path: root/fs
2013-08-20jbd2: Fix use after free after error in jbd2_journal_dirty_metadata()Jan Kara
commit 91aa11fae1cf8c2fd67be0609692ea9741cdcc43 upstream. When jbd2_journal_dirty_metadata() returns error, __ext4_handle_dirty_metadata() stops the handle. However callers of this function do not count with that fact and still happily used now freed handle. This use after free can result in various issues but very likely we oops soon. The motivation of adding __ext4_journal_stop() into __ext4_handle_dirty_metadata() in commit 9ea7a0df seems to be only to improve error reporting. So replace __ext4_journal_stop() with ext4_journal_abort_handle() which was there before that commit and add WARN_ON_ONCE() to dump stack to provide useful information. Reported-by: Sage Weil <sage@inktank.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20fs/proc/task_mmu.c: fix buffer overflow in add_page_map()yonghua zheng
commit 8c8296223f3abb142be8fc31711b18a704c0e7d8 upstream. Recently we met quite a lot of random kernel panic issues after enabling CONFIG_PROC_PAGE_MONITOR. After debuggind we found this has something to do with following bug in pagemap: In struct pagemapread: struct pagemapread { int pos, len; pagemap_entry_t *buffer; bool v2; }; pos is number of PM_ENTRY_BYTES in buffer, but len is the size of buffer, it is a mistake to compare pos and len in add_page_map() for checking buffer is full or not, and this can lead to buffer overflow and random kernel panic issue. Correct len to be total number of PM_ENTRY_BYTES in buffer. [akpm@linux-foundation.org: document pagemapread.pos and .len units, fix PM_ENTRY_BYTES definition] Signed-off-by: Yonghua Zheng <younghua.zheng@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14vfs: d_obtain_alias() needs to use "/" as default name.NeilBrown
commit b911a6bdeef5848c468597d040e3407e0aee04ce upstream. NFS appears to use d_obtain_alias() to create the root dentry rather than d_make_root. This can cause 'prepend_path()' to complain that the root has a weird name if an NFS filesystem is lazily unmounted. e.g. if "/mnt" is an NFS mount then { cd /mnt; umount -l /mnt ; ls -l /proc/self/cwd; } will cause a WARN message like WARNING: at /home/git/linux/fs/dcache.c:2624 prepend_path+0x1d7/0x1e0() ... Root dentry has weird name <> to appear in kernel logs. So change d_obtain_alias() to use "/" rather than "" as the anonymous name. Signed-off-by: NeilBrown <neilb@suse.de> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> [bwh: Backported to 3.2: use named initialisers instead of QSTR_INIT()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14debugfs: debugfs_remove_recursive() must not rely on list_empty(d_subdirs)Oleg Nesterov
commit 776164c1faac4966ab14418bb0922e1820da1d19 upstream. debugfs_remove_recursive() is wrong, 1. it wrongly assumes that !list_empty(d_subdirs) means that this dir should be removed. This is not that bad by itself, but: 2. if d_subdirs does not becomes empty after __debugfs_remove() it gives up and silently fails, it doesn't even try to remove other entries. However ->d_subdirs can be non-empty because it still has the already deleted !debugfs_positive() entries. 3. simple_release_fs() is called even if __debugfs_remove() fails. Suppose we have dir1/ dir2/ file2 file1 and someone opens dir1/dir2/file2. Now, debugfs_remove_recursive(dir1/dir2) succeeds, and dir1/dir2 goes away. But debugfs_remove_recursive(dir1) silently fails and doesn't remove this directory. Because it tries to delete (the already deleted) dir1/dir2/file2 again and then fails due to "Avoid infinite loop" logic. Test-case: #!/bin/sh cd /sys/kernel/debug/tracing echo 'p:probe/sigprocmask sigprocmask' >> kprobe_events sleep 1000 < events/probe/sigprocmask/id & echo -n >| kprobe_events [ -d events/probe ] && echo "ERR!! failed to rm probe" And after that it is not possible to create another probe entry. With this patch debugfs_remove_recursive() skips !debugfs_positive() files although this is not strictly needed. The most important change is that it does not try to make ->d_subdirs empty, it simply scans the whole list(s) recursively and removes as much as possible. Link: http://lkml.kernel.org/r/20130726151256.GC19472@redhat.com Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14cifs: extend the buffer length enought for sprintf() usingChen Gang
commit 057d6332b24a4497c55a761c83c823eed9e3f23b upstream. For cifs_set_cifscreds() in "fs/cifs/connect.c", 'desc' buffer length is 'CIFSCREDS_DESC_SIZE' (56 is less than 256), and 'ses->domainName' length may be "255 + '\0'". The related sprintf() may cause memory overflow, so need extend related buffer enough to hold all things. It is also necessary to be sure of 'ses->domainName' must be less than 256, and define the related macro instead of hard code number '256'. Signed-off-by: Chen Gang <gang.chen@asianux.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Scott Lovenberg <scott.lovenberg@gmail.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14ext4: fix mount/remount error messages for incompatible mount optionsPiotr Sarna
commit 6ae6514b33f941d3386da0dfbe2942766eab1577 upstream. Commit 5688978 ("ext4: improve handling of conflicting mount options") introduced incorrect messages shown while choosing wrong mount options. First of all, both cases of incorrect mount options, "data=journal,delalloc" and "data=journal,dioread_nolock" result in the same error message. Secondly, the problem above isn't solved for remount option: the mismatched parameter is simply ignored. Moreover, ext4_msg states that remount with options "data=journal,delalloc" succeeded, which is not true. To fix it up, I added a simple check after parse_options() call to ensure that data=journal and delalloc/dioread_nolock parameters are not present at the same time. Signed-off-by: Piotr Sarna <p.sarna@partner.samsung.com> Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14ext4: make sure group number is bumped after a inode allocation raceTheodore Ts'o
commit a34eb503742fd25155fd6cff6163daacead9fbc3 upstream. When we try to allocate an inode, and there is a race between two CPU's trying to grab the same inode, _and_ this inode is the last free inode in the block group, make sure the group number is bumped before we continue searching the rest of the block groups. Otherwise, we end up searching the current block group twice, and we end up skipping searching the last block group. So in the unlikely situation where almost all of the inodes are allocated, it's possible that we will return ENOSPC even though there might be free inodes in that last block group. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11fanotify: info leak in copy_event_to_user()Dan Carpenter
commit de1e0c40aceb9d5bff09c3a3b97b2f1b178af53f upstream. The ->reserved field isn't cleared so we leak one byte of stack information to userspace. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Eric Paris <eparis@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis Henriques <luis.henriques@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04livelock avoidance in sget()Al Viro
commit acfec9a5a892f98461f52ed5770de99a3e571ae2 upstream. Eric Sandeen has found a nasty livelock in sget() - take a mount(2) about to fail. The superblock is on ->fs_supers, ->s_umount is held exclusive, ->s_active is 1. Along comes two more processes, trying to mount the same thing; sget() in each is picking that superblock, bumping ->s_count and trying to grab ->s_umount. ->s_active is 3 now. Original mount(2) finally gets to deactivate_locked_super() on failure; ->s_active is 2, superblock is still ->fs_supers because shutdown will *not* happen until ->s_active hits 0. ->s_umount is dropped and now we have two processes chasing each other: s_active = 2, A acquired ->s_umount, B blocked A sees that the damn thing is stillborn, does deactivate_locked_super() s_active = 1, A drops ->s_umount, B gets it A restarts the search and finds the same superblock. And bumps it ->s_active. s_active = 2, B holds ->s_umount, A blocked on trying to get it ... and we are in the earlier situation with A and B switched places. The root cause, of course, is that ->s_active should not grow until we'd got MS_BORN. Then failing ->mount() will have deactivate_locked_super() shut the damn thing down. Fortunately, it's easy to do - the key point is that grab_super() is called only for superblocks currently on ->fs_supers, so it can bump ->s_count and grab ->s_umount first, then check MS_BORN and bump ->s_active; we must never increment ->s_count for superblocks past ->kill_sb(), but grab_super() is never called for those. The bug is pretty old; we would've caught it by now, if not for accidental exclusion between sget() for block filesystems; the things like cgroup or e.g. mtd-based filesystems don't have anything of that sort, so they get bitten. The right way to deal with that is obviously to fix sget()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04Btrfs: re-add root to dead root list if we stop dropping itJosef Bacik
commit d29a9f629e009c9b90e5859bce581070fd6247fc upstream. If we stop dropping a root for whatever reason we need to add it back to the dead root list so that we will re-start the dropping next transaction commit. The other case this happens is if we recover a drop because we will add a root without adding it to the fs radix tree, so we can leak it's root and commit root extent buffer, adding this to the dead root list makes this cleanup happen. Thanks, Reported-by: Alex Lyakas <alex.btrfs@zadarastorage.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04Btrfs: fix lock leak when resuming snapshot deletionJosef Bacik
commit fec386ac1428f9c0e672df952cbca5cebd4e4e2f upstream. We aren't setting path->locks[level] when we resume a snapshot deletion which means we won't unlock the buffer when we free the path. This causes deadlocks if we happen to re-allocate the block before we've evicted the extent buffer from cache. Thanks, Reported-by: Alex Lyakas <alex.btrfs@zadarastorage.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28lockd: protect nlm_blocked access in nlmsvc_retry_blockedDavid Jeffery
commit 1c327d962fc420aea046c16215a552710bde8231 upstream. In nlmsvc_retry_blocked, the check that the list is non-empty and acquiring the pointer of the first entry is unprotected by any lock. This allows a rare race condition when there is only one entry on the list. A function such as nlmsvc_grant_callback() can be called, which will temporarily remove the entry from the list. Between the list_empty() and list_entry(),the list may become empty, causing an invalid pointer to be used as an nlm_block, leading to a possible crash. This patch adds the nlm_block_lock around these calls to prevent concurrent use of the nlm_blocked list. This was a regression introduced by f904be9cc77f361d37d71468b13ff3d1a1823dea "lockd: Mostly remove BKL from the server". Signed-off-by: David Jeffery <djeffery@redhat.com> Cc: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28writeback: Fix periodic writeback after fs mountJan Kara
commit a5faeaf9109578e65e1a32e2a3e76c8b47e7dcb6 upstream. Code in blkdev.c moves a device inode to default_backing_dev_info when the last reference to the device is put and moves the device inode back to its bdi when the first reference is acquired. This includes moving to wb.b_dirty list if the device inode is dirty. The code however doesn't setup timer to wake corresponding flusher thread and while wb.b_dirty list is non-empty __mark_inode_dirty() will not set it up either. Thus periodic writeback is effectively disabled until a sync(2) call which can lead to unexpected data loss in case of crash or power failure. Fix the problem by setting up a timer for periodic writeback in case we add the first dirty inode to wb.b_dirty list in bdev_inode_switch_bdi(). Reported-by: Bert De Jonghe <Bert.DeJonghe@amplidata.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ext3: fix data=journal fast mount/umount hangJan Kara
commit e643692138cfa33528f054b071ba2583509bb217 upstream. In data=journal mode, if we unmount the file system before a transaction has a chance to complete, when the journal inode is being evicted, we can end up calling into log_wait_commit() for the last transaction, after the journalling machinery has been shut down. That triggers the WARN_ONCE in __log_start_commit(). Arguably we should adjust ext3_should_journal_data() to return FALSE for the journal inode, but the only place it matters is ext3_evict_inode(), and so it's to save a bit of CPU time, and to make the patch much more obviously correct by inspection(tm), we'll fix it by explicitly not trying to waiting for a journal commit when we are evicting the journal inode, since it's guaranteed to never succeed in this case. This can be easily replicated via: mount -t ext3 -o data=journal /dev/vdb /vdb ; umount /vdb This is a port of ext4 fix from Ted Ts'o. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21Handle big endianness in NTLM (ntlmv2) authenticationSteve French
commit fdf96a907c1fbb93c633e2b7ede3b8df26d6a4c0 upstream. This is RH bug 970891 Uppercasing of username during calculation of ntlmv2 hash fails because UniStrupr function does not handle big endian wchars. Also fix a comment in the same code to reflect its correct usage. [To make it easier for stable (rather than require 2nd patch) fixed this patch of Shirish's to remove endian warning generated by sparse -- steve f.] Reported-by: steve <sanpatr1@in.ibm.com> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21ext4: don't allow ext4_free_blocks() to fail due to ENOMEMTheodore Ts'o
commit e7676a704ee0a1ef71a6b23760b5a8f6896cb1a1 upstream. The filesystem should not be marked inconsistent if ext4_free_blocks() is not able to allocate memory. Unfortunately some callers (most notably ext4_truncate) don't have a way to reflect an error back up to the VFS. And even if we did, most userspace applications won't deal with most system calls returning ENOMEM anyway. Reported-by: Nagachandra P <nagachandra@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21ext4: fix overflow when counting used blocks on 32-bit architecturesJan Kara
commit 8af8eecc1331dbf5e8c662022272cf667e213da5 upstream. The arithmetics adding delalloc blocks to the number of used blocks in ext4_getattr() can easily overflow on 32-bit archs as we first multiply number of blocks by blocksize and then divide back by 512. Make the arithmetics more clever and also use proper type (unsigned long long instead of unsigned long). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21ext4: fix data offset overflow in ext4_xattr_fiemap() on 32-bit archsJan Kara
commit a60697f411eb365fb09e639e6f183fe33d1eb796 upstream. On 32-bit architectures with 32-bit sector_t computation of data offset in ext4_xattr_fiemap() can overflow resulting in reporting bogus data location. Fix the problem by typing block number to proper type before shifting. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21ocfs2: xattr: fix inlined xattr reflinkJunxiao Bi
commit ef962df057aaafd714f5c22ba3de1be459571fdf upstream. Inlined xattr shared free space of inode block with inlined data or data extent record, so the size of the later two should be adjusted when inlined xattr is enabled. See ocfs2_xattr_ibody_init(). But this isn't done well when reflink. For inode with inlined data, its max inlined data size is adjusted in ocfs2_duplicate_inline_data(), no problem. But for inode with data extent record, its record count isn't adjusted. Fix it, or data extent record and inlined xattr may overwrite each other, then cause data corruption or xattr failure. One panic caused by this bug in our test environment is the following: kernel BUG at fs/ocfs2/xattr.c:1435! invalid opcode: 0000 [#1] SMP Pid: 10871, comm: multi_reflink_t Not tainted 2.6.39-300.17.1.el5uek #1 RIP: ocfs2_xa_offset_pointer+0x17/0x20 [ocfs2] RSP: e02b:ffff88007a587948 EFLAGS: 00010283 RAX: 0000000000000000 RBX: 0000000000000010 RCX: 00000000000051e4 RDX: ffff880057092060 RSI: 0000000000000f80 RDI: ffff88007a587a68 RBP: ffff88007a587948 R08: 00000000000062f4 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000010 R13: ffff88007a587a68 R14: 0000000000000001 R15: ffff88007a587c68 FS: 00007fccff7f06e0(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000 CS: e033 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000015cf000 CR3: 000000007aa76000 CR4: 0000000000000660 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process multi_reflink_t Call Trace: ocfs2_xa_reuse_entry+0x60/0x280 [ocfs2] ocfs2_xa_prepare_entry+0x17e/0x2a0 [ocfs2] ocfs2_xa_set+0xcc/0x250 [ocfs2] ocfs2_xattr_ibody_set+0x98/0x230 [ocfs2] __ocfs2_xattr_set_handle+0x4f/0x700 [ocfs2] ocfs2_xattr_set+0x6c6/0x890 [ocfs2] ocfs2_xattr_user_set+0x46/0x50 [ocfs2] generic_setxattr+0x70/0x90 __vfs_setxattr_noperm+0x80/0x1a0 vfs_setxattr+0xa9/0xb0 setxattr+0xc3/0x120 sys_fsetxattr+0xa8/0xd0 system_call_fastpath+0x16/0x1b Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21ext3,ext4: don't mess with dir_file->f_pos in htree_dirblock_to_tree()Al Viro
commit 64cb927371cd2ec43758d8a094a003d27bc3d0dc upstream. Both ext3 and ext4 htree_dirblock_to_tree() is just filling the in-core rbtree for use by call_filldir(). All updates of ->f_pos are done by the latter; bumping it here (on error) is obviously wrong - we might very well have it nowhere near the block we'd found an error in. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21jbd2: fix theoretical race in jbd2__journal_restartTheodore Ts'o
commit 39c04153fda8c32e85b51c96eb5511a326ad7609 upstream. Once we decrement transaction->t_updates, if this is the last handle holding the transaction from closing, and once we release the t_handle_lock spinlock, it's possible for the transaction to commit and be released. In practice with normal kernels, this probably won't happen, since the commit happens in a separate kernel thread and it's unlikely this could all happen within the space of a few CPU cycles. On the other hand, with a real-time kernel, this could potentially happen, so save the tid found in transaction->t_tid before we release t_handle_lock. It would require an insane configuration, such as one where the jbd2 thread was set to a very high real-time priority, perhaps because a high priority real-time thread is trying to read or write to a file system. But some people who use real-time kernels have been known to do insane things, including controlling laser-wielding industrial robots. :-) Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21CIFS use sensible file nlink values if unprovidedSteve French
commit 6658b9f70ebca5fc0795b1d6d733996af1e2caa7 upstream. Certain servers may not set the NumberOfLinks field in query file/path info responses. In such a case, cifs_inode_needs_reval() assumes that all regular files are hardlinks and triggers revalidation, leading to excessive and unnecessary network traffic. This change hardcodes cf_nlink (and subsequently i_nlink) when not returned by the server, similar to what already occurs in cifs_mkdir(). Signed-off-by: David Disseldorp <ddiss@suse.de> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-13nfsd4: fix decoding of compounds across page boundariesJ. Bruce Fields
commit 247500820ebd02ad87525db5d9b199e5b66f6636 upstream. A freebsd NFSv4.0 client was getting rare IO errors expanding a tarball. A network trace showed the server returning BAD_XDR on the final getattr of a getattr+write+getattr compound. The final getattr started on a page boundary. I believe the Linux client ignores errors on the post-write getattr, and that that's why we haven't seen this before. Reported-by: Rick Macklem <rmacklem@uoguelph.ca> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-13hpfs: better test for errorsMikulas Patocka
commit 3ebacb05044f82c5f0bb456a894eb9dc57d0ed90 upstream. The test if bitmap access is out of bound could errorneously pass if the device size is divisible by 16384 sectors and we are asking for one bitmap after the end. Check for invalid size in the superblock. Invalid size could cause integer overflows in the rest of the code. Signed-off-by: Mikulas Patocka <mpatocka@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03UBIFS: fix a horrid bugArtem Bityutskiy
commit 605c912bb843c024b1ed173dc427cd5c08e5d54d upstream. Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are in the middle of 'ubifs_readdir()'. This means that 'file->private_data' can be freed while 'ubifs_readdir()' uses it, and this is a very bad bug: not only 'ubifs_readdir()' can return garbage, but this may corrupt memory and lead to all kinds of problems like crashes an security holes. This patch fixes the problem by using the 'file->f_version' field, which '->llseek()' always unconditionally sets to zero. We set it to 1 in 'ubifs_readdir()' and whenever we detect that it became 0, we know there was a seek and it is time to clear the state saved in 'file->private_data'. I tested this patch by writing a user-space program which runds readdir and seek in parallell. I could easily crash the kernel without these patches, but could not crash it with these patches. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03UBIFS: prepare to fix a horrid bugArtem Bityutskiy
commit 33f1a63ae84dfd9ad298cf275b8f1887043ced36 upstream. Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are in the middle of 'ubifs_readdir()'. First of all, this means that 'file->private_data' can be freed while 'ubifs_readdir()' uses it. But this particular patch does not fix the problem. This patch is only a preparation, and the fix will follow next. In this patch we make 'ubifs_readdir()' stop using 'file->f_pos' directly, because 'file->f_pos' can be changed by '->llseek()' at any point. This may lead 'ubifs_readdir()' to returning inconsistent data: directory entry names may correspond to incorrect file positions. So here we introduce a local variable 'pos', read 'file->f_pose' once at very the beginning, and then stick to 'pos'. The result of this is that when 'ubifs_dir_llseek()' changes 'file->f_pos' while we are in the middle of 'ubifs_readdir()', the latter "wins". Reported-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03perf: Disable monitoring on setuid processes for regular usersStephane Eranian
commit 2976b10f05bd7f6dab9f9e7524451ddfed656a89 upstream. There was a a bug in setup_new_exec(), whereby the test to disabled perf monitoring was not correct because the new credentials for the process were not yet committed and therefore the get_dumpable() test was never firing. The patch fixes the problem by moving the perf_event test until after the credentials are committed. Signed-off-by: Stephane Eranian <eranian@google.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-27inotify: invalid mask should return a error number but not set itZhao Hongjiang
commit 04df32fa10ab9a6f0643db2949d42efc966bc844 upstream. When we run the crackerjack testsuite, the inotify_add_watch test is stalled. This is caused by the invalid mask 0 - the task is waiting for the event but it never comes. inotify_add_watch() should return -EINVAL as it did before commit 676a0675cf92 ("inotify: remove broken mask checks causing unmount to be EINVAL"). That commit removes the invalid mask check, but that check is needed. Check the mask's ALL_INOTIFY_BITS before the inotify_arg_to_mask() call. If none are set, just return -EINVAL. Because IN_UNMOUNT is in ALL_INOTIFY_BITS, this change will not trigger the problem that above commit fixed. [akpm@linux-foundation.org: fix build] Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Acked-by: Jim Somerville <Jim.Somerville@windriver.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20ceph: fix statvfs fr_sizeSage Weil
commit 92a49fb0f79f3300e6e50ddf56238e70678e4202 upstream. Different versions of glibc are broken in different ways, but the short of it is that for the time being, frsize should == bsize, and be used as the multiple for the blocks, free, and available fields. This mirrors what is done for NFS. The previous reporting of the page size for frsize meant that newer glibc and df would report a very small value for the fs size. Fixes http://tracker.ceph.com/issues/3793. Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Greg Farnum <greg@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20libceph: wrap auth ops in wrapper functionsSage Weil
commit 27859f9773e4a0b2042435b13400ee2c891a61f4 upstream. Use wrapper functions that check whether the auth op exists so that callers do not need a bunch of conditional checks. Simplifies the external interface. Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20libceph: add update_authorizer auth methodSage Weil
commit 0bed9b5c523d577378b6f83eab5835fe30c27208 upstream. Currently the messenger calls out to a get_authorizer con op, which will create a new authorizer if it doesn't yet have one. In the meantime, when we rotate our service keys, the authorizer doesn't get updated. Eventually it will be rejected by the server on a new connection attempt and get invalidated, and we will then rebuild a new authorizer, but this is not ideal. Instead, if we do have an authorizer, call a new update_authorizer op that will verify that the current authorizer is using the latest secret. If it is not, we will build a new one that does. This avoids the transient failure. This fixes one of the sorry sequence of events for bug http://tracker.ceph.com/issues/4282 Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20ceph: ceph_pagelist_append might sleep while atomicJim Schutt
commit 39be95e9c8c0b5668c9f8806ffe29bf9f4bc0f40 upstream. Ceph's encode_caps_cb() worked hard to not call __page_cache_alloc() while holding a lock, but it's spoiled because ceph_pagelist_addpage() always calls kmap(), which might sleep. Here's the result: [13439.295457] ceph: mds0 reconnect start [13439.300572] BUG: sleeping function called from invalid context at include/linux/highmem.h:58 [13439.309243] in_atomic(): 1, irqs_disabled(): 0, pid: 12059, name: kworker/1:1 . . . [13439.376225] Call Trace: [13439.378757] [<ffffffff81076f4c>] __might_sleep+0xfc/0x110 [13439.384353] [<ffffffffa03f4ce0>] ceph_pagelist_append+0x120/0x1b0 [libceph] [13439.391491] [<ffffffffa0448fe9>] ceph_encode_locks+0x89/0x190 [ceph] [13439.398035] [<ffffffff814ee849>] ? _raw_spin_lock+0x49/0x50 [13439.403775] [<ffffffff811cadf5>] ? lock_flocks+0x15/0x20 [13439.409277] [<ffffffffa045e2af>] encode_caps_cb+0x41f/0x4a0 [ceph] [13439.415622] [<ffffffff81196748>] ? igrab+0x28/0x70 [13439.420610] [<ffffffffa045e9f8>] ? iterate_session_caps+0xe8/0x250 [ceph] [13439.427584] [<ffffffffa045ea25>] iterate_session_caps+0x115/0x250 [ceph] [13439.434499] [<ffffffffa045de90>] ? set_request_path_attr+0x2d0/0x2d0 [ceph] [13439.441646] [<ffffffffa0462888>] send_mds_reconnect+0x238/0x450 [ceph] [13439.448363] [<ffffffffa0464542>] ? ceph_mdsmap_decode+0x5e2/0x770 [ceph] [13439.455250] [<ffffffffa0462e42>] check_new_map+0x352/0x500 [ceph] [13439.461534] [<ffffffffa04631ad>] ceph_mdsc_handle_map+0x1bd/0x260 [ceph] [13439.468432] [<ffffffff814ebc7e>] ? mutex_unlock+0xe/0x10 [13439.473934] [<ffffffffa043c612>] extra_mon_dispatch+0x22/0x30 [ceph] [13439.480464] [<ffffffffa03f6c2c>] dispatch+0xbc/0x110 [libceph] [13439.486492] [<ffffffffa03eec3d>] process_message+0x1ad/0x1d0 [libceph] [13439.493190] [<ffffffffa03f1498>] ? read_partial_message+0x3e8/0x520 [libceph] . . . [13439.587132] ceph: mds0 reconnect success [13490.720032] ceph: mds0 caps stale [13501.235257] ceph: mds0 recovery completed [13501.300419] ceph: mds0 caps renewed Fix it up by encoding locks into a buffer first, and when the number of encoded locks is stable, copy that into a ceph_pagelist. [elder@inktank.com: abbreviated the stack info a bit.] Signed-off-by: Jim Schutt <jaschut@sandia.gov> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20ceph: add cpu_to_le32() calls when encoding a reconnect capabilityJim Schutt
commit c420276a532a10ef59849adc2681f45306166b89 upstream. In his review, Alex Elder mentioned that he hadn't checked that num_fcntl_locks and num_flock_locks were properly decoded on the server side, from a le32 over-the-wire type to a cpu type. I checked, and AFAICS it is done; those interested can consult Locker::_do_cap_update() in src/mds/Locker.cc and src/include/encoding.h in the Ceph server code (git://github.com/ceph/ceph). I also checked the server side for flock_len decoding, and I believe that also happens correctly, by virtue of having been declared __le32 in struct ceph_mds_cap_reconnect, in src/include/ceph_fs.h. Signed-off-by: Jim Schutt <jaschut@sandia.gov> Reviewed-by: Alex Elder <elder@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07jfs: fix a couple racesDave Kleikamp
commit 73aaa22d5ffb2630456bac2f9a4ed9b81d0d7271 upstream. This patch fixes races uncovered by xfstests testcase 068. One race is the result of jfs_sync() trying to write a sync point to the journal after it has been frozen (or possibly in the process). Since freezing sync's the journal, there is no need to write a sync point so we simply want to return. The second involves jfs_write_inode() being called on a deleted inode. It calls jfs_flush_journal which is held up by the jfs_commit thread doing the final iput on the same deleted inode, which itself is waiting for the I_SYNC flag to be cleared. jfs_write_inode need not do anything when i_nlink is zero, which is the easy fix. Reported-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07cifs: fix potential buffer overrun when composing a new options stringJeff Layton
commit 166faf21bd14bc5c5295a44874bf7f3930c30b20 upstream. Consider the case where we have a very short ip= string in the original mount options, and when we chase a referral we end up with a very long IPv6 address. Be sure to allow for that possibility when estimating the size of the string to allocate. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07xfs: kill suid/sgid through the truncate path.Dave Chinner
commit 2962f5a5dcc56f69cbf62121a7be67cc15d6940b upstream. XFS has failed to kill suid/sgid bits correctly when truncating files of non-zero size since commit c4ed4243 ("xfs: split xfs_setattr") introduced in the 3.1 kernel. Fix it. Fix it. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07NFSv4: Fix a thinko in nfs4_try_open_cachedTrond Myklebust
commit f448badd34700ae728a32ba024249626d49c10e1 upstream. We need to pass the full open mode flags to nfs_may_open() when doing a delegated open. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundaryRyusuke Konishi
commit 136e8770cd5d1fe38b3c613100dd6dc4db6d4fa6 upstream. nilfs2: fix issue of nilfs_set_page_dirty for page at EOF boundary DESCRIPTION: There are use-cases when NILFS2 file system (formatted with block size lesser than 4 KB) can be remounted in RO mode because of encountering of "broken bmap" issue. The issue was reported by Anthony Doggett <Anthony2486@interfaces.org.uk>: "The machine I've been trialling nilfs on is running Debian Testing, Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.35-2), but I've also reproduced it (identically) with Debian Unstable amd64 and Debian Experimental (using the 3.8-trunk kernel). The problematic partitions were formatted with "mkfs.nilfs2 -b 1024 -B 8192"." SYMPTOMS: (1) System log contains error messages likewise: [63102.496756] nilfs_direct_assign: invalid pointer: 0 [63102.496786] NILFS error (device dm-17): nilfs_bmap_assign: broken bmap (inode number=28) [63102.496798] [63102.524403] Remounting filesystem read-only (2) The NILFS2 file system is remounted in RO mode. REPRODUSING PATH: (1) Create volume group with name "unencrypted" by means of vgcreate utility. (2) Run script (prepared by Anthony Doggett <Anthony2486@interfaces.org.uk>): ----------------[BEGIN SCRIPT]-------------------- VG=unencrypted lvcreate --size 2G --name ntest $VG mkfs.nilfs2 -b 1024 -B 8192 /dev/mapper/$VG-ntest mkdir /var/tmp/n mkdir /var/tmp/n/ntest mount /dev/mapper/$VG-ntest /var/tmp/n/ntest mkdir /var/tmp/n/ntest/thedir cd /var/tmp/n/ntest/thedir sleep 2 date darcs init sleep 2 dmesg|tail -n 5 date darcs whatsnew || true date sleep 2 dmesg|tail -n 5 ----------------[END SCRIPT]-------------------- REPRODUCIBILITY: 100% INVESTIGATION: As it was discovered, the issue takes place during segment construction after executing such sequence of user-space operations: open("_darcs/index", O_RDWR|O_CREAT|O_NOCTTY, 0666) = 7 fstat(7, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0 ftruncate(7, 60) The error message "NILFS error (device dm-17): nilfs_bmap_assign: broken bmap (inode number=28)" takes place because of trying to get block number for third block of the file with logical offset #3072 bytes. As it is possible to see from above output, the file has 60 bytes of the whole size. So, it is enough one block (1 KB in size) allocation for the whole file. Trying to operate with several blocks instead of one takes place because of discovering several dirty buffers for this file in nilfs_segctor_scan_file() method. The root cause of this issue is in nilfs_set_page_dirty function which is called just before writing to an mmapped page. When nilfs_page_mkwrite function handles a page at EOF boundary, it fills hole blocks only inside EOF through __block_page_mkwrite(). The __block_page_mkwrite() function calls set_page_dirty() after filling hole blocks, thus nilfs_set_page_dirty function (= a_ops->set_page_dirty) is called. However, the current implementation of nilfs_set_page_dirty() wrongly marks all buffers dirty even for page at EOF boundary. As a result, buffers outside EOF are inconsistently marked dirty and queued for write even though they are not mapped with nilfs_get_block function. FIX: This modifies nilfs_set_page_dirty() not to mark hole blocks dirty. Thanks to Vyacheslav Dubeyko for his effort on analysis and proposals for this issue. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reported-by: Anthony Doggett <Anthony2486@interfaces.org.uk> Reported-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07ocfs2: goto out_unlock if ocfs2_get_clusters_nocache() failed in ocfs2_fiemap()Joseph Qi
commit b4ca2b4b577c3530e34dcfaafccb2cc680ce95d1 upstream. Last time we found there is lock/unlock bug in ocfs2_file_aio_write, and then we did a thorough search for all lock resources in ocfs2_inode_info, including rw, inode and open lockres and found this bug. My kernel version is 3.0.13, and it is also in the lastest version 3.9. In ocfs2_fiemap, once ocfs2_get_clusters_nocache failed, it should goto out_unlock instead of out, because we need release buffer head, up read alloc sem and unlock inode. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Acked-by: Sunil Mushran <sunil.mushran@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07fat: fix possible overflow for fat_clustersOGAWA Hirofumi
commit 7b92d03c3239f43e5b86c9cc9630f026d36ee995 upstream. Intermediate value of fat_clusters can be overflowed on 32bits arch. Reported-by: Krzysztof Strasburger <strasbur@chkw386.ch.pwr.wroc.pl> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07cifs: only set ops for inodes in I_NEW stateJeff Layton
commit c2b93e0699723700f886ce17bb65ffd771195a6d upstream. It's generally not safe to reset the inode ops once they've been set. In the case where the inode was originally thought to be a directory and then later found to be a DFS referral, this can lead to an oops when we try to trigger an inode op on it after changing the ops to the blank referral operations. Reported-and-Tested-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24btrfs: don't stop searching after encountering the wrong itemGabriel de Perthuis
commit 03b71c6ca6286625d8f1ed44aabab9b5bf5dac10 upstream. The search ioctl skips items that are too large for a result buffer, but inline items of a certain size occuring before any search result is found would trigger an overflow and stop the search entirely. Bug: https://bugzilla.kernel.org/show_bug.cgi?id=57641 Signed-off-by: Gabriel de Perthuis <g2p.code+btrfs@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19hugetlbfs: fix mmap failure in unaligned size requestNaoya Horiguchi
commit af73e4d9506d3b797509f3c030e7dcd554f7d9c4 upstream. The current kernel returns -EINVAL unless a given mmap length is "almost" hugepage aligned. This is because in sys_mmap_pgoff() the given length is passed to vm_mmap_pgoff() as it is without being aligned with hugepage boundary. This is a regression introduced in commit 40716e29243d ("hugetlbfs: fix alignment of huge page requests"), where alignment code is pushed into hugetlb_file_setup() and the variable len in caller side is not changed. To fix this, this patch partially reverts that commit, and adds alignment code in caller side. And it also introduces hstate_sizelog() in order to get proper hstate to specified hugepage size. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=56881 [akpm@linux-foundation.org: fix warning when CONFIG_HUGETLB_PAGE=n] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: <iceman_dvd@yahoo.com> Cc: Steven Truelove <steven.truelove@utoronto.ca> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ext4: limit group search loop for non-extent filesLachlan McIlroy
commit e6155736ad76b2070652745f9e54cdea3f0d8567 upstream. In the case where we are allocating for a non-extent file, we must limit the groups we allocate from to those below 2^32 blocks, and ext4_mb_regular_allocator() attempts to do this initially by putting a cap on ngroups for the subsequent search loop. However, the initial target group comes in from the allocation context (ac), and it may already be beyond the artificially limited ngroups. In this case, the limit if (group == ngroups) group = 0; at the top of the loop is never true, and the loop will run away. Catch this case inside the loop and reset the search to start at group 0. [sandeen@redhat.com: add commit msg & comments] Signed-off-by: Lachlan McIlroy <lmcilroy@redhat.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19nfsd4: don't allow owner override on 4.1 CLAIM_FH opensJ. Bruce Fields
commit 9f415eb25574db4b73a9a712a4438e41dc284922 upstream. The Linux client is using CLAIM_FH to implement regular opens, not just recovery cases, so it depends on the server to check permissions correctly. Therefore the owner override, which may make sense in the delegation recovery case, isn't right in the CLAIM_FH case. Symptoms: on a client with 49f9a0fafd844c32f2abada047c0b9a5ba0d6255 "NFSv4.1: Enable open-by-filehandle", Bryan noticed this: touch test.txt chmod 000 test.txt echo test > test.txt succeeding. Reported-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11ext4: add check for inodes_count overflow in new resize ioctlTheodore Ts'o
commit 3f8a6411fbada1fa482276591e037f3b1adcf55b upstream. Addresses-Red-Hat-Bugzilla: #913245 Reported-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com> Signed-off-by: Lingzhu Xiang <lxiang@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11autofs - remove autofs dentry mount checkDavid Jeffery
commit ce8a5dbdf9e709bdaf4618d7ef8cceb91e8adc69 upstream. When checking if an autofs mount point is busy it isn't sufficient to only check if it's a mount point. For example, if the mount of an offset mountpoint in a tree is denied for this host by its export and the dentry becomes a process working directory the check incorrectly returns the mount as not in use at expire. This can happen since the default when mounting within a tree is nostrict, which means ingnore mount fails on mounts within the tree and continue. The nostrict option is meant to allow mounting in this case. Signed-off-by: David Jeffery <djeffery@redhat.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ext4: fix Kconfig documentation for CONFIG_EXT4_DEBUGTheodore Ts'o
commit 7f3e3c7cfcec148ccca9c0dd2dbfd7b00b7ac10f upstream. Fox the Kconfig documentation for CONFIG_EXT4_DEBUG to match the change made by commit a0b30c1229: ext4: use module parameters instead of debugfs for mballoc_debug Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ext4: fix online resizing for ext3-compat file systemsTheodore Ts'o
commit c5c72d814cf0f650010337c73638b25e6d14d2d4 upstream. Commit fb0a387dcdc restricts block allocations for indirect-mapped files to block groups less than s_blockfile_groups. However, the online resizing code wasn't setting s_blockfile_groups, so the newly added block groups were not available for non-extent mapped files. Reported-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ext4: fix journal callback list traversalDmitry Monakhov
commit 5d3ee20855e28169d711b394857ee608a5023094 upstream. It is incorrect to use list_for_each_entry_safe() for journal callback traversial because ->next may be removed by other task: ->ext4_mb_free_metadata() ->ext4_mb_free_metadata() ->ext4_journal_callback_del() This results in the following issue: WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250() Hardware name: list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107 Call Trace: [<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0 [<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50 [<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0 [<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250 [<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0 [<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570 [<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0 [<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0 [<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0 [<ffffffff810ad630>] ? wake_up_bit+0x40/0x40 [<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80 [<ffffffff810ac6be>] kthread+0x10e/0x120 [<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70 [<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0 [<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70 This patch fix the issue as follows: - ext4_journal_commit_callback() make list truly traversial safe simply by always starting from list_head - fix race between two ext4_journal_callback_del() and ext4_journal_callback_try_del() Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
