fs/namespace.c:2721:6: warning: 'kernel_dev' may be used uninitialized in this function [-Wmaybe-uninitialized]
ret = do_mount(kernel_dev, kernel_dir->name, kernel_type, flags,
(void *) data_page);
fs/namespace.c:2721:6: warning: 'kernel_type' may be used uninitialized in this function [-Wmaybe-uninitialized]
drivers/media/platform/mxc/capture/ov5640_mipi.c:879:18: warning: 'sclk_rdiv_map' defined but not used [-Wunused-const-variable=]
static const int sclk_rdiv_map[] = {1, 2, 4, 8};
drivers/net/usb/usbnet.c:84:19: warning: 'driver_name' defined but not used [-Wunused-const-variable=]
static const char driver_name [] = "usbnet";
fs/cifs/netmisc.c:133:40: warning: 'mapping_table_ERRHRD' defined but not used [-Wunused-const-variable=]
static const struct smb_to_posix_error mapping_table_ERRHRD[] = {
kernel/cgroup.c:3839:36: warning: 'cgroup_pidlist_seq_operations' defined but not used [-Wunused-const-variable=]
static const struct seq_operations cgroup_pidlist_seq_operations = {
net/core/net-sysfs.c:30:19: warning: 'fmt_long_hex' defined but not used [-Wunused-const-variable=]
static const char fmt_long_hex[] = "%#lx\n";
net/core/rtnetlink.c:1266:32: warning: 'ifla_vf_policy' defined but not used [-Wunused-const-variable=]
static const struct nla_policy ifla_vf_policy[IFLA_VF_MAX+1] = {
net/core/rtnetlink.c:1262:32: warning: 'ifla_vfinfo_policy' defined but not used [-Wunused-const-variable=]
static const struct nla_policy ifla_vfinfo_policy[IFLA_VF_INFO_MAX+1] = {
net/core/sysctl_net_core.c:26:12: warning: 'one' defined but not used [-Wunused-variable]
static int one = 1;
net/ipv4/ping.c:1148:36: warning: 'ping_v4_seq_ops' defined but not used [-Wunused-const-variable=]
static const struct seq_operations ping_v4_seq_ops = {
net/rfkill/rfkill-gpio.c:187:36: warning: 'rfkill_acpi_match' defined but not used [-Wunused-const-variable=]
static const struct acpi_device_id rfkill_acpi_match[] = {
drivers/net/wireless/rtlwifi/efuse.c:38:31: warning: 'RTL8712_SDIO_EFUSE_TABLE' defined but not used [-Wunused-const-variable=]
static const struct efuse_map RTL8712_SDIO_EFUSE_TABLE[] = {
drivers/net/wireless/rtlwifi/efuse.c:34:17: warning: 'MAX_PGPKT_SIZE' defined but not used [-Wunused-const-variable=]
static const u8 MAX_PGPKT_SIZE = 9;
commit f15133df088ecadd141ea1907f2c96df67c729f0 upstream.
path_openat() jumps to the wrong place after do_tmpfile() - it has
already done path_cleanup() (as part of path_lookupat() called by
do_tmpfile()), so doing that again can lead to double fput().
commit 60942f2f235ce7b817166cdf355eed729094834d upstream.
Since now the shrink list is private and nobody can free the dentry while
it is on the shrink list, we can remove RCU protection from this.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
commit 9c8c10e262e0f62cb2530f1b076de979123183dd upstream.
Start with shrink_dcache_parent(), then scan what remains.
First of all, BUG() is very much an overkill here; we are holding
->s_umount, and hitting BUG() means that a lot of interesting stuff
will be hanging after that point (sync(2), for example). Moreover,
in cases when there had been more than one leak, we'll be better
off reporting all of them. And more than just the last component
of pathname - %pd is there for just such uses...
That was the last user of dentry_lru_del(), so kill it off...
commit fe91522a7ba82ca1a51b07e19954b3825e4aaa22 upstream.
If we find something already on a shrink list, just increment
data->found and do nothing else. Loops in shrink_dcache_parent() and
check_submounts_and_drop() will do the right thing - everything we
did put into our list will be evicted and if there had been nothing,
but data->found got non-zero, well, we have somebody else shrinking
those guys; just try again.
commit 41edf278fc2f042f4e22a12ed87d19c5201210e1 upstream.
If the victim in on the shrink list, don't remove it from there.
If shrink_dentry_list() manages to remove it from the list before
we are done - fine, we'll just free it as usual. If not - mark
it with new flag (DCACHE_MAY_FREE) and leave it there.
Eventually, shrink_dentry_list() will get to it, remove the sucker
from shrink list and call dentry_kill(dentry, 0). Which is where
we'll deal with freeing.
Since now dentry_kill(dentry, 0) may happen after or during
dentry_kill(dentry, 1), we need to recognize that (by seeing
DCACHE_DENTRY_KILLED already set), unlock everything
and either free the sucker (in case DCACHE_MAY_FREE has been
set) or leave it for ongoing dentry_kill(dentry, 1) to deal with.
commit 01b6035190b024240a43ac1d8e9c6f964f5f1c63 upstream.
commit b4f0354e968f5fabd39bc85b99fedae4a97589fe upstream.
The part of old d_free() that dealt with actual freeing of dentry.
Taken out of dentry_kill() into a separate function.
commit 5c47e6d0ad608987b91affbcf7d1fc12dfbe8fb4 upstream.
commit 03b3b889e79cdb6b806fc0ba9be0d71c186bbfaa upstream.
commit 3ead7c52bdb0ab44f4bb1feed505a8323cc12ba7 upstream.
This function may copy the si_addr_lsb field to user mode when it hasn't
been initialized, which can leak kernel stack data to user mode.
Just checking the value of si_code is insufficient because the same
si_code value is shared between multiple signals. This is solved by
checking the value of si_signo in addition to si_code.
Signed-off-by: Amanieu d'Antras <amanieu@gmail.com>
commit 209f7512d007980fd111a74a064d70a3656079cf upstream.
The "BUG_ON(list_empty(&osb->blocked_lock_list))" in
ocfs2_downconvert_thread_do_work can be triggered in the following case:
ocfs2dc has firstly saved osb->blocked_lock_count to local varibale
processed, and then processes the dentry lockres. During the dentry
put, it calls iput and then deletes rw, inode and open lockres from
blocked list in ocfs2_mark_lockres_freeing. And this causes the
variable `processed' to not reflect the number of blocked lockres to be
processed, which triggers the BUG.
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Cc: Mark Fasheh <mfasheh@suse.com>
commit 8f2f3eb59dff4ec538de55f2e0592fec85966aab upstream.
fsnotify_clear_marks_by_group_flags() can race with
fsnotify_destroy_marks() so that when fsnotify_destroy_mark_locked()
drops mark_mutex, a mark from the list iterated by
fsnotify_clear_marks_by_group_flags() can be freed and thus the next
entry pointer we have cached may become stale and we dereference free
memory.
Fix the problem by first moving marks to free to a special private list
and then always free the first entry in the special list. This method
is safe even when entries from the list can disappear once we drop the
lock.
Signed-off-by: Jan Kara <jack@suse.com>
Reported-by: Ashish Sangwan <a.sangwan@samsung.com>
Reviewed-by: Ashish Sangwan <a.sangwan@samsung.com>
Cc: Lino Sanfilippo <LinoSanfilippo@gmx.de>
commit 75a6f82a0d10ef8f13cd8fe7212911a0252ab99e upstream.
Normally opening a file, unlinking it and then closing will have
the inode freed upon close() (provided that it's not otherwise busy and
has no remaining links, of course). However, there's one case where that
does *not* happen. Namely, if you open it by fhandle with cold dcache,
then unlink() and close().
In normal case you get d_delete() in unlink(2) notice that dentry
is busy and unhash it; on the final dput() it will be forcibly evicted from
dcache, triggering iput() and inode removal. In this case, though, we end
up with *two* dentries - disconnected (created by open-by-fhandle) and
regular one (used by unlink()). The latter will have its reference to inode
dropped just fine, but the former will not - it's considered hashed (it
is on the ->s_anon list), so it will stay around until the memory pressure
will finally do it in. As the result, we have the final iput() delayed
indefinitely. It's trivial to reproduce -
void flush_dcache(void)
system("mount -o remount,rw /");
static char buf[20 * 1024 * 1024];
main()
int fd;
union {
struct file_handle f;
char buf[MAX_HANDLE_SZ];
} x;
int m;
x.f.handle_bytes = sizeof(x);
chdir("/root");
mkdir("foo", 0700);
fd = open("foo/bar", O_CREAT | O_RDWR, 0600);
close(fd);
name_to_handle_at(AT_FDCWD, "foo/bar", &x.f, &m, 0);
flush_dcache();
fd = open_by_handle_at(AT_FDCWD, &x.f, O_RDWR);
unlink("foo/bar");
write(fd, buf, sizeof(buf));
system("df ."); /* 20Mb eaten */
close(fd);
system("df ."); /* should've freed those 20Mb */
flush_dcache();
system("df ."); /* should be the same as #2 */
will spit out something like
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 322023 303843 1131 100% /
/dev/root 322023 283282 21692 93% /
- inode gets freed only when dentry is finally evicted (here we trigger
than by remount; normally it would've happened in response to memory
pressure hell knows when).
Acked-by: J. Bruce Fields <bfields@fieldses.org>
commit a28e4b2b18ccb90df402da3f21e1a83c9d4f8ec1 upstream.
Removing unnecessary static buffers is good.
Use the vsprintf %pV extension instead.
Signed-off-by: Mikulas Patocka <mikulas@twibright.com>
commit 0a73d0a204a4a04a1e110539c5a524ae51f91d6d upstream.
commit e8d975e73e5fa05f983fbf2723120edcf68e0b38 upstream.
Problem: When an operation like WRITE receives a BAD_STATEID, even though
recovery code clears the RECLAIM_NOGRACE recovery flag before recovering
the open state, because of clearing delegation state for the associated
inode, nfs_inode_find_state_and_recover() gets called and it makes the
same state with RECLAIM_NOGRACE flag again. As a results, when we restart
looking over the open states, we end up in the infinite loop instead of
breaking out in the next test of state flags.
Solution: unset the RECLAIM_NOGRACE set because of
calling of nfs_inode_find_state_and_recover() after returning from calling
recover_open() function.
Signed-off-by: Olga Kornievskaia <kolga@netapp.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit d683cc49daf7c5afca8cd9654aaa1bf63cdf2ad9 upstream.
When encoding the NFSACL SETACL operation, reserve just the estimated
size of the ACL rather than a fixed maximum. This eliminates needless
zero padding on the wire that the server ignores.
Fixes: ee5dc7732bd5 ('NFS: Fix "kernel BUG at fs/nfs/nfs3xdr.c:1338!"')
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
commit f3f5da624e0a891c34d8cd513c57f1d9b0c7dadc upstream.
This fixes a data corruption bug when using discard on top of MD linear,
raid0 and raid10 personalities.
Commit 20d0189b1012 "block: Introduce new bio_split()" permits sharing
the bio_vec between the two resulting bios. That is fine for read/write
requests where the bio_vec is immutable. For discards, however, we need
to be able to attach a payload and update the bio_vec so the page can
get mapped to a scatterlist entry. Therefore the bio_vec can not be
shared when splitting discards and we must do a full clone.
Reported-by: Seunguk Shin <seunguk.shin@samsung.com>
Tested-by: Seunguk Shin <seunguk.shin@samsung.com>
Cc: Seunguk Shin <seunguk.shin@samsung.com>
Cc: Jens Axboe <axboe@fb.com>
Cc: Kent Overstreet <kent.overstreet@gmail.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 0ad0b3255a08020eaf50e34ef0d6df5bdf5e09ed upstream.
fc->release is called from fuse_conn_put() which was used in the error
cleanup before fc->release was initialized.
[Jeremiah Mahler <jmmahler@gmail.com>: assign fc->release after calling
fuse_conn_init(fc) instead of before.]
Fixes: a325f9b92273 ("fuse: update fuse_conn_init() and separate out fuse_conn_kill()")
commit 497b4050e0eacd4c746dd396d14916b1e669849d upstream.
We were allocating memory with memdup_user() but we were never releasing
that memory. This affected pretty much every call to the ioctl, whether
it deduplicated extents or not.
This issue was reported on IRC by Julian Taylor and on the mailing list
by Marcel Ritter, credit goes to them for finding the issue.
Reported-by: Julian Taylor <jtaylor.debian@googlemail.com>
Reported-by: Marcel Ritter <ritter.marcel@gmail.com>
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Reviewed-by: Mark Fasheh <mfasheh@suse.de>
commit c3f4a1685bb87e59c886ee68f7967eae07d4dffa upstream.
The free space entries are allocated using kmem_cache_zalloc(),
through __btrfs_add_free_space(), therefore we should use
kmem_cache_free() and not kfree() to avoid any confusion and
any potential problem. Looking at the kfree() definition at
mm/slab.c it has the following comment:
* Don't free memory not originally allocated by kmalloc()
* or you will run into trouble.
So better be safe and use kmem_cache_free().
Reviewed-by: David Sterba <dsterba@suse.cz>
Signed-off-by: Chris Mason <clm@fb.com>
commit 2ac56d3d4bd625450a54d4c3f9292d58f6b88232 upstream.
If we create a CRC filesystem, mount it, and create a symlink with
a path long enough that it can't live in the inode, we get a very
strange result upon remount:
# ls -l mnt
total 4
lrwxrwxrwx. 1 root root 929 Jun 15 16:58 link -> XSLM
XSLM is the V5 symlink block header magic (which happens to be
followed by a NUL, so the string looks terminated).
xfs_readlink_bmap() advanced cur_chunk by the size of the header
for CRC filesystems, but never actually used that pointer; it
kept reading from bp->b_addr, which is the start of the block,
rather than the start of the symlink data after the header.
Looks like this problem goes back to v3.10.
Fixing this gets us reading the proper link target, again.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit 6f6a6fda294506dfe0e3e0a253bb2d2923f28f0a upstream.
If updating journal superblock fails after journal data has been
flushed, the error is omitted and this will mislead the caller as a
normal case. In ocfs2, the checkpoint will be treated successfully
and the other node can get the lock to update. Since the sb_start is
still pointing to the old log block, it will rewrite the journal data
during journal recovery by the other node. Thus the new updates will
be overwritten and ocfs2 corrupts. So in above case we have to return
the error, and ocfs2_commit_cache will take care of the error and
prevent the other node to do update first. And only after recovering
journal it can do the new updates.
The issue discussion mail can be found at:
https://oss.oracle.com/pipermail/ocfs2-devel/2015-June/010856.html
http://comments.gmane.org/gmane.comp.file-systems.ext4/48841
[ Fixed bug in patch which allowed a non-negative error return from
jbd2_cleanup_journal_tail() to leak out of jbd2_fjournal_flush(); this
was causing xfstests ext4/306 to fail. -- Ted ]
Reported-by: Yiwen Jiang <jiangyiwen@huawei.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Tested-by: Yiwen Jiang <jiangyiwen@huawei.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
commit b4f1afcd068f6e533230dfed00782cd8a907f96b upstream.
jbd2_cleanup_journal_tail() can be invoked by jbd2__journal_start()
So allocations should be done with GFP_NOFS
[Full stack trace snipped from 3.10-rh7]
[<ffffffff815c4bd4>] dump_stack+0x19/0x1b
[<ffffffff8105dba1>] warn_slowpath_common+0x61/0x80
[<ffffffff8105dcca>] warn_slowpath_null+0x1a/0x20
[<ffffffff815c2142>] slab_pre_alloc_hook.isra.31.part.32+0x15/0x17
[<ffffffff8119c045>] kmem_cache_alloc+0x55/0x210
[<ffffffff811477f5>] ? mempool_alloc_slab+0x15/0x20
[<ffffffff811477f5>] mempool_alloc_slab+0x15/0x20
[<ffffffff81147939>] mempool_alloc+0x69/0x170
[<ffffffff815cb69e>] ? _raw_spin_unlock_irq+0xe/0x20
[<ffffffff8109160d>] ? finish_task_switch+0x5d/0x150
[<ffffffff811f1a8e>] bio_alloc_bioset+0x1be/0x2e0
[<ffffffff8127ee49>] blkdev_issue_flush+0x99/0x120
[<ffffffffa019a733>] jbd2_cleanup_journal_tail+0x93/0xa0 [jbd2] -->GFP_KERNEL
[<ffffffffa019aca1>] jbd2_log_do_checkpoint+0x221/0x4a0 [jbd2]
[<ffffffffa019afc7>] __jbd2_log_wait_for_space+0xa7/0x1e0 [jbd2]
[<ffffffffa01952d8>] start_this_handle+0x2d8/0x550 [jbd2]
[<ffffffff811b02a9>] ? __memcg_kmem_put_cache+0x29/0x30
[<ffffffff8119c120>] ? kmem_cache_alloc+0x130/0x210
[<ffffffffa019573a>] jbd2__journal_start+0xba/0x190 [jbd2]
[<ffffffff811532ce>] ? lru_cache_add+0xe/0x10
[<ffffffffa01c9549>] ? ext4_da_write_begin+0xf9/0x330 [ext4]
[<ffffffffa01f2c77>] __ext4_journal_start_sb+0x77/0x160 [ext4]
[<ffffffffa01c9549>] ext4_da_write_begin+0xf9/0x330 [ext4]
[<ffffffff811446ec>] generic_file_buffered_write_iter+0x10c/0x270
[<ffffffff81146918>] __generic_file_write_iter+0x178/0x390
[<ffffffff81146c6b>] __generic_file_aio_write+0x8b/0xb0
[<ffffffff81146ced>] generic_file_aio_write+0x5d/0xc0
[<ffffffffa01bf289>] ext4_file_write+0xa9/0x450 [ext4]
[<ffffffff811c31d9>] ? pipe_read+0x379/0x4f0
[<ffffffff811b93f0>] do_sync_write+0x90/0xe0
[<ffffffff811b9b6d>] vfs_write+0xbd/0x1e0
[<ffffffff811ba5b8>] SyS_write+0x58/0xb0
[<ffffffff815d4799>] system_call_fastpath+0x16/0x1b
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit 7444a072c387a93ebee7066e8aee776954ab0e41 upstream.
ext4_free_blocks is looping around the allocation request and mimics
__GFP_NOFAIL behavior without any allocation fallback strategy. Let's
remove the open coded loop and replace it with __GFP_NOFAIL. Without the
flag the allocator has no way to find out never-fail requirement and
cannot help in any way.
commit 8974fec7d72e3e02752fe0f27b4c3719c78d9a15 upstream.
Currently ext4_ind_migrate() doesn't correctly handle a file which
contains a hole at the beginning of the file. This caused the migration
to be done incorrectly, and then if there is a subsequent following
delayed allocation write to the "hole", this would reclaim the same data
blocks again and results in fs corruption.
# assmuing 4k block size ext4, with delalloc enabled
# skip the first block and write to the second block
xfs_io -fc "pwrite 4k 4k" -c "fsync" /mnt/ext4/testfile
# converting to indirect-mapped file, which would move the data blocks
# to the beginning of the file, but extent status cache still marks
# that region as a hole
chattr -e /mnt/ext4/testfile
# delayed allocation writes to the "hole", reclaim the same data block
# again, results in i_blocks corruption
xfs_io -c "pwrite 0 4k" /mnt/ext4/testfile
umount /mnt/ext4
e2fsck -nf /dev/sda6
Inode 53, i_blocks is 16, should be 8. Fix? no
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit d6f123a9297496ad0b6335fe881504c4b5b2a5e5 upstream.
Currently the check in ext4_ind_migrate() is not enough before doing the
real conversion:
a) delayed allocated extents could bypass the check on eh->eh_entries
and eh->eh_depth
This can be demonstrated by this script
xfs_io -fc "pwrite 0 4k" -c "pwrite 8k 4k" /mnt/ext4/testfile
where testfile has two extents but still be converted to non-extent
based file format.
b) only extent length is checked but not the offset, which would result
in data lose (delalloc) or fs corruption (nodelalloc), because
non-extent based file only supports at most (12 + 2^10 + 2^20 + 2^30)
blocks
This can be demostrated by
xfs_io -fc "pwrite 5T 4k" /mnt/ext4/testfile
sync
If delalloc is enabled, dmesg prints
EXT4-fs warning (device dm-4): ext4_block_to_path:105: block 1342177280 > max in inode 53
EXT4-fs (dm-4): Delayed block allocation failed for inode 53 at logical offset 1342177280 with max blocks 1 with error 5
EXT4-fs (dm-4): This should not happen!! Data will be lost
If delalloc is disabled, e2fsck -nf shows corruption
Inode 53, i_size is 5497558142976, should be 4096. Fix? no
Fix the two issues by
a) forcing all delayed allocation blocks to be allocated before checking
eh->eh_depth and eh->eh_entries
b) limiting the last logical block of the extent is within direct map
commit 9705acd63b125dee8b15c705216d7186daea4625 upstream.
On delalloc enabled file system on invalidatepage operation
in ext4_da_page_release_reservation() we want to clear the delayed
buffer and remove the extent covering the delayed buffer from the extent
status tree.
However currently there is a bug where on the systems with page size >
block size we will always remove extents from the start of the page
regardless where the actual delayed buffers are positioned in the page.
This leads to the errors like this:
EXT4-fs warning (device loop0): ext4_da_release_space:1225:
ext4_da_release_space: ino 13, to_free 1 with only 0 reserved data
blocks
This however can cause data loss on writeback time if the file system is
in ENOSPC condition because we're releasing reservation for someones
else delayed buffer.
Fix this by only removing extents that corresponds to the part of the
page we want to invalidate.
This problem is reproducible by the following fio receipt (however I was
only able to reproduce it with fio-2.1 or older.
[global]
bs=8k
iodepth=1024
iodepth_batch=60
randrepeat=1
size=1m
directory=/mnt/test
numjobs=20
[job1]
ioengine=sync
bs=1k
direct=1
rw=randread
filename=file1:file2
[job2]
ioengine=libaio
rw=randwrite
direct=1
[job3]
bs=1k
ioengine=posixaio
rw=randwrite
direct=1
[job5]
bs=1k
ioengine=sync
rw=randread
[job7]
ioengine=libaio
rw=randwrite
[job8]
ioengine=posixaio
rw=randwrite
[job10]
ioengine=mmap
rw=randwrite
bs=1k
[job11]
ioengine=mmap
rw=randwrite
direct=1
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
commit 292db1bc6c105d86111e858859456bcb11f90f91 upstream.
ext4 isn't willing to map clusters to a non-extent file. Don't signal
this with an out of space error, since the FS will retry the
allocation (which didn't fail) forever. Instead, return EUCLEAN so
that the operation will fail immediately all the way back to userspace.
(The fix is either to run e2fsck -E bmap2extent, or to chattr +e the file.)
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
commit 89d96a6f8e6491f24fc8f99fd6ae66820e85c6c1 upstream.
Normally all of the buffers will have been forced out to disk before
we call invalidate_bdev(), but there will be some cases, where a file
system operation was aborted due to an ext4_error(), where there may
still be some dirty buffers in the buffer cache for the device. So
try to force them out to memory before calling invalidate_bdev().
This fixes a warning triggered by generic/081:
WARNING: CPU: 1 PID: 3473 at /usr/projects/linux/ext4/fs/block_dev.c:56 __blkdev_put+0xb5/0x16f()
commit bdf96838aea6a265f2ae6cbcfb12a778c84a0b8e upstream.
The commit cf108bca465d: "ext4: Invert the locking order of page_lock
and transaction start" caused __ext4_journalled_writepage() to drop
the page lock before the page was written back, as part of changing
the locking order to jbd2_journal_start -> page_lock. However, this
introduced a potential race if there was a truncate racing with the
data=journalled writeback mode.
Fix this by grabbing the page lock after starting the journal handle,
and then checking to see if page had gotten truncated out from under
us.
This fixes a number of different warnings or BUG_ON's when running
xfstests generic/086 in data=journalled mode, including:
jbd2_journal_dirty_metadata: vdc-8: bad jh for block 115643: transaction (ee3fe7
c0, 164), jh->b_transaction ( (null), 0), jh->b_next_transaction ( (null), 0), jlist 0
- and -
kernel BUG at /usr/projects/linux/ext4/fs/jbd2/transaction.c:2200!
Call Trace:
[<c02b2ded>] ? __ext4_journalled_invalidatepage+0x117/0x117
[<c02b2de5>] __ext4_journalled_invalidatepage+0x10f/0x117
[<c027d883>] ? lock_buffer+0x36/0x36
[<c02b2dfa>] ext4_journalled_invalidatepage+0xd/0x22
[<c0229139>] do_invalidatepage+0x22/0x26
[<c0229198>] truncate_inode_page+0x5b/0x85
[<c022934b>] truncate_inode_pages_range+0x156/0x38c
[<c0229592>] truncate_inode_pages+0x11/0x15
[<c022962d>] truncate_pagecache+0x55/0x71
[<c02b913b>] ext4_setattr+0x4a9/0x560
[<c01ca542>] ? current_kernel_time+0x10/0x44
[<c026c4d8>] notify_change+0x1c7/0x2be
[<c0256a00>] do_truncate+0x65/0x85
[<c0226f31>] ? file_ra_state_init+0x12/0x29
- and -
WARNING: CPU: 1 PID: 1331 at /usr/projects/linux/ext4/fs/jbd2/transaction.c:1396
irty_metadata+0x14a/0x1ae()
Call Trace:
[<c01b879f>] ? console_unlock+0x3a1/0x3ce
[<c082cbb4>] dump_stack+0x48/0x60
[<c0178b65>] warn_slowpath_common+0x89/0xa0
[<c02ef2cf>] ? jbd2_journal_dirty_metadata+0x14a/0x1ae
[<c0178bef>] warn_slowpath_null+0x14/0x18
[<c02ef2cf>] jbd2_journal_dirty_metadata+0x14a/0x1ae
[<c02d8615>] __ext4_handle_dirty_metadata+0xd4/0x19d
[<c02b2f44>] write_end_fn+0x40/0x53
[<c02b4a16>] ext4_walk_page_buffers+0x4e/0x6a
[<c02b59e7>] ext4_writepage+0x354/0x3b8
[<c02b2f04>] ? mpage_release_unused_pages+0xd4/0xd4
[<c02b1b21>] ? wait_on_buffer+0x2c/0x2c
[<c02b5a4b>] ? ext4_writepage+0x3b8/0x3b8
[<c02b5a5b>] __writepage+0x10/0x2e
[<c0225956>] write_cache_pages+0x22d/0x32c
[<c02b6ee8>] ext4_writepages+0x102/0x607
[<c019adfe>] ? sched_clock_local+0x10/0x10e
[<c01a8a7c>] ? __lock_is_held+0x2e/0x44
[<c01a8ad5>] ? lock_is_held+0x43/0x51
[<c0226dff>] do_writepages+0x1c/0x29
[<c0276bed>] __writeback_single_inode+0xc3/0x545
[<c0277c07>] writeback_sb_inodes+0x21f/0x36d
commit ceeb0e5d39fcdf4dca2c997bf225c7fc49200b37 upstream.
Limit the mounts fs_fully_visible considers to locked mounts.
Unlocked can always be unmounted so considering them adds hassle
but no security benefit.
commit 93e3bce6287e1fb3e60d3324ed08555b5bbafa89 upstream.
The warning message in prepend_path is unclear and outdated. It was
added as a warning that the mechanism for generating names of pseudo
files had been removed from prepend_path and d_dname should be used
instead. Unfortunately the warning reads like a general warning,
making it unclear what to do with it.
Remove the warning. The transition it was added to warn about is long
over, and I added code several years ago which in rare cases causes
the warning to fire on legitimate code, and the warning is now firing
and scaring people for no good reason.
Reported-by: Ivan Delalande <colona@arista.com>
Reported-by: Omar Sandoval <osandov@osandov.com>
Fixes: f48cfddc6729e ("vfs: In d_path don't call d_dname on a mount point")
commit 2426f3910069ed47c0cc58559a6d088af7920201 upstream.
file_remove_suid() could mistakenly set S_NOSEC inode bit when root was
modifying the file. As a result following writes to the file by ordinary
user would avoid clearing suid or sgid bits.
Fix the bug by checking actual mode bits before setting S_NOSEC.
commit 894c6350eaad7e613ae267504014a456e00a3e2a from the 3.2-stable branch.
We need to check the position and size of file writes against various
limits, using generic_write_check(). This was not being done for
the splice write path. It was fixed upstream by commit 8d0207652cbe
("->splice_write() via ->write_iter()") but we can't apply that.
CVE-2014-7822
Cc: Vinson Lee <vlee@twopensource.com>
commit 5f5bc6b1e2d5a6f827bc860ef2dc5b6f365d1339 upstream.
Replacing a xattr consists of doing a lookup for its existing value, delete
the current value from the respective leaf, release the search path and then
finally insert the new value. This leaves a time window where readers (getxattr,
listxattrs) won't see any value for the xattr. Xattrs are used to store ACLs,
so this has security implications.
This change also fixes 2 other existing issues which were:
*) Deleting the old xattr value without verifying first if the new xattr will
fit in the existing leaf item (in case multiple xattrs are packed in the
same item due to name hash collision);
*) Returning -EEXIST when the flag XATTR_CREATE is given and the xattr doesn't
exist but we have have an existing item that packs muliple xattrs with
the same name hash as the input xattr. In this case we should return ENOSPC.
A test case for xfstests follows soon.
Thanks to Alexandre Oliva for reporting the non-atomicity of the xattr replace
implementation.
Reported-by: Alexandre Oliva <oliva@gnu.org>
pipe_iov_copy_{from,to}_user() may be tried twice with the same iovec,
the first time atomically and the second time not. The second attempt
needs to continue from the iovec position, pipe buffer offset and
remaining length where the first attempt failed, but currently the
pipe buffer offset and remaining length are reset. This will corrupt
the piped data (possibly also leading to an information leak between
processes) and may also corrupt kernel memory.
This was fixed upstream by commits f0d1bec9d58d ("new helper:
copy_page_from_iter()") and 637b58c2887e ("switch pipe_read() to
copy_page_to_iter()"), but those aren't suitable for stable. This fix
for older kernel versions was made by Seth Jennings for RHEL and I
have extracted it from their update.
CVE-2015-1805
References: https://bugzilla.redhat.com/show_bug.cgi?id=1202855
commit 727b9784b6085c99c2f836bf4fcc2848dc9cf904 upstream.
Orphans in the fs tree are cleaned up via open_ctree and subvolume
orphans are cleaned via btrfs_lookup_dentry -- except when a default
subvolume is in use. The name for the default subvolume uses a manual
lookup that doesn't trigger orphan cleanup and needs to trigger it
manually as well. This doesn't apply to the remount case since the
subvolumes are cleaned up by walking the root radix tree.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 26e726afe01c1c82072cf23a5ed89ce25f39d9f2 upstream.
fiemap_fill_next_extent returns 0 on success, -errno on error, 1 if this was
the last extent that will fit in user array. If 1 is returned, the return
value may eventually returned to user space, which should not happen, according
to manpage of ioctl.
Signed-off-by: Chengyu Song <csong84@gatech.edu>
Reviewed-by: Liu Bo <bo.li.liu@oracle.com>
commit 2b1d3ae940acd11be44c6eced5873d47c2e00ffa upstream.
load_elf_binary() returns `retval', not `error'.
Fixes: a87938b2e246b81b4fb ("fs/binfmt_elf.c: fix bug in loading of PIE binaries")
Reported-by: James Hogan <james.hogan@imgtec.com>
Cc: Michael Davidson <md@google.com>
commit 161f873b89136eb1e69477c847d5a5033239d9ba upstream.
We used to read file_handle twice. Once to get the amount of extra
bytes, and once to fetch the entire structure.
This may be problematic since we do size verifications only after the
first read, so if the number of extra bytes changes in userspace between
the first and second calls, we'll have an incoherent view of
file_handle.
Instead, read the constant size once, and copy that over to the final
structure without having to re-read it again.
commit e531d0bceb402e643a4499de40dd3fa39d8d2e43 upstream.
The journal revoke block recovery code does not check r_count for
sanity, which means that an evil value of r_count could result in
the kernel reading off the end of the revoke table and into whatever
garbage lies beyond. This could crash the kernel, so fix that.
However, in testing this fix, I discovered that the code to write
out the revoke tables also was not correctly checking to see if the
block was full -- the current offset check is fine so long as the
revoke table space size is a multiple of the record size, but this
is not true when either journal_csum_v[23] are set.
commit 2f974865ffdfe7b9f46a9940836c8b167342563d upstream.
The following commit introduced a bug when checking for zero length extent
5946d08 ext4: check for overlapping extents in ext4_valid_extent_entries()
Zero length extent could pass the check if lblock is zero.
Adding the explicit check for zero length back.
commit 9d506594069355d1fb2de3f9104667312ff08ed3 upstream.
Currently when journal restart fails, we'll have the h_transaction of
the handle set to NULL to indicate that the handle has been effectively
aborted. We handle this situation quietly in the jbd2_journal_stop() and just
free the handle and exit because everything else has been done before we
attempted (and failed) to restart the journal.
Unfortunately there are a number of problems with that approach
introduced with commit
41a5b913197c "jbd2: invalidate handle if jbd2_journal_restart()
fails"
First of all in ext4 jbd2_journal_stop() will be called through
__ext4_journal_stop() where we would try to get a hold of the superblock
by dereferencing h_transaction which in this case would lead to NULL
pointer dereference and crash.
In addition we're going to free the handle regardless of the refcount
which is bad as well, because others up the call chain will still
reference the handle so we might potentially reference already freed
memory.
Moreover it's expected that we'll get aborted handle as well as detached
handle in some of the journalling function as the error propagates up
the stack, so it's unnecessary to call WARN_ON every time we get
detached handle.
And finally we might leak some memory by forgetting to free reserved
handle in jbd2_journal_stop() in the case where handle was detached from
the transaction (h_transaction is NULL).
Fix the NULL pointer dereference in __ext4_journal_stop() by just
calling jbd2_journal_stop() quietly as suggested by Jan Kara. Also fix
the potential memory leak in jbd2_journal_stop() and use proper
handle refcounting before we attempt to free it to avoid use-after-free
issues.
And finally remove all WARN_ON(!transaction) from the code so that we do
not get random traces when something goes wrong because when journal
restart fails we will get to some of those functions.
commit 2159184ea01e4ae7d15f2017e296d4bc82d5aeb0 upstream.
when we find that a child has died while we'd been trying to ascend,
we should go into the first live sibling itself, rather than its sibling.
Off-by-one in question had been introduced in "deal with deadlock in
d_walk()" and the fix needs to be backported to all branches this one
has been backported to.
commit dcbff39da3d815f08750552fdd04f96b51751129 upstream.
match_token() expects a NULL terminator at the end of the token list so
that it would know where to stop. Not having one causes it to overrun
to invalid memory.
In practice, passing a mount option that omfs didn't recognize would
sometimes panic the system.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
commit ca5358ef75fc69fee5322a38a340f5739d997c10 upstream.
... by not hitting rename_retry for reasons other than rename having
happened. In other words, do _not_ restart when finding that
between unlocking the child and locking the parent the former got
into __dentry_kill(). Skip the killed siblings instead...
Cc: Ben Hutchings <ben@decadent.org.uk>
[hujianyang: Backported to 3.14 refer to the work of Ben Hutchings in 3.2:
- Adjust context to make __dentry_kill() apply to d_kill()]
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit 7e96c1b0e0f495c5a7450dc4aa7c9a24ba4305bd upstream.
This fixes a dumb bug in fs_fully_visible that allows proc or sys to
be mounted if there is a bind mount of part of /proc/ or /sys/ visible.
Reported-by: Eric Windisch <ewindisch@docker.com>
