path: root/fs
2011-07-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: CIFS: Fix wrong length in cifs_iovec_read
2011-07-21vfs: drop conditional inode prefetch in __do_lookup_rcuLinus Torvalds
It seems to hurt performance in real life. Yes, the inode will be used later, but the conditional doesn't seem to predict all that well (negative dentries are not uncommon) and it looks like the cost of prefetching is simply higher than depending on the cache doing the right thing. As usual. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-21FS-Cache: Fix __fscache_uncache_all_inode_pages()'s outer loopJan Beulich
The compiler, at least for ix86 and m68k, validly warns that the comparison: next <= (loff_t)-1 is always true (and it's always true also for x86-64 and probably all other arches - as long as pgoff_t isn't wider than loff_t). The intention appears to be to avoid wrapping of "next", so rather than eliminating the pointless comparison, fix the loop to indeed get exited when "next" would otherwise wrap. On m68k the following warning is observed: fs/fscache/page.c: In function '__fscache_uncache_all_inode_pages': fs/fscache/page.c:979: warning: comparison is always false due to limited range of data type Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Reported-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Suresh Jayaraman <sjayaraman@suse.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-21CIFS: Fix wrong length in cifs_iovec_readPavel Shilovsky
Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-19fs/libfs.c: fix simple_attr_write() on 32bit machinesAkinobu Mita
Assume that /sys/kernel/debug/dummy64 is debugfs file created by debugfs_create_x64(). # cd /sys/kernel/debug # echo 0x1234567812345678 > dummy64 # cat dummy64 0x0000000012345678 # echo 0x80000000 > dummy64 # cat dummy64 0xffffffff80000000 A value larger than INT_MAX cannot be written to the debugfs file created by debugfs_create_u64 or debugfs_create_x64 on 32bit machine. Because simple_attr_write() uses simple_strtol() for the conversion. To fix this, use simple_strtoll() instead. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: vfs: fix race in rcu lookup of pruned dentry Fix cifs_get_root() [ Edited the last commit to get rid of a 'unused variable "seq"' warning due to Al editing the patch. - Linus ]
2011-07-19vfs: fix race in rcu lookup of pruned dentryLinus Torvalds
Don't update *inode in __follow_mount_rcu() until we'd verified that there is mountpoint there. Kudos to Hugh Dickins for catching that one in the first place and eventually figuring out the solution (and catching a braino in the earlier version of patch). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-18Fix cifs_get_root()Al Viro
Add missing ->i_mutex, convert to lookup_one_len() instead of (broken) open-coded analog, cope with getting something like a//b as relative pathname. Simplify the hell out of it, while we are there... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Reviewed-by: Jeff Layton <jlayton@redhat.com>
2011-07-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: hppfs_lookup(): don't open-code lookup_one_len() hppfs: fix dentry leak cramfs: get_cramfs_inode() returns ERR_PTR() on failure ufs should use d_splice_alias() fix exofs ->get_parent() ceph analog of cifs build_path_from_dentry() race fix cifs: build_path_from_dentry() race fix
2011-07-17hppfs_lookup(): don't open-code lookup_one_len()Al Viro
... and it's getting it wrong, too - missing ->d_revalidate() calls when it's dealing with filesystem (procfs) that has non-trivial ->d_revalidate()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-17hppfs: fix dentry leakAl Viro
2011-07-17cramfs: get_cramfs_inode() returns ERR_PTR() on failureAl Viro
... and we want to report these failures in ->lookup() anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-17ufs should use d_splice_alias()Al Viro
it's NFS-exportable, so... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-17fix exofs ->get_parent()Al Viro
NULL is not a possible return value for that method, TYVM... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] update cifs to version 1.74 [CIFS] update limit for snprintf in cifs_construct_tcon cifs: Fix signing failure when server mandates signing for NTLMSSP
2011-07-16ceph analog of cifs build_path_from_dentry() race fixAl Viro
... unfortunately, cifs bug got copied. Fix is essentially the same. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-16cifs: build_path_from_dentry() race fixAl Viro
deal with d_move() races properly; rename_lock read-retry loop, rcu_read_lock() held while walking to root, d_lock held over subtraction from namelen and copying the component to stabilize ->d_name. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fix loop checks in d_materialise_unique() Fix ->d_lock locking order in unlazy_walk()
2011-07-14fix loop checks in d_materialise_unique()Al Viro
Both __d_unalias() and __d_materialise_dentry() need loop prevention. Grab rename_lock in caller, check for loops there... As a side benefit, we have dentry_lock_for_move() called only under rename_lock, which seriously reduces deadlock potential of the execrable "locking order" used for ->d_lock. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes: GFS2: Resolve inode eviction and ail list interaction bug GFS2: Fix race during filesystem mount GFS2: force a log flush when invalidating the rindex glock
2011-07-14GFS2: Resolve inode eviction and ail list interaction bugSteven Whitehouse
This patch contains a few misc fixes which resolve a recently reported issue. This patch has been a real team effort and has received a lot of testing. The first issue is that the ail lock needs to be held over a few more operations. The lock thats added into gfs2_releasepage() may possibly be a candidate for replacing with RCU at some future point, but at this stage we've gone for the obvious fix. The second issue is that gfs2_write_inode() can end up calling a glock recursively when called from gfs2_evict_inode() via the syncing code, so it needs a guard added. The third issue is that we either need to not truncate the metadata pages of inodes which have zero link count, but which we cannot deallocate due to them still being in use by other nodes, or we need to ensure that those pages have all made it through the journal and ail lists first. This patch takes the former approach, but the latter has also been tested and there is nothing to choose between them performance-wise. So again, we could revise that decision in the future. Also, the inode eviction process is now better documented. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Tested-by: Bob Peterson <rpeterso@redhat.com> Tested-by: Abhijith Das <adas@redhat.com> Reported-by: Barry J. Marson <bmarson@redhat.com> Reported-by: David Teigland <teigland@redhat.com>
2011-07-13Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: SUNRPC: Fix use of static variable in rpcb_getport_async NFSv4.1: update nfs4_fattr_bitmap_maxsz SUNRPC: Fix a race between work-queue and rpc_killall_tasks pnfs: write: Set mds_offset in the generic layer - it is needed by all LDs
2011-07-12Fix ->d_lock locking order in unlazy_walk()Al Viro
Make sure that child is still a child of parent before nested locking of child->d_lock in unlazy_walk(); otherwise we are risking a violation of locking order and deadlocks. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-12[CIFS] update cifs to version 1.74Steve French
2011-07-12[CIFS] update limit for snprintf in cifs_construct_tconSteve French
In 34c87901e113 "Shrink stack space usage in cifs_construct_tcon" we change the size of the username name buffer from MAX_USERNAME_SIZE (256) to 28. This call to snprintf() needs to be updated as well. Reported by Dan Carpenter. Reviewed-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-12cifs: Fix signing failure when server mandates signing for NTLMSSPShirish Pargaonkar
When using NTLMSSP authentication mechanism, if server mandates signing, keep the flags in type 3 messages of the NTLMSSP exchange same as in type 1 messages (i.e. keep the indicated capabilities same). Some of the servers such as Samba, expect the flags such as Negotiate_Key_Exchange in type 3 message of NTLMSSP exchange as well. Some servers like Windows do not. https://bugzilla.samba.org/show_bug.cgi?id=8212 Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-12GFS2: Fix race during filesystem mountSteven Whitehouse
There is a potential race during filesystem mounting which has recently been reported. It occurs when the userland gfs_controld is able to process requests fast enough that it tries to use the sysfs interface before the lock module is properly initialised. This is a pretty unusual case as normally the lock module initialisation is very quick compared with gfs_controld. This patch adds an interruptible completion which is used to ensure that userland will wait for the initialisation of the lock module to complete. There are other potential solutions to this problem, but this is the quickest at this stage and has been tested both with and without mount.gfs2 present in the system. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Reported-by: David Booher <dbooher@adams.net>
2011-07-12GFS2: force a log flush when invalidating the rindex glockBenjamin Marzinski
Right now, there is nothing that forces the log to get flushed when a node drops its rindex glock so that another node can grow the filesystem. If the log doesn't get flushed, GFS2 can corrupt the sd_log_le_rg list in the following way. A node puts an rgd on the list in rg_lo_add(), and then the rindex glock is dropped so the other node can grow the filesystem. When the node reacquires the rindex glock, that rgd gets deleted in clear_rgrpdi() before ever being removed from the list by gfs2_log_flush(). This code simply forces a log flush when the rindex glock is invalidated, solving the problem. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-07-11NFSv4.1: update nfs4_fattr_bitmap_maxszAndy Adamson
Attribute IDs assigned in RFC 5661 now require three bitmaps. Fixes hitting a BUG_ON in xdr_shrink_bufhead when getting ACLs. Signed-off-by: Andy Adamson <andros@netapp.com> Cc:stable@kernel.org [2.6.39] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: drop spinlock before calling cifs_put_tlink cifs: fix expand_dfs_referral cifs: move bdi_setup_and_register outside of CONFIG_CIFS_DFS_UPCALL cifs: factor smb_vol allocation out of cifs_setup_volume_info cifs: have cifs_cleanup_volume_info not take a double pointer cifs: fix build_unc_path_to_root to account for a prefixpath cifs: remove bogus call to cifs_cleanup_volume_info
2011-07-11cifs: drop spinlock before calling cifs_put_tlinkJeff Layton
...as that function can sleep. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-09cifs: fix expand_dfs_referralJeff Layton
Regression introduced in commit 724d9f1cfba. Prior to that, expand_dfs_referral would regenerate the mount data string and then call cifs_parse_mount_options to re-parse it (klunky, but it worked). The above commit moved cifs_parse_mount_options out of cifs_mount, so the re-parsing of the new mount options no longer occurred. Fix it by making expand_dfs_referral re-parse the mount options. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-09cifs: move bdi_setup_and_register outside of CONFIG_CIFS_DFS_UPCALLJeff Layton
This needs to be done regardless of whether that KConfig option is set or not. Reported-by: Sven-Haegar Koch <haegar@sdinet.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: btrfs: fix oops when doing space balance Btrfs: don't panic if we get an error while balancing V2 btrfs: add missing options displayed in mount output
2011-07-08Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: unpin stale inodes directly in IOP_COMMITTED
2011-07-08cifs: factor smb_vol allocation out of cifs_setup_volume_infoJeff Layton
Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-07FS-Cache: Add a helper to bulk uncache pages on an inodeDavid Howells
Add an FS-Cache helper to bulk uncache pages on an inode. This will only work for the circumstance where the pages in the cache correspond 1:1 with the pages attached to an inode's page cache. This is required for CIFS and NFS: When disabling inode cookie, we were returning the cookie and setting cifsi->fscache to NULL but failed to invalidate any previously mapped pages. This resulted in "Bad page state" errors and manifested in other kind of errors when running fsstress. Fix it by uncaching mapped pages when we disable the inode cookie. This patch should fix the following oops and "Bad page state" errors seen during fsstress testing. ------------[ cut here ]------------ kernel BUG at fs/cachefiles/namei.c:201! invalid opcode: 0000 [#1] SMP Pid: 5, comm: kworker/u:0 Not tainted 2.6.38.7-30.fc15.x86_64 #1 Bochs Bochs RIP: 0010: cachefiles_walk_to_object+0x436/0x745 [cachefiles] RSP: 0018:ffff88002ce6dd00 EFLAGS: 00010282 RAX: ffff88002ef165f0 RBX: ffff88001811f500 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000100 RDI: 0000000000000282 RBP: ffff88002ce6dda0 R08: 0000000000000100 R09: ffffffff81b3a300 R10: 0000ffff00066c0a R11: 0000000000000003 R12: ffff88002ae54840 R13: ffff88002ae54840 R14: ffff880029c29c00 R15: ffff88001811f4b0 FS: 00007f394dd32720(0000) GS:ffff88002ef00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007fffcb62ddf8 CR3: 000000001825f000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process kworker/u:0 (pid: 5, threadinfo ffff88002ce6c000, task ffff88002ce55cc0) Stack: 0000000000000246 ffff88002ce55cc0 ffff88002ce6dd58 ffff88001815dc00 ffff8800185246c0 ffff88001811f618 ffff880029c29d18 ffff88001811f380 ffff88002ce6dd50 ffffffff814757e4 ffff88002ce6dda0 ffffffff8106ac56 Call Trace: cachefiles_lookup_object+0x78/0xd4 [cachefiles] fscache_lookup_object+0x131/0x16d [fscache] fscache_object_work_func+0x1bc/0x669 [fscache] process_one_work+0x186/0x298 worker_thread+0xda/0x15d kthread+0x84/0x8c kernel_thread_helper+0x4/0x10 RIP cachefiles_walk_to_object+0x436/0x745 [cachefiles] ---[ end trace 1d481c9af1804caa ]--- I tested the uncaching by the following means: (1) Create a big file on my NFS server (104857600 bytes). (2) Read the file into the cache with md5sum on the NFS client. Look in /proc/fs/fscache/stats: Pages : mrk=25601 unc=0 (3) Open the file for read/write ("bash 5<>/warthog/bigfile"). Look in proc again: Pages : mrk=25601 unc=25601 Reported-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de> cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-06btrfs: fix oops when doing space balanceMiao Xie
We need to make sure the data relocation inode doesn't go through the delayed metadata updates, otherwise we get an oops during balance: kernel BUG at fs/btrfs/relocation.c:4303! [SNIP] Call Trace: [<ffffffffa03143fd>] ? update_ref_for_cow+0x22d/0x330 [btrfs] [<ffffffffa0314951>] __btrfs_cow_block+0x451/0x5e0 [btrfs] [<ffffffffa031355d>] ? read_block_for_search+0x14d/0x4d0 [btrfs] [<ffffffffa0314beb>] btrfs_cow_block+0x10b/0x240 [btrfs] [<ffffffffa031acae>] btrfs_search_slot+0x49e/0x7a0 [btrfs] [<ffffffffa032d8af>] btrfs_lookup_inode+0x2f/0xa0 [btrfs] [<ffffffff8147bf0e>] ? mutex_lock+0x1e/0x50 [<ffffffffa0380cf1>] btrfs_update_delayed_inode+0x71/0x160 [btrfs] [<ffffffffa037ff27>] ? __btrfs_release_delayed_node+0x67/0x190 [btrfs] [<ffffffffa0381cf8>] btrfs_run_delayed_items+0xe8/0x120 [btrfs] [<ffffffffa03365e0>] btrfs_commit_transaction+0x250/0x850 [btrfs] [<ffffffff810f91d9>] ? find_get_pages+0x39/0x130 [<ffffffffa0336cd5>] ? join_transaction+0x25/0x250 [btrfs] [<ffffffff81081de0>] ? wake_up_bit+0x40/0x40 [<ffffffffa03785fa>] prepare_to_relocate+0xda/0xf0 [btrfs] [<ffffffffa037f2bb>] relocate_block_group+0x4b/0x620 [btrfs] [<ffffffffa0334cf5>] ? btrfs_clean_old_snapshots+0x35/0x150 [btrfs] [<ffffffffa037fa43>] btrfs_relocate_block_group+0x1b3/0x2e0 [btrfs] [<ffffffffa0368ec0>] ? btrfs_tree_unlock+0x50/0x50 [btrfs] [<ffffffffa035e39b>] btrfs_relocate_chunk+0x8b/0x670 [btrfs] [<ffffffffa031303d>] ? btrfs_set_path_blocking+0x3d/0x50 [btrfs] [<ffffffffa03577d8>] ? read_extent_buffer+0xd8/0x1d0 [btrfs] [<ffffffffa031bea1>] ? btrfs_previous_item+0xb1/0x150 [btrfs] [<ffffffffa03577d8>] ? read_extent_buffer+0xd8/0x1d0 [btrfs] [<ffffffffa035f5aa>] btrfs_balance+0x21a/0x2b0 [btrfs] [<ffffffffa0368898>] btrfs_ioctl+0x798/0xd20 [btrfs] [<ffffffff8111e358>] ? handle_mm_fault+0x148/0x270 [<ffffffff814809e8>] ? do_page_fault+0x1d8/0x4b0 [<ffffffff81160d6a>] do_vfs_ioctl+0x9a/0x540 [<ffffffff811612b1>] sys_ioctl+0xa1/0xb0 [<ffffffff81484ec2>] system_call_fastpath+0x16/0x1b [SNIP] RIP [<ffffffffa037c1cc>] btrfs_reloc_cow_block+0x22c/0x270 [btrfs] Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-07-06Btrfs: don't panic if we get an error while balancing V2Josef Bacik
A user reported an error where if we try to balance an fs after a device has been removed it will blow up. This is because we get an EIO back and this is where BUG_ON(ret) bites us in the ass. To fix we just exit. Thanks, Reported-by: Anand Jain <Anand.Jain@oracle.com> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-07-06btrfs: add missing options displayed in mount outputDavid Sterba
There are three missed mount options settable by user which are not currently displayed in mount output. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-07-06xfs: unpin stale inodes directly in IOP_COMMITTEDDave Chinner
When inodes are marked stale in a transaction, they are treated specially when the inode log item is being inserted into the AIL. It tries to avoid moving the log item forward in the AIL due to a race condition with the writing the underlying buffer back to disk. The was "fixed" in commit de25c18 ("xfs: avoid moving stale inodes in the AIL"). To avoid moving the item forward, we return a LSN smaller than the commit_lsn of the completing transaction, thereby trying to trick the commit code into not moving the inode forward at all. I'm not sure this ever worked as intended - it assumes the inode is already in the AIL, but I don't think the returned LSN would have been small enough to prevent moving the inode. It appears that the reason it worked is that the lower LSN of the inodes meant they were inserted into the AIL and flushed before the inode buffer (which was moved to the commit_lsn of the transaction). The big problem is that with delayed logging, the returning of the different LSN means insertion takes the slow, non-bulk path. Worse yet is that insertion is to a position -before- the commit_lsn so it is doing a AIL traversal on every insertion, and has to walk over all the items that have already been inserted into the AIL. It's expensive. To compound the matter further, with delayed logging inodes are likely to go from clean to stale in a single checkpoint, which means they aren't even in the AIL at all when we come across them at AIL insertion time. Hence these were all getting inserted into the AIL when they simply do not need to be as inodes marked XFS_ISTALE are never written back. Transactional/recovery integrity is maintained in this case by the other items in the unlink transaction that were modified (e.g. the AGI btree blocks) and committed in the same checkpoint. So to fix this, simply unpin the stale inodes directly in xfs_inode_item_committed() and return -1 to indicate that the AIL insertion code does not need to do any further processing of these inodes. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-07-06cifs: have cifs_cleanup_volume_info not take a double pointerJeff Layton
...as that makes for a cumbersome interface. Make it take a regular smb_vol pointer and rely on the caller to zero it out if needed. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-06cifs: fix build_unc_path_to_root to account for a prefixpathJeff Layton
Regression introduced by commit f87d39d9513. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-06cifs: remove bogus call to cifs_cleanup_volume_infoJeff Layton
This call to cifs_cleanup_volume_info is clearly wrong. As soon as it's called the following call to cifs_get_tcp_session will oops as the volume_info pointer will then be NULL. The caller of cifs_mount should clean up this data since it passed it in. There's no need for us to call this here. Regression introduced by commit 724d9f1cfba. Reported-by: Adam Williamson <awilliam@redhat.com> Cc: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-06FDPIC: Fix memory leakDavidlohr Bueso
The shdr4extnum variable isn't being freed in the cleanup process of elf_fdpic_core_dump(). Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-06fs: fix lock initializationMiklos Szeredi
locks_alloc_lock() assumed that the allocated struct file_lock is already initialized to zero members. This is only true for the first allocation of the structure, after reuse some of the members will have random values. This will for example result in passing random fl_start values to userspace in fuse for FL_FLOCK locks, which is an information leak at best. Fix by reinitializing those members which may be non-zero after freeing. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: fix sync and dio writes across stripe boundaries libceph: fix page calculation for non-page-aligned io ceph: fix page alignment corrections
git://git.kernel.org/pub/scm/linux/kernel/git/hch/hfsplus * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/hch/hfsplus: hfsplus: Fix double iput of the same inode in hfsplus_fill_super() hfsplus: add missing call to bio_put()
2011-07-01cifs: set socket send and receive timeouts before attempting connectJeff Layton
Benjamin S. reported that he was unable to suspend his machine while it had a cifs share mounted. The freezer caused this to spew when he tried it: -----------------------[snip]------------------ PM: Syncing filesystems ... done. Freezing user space processes ... (elapsed 0.01 seconds) done. Freezing remaining freezable tasks ... Freezing of tasks failed after 20.01 seconds (1 tasks refusing to freeze, wq_busy=0): cifsd S ffff880127f7b1b0 0 1821 2 0x00800000 ffff880127f7b1b0 0000000000000046 ffff88005fe008a8 ffff8800ffffffff ffff880127cee6b0 0000000000011100 ffff880127737fd8 0000000000004000 ffff880127737fd8 0000000000011100 ffff880127f7b1b0 ffff880127736010 Call Trace: [<ffffffff811e85dd>] ? sk_reset_timer+0xf/0x19 [<ffffffff8122cf3f>] ? tcp_connect+0x43c/0x445 [<ffffffff8123374e>] ? tcp_v4_connect+0x40d/0x47f [<ffffffff8126ce41>] ? schedule_timeout+0x21/0x1ad [<ffffffff8126e358>] ? _raw_spin_lock_bh+0x9/0x1f [<ffffffff811e81c7>] ? release_sock+0x19/0xef [<ffffffff8123e8be>] ? inet_stream_connect+0x14c/0x24a [<ffffffff8104485b>] ? autoremove_wake_function+0x0/0x2a [<ffffffffa02ccfe2>] ? ipv4_connect+0x39c/0x3b5 [cifs] [<ffffffffa02cd7b7>] ? cifs_reconnect+0x1fc/0x28a [cifs] [<ffffffffa02cdbdc>] ? cifs_demultiplex_thread+0x397/0xb9f [cifs] [<ffffffff81076afc>] ? perf_event_exit_task+0xb9/0x1bf [<ffffffffa02cd845>] ? cifs_demultiplex_thread+0x0/0xb9f [cifs] [<ffffffffa02cd845>] ? cifs_demultiplex_thread+0x0/0xb9f [cifs] [<ffffffff810444a1>] ? kthread+0x7a/0x82 [<ffffffff81002d14>] ? kernel_thread_helper+0x4/0x10 [<ffffffff81044427>] ? kthread+0x0/0x82 [<ffffffff81002d10>] ? kernel_thread_helper+0x0/0x10 Restarting tasks ... done. -----------------------[snip]------------------ We do attempt to perform a try_to_freeze in cifs_reconnect, but the connection attempt itself seems to be taking longer than 20s to time out. The connect timeout is governed by the socket send and receive timeouts, so we can shorten that period by setting those timeouts before attempting the connect instead of after. Adam Williamson tested the patch and said that it seems to have fixed suspending on his laptop when a cifs share is mounted. Reported-by: Benjamin S <da_joind@gmx.net> Tested-by: Adam Williamson <awilliam@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-06-30hfsplus: Fix double iput of the same inode in hfsplus_fill_super()Alexey Khoroshilov
There is a misprint in resource deallocation code on error path in hfsplus_fill_super(): the sbi->alloc_file inode is iput twice, while the root inode in not iput at all. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Christoph Hellwig <hch@lst.de>
