This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
[ Upstream commit fe5e7ba11fcf1d75af8173836309e8562aefedef ]
Commit 9287c6452d2b fixed a situation in which gfs2 could use a glock
after it had been freed. To do that, it temporarily added a new glock
reference by calling gfs2_glock_hold in function gfs2_add_revoke.
However, if the bd element was removed by gfs2_trans_remove_revoke, it
failed to drop the additional reference.
This patch adds logic to gfs2_trans_remove_revoke to properly drop the
additional glock reference.
Fixes: 9287c6452d2b ("gfs2: Fix occasional glock use-after-free")
Cc: stable@vger.kernel.org # v5.2+
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
commit 565333a1554d704789e74205989305c811fd9c7a upstream.
No need to wait for any commit once the page is fully truncated.
Besides, it may confuse e.g. concurrent ext4_writepage() with the page
still be dirty (will be cleared by truncate_pagecache() in
ext4_setattr()) but buffers has been freed; and then trigger a bug
show as below:
[ 26.057508] ------------[ cut here ]------------
[ 26.058531] kernel BUG at fs/ext4/inode.c:2134!
[ 26.088130] Call trace:
[ 26.088695] ext4_writepage+0x914/0xb28
[ 26.089541] writeout.isra.4+0x1b4/0x2b8
[ 26.090409] move_to_new_page+0x3b0/0x568
[ 26.091338] __unmap_and_move+0x648/0x988
[ 26.092241] unmap_and_move+0x48c/0xbb8
[ 26.093096] migrate_pages+0x220/0xb28
[ 26.093945] kernel_mbind+0x828/0xa18
[ 26.094791] __arm64_sys_mbind+0xc8/0x138
[ 26.095716] el0_svc_common+0x190/0x490
[ 26.096571] el0_svc_handler+0x60/0xd0
[ 26.097423] el0_svc+0x8/0xc
Run the procedure (generate by syzkaller) parallel with ext3.
void main()
int fd, fd1, ret;
void *addr;
size_t length = 4096;
int flags;
off_t offset = 0;
char *str = "12345";
fd = open("a", O_RDWR | O_CREAT);
assert(fd >= 0);
/* Truncate to 4k */
ret = ftruncate(fd, length);
assert(ret == 0);
/* Journal data mode */
flags = 0xc00f;
ret = ioctl(fd, _IOW('f', 2, long), &flags);
assert(ret == 0);
/* Truncate to 0 */
fd1 = open("a", O_TRUNC | O_NOATIME);
assert(fd1 >= 0);
addr = mmap(NULL, length, PROT_WRITE | PROT_READ,
MAP_SHARED, fd, offset);
assert(addr != (void *)-1);
memcpy(addr, str, 5);
mbind(addr, length, 0, 0, 0, MPOL_MF_MOVE);
And the bug will be triggered once we seen the below order.
reproduce1 reproduce2
truncate to 4k |
change to journal data mode |
| memcpy(set page dirty)
truncate to 0: |
ext4_setattr: |
ext4_wait_for_tail_page_commit |
| mbind(trigger bug)
truncate_pagecache(clean dirty)| ...
mbind will call ext4_writepage() since the page still be dirty, and then
report the bug since the buffers has been free. Fix it by return
directly once offset equals to 0 which means the page has been fully
truncated.
Signed-off-by: yangerkun <yangerkun@huawei.com>
Link: https://lore.kernel.org/r/20190919063508.1045-1-yangerkun@huawei.com
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit c7df4a1ecb8579838ec8c56b2bb6a6716e974f37 upstream.
If the file system is corrupted such that a file's i_links_count is
too small, then it's possible that when unlinking that file, i_nlink
will already be zero. Previously we were working around this kind of
corruption by forcing i_nlink to one; but we were doing this before
trying to delete the directory entry --- and if the file system is
corrupted enough that ext4_delete_entry() fails, then we exit with
i_nlink elevated, and this causes the orphan inode list handling to be
FUBAR'ed, such that when we unmount the file system, the orphan inode
list can get corrupted.
A better way to fix this is to simply skip trying to call drop_nlink()
if i_nlink is already zero, thus moving the check to the place where
it makes the most sense.
https://bugzilla.kernel.org/show_bug.cgi?id=205433
Link: https://lore.kernel.org/r/20191112032903.8828-1-tytso@mit.edu
Cc: stable@kernel.org
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
commit 60e4cf67a582d64f07713eda5fcc8ccdaf7833e6 upstream.
Since commit d0a5b995a308 (vfs: Add IOP_XATTR inode operations flag)
extended attributes haven't worked on the root directory in reiserfs.
This is due to reiserfs conditionally setting the sb->s_xattrs handler
array depending on whether it located or create the internal privroot
directory. It necessarily does this after the root inode is already
read in. The IOP_XATTR flag is set during inode initialization, so
it never gets set on the root directory.
This commit unconditionally assigns sb->s_xattrs and clears IOP_XATTR on
internal inodes. The old return values due to the conditional assignment
are handled via open_xa_root, which now returns EOPNOTSUPP as the VFS
would have done.
Link: https://lore.kernel.org/r/20191024143127.17509-1-jeffm@suse.com
CC: stable@vger.kernel.org
Fixes: d0a5b995a308 ("vfs: Add IOP_XATTR inode operations flag")
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 65db869c754e7c271691dd5feabf884347e694f5 upstream.
Estimate for the number of credits needed for final freeing of inode in
ext4_evict_inode() was to small. We may modify 4 blocks (inode & sb for
orphan deletion, bitmap & group descriptor for inode freeing) and not
just 3.
[ Fixed minor whitespace nit. -- TYT ]
Fixes: e50e5129f384 ("ext4: xattr-in-inode support")
Link: https://lore.kernel.org/r/20191105164437.32602-6-jack@suse.cz
commit 6ff33d99fc5c96797103b48b7b0902c296f09c05 upstream.
Write only quotas which are dirty at entry.
XFSTEST: https://github.com/dmonakhov/xfstests/commit/b10ad23566a5bf75832a6f500e1236084083cddc
Link: https://lore.kernel.org/r/20191031103920.3919-1-dmonakhov@openvz.org
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Signed-off-by: Dmitry Monakhov <dmtrmonakhov@yandex-team.ru>
commit e705f4b8aa27a59f8933e8f384e9752f052c469c upstream.
Check err when partial == NULL is meaningless because
partial == NULL means getting branch successfully without
error.
Link: https://lore.kernel.org/r/20191105045100.7104-1-cgxu519@mykernel.net
Signed-off-by: Chengguang Xu <cgxu519@mykernel.net>
commit df4bb5d128e2c44848aeb36b7ceceba3ac85080d upstream.
There is a race window where quota was redirted once we drop dq_list_lock inside dqput(),
but before we grab dquot->dq_lock inside dquot_release()
TASK1 TASK2 (chowner)
->dqput()
we_slept:
spin_lock(&dq_list_lock)
if (dquot_dirty(dquot)) {
spin_unlock(&dq_list_lock);
dquot->dq_sb->dq_op->write_dquot(dquot);
goto we_slept
if (test_bit(DQ_ACTIVE_B, &dquot->dq_flags)) {
dquot->dq_sb->dq_op->release_dquot(dquot);
dqget()
mark_dquot_dirty()
dqput()
goto we_slept;
So dquot dirty quota will be released by TASK1, but on next we_sleept loop
we detect this and call ->write_dquot() for it.
XFSTEST: https://github.com/dmonakhov/xfstests/commit/440a80d4cbb39e9234df4d7240aee1d551c36107
Link: https://lore.kernel.org/r/20191031103920.3919-2-dmonakhov@openvz.org
commit 6889ee5a53b8d969aa542047f5ac8acdc0e79a91 upstream.
In ovl_rename(), if new upper is hardlinked to old upper underneath
overlayfs before upper dirs are locked, user will get an ESTALE error
and a WARN_ON will be printed.
Changes to underlying layers while overlayfs is mounted may result in
unexpected behavior, but it shouldn't crash the kernel and it shouldn't
trigger WARN_ON() either, so relax this WARN_ON().
Reported-by: syzbot+bb1836a212e69f8e201a@syzkaller.appspotmail.com
Fixes: 804032fabb3b ("ovl: don't check rename to self")
Cc: <stable@vger.kernel.org> # v4.9+
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit 3e1740993e43116b3bc71b0aad1e6872f6ccf341 upstream.
Testing with the new fsstress support for subvolumes uncovered a pretty
bad problem with rename exchange on subvolumes. We're modifying two
different subvolumes, but we only start the transaction on one of them,
so the other one is not added to the dirty root list. This is caught by
btrfs_cow_block() with a warning because the root has not been updated,
however if we do not modify this root again we'll end up pointing at an
invalid root because the root item is never updated.
Fix this by making sure we add the destination root to the trans list,
the same as we do with normal renames. This fixes the corruption.
Fixes: cdd1fedf8261 ("btrfs: add support for RENAME_EXCHANGE and RENAME_WHITEOUT")
CC: stable@vger.kernel.org # 4.9+
Reviewed-by: Filipe Manana <fdmanana@suse.com>
Signed-off-by: Josef Bacik <josef@toxicpanda.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit fd0ddbe2509568b00df364156f47561e9f469f15 upstream.
Backreference walking, which is used by send to figure if it can issue
clone operations instead of write operations, can be very slow and use
too much memory when extents have many references. This change simply
skips backreference walking when an extent has more than 64 references,
in which case we fallback to a write operation instead of a clone
operation. This limit is conservative and in practice I observed no
signicant slowdown with up to 100 references and still low memory usage
up to that limit.
This is a temporary workaround until there are speedups in the backref
walking code, and as such it does not attempt to add extra interfaces or
knobs to tweak the threshold.
Reported-by: Atemu <atemu.main@gmail.com>
Link: https://lore.kernel.org/linux-btrfs/CAE4GHgkvqVADtS4AzcQJxo0Q1jKQgKaW3JGp3SGdoinVo=C9eQ@mail.gmail.com/T/#me55dc0987f9cc2acaa54372ce0492c65782be3fa
CC: stable@vger.kernel.org # 4.4+
Reviewed-by: Qu Wenruo <wqu@suse.com>
Signed-off-by: Filipe Manana <fdmanana@suse.com>
commit 34b127aecd4fe8e6a3903e10f204a7b7ffddca22 upstream.
The last user of btrfs_bio::flags was removed in commit 326e1dbb5736
("block: remove management of bi_remaining when restoring original
bi_end_io"), remove it.
(Tagged for stable as the structure is heavily used and space savings
are desirable.)
Signed-off-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
write
commit a0e248bb502d5165b3314ac3819e888fdcdf7d9f upstream.
When doing a buffered write it's possible to leave the subv_writers
counter of the root, used for synchronization between buffered nocow
writers and snapshotting. This happens in an exceptional case like the
following:
1) We fail to allocate data space for the write, since there's not
enough available data space nor enough unallocated space for allocating
a new data block group;
2) Because of that failure, we try to go to NOCOW mode, which succeeds
and therefore we set the local variable 'only_release_metadata' to true
and set the root's sub_writers counter to 1 through the call to
btrfs_start_write_no_snapshotting() made by check_can_nocow();
3) The call to btrfs_copy_from_user() returns zero, which is very unlikely
to happen but not impossible;
4) No pages are copied because btrfs_copy_from_user() returned zero;
5) We call btrfs_end_write_no_snapshotting() which decrements the root's
subv_writers counter to 0;
6) We don't set 'only_release_metadata' back to 'false' because we do
it only if 'copied', the value returned by btrfs_copy_from_user(), is
greater than zero;
7) On the next iteration of the while loop, which processes the same
page range, we are now able to allocate data space for the write (we
got enough data space released in the meanwhile);
8) After this if we fail at btrfs_delalloc_reserve_metadata(), because
now there isn't enough free metadata space, or in some other place
further below (prepare_pages(), lock_and_cleanup_extent_if_need(),
btrfs_dirty_pages()), we break out of the while loop with
'only_release_metadata' having a value of 'true';
9) Because 'only_release_metadata' is 'true' we end up decrementing the
root's subv_writers counter to -1 (through a call to
btrfs_end_write_no_snapshotting()), and we also end up not releasing the
data space previously reserved through btrfs_check_data_free_space().
As a consequence the mechanism for synchronizing NOCOW buffered writes
with snapshotting gets broken.
Fix this by always setting 'only_release_metadata' to false at the start
of each iteration.
Fixes: 8257b2dc3c1a ("Btrfs: introduce btrfs_{start, end}_nocow_write() for each subvolume")
Fixes: 7ee9e4405f26 ("Btrfs: check if we can nocow if we don't have data space")
Reviewed-by: Josef Bacik <josef@toxicpanda.com>
commit baf320b9d531f1cfbf64c60dd155ff80a58b3796 upstream.
We hit the following warning while running down a different problem
[ 6197.175850] ------------[ cut here ]------------
[ 6197.185082] refcount_t: underflow; use-after-free.
[ 6197.194704] WARNING: CPU: 47 PID: 966 at lib/refcount.c:190 refcount_sub_and_test_checked+0x53/0x60
[ 6197.521792] Call Trace:
[ 6197.526687] __btrfs_release_delayed_node+0x76/0x1c0
[ 6197.536615] btrfs_kill_all_delayed_nodes+0xec/0x130
[ 6197.546532] ? __btrfs_btree_balance_dirty+0x60/0x60
[ 6197.556482] btrfs_clean_one_deleted_snapshot+0x71/0xd0
[ 6197.566910] cleaner_kthread+0xfa/0x120
[ 6197.574573] kthread+0x111/0x130
[ 6197.581022] ? kthread_create_on_node+0x60/0x60
[ 6197.590086] ret_from_fork+0x1f/0x30
[ 6197.597228] ---[ end trace 424bb7ae00509f56 ]---
This is because the free side drops the ref without the lock, and then
takes the lock if our refcount is 0. So you can have nodes on the tree
that have a refcount of 0. Fix this by zero'ing out that element in our
temporary array so we don't try to kill it again.
CC: stable@vger.kernel.org # 4.14+
Reviewed-by: Nikolay Borisov <nborisov@suse.com>
[ add comment ]
commit 3797136b626ad4b6582223660c041efdea8f26b2 upstream.
While testing 5.2 we ran into the following panic
[52238.017028] BUG: kernel NULL pointer dereference, address: 0000000000000001
[52238.105608] RIP: 0010:drop_buffers+0x3d/0x150
[52238.304051] Call Trace:
[52238.308958] try_to_free_buffers+0x15b/0x1b0
[52238.317503] shrink_page_list+0x1164/0x1780
[52238.325877] shrink_inactive_list+0x18f/0x3b0
[52238.334596] shrink_node_memcg+0x23e/0x7d0
[52238.342790] ? do_shrink_slab+0x4f/0x290
[52238.350648] shrink_node+0xce/0x4a0
[52238.357628] balance_pgdat+0x2c7/0x510
[52238.365135] kswapd+0x216/0x3e0
[52238.371425] ? wait_woken+0x80/0x80
[52238.378412] ? balance_pgdat+0x510/0x510
[52238.386265] kthread+0x111/0x130
[52238.392727] ? kthread_create_on_node+0x60/0x60
[52238.401782] ret_from_fork+0x1f/0x30
The page we were trying to drop had a page->private, but had no
page->mapping and so called drop_buffers, assuming that we had a
buffer_head on the page, and then panic'ed trying to deref 1, which is
our page->private for data pages.
This is happening because we're truncating the free space cache while
we're trying to load the free space cache. This isn't supposed to
happen, and I'll fix that in a followup patch. However we still
shouldn't allow those sort of mistakes to result in messing with pages
that do not belong to us. So add the page->mapping check to verify that
we still own this page after dropping and re-acquiring the page lock.
This page being unlocked as:
btrfs_readpage
extent_read_full_page
__extent_read_full_page
__do_readpage
if (!nr)
unlock_page <-- nr can be 0 only if submit_extent_page
returns an error
[ add callchain ]
commit 419e9c38aa075ed0cd3c13d47e15954b686bcdb6 upstream.
When splicing using iomap_dio_rw() to a pipe, we may leak pipe pages
because bio_iov_iter_get_pages() records that the pipe will have full
extent worth of data however if file size is not block size aligned
iomap_dio_rw() returns less than what bio_iov_iter_get_pages() set up
and splice code gets confused leaking a pipe page with the file tail.
Handle the situation similarly to the old direct IO implementation and
revert iter to actually returned read amount which makes iter consistent
with value returned from iomap_dio_rw() and thus the splice code is
happy.
Fixes: ff6a9292e6f6 ("iomap: implement direct I/O")
Reported-by: syzbot+991400e8eba7e00a26e1@syzkaller.appspotmail.com
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
commit e23f568aa63f64cd6b355094224cc9356c0f696b upstream.
When the 32bit ino wraps around, kernfs increments the generation
number to distinguish reused ino instances. The wrap-around detection
tests whether the allocated ino is lower than what the cursor but the
cursor is pointing to the next ino to allocate so the condition never
triggers.
Fix it by remembering the last ino and comparing against that.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Fixes: 4a3ef68acacf ("kernfs: implement i_generation")
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: stable@vger.kernel.org # v4.14+
commit fa9c2362497fbd64788063288dc4e74daf977ebb upstream.
Even when mounting modern protocol version the server may be
configured without supporting SMB2.1 leases and the client
uses SMB2 oplock to optimize IO performance through local caching.
However there is a problem in oplock break handling that leads
to missing a break notification on the client who has a file
opened. It latter causes big latencies to other clients that
are trying to open the same file.
The problem reproduces when there are multiple shares from the
same server mounted on the client. The processing code tries to
match persistent and volatile file ids from the break notification
with an open file but it skips all share besides the first one.
Fix this by looking up in all shares belonging to the server that
issued the oplock break.
Cc: Stable <stable@vger.kernel.org>
Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com>
Signed-off-by: Steve French <stfrench@microsoft.com>
commit 6f582b273ec23332074d970a7fb25bef835df71f upstream.
Currently when the client creates a cifsFileInfo structure for
a newly opened file, it allocates a list of byte-range locks
with a pointer to the new cfile and attaches this list to the
inode's lock list. The latter happens before initializing all
other fields, e.g. cfile->tlink. Thus a partially initialized
cifsFileInfo structure becomes available to other threads that
walk through the inode's lock list. One example of such a thread
may be an oplock break worker thread that tries to push all
cached byte-range locks. This causes NULL-pointer dereference
in smb2_push_mandatory_locks() when accessing cfile->tlink:
[598428.945633] BUG: kernel NULL pointer dereference, address: 0000000000000038
[598428.945749] Workqueue: cifsoplockd cifs_oplock_break [cifs]
[598428.945793] RIP: 0010:smb2_push_mandatory_locks+0xd6/0x5a0 [cifs]
[598428.945834] Call Trace:
[598428.945870] ? cifs_revalidate_mapping+0x45/0x90 [cifs]
[598428.945901] cifs_oplock_break+0x13d/0x450 [cifs]
[598428.945909] process_one_work+0x1db/0x380
[598428.945914] worker_thread+0x4d/0x400
[598428.945921] kthread+0x104/0x140
[598428.945925] ? process_one_work+0x380/0x380
[598428.945931] ? kthread_park+0x80/0x80
[598428.945937] ret_from_fork+0x35/0x40
Fix this by reordering initialization steps of the cifsFileInfo
structure: initialize all the fields first and then add the new
byte-range lock list to the inode's lock list.
Reviewed-by: Aurelien Aptel <aaptel@suse.com>
commit eb59bd17d2fa6e5e84fba61a5ebdea984222e6d5 upstream.
If a filesystem returns negative inode sizes, future reads on the file were
causing the cpu to spin on truncate_pagecache.
Create a helper to validate the attributes. This now does two things:
- check the file mode
- check if the file size fits in i_size without overflowing
Reported-by: Arijit Banerjee <arijit@rubrik.com>
Fixes: d8a5ba45457e ("[PATCH] FUSE - core")
Cc: <stable@vger.kernel.org> # v2.6.14
commit c634da718db9b2fac201df2ae1b1b095344ce5eb upstream.
When adding a new hard link, make sure that i_nlink doesn't overflow.
Fixes: ac45d61357e8 ("fuse: fix nlink after unlink")
Cc: <stable@vger.kernel.org> # v3.4
[ Upstream commit 255fbca65137e25b12bced18ec9a014dc77ecda0 ]
As the man(2) page for utime/utimes states, EPERM is returned when the
second parameter of utime or utimes is not NULL, the caller's effective UID
does not match the owner of the file, and the caller is not privileged.
However, in a NFS directory mounted from knfsd, it will return EACCES
(from nfsd_setattr-> fh_verify->nfsd_permission). This patch fixes
that.
Signed-off-by: zhengbin <zhengbin13@huawei.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[ Upstream commit 8665569e97dd52920713b95675409648986b5b0d ]
Given corruption in the ftrace records, it might be possible to allocate
tmp_prz without assigning prz to it, but still marking it as needing to
be freed, which would cause at least a NULL dereference.
smatch warnings:
fs/pstore/ram.c:340 ramoops_pstore_read() error: we previously assumed 'prz' could be null (see line 255)
https://lists.01.org/pipermail/kbuild-all/2018-December/055528.html
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: 2fbea82bbb89 ("pstore: Merge per-CPU ftrace records into one")
Cc: "Joel Fernandes (Google)" <joel@joelfernandes.org>
[ Upstream commit 3595c559326d0b660bb088a88e22e0ca630a0e35 ]
The warning added in commit 3b0e761ba83
"dlm: print log message when cluster name is not set"
did not account for the fact that lockspaces created
from userland do not supply a cluster name, so bogus
warnings are printed every time a userland lockspace
is created.
Signed-off-by: David Teigland <teigland@redhat.com>
[ Upstream commit b493fd31c0b89d9453917e977002de58bebc3802 ]
__cld_pipe_upcall() emits a "do not call blocking ops when
!TASK_RUNNING" warning due to the dput() call in rpc_queue_upcall().
Fix it by using a completion instead of hand coding the wait.
Signed-off-by: Scott Mayhew <smayhew@redhat.com>
[ Upstream commit f31a89692830061bceba8469607e4e4b0f900159 ]
kmem_cache_destroy(NULL) is safe, so removes NULL check before
freeing the mem. This patch also fix ifnullfree.cocci warnings.
Signed-off-by: Wen Yang <wen.yang99@zte.com.cn>
[ Upstream commit b8db159239b3f51e2b909859935cc25cb3ff3eed ]
We fail to advance the read pointer when reading the stat.oh field that
identifies the lock-holder in a TEST result.
This turns out not to matter if the server is knfsd, which always
returns a zero-length field. But other servers (Ganesha is an example)
may not do this. The result is bad values in fcntl F_GETLK results.
Fix this.
[ Upstream commit 08ac9a3870f6babb2b1fff46118536ca8a71ef19 ]
Allow node type segments also to be GC'd via f2fs ioctl
F2FS_IOC_GARBAGE_COLLECT_RANGE.
Signed-off-by: Sahitya Tummala <stummala@codeaurora.org>
Reviewed-by: Chao Yu <yuchao0@huawei.com>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[ Upstream commit 67b0e42b768c9ddc3fd5ca1aee3db815cfaa635c ]
f2fs_ioc_gc_range skips blocks_per_seg each time, however, f2fs_gc moves
blocks of section each time, so fix it from segment to section.
Signed-off-by: Yunlong Song <yunlong.song@huawei.com>
[ Upstream commit d6c66cd19ef322fe0d51ba09ce1b7f386acab04a ]
When sbi->segs_per_sec > 1, and if some segno has 0 valid blocks before
gc starts, do_garbage_collect will skip counting seg_freed++, and this
will cause seg_freed < sbi->segs_per_sec and finally skip sec_freed++.
Signed-off-by: Chao Yu <yuchao0@huawei.com>
[ Upstream commit b450672fb66b4a991a5b55ee24209ac7ae7690ce ]
If we are doing sub-block dio that extends EOF, we need to zero
the unused tail of the block to initialise the data in it it. If we
do not zero the tail of the block, then an immediate mmap read of
the EOF block will expose stale data beyond EOF to userspace. Found
with fsx running sub-block DIO sizes vs MAPREAD/MAPWRITE operations.
Fix this by detecting if the end of the DIO write is beyond EOF
and zeroing the tail if necessary.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
[ Upstream commit 8fc6ed9a3508a0435b9270c313600799d210d319 ]
Which would leak memory for the idr internals.
[ Upstream commit 58a923adf4d9aca8bf7205985c9c8fc531c65d72 ]
Technically dlm_config_nodes() could return error and keep nodes
uninitialized. After that on the fail path of we'll call kfree()
for that uninitialized value.
The patch is simple - we should just initialize nodes with NULL.
Signed-off-by: Denis V. Lunev <den@openvz.org>
locked
[ Upstream commit a2ece088882666e1dc7113744ac912eb161e3f87 ]
[ Upstream commit 03ad0d703df75c43f78bd72e16124b5b94a95188 ]
if the second call of should_expire() in there ends up
grabbing and returning a new reference to dentry, we need
to drop it before continuing.
commit 4610ba7ad877fafc0a25a30c6c82015304120426 upstream.
mm_release() contains the futex exit handling. mm_release() is called from
do_exit()->exit_mm() and from exec()->exec_mm().
In the exit_mm() case PF_EXITING and the futex state is updated. In the
exec_mm() case these states are not touched.
As the futex exit code needs further protections against exit races, this
needs to be split into two functions.
Preparatory only, no functional change.
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: https://lkml.kernel.org/r/20191106224556.240518241@linutronix.de
commit 4ea99936a1630f51fc3a2d61a58ec4a1c4b7d55a upstream.
It's possible to specify a non-zero s_want_extra_isize via debugging
option, and this can cause bad things(tm) to happen when using a file
system with an inode size of 128 bytes.
Add better checking when the file system is mounted, as well as when
we are actually doing the trying to do the inode expansion.
Link: https://lore.kernel.org/r/20191110121510.GH23325@mit.edu
Reported-by: syzbot+f8d6f8386ceacdbfff57@syzkaller.appspotmail.com
Reported-by: syzbot+33d7ea72e47de3bdf4e1@syzkaller.appspotmail.com
Reported-by: syzbot+44b6763edfc17144296f@syzkaller.appspotmail.com
[ Upstream commit d85400af790dba2aa294f0a77e712f166681f977 ]
Dirty flag of the journal should be cleared at the last stage of umount,
if do it before jbd2_journal_destroy(), then some metadata in uncommitted
transaction could be lost due to io error, but as dirty flag of journal
was already cleared, we can't find that until run a full fsck. This may
cause system panic or other corruption.
Link: http://lkml.kernel.org/r/20181121020023.3034-3-junxiao.bi@oracle.com
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Yiwen Jiang <jiangyiwen@huawei.com>
Reviewed-by: Joseph Qi <jiangqi903@gmail.com>
Cc: Jun Piao <piaojun@huawei.com>
Cc: Changwei Ge <ge.changwei@h3c.com>
Cc: Mark Fasheh <mfasheh@versity.com>
[ Upstream commit b32e019049e959ee10ec359893c9dd5d057dad55 ]
If user change inode's i_flags via ioctl, let's add it into global
dirty list, so that checkpoint can guarantee its persistence before
fsync, it can make checkpoint keeping strong consistency.
[ Upstream commit 7ca860e3c1a74ad6bd8949364073ef1044cad758 ]
The bulkstat family of ioctls are problematic on x32, because there is
a mixup of native 32-bit and 64-bit conventions. The xfs_fsop_bulkreq
struct contains pointers and 32-bit integers so that matches the native
32-bit layout, and that means the ioctl implementation goes into the
regular compat path on x32.
However, the 'ubuffer' member of that struct in turn refers to either
struct xfs_inogrp or xfs_bstat (or an array of these). On x32, those
structures match the native 64-bit layout. The compat implementation
writes out the 32-bit version of these structures. This is not the
expected format for x32 userspace, causing problems.
Fortunately the functions which actually output these xfs_inogrp and
xfs_bstat structures have an easy way to select which output format
is required, so we just need a little tweak to select the right format
on x32.
Signed-off-by: Nick Bowler <nbowler@draconx.ca>
[ Upstream commit c456d64449efe37da50832b63d91652a85ea1d20 ]
While inspecting the ioctl implementations, I noticed that the compat
implementation of XFS_IOC_ATTRLIST_BY_HANDLE does not do exactly the
same thing as the native implementation. Specifically, the "cursor"
does not appear to be written out to userspace on the compat path,
like it is on the native path.
This adjusts the compat implementation to copy out the cursor just
like the native implementation does. The attrlist cursor does not
require any special compat handling. This fixes xfstests xfs/269
on both IA-32 and x32 userspace, when running on an amd64 kernel.
Fixes: 0facef7fb053b ("xfs: in _attrlist_by_handle, copy the cursor back to userspace")
[ Upstream commit bc0205612bbd4dd4026d4ba6287f5643c37366ec ]
Before this patch, function do_grow would not reserve enough journal
blocks in the transaction to unstuff jdata files while growing them.
This patch adds the logic to add one more block if the file to grow
is jdata.
Reviewed-by: Andreas Gruenbacher <agruenba@redhat.com>
[ Upstream commit 26cb5a328c6b2bda9e859307ce4cfc60df3a2c28 ]
... and don't abuse mount_nodev(), while we are at it.
Reviewed-by: David Howells <dhowells@redhat.com>
[ Upstream commit 158ffa364bf723fa1ef128060646d23dc3942994 ]
We use this number to figure out how many delayed refs to run, but
__btrfs_run_delayed_refs really only checks every time we need a new
delayed ref head, so we always run at least one ref head completely no
matter what the number of items on it. Fix the accounting to only be
adjusted when we add/remove a ref head.
In addition to using this number to limit the number of delayed refs
run, a future patch is also going to use it to calculate the amount of
space required for delayed refs space reservation.
Signed-off-by: Josef Bacik <jbacik@fb.com>
[ Upstream commit 64bafd2f1e484e27071e7584642005d56516cb77 ]
Since mkfs always formats the filesystem with the realtime bitmap and
summary inodes immediately after the root directory, we should expect
that both of them are present and loadable, even if there isn't a
realtime volume attached. There's no reason to skip this if rbmino ==
NULLFSINO; in fact, this causes an immediate crash if the there /is/ a
realtime volume and someone writes to it.
Reviewed-by: Bill O'Donnell <billodo@redhat.com>
[ Upstream commit ff29fde84d1fc82f233c7da0daa3574a3942bec7 ]
If someone requests fscache on the mount, and the kernel doesn't
support it, it should fail the mount.
[ Drop ceph prefix -- it's provided by pr_err. ]
Signed-off-by: Jeff Layton <jlayton@kernel.org>
Reviewed-by: Ilya Dryomov <idryomov@gmail.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
commit a634644751c46238df58bbfe992e30c1668388db upstream.
Remove ocfs2_is_o2cb_active(). We have similar functions to identify
which cluster stack is being used via osb->osb_cluster_stack.
Secondly, the current implementation of ocfs2_is_o2cb_active() is not
totally safe. Based on the design of stackglue, we need to get
ocfs2_stack_lock before using ocfs2_stack related data structures, and
that active_stack pointer can be NULL in the case of mount failure.
Link: http://lkml.kernel.org/r/1495441079-11708-1-git-send-email-ghe@suse.com
Signed-off-by: Gang He <ghe@suse.com>
Reviewed-by: Eric Ren <zren@suse.com>
Acked-by: Changwei Ge <ge.changwei@h3c.com>
Cc: Mark Fasheh <mark@fasheh.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
[ Upstream commit 9de30f3f7f4d31037cfbb7c787e1089c1944b3a7 ]
In copy_result_to_user(), we first create a struct dlm_lock_result, which
contains a struct dlm_lksb, the last member of which is a pointer to the
lvb. Unfortunately, we copy the entire struct dlm_lksb to the result
struct, which is then copied to userspace at the end of the function,
leaking the contents of sb_lvbptr, which is a valid kernel pointer in some
cases (indeed, later in the same function the data it points to is copied
to userspace).
It is an error to leak kernel pointers to userspace, as it undermines KASLR
protections (see e.g. 65eea8edc31 ("floppy: Do not copy a kernel pointer to
user memory in FDGETPRM ioctl") for another example of this).
Signed-off-by: Tycho Andersen <tycho@tycho.ws>
[ Upstream commit d968b4e240cfe39d39d80483bac8bca8716fd93c ]
dlm_config_nodes() does not allocate nodes on failure, so we should not
free() nodes when it fails.
