path: root/fs
2013-06-20splice: don't pass the address of ->f_pos to methodsAl Viro
2013-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS fixes from Al Viro: "Several fixes + obvious cleanup (you've missed a couple of open-coded can_lookup() back then)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: snd_pcm_link(): fix a leak... use can_lookup() instead of direct checks of ->i_op->lookup move exit_task_namespaces() outside of exit_notify() fput: task_work_add() can fail if the caller has passed exit_task_work() ncpfs: fix rmdir returns Device or resource busy
2013-06-14Merge tag 'for-linus-v3.10-rc6' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs fixes from Ben Myers: - Remove noisy warnings about experimental support which spams the logs - Add padding to align directory and attr structures correctly - Set block number on child buffer on a root btree split - Disable verifiers during log recovery for non-CRC filesystems * tag 'for-linus-v3.10-rc6' of git://oss.sgi.com/xfs/xfs: xfs: don't shutdown log recovery on validation errors xfs: ensure btree root split sets blkno correctly xfs: fix implicit padding in directory and attr CRC formats xfs: don't emit v5 superblock warnings on write
2013-06-15use can_lookup() instead of direct checks of ->i_op->lookupAl Viro
a couple of places got missed back when Linus has introduced that one... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-15fput: task_work_add() can fail if the caller has passed exit_task_work()Oleg Nesterov
fput() assumes that it can't be called after exit_task_work() but this is not true, for example free_ipc_ns()->shm_destroy() can do this. In this case fput() silently leaks the file. Change it to fallback to delayed_fput_work if task_work_add() fails. The patch looks complicated but it is not, it changes the code from if (PF_KTHREAD) { schedule_work(...); return; } task_work_add(...) to if (!PF_KTHREAD) { if (!task_work_add(...)) return; /* fallback */ } schedule_work(...); As for shm_destroy() in particular, we could make another fix but I think this change makes sense anyway. There could be another similar user, it is not safe to assume that task_work_add() can't fail. Reported-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-14xfs: don't shutdown log recovery on validation errorsDave Chinner
Unfortunately, we cannot guarantee that items logged multiple times and replayed by log recovery do not take objects back in time. When they are taken back in time, the go into an intermediate state which is corrupt, and hence verification that occurs on this intermediate state causes log recovery to abort with a corruption shutdown. Instead of causing a shutdown and unmountable filesystem, don't verify post-recovery items before they are written to disk. This is less than optimal, but there is no way to detect this issue for non-CRC filesystems If log recovery successfully completes, this will be undone and the object will be consistent by subsequent transactions that are replayed, so in most cases we don't need to take drastic action. For CRC enabled filesystems, leave the verifiers in place - we need to call them to recalculate the CRCs on the objects anyway. This recovery problem can be solved for such filesystems - we have a LSN stamped in all metadata at writeback time that we can to determine whether the item should be replayed or not. This is a separate piece of work, so is not addressed by this patch. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 9222a9cf86c0d64ffbedf567412b55da18763aa3)
2013-06-14xfs: ensure btree root split sets blkno correctlyDave Chinner
For CRC enabled filesystems, the BMBT is rooted in an inode, so it passes through a different code path on root splits than the freespace and inode btrees. This is much less traversed by xfstests than the other trees. When testing on a 1k block size filesystem, I've been seeing ASSERT failures in generic/234 like: XFS: Assertion failed: cur->bc_btnum != XFS_BTNUM_BMAP || cur->bc_private.b.allocated == 0, file: fs/xfs/xfs_btree.c, line: 317 which are generally preceded by a lblock check failure. I noticed this in the bmbt stats: $ pminfo -f xfs.btree.block_map xfs.btree.block_map.lookup value 39135 xfs.btree.block_map.compare value 268432 xfs.btree.block_map.insrec value 15786 xfs.btree.block_map.delrec value 13884 xfs.btree.block_map.newroot value 2 xfs.btree.block_map.killroot value 0 ..... Very little coverage of root splits and merges. Indeed, on a 4k filesystem, block_map.newroot and block_map.killroot are both zero. i.e. the code is not exercised at all, and it's the only generic btree infrastructure operation that is not exercised by a default run of xfstests. Turns out that on a 1k filesystem, generic/234 accounts for one of those two root splits, and that is somewhat of a smoking gun. In fact, it's the same problem we saw in the directory/attr code where headers are memcpy()d from one block to another without updating the self describing metadata. Simple fix - when copying the header out of the root block, make sure the block number is updated correctly. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit ade1335afef556df6538eb02e8c0dc91fbd9cc37)
2013-06-14xfs: fix implicit padding in directory and attr CRC formatsDave Chinner
Michael L. Semon has been testing CRC patches on a 32 bit system and been seeing assert failures in the directory code from xfs/080. Thanks to Michael's heroic efforts with printk debugging, we found that the problem was that the last free space being left in the directory structure was too small to fit a unused tag structure and it was being corrupted and attempting to log a region out of bounds. Hence the assert failure looked something like: ..... #5 calling xfs_dir2_data_log_unused() 36 32 #1 4092 4095 4096 #2 8182 8183 4096 XFS: Assertion failed: first <= last && last < BBTOB(bp->b_length), file: fs/xfs/xfs_trans_buf.c, line: 568 Where #1 showed the first region of the dup being logged (i.e. the last 4 bytes of a directory buffer) and #2 shows the corrupt values being calculated from the length of the dup entry which overflowed the size of the buffer. It turns out that the problem was not in the logging code, nor in the freespace handling code. It is an initial condition bug that only shows up on 32 bit systems. When a new buffer is initialised, where's the freespace that is set up: [ 172.316249] calling xfs_dir2_leaf_addname() from xfs_dir_createname() [ 172.316346] #9 calling xfs_dir2_data_log_unused() [ 172.316351] #1 calling xfs_trans_log_buf() 60 63 4096 [ 172.316353] #2 calling xfs_trans_log_buf() 4094 4095 4096 Note the offset of the first region being logged? It's 60 bytes into the buffer. Once I saw that, I pretty much knew that the bug was going to be caused by this. Essentially, all direct entries are rounded to 8 bytes in length, and all entries start with an 8 byte alignment. This means that we can decode inplace as variables are naturally aligned. With the directory data supposedly starting on a 8 byte boundary, and all entries padded to 8 bytes, the minimum freespace in a directory block is supposed to be 8 bytes, which is large enough to fit a unused data entry structure (6 bytes in size). The fact we only have 4 bytes of free space indicates a directory data block alignment problem. And what do you know - there's an implicit hole in the directory data block header for the CRC format, which means the header is 60 byte on 32 bit intel systems and 64 bytes on 64 bit systems. Needs padding. And while looking at the structures, I found the same problem in the attr leaf header. Fix them both. Note that this only affects 32 bit systems with CRCs enabled. Everything else is just fine. Note that CRC enabled filesystems created before this fix on such systems will not be readable with this fix applied. Reported-by: Michael L. Semon <mlsemon35@gmail.com> Debugged-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 8a1fd2950e1fe267e11fc8c85dcaa6b023b51b60)
2013-06-14xfs: don't emit v5 superblock warnings on writeDave Chinner
We write the superblock every 30s or so which results in the verifier being called. Right now that results in this output every 30s: XFS (vda): Version 5 superblock detected. This kernel has EXPERIMENTAL support enabled! Use of these features in this kernel is at your own risk! And spamming the logs. We don't need to check for whether we support v5 superblocks or whether there are feature bits we don't support set as these are only relevant when we first mount the filesytem. i.e. on superblock read. Hence for the write verification we can just skip all the checks (and hence verbose output) altogether. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 34510185abeaa5be9b178a41c0a03d30aec3db7e)
2013-06-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "This is an assortment of crash fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: stop all workers before cleaning up roots Btrfs: fix use-after-free bug during umount Btrfs: init relocate extent_io_tree with a mapping btrfs: Drop inode if inode root is NULL Btrfs: don't delete fs_roots until after we cleanup the transaction
2013-06-12Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "Bunch of fixes and one little addition to math64.h" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (27 commits) include/linux/math64.h: add div64_ul() mm: memcontrol: fix lockless reclaim hierarchy iterator frontswap: fix incorrect zeroing and allocation size for frontswap_map kernel/audit_tree.c:audit_add_tree_rule(): protect `rule' from kill_rules() mm: migration: add migrate_entry_wait_huge() ocfs2: add missing lockres put in dlm_mig_lockres_handler mm/page_alloc.c: fix watermark check in __zone_watermark_ok() drivers/misc/sgi-gru/grufile.c: fix info leak in gru_get_config_info() aio: fix io_destroy() regression by using call_rcu() rtc-at91rm9200: use shadow IMR on at91sam9x5 rtc-at91rm9200: add shadow interrupt mask rtc-at91rm9200: refactor interrupt-register handling rtc-at91rm9200: add configuration support rtc-at91rm9200: add match-table compile guard fs/ocfs2/namei.c: remove unecessary ERROR when removing non-empty directory swap: avoid read_swap_cache_async() race to deadlock while waiting on discard I/O completion drivers/rtc/rtc-twl.c: fix missing device_init_wakeup() when booted with device tree cciss: fix broken mutex usage in ioctl audit: wait_for_auditd() should use TASK_UNINTERRUPTIBLE drivers/rtc/rtc-cmos.c: fix accidentally enabling rtc channel ...
2013-06-12ocfs2: add missing lockres put in dlm_mig_lockres_handlerXue jiufei
dlm_mig_lockres_handler() is missing a dlm_lockres_put() on an error path. Signed-off-by: joyce <xuejiufei@huawei.com> Reviewed-by: shencanquan <shencanquan@huawei.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12aio: fix io_destroy() regression by using call_rcu()Kent Overstreet
There was a regression introduced by 36f5588905c1 ("aio: refcounting cleanup"), reported by Jens Axboe - the refcounting cleanup switched to using RCU in the shutdown path, but the synchronize_rcu() was done in the context of the io_destroy() syscall greatly increasing the time it could block. This patch switches it to call_rcu() and makes shutdown asynchronous (more asynchronous than it was originally; before the refcount changes io_destroy() would still wait on pending kiocbs). Note that there's a global quota on the max outstanding kiocbs, and that quota must be manipulated synchronously; otherwise io_setup() could return -EAGAIN when there isn't quota available, and userspace won't have any way of waiting until shutdown of the old kioctxs has finished (besides busy looping). So we release our quota before kioctx shutdown has finished, which should be fine since the quota never corresponded to anything real anyways. Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Reported-by: Jens Axboe <axboe@kernel.dk> Tested-by: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Tested-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12fs/ocfs2/namei.c: remove unecessary ERROR when removing non-empty directoryGoldwyn Rodrigues
While removing a non-empty directory, the kernel dumps a message: (rmdir,21743,1):ocfs2_unlink:953 ERROR: status = -39 Suppress the error message from being printed in the dmesg so users don't panic. Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Acked-by: Sunil Mushran <sunil.mushran@gmail.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12ocfs2: ocfs2_prep_new_orphaned_file() should return retXiaowei.Hu
If an error occurs, for example an EIO in __ocfs2_prepare_orphan_dir, ocfs2_prep_new_orphaned_file will release the inode_ac, then when the caller of ocfs2_prep_new_orphaned_file gets a 0 return, it will refer to a NULL ocfs2_alloc_context struct in the following functions. A kernel panic happens. Signed-off-by: "Xiaowei.Hu" <xiaowei.hu@oracle.com> Reviewed-by: shencanquan <shencanquan@huawei.com> Acked-by: Sunil Mushran <sunil.mushran@gmail.com> Cc: Joe Jin <joe.jin@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12kmsg: honor dmesg_restrict sysctl on /dev/kmsgKees Cook
The dmesg_restrict sysctl currently covers the syslog method for access dmesg, however /dev/kmsg isn't covered by the same protections. Most people haven't noticed because util-linux dmesg(1) defaults to using the syslog method for access in older versions. With util-linux dmesg(1) defaults to reading directly from /dev/kmsg. To fix /dev/kmsg, let's compare the existing interfaces and what they allow: - /proc/kmsg allows: - open (SYSLOG_ACTION_OPEN) if CAP_SYSLOG since it uses a destructive single-reader interface (SYSLOG_ACTION_READ). - everything, after an open. - syslog syscall allows: - anything, if CAP_SYSLOG. - SYSLOG_ACTION_READ_ALL and SYSLOG_ACTION_SIZE_BUFFER, if dmesg_restrict==0. - nothing else (EPERM). The use-cases were: - dmesg(1) needs to do non-destructive SYSLOG_ACTION_READ_ALLs. - sysklog(1) needs to open /proc/kmsg, drop privs, and still issue the destructive SYSLOG_ACTION_READs. AIUI, dmesg(1) is moving to /dev/kmsg, and systemd-journald doesn't clear the ring buffer. Based on the comments in devkmsg_llseek, it sounds like actions besides reading aren't going to be supported by /dev/kmsg (i.e. SYSLOG_ACTION_CLEAR), so we have a strict subset of the non-destructive syslog syscall actions. To this end, move the check as Josh had done, but also rename the constants to reflect their new uses (SYSLOG_FROM_CALL becomes SYSLOG_FROM_READER, and SYSLOG_FROM_FILE becomes SYSLOG_FROM_PROC). SYSLOG_FROM_READER allows non-destructive actions, and SYSLOG_FROM_PROC allows destructive actions after a capabilities-constrained SYSLOG_ACTION_OPEN check. - /dev/kmsg allows: - open if CAP_SYSLOG or dmesg_restrict==0 - reading/polling, after open Addresses https://bugzilla.redhat.com/show_bug.cgi?id=903192 [akpm@linux-foundation.org: use pr_warn_once()] Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Christian Kujau <lists@nerdbynature.de> Tested-by: Josh Boyer <jwboyer@redhat.com> Cc: Kay Sievers <kay@vrfy.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull ceph fixes from Sage Weil: "There is a pair of fixes for double-frees in the recent bundle for 3.10, a couple of fixes for long-standing bugs (sleep while atomic and an endianness fix), and a locking fix that can be triggered when osds are going down" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: fix cleanup in rbd_add() rbd: don't destroy ceph_opts in rbd_add() ceph: ceph_pagelist_append might sleep while atomic ceph: add cpu_to_le32() calls when encoding a reconnect capability libceph: must hold mutex for reset_changed_osds()
2013-06-08hpfs: fix warnings when the filesystem fills upMikulas Patocka
This patch fixes warnings due to missing lock on write error path. WARNING: at fs/hpfs/hpfs_fn.h:353 hpfs_truncate+0x75/0x80 [hpfs]() Hardware name: empty Pid: 26563, comm: dd Tainted: P O 3.9.4 #12 Call Trace: hpfs_truncate+0x75/0x80 [hpfs] hpfs_write_begin+0x84/0x90 [hpfs] _hpfs_bmap+0x10/0x10 [hpfs] generic_file_buffered_write+0x121/0x2c0 __generic_file_aio_write+0x1c7/0x3f0 generic_file_aio_write+0x7c/0x100 do_sync_write+0x98/0xd0 hpfs_file_write+0xd/0x50 [hpfs] vfs_write+0xa2/0x160 sys_write+0x51/0xa0 page_fault+0x22/0x30 system_call_fastpath+0x1a/0x1f Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: stable@kernel.org # 2.6.39+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-08Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: - Trivial: unused variable removal - Posix-timers: Add the clock ID to the new proc interface to make it useful. The interface is new and should be functional when we reach the final 3.10 release. - Cure a false positive warning in the tick code introduced by the overhaul in 3.10 - Fix for a persistent clock detection regression introduced in this cycle * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timekeeping: Correct run-time detection of persistent_clock. ntp: Remove unused variable flags in __hardpps posix-timers: Show clock ID in proc file tick: Cure broadcast false positive pending bit warning
2013-06-08Btrfs: stop all workers before cleaning up rootsJosef Bacik
Dave reported a panic because the extent_root->commit_root was NULL in the caching kthread. That is because we just unset it in free_root_pointers, which is not the correct thing to do, we have to either wait for the caching kthread to complete or hold the extent_commit_sem lock so we know the thread has exited. This patch makes the kthreads all stop first and then we do our cleanup. This should fix the race. Thanks, Reported-by: David Sterba <dsterba@suse.cz> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-06-08Btrfs: fix use-after-free bug during umountLiu Bo
Commit be283b2e674a09457d4563729015adb637ce7cc1 ( Btrfs: use helper to cleanup tree roots) introduced the following bug, BUG: unable to handle kernel NULL pointer dereference at 0000000000000034 IP: [<ffffffffa039368c>] extent_buffer_get+0x4/0xa [btrfs] [...] Pid: 2463, comm: btrfs-cache-1 Tainted: G O 3.9.0+ #4 innotek GmbH VirtualBox/VirtualBox RIP: 0010:[<ffffffffa039368c>] [<ffffffffa039368c>] extent_buffer_get+0x4/0xa [btrfs] Process btrfs-cache-1 (pid: 2463, threadinfo ffff880112d60000, task ffff880117679730) [...] Call Trace: [<ffffffffa0398a99>] btrfs_search_slot+0x104/0x64d [btrfs] [<ffffffffa039aea4>] btrfs_next_old_leaf+0xa7/0x334 [btrfs] [<ffffffffa039b141>] btrfs_next_leaf+0x10/0x12 [btrfs] [<ffffffffa039ea13>] caching_thread+0x1a3/0x2e0 [btrfs] [<ffffffffa03d8811>] worker_loop+0x14b/0x48e [btrfs] [<ffffffffa03d86c6>] ? btrfs_queue_worker+0x25c/0x25c [btrfs] [<ffffffff81068d3d>] kthread+0x8d/0x95 [<ffffffff81068cb0>] ? kthread_freezable_should_stop+0x43/0x43 [<ffffffff8151e5ac>] ret_from_fork+0x7c/0xb0 [<ffffffff81068cb0>] ? kthread_freezable_should_stop+0x43/0x43 RIP [<ffffffffa039368c>] extent_buffer_get+0x4/0xa [btrfs] We've free'ed commit_root before actually getting to free block groups where caching thread needs valid extent_root->commit_root. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-06-08Btrfs: init relocate extent_io_tree with a mappingJosef Bacik
Dave reported a NULL pointer deref. This is caused because he thought he'd be smart and add sanity checks to the extent_io bit operations, but he didn't expect a tree to have a NULL mapping. To fix this we just need to init the relocation's processed_blocks with the btree_inode->i_mapping. Thanks, Reported-by: David Sterba <dsterba@suse.cz> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-06-08btrfs: Drop inode if inode root is NULLNaohiro Aota
There is a path where btrfs_drop_inode() is called with its inode's root is NULL: In btrfs_new_inode(), when btrfs_set_inode_index() fails, iput() is called. We should handle this case before taking look at the root->root_item. Signed-off-by: Naohiro Aota <naota@elisp.net> Reviewed-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-06-08Btrfs: don't delete fs_roots until after we cleanup the transactionJosef Bacik
We get a use after free if we had a transaction to cleanup since there could be delayed inodes which refer to their respective fs_root. Thanks Reported-by: David Sterba <dsterba@suse.cz> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-06-07Merge tag 'ecryptfs-3.10-rc5-msync' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull ecryptfs fixes from Tyler Hicks: - Fixes how eCryptfs handles msync to sync both the upper and lower file - A couple of MAINTAINERS updates * tag 'ecryptfs-3.10-rc5-msync' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: Check return of filemap_write_and_wait during fsync Update eCryptFS maintainers ecryptfs: fixed msync to flush data
2013-06-07Merge branch 'for-3.10' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fix from Steve French: "Fix one byte buffer overrun with prefixpaths on cifs mounts which can cause a problem with mount depending on the string length" * 'for-3.10' of git://git.samba.org/sfrench/cifs-2.6: cifs: fix off-by-one bug in build_unc_path_to_root
2013-06-07ncpfs: fix rmdir returns Device or resource busyDave Chiluk
1d2ef5901483004d74947bbf78d5146c24038fe7 caused a regression in ncpfs such that directories could no longer be removed. This was because ncp_rmdir checked to see if a dentry could be unhashed before allowing it to be removed. Since 1d2ef5901483004d74947bbf78d5146c24038fe7 introduced a change that incremented dentry->d_count causing it to always be greater than 1 unhash would always fail. Thus causing the error path in ncp_rmdir to always be taken. Removing this error path is safe as unhashing is still accomplished by calls to dput from vfs_rmdir. Signed-off-by: Dave Chiluk <chiluk@canonical.com> Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-06Merge tag 'for-linus-v3.10-rc5' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull more xfs updates from Ben Myers: "Here are several fixes for filesystems with CRC support turned on: fixes for quota, remote attributes, and recovery. There is also some feature work related to CRCs: the implementation of CRCs for the inode unlinked lists, disabling noattr2/attr2 options when appropriate, and bumping the maximum number of ACLs. I would have preferred to defer this last category of items to 3.11. This would require setting a feature bit for the on-disk changes, so there is some pressure to get these in 3.10. I believe this represents the end of the CRC related queue. - Rework of dquot CRCs - Fix for remote attribute invalidation of a leaf - Fix ordering of transaction replay in recovery - Implement CRCs for inode unlinked list - Disable noattr2/attr2 mount options when CRCs are enabled - Bump the limitation of ACL entries for v5 superblocks" * tag 'for-linus-v3.10-rc5' of git://oss.sgi.com/xfs/xfs: xfs: increase number of ACL entries for V5 superblocks xfs: disable noattr2/attr2 mount options for CRC enabled filesystems xfs: inode unlinked list needs to recalculate the inode CRC xfs: fix log recovery transaction item reordering xfs: fix remote attribute invalidation for a leaf xfs: rework dquot CRCs
2013-06-06xfs: increase number of ACL entries for V5 superblocksDave Chinner
The limit of 25 ACL entries is arbitrary, but baked into the on-disk format. For version 5 superblocks, increase it to the maximum nuber of ACLs that can fit into a single xattr. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Mark Tinguely <tinuguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 5c87d4bc1a86bd6e6754ac3d6e111d776ddcfe57)
2013-06-06xfs: disable noattr2/attr2 mount options for CRC enabled filesystemsDave Chinner
attr2 format is always enabled for v5 superblock filesystems, so the mount options to enable or disable it need to be cause mount errors. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit d3eaace84e40bf946129e516dcbd617173c1cf14)
2013-06-06xfs: inode unlinked list needs to recalculate the inode CRCDave Chinner
The inode unlinked list manipulations operate directly on the inode buffer, and so bypass the inode CRC calculation mechanisms. Hence an inode on the unlinked list has an invalid CRC. Fix this by recalculating the CRC whenever we modify an unlinked list pointer in an inode, ncluding during log recovery. This is trivial to do and results in unlinked list operations always leaving a consistent inode in the buffer. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 0a32c26e720a8b38971d0685976f4a7d63f9e2ef)
2013-06-06xfs: fix log recovery transaction item reorderingDave Chinner
There are several constraints that inode allocation and unlink logging impose on log recovery. These all stem from the fact that inode alloc/unlink are logged in buffers, but all other inode changes are logged in inode items. Hence there are ordering constraints that recovery must follow to ensure the correct result occurs. As it turns out, this ordering has been working mostly by chance than good management. The existing code moves all buffers except cancelled buffers to the head of the list, and everything else to the tail of the list. The problem with this is that is interleaves inode items with the buffer cancellation items, and hence whether the inode item in an cancelled buffer gets replayed is essentially left to chance. Further, this ordering causes problems for log recovery when inode CRCs are enabled. It typically replays the inode unlink buffer long before it replays the inode core changes, and so the CRC recorded in an unlink buffer is going to be invalid and hence any attempt to validate the inode in the buffer is going to fail. Hence we really need to enforce the ordering that the inode alloc/unlink code has expected log recovery to have since inode chunk de-allocation was introduced back in 2003... Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit a775ad778073d55744ed6709ccede36310638911)
2013-06-06xfs: fix remote attribute invalidation for a leafDave Chinner
When invalidating an attribute leaf block block, there might be remote attributes that it points to. With the recent rework of the remote attribute format, we have to make sure we calculate the length of the attribute correctly. We aren't doing that in xfs_attr3_leaf_inactive(), so fix it. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Mark Tinguely <tinuguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 59913f14dfe8eb772ff93eb442947451b4416329)
2013-06-06xfs: rework dquot CRCsDave Chinner
Calculating dquot CRCs when the backing buffer is written back just doesn't work reliably. There are several places which manipulate dquots directly in the buffers, and they don't calculate CRCs appropriately, nor do they always set the buffer up to calculate CRCs appropriately. Firstly, if we log a dquot buffer (e.g. during allocation) it gets logged without valid CRC, and so on recovery we end up with a dquot that is not valid. Secondly, if we recover/repair a dquot, we don't have a verifier attached to the buffer and hence CRCs are not calculated on the way down to disk. Thirdly, calculating the CRC after we've changed the contents means that if we re-read the dquot from the buffer, we cannot verify the contents of the dquot are valid, as the CRC is invalid. So, to avoid all the dquot CRC errors that are being detected by the read verifier, change to using the same model as for inodes. That is, dquot CRCs are calculated and written to the backing buffer at the time the dquot is flushed to the backing buffer. If we modify the dquot directly in the backing buffer, calculate the CRC immediately after the modification is complete. Hence the dquot in the on-disk buffer should always have a valid CRC. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 6fcdc59de28817d1fbf1bd58cc01f4f3fac858fb)
2013-06-04eCryptfs: Check return of filemap_write_and_wait during fsyncTyler Hicks
Error out of ecryptfs_fsync() if filemap_write_and_wait() fails. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Cc: Paul Taysom <taysom@chromium.org> Cc: Olof Johansson <olofj@chromium.org> Cc: stable@vger.kernel.org # v3.6+
2013-06-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixesLinus Torvalds
Pull gfs2 fixes from Steven Whitehouse: "There are four patches this time. The first fixes a problem where the wrong descriptor type was being written into the log for journaled data blocks. The second fixes a race relating to the deallocation of allocator data. The third provides a fallback if kmalloc is unable to satisfy a request to allocate a directory hash table. The fourth fixes the iopen glock caching so that inodes are deleted in a more timely manner after rmdir/unlink" * git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes: GFS2: Don't cache iopen glocks GFS2: Fall back to vmalloc if kmalloc fails for dir hash tables GFS2: Increase i_writecount during gfs2_setattr_size GFS2: Set log descriptor type for jdata blocks
2013-06-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse fixes from Miklos Szeredi: "One patch fixes an Oops introduced in 3.9 with the readdirplus feature. The rest are fixes for async-dio in 3.10" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: fix alignment in short read optimization for async_dio fuse: return -EIOCBQUEUED from fuse_direct_IO() for all async requests fuse: fix readdirplus Oops in fuse_dentry_revalidate fuse: update inode size and invalidate attributes on fallocate fuse: truncate pagecache range on hole punch fuse: allocate for_background dio requests based on io->async state
2013-06-04Merge tag 'jfs-3.10-rc5' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs bugfixes from David Kleikamp: "A couple jfs bug fixes for 3.10-rc5" * tag 'jfs-3.10-rc5' of git://github.com/kleikamp/linux-shaggy: fs/jfs: Add check if journaling to disk has been disabled in lbmRead() jfs: Several bugs in jfs_freeze() and jfs_unfreeze()
2013-06-03GFS2: Don't cache iopen glocksBob Peterson
This patch makes GFS2 immediately reclaim/delete all iopen glocks as soon as they're dequeued. This allows deleters to get an EXclusive lock on iopen so files are deleted properly instead of being set as unlinked. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-06-03GFS2: Fall back to vmalloc if kmalloc fails for dir hash tablesBob Peterson
This version has one more correction: the vmalloc calls are replaced by __vmalloc calls to preserve the GFP_NOFS flag. When GFS2's directory management code allocates buffers for a directory hash table, if it can't get the memory it needs, it currently gives a bad return code. Rather than giving an error, this patch allows it to use virtual memory rather than kernel memory for the hash table. This should make it possible for directories to function properly, even when kernel memory becomes very fragmented. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-06-03GFS2: Increase i_writecount during gfs2_setattr_sizeBob Peterson
This patch calls get_write_access in a few functions. This merely increases inode->i_writecount for the duration of the function. That will ensure that any file closes won't delete the inode's multi-block reservation while the function is running. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-06-03GFS2: Set log descriptor type for jdata blocksBob Peterson
This patch sets the log descriptor type according to whether the journal commit is for (journaled) data or metadata. This was recently broken when the functions to process data and metadata log ops were combined. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-06-03fuse: fix alignment in short read optimization for async_dioMaxim Patlasov
The bug was introduced with async_dio feature: trying to optimize short reads, we cut number-of-bytes-to-read to i_size boundary. Hence the following example: truncate --size=300 /mnt/file dd if=/mnt/file of=/dev/null iflag=direct led to FUSE_READ request of 300 bytes size. This turned out to be problem for userspace fuse implementations who rely on assumption that kernel fuse does not change alignment of request from client FS. The patch turns off the optimization if async_dio is disabled. And, if it's enabled, the patch fixes adjustment of number-of-bytes-to-read to preserve alignment. Note, that we cannot throw out short read optimization entirely because otherwise a direct read of a huge size issued on a tiny file would generate a huge amount of fuse requests and most of them would be ACKed by userspace with zero bytes read. Signed-off-by: Maxim Patlasov <MPatlasov@parallels.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-06-03fuse: return -EIOCBQUEUED from fuse_direct_IO() for all async requestsBrian Foster
If request submission fails for an async request (i.e., get_user_pages() returns -ERESTARTSYS), we currently skip the -EIOCBQUEUED return and drop into wait_for_sync_kiocb() forever. Avoid this by always returning -EIOCBQUEUED for async requests. If an error occurs, the error is passed into fuse_aio_complete(), returned via aio_complete() and thus propagated to userspace via io_getevents(). Signed-off-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Maxim Patlasov <MPatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-06-03fuse: fix readdirplus Oops in fuse_dentry_revalidateMiklos Szeredi
Fix bug introduced by commit 4582a4ab2a "FUSE: Adapt readdirplus to application usage patterns". We need to check for a positive dentry; negative dentries are not added by readdirplus. Secondly we need to advise the use of readdirplus on the *parent*, otherwise the whole thing is useless. Thirdly all this is only relevant if "readdirplus_auto" mode is selected by the filesystem. We advise the use of readdirplus only if the dentry was still valid. If we had to redo the lookup then there was no use in doing the -plus version. Reported-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Feng Shuo <steve.shuo.feng@gmail.com> CC: stable@vger.kernel.org
2013-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull assorted fixes from Al Viro: "There'll be more - I'm trying to dig out from under the pile of mail (a couple of weeks of something flu-like ;-/) and there's several more things waiting for review; this is just the obvious stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: zoran: racy refcount handling in vm_ops ->open()/->close() befs_readdir(): do not increment ->f_pos if filldir tells us to stop hpfs: deadlock and race in directory lseek() qnx6: qnx6_readdir() has a braino in pos calculation fix buffer leak after "scsi: saner replacements for ->proc_info()" vfs: Fix invalid ida_remove() call
2013-06-01Merge tag 'nfs-for-3.10-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull two NFS client fixes from Trond Myklebust: - Fix a regression that broke NFS mounting using klibc and busybox - Stable fix to check access modes correctly on NFSv4 delegated open() * tag 'nfs-for-3.10-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFS: Fix security flavor negotiation with legacy binary mounts NFSv4: Fix a thinko in nfs4_try_open_cached
2013-06-01Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull reiserfs fixes from Jan Kara: "Three reiserfs fixes. They fix real problems spotted by users so I hope they are ok even at this stage." * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: reiserfs: fix deadlock with nfs racing on create/lookup reiserfs: fix problems with chowning setuid file w/ xattrs reiserfs: fix spurious multiple-fill in reiserfs_readdir_dentry
2013-06-01Merge tag 'for-linus-v3.10-rc4-crc-xattr-fixes' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs extended attribute fixes for CRCs from Ben Myers: "Here are several fixes that are relevant on CRC enabled XFS filesystems. They are followed by a rework of the remote attribute code so that each block of the attribute contains a header with a CRC. Previously there was a CRC header per extent in the remote attribute code, but this was untenable because it was not possible to know how many extents would be allocated for the attribute until after the allocation has completed, due to the fragmentation of free space. This became complicated because the size of the headers needs to be added to the length of the payload to get the overall length required for the allocation. With a header per block, things are less complicated at the cost of a little space. I would have preferred to defer this and the rest of the CRC queue to 3.11 to mitigate risk for existing non-crc users in 3.10. Doing so would require setting a feature bit for the on-disk changes, and so I have been pressured into sending this pull request by Eric Sandeen and David Chinner from Red Hat. I'll send another pull request or two with the rest of the CRC queue next week. - Remove assert on count of remote attribute CRC headers - Fix the number of blocks read in for remote attributes - Zero remote attribute tails properly - Fix mapping of remote attribute buffers to have correct length - initialize temp leaf properly in xfs_attr3_leaf_unbalance, and xfs_attr3_leaf_compact - Rework remote atttributes to have a header per block" * tag 'for-linus-v3.10-rc4-crc-xattr-fixes' of git://oss.sgi.com/xfs/xfs: xfs: rework remote attr CRCs xfs: fully initialise temp leaf in xfs_attr3_leaf_compact xfs: fully initialise temp leaf in xfs_attr3_leaf_unbalance xfs: correctly map remote attr buffers during removal xfs: remote attribute tail zeroing does too much xfs: remote attribute read too short xfs: remote attribute allocation may be contiguous
2013-06-01Merge tag 'for-linus-v3.10-rc4' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs fixes from Ben Myers: - Fix nested transactions in xfs_qm_scall_setqlim - Clear suid/sgid bits when we truncate with size update - Fix recovery for split buffers - Fix block count on remote symlinks - Add fsgeom flag for v5 superblock support - Disable XFS_IOC_SWAPEXT for CRC enabled filesystems - Fix dirv3 freespace block corruption * tag 'for-linus-v3.10-rc4' of git://oss.sgi.com/xfs/xfs: xfs: fix dir3 freespace block corruption xfs: disable swap extents ioctl on CRC enabled filesystems xfs: add fsgeom flag for v5 superblock support. xfs: fix incorrect remote symlink block count xfs: fix split buffer vector log recovery support xfs: kill suid/sgid through the truncate path. xfs: avoid nesting transactions in xfs_qm_scall_setqlim()
