path: root/fs
2011-09-21Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: floppy: use del_timer_sync() in init cleanup blk-cgroup: be able to remove the record of unplugged device block: Don't check QUEUE_FLAG_SAME_COMP in __blk_complete_request mm: Add comment explaining task state setting in bdi_forker_thread() mm: Cleanup clearing of BDI_pending bit in bdi_forker_thread() block: simplify force plug flush code a little bit block: change force plug flush call order block: Fix queue_flag update when rq_affinity goes from 2 to 1 block: separate priority boosting from REQ_META block: remove READ_META and WRITE_META xen-blkback: fixed indentation and comments xen-blkback: Don't disconnect backend until state switched to XenbusStateClosed.
2011-09-21teach /proc/$pid/numa_maps about transparent hugepagesDave Hansen
This is modeled after the smaps code. It detects transparent hugepages and then does a single gather_stats() for the page as a whole. This has two benifits: 1. It is more efficient since it does many pages in a single shot. 2. It does not have to break down the huge page. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-21break out numa_maps gather_pte_stats() checksDave Hansen
gather_pte_stats() does a number of checks on a target page to see whether it should even be considered for statistics. This breaks that code out in to a separate function so that we can use it in the transparent hugepage case in the next patch. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Hugh Dickins <hughd@google.com> Reviewed-by: Christoph Lameter <cl@gentwo.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-21make /proc/$pid/numa_maps gather_stats() take variable page sizeDave Hansen
We need to teach the numa_maps code about transparent huge pages. The first step is to teach gather_stats() that the pte it is dealing with might represent more than one page. Note that will we use this in a moment for transparent huge pages since they have use a single pmd_t which _acts_ as a "surrogate" for a bunch of smaller pte_t's. I'm a _bit_ unhappy that this interface counts in hugetlbfs page sizes for hugetlbfs pages and PAGE_SIZE for normal pages. That means that to figure out how many _bytes_ "dirty=1" means, you must first know the hugetlbfs page size. That's easier said than done especially if you don't have visibility in to the mount. But, that's probably a discussion for another day especially since it would change behavior to fix it. But, just in case anyone wonders why this patch only passes a '1' in the hugetlb case... Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-20Merge branch 'for-linus' of git://github.com/chrismason/linuxLinus Torvalds
* 'for-linus' of git://github.com/chrismason/linux: Btrfs: reserve sufficient space for ioctl clone
2011-09-20Merge branch 'btrfs-3.0' into for-linusChris Mason
2011-09-20Btrfs: reserve sufficient space for ioctl cloneSage Weil
Fix a crash/BUG_ON in the clone ioctl due to insufficient reservation. We need to reserve space for: - adjusting the old extent (possibly splitting it) - adding the new extent - updating the inode Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-19cifs: Fix broken sec=ntlmv2/i sec option (try #2)Shirish Pargaonkar
Fix sec=ntlmv2/i authentication option during mount of Samba shares. cifs client was coding ntlmv2 response incorrectly. All that is needed in temp as specified in MS-NLMP seciton 3.3.2 "Define ComputeResponse(NegFlg, ResponseKeyNT, ResponseKeyLM, CHALLENGE_MESSAGE.ServerChallenge, ClientChallenge, Time, ServerName) as Set temp to ConcatenationOf(Responserversion, HiResponserversion, Z(6), Time, ClientChallenge, Z(4), ServerName, Z(4)" is MsvAvNbDomainName. For sec=ntlmsspi, build_av_pair is not used, a blob is plucked from type 2 response sent by the server to use in authentication. I tested sec=ntlmv2/i and sec=ntlmssp/i mount options against Samba (3.6) and Windows - XP, 2003 Server and 7. They all worked. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-09-19Fix the conflict between rwpidforward and rw mount optionsSteve French
Both these options are started with "rw" - that's why the first one isn't switched on even if it is specified. Fix this by adding a length check for "rw" option check. Cc: <stable@kernel.org> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-09-19CIFS: Fix ERR_PTR dereference in cifs_get_rootPavel Shilovsky
move it to the beginning of the loop. Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-09-19cifs: fix possible memory corruption in CIFSFindNextJeff Layton
The name_len variable in CIFSFindNext is a signed int that gets set to the resume_name_len in the cifs_search_info. The resume_name_len however is unsigned and for some infolevels is populated directly from a 32 bit value sent by the server. If the server sends a very large value for this, then that value could look negative when converted to a signed int. That would make that value pass the PATH_MAX check later in CIFSFindNext. The name_len would then be used as a length value for a memcpy. It would then be treated as unsigned again, and the memcpy scribbles over a ton of memory. Fix this by making the name_len an unsigned value in CIFSFindNext. Cc: <stable@kernel.org> Reported-by: Darren Lavender <dcl@hppine99.gbr.hp.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-09-19Merge branch 'for-linus' of git://github.com/chrismason/linuxLinus Torvalds
* 'for-linus' of git://github.com/chrismason/linux: Btrfs: only clear the need lookup flag after the dentry is setup BTRFS: Fix lseek return value for error Btrfs: don't change inode flag of the dest clone file Btrfs: don't make a file partly checksummed through file clone Btrfs: fix pages truncation in btrfs_ioctl_clone() btrfs: fix d_off in the first dirent
2011-09-18Btrfs: only clear the need lookup flag after the dentry is setupJosef Bacik
We can race with readdir and the RCU path walking stuff. This is because we clear the need lookup flag before actually instantiating the inode. This will lead the RCU path walk stuff to find a dentry it thinks is valid without a d_inode attached. So instead unhash the dentry when we first start the lookup, and then clear the flag after we've instantiated the dentry so we're garunteed to either try the slow lookup, or have the d_inode set properly. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-18BTRFS: Fix lseek return value for errorJeff Liu
The recent reworking of btrfs' lseek lead to incorrect values being returned. This adds checks for seeking beyond EOF in SEEK_HOLE and makes sure the error values come back correct. Andi Kleen also sent in similar patches. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-18Merge branch 'btrfs-3.0' into for-linusChris Mason
2011-09-18Btrfs: don't change inode flag of the dest clone fileLi Zefan
The dst file will have the same inode flags with dst file after file clone, and I think it's unexpected. For example, the dst file will suddenly become immutable after getting some share of data with src file, if the src is immutable. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-18Btrfs: don't make a file partly checksummed through file cloneLi Zefan
To reproduce the bug: # mount /dev/sda7 /mnt # dd if=/dev/zero of=/mnt/src bs=4K count=1 # umount /mnt # mount -o nodatasum /dev/sda7 /mnt # dd if=/dev/zero of=/mnt/dst bs=4K count=1 # clone_range -s 4K -l 4K /mnt/src /mnt/dst # echo 3 > /proc/sys/vm/drop_caches # cat /mnt/dst # dmesg ... btrfs no csum found for inode 258 start 0 btrfs csum failed ino 258 off 0 csum 2566472073 private 0 It's because part of the file is checksummed and the other part is not, and then btrfs will complain checksum is not found when we read the file. Disallow file clone if src and dst file have different checksum flag, so we ensure a file is completely checksummed or unchecksummed. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-18Btrfs: fix pages truncation in btrfs_ioctl_clone()Li Zefan
It's a bug in commit f81c9cdc567cd3160ff9e64868d9a1a7ee226480 (Btrfs: truncate pages from clone ioctl target range) We should pass the dest range to the truncate function, but not the src range. Also move the function before locking extent state. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-18btrfs: fix d_off in the first direntHidetoshi Seto
Since the d_off in the first dirent for "." (that originates from the 4th argument "offset" of filldir() for the 2nd dirent for "..") is wrongly assigned in btrfs_real_readdir(), telldir returns same offset for different locations. | # mkfs.btrfs /dev/sdb1 | # mount /dev/sdb1 fs0 | # cd fs0 | # touch file0 file1 | # ../test | telldir: 0 | readdir: d_off = 2, d_name = "." | telldir: 2 | readdir: d_off = 2, d_name = ".." | telldir: 2 | readdir: d_off = 3, d_name = "file0" | telldir: 3 | readdir: d_off = 2147483647, d_name = "file1" | telldir: 2147483647 To fix this problem, pass filp->f_pos (which is loff_t) instead. | # ../test | telldir: 0 | readdir: d_off = 1, d_name = "." | telldir: 1 | readdir: d_off = 2, d_name = ".." | telldir: 2 | readdir: d_off = 3, d_name = "file0" : At the moment the "offset" for "." is unused because there is no preceding dirent, however it is better to pass filp->f_pos to follow grammatical usage. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-15Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: nfs: Do not allow multiple mounts on same mountpoint when using -o noac NFS: Fix a typo in nfs_flush_multi NFSv4: renewd needs to be able to handle the NFS4ERR_CB_PATH_DOWN error NFSv4: The NFSv4.0 client must send RENEW calls if it holds a delegation NFSv4: nfs4_proc_renew should be declared static NFSv4: nfs4_proc_async_renew should use a GFP_NOFS allocation
2011-09-15hfsplus: fix filesystem size checksChristoph Hellwig
generic_check_addressable can't deal with hfsplus's larger than page size allocation blocks, so simply opencode the checks that we actually need in hfsplus_fill_super. Signed-off-by: Christoph Hellwig <hch@tuxera.com> Reported-by: Pavel Ivanov <paivanof@gmail.com> Tested-by: Pavel Ivanov <paivanof@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-15hfsplus: Fix kfree of wrong pointers in hfsplus_fill_super() error pathSeth Forshee
Commit 6596528e391a ("hfsplus: ensure bio requests are not smaller than the hardware sectors") changed the pointers used for volume header allocations but failed to free the correct pointers in the error path path of hfsplus_fill_super() and hfsplus_read_wrapper. The second hunk came from a separate patch by Pavel Ivanov. Reported-by: Pavel Ivanov <paivanof@gmail.com> Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Christoph Hellwig <hch@tuxera.com> Cc: <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: fix a use after free in xfs_end_io_direct_write
2011-09-14restore pinning the victim dentry in vfs_rmdir()/vfs_rename_dir()Al Viro
We used to get the victim pinned by dentry_unhash() prior to commit 64252c75a219 ("vfs: remove dget() from dentry_unhash()") and ->rmdir() and ->rename() instances relied on that; most of them don't care, but ones that used d_delete() themselves do. As the result, we are getting rmdir() oopses on NFS now. Just grab the reference before locking the victim and drop it explicitly after unlocking, same as vfs_rename_other() does. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Simon Kirby <sim@hostway.ca> Cc: stable@kernel.org (3.0.x) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14xfs: fix a use after free in xfs_end_io_direct_writeChristoph Hellwig
There is a window in which the ioend that we call inode_dio_wake on in xfs_end_io_direct_write is already free. Fix this by storing the inode pointer in a local variable. This is a fix for the regression introduced in 3.1-rc by "fs: move inode_dio_done to the end_io handler". Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-09-13nfs: Do not allow multiple mounts on same mountpoint when using -o noacSachin Prabhu
Do not allow multiple mounts on same mountpoint when using -o noac When you normally attempt to mount a share twice on the same mountpoint, a check in do_add_mount causes it to return an error # mount localhost:/nfsv3 /mnt # mount localhost:/nfsv3 /mnt mount.nfs: /mnt is already mounted or busy However when using the option 'noac', the user is able to mount the same share on the same mountpoint multiple times. This happens because a share mounted with the noac option is automatically assigned the 'sync' flag MS_SYNCHRONOUS in nfs_initialise_sb(). This flag is set after the check for already existing superblocks is done in sget(). The check for the mount flags in nfs_compare_mount_options() does not take into account the 'sync' flag applied later on in the code path. This means that when using 'noac', a new superblock structure is assigned for every new mount of the same share and multiple shares on the same mountpoint are allowed. ie. # mount -onoac localhost:/nfsv3 /mnt can be run multiple times. The patch checks for noac and assigns the sync flag before sget() is called to obtain an already existing superblock structure. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-09-13NFS: Fix a typo in nfs_flush_multiTrond Myklebust
Fix a typo which causes an Oops in the RPC layer, when using wsize < 4k. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Sricharan R <r.sricharan@ti.com>
2011-09-12Merge branch 'for-linus' of git://github.com/chrismason/linuxLinus Torvalds
* 'for-linus' of git://github.com/chrismason/linux: Btrfs: add dummy extent if dst offset excceeds file end in Btrfs: calc file extent num_bytes correctly in file clone btrfs: xattr: fix attribute removal Btrfs: fix wrong nbytes information of the inode Btrfs: fix the file extent gap when doing direct IO Btrfs: fix unclosed transaction handle in btrfs_cont_expand Btrfs: fix misuse of trans block rsv Btrfs: reset to appropriate block rsv after orphan operations Btrfs: skip locking if searching the commit root in csum lookup btrfs: fix warning in iput for bad-inode Btrfs: fix an oops when deleting snapshots
2011-09-12fuse: fix memory leakMiklos Szeredi
kmemleak is reporting that 32 bytes are being leaked by FUSE: unreferenced object 0xe373b270 (size 32): comm "fusermount", pid 1207, jiffies 4294707026 (age 2675.187s) hex dump (first 32 bytes): 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<b05517d7>] kmemleak_alloc+0x27/0x50 [<b0196435>] kmem_cache_alloc+0xc5/0x180 [<b02455be>] fuse_alloc_forget+0x1e/0x20 [<b0245670>] fuse_alloc_inode+0xb0/0xd0 [<b01b1a8c>] alloc_inode+0x1c/0x80 [<b01b290f>] iget5_locked+0x8f/0x1a0 [<b0246022>] fuse_iget+0x72/0x1a0 [<b02461da>] fuse_get_root_inode+0x8a/0x90 [<b02465cf>] fuse_fill_super+0x3ef/0x590 [<b019e56f>] mount_nodev+0x3f/0x90 [<b0244e95>] fuse_mount+0x15/0x20 [<b019d1bc>] mount_fs+0x1c/0xc0 [<b01b5811>] vfs_kern_mount+0x41/0x90 [<b01b5af9>] do_kern_mount+0x39/0xd0 [<b01b7585>] do_mount+0x2e5/0x660 [<b01b7966>] sys_mount+0x66/0xa0 This leak report is consistent and happens once per boot on 3.1.0-rc5-dirty. This happens if a FORGET request is queued after the fuse device was released. Reported-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-12fuse: fix flock breakageMiklos Szeredi
Commit 37fb3a30b4 ("fuse: fix flock") added in 3.1-rc4 caused flock() to fail with ENOSYS with the kernel ABI version 7.16 or earlier. Fix by falling back to testing FUSE_POSIX_LOCKS for ABI versions 7.16 and earlier. Reported-by: Martin Ziegler <ziegler@email.mathematik.uni-freiburg.de> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Martin Ziegler <ziegler@email.mathematik.uni-freiburg.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-11Btrfs: add dummy extent if dst offset excceeds file end inLi Zefan
You can see there's no file extent with range [0, 4096]. Check this by btrfsck: # btrfsck /dev/sda7 root 5 inode 258 errors 100 ... Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: calc file extent num_bytes correctly in file cloneLi Zefan
num_bytes should be 4096 not 12288. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11btrfs: xattr: fix attribute removalDavid Sterba
An attribute is not removed by 'setfattr -x attr file' and remains visible in attr list. This makes xfstests/062 pass again. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: fix wrong nbytes information of the inodeMiao Xie
If we write some data into the data hole of the file(no preallocation for this hole), Btrfs will allocate some disk space, and update nbytes of the inode, but the other element--disk_i_size needn't be updated. At this condition, we must update inode metadata though disk_i_size is not changed(btrfs_ordered_update_i_size() return 1). # mkfs.btrfs /dev/sdb1 # mount /dev/sdb1 /mnt # touch /mnt/a # truncate -s 856002 /mnt/a # dd if=/dev/zero of=/mnt/a bs=4K count=1 conv=nocreat,notrunc # umount /mnt # btrfsck /dev/sdb1 root 5 inode 257 errors 400 found 32768 bytes used err is 1 Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: fix the file extent gap when doing direct IOMiao Xie
When we write some data to the place that is beyond the end of the file in direct I/O mode, a data hole will be created. And Btrfs should insert a file extent item that point to this hole into the fs tree. But unfortunately Btrfs forgets doing it. The following is a simple way to reproduce it: # mkfs.btrfs /dev/sdc2 # mount /dev/sdc2 /test4 # touch /test4/a # dd if=/dev/zero of=/test4/a seek=8 count=1 bs=4K oflag=direct conv=nocreat,notrunc # umount /test4 # btrfsck /dev/sdc2 root 5 inode 257 errors 100 Reported-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Tested-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: fix unclosed transaction handle in btrfs_cont_expandMiao Xie
The function - btrfs_cont_expand() forgot to close the transaction handle before it jump out the while loop. Fix it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: fix misuse of trans block rsvLiu Bo
At the beginning of create_pending_snapshot, trans->block_rsv is set to pending->block_rsv and is used for snapshot things, however, when it is done, we do not recover it as will. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: reset to appropriate block rsv after orphan operationsLiu Bo
While truncating free space cache, we forget to change trans->block_rsv back to the original one, but leave it with the orphan_block_rsv, and then with option inode_cache enable, it leads to countless warnings of btrfs_alloc_free_block and btrfs_orphan_commit_root: WARNING: at fs/btrfs/extent-tree.c:5711 btrfs_alloc_free_block+0x180/0x350 [btrfs]() ... WARNING: at fs/btrfs/inode.c:2193 btrfs_orphan_commit_root+0xb0/0xc0 [btrfs]() Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: skip locking if searching the commit root in csum lookupJosef Bacik
It's not enough to just search the commit root, since we could be cow'ing the very block we need to search through, which would mean that its locked and we'll still deadlock. So use path->skip_locking as well. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11btrfs: fix warning in iput for bad-inodeSergei Trofimovich
iput() shouldn't be called for inodes in I_NEW state. We need to mark inode as constructed first. WARNING: at fs/inode.c:1309 iput+0x20b/0x210() Call Trace: [<ffffffff8103e7ba>] warn_slowpath_common+0x7a/0xb0 [<ffffffff8103e805>] warn_slowpath_null+0x15/0x20 [<ffffffff810eaf0b>] iput+0x20b/0x210 [<ffffffff811b96fb>] btrfs_iget+0x1eb/0x4a0 [<ffffffff811c3ad6>] btrfs_run_defrag_inodes+0x136/0x210 [<ffffffff811ad55f>] cleaner_kthread+0x17f/0x1a0 [<ffffffff81035b7d>] ? sub_preempt_count+0x9d/0xd0 [<ffffffff811ad3e0>] ? transaction_kthread+0x280/0x280 [<ffffffff8105af86>] kthread+0x96/0xa0 [<ffffffff814336d4>] kernel_thread_helper+0x4/0x10 [<ffffffff8105aef0>] ? kthread_worker_fn+0x190/0x190 [<ffffffff814336d0>] ? gs_change+0xb/0xb Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org> CC: Konstantin Khlebnikov <khlebnikov@openvz.org> Tested-by: David Sterba <dsterba@suse.cz> CC: Josef Bacik <josef@redhat.com> CC: Chris Mason <chris.mason@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: fix an oops when deleting snapshotsLiu Bo
We can reproduce this oops via the following steps: $ mkfs.btrfs /dev/sdb7 $ mount /dev/sdb7 /mnt/btrfs $ for ((i=0; i<3; i++)); do btrfs sub snap /mnt/btrfs /mnt/btrfs/s_$i; done $ rm -fr /mnt/btrfs/* $ rm -fr /mnt/btrfs/* then we'll get ------------[ cut here ]------------ kernel BUG at fs/btrfs/inode.c:2264! [...] Call Trace: [<ffffffffa05578c7>] btrfs_rmdir+0xf7/0x1b0 [btrfs] [<ffffffff81150b95>] vfs_rmdir+0xa5/0xf0 [<ffffffff81153cc3>] do_rmdir+0x123/0x140 [<ffffffff81145ac7>] ? fput+0x197/0x260 [<ffffffff810aecff>] ? audit_syscall_entry+0x1bf/0x1f0 [<ffffffff81153d0d>] sys_unlinkat+0x2d/0x40 [<ffffffff8147896b>] system_call_fastpath+0x16/0x1b RIP [<ffffffffa054f7b9>] btrfs_orphan_add+0x179/0x1a0 [btrfs] When it comes to btrfs_lookup_dentry, we may set a snapshot's inode->i_ino to BTRFS_EMPTY_SUBVOL_DIR_OBJECTID instead of BTRFS_FIRST_FREE_OBJECTID, while the snapshot's location.objectid remains unchanged. However, btrfs_ino() does not take this into account, and returns a wrong ino, and causes the oops. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-10Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: Fix handling for devices from 2TB to 4TB in 0.90 metadata. md/raid1,10: Remove use-after-free bug in make_request. md/raid10: unify handling of write completion. Avoid dereferencing a 'request_queue' after last close.
2011-09-10Avoid dereferencing a 'request_queue' after last close.NeilBrown
On the last close of an 'md' device which as been stopped, the device is destroyed and in particular the request_queue is freed. The free is done in a separate thread so it might happen a short time later. __blkdev_put calls bdev_inode_switch_bdi *after* ->release has been called. Since commit f758eeabeb96f878c860e8f110f94ec8820822a9 bdev_inode_switch_bdi will dereference the 'old' bdi, which lives inside a request_queue, to get a spin lock. This causes the last close on an md device to sometime take a spin_lock which lives in freed memory - which results in an oops. So move the called to bdev_inode_switch_bdi before the call to ->release. Cc: Christoph Hellwig <hch@lst.de> Cc: Hugh Dickins <hughd@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-09Merge branch 'for-linus' of git://ceph.newdream.net/git/ceph-clientLinus Torvalds
* 'for-linus' of git://ceph.newdream.net/git/ceph-client: libceph: fix leak of osd structs during shutdown ceph: fix memory leak ceph: fix encoding of ino only (not relative) paths libceph: fix msgpool
2011-09-09vfs: automount should ignore LOOKUP_FOLLOWMiklos Szeredi
Prior to 2.6.38 automount would not trigger on either stat(2) or lstat(2) on the automount point. After 2.6.38, with the introduction of the ->d_automount() infrastructure, stat(2) and others would start triggering automount while lstat(2), etc. still would not. This is a regression and a userspace ABI change. Problem originally reported here: http://thread.gmane.org/gmane.linux.kernel.autofs/6098 It appears that there was an attempt at fixing various userspace tools to not trigger the automount. But since the stat system call is rather common it is impossible to "fix" all userspace. This patch reverts the original behavior, which is to not trigger on stat(2) and other symlink following syscalls. [ It's not really clear what the right behavior is. Apparently Solaris does the "automount on stat, leave alone on lstat". And some programs can get unhappy when "stat+open+fstat" ends up giving a different result from the fstat than from the initial stat. But the change in 2.6.38 resulted in problems for some people, so we're going back to old behavior. Maybe we can re-visit this discussion at some future date - Linus ] Reported-by: Leonardo Chiquitto <leonardo.lists@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Ian Kent <raven@themaw.net> Cc: David Howells <dhowells@redhat.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-07Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6 and ↵Linus Torvalds
git://git.infradead.org/ubi-2.6 * branch 'linux-next' of git://git.infradead.org/ubifs-2.6: UBIFS: not build debug messages with CONFIG_UBIFS_FS_DEBUG disabled * branch 'linux-next' of git://git.infradead.org/ubi-2.6: UBI: do not link debug messages when debugging is disabled
2011-09-06fs/9p: Use protocol-defined value for lock/getlock 'type' field.Jim Garlick
Signed-off-by: Jim Garlick <garlick@llnl.gov> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-09-06fs/9p: Always ask new inode in lookup for cache mode disabledAneesh Kumar K.V
This make sure we don't end up reusing the unlinked inode object. The ideal way is to use inode i_generation. But i_generation is not available in userspace always. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-09-06fs/9p: Add OS dependent open flags in 9p protocolAneesh Kumar K.V
Some of the flags are OS/arch dependent we add a 9p protocol value which maps to asm-generic/fcntl.h values in Linux Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-09-06fs/9p: Don't update file type when updating file attributesAneesh Kumar K.V
We should only update attributes that we can change on stat2inode. Also do file type initialization in v9fs_init_inode. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
