path: root/fs
2017-12-21vfs: make O_PATH file descriptors usable for 'fchdir()'Linus Torvalds
We already use them for openat() and friends, but fchdir() also wants to be able to use O_PATH file descriptors. This should make it comparable to the O_SEARCH of Solaris. In particular, O_PATH allows you to access (not-quite-open) a directory you don't have read persmission to, only execute permission. Noticed during development of multithread support for ksh93. Reported-by: ольга крыжановская <olga.kryzhanovska@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org # O_PATH introduced in 3.0+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 332a2e1244bd08b9e3ecd378028513396a004a24) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21vfs: make O_PATH file descriptors usable for 'fstat()'Linus Torvalds
We already use them for openat() and friends, but fstat() also wants to be able to use O_PATH file descriptors. This should make it more directly comparable to the O_SEARCH of Solaris. Note that you could already do the same thing with "fstatat()" and an empty path, but just doing "fstat()" directly is simpler and faster, so there is no reason not to just allow it directly. See also commit 332a2e1244bd, which did the same thing for fchdir, for the same reasons. Reported-by: ольга крыжановская <olga.kryzhanovska@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org # O_PATH introduced in 3.0+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 55815f70147dcfa3ead5738fd56d3574e2e3c1c2) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21VFS: make vfs_fstat() use f[get|put]_light()Linus Torvalds
Use the *_light() versions that properly avoid doing the file user count updates when they are unnecessary. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit e994defb7b6813ba6fa7a2a36e86d2455ad1dc35) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-03-30Merge remote-tracking branch 'remotes/ubifs-v3.1/master' into tegra-nand-nextMarcel Ziswiler
Conflicts: drivers/mtd/ubi/ubi.h drivers/mtd/ubi/wl.c
2014-10-28yaffs: fix spinning when flush inodesStefan Agner
While in list_for_each_entry() of yaffs_flush_inodes, the fs code can delete inodes. This leads to an endless loop which causes a softlockup. Typically this happend in sync_supers when creating and deleting files while under CPU load. This fix checks whether we get twice the same inode. If this is true, we just retry again. This is an alternative fix to the proposed fix Jisheng Zhang: yaffs: fix softlockup cauesed by inode deleted when scanning s_inodes list http://www.aleph1.co.uk/lurker/message/20110831.075307.3cfeacdf.fr.html
2014-09-25yaffs: fix function prototypeStefan Agner
The fsync function in the fs.h header file in our kernel version has two additional function introduced by this commit: 02c24a82187d5a628c68edfe71ae60dc135cd178 fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers Update the function prototype for YAFFS2 too to avoid missinterpreted datasync parameter and to avoid warnings.
2013-07-05UBIFS: fix a horrid bugArtem Bityutskiy
Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are in the middle of 'ubifs_readdir()'. This means that 'file->private_data' can be freed while 'ubifs_readdir()' uses it, and this is a very bad bug: not only 'ubifs_readdir()' can return garbage, but this may corrupt memory and lead to all kinds of problems like crashes an security holes. This patch fixes the problem by using the 'file->f_version' field, which '->llseek()' always unconditionally sets to zero. We set it to 1 in 'ubifs_readdir()' and whenever we detect that it became 0, we know there was a seek and it is time to clear the state saved in 'file->private_data'. I tested this patch by writing a user-space program which runds readdir and seek in parallell. I could easily crash the kernel without these patches, but could not crash it with these patches. Cc: stable@vger.kernel.org Reported-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-05UBIFS: prepare to fix a horrid bugArtem Bityutskiy
Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are in the middle of 'ubifs_readdir()'. First of all, this means that 'file->private_data' can be freed while 'ubifs_readdir()' uses it. But this particular patch does not fix the problem. This patch is only a preparation, and the fix will follow next. In this patch we make 'ubifs_readdir()' stop using 'file->f_pos' directly, because 'file->f_pos' can be changed by '->llseek()' at any point. This may lead 'ubifs_readdir()' to returning inconsistent data: directory entry names may correspond to incorrect file positions. So here we introduce a local variable 'pos', read 'file->f_pose' once at very the beginning, and then stick to 'pos'. The result of this is that when 'ubifs_dir_llseek()' changes 'file->f_pos' while we are in the middle of 'ubifs_readdir()', the latter "wins". Cc: stable@vger.kernel.org Reported-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-05UBIFS: correct mount messageRichard Genoud
When mounting an UBIFS R/W volume, we have the message: UBIFS: mounted UBI device 0, volume 1, name "rootfs"(null) With this patch, we'll have: UBIFS: mounted UBI device 0, volume 1, name "rootfs" Which is, I think, what was intended. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Cc: stable@vger.kernel.org [v3.7+] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-07-05UBIFS: make space fixup work in the remount caseArtem Bityutskiy
The UBIFS space fixup is a useful feature which allows to fixup the "broken" flash space at the time of the first mount. The "broken" space is usually the result of using a "dumb" industrial flasher which is not able to skip empty NAND pages and just writes all 0xFFs to the empty space, which has grave side-effects for UBIFS when UBIFS trise to write useful data to those empty pages. The fix-up feature works roughly like this: 1. mkfs.ubifs sets the fixup flag in UBIFS superblock when creating the image (see -F option) 2. when the file-system is mounted for the first time, UBIFS notices the fixup flag and re-writes the entire media atomically, which may take really a lot of time. 3. UBIFS clears the fixup flag in the superblock. This works fine when the file system is mounted R/W for the very first time. But it did not really work in the case when we first mount the file-system R/O, and then re-mount R/W. The reason was that we started the fixup procedure too late, which we cannot really do because we have to fixup the space before it starts being used. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Reported-by: Mark Jackson <mpfj-list@mimc.co.uk> Cc: stable@vger.kernel.org # 3.0+
2013-02-22UBIFS: fix double free of ubifs_orphan objectsAdam Thomas
The last orphan in the dnext list has its dnext set to NULL. Because of that, ubifs_delete_orphan assumes that it is not on the dnext list and frees it immediately instead ignoring it as a second delete. The orphan is later freed again by erase_deleted. This change adds an explicit flag to ubifs_orphan indicating whether it is pending delete. Signed-off-by: Adam Thomas <adamthomas1111@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: stable@vger.kernel.org
2013-02-22UBIFS: fix use of freed ubifs_orphan objectsAdam Thomas
The last orphan in the cnext list has its cnext set to NULL. Because of that, ubifs_delete_orphan assumes that it is not on the cnext list and frees it immediately instead of adding it to the dnext list. The freed orphan is later modified by write_orph_node. This can cause various inconsistencies including directory entries that cannot be removed and this error: UBIFS error (pid 20685): layout_cnodes: LPT out of space at LEB 14:129009 needing 17, done_ltab 1, done_lsave 1 This is a regression introduced by "7074e5eb UBIFS: remove invalid reference to list iterator variable". This change adds an explicit flag to ubifs_orphan indicating whether it is pending commit. Signed-off-by: Adam Thomas <adamthomas1111@gmail.com> Reviewed-by: Adrian Hunter <adrian.hunter@intel.com> Cc: stable@vger.kernel.org # v3.6+ Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22UBIFS: rename random32() to prandom_u32()Akinobu Mita
Use more preferable function name which implies using a pseudo-random number generator. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2013-02-22ubifs: use prandom_bytesAkinobu Mita
This also converts filling memory loop to use memset. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: David Laight <david.laight@aculab.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Michel Lespinasse <walken@google.com> Cc: Robert Love <robert.w.love@intel.com> Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-16UBIFS: fix mounting problems after power cutsArtem Bityutskiy
This is a bugfix for a problem with the following symptoms: 1. A power cut happens 2. After reboot, we try to mount UBIFS 3. Mount fails with "No space left on device" error message UBIFS complains like this: UBIFS error (pid 28225): grab_empty_leb: could not find an empty LEB The root cause of this problem is that when we mount, not all LEBs are categorized. Only those which were read are. However, the 'ubifs_find_free_leb_for_idx()' function assumes that all LEBs were categorized and 'c->freeable_cnt' is valid, which is a false assumption. This patch fixes the problem by teaching 'ubifs_find_free_leb_for_idx()' to always fall back to LPT scanning if no freeable LEBs were found. This problem was reported by few people in the past, but Brent Taylor was able to reproduce it and send me a flash image which cannot be mounted, which made it easy to hunt the bug. Kudos to Brent. Reported-by: Brent Taylor <motobud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: stable@vger.kernel.org
2012-11-16UBIFS: introduce categorized lprops counterArtem Bityutskiy
This commit is a preparation for a subsequent bugfix. We introduce a counter for categorized lprops. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: stable@vger.kernel.org
2012-10-05UBIFS: print lessArtem Bityutskiy
UBIFS currently prints a lot of information when it mounts a volume, which bothers some people. Make it less chatty - print only important information by default. Get rid of 'dbg_msg()' macro completely. Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBIFS: use pr_ helper instead of printkArtem Bityutskiy
Use 'pr_err()' instead of 'printk(KERN_ERR', etc. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBIFS: comply with coding styleArtem Bityutskiy
Join all the split printk lines in order to stop checkpatch complaining. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBIFS: use __aligned() attributeArtem Bityutskiy
.. instead of __attribute__((aligned())). Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBIFS: remove __DATE__ and __TIME__Jiri Slaby
This tag is useless and it breaks automatic builds. It causes rebuilds for packages that depend on kernel for no real reason. Further, quoting Michal, who removed most of the users already: The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBIFS: fix power cut emulation for mtdramArtem Bityutskiy
The power cut emulation did not work correctly because we corrupted more than one max. I/O unit in the buffer and then wrote the entire buffer. This lead to recovery errors because UBIFS complained about corrupted free space. And this was easily reproducible on mtdram because max. write size is very small there (64 bytes), and we could easily have a 1KiB buffer, corrupt 128 bytes there, and then write the entire buffer. The fix is to corrupt max. write size bytes at most, and write only up to the last corrupted max. write size chunk, not the entire buffer. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBIFS: improve scanning debug outputArtem Bityutskiy
Include LEB number and offset in scanning debugging output. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBIFS: always print full error reportsArtem Bityutskiy
Even when we are emulating power cuts, otherwise it is difficult to investigate failures during emulated power cuts testing. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-10-05UBIFS: print PID in debug messagesArtem Bityutskiy
2012-10-05UBIFS: fix error messages spellingArtem Bityutskiy
Corruptio -> corruption. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-23UBIFS: fix complaints about too small debug buffer sizeArtem Bityutskiy
When debugging is enabled, we use a temporary on-stack buffer for formatting the key strings like "(11368871, direntry, 0xcd0750)". The buffer size is 32 bytes and sometimes it is not enough to fit the key string - e.g., when inode numbers are high. This is not fatal, but the key strings are incomplete and UBIFS complains like this: UBIFS assert failed in dbg_snprintf_key at 137 (pid 1) This is a regression caused by "515315a UBIFS: fix key printing". Fix the issue by increasing the buffer to 48 bytes. Reported-by: Michael Hench <michaelhench@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Tested-by: Michael Hench <michaelhench@gmail.com> Cc: stable@vger.kernel.org [v3.3+]
2012-08-23UBIFS: fix replay regressionArtem Bityutskiy
Commit "d51f17e UBIFS: simplify reply code a bit" introduces a bug with the following symptoms: UBIFS error (pid 1): replay_log_leb: first CS node at LEB 3:0 has wrong commit number 0 expected 1 The issue is that we start replaying the log from UBIFS_LOG_LNUM instead of c->lhead_lnum. This patch fixes that. Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-23UBIFS: fix crash on error pathArtem Bityutskiy
This patch fixes a regression introduced by "4994297 UBIFS: make ubifs_lpt_init clean-up in case of failure" which I've hit while running the 'integck -p' test. When remount the file-system from R/O mode to R/W mode and 'lpt_init_wr()' fails, we free _all_ LPT resources by calling 'ubifs_lpt_free(c, 0)', even those needed for R/O mode. This leads to subsequent crashes, e.g., if we try to unmount the file-system. Cc: stable@vger.kernel.org [v3.5+] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-23UBIFS: remove stale commentaryArtem Bityutskiy
2012-07-23UBIFS: remove invalid reference to list iterator variableJulia Lawall
If list_for_each_entry, etc complete a traversal of the list, the iterator variable ends up pointing to an address at an offset from the list head, and not a meaningful structure. Thus this value should not be used after the end of the iterator. Replace a field access from orphan by NULL in two places. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier c; expression E; iterator name list_for_each_entry; statement S; @@ list_for_each_entry(c,...) { ... when != break; when forall when strict } ... ( c = E | *c ) // </smpl> Artem: fortunately, this did not cause any issues because we iterate the orphan list using the elements count, so we never dereferenced the corrupted pointer. This is why I do not send this patch to -stable. But otherwise - well spotted! Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
2012-07-23UBIFS: simplify reply code a bitArtem Bityutskiy
In the log reply code we assume that 'c->lhead_offs' is known and may be non-zero, which is not the case because we do not store it in the master node and have to find out by scanning on every mount. Knowing this fact allows us to simplify the log scanning loop a bit and remove a couple of unneeded local variables. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
2012-07-23UBIFS: add debugfs knob to switch to R/O modeArtem Bityutskiy
This patch adds another debugfs knob which switches UBIFS to R/O mode. I needed it while trying to reproduce the 'first log node is not CS node' bug. Without this debugfs knob you have to perform a power cut to repruduce the bug. The knob is named 'ro_error' and all it does is it sets the 'ro_error' UBIFS flag which makes UBIFS disallow any further writes - even write-back will fail with -EROFS. Useful for debugging. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
2012-07-23UBIFS: fix a bug in empty space fix-upArtem Bityutskiy
UBIFS has a feature called "empty space fix-up" which is a quirk to work-around limitations of dumb flasher programs. Namely, of those flashers that are unable to skip NAND pages full of 0xFFs while flashing, resulting in empty space at the end of half-filled eraseblocks to be unusable for UBIFS. This feature is relatively new (introduced in v3.0). The fix-up routine (fixup_free_space()) is executed only once at the very first mount if the superblock has the 'space_fixup' flag set (can be done with -F option of mkfs.ubifs). It basically reads all the UBIFS data and metadata and writes it back to the same LEB. The routine assumes the image is pristine and does not have anything in the journal. There was a bug in 'fixup_free_space()' where it fixed up the log incorrectly. All but one LEB of the log of a pristine file-system are empty. And one contains just a commit start node. And 'fixup_free_space()' just unmapped this LEB, which resulted in wiping the commit start node. As a result, some users were unable to mount the file-system next time with the following symptom: UBIFS error (pid 1): replay_log_leb: first log node at LEB 3:0 is not CS node UBIFS error (pid 1): replay_log_leb: log error detected while replaying the log at LEB 3:0 The root-cause of this bug was that 'fixup_free_space()' wrongly assumed that the beginning of empty space in the log head (c->lhead_offs) was known on mount. However, it is not the case - it was always 0. UBIFS does not store in it the master node and finds out by scanning the log on every mount. The fix is simple - just pass commit start node size instead of 0 to 'fixup_leb()'. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com> Cc: stable@vger.kernel.org [v3.0+] Reported-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com> Tested-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com> Reported-by: James Nute <newten82@gmail.com>
2012-07-01proc: enhance time-average nr_running statsAlex Frid
Add time-average nr_running to loadavg printout Bug 958978 Change-Id: I5c6904efb52a86f4964eb66c1576fc91f60f5b1d Signed-off-by: Alex Frid <afrid@nvidia.com> (cherry picked from commit 86f3642cc44a69d1e4798719bd9182cd6923f526) Reviewed-on: http://git-master/r/111636 Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Tested-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2012-06-28UBIFS: correct usage of IS_ENABLED()Brian Norris
Commit "818039c UBIFS: fix debugfs-less systems support" fixed one regression but introduced a different regression - the debugfs is now always compiled out. Root cause: IS_ENABLED() arguments should be used with the CONFIG_* prefix. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-06-28UBIFS: fix assertionDan Carpenter
The asserts here never check anything because it uses '|' instead of '&'. Now if the flags are not set it prints a warning a a stack trace. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-06-11fat: Remove FAT Directory Bread messagenaveenk
Remove FAT Directory Bread message which is causing timing issues. Bug 992496 Change-Id: Ieb58e38bf8ac81f6c0558361f9f296a8e9071b33 Signed-off-by: venkata jagadish <vjagadish@nvidia.com> Reviewed-on: http://git-master/r/105354 Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com> Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-06-08UBIFS: fix debugfs-less systems supportArtem Bityutskiy
Commit "f70b7e5 UBIFS: remove Kconfig debugging option" broke UBIFS and it refuses to initialize if debugfs (CONFIG_DEBUG_FS) is disabled. I incorrectly assumed that debugfs files creation function will return success if debugfs is disabled, but they actually return -ENODEV. This patch fixes the issue. Reported-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Tested-by: Paul Parsons <lost.distance@yahoo.com>
2012-05-23UBI: amend commentaries WRT dtypeArtem Bityutskiy
Richard removed the "dtype" hint, but few commentaries were left and this patch removes them. I've also added a better description about the "dtype" field in the ubi-user.h for people who may ever wonder what was that dtype thing about. This patch also adds an important note that it is better to use value "3" for the "dtype" field. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-23UBI: Kill data type hintRichard Weinberger
We do not need this feature and to our shame it even was not working and there was a bug found very recently. -- Artem Bityutskiy Without the data type hint UBI2 (fastmap) will be easier to implement. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-23UBIFS: fix memory leak on error pathSidney Amani
UBIFS leaks memory on error path in 'mount_ubifs()'. In case of failure in 'ubifs_fixup_free_space()', it does not call 'ubifs_lpt_free()' whereas LPT data structures can potentially be allocated. The amount of memory leaked can be quite high -- see 'ubifs_lpt_init()'. The bug was introduced when moving the LPT initialisation earlier in the mount process (commit '781c5717a95a74b294beb38b8276943b0f8b5bb4'). Signed-off-by: Sidney Amani <seed95@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-23UBIFS: make ubifs_lpt_init clean-up in case of failureArtem Bityutskiy
Most functions in UBIFS follow the following designn pattern: if the function allocates multiple resources, and failss at some point, it frees what it has allocated and returns an error. So the caller can rely on the fact that the callee has cleaned up everything after own failure. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Acked-by: Sidney Amani <seed95@gmail.com>
2012-05-23UBIFS: get rid of dbg_errArtem Bityutskiy
This patch removes the 'dbg_err()' macro and we now use 'ubifs_err()' instead. The idea of 'dbg_err()' was to compile out some error message to make the binary a bit smaller - but I think it was a bad idea. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-23UBIFS: remove Kconfig debugging optionArtem Bityutskiy
Have the debugging stuff always compiled-in instead. It simplifies maintanance a lot. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-23UBIFS: remove a couple of unused macrosArtem Bityutskiy
2012-05-23UBIFS: rename dumping functionsArtem Bityutskiy
This commit re-names all functions which dump something from "dbg_dump_*()" to "ubifs_dump_*()". This is done for consistency with UBI and because this way it will be more logical once we remove the debugging sompilation option. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-23UBIFS: get rid of dbg_dump_stackArtem Bityutskiy
In case of errors we almost always need the stack dump - it makes no sense to compile it out. Remove the 'dbg_dump_stack()' function completely. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-23UBIFS: remove xattr Kconnfig optionSubodh Nijsure
Remove CONFIG_UBIFS_FS_XATTR configuration option and associated UBIFS_FS_XATTR ifdefs. Testing: Tested using integck while using nandsim on x86 & MX28 based platform with Micron MT29F2G08ABAEAH4 nand. Signed-off-by: Subodh Nijsure <snijsure@grid-net.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-23UBIFS: remove douple initialization in change_category()Dan Carpenter
"heap" is initialized twice. I removed the first one, because it makes Smatch complain that we use "new_cat" as an offset before checking it. This doesn't change how the code works, it's just a cleanup. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
