path: root/fs
2015-01-17Merge tag 'driver-core-3.19-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fix from Greg KH: "Here is one kernfs fix for a reported issue for 3.19-rc5. It has been in linux-next for a while" * tag 'driver-core-3.19-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: kernfs: Fix kernfs_name_compare
2015-01-17Merge tag 'nfs-for-3.19-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights include: - Stable fix for a NFSv3/lockd race - Fixes for several NFSv4.1 client id trunking bugs - Remove an incorrect test when checking for delegated opens" * tag 'nfs-for-3.19-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4: Remove incorrect check in can_open_delegated() NFS: Ignore transport protocol when detecting server trunking NFSv4/v4.1: Verify the client owner id during trunking detection NFSv4: Cache the NFSv4/v4.1 client owner_id in the struct nfs_client NFSv4.1: Fix client id trunking on Linux LOCKD: Fix a race when initialising nlmsvc_timeout
2015-01-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse fixes from Miklos Szeredi: "This fixes a regression in the latest fuse update plus a fix for a rather theoretical memory ordering issue" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: add memory barrier to INIT fuse: fix LOOKUP vs INIT compat handling
2015-01-13locks: fix NULL-deref in generic_delete_leaseNeilBrown
commit 0efaa7e82f02fe69c05ad28e905f31fc86e6f08e locks: generic_delete_lease doesn't need a file_lock at all moves the call to fl->fl_lmops->lm_change() to a place in the code where fl might be a non-lease lock. When that happens, fl_lmops is NULL and an Oops ensures. So add an extra test to restore correct functioning. Reported-by: Linda Walsh <suse@tlinx.org> Link: https://bugzilla.suse.com/show_bug.cgi?id=912569 Cc: stable@vger.kernel.org (v3.18) Fixes: 0efaa7e82f02fe69c05ad28e905f31fc86e6f08e Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jeff Layton <jlayton@primarydata.com>
2015-01-11Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Misc fixes: group scheduling corner case fix, two deadline scheduler fixes, effective_load() overflow fix, nested sleep fix, 6144 CPUs system fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/fair: Fix RCU stall upon -ENOMEM in sched_create_group() sched/deadline: Avoid double-accounting in case of missed deadlines sched/deadline: Fix migration of SCHED_DEADLINE tasks sched: Fix odd values in effective_load() calculations sched, fanotify: Deal with nested sleeps sched: Fix KMALLOC_MAX_SIZE overflow during cpumask allocation
2015-01-09Merge branch 'for-3.19' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull two nfsd bugfixes from Bruce Fields. * 'for-3.19' of git://linux-nfs.org/~bfields/linux: rpc: fix xdr_truncate_encode to handle buffer ending on page boundary nfsd: fix fi_delegees leak when fi_had_conflict returns true
2015-01-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull two Ceph fixes from Sage Weil: "These are both pretty trivial: a sparse warning fix and size_t printk thing" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: libceph: fix sparse endianness warnings ceph: use %zu for len in ceph_fill_inline_data()
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "None of these are huge, but my commit does fix a regression from 3.18 that could cause lost files during log replay. This also adds Dave Sterba to the list of Btrfs maintainers. It doesn't mean we're doing things differently, but Dave has really been helping with the maintainer workload for years" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: don't delay inode ref updates during log replay Btrfs: correctly get tree level in tree_backref_for_extent Btrfs: call inode_dec_link_count() on mkdir error path Btrfs: abort transaction if we don't find the block group Btrfs, scrub: uninitialized variable in scrub_extent_for_parity() Btrfs: add more maintainers
2015-01-09kernfs: Fix kernfs_name_compareRasmus Villemoes
Returning a difference from a comparison functions is usually wrong (see acbbe6fbb240 "kcmp: fix standard comparison bug" for the long story). Here there is the additional twist that if the void pointers ns and kn->ns happen to differ by a multiple of 2^32, kernfs_name_compare returns 0, falsely reporting a match to the caller. Technically 'hash - kn->hash' is ok since the hashes are restricted to 31 bits, but it's better to avoid that subtlety. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09sched, fanotify: Deal with nested sleepsPeter Zijlstra
As per e23738a7300a ("sched, inotify: Deal with nested sleeps"). fanotify_read is a wait loop with sleeps in. Wait loops rely on task_struct::state and sleeps do too, since that's the only means of actually sleeping. Therefore the nested sleeps destroy the wait loop state and the wait loop breaks the sleep functions that assume TASK_RUNNING (mutex_lock). Fix this by using the new woken_wake_function and wait_woken() stuff, which registers wakeups in wait and thereby allows shrinking the task_state::state changes to the actual sleep part. Reported-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Reported-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Takashi Iwai <tiwai@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Eric Paris <eparis@redhat.com> Link: http://lkml.kernel.org/r/20141216152838.GZ3337@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-01-08vfs: renumber FMODE_NONOTIFY and add to uniqueness checkDavid Drysdale
Fix clashing values for O_PATH and FMODE_NONOTIFY on sparc. The clashing O_PATH value was added in commit 5229645bdc35 ("vfs: add nonconflicting values for O_PATH") but this can't be changed as it is user-visible. FMODE_NONOTIFY is only used internally in the kernel, but it is in the same numbering space as the other O_* flags, as indicated by the comment at the top of include/uapi/asm-generic/fcntl.h (and its use in fs/notify/fanotify/fanotify_user.c). So renumber it to avoid the clash. All of this has happened before (commit 12ed2e36c98a: "fanotify: FMODE_NONOTIFY and __O_SYNC in sparc conflict"), and all of this will happen again -- so update the uniqueness check in fcntl_init() to include __FMODE_NONOTIFY. Signed-off-by: David Drysdale <drysdale@google.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jan Kara <jack@suse.cz> Cc: Heinrich Schuchardt <xypron.glpk@gmx.de> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-08ocfs2: fix the wrong directory passed to ocfs2_lookup_ino_from_name() when ↵Xue jiufei
link file In ocfs2_link(), the parent directory inode passed to function ocfs2_lookup_ino_from_name() is wrong. Parameter dir is the parent of new_dentry not old_dentry. We should get old_dir from old_dentry and lookup old_dentry in old_dir in case another node remove the old dentry. With this change, hard linking works again, when paths are relative with at least one subdirectory. This is how the problem was reproducable: # mkdir a # mkdir b # touch a/test # ln a/test b/test ln: failed to create hard link `b/test' => `a/test': No such file or directory However when creating links in the same dir, it worked well. Now the link gets created. Fixes: 0e048316ff57 ("ocfs2: check existence of old dentry in ocfs2_link()") Signed-off-by: joyce.xue <xuejiufei@huawei.com> Reported-by: Szabo Aron - UBIT <aron@ubit.hu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Tested-by: Aron Szabo <aron@ubit.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-08ocfs2: remove bogus check in dlm_process_recovery_dataJoseph Qi
In dlm_process_recovery_data, only when dlm_new_lock failed the ret will be set to -ENOMEM. And in this case, newlock is definitely NULL. So test newlock is meaningless, remove it. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Reviewed-by: Alex Chen <alex.chen@huawei.com> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-08ceph: use %zu for len in ceph_fill_inline_data()Ilya Dryomov
len is size_t, should be printed with %zu. Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
2015-01-07nfsd: fix fi_delegees leak when fi_had_conflict returns trueJeff Layton
Currently, nfs4_set_delegation takes a reference to an existing delegation and then checks to see if there is a conflict. If there is one, then it doesn't release that reference. Change the code to take the reference after the check and only if there is no conflict. Signed-off-by: Jeff Layton <jlayton@primarydata.com> Cc: stable@vger.kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2015-01-06Merge tag 'ext4_for_linus_stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 bugfixes from Ted Ts'o: "Revert a potential seek_data/hole regression which shows up when using ext4 to handle ext3 file systems, plus two minor bug fixes" * tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: remove spurious KERN_INFO from ext4_warning call Revert "ext4: fix suboptimal seek_{data,hole} extents traversial" ext4: prevent online resize with backup superblock
2015-01-06fuse: add memory barrier to INITMiklos Szeredi
Theoretically we need to order setting of various fields in fc with fc->initialized. No known bug reports related to this yet. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2015-01-06fuse: fix LOOKUP vs INIT compat handlingMiklos Szeredi
Analysis from Marc: "Commit 7078187a795f ("fuse: introduce fuse_simple_request() helper") from the above pull request triggers some EIO errors for me in some tests that rely on fuse Looking at the code changes and a bit of debugging info I think there's a general problem here that fuse_get_req checks and possibly waits for fc->initialized, and this was always called first. But this commit changes the ordering and in many places fc->minor is now possibly used before fuse_get_req, and we can't be sure that fc has been initialized. In my case fuse_lookup_init sets req->out.args[0].size to the wrong size because fc->minor at that point is still 0, leading to the EIO error." Fix by moving the compat adjustments into fuse_simple_request() to after fuse_get_req(). This is also more readable than the original, since now compatibility is handled in a single function instead of cluttering each operation. Reported-by: Marc Dionne <marc.c.dionne@gmail.com> Tested-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Fixes: 7078187a795f ("fuse: introduce fuse_simple_request() helper")
2015-01-05NFSv4: Remove incorrect check in can_open_delegated()Trond Myklebust
Remove an incorrect check for NFS_DELEGATION_NEED_RECLAIM in can_open_delegated(). We are allowed to cache opens even in a situation where we're doing reboot recovery. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-01-05NFS: Ignore transport protocol when detecting server trunkingChuck Lever
Detect server trunking across transport protocols. Otherwise, an RDMA mount and a TCP mount of the same server will end up with separate nfs_clients using the same clientid4. Reported-by: Dai Ngo <dai.ngo@oracle.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-01-05NFSv4/v4.1: Verify the client owner id during trunking detectionTrond Myklebust
While we normally expect the NFSv4 client to always send the same client owner to all servers, there are a couple of situations where that is not the case: 1) In NFSv4.0, switching between use of '-omigration' and not will cause the kernel to switch between using the non-uniform and uniform client strings. 2) In NFSv4.1, or NFSv4.0 when using uniform client strings, if the uniquifier string is suddenly changed. This patch will catch those situations by checking the client owner id in the trunking detection code, and will do the right thing if it notices that the strings differ. Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-01-05NFSv4: Cache the NFSv4/v4.1 client owner_id in the struct nfs_clientTrond Myklebust
Ensure that we cache the NFSv4/v4.1 client owner_id so that we can verify it when we're doing trunking detection. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-01-05NFSv4.1: Fix client id trunking on LinuxTrond Myklebust
Currently, our trunking code will check for session trunking, but will fail to detect client id trunking. This is a problem, because it means that the client will fail to recognise that the two connections represent shared state, even if they do not permit a shared session. By removing the check for the server minor id, and only checking the major id, we will end up doing the right thing in both cases: we close down the new nfs_client and fall back to using the existing one. Fixes: 05f4c350ee02e ("NFS: Discover NFSv4 server trunking when mounting") Cc: Chuck Lever <chuck.lever@oracle.com> Cc: stable@vger.kernel.org # 3.7.x Tested-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-01-05LOCKD: Fix a race when initialising nlmsvc_timeoutTrond Myklebust
This commit fixes a race whereby nlmclnt_init() first starts the lockd daemon, and then calls nlm_bind_host() with the expectation that nlmsvc_timeout has already been initialised. Unfortunately, there is no no synchronisation between lockd() and lockd_up() to guarantee that this is the case. Fix is to move the initialisation of nlmsvc_timeout into lockd_create_svc Fixes: 9a1b6bf818e74 ("LOCKD: Don't call utsname()->nodename...") Cc: Bruce Fields <bfields@fieldses.org> Cc: stable@vger.kernel.org # 3.10.x Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-01-02ext4: remove spurious KERN_INFO from ext4_warning callJakub Wilk
Signed-off-by: Jakub Wilk <jwilk@jwilk.net> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2015-01-02Revert "ext4: fix suboptimal seek_{data,hole} extents traversial"Theodore Ts'o
This reverts commit 14516bb7bb6ffbd49f35389f9ece3b2045ba5815. This was causing regression test failures with generic/285 with an ext3 filesystem using CONFIG_EXT4_USE_FOR_EXT23. Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2015-01-02Btrfs: don't delay inode ref updates during log replayChris Mason
Commit 1d52c78afbb (Btrfs: try not to ENOSPC on log replay) added a check to skip delayed inode updates during log replay because it confuses the enospc code. But the delayed processing will end up ignoring delayed refs from log replay because the inode itself wasn't put through the delayed code. This can end up triggering a warning at commit time: WARNING: CPU: 2 PID: 778 at fs/btrfs/delayed-inode.c:1410 btrfs_assert_delayed_root_empty+0x32/0x34() Which is repeated for each commit because we never process the delayed inode ref update. The fix used here is to change btrfs_delayed_delete_inode_ref to return an error if we're currently in log replay. The caller will do the ref deletion immediately and everything will work properly. Signed-off-by: Chris Mason <clm@fb.com> cc: stable@vger.kernel.org # v3.18 and any stable series that picked 1d52c78afbbf80b58299e076a159617d6b42fe3c
2015-01-02Btrfs: correctly get tree level in tree_backref_for_extentFilipe Manana
If we are using skinny metadata, the block's tree level is in the offset of the key and not in a btrfs_tree_block_info structure following the extent item (it doesn't exist). Therefore fix it. Besides returning the correct level in the tree, this also prevents reading past the leaf's end in the case where the extent item is the last item in the leaf (eb) and it has only 1 inline reference - this is because sizeof(struct btrfs_tree_block_info) is greater than sizeof(struct btrfs_extent_inline_ref). Got it while running a scrub which produced the following warning: BTRFS: checksum error at logical 42123264 on dev /dev/sde, sector 15840: metadata node (level 24) in tree 5 Signed-off-by: Filipe Manana <fdmanana@suse.com> Reviewed-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-01-02Btrfs: call inode_dec_link_count() on mkdir error pathWang Shilong
In btrfs_mkdir(), if it fails to create dir, we should clean up existed items, setting inode's link properly to make sure it could be cleaned up properly. Signed-off-by: Wang Shilong <wangshilong1991@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-01-02Btrfs: abort transaction if we don't find the block groupJosef Bacik
We shouldn't BUG_ON() if there is corruption. I hit this while testing my block group patch and the abort worked properly. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2015-01-02Btrfs, scrub: uninitialized variable in scrub_extent_for_parity()Dan Carpenter
The only way that "ret" is set is when we call scrub_pages_for_parity() so the skip to "if (ret) " test doesn't make sense and causes a static checker warning. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-12-29Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "A set of three minor cifs fixes" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: cifs: make new inode cache when file type is different Fix signed/unsigned pointer warning Convert MessageID in smb2_hdr to LE
2014-12-29Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull UDF & isofs fixes from Jan Kara: "A couple of UDF fixes of handling of corrupted media and one iso9660 fix of the same" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: Reduce repeated dereferences udf: Check component length before reading it udf: Check path length when reading symlink udf: Verify symlink size before loading it udf: Verify i_size when loading inode isofs: Fix unchecked printing of ER records
2014-12-26ext4: prevent online resize with backup superblockTheodore Ts'o
Prevent BUG or corrupted file systems after the following: mkfs.ext4 /dev/vdc 100M mount -t ext4 -o sb=40961 /dev/vdc /vdc resize2fs /dev/vdc We previously prevented online resizing using the old resize ioctl. Move the code to ext4_resize_begin(), so the check applies for all of the resize ioctl's. Reported-by: Maxim Malkov <malkov@ispras.ru> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2014-12-22cifs: make new inode cache when file type is differentNakajima Akira
In spite of different file type, if file is same name and same inode number, old inode cache is used. This causes that you can not cd directory, can not cat SymbolicLink. So this patch is that if file type is different, return error. Reproducible sample : 1. create file 'a' at cifs client. 2. repeat rm and mkdir 'a' 4 times at server, then direcotry 'a' having same inode number is created. (Repeat 4 times, then same inode number is recycled.) (When server is under RHEL 6.6, 1 time is O.K. Always same inode number is recycled.) 3. ls -li at client, then you can not cd directory, can not remove directory. SymbolicLink has same problem. Bug link: https://bugzilla.kernel.org/show_bug.cgi?id=90011 Signed-off-by: Nakajima Akira <nakajima.akira@nttcom.co.jp> Acked-by: Jeff Layton <jlayton@primarydata.com> Signed-off-by: Steve French <steve.french@primarydata.com>
2014-12-21udf: Reduce repeated dereferencesJan Kara
Replace repeated dereferences like dir->i_sb by storing superblock pointer in a variable and using that. Signed-off-by: Jan Kara <jack@suse.cz>
2014-12-21udf: Check component length before reading itJan Kara
Check that length specified in a component of a symlink fits in the input buffer we are reading. Also properly ignore component length for component types that do not use it. Otherwise we read memory after end of buffer for corrupted udf image. Reported-by: Carl Henrik Lunde <chlunde@ping.uio.no> CC: stable@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2014-12-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #3 from Al Viro: "Assorted fixes and patches from the last cycle" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: [regression] chunk lost from bd9b51 vfs: make mounts and mountstats honor root dir like mountinfo does vfs: cleanup show_mountinfo init: fix read-write root mount unfuck binfmt_misc.c (broken by commit e6084d4) vm_area_operations: kill ->migrate() new helper: iter_is_iovec() move_extent_per_page(): get rid of unused w_flags lustre: get rid of playing with ->fs btrfs: filp_open() returns ERR_PTR() on failure, not NULL...
2014-12-19Merge tag 'ecryptfs-3.19-rc1-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull eCryptfs fixes from Tyler Hicks: "Fixes for filename decryption and encrypted view plus a cleanup - The filename decryption routines were, at times, writing a zero byte one character past the end of the filename buffer - The encrypted view feature attempted, and failed, to roll its own form of enforcing a read-only mount instead of letting the VFS enforce it" * tag 'ecryptfs-3.19-rc1-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: Remove buggy and unnecessary write in file name decode routine eCryptfs: Remove unnecessary casts when parsing packet lengths eCryptfs: Force RO mount when encrypted view is enabled
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull more btrfs updates from Chris Mason: "This is part two of our merge window patches. These are all from Filipe, and fix some really hard to find races that can cause corruptions. Most of them involved block group removal (balance) or discard" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: remove non-sense btrfs_error_discard_extent() function Btrfs: fix fs corruption on transaction abort if device supports discard Btrfs: always clear a block group node when removing it from the tree Btrfs: ensure deletion from pinned_chunks list is protected
2014-12-19Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq core fix from Thomas Gleixner: "A single fix plugging a long standing race between proc/stat and proc/interrupts access and freeing of interrupt descriptors" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Prevent proc race against freeing of irq descriptors
2014-12-19udf: Check path length when reading symlinkJan Kara
Symlink reading code does not check whether the resulting path fits into the page provided by the generic code. This isn't as easy as just checking the symlink size because of various encoding conversions we perform on path. So we have to check whether there is still enough space in the buffer on the fly. CC: stable@vger.kernel.org Reported-by: Carl Henrik Lunde <chlunde@ping.uio.no> Signed-off-by: Jan Kara <jack@suse.cz>
2014-12-19udf: Verify symlink size before loading itJan Kara
UDF specification allows arbitrarily large symlinks. However we support only symlinks at most one block large. Check the length of the symlink so that we don't access memory beyond end of the symlink block. CC: stable@vger.kernel.org Reported-by: Carl Henrik Lunde <chlunde@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-12-19udf: Verify i_size when loading inodeJan Kara
Verify that inode size is sane when loading inode with data stored in ICB. Otherwise we may get confused later when working with the inode and inode size is too big. CC: stable@vger.kernel.org Reported-by: Carl Henrik Lunde <chlunde@ping.uio.no> Signed-off-by: Jan Kara <jack@suse.cz>
2014-12-19isofs: Fix unchecked printing of ER recordsJan Kara
We didn't check length of rock ridge ER records before printing them. Thus corrupted isofs image can cause us to access and print some memory behind the buffer with obvious consequences. Reported-and-tested-by: Carl Henrik Lunde <chlunde@ping.uio.no> CC: stable@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2014-12-18Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: "A few stragglers" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: tools/testing/selftests/Makefile: alphasort the TARGETS list mm/zsmalloc: adjust order of functions ocfs2: fix journal commit deadlock ocfs2/dlm: fix race between dispatched_work and dlm_lockres_grab_inflight_worker ocfs2: reflink: fix slow unlink for refcounted file mm/memory.c:do_shared_fault(): add comment .mailmap: Santosh Shilimkar has moved .mailmap: update akpm@osdl.org lib/show_mem.c: add cma reserved information fs/proc/meminfo.c: include cma info in proc/meminfo mm: cma: split cma-reserved in dmesg log hfsplus: fix longname handling mm/mempolicy.c: remove unnecessary is_valid_nodemask()
2014-12-18ocfs2: fix journal commit deadlockJunxiao Bi
For buffer write, page lock will be got in write_begin and released in write_end, in ocfs2_write_end_nolock(), before it unlock the page in ocfs2_free_write_ctxt(), it calls ocfs2_run_deallocs(), this will ask for the read lock of journal->j_trans_barrier. Holding page lock and ask for journal->j_trans_barrier breaks the locking order. This will cause a deadlock with journal commit threads, ocfs2cmt will get write lock of journal->j_trans_barrier first, then it wakes up kjournald2 to do the commit work, at last it waits until done. To commit journal, kjournald2 needs flushing data first, it needs get the cache page lock. Since some ocfs2 cluster locks are holding by write process, this deadlock may hung the whole cluster. unlock pages before ocfs2_run_deallocs() can fix the locking order, also put unlock before ocfs2_commit_trans() to make page lock is unlocked before j_trans_barrier to preserve unlocking order. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Reviewed-by: Wengang Wang <wen.gang.wang@oracle.com> Cc: <stable@vger.kernel.org> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-18ocfs2/dlm: fix race between dispatched_work and dlm_lockres_grab_inflight_workerJoseph Qi
Commit ac4fef4d23ed ("ocfs2/dlm: do not purge lockres that is queued for assert master") may have the following possible race case: dlm_dispatch_assert_master dlm_wq ======================================================================== queue_work(dlm->quedlm_worker, &dlm->dispatched_work); dispatch work, dlm_lockres_drop_inflight_worker *BUG_ON(res->inflight_assert_workers == 0)* dlm_lockres_grab_inflight_worker inflight_assert_workers++ So ensure inflight_assert_workers to be increased first. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Signed-off-by: Xue jiufei <xuejiufei@huawei.com> Cc: Joel Becker <jlbec@evilplan.org> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-18ocfs2: reflink: fix slow unlink for refcounted fileJunxiao Bi
When running ocfs2 test suite multiple nodes reflink stress test, for a 4 nodes cluster, every unlink() for refcounted file needs about 700s. The slow unlink is caused by the contention of refcount tree lock since all nodes are unlink files using the same refcount tree. When the unlinking file have many extents(over 1600 in our test), most of the extents has refcounted flag set. In ocfs2_commit_truncate(), it will execute the following call trace for every extents. This means it needs get and released refcount tree lock about 1600 times. And when several nodes are do this at the same time, the performance will be very low. ocfs2_remove_btree_range() -- ocfs2_lock_refcount_tree() ---- ocfs2_refcount_lock() ------ __ocfs2_cluster_lock() ocfs2_refcount_lock() is costly, move it to ocfs2_commit_truncate() to do lock/unlock once can improve a lot performance. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Wengang <wen.gang.wang@oracle.com> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-18fs/proc/meminfo.c: include cma info in proc/meminfoPintu Kumar
This patch include CMA info (CMATotal, CMAFree) in /proc/meminfo. Currently, in a CMA enabled system, if somebody wants to know the total CMA size declared, there is no way to tell, other than the dmesg or /var/log/messages logs. With this patch we are showing the CMA info as part of meminfo, so that it can be determined at any point of time. This will be populated only when CMA is enabled. Below is the sample output from a ARM based device with RAM:512MB and CMA:16MB. MemTotal: 471172 kB MemFree: 111712 kB MemAvailable: 271172 kB . . . CmaTotal: 16384 kB CmaFree: 6144 kB This patch also fix below checkpatch errors that were found during these changes. ERROR: space required after that ',' (ctx:ExV) 199: FILE: fs/proc/meminfo.c:199: + ,atomic_long_read(&num_poisoned_pages) << (PAGE_SHIFT - 10) ^ ERROR: space required after that ',' (ctx:ExV) 202: FILE: fs/proc/meminfo.c:202: + ,K(global_page_state(NR_ANON_TRANSPARENT_HUGEPAGES) * ^ ERROR: space required after that ',' (ctx:ExV) 206: FILE: fs/proc/meminfo.c:206: + ,K(totalcma_pages) ^ total: 3 errors, 0 warnings, 2 checks, 236 lines checked Signed-off-by: Pintu Kumar <pintu.k@samsung.com> Signed-off-by: Vishnu Pratap Singh <vishnu.ps@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
