to the server: when clientCanCacheAll value can be changed during the execution of __generic_file_aio_write. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-30cifs: adjust sequence number downward after signing NT_CANCEL requestJeff Layton
When a call goes out, the signing code adjusts the sequence number upward by two to account for the request and the response. An NT_CANCEL however doesn't get a response of its own, it just hurries the server along to get it to respond to the original request more quickly. Therefore, we must adjust the sequence number back down by one after signing a NT_CANCEL request. Cc: <stable@vger.kernel.org> Reported-by: Tim Perry <tdparmor-sambabugs@yahoo.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-30cifs: move check for NULL socket into smb_send_rqstJeff Layton
Cai reported this oops: [90701.616664] BUG: unable to handle kernel NULL pointer dereference at 0000000000000028 [90701.625438] IP: [<ffffffff814a343e>] kernel_setsockopt+0x2e/0x60 [90701.632167] PGD fea319067 PUD 103fda4067 PMD 0 [90701.637255] Oops: 0000 [#1] SMP [90701.640878] Modules linked in: des_generic md4 nls_utf8 cifs dns_resolver binfmt_misc tun sg igb iTCO_wdt iTCO_vendor_support lpc_ich pcspkr i2c_i801 i2c_core i7core_edac edac_core ioatdma dca mfd_core coretemp kvm_intel kvm crc32c_intel microcode sr_mod cdrom ata_generic sd_mod pata_acpi crc_t10dif ata_piix libata megaraid_sas dm_mirror dm_region_hash dm_log dm_mod [90701.677655] CPU 10 [90701.679808] Pid: 9627, comm: ls Tainted: G W 3.7.1+ #10 QCI QSSC-S4R/QSSC-S4R [90701.688950] RIP: 0010:[<ffffffff814a343e>] [<ffffffff814a343e>] kernel_setsockopt+0x2e/0x60 [90701.698383] RSP: 0018:ffff88177b431bb8 EFLAGS: 00010206 [90701.704309] RAX: ffff88177b431fd8 RBX: 00007ffffffff000 RCX: ffff88177b431bec [90701.712271] RDX: 0000000000000003 RSI: 0000000000000006 RDI: 0000000000000000 [90701.720223] RBP: ffff88177b431bc8 R08: 0000000000000004 R09: 0000000000000000 [90701.728185] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000001 [90701.736147] R13: ffff88184ef92000 R14: 0000000000000023 R15: ffff88177b431c88 [90701.744109] FS: 00007fd56a1a47c0(0000) GS:ffff88105fc40000(0000) knlGS:0000000000000000 [90701.753137] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [90701.759550] CR2: 0000000000000028 CR3: 000000104f15f000 CR4: 00000000000007e0 [90701.767512] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [90701.775465] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [90701.783428] Process ls (pid: 9627, threadinfo ffff88177b430000, task ffff88185ca4cb60) [90701.792261] Stack: [90701.794505] 0000000000000023 ffff88177b431c50 ffff88177b431c38 ffffffffa014fcb1 [90701.802809] ffff88184ef921bc 0000000000000000 00000001ffffffff ffff88184ef921c0 [90701.811123] ffff88177b431c08 ffffffff815ca3d9 ffff88177b431c18 ffff880857758000 [90701.819433] Call Trace: [90701.822183] [<ffffffffa014fcb1>] smb_send_rqst+0x71/0x1f0 [cifs] [90701.828991] [<ffffffff815ca3d9>] ? schedule+0x29/0x70 [90701.834736] [<ffffffffa014fe6d>] smb_sendv+0x3d/0x40 [cifs] [90701.841062] [<ffffffffa014fe96>] smb_send+0x26/0x30 [cifs] [90701.847291] [<ffffffffa015801f>] send_nt_cancel+0x6f/0xd0 [cifs] [90701.854102] [<ffffffffa015075e>] SendReceive+0x18e/0x360 [cifs] [90701.860814] [<ffffffffa0134a78>] CIFSFindFirst+0x1a8/0x3f0 [cifs] [90701.867724] [<ffffffffa013f731>] ? build_path_from_dentry+0xf1/0x260 [cifs] [90701.875601] [<ffffffffa013f731>] ? build_path_from_dentry+0xf1/0x260 [cifs] [90701.883477] [<ffffffffa01578e6>] cifs_query_dir_first+0x26/0x30 [cifs] [90701.890869] [<ffffffffa015480d>] initiate_cifs_search+0xed/0x250 [cifs] [90701.898354] [<ffffffff81195970>] ? fillonedir+0x100/0x100 [90701.904486] [<ffffffffa01554cb>] cifs_readdir+0x45b/0x8f0 [cifs] [90701.911288] [<ffffffff81195970>] ? fillonedir+0x100/0x100 [90701.917410] [<ffffffff81195970>] ? fillonedir+0x100/0x100 [90701.923533] [<ffffffff81195970>] ? fillonedir+0x100/0x100 [90701.929657] [<ffffffff81195848>] vfs_readdir+0xb8/0xe0 [90701.935490] [<ffffffff81195b9f>] sys_getdents+0x8f/0x110 [90701.941521] [<ffffffff815d3b99>] system_call_fastpath+0x16/0x1b [90701.948222] Code: 66 90 55 65 48 8b 04 25 f0 c6 00 00 48 89 e5 53 48 83 ec 08 83 fe 01 48 8b 98 48 e0 ff ff 48 c7 80 48 e0 ff ff ff ff ff ff 74 22 <48> 8b 47 28 ff 50 68 65 48 8b 14 25 f0 c6 00 00 48 89 9a 48 e0 [90701.970313] RIP [<ffffffff814a343e>] kernel_setsockopt+0x2e/0x60 [90701.977125] RSP <ffff88177b431bb8> [90701.981018] CR2: 0000000000000028 [90701.984809] ---[ end trace 24bd602971110a43 ]--- This is likely due to a race vs. a reconnection event. The current code checks for a NULL socket in smb_send_kvec, but that's too late. By the time that check is done, the socket will already have been passed to kernel_setsockopt. Move the check into smb_send_rqst, so that it's checked earlier. In truth, this is a bit of a half-assed fix. The -ENOTSOCK error return here looks like it could bubble back up to userspace. The locking rules around the ssocket pointer are really unclear as well. There are cases where the ssocket pointer is changed without holding the srv_mutex, but I'm not clear whether there's a potential race here yet or not. This code seems like it could benefit from some fundamental re-think of how the socket handling should behave. Until then though, this patch should at least fix the above oops in most cases. Cc: <stable@vger.kernel.org> # 3.7+ Reported-and-Tested-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-28f2fs: unify string length declarations and usageLeon Romanovsky
This patch is intended to unify string length declarations and usage. There are number of calls to strlen which return size_t object. The size of this object depends on compiler if it will be bigger, equal or even smaller than an unsigned int Signed-off-by: Leon Romanovsky <leon@leon.nu> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-28f2fs: clean up unused variables and return valuesJaegeuk Kim
This patch cleans up a couple of unnecessary codes related to unused variables and return values. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-28f2fs: clean up the start_bidx_of_node functionJaegeuk Kim
This patch also resolves the following warning reported by kbuild test robot. fs/f2fs/gc.c: In function 'start_bidx_of_node': fs/f2fs/gc.c:453:21: warning: 'bidx' may be used uninitialized in this function Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-28f2fs: remove unneeded variable from f2fs_sync_fsNamjae Jeon
We can directly return '0' from the function, instead of introducing a 'ret' variable. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-28f2fs: fix fsync_inode list addition logic and avoid invalid access to memoryNamjae Jeon
In function find_fsync_dnodes() - the fsync inodes gets added to the list, but in one path suppose f2fs_iget results in error, in such case - error gets added to the fsync inode list. In next call to recover_data()->get_fsync_inode() entry = list_entry(this, struct fsync_inode_entry, list); if (entry->inode->i_ino == ino) This can result in "invalid access to memory" when it encounters 'error' as entry in the fsync inode list. So, add the fsync inode entry to the list only in case of no errors. And, free the object at that point itself in case of issue. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-28f2fs: remove unneeded initialization of nr_dirty in dirty_seglist_infoNamjae Jeon
Since, the memory for the object of dirty_seglist_info is allocated using kzalloc - which returns zeroed out memory. So, there is no need to initialize the nr_dirty values with zeroes. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-28f2fs: handle error from f2fs_iget_nowaitNamjae Jeon
In case f2fs_iget_nowait returns error, it results in truncate_hole being called with 'error' value as inode pointer. There is no check in truncate_hole for valid inode, so it could result in crash due "invalid access to memory". Avoid this by handling error condition properly. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-28f2fs: fix equation of has_not_enough_free_secs()Jaegeuk Kim
Practically, has_not_enough_free_secs() should calculate with the numbers of current node and directory data blocks together. Actually the equation was implemented in need_to_flush(). So, this patch removes need_flush() and moves the equation into has_not_enough_free_secs(). Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-28f2fs: return a default value for non-void functionJaegeuk Kim
This patch resolves a build warning reported by kbuild test robot. " fs/f2fs/segment.c: In function '__get_segment_type': fs/f2fs/segment.c:806:1: warning: control reaches end of non-void function [-Wreturn-type] " Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-28f2fs: invalidate the node page if allocation is failedJaegeuk Kim
The new_node_page() is processed as the following procedure. 1. A new node page is allocated. 2. Set PageUptodate with proper footer information. 3. Check if there is a free space for allocation 4.a. If there is no space, f2fs returns with -ENOSPC. 4.b. Otherwise, go next. In the case of step #4.a, f2fs remains a wrong node page in the page cache with the uptodate flag. Also, even though a new node page is allocated successfully, an error can be occurred afterwards due to allocation failure of the other data structures. In such a case, remove_inode_page() would be triggered, so that we have to clear uptodate flag in truncate_node() too. So, we should remove the uptodate flag, if allocation is failed. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-28f2fs: add missing #include <linux/prefetch.h>Geert Uytterhoeven
m68k allmodconfig: fs/f2fs/data.c: In function ‘read_end_io’: fs/f2fs/data.c:311: error: implicit declaration of function ‘prefetchw’ fs/f2fs/segment.c: In function ‘f2fs_end_io_write’: fs/f2fs/segment.c:628: error: implicit declaration of function ‘prefetchw’ Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-27ext4: avoid hang when mounting non-journal filesystems with orphan listTheodore Ts'o
When trying to mount a file system which does not contain a journal, but which does have a orphan list containing an inode which needs to be truncated, the mount call with hang forever in ext4_orphan_cleanup() because ext4_orphan_del() will return immediately without removing the inode from the orphan list, leading to an uninterruptible loop in kernel code which will busy out one of the CPU's on the system. This can be trivially reproduced by trying to mount the file system found in tests/f_orphan_extents_inode/image.gz from the e2fsprogs source tree. If a malicious user were to put this on a USB stick, and mount it on a Linux desktop which has automatic mounts enabled, this could be considered a potential denial of service attack. (Not a big deal in practice, but professional paranoids worry about such things, and have even been known to allocate CVE numbers for such problems.) Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Zheng Liu <wenqing.lz@taobao.com> Cc: stable@vger.kernel.org
2012-12-27ext4: lock i_mutex when truncating orphan inodesTheodore Ts'o
Commit c278531d39 added a warning when ext4_flush_unwritten_io() is called without i_mutex being taken. It had previously not been taken during orphan cleanup since races weren't possible at that point in the mount process, but as a result of this c278531d39, we will now see a kernel WARN_ON in this case. Take the i_mutex in ext4_orphan_cleanup() to suppress this warning. Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Zheng Liu <wenqing.lz@taobao.com> Cc: stable@vger.kernel.org
2012-12-25f2fs: Don't assign e_id in f2fs_acl_from_diskEric W. Biederman
With user namespaces enabled building f2fs fails with: CC fs/f2fs/acl.o fs/f2fs/acl.c: In function ‘f2fs_acl_from_disk’: fs/f2fs/acl.c:85:21: error: ‘struct posix_acl_entry’ has no member named ‘e_id’ make[2]: *** [fs/f2fs/acl.o] Error 1 make[2]: Target `__build' not remade because of errors. e_id is a backwards compatibility field only used for file systems that haven't been converted to use kuids and kgids. When the posix acl tag field is neither ACL_USER nor ACL_GROUP assigning e_id is unnecessary. Remove the assignment so f2fs will build with user namespaces enabled. Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Amit Sahrawat <a.sahrawat@samsung.com> Acked-by: Jaegeuk Kim <jaegeuk.kim@samsung.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-12-26f2fs: do f2fs_balance_fs in front of dir operationsJaegeuk Kim
In order to conserve free sections to deal with the worst-case scenarios, f2fs should be able to freeze all the directory operations especially when there are not enough free sections. The f2fs_balance_fs() is for this use. When FS utilization becomes almost 100%, directory operations can be failed due to -ENOSPC frequently, which produces some dirty node pages occasionally. Previously, in such a case, f2fs_balance_fs() is not able to be triggered since it is triggered only if the directory operation ends up with success. So, this patch triggers f2fs_balance_fs() at first before handling directory operations. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-26f2fs: should recover orphan and fsync dataJaegeuk Kim
The recovery routine should do all the time regardless of normal umount action. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-26f2fs: fix handling errors got by f2fs_write_inodeJaegeuk Kim
Ruslan reported that f2fs hangs with an infinite loop in f2fs_sync_file(): while (sync_node_pages(sbi, inode->i_ino, &wbc) == 0) f2fs_write_inode(inode, NULL); The reason was revealed that the cold flag is not set even thought this inode is a normal file. Therefore, sync_node_pages() skips to write node blocks since it only writes cold node blocks. The cold flag is stored to the node_footer in node block, and whenever a new node page is allocated, it is set according to its file type, file or directory. But, after sudden-power-off, when recovering the inode page, f2fs doesn't recover its cold flag. So, let's assign the cold flag in more right places. One more thing: If f2fs_write_inode() returns an error due to whatever situations, there would be no dirty node pages so that sync_node_pages() returns zero. (i.e., zero means nothing was written.) Reported-by: Ruslan N. Marchenko <me@ruff.mobi> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-26f2fs: fix up f2fs_get_parent issue to retrieve correct parent inode numberNamjae Jeon
Test Case: [NFS Client] ls -lR . [NFS Server] while [ 1 ] do echo 3 > /proc/sys/vm/drop_caches done Error on NFS Client: "No such file or directory" When cache is dropped at the server, it results in lookup failure at the NFS client due to non-connection with the parent. The default path is it initiates a lookup by calculating the hash value for the name, even though the hash values stored on the disk for "." and ".." is maintained as zero, which results in failure from find_in_block due to not matching HASH values. Fix up, by using the correct hashing values for these entries. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-26f2fs: fix wrong calculation on f_files in statfsJaegeuk Kim
In f2fs_statfs(), f_files should be the total number of available inodes instead of the currently allocated inodes. So, this patch should resolve the reported bug below. Note that, showing 10% usage is not a bug, since f2fs reveals whole volume size as much as possible and shows the space overhead as *used*. This policy is fair enough with respect to other file systems. <Reported Bug> (loop0 is backed by 1GiB file) $ mkfs.f2fs /dev/loop0 F2FS-tools: Ver: 1.1.0 (2012-12-11) Info: sector size = 512 Info: total sectors = 2097152 (in 512bytes) Info: zone aligned segment0 blkaddr: 512 Info: format successful $ mount /dev/loop0 mnt/ $ df mnt/ Filesystem 1K-blocks Used Available Use% Mounted on /dev/loop0 1046528 98312 929784 10% /home/zeta/linux-devel/mtd-bench/mnt $ df mnt/ -i Filesystem Inodes IUsed IFree IUse% Mounted on /dev/loop0 1 -465918 465919 - /home/zeta/linux-devel/mtd-bench/mnt Notice IUsed is negative. Also, 10% usage on a fresh f2fs seems too much to be correct. Reported-and-Tested-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
