Drivers that register a ->fault handler, but do not range-check the
offset argument, must set VM_DONTEXPAND in the vm_flags in order to
prevent an expanding mremap from overflowing the resource.
I've audited the tree and attempted to fix these problems (usually by
adding VM_DONTEXPAND where it is not obvious).
Signed-off-by: Nick Piggin <npiggin@suse.de>
vfs: coredumping fix
patch c46f739dd39db3b07ab5deb4e3ec81e1c04a91af in mainline
fix: http://bugzilla.kernel.org/show_bug.cgi?id=3043
only allow coredumping to the same uid that the coredumping
task runs under.
Acked-by: Alan Cox <alan@redhat.com>
Acked-by: Christoph Hellwig <hch@lst.de>
Acked-by: Al Viro <viro@ftp.linux.org.uk>
Cc: maximilian attems <max@stro.at>
(CVE-2008-0001)
patch 974a9f0b47da74e28f68b9c8645c3786aa5ace1a in mainline
Way back when (in commit 834f2a4a1554dc5b2598038b3fe8703defcbe467, aka
"VFS: Allow the filesystem to return a full file pointer on open intent"
to be exact), Trond changed the open logic to keep track of the original
flags to a file open, in order to pass down the the intent of a dentry
lookup to the low-level filesystem.
However, when doing that reorganization, it changed the meaning of
namei_flags, and thus inadvertently changed the test of access mode for
directories (and RO filesystem) to use the wrong flag. So fix those
test back to use access mode ("acc_mode") rather than the open flag
("flag").
Issue noticed by Bill Roman at Datalight.
Reported-and-tested-by: Bill Roman <bill.roman@datalight.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
patch b8da0d1c27f144bce999c653467106f3f0d5a308 in mainline.
fsid_source decided where to get the 'fsid' number to
return for a GETATTR based on the type of filehandle.
It can be from the device, from the fsid, or from the
UUID.
It is possible for the filehandle to be inconsistent
with the export information, so make sure the export information
actually has the info implied by the value returned by
fsid_source.
Signed-off-by: Neil Brown <neilb@suse.de>
Cc: "Luiz Fernando N. Capitulino" <lcapitulino@gmail.com>
Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu>
Cc: Oliver Pintr <oliver.pntr@gmail.com>
ocfs2: fix write() performance regression
patch 4e9563fd55ff4479f2b118d0757d121dd0cfc39c in mainline.
On file systems which don't support sparse files, Ocfs2_map_page_blocks()
was reading blocks on appending writes. This caused write performance to
suffer dramatically. Fix this by detecting an appending write on a nonsparse
fs and skipping the read.
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
patch 44ec6f3f89889a469773b1fd894f8fcc07c29cf in mainline
This attempts to address CVE-2006-6058
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2006-6058
first reported at http://projects.info-pull.com/mokb/MOKB-17-11-2006.html
Essentially a corrupted minix dir inode reporting a very large
i_size will loop for a very long time in minix_readdir, minix_find_entry,
etc, because on EIO they just move on to try the next page. This is
under the BKL, printk-storming as well. This can lock up the machine
for a very long time. Simply ratelimiting the printks gets things back
under control. Make the message a bit more informative while we're here.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Cc: Bodo Eggert <7eggert@gmx.de>
changeset a6d85430424d44e946e0946bfaad607115510989 in upstream
The recent fix for a circular lock dependency unfortunately introduced a
potential memory leak in the event where the call to nlmsvc_lookup_host
fails for some reason.
Thanks to Roel Kluin for spotting this.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 255129d1e9ca0ed3d69d5517fae3e03d7ab4b806 in upstream.
The problem is that the garbage collector for the 'host' structures
nlm_gc_hosts(), holds nlm_host_mutex while calling down to
nlmsvc_mark_resources, which, eventually takes the file->f_mutex.
We cannot therefore call nlmsvc_lookup_host() from within
nlmsvc_create_block, since the caller will already hold file->f_mutex, so
the attempt to grab nlm_host_mutex may deadlock.
Fix the problem by calling nlmsvc_lookup_host() outside the file->f_mutex.
commit 3d82abae9523c33d4a16fdfdfd2bdde316d7b56a in mainline.
Convert asserts (BUGs) in dx_probe from bad on-disk data to recoverable
errors with helpful warnings. With help catching other asserts from Duane
Griffin <duaneg@dghda.com>
Acked-by: Duane Griffin <duaneg@dghda.com>
Acked-by: Theodore Ts'o <tytso@mit.edu>
commit 49af7ee181f4f516ac99eba85d3f70ed42cabe76 in mainline.
NFS unregisters sysctls only if V4 support is compiled in. However, sysctl
table is not V4 specific, so unregister it always.
Steps to reproduce:
[build nfs.ko with CONFIG_NFS_V4=n]
modrobe nfs
rmmod nfs
ls /proc/sys
Unable to handle kernel paging request at ffffffff880661c0 RIP:
[<ffffffff802af8e3>] proc_sys_readdir+0xd3/0x350
PGD 203067 PUD 207063 PMD 7e216067 PTE 0
Oops: 0000 [1] SMP
CPU 1
Modules linked in: lockd nfs_acl sunrpc
Pid: 3335, comm: ls Not tainted 2.6.23-rc3-bloat #2
RIP: 0010:[<ffffffff802af8e3>] [<ffffffff802af8e3>] proc_sys_readdir+0xd3/0x350
RSP: 0018:ffff81007fd93e78 EFLAGS: 00010286
RAX: ffffffff880661c0 RBX: ffffffff80466370 RCX: ffffffff880661c0
RDX: 00000000000014c0 RSI: ffff81007f3ad020 RDI: ffff81007efd8b40
RBP: 0000000000000018 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: ffffffff802a8570 R12: ffffffff880661c0
R13: ffff81007e219640 R14: ffff81007efd8b40 R15: ffff81007ded7280
FS: 00002ba25ef03060(0000) GS:ffff81007ff81258(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffffffff880661c0 CR3: 000000007dfaf000 CR4: 00000000000006e0
Process ls (pid: 3335, threadinfo ffff81007fd92000, task ffff81007d8a0000)
Stack: ffff81007f3ad150 ffffffff80283f30 ffff81007fd93f48 ffff81007efd8b40
ffff81007ee00440 0000000422222222 0000000200035593 ffffffff88037e9a
2222222222222222 ffffffff80466500 ffff81007e416400 ffff81007e219640
Call Trace:
[<ffffffff80283f30>] filldir+0x0/0xf0
[<ffffffff802840c7>] vfs_readdir+0xa7/0xc0
[<ffffffff80284376>] sys_getdents+0x96/0xe0
[<ffffffff8020bb3e>] system_call+0x7e/0x83
Code: 41 8b 14 24 85 d2 74 dc 49 8b 44 24 08 48 85 c0 74 e7 49 3b
RIP [<ffffffff802af8e3>] proc_sys_readdir+0xd3/0x350
RSP <ffff81007fd93e78>
Kernel panic - not syncing: Fatal exception
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
commit ef2b02d3e617cb0400eedf2668f86215e1b0e6af in mainline.
The do_split() function for htree dir blocks is intended to split a leaf
block to make room for a new entry. It sorts the entries in the original
block by hash value, then moves the last half of the entries to the new
block - without accounting for how much space this actually moves. (IOW,
it moves half of the entry *count* not half of the entry *space*). If by
chance we have both large & small entries, and we move only the smallest
entries, and we have a large new entry to insert, we may not have created
enough space for it.
The patch below stores each record size when calculating the dx_map, and
then walks the hash-sorted dx_map, calculating how many entries must be
moved to more evenly split the existing entries between the old block and
the new block, guaranteeing enough space for the new entry.
The dx_map "offs" member is reduced to u16 so that the overall map size
does not change - it is temporarily stored at the end of the new block, and
if it grows too large it may be overwritten. By making offs and size both
u16, we won't grow the map size.
Also add a few comments to the functions involved.
This fixes the testcase reported by hooanon05@yahoo.co.jp on the
linux-ext4 list, "ext3 dir_index causes an error"
Thanks to Andreas Dilger for discussing the problem & solution with me.
Signed-off-by: Andreas Dilger <adilger@clusterfs.com>
Tested-by: Junjiro Okajima <hooanon05@yahoo.co.jp>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: ext4 <linux-ext4@vger.kernel.org>
commit 0e2f6db88a6900bc9db576d6b478b12ee60d61f7 in mainline.
The inode->i_flock list contains the leases, flocks and posix
locks in the specified order. However, the flocks are added in
the head of this list thus hiding the leases from F_GETLEASE
command, from time_out_leases() and other code that expects
the leases to come first.
The following example will demonstrate this:
#define _GNU_SOURCE
#include <unistd.h>
#include <fcntl.h>
#include <stdio.h>
#include <sys/file.h>
static void show_lease(int fd)
int res;
res = fcntl(fd, F_GETLEASE);
switch (res) {
case F_RDLCK:
printf("Read lease\n");
break;
case F_WRLCK:
printf("Write lease\n");
break;
case F_UNLCK:
printf("No leases\n");
break;
default:
printf("Some shit\n");
break;
int main(int argc, char **argv)
int fd, res;
fd = open(argv[1], O_RDONLY);
if (fd == -1) {
perror("Can't open file");
return 1;
res = fcntl(fd, F_SETLEASE, F_WRLCK);
if (res == -1) {
perror("Can't set lease");
return 1;
show_lease(fd);
if (flock(fd, LOCK_SH) == -1) {
perror("Can't flock shared");
return 1;
show_lease(fd);
return 0;
The first call to show_lease() will show the write lease set, but
the second will show no leases.
Fix the flock adding so that the leases always stay in the head
of this list.
Found during making the flocks pid-namespaces aware.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
commit 1a1a1a758bf0107d1f78ff1d622f45987803d894 in mainline.
dput must be called before mntput here.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Acked-By: David Howells <dhowells@redhat.com>
This is a splice patch for 2.6.22 and 2.6.21 (and earlier, I did not
check. Let me know if you still maintain older stable trees!). It fixes
an infinite loop in do_splice_direct(), when there's either nothing to
read or nothing to write and blocking doesn't help. It could be things
like running out of disk space. We need to exit both for failure and
zero return, or we could be going around forever.
This got fixed in 2.6.23-git with commit 51a92c0f6ce8fa85fa0e18ecda1d847e606e8066
Herbert Poetzl <herbert@13thfloor.at> noticed this bug in 2.6.22, and
has verified that this minimal fix works.
Changeset fc0e01974ccccc7530b7634a63ee3fcc57b845ea from mainline.
I've bisected the deadlock when many small appends are done on jffs2 down to
this commit:
commit 6fe6900e1e5b6fa9e5c59aa5061f244fe3f467e2
Author: Nick Piggin <npiggin@suse.de>
Date: Sun May 6 14:49:04 2007 -0700
mm: make read_cache_page synchronous
Ensure pages are uptodate after returning from read_cache_page, which allows
us to cut out most of the filesystem-internal PageUptodate calls.
I didn't have a great look down the call chains, but this appears to fixes 7
possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in
ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in
block2mtd. All depending on whether the filler is async and/or can return
with a !uptodate page.
It introduced a wait to read_cache_page, as well as a
read_cache_page_async function equivalent to the old read_cache_page
without any callers.
Switching jffs2_gc_fetch_page to read_cache_page_async for the old
behavior makes the deadlocks go away, but maybe reintroduces the
use-before-uptodate problem? I don't understand the mm/fs interaction
well enough to say.
[It's fine. dwmw2.]
Signed-off-by: Jason Lunz <lunz@falooley.org>
With this patch any thread can dequeue its own private signals via signalfd,
even if it was created by another sub-thread.
To do so, we pass "current" to dequeue_signal() if the caller is from the same
thread group. This also fixes the scheduling of posix timers broken by the
previous patch.
If the caller doesn't belong to this thread group, we can't handle __SI_TIMER
case properly anyway. Perhaps we should forbid the cross-process signalfd usage
and convert ctx->tsk to ctx->sighand.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Cc: Roland McGrath <roland@redhat.com>
[PATCH] ocfs2: Fix bad source start calculation during kernel writes
For in-kernel writes ocfs2_get_write_source() should be starting the buffer
at a page boundary as the math in ocfs2_map_and_write_user_data() will pad
it back out to the correct write offset. Instead, we were passing the raw
offset, which caused ocfs2_map_and_write_user_data() start too far into the
buffer, resulting in corruptions from nfs client writes.
Commit a491486a2087ac3dfc00efb4f838c8d684afaf54 introduced a locking
problem in JFFS2 -- we up() the alloc_sem when we weren't previously
holding it. This leads to all kinds of fun behaviour later.
There was a _reason_ for the
if (1 /* alternative path needs testing */ ||
which the above-mentioned commit removed :)
Discovered and debugged by Giulio Fedel <giulio.fedel@andorsystems.com>
This fixes a vulnerability in the "parent process death signal"
implementation discoverd by Wojciech Purczynski of COSEINC PTE Ltd.
and iSEC Security Research.
http://marc.info/?l=bugtraq&m=118711306802632&w=2
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Need to initialize map_bh.b_state to zero. Otherwise, in case of a faulty
user-buffer its possible to go into dio_zero_block() and submit a page by
mistake - since it checks for buffer_new().
http://marc.info/?l=linux-kernel&m=118551339032528&w=2
akpm: Linus had a (better) patch to just do a kzalloc() in there, but it got
lost. Probably this version is better for -stable anwyay.
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
Acked-by: Joe Jin <joe.jin@oracle.com>
Acked-by: Zach Brown <zach.brown@oracle.com>
Cc: gurudas pai <gurudas.pai@oracle.com>
We have to check that also the second checkpoint list is non-empty before
dropping the transaction.
Cc: Chuck Ebbert <cebbert@redhat.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: <linux-ext4@vger.kernel.org>
When buf_check_overflow() returns != 0 we will hit kfree(ERR_PTR(err))
and it will not be happy about it.
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
The value of nperbucket calculated here is too small--we should be rounding up
instead of down--with the result that the index j in the following loop can
overflow the raparm_hash array. At least in my case, the next thing in memory
turns out to be export_table, so the symptoms I see are crashes caused by the
appearance of four zeroed-out export entries in the first bucket of the hash
table of exports (which were actually entries in the readahead cache, a
pointer to which had been written to the export table in this initialization
code).
It looks like the bug was probably introduced with commit
fce1456a19f5c08b688c29f00ef90fdfa074c79b ("knfsd: make the readahead params
cache SMP-friendly").
Cc: Greg Banks <gnb@melbourne.sgi.com>
Acked-by: NeilBrown <neilb@suse.de>
There is another bug recently introduced into the ecryptfs_setattr()
function in 2.6.22. eCryptfs will attempt to treat special files like
regular eCryptfs files on chmod, chown, and so forth. This leads to a NULL
pointer dereference. This patch validates that the file is a regular file
before proceeding with operations related to the inode's crypt_stat.
Thanks to Ryusuke Konishi for finding this bug and suggesting the fix.
Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com>
Yan Zheng wrote:
> I think I found a bug in ext4/extents.c, "ext4_ext_put_in_cache" uses
> "__u32" to receive physical block number. "ext4_ext_put_in_cache" is
> used in "ext4_ext_get_blocks", it sets ext4 inode's extent cache
> according most recently tree lookup (higher 16 bits of saved physical
> block number are always zero). when serving a mapping request,
> "ext4_ext_get_blocks" first check whether the logical block is in
> inode's extent cache. if the logical block is in the cache and the
> cached region isn't a gap, "ext4_ext_get_blocks" gets physical block
> number by using cached region's physical block number and offset in
> the cached region. as described above, "ext4_ext_get_blocks" may
> return wrong result when there are physical block numbers bigger than
> 0xffffffff.
You are right. Thanks for reporting this!
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
Cc: Yan Zheng <yanzheng@21cn.com>
If add_to_page_cache_lru() fails, the page will not be locked. But
splice jumps to an error path that does a page release and unlock,
causing a BUG() in unlock_page().
Fix this by adding one more label that just releases the page. This bug
was actually triggered on EL5 by gurudas pai <gurudas.pai@oracle.com>
using fio.
Davi fixed a missing cast in the __put_user(), that was making timerfd
return a single byte instead of the full value.
Talking with Michael about the timerfd man page, we think it'd be better to
use a u64 for the returned value, to align it with the eventfd
implementation.
This is an ABI change. The timerfd code is new in 2.6.22 and if we merge this
into 2.6.23 then we should also merge it into 2.6.22.x. That will leave a few
early 2.6.22 kernels out in the wild which might misbehave when a future
timerfd-enabled glibc is run on them.
mtk says:
The difference would be that read() will only return 4 bytes,
while the application will expect 8. If the application is
checking the size of returned value, as it should, then it will
be able to detect the problem (it could even be sophisticated
enough to know that if this is a 4-byte return, then it is
running on an old 2.6.22 kernel). If the application is not
checking the return from read(), then its 8-byte buffer will not
be filled -- the contents of the last 4 bytes will be undefined,
so the u64 value as a whole will be junk.
When I wrote up that description above, I forgot a crucial
detail. The above description described the difference between
the new behavior implemented by the patch, and the current
(i.e., 2.6.22) *intended* behavior. However, as I originally
remarked to Davide, the 2.6.22 read() behavior is broken: it
should return 4 bytes on a read(), but as originally
implemented, only the least significant byte contained valid
information. (In other words, the top 3 bytes of overrun
information were simply being discarded.)
So the patch both fixes a bug in the originally intended
behavior, and changes the intended behavior (to return 8 bytes
from a read() instead of 4).
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Davi Arnaut <davi@haxent.com.br>
Commit 1c710c896eb461895d3c399e15bb5f20b39c9073 added the utimensat()
system call, but didn't handle the case of checking for the writability
of the target right, when the target was a file descriptor, not a
filename.
We cannot use vfs_permission(MAY_WRITE) for that case, and need to
simply check whether the file descriptor is writable. The oops from
using the wrong function was noticed and narrowed down by Markus
Trippelsdorf.
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
The dependency of DLM on SYSFS got lost in
commit 6ed7257b46709e87d79ac2b6b819b7e0c9184998 resulting in the
following compile error with CONFIG_DLM=y, CONFIG_SYSFS=n:
<-- snip -->
LD .tmp_vmlinux1
fs/built-in.o: In function `dlm_lockspace_init':
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/fs/dlm/lockspace.c:231: undefined reference to `kernel_subsys'
fs/built-in.o: In function `configfs_init':
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/fs/configfs/mount.c:143: undefined reference to `kernel_subsys'
make[1]: *** [.tmp_vmlinux1] Error 1
<-- snip -->
elf_core_dump() supports dumping arch specific ELF notes, via the #define
ELF_CORE_WRITE_EXTRA_NOTES. Currently the only user of this is the powerpc
spu coredump code.
There is a bug in the handling of foffset WRT the arch notes, which causes
us to erroneously increment foffset by the size of the arch notes, leaving
a block of zeroes in the file, and causing all subsequent data in the file
to be at <supposed position> + <arch note size>. eg:
LOAD 0x050000 0x00100000 0x00000000 0x20000 0x20000 R E 0x10000
Tells us we should have a chunk of data at 0x50000. The truth is the data
is at 0x90dbc = 0x50000 + 0x40dbc (the size of the arch notes).
This bug prevents gdb from reading the core file correctly.
The simplest fix is to simply remember the size of the arch notes, and add
it to foffset after we've written the arch notes. The only drawback is
that if the arch code doesn't write as many bytes as it said it would, we
end up with a broken core dump again. For now I think that's a reasonable
requirement.
Tested on a Cell blade, gdb no longer complains about the core file being
bogus.
While I'm here I should point out that the spu coredump code does not work
if we're dumping to a pipe - we'll have to wait for 23 to fix that.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Paul Mackerras <paulus@samba.org>
We should have stopped returning 1 from read_dnode() to indicate
failure. We can just mark the damn thing obsolete immediately. But I
missed a case where we don't.
Badari Pulavarty reported a case of this BUG_ON is triggering during
testing. It's completely bogus and should be removed.
It's trying to notice if we left references to the dio hanging around in
the sync case. They should have been dropped as IO completed while this
path was in dio_await_completion(). This condition will also be
checked, via some twisty logic, by the BUG_ON(ret != -EIOCBQUEUED) a few
lines lower. So to start this BUG_ON() is redundant.
More fatally, it's dereferencing dio-> after having dropped its
reference. It's only safe to dereference the dio after releasing the
lock if the final reference was just dropped. Another CPU might free
the dio in bio completion and reuse the memory after this path drops the
dio lock but before the BUG_ON() is evaluated.
This patch passed aio+dio regression unit tests and aio-stress on ext3.
Signed-off-by: Zach Brown <zach.brown@oracle.com>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Not all the world is an i386. Many architectures need 64-bit arguments to be
aligned in suitable pairs of registers, and the original
sys_sync_file_range(int, loff_t, loff_t, int) was therefore wasting an
argument register for padding after the first integer. Since we don't
normally have more than 6 arguments for system calls, that left no room for
the final argument on some architectures.
Fix this by introducing sys_sync_file_range2(int, int, loff_t, loff_t) which
all fits nicely. In fact, ARM already had that, but called it
sys_arm_sync_file_range. Move it to fs/sync.c and rename it, then implement
the needed compatibility routine. And stop the missing syscall check from
bitching about the absence of sys_sync_file_range() if we've implemented
sys_sync_file_range2() instead.
Tested on PPC32 and with 32-bit and 64-bit userspace on PPC64.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
gcc correctly says
fs/ext2/super.c: In function 'ext2_remount':
fs/ext2/super.c:1055: warning: 'err' may be used uninitialized in this function
The new code in kernel/signal.c does not allow fetching private signals
from another task. This patch avoid spurious POLLIN returns from a
signalfd poll(2) operation.
Cc: Oleg Nesterov <oleg@tv-sign.ru>
When one llseek's past the end of the file and then writes, every page past
the previous end of the file should be cleared. Trevor found that the code,
as is, does not assure that the very last page is always cleared. This patch
takes care of that.
Recent changes in eCryptfs have made it possible to get to ecryptfs_setattr()
with an uninitialized crypt_stat struct. This results in a wide and colorful
variety of unpleasantries. This patch properly initializes the crypt_stat
structure in ecryptfs_setattr() when it is necessary to do so.
This patch fixes the processes involved in wiping regions of the data during
truncate and write events, fixing a kernel hang in 2.6.22-rc4 while assuring
that zero values are written out to the appropriate locations during events in
which the i_size will change.
The range passed to ecryptfs_truncate() from ecryptfs_prepare_write() includes
the page that is the object of ecryptfs_prepare_write(). This leads to a
kernel hang as read_cache_page() is executed on the same page in the
ecryptfs_truncate() execution path. This patch remedies this by limiting the
range passed to ecryptfs_truncate() so as to exclude the page that is the
object of ecryptfs_prepare_write(); it also adds code to
ecryptfs_prepare_write() to zero out the region of its own page when writing
past the i_size position. This patch also modifies ecryptfs_truncate() so
that when a file is truncated to a smaller size, eCryptfs will zero out the
contents of the new last page from the new size through to the end of the last
page.
One of error path in ext4_read_inode() leaks bh since brelse is forgoten.
Signed-off-by: Kirill Korotaev <dev@openvz.org>
Acked-by: Vasily Averin <vvs@sw.ru>
One of error path in ext3_read_inode() leaks bh since brelse is forgoten.
Yan Zheng pointed out that ext2_remount lacks checking if -o xip should be
enabled or not. This patch checks for presence of direct_access on the
backing block device and if the blocksize meets the requirements.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
SGI-PV: 957103
SGI-Modid: xfs-linux-melb:xfs-kern:28678a
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Tim Shimmin <tes@sgi.com>
Some user space tools need to identify SYSV shared memory when examining
/proc/<pid>/maps. To do so they look for a block device with major zero, a
dentry named SYSV<sysv key>, and having the minor of the internal sysv
shared memory kernel mount.
To help these tools and to make it easier for people just browsing
/proc/<pid>/maps this patch modifies hugetlb sysv shared memory to use the
SYSV<key> dentry naming convention.
User space tools will still have to be aware that hugetlb sysv shared
memory lives on a different internal kernel mount and so has a different
block device minor number from the rest of sysv shared memory.
Cc: "Serge E. Hallyn" <serge@hallyn.com>
Cc: Albert Cahalan <acahalan@gmail.com>
We have to take care that when we call udf_discard_prealloc() from
udf_clear_inode() we have to write inode ourselves afterwards (otherwise,
some changes might be lost leading to leakage of blocks, use of free blocks
or improperly aligned extents).
Also udf_discard_prealloc() does two different things - it removes
preallocated blocks and truncates the last extent to exactly match i_size.
We move the latter functionality to udf_truncate_tail_extent(), call
udf_discard_prealloc() when last reference to a file is dropped and call
udf_truncate_tail_extent() when inode is being removed from inode cache
(udf_clear_inode() call).
We cannot call udf_truncate_tail_extent() earlier as subsequent open+write
would find the last block of the file mapped and happily write to the end
of it, although the last extent says it's shorter.
[akpm@linux-foundation.org: Make checkpatch.pl happier]
Cc: Eric Sandeen <sandeen@sandeen.net>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
fs/fuse/inode.c:658:3: error: Initializer entry defined twice
fs/fuse/inode.c:661:3: also defined here
Acked-by: Miklos Szeredi <mszeredi@suse.cz>
We only ever set do_wakeup to non-zero if the pipe has an inode
backing, so it's pointless to check outside the pipe->inode
check.
If the destination pipe is full and we already transferred
data, we break out instead of waiting for more pipe room.
The exit logic looks at spd->nr_pages to see if we moved
everything inside the spd container, but we decrement that
variable in the loop to decide when spd has emptied.
Instead we want to compare to the original page count in
the spd, so cache that in a local variable.
As we have potentially dirtied more than 1 page, we should indicate as
such to the dirty page balancing. So call
balance_dirty_pages_ratelimited_nr() and pass in the approximate number
of pages we dirtied.
