path: root/fs
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-03-08Merge branch 'master'; commit 'v2.6.38-rc7' into nextJames Morris
2011-03-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: no .snap inside of snapped namespace libceph: fix msgr standby handling libceph: fix msgr keepalive flag libceph: fix msgr backoff libceph: retry after authorization failure libceph: fix handling of short returns from get_user_pages ceph: do not clear I_COMPLETE from d_release ceph: do not set I_COMPLETE Revert "ceph: keep reference to parent inode on ceph_dentry"
2011-03-04nfs4: Ensure that ACL pages sent over NFS were not allocated from the slab (v3)Neil Horman
The "bad_page()" page allocator sanity check was reported recently (call chain as follows): bad_page+0x69/0x91 free_hot_cold_page+0x81/0x144 skb_release_data+0x5f/0x98 __kfree_skb+0x11/0x1a tcp_ack+0x6a3/0x1868 tcp_rcv_established+0x7a6/0x8b9 tcp_v4_do_rcv+0x2a/0x2fa tcp_v4_rcv+0x9a2/0x9f6 do_timer+0x2df/0x52c ip_local_deliver+0x19d/0x263 ip_rcv+0x539/0x57c netif_receive_skb+0x470/0x49f :virtio_net:virtnet_poll+0x46b/0x5c5 net_rx_action+0xac/0x1b3 __do_softirq+0x89/0x133 call_softirq+0x1c/0x28 do_softirq+0x2c/0x7d do_IRQ+0xec/0xf5 default_idle+0x0/0x50 ret_from_intr+0x0/0xa default_idle+0x29/0x50 cpu_idle+0x95/0xb8 start_kernel+0x220/0x225 _sinittext+0x22f/0x236 It occurs because an skb with a fraglist was freed from the tcp retransmit queue when it was acked, but a page on that fraglist had PG_Slab set (indicating it was allocated from the Slab allocator (which means the free path above can't safely free it via put_page. We tracked this back to an nfsv4 setacl operation, in which the nfs code attempted to fill convert the passed in buffer to an array of pages in __nfs4_proc_set_acl, which gets used by the skb->frags list in xs_sendpages. __nfs4_proc_set_acl just converts each page in the buffer to a page struct via virt_to_page, but the vfs allocates the buffer via kmalloc, meaning the PG_slab bit is set. We can't create a buffer with kmalloc and free it later in the tcp ack path with put_page, so we need to either: 1) ensure that when we create the list of pages, no page struct has PG_Slab set or 2) not use a page list to send this data Given that these buffers can be multiple pages and arbitrarily sized, I think (1) is the right way to go. I've written the below patch to allocate a page from the buddy allocator directly and copy the data over to it. This ensures that we have a put_page free-able page for every entry that winds up on an skb frag list, so it can be safely freed when the frame is acked. We do a put page on each entry after the rpc_call_sync call so as to drop our own reference count to the page, leaving only the ref count taken by tcp_sendpages. This way the data will be properly freed when the ack comes in Successfully tested by myself to solve the above oops. Note, as this is the result of a setacl operation that exceeded a page of data, I think this amounts to a local DOS triggerable by an uprivlidged user, so I'm CCing security on this as well. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Trond Myklebust <Trond.Myklebust@netapp.com> CC: security@kernel.org CC: Jeff Layton <jlayton@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-04ceph: no .snap inside of snapped namespaceSage Weil
Otherwise you can do things like # mkdir .snap/foo # cd .snap/foo/.snap # ls <badness> Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-03Merge branch 'i_nlink' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'i_nlink' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: hfs: fix rename() over non-empty directory udf: fix i_nlink limit fix reiserfs mkdir() breakage exofs: i_nlink races in rename() nilfs2: i_nlink races in rename() minix: i_nlink races in rename() ufs: i_nlink races in rename() sysv: i_nlink races in rename()
2011-03-03LSM: Pass -o remount options to the LSMEric Paris
The VFS mount code passes the mount options to the LSM. The LSM will remove options it understands from the data and the VFS will then pass the remaining options onto the underlying filesystem. This is how options like the SELinux context= work. The problem comes in that -o remount never calls into LSM code. So if you include an LSM specific option it will get passed to the filesystem and will cause the remount to fail. An example of where this is a problem is the 'seclabel' option. The SELinux LSM hook will print this word in /proc/mounts if the filesystem is being labeled using xattrs. If you pass this word on mount it will be silently stripped and ignored. But if you pass this word on remount the LSM never gets called and it will be passed to the FS. The FS doesn't know what seclabel means and thus should fail the mount. For example an ext3 fs mounted over loop # mount -o loop /tmp/fs /mnt/tmp # cat /proc/mounts | grep /mnt/tmp /dev/loop0 /mnt/tmp ext3 rw,seclabel,relatime,errors=continue,barrier=0,data=ordered 0 0 # mount -o remount /mnt/tmp mount: /mnt/tmp not mounted already, or bad option # dmesg EXT3-fs (loop0): error: unrecognized mount option "seclabel" or missing value This patch passes the remount mount options to an new LSM hook. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: James Morris <jmorris@namei.org>
2011-03-03Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: zero proper structure size for geometry calls
2011-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: fix regression that i-flag is not set on changeless checkpoints
2011-03-03ceph: do not clear I_COMPLETE from d_releaseSage Weil
First, this was racy anyway: d_release isn't called until well after the dentry is unhashed. Second, this runs afoul of the recent dcache change that clears d_parent prior to calling d_release (949854d0), causing a NULL pointer dereference. Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-03ceph: do not set I_COMPLETESage Weil
Do not set the I_COMPLETE flag on directories until we resolve races with dcache pruning. Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-03Revert "ceph: keep reference to parent inode on ceph_dentry"Sage Weil
This reverts commit 97d79b403ef03f729883246208ef5d8a2ebc4d68. This fails to account for d_parent changes due to rename or disconnected dentries due to submounts or NFS reexports. Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-03hfs: fix rename() over non-empty directoryAl Viro
merge hfs_unlink() and hfs_rmdir(), while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-03udf: fix i_nlink limitAl Viro
(256 << sizeof(x)) - 1 is not the maximal possible value of x... In reality, the maximal allowed value for UDF FileLinkCount is 65535. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-03fix reiserfs mkdir() breakageAl Viro
if directory has so many subdirectories that its link count is set to 1 (i.e. "can't tell accurately") and reiserfs_new_inode() fails, we shouldn't decrement the parent's link count in cleanup path; that's what DEC_DIR_INODE_NLINK() is for. As it is, we end up with parent suddenly getting zero i_nlink, with very unpleasant effects. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-03exofs: i_nlink races in rename()Al Viro
2011-03-03nilfs2: i_nlink races in rename()Al Viro
2011-03-03minix: i_nlink races in rename()Al Viro
2011-03-03ufs: i_nlink races in rename()Al Viro
2011-03-03sysv: i_nlink races in rename()Al Viro
2011-03-02Merge branch 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6: of/promtree: allow DT device matching by fixing 'name' brokenness (v5) x86: OLPC: have prom_early_alloc BUG rather than return NULL of/flattree: Drop an uninteresting message to pr_debug level of: Add missing of_address.h to xilinx ehci driver
2011-03-02of/flattree: Drop an uninteresting message to pr_debug levelPaul Bolle
This message looks like an error (which it isn't) when booting with a flattened device tree. Remove the message from normal kernel builds. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-02ext2: Fix link count corruption under heavy link+rename loadJosh Hunt
vfs_rename_other() does not lock renamed inode with i_mutex. Thus changing i_nlink in a non-atomic manner (which happens in ext2_rename()) can corrupt it as reported and analyzed by Josh. In fact, there is no good reason to mess with i_nlink of the moved file. We did it presumably to simulate linking into the new directory and unlinking from an old one. But the practical effect of this is disputable because fsck can possibly treat file as being properly linked into both directories without writing any error which is confusing. So we just stop increment-decrement games with i_nlink which also fixes the corruption. CC: stable@kernel.org CC: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Josh Hunt <johunt@akamai.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-03-01xfs: zero proper structure size for geometry callsAlex Elder
Commit 493f3358cb289ccf716c5a14fa5bb52ab75943e5 added this call to xfs_fs_geometry() in order to avoid passing kernel stack data back to user space: + memset(geo, 0, sizeof(*geo)); Unfortunately, one of the callers of that function passes the address of a smaller data type, cast to fit the type that xfs_fs_geometry() requires. As a result, this can happen: Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: f87aca93 Pid: 262, comm: xfs_fsr Not tainted 2.6.38-rc6-493f3358cb2+ #1 Call Trace: [<c12991ac>] ? panic+0x50/0x150 [<c102ed71>] ? __stack_chk_fail+0x10/0x18 [<f87aca93>] ? xfs_ioc_fsgeometry_v1+0x56/0x5d [xfs] Fix this by fixing that one caller to pass the right type and then copy out the subset it is interested in. Note: This patch is an alternative to one originally proposed by Eric Sandeen. Reported-by: Jeffrey Hundstad <jeffrey.hundstad@mnsu.edu> Signed-off-by: Alex Elder <aelder@sgi.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Tested-by: Jeffrey Hundstad <jeffrey.hundstad@mnsu.edu>
2011-03-02nilfs2: fix regression that i-flag is not set on changeless checkpointsRyusuke Konishi
According to the report from Jiro SEKIBA titled "regression in 2.6.37?" (Message-Id: <8739n8vs1f.wl%jir@sekiba.com>), on 2.6.37 and later kernels, lscp command no longer displays "i" flag on checkpoints that snapshot operations or garbage collection created. This is a regression of nilfs2 checkpointing function, and it's critical since it broke behavior of a part of nilfs2 applications. For instance, snapshot manager of TimeBrowse gets to create meaningless snapshots continuously; snapshot creation triggers another checkpoint, but applications cannot distinguish whether the new checkpoint contains meaningful changes or not without the i-flag. This patch fixes the regression and brings that application behavior back to normal. Reported-by: Jiro SEKIBA <jir@unicus.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Jiro SEKIBA <jir@unicus.jp> Cc: stable <stable@kernel.org> [2.6.37]
2011-02-28fs/block_dev.c: fix new kernel-doc warningRandy Dunlap
Fix new kernel-doc warning in fs/block_dev.c: Warning(fs/block_dev.c:937): No description found for parameter 'kill_dirty' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: fix truncate after open fuse: fix hang of single threaded fuseblk filesystem
2011-02-28Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: ocfs2: Check heartbeat mode for kernel stacks only Ocfs2/refcounttree: Fix a bug for refcounttree to writeback clusters in a right number. ocfs2: Fix estimate of necessary credits for mkdir
2011-02-25aio: fix race between io_destroy() and io_submit()Jan Kara
A race can occur when io_submit() races with io_destroy(): CPU1 CPU2 io_submit() do_io_submit() ... ctx = lookup_ioctx(ctx_id); io_destroy() Now do_io_submit() holds the last reference to ctx. ... queue new AIO put_ioctx(ctx) - frees ctx with active AIOs We solve this issue by checking whether ctx is being destroyed in AIO submission path after adding new AIO to ctx. Then we are guaranteed that either io_destroy() waits for new AIO or we see that ctx is being destroyed and bail out. Cc: Nick Piggin <npiggin@kernel.dk> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25aio: fix rcu ioctx lookupNick Piggin
aio-dio-invalidate-failure GPFs in aio_put_req from io_submit. lookup_ioctx doesn't implement the rcu lookup pattern properly. rcu_read_lock does not prevent refcount going to zero, so we might take a refcount on a zero count ioctx. Fix the bug by atomically testing for zero refcount before incrementing. [jack@suse.cz: added comment into the code] Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25ldm: corrupted partition table can cause kernel oopsTimo Warns
The kernel automatically evaluates partition tables of storage devices. The code for evaluating LDM partitions (in fs/partitions/ldm.c) contains a bug that causes a kernel oops on certain corrupted LDM partitions. A kernel subsystem seems to crash, because, after the oops, the kernel no longer recognizes newly connected storage devices. The patch changes ldm_parse_vmdb() to Validate the value of vblk_size. Signed-off-by: Timo Warns <warns@pre-sense.de> Cc: Eugene Teo <eugeneteo@kernel.sg> Acked-by: Richard Russon <ldm@flatcap.org> Cc: Harvey Harrison <harvey.harrison@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25epoll: prevent creating circular epoll structuresDavide Libenzi
In several places, an epoll fd can call another file's ->f_op->poll() method with ep->mtx held. This is in general unsafe, because that other file could itself be an epoll fd that contains the original epoll fd. The code defends against this possibility in its own ->poll() method using ep_call_nested, but there are several other unsafe calls to ->poll elsewhere that can be made to deadlock. For example, the following simple program causes the call in ep_insert recursively call the original fd's ->poll, leading to deadlock: #include <unistd.h> #include <sys/epoll.h> int main(void) { int e1, e2, p[2]; struct epoll_event evt = { .events = EPOLLIN }; e1 = epoll_create(1); e2 = epoll_create(2); pipe(p); epoll_ctl(e2, EPOLL_CTL_ADD, e1, &evt); epoll_ctl(e1, EPOLL_CTL_ADD, p[0], &evt); write(p[1], p, sizeof p); epoll_ctl(e1, EPOLL_CTL_ADD, e2, &evt); return 0; } On insertion, check whether the inserted file is itself a struct epoll, and if so, do a recursive walk to detect whether inserting this file would create a loop of epoll structures, which could lead to deadlock. [nelhage@ksplice.com: Use epmutex to serialize concurrent inserts] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Reported-by: Nelson Elhage <nelhage@ksplice.com> Tested-by: Nelson Elhage <nelhage@ksplice.com> Cc: <stable@kernel.org> [2.6.34+, possibly earlier] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix fiemap bugs with delalloc Btrfs: set FMODE_EXCL in btrfs_device->mode Btrfs: make btrfs_rm_device() fail gracefully Btrfs: Avoid accessing unmapped kernel address Btrfs: Fix BTRFS_IOC_SUBVOL_SETFLAGS ioctl Btrfs: allow balance to explicitly allocate chunks as it relocates Btrfs: put ENOSPC debugging under a mount option
2011-02-25Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: Fix - again - partition detection when array becomes active Fix over-zealous flush_disk when changing device size. md: avoid spinlock problem in blk_throtl_exit md: correctly handle probe of an 'mdp' device. md: don't set_capacity before array is active. md: Fix raid1->raid0 takeover
2011-02-25afs: Fix oops in afs_unlink_writebackAnton Blanchard
I'm seeing the following oops when testing afs: Unable to handle kernel paging request for data at address 0x00000008 ... NIP [c0000000003393b0] .afs_unlink_writeback+0x38/0xc0 LR [c00000000033987c] .afs_put_writeback+0x98/0xec Call Trace: [c00000000345f600] [c00000000033987c] .afs_put_writeback+0x98/0xec [c00000000345f690] [c00000000033ae80] .afs_write_begin+0x6a4/0x75c [c00000000345f790] [c00000000012b77c] .generic_file_buffered_write+0x148/0x320 [c00000000345f8d0] [c00000000012e1b8] .__generic_file_aio_write+0x37c/0x3e4 [c00000000345f9d0] [c00000000012e2a8] .generic_file_aio_write+0x88/0xfc [c00000000345fa90] [c0000000003390a8] .afs_file_write+0x10c/0x178 [c00000000345fb40] [c000000000188788] .do_sync_write+0xc4/0x128 [c00000000345fcc0] [c000000000189658] .vfs_write+0xe8/0x1d8 [c00000000345fd70] [c000000000189884] .SyS_write+0x68/0xb0 [c00000000345fe30] [c000000000008564] syscall_exit+0x0/0x40 afs_write_begin hits an error and calls afs_unlink_writeback. In there we do list_del_init on an uninitialised list. The patch below initialises ->link when creating the afs_writeback struct. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25fuse: fix truncate after openMiklos Szeredi
Commit e1181ee6 "vfs: pass struct file to do_truncate on O_TRUNC opens" broke the behavior of open(O_TRUNC|O_RDONLY) in fuse. Fuse assumed that when called from open, a truncate() will be done, not an ftruncate(). Fix by restoring the old behavior, based on the ATTR_OPEN flag. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-02-25fuse: fix hang of single threaded fuseblk filesystemMiklos Szeredi
Single threaded NTFS-3G could get stuck if a delayed RELEASE reply triggered a DESTROY request via path_put(). Fix this by a) making RELEASE requests synchronous, whenever possible, on fuseblk filesystems b) if not possible (triggered by an asynchronous read/write) then do the path_put() in a separate thread with schedule_work(). Reported-by: Oliver Neukum <oneukum@suse.de> Cc: stable@kernel.org Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-02-24block: bd_link_disk_holder() should hold on to holder_dirTejun Heo
The new implementation of bd_link_disk_holder() added by 49731baa41d (block: restore multiple bd_link_disk_holder() support) didn't get an extra reference for the holder_dir kobject of the slave bdev; however, bdev kills holder_dir on removal, not release, so if the slave bdev is removed while there are holder links, the holder_dir will be destroyed while there still are holder links, which leads to oops later when bd_unlink_disk_order() tries to remove those links. Make bd_link_disk_holder() grab an extra reference for the slave's holder_dir and put it in bd_unlink_disk_holder(). Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: "Hawrylewicz Czarnowski, Przemyslaw" <przemyslaw.hawrylewicz.czarnowski@intel.com> Tested-by: "Hawrylewicz Czarnowski, Przemyslaw" <przemyslaw.hawrylewicz.czarnowski@intel.com> Cc: Neil Brown <neilb@suse.de> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-24Unlock vfsmount_lock in do_umountJ. R. Okajima
By the commit b3e19d9 2011-01-07 fs: scale mntget/mntput vfsmount_lock was introduced around testing mnt_count. Fix the mis-typed 'unlock' Signed-off-by: J. R. Okajima <hooanon05@yahoo.co.jp> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-24Fix over-zealous flush_disk when changing device size.NeilBrown
There are two cases when we call flush_disk. In one, the device has disappeared (check_disk_change) so any data will hold becomes irrelevant. In the oter, the device has changed size (check_disk_size_change) so data we hold may be irrelevant. In both cases it makes sense to discard any 'clean' buffers, so they will be read back from the device if needed. In the former case it makes sense to discard 'dirty' buffers as there will never be anywhere safe to write the data. In the second case it *does*not* make sense to discard dirty buffers as that will lead to file system corruption when you simply enlarge the containing devices. flush_disk calls __invalidate_devices. __invalidate_device calls both invalidate_inodes and invalidate_bdev. invalidate_inodes *does* discard I_DIRTY inodes and this does lead to fs corruption. invalidate_bev *does*not* discard dirty pages, but I don't really care about that at present. So this patch adds a flag to __invalidate_device (calling it __invalidate_device2) to indicate whether dirty buffers should be killed, and this is passed to invalidate_inodes which can choose to skip dirty inodes. flusk_disk then passes true from check_disk_change and false from check_disk_size_change. dm avoids tripping over this problem by calling i_size_write directly rathher than using check_disk_size_change. md does use check_disk_size_change and so is affected. This regression was introduced by commit 608aeef17a which causes check_disk_size_change to call flush_disk, so it is suitable for any kernel since 2.6.27. Cc: stable@kernel.org Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Andrew Patterson <andrew.patterson@hp.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: NeilBrown <neilb@suse.de>
2011-02-23mm: prevent concurrent unmap_mapping_range() on the same inodeMiklos Szeredi
Michael Leun reported that running parallel opens on a fuse filesystem can trigger a "kernel BUG at mm/truncate.c:475" Gurudas Pai reported the same bug on NFS. The reason is, unmap_mapping_range() is not prepared for more than one concurrent invocation per inode. For example: thread1: going through a big range, stops in the middle of a vma and stores the restart address in vm_truncate_count. thread2: comes in with a small (e.g. single page) unmap request on the same vma, somewhere before restart_address, finds that the vma was already unmapped up to the restart address and happily returns without doing anything. Another scenario would be two big unmap requests, both having to restart the unmapping and each one setting vm_truncate_count to its own value. This could go on forever without any of them being able to finish. Truncate and hole punching already serialize with i_mutex. Other callers of unmap_mapping_range() do not, and it's difficult to get i_mutex protection for all callers. In particular ->d_revalidate(), which calls invalidate_inode_pages2_range() in fuse, may be called with or without i_mutex. This patch adds a new mutex to 'struct address_space' to prevent running multiple concurrent unmap_mapping_range() on the same mapping. [ We'll hopefully get rid of all this with the upcoming mm preemptibility series by Peter Zijlstra, the "mm: Remove i_mmap_mutex lockbreak" patch in particular. But that is for 2.6.39 ] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reported-by: Michael Leun <lkml20101129@newton.leun.net> Reported-by: Gurudas Pai <gurudas.pai@oracle.com> Tested-by: Gurudas Pai <gurudas.pai@oracle.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-23Btrfs: fix fiemap bugs with delallocChris Mason
The Btrfs fiemap code wasn't properly returning delalloc extents, so applications that trust fiemap to decide if there are holes in the file see holes instead of delalloc. This reworks the btrfs fiemap code, adding a get_extent helper that searches for delalloc ranges and also adding a helper for extent_fiemap that skips past holes in the file. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-02-22xfs: check if device support discard in xfs_ioc_trim()Lukas Czerner
Right now we, are relying on the fact that when we attempt to actually do the discard, blkdev_issue_discar() returns -EOPNOTSUPP and the user is informed that the device does not support discard. However, in the case where the we do not hit any suitable free extent to trim in FITRIM code, it will finish without any error. This is very confusing, because it seems that FITRIM was successful even though the device does not actually supports discard. Solution: Check for the discard support before attempt to search for free extents. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-02-22xfs: prevent leaking uninitialized stack memory in FSGEOMETRY_V1Dan Rosenberg
The FSGEOMETRY_V1 ioctl (and its compat equivalent) calls out to xfs_fs_geometry() with a version number of 3. This code path does not fill in the logsunit member of the passed xfs_fsop_geom_t, leading to the leaking of four bytes of uninitialized stack data to potentially unprivileged callers. v2 switches to memset() to avoid future issues if structure members change, on suggestion of Dave Chinner. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Reviewed-by: Eugene Teo <eugeneteo@kernel.org> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6: eCryptfs: Copy up lower inode attrs in getattr ecryptfs: read on a directory should return EISDIR if not supported eCryptfs: Handle NULL nameidata pointers eCryptfs: Revert "dont call lookup_one_len to avoid NULL nameidata"
2011-02-21Docbook: add fs/eventfd.c and fix typos in itRandy Dunlap
Add fs/eventfd.c to filesystems docbook. Make typo corrections in fs/eventfd.c. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: keep reference to parent inode on ceph_dentry ceph: queue cap_snaps once per realm libceph: fix socket write error handling libceph: fix socket read error handling
2011-02-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] update cifs version cifs: Fix regression in LANMAN (LM) auth code cifs: fix handling of scopeid in cifs_convert_address
2011-02-21[CIFS] update cifs versionSteve French
Update version to 1.71 so we can more easily spot modules with the last two fixes Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-02-21cifs: Fix regression in LANMAN (LM) auth codeShirish Pargaonkar
LANMAN response length was changed to 16 bytes instead of 24 bytes. Revert it back to 24 bytes. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> CC: stable@kernel.org Signed-off-by: Steve French <sfrench@us.ibm.com>
