path: root/fs
2017-03-17Merge tag 'v4.1.39' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.39 * tag 'v4.1.39': (138 commits) Linux 4.1.39 KVM: x86: remove data variable from kvm_get_msr_common KVM: VMX: Fix host initiated access to guest MSR_TSC_AUX KVM: x86: pass host_initiated to functions that read MSRs perf/core: Fix the perf_cpu_time_max_percent check perf/core: Make sysctl_perf_cpu_time_max_percent conform to documentation perf/core: Fix implicitly enable dynamic interrupt throttle perf/core: Fix dynamic interrupt throttle Fix missing sanity check in /dev/sg printk: use rcuidle console tracepoint vfs: fix uninitialized flags in splice_to_pipe() drm/radeon: Use mode h/vdisplay fields to hide out of bounds HW cursor ARM: 8658/1: uaccess: fix zeroing of 64-bit get_user() drm/dp/mst: fix kernel oops when turning off secondary monitor [media] siano: make it work again with CONFIG_VMAP_STACK mmc: core: fix multi-bit bus width without high-speed mode futex: Move futex_init() to core_initcall xen-netfront: Delete rx_refill_timer in xennet_disconnect_backend() scsi: aacraid: Fix INTx/MSI-x issue with older controllers cpumask: use nr_cpumask_bits for parsing functions ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2017-03-06vfs: fix uninitialized flags in splice_to_pipe()Miklos Szeredi
[ Upstream commit 5a81e6a171cdbd1fa8bc1fdd80c23d3d71816fac ] Flags (PIPE_BUF_FLAG_PACKET, PIPE_BUF_FLAG_GIFT) could remain on the unused part of the pipe ring buffer. Previously splice_to_pipe() left the flags value alone, which could result in incorrect behavior. Uninitialized flags appears to have been there from the introduction of the splice syscall. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Cc: <stable@vger.kernel.org> # 2.6.17+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-03-06btrfs: fix btrfs_compat_ioctl failures on non-compat ioctlsJeff Mahoney
[ Upstream commit 2a362249187a8d0f6d942d6e1d763d150a296f47 ] Commit 4c63c2454ef incorrectly assumed that returning -ENOIOCTLCMD would cause the native ioctl to be called. The ->compat_ioctl callback is expected to handle all ioctls, not just compat variants. As a result, when using 32-bit userspace on 64-bit kernels, everything except those three ioctls would return -ENOTTY. Fixes: 4c63c2454ef ("btrfs: bugfix: handle FS_IOC32_{GETFLAGS,SETFLAGS,GETVERSION} in btrfs_ioctl") Cc: stable@vger.kernel.org Signed-off-by: Jeff Mahoney <jeffm@suse.com> Reviewed-by: David Sterba <dsterba@suse.com> Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-03-06NFSD: Fix a null reference case in find_or_create_lock_stateid()Kinglong Mee
[ Upstream commit d19fb70dd68c4e960e2ac09b0b9c79dfdeefa726 ] nfsd assigns the nfs4_free_lock_stateid to .sc_free in init_lock_stateid(). If nfsd doesn't go through init_lock_stateid() and put stateid at end, there is a NULL reference to .sc_free when calling nfs4_put_stid(ns). This patch let the nfs4_stid.sc_free assignment to nfs4_alloc_stid(). Cc: stable@vger.kernel.org Fixes: 356a95ece7aa "nfsd: clean up races in lock stateid searching..." Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-03-06nfs: Fix "Don't increment lock sequence ID after NFS4ERR_MOVED"Chuck Lever
[ Upstream commit 406dab8450ec76eca88a1af2fc15d18a2b36ca49 ] Lock sequence IDs are bumped in decode_lock by calling nfs_increment_seqid(). nfs_increment_sequid() does not use the seqid_mutating_err() function fixed in commit 059aa7348241 ("Don't increment lock sequence ID after NFS4ERR_MOVED"). Fixes: 059aa7348241 ("Don't increment lock sequence ID after ...") Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: Xuan Qi <xuan.qi@oracle.com> Cc: stable@vger.kernel.org # v3.7+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-03-06ceph: fix bad endianness handling in parse_reply_info_extraJeff Layton
[ Upstream commit 6df8c9d80a27cb587f61b4f06b57e248d8bc3f86 ] sparse says: fs/ceph/mds_client.c:291:23: warning: restricted __le32 degrades to integer fs/ceph/mds_client.c:293:28: warning: restricted __le32 degrades to integer fs/ceph/mds_client.c:294:28: warning: restricted __le32 degrades to integer fs/ceph/mds_client.c:296:28: warning: restricted __le32 degrades to integer The op value is __le32, so we need to convert it before comparing it. Cc: stable@vger.kernel.org # needs backporting for < 3.14 Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-03-06ubifs: Fix journal replay wrt. xattr nodesRichard Weinberger
[ Upstream commit 1cb51a15b576ee325d527726afff40947218fd5e ] When replaying the journal it can happen that a journal entry points to a garbage collected node. This is the case when a power-cut occurred between a garbage collect run and a commit. In such a case nodes have to be read using the failable read functions to detect whether the found node matches what we expect. One corner case was forgotten, when the journal contains an entry to remove an inode all xattrs have to be removed too. UBIFS models xattr like directory entries, so the TNC code iterates over all xattrs of the inode and removes them too. This code re-uses the functions for walking directories and calls ubifs_tnc_next_ent(). ubifs_tnc_next_ent() expects to be used only after the journal and aborts when a node does not match the expected result. This behavior can render an UBIFS volume unmountable after a power-cut when xattrs are used. Fix this issue by using failable read functions in ubifs_tnc_next_ent() too when replaying the journal. Cc: stable@vger.kernel.org Fixes: 1e51764a3c2ac05a ("UBIFS: add new flash file system") Reported-by: Rock Lee <rockdotlee@gmail.com> Reviewed-by: David Gstir <david@sigma-star.at> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-03-06ocfs2: fix crash caused by stale lvb with fsdlm pluginEric Ren
[ Upstream commit e7ee2c089e94067d68475990bdeed211c8852917 ] The crash happens rather often when we reset some cluster nodes while nodes contend fiercely to do truncate and append. The crash backtrace is below: dlm: C21CBDA5E0774F4BA5A9D4F317717495: dlm_recover_grant 1 locks on 971 resources dlm: C21CBDA5E0774F4BA5A9D4F317717495: dlm_recover 9 generation 5 done: 4 ms ocfs2: Begin replay journal (node 318952601, slot 2) on device (253,18) ocfs2: End replay journal (node 318952601, slot 2) on device (253,18) ocfs2: Beginning quota recovery on device (253,18) for slot 2 ocfs2: Finishing quota recovery on device (253,18) for slot 2 (truncate,30154,1):ocfs2_truncate_file:470 ERROR: bug expression: le64_to_cpu(fe->i_size) != i_size_read(inode) (truncate,30154,1):ocfs2_truncate_file:470 ERROR: Inode 290321, inode i_size = 732 != di i_size = 937, i_flags = 0x1 ------------[ cut here ]------------ kernel BUG at /usr/src/linux/fs/ocfs2/file.c:470! invalid opcode: 0000 [#1] SMP Modules linked in: ocfs2_stack_user(OEN) ocfs2(OEN) ocfs2_nodemanager ocfs2_stackglue(OEN) quota_tree dlm(OEN) configfs fuse sd_mod iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi af_packet iscsi_ibft iscsi_boot_sysfs softdog xfs libcrc32c ppdev parport_pc pcspkr parport joydev virtio_balloon virtio_net i2c_piix4 acpi_cpufreq button processor ext4 crc16 jbd2 mbcache ata_generic cirrus virtio_blk ata_piix drm_kms_helper ahci syscopyarea libahci sysfillrect sysimgblt fb_sys_fops ttm floppy libata drm virtio_pci virtio_ring uhci_hcd virtio ehci_hcd usbcore serio_raw usb_common sg dm_multipath dm_mod scsi_dh_rdac scsi_dh_emc scsi_dh_alua scsi_mod autofs4 Supported: No, Unsupported modules are loaded CPU: 1 PID: 30154 Comm: truncate Tainted: G OE N 4.4.21-69-default #1 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.8.1-0-g4adadbd-20151112_172657-sheep25 04/01/2014 task: ffff88004ff6d240 ti: ffff880074e68000 task.ti: ffff880074e68000 RIP: 0010:[<ffffffffa05c8c30>] [<ffffffffa05c8c30>] ocfs2_truncate_file+0x640/0x6c0 [ocfs2] RSP: 0018:ffff880074e6bd50 EFLAGS: 00010282 RAX: 0000000000000074 RBX: 000000000000029e RCX: 0000000000000000 RDX: 0000000000000001 RSI: 0000000000000246 RDI: 0000000000000246 RBP: ffff880074e6bda8 R08: 000000003675dc7a R09: ffffffff82013414 R10: 0000000000034c50 R11: 0000000000000000 R12: ffff88003aab3448 R13: 00000000000002dc R14: 0000000000046e11 R15: 0000000000000020 FS: 00007f839f965700(0000) GS:ffff88007fc80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f839f97e000 CR3: 0000000036723000 CR4: 00000000000006e0 Call Trace: ocfs2_setattr+0x698/0xa90 [ocfs2] notify_change+0x1ae/0x380 do_truncate+0x5e/0x90 do_sys_ftruncate.constprop.11+0x108/0x160 entry_SYSCALL_64_fastpath+0x12/0x6d Code: 24 28 ba d6 01 00 00 48 c7 c6 30 43 62 a0 8b 41 2c 89 44 24 08 48 8b 41 20 48 c7 c1 78 a3 62 a0 48 89 04 24 31 c0 e8 a0 97 f9 ff <0f> 0b 3d 00 fe ff ff 0f 84 ab fd ff ff 83 f8 fc 0f 84 a2 fd ff RIP [<ffffffffa05c8c30>] ocfs2_truncate_file+0x640/0x6c0 [ocfs2] It's because ocfs2_inode_lock() get us stale LVB in which the i_size is not equal to the disk i_size. We mistakenly trust the LVB because the underlaying fsdlm dlm_lock() doesn't set lkb_sbflags with DLM_SBF_VALNOTVALID properly for us. But, why? The current code tries to downconvert lock without DLM_LKF_VALBLK flag to tell o2cb don't update RSB's LVB if it's a PR->NULL conversion, even if the lock resource type needs LVB. This is not the right way for fsdlm. The fsdlm plugin behaves different on DLM_LKF_VALBLK, it depends on DLM_LKF_VALBLK to decide if we care about the LVB in the LKB. If DLM_LKF_VALBLK is not set, fsdlm will skip recovering RSB's LVB from this lkb and set the right DLM_SBF_VALNOTVALID appropriately when node failure happens. The following diagram briefly illustrates how this crash happens: RSB1 is inode metadata lock resource with LOCK_TYPE_USES_LVB; The 1st round: Node1 Node2 RSB1: PR RSB1(master): NULL->EX ocfs2_downconvert_lock(PR->NULL, set_lvb==0) ocfs2_dlm_lock(no DLM_LKF_VALBLK) - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - dlm_lock(no DLM_LKF_VALBLK) convert_lock(overwrite lkb->lkb_exflags with no DLM_LKF_VALBLK) RSB1: NULL RSB1: EX reset Node2 dlm_recover_rsbs() recover_lvb() /* The LVB is not trustable if the node with EX fails and * no lock >= PR is left. We should set RSB_VALNOTVALID for RSB1. */ if(!(kb_exflags & DLM_LKF_VALBLK)) /* This means we miss the chance to return; * to invalid the LVB here. */ The 2nd round: Node 1 Node2 RSB1(become master from recovery) ocfs2_setattr() ocfs2_inode_lock(NULL->EX) /* dlm_lock() return the stale lvb without setting DLM_SBF_VALNOTVALID */ ocfs2_meta_lvb_is_trustable() return 1 /* so we don't refresh inode from disk */ ocfs2_truncate_file() mlog_bug_on_msg(disk isize != i_size_read(inode)) /* crash! */ The fix is quite straightforward. We keep to set DLM_LKF_VALBLK flag for dlm_lock() if the lock resource type needs LVB and the fsdlm plugin is uesed. Link: http://lkml.kernel.org/r/1481275846-6604-1-git-send-email-zren@suse.com Signed-off-by: Eric Ren <zren@suse.com> Reviewed-by: Joseph Qi <jiangqi903@gmail.com> Cc: Mark Fasheh <mfasheh@versity.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Junxiao Bi <junxiao.bi@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-03-06sysctl: Drop reference added by grab_header in proc_sys_readdirZhou Chengming
[ Upstream commit 93362fa47fe98b62e4a34ab408c4a418432e7939 ] Fixes CVE-2016-9191, proc_sys_readdir doesn't drop reference added by grab_header when return from !dir_emit_dots path. It can cause any path called unregister_sysctl_table will wait forever. The calltrace of CVE-2016-9191: [ 5535.960522] Call Trace: [ 5535.963265] [<ffffffff817cdaaf>] schedule+0x3f/0xa0 [ 5535.968817] [<ffffffff817d33fb>] schedule_timeout+0x3db/0x6f0 [ 5535.975346] [<ffffffff817cf055>] ? wait_for_completion+0x45/0x130 [ 5535.982256] [<ffffffff817cf0d3>] wait_for_completion+0xc3/0x130 [ 5535.988972] [<ffffffff810d1fd0>] ? wake_up_q+0x80/0x80 [ 5535.994804] [<ffffffff8130de64>] drop_sysctl_table+0xc4/0xe0 [ 5536.001227] [<ffffffff8130de17>] drop_sysctl_table+0x77/0xe0 [ 5536.007648] [<ffffffff8130decd>] unregister_sysctl_table+0x4d/0xa0 [ 5536.014654] [<ffffffff8130deff>] unregister_sysctl_table+0x7f/0xa0 [ 5536.021657] [<ffffffff810f57f5>] unregister_sched_domain_sysctl+0x15/0x40 [ 5536.029344] [<ffffffff810d7704>] partition_sched_domains+0x44/0x450 [ 5536.036447] [<ffffffff817d0761>] ? __mutex_unlock_slowpath+0x111/0x1f0 [ 5536.043844] [<ffffffff81167684>] rebuild_sched_domains_locked+0x64/0xb0 [ 5536.051336] [<ffffffff8116789d>] update_flag+0x11d/0x210 [ 5536.057373] [<ffffffff817cf61f>] ? mutex_lock_nested+0x2df/0x450 [ 5536.064186] [<ffffffff81167acb>] ? cpuset_css_offline+0x1b/0x60 [ 5536.070899] [<ffffffff810fce3d>] ? trace_hardirqs_on+0xd/0x10 [ 5536.077420] [<ffffffff817cf61f>] ? mutex_lock_nested+0x2df/0x450 [ 5536.084234] [<ffffffff8115a9f5>] ? css_killed_work_fn+0x25/0x220 [ 5536.091049] [<ffffffff81167ae5>] cpuset_css_offline+0x35/0x60 [ 5536.097571] [<ffffffff8115aa2c>] css_killed_work_fn+0x5c/0x220 [ 5536.104207] [<ffffffff810bc83f>] process_one_work+0x1df/0x710 [ 5536.110736] [<ffffffff810bc7c0>] ? process_one_work+0x160/0x710 [ 5536.117461] [<ffffffff810bce9b>] worker_thread+0x12b/0x4a0 [ 5536.123697] [<ffffffff810bcd70>] ? process_one_work+0x710/0x710 [ 5536.130426] [<ffffffff810c3f7e>] kthread+0xfe/0x120 [ 5536.135991] [<ffffffff817d4baf>] ret_from_fork+0x1f/0x40 [ 5536.142041] [<ffffffff810c3e80>] ? kthread_create_on_node+0x230/0x230 One cgroup maintainer mentioned that "cgroup is trying to offline a cpuset css, which takes place under cgroup_mutex. The offlining ends up trying to drain active usages of a sysctl table which apprently is not happening." The real reason is that proc_sys_readdir doesn't drop reference added by grab_header when return from !dir_emit_dots path. So this cpuset offline path will wait here forever. See here for details: http://www.openwall.com/lists/oss-security/2016/11/04/13 Fixes: f0c3b5093add ("[readdir] convert procfs") Cc: stable@vger.kernel.org Reported-by: CAI Qian <caiqian@redhat.com> Tested-by: Yang Shukui <yangshukui@huawei.com> Signed-off-by: Zhou Chengming <zhouchengming1@huawei.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-03-06mnt: Protect the mountpoint hashtable with mount_lockEric W. Biederman
[ Upstream commit 3895dbf8985f656675b5bde610723a29cbce3fa7 ] Protecting the mountpoint hashtable with namespace_sem was sufficient until a call to umount_mnt was added to mntput_no_expire. At which point it became possible for multiple calls of put_mountpoint on the same hash chain to happen on the same time. Kristen Johansen <kjlx@templeofstupid.com> reported: > This can cause a panic when simultaneous callers of put_mountpoint > attempt to free the same mountpoint. This occurs because some callers > hold the mount_hash_lock, while others hold the namespace lock. Some > even hold both. > > In this submitter's case, the panic manifested itself as a GP fault in > put_mountpoint() when it called hlist_del() and attempted to dereference > a m_hash.pprev that had been poisioned by another thread. Al Viro observed that the simple fix is to switch from using the namespace_sem to the mount_lock to protect the mountpoint hash table. I have taken Al's suggested patch moved put_mountpoint in pivot_root (instead of taking mount_lock an additional time), and have replaced new_mountpoint with get_mountpoint a function that does the hash table lookup and addition under the mount_lock. The introduction of get_mounptoint ensures that only the mount_lock is needed to manipulate the mountpoint hashtable. d_set_mounted is modified to only set DCACHE_MOUNTED if it is not already set. This allows get_mountpoint to use the setting of DCACHE_MOUNTED to ensure adding a struct mountpoint for a dentry happens exactly once. Cc: stable@vger.kernel.org Fixes: ce07d891a089 ("mnt: Honor MNT_LOCKED when detaching mounts") Reported-by: Krister Johansen <kjlx@templeofstupid.com> Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-03-02ptrace: Capture the ptracer's creds not PT_PTRACE_CAPEric W. Biederman
[ Upstream commit 64b875f7ac8a5d60a4e191479299e931ee949b67 ] When the flag PT_PTRACE_CAP was added the PTRACE_TRACEME path was overlooked. This can result in incorrect behavior when an application like strace traces an exec of a setuid executable. Further PT_PTRACE_CAP does not have enough information for making good security decisions as it does not report which user namespace the capability is in. This has already allowed one mistake through insufficient granulariy. I found this issue when I was testing another corner case of exec and discovered that I could not get strace to set PT_PTRACE_CAP even when running strace as root with a full set of caps. This change fixes the above issue with strace allowing stracing as root a setuid executable without disabling setuid. More fundamentaly this change allows what is allowable at all times, by using the correct information in it's decision. Cc: stable@vger.kernel.org Fixes: 4214e42f96d4 ("v2.4.9.11 -> v2.4.9.12") Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-23Merge tag 'v4.1.38' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.38 * tag 'v4.1.38': (109 commits) Linux 4.1.38 gro: Allow tunnel stacking in the case of FOU/GUE tunnels: Don't apply GRO to multiple layers of encapsulation. net: ipv4: Convert IP network timestamps to be y2038 safe ipip: Properly mark ipip GRO packets as encapsulated. sg_write()/bsg_write() is not fit to be called under KERNEL_DS fs: exec: apply CLOEXEC before changing dumpable task flags IB/cma: Fix a race condition in iboe_addr_get_sgid() Revert "ALSA: usb-audio: Fix race at stopping the stream" kvm: nVMX: Allow L1 to intercept software exceptions (#BP and #OF) drivers/gpu/drm/ast: Fix infinite loop if read fails target/user: Fix use-after-free of tcmu_cmds if they are expired kernel/debug/debug_core.c: more properly delay for secondary CPUs scsi: avoid a permanent stop of the scsi device's request queue IB/multicast: Check ib_find_pkey() return value IPoIB: Avoid reading an uninitialized member variable block_dev: don't test bdev->bd_contains when it is not stable btrfs: limit async_work allocation and worker func duration mm/vmscan.c: set correct defer count for shrinker Input: drv260x - fix input device's parent assignment ...
2017-01-12fs: exec: apply CLOEXEC before changing dumpable task flagsAleksa Sarai
[ Upstream commit 613cc2b6f272c1a8ad33aefa21cad77af23139f7 ] If you have a process that has set itself to be non-dumpable, and it then undergoes exec(2), any CLOEXEC file descriptors it has open are "exposed" during a race window between the dumpable flags of the process being reset for exec(2) and CLOEXEC being applied to the file descriptors. This can be exploited by a process by attempting to access /proc/<pid>/fd/... during this window, without requiring CAP_SYS_PTRACE. The race in question is after set_dumpable has been (for get_link, though the trace is basically the same for readlink): [vfs] -> proc_pid_link_inode_operations.get_link -> proc_pid_get_link -> proc_fd_access_allowed -> ptrace_may_access(task, PTRACE_MODE_READ_FSCREDS); Which will return 0, during the race window and CLOEXEC file descriptors will still be open during this window because do_close_on_exec has not been called yet. As a result, the ordering of these calls should be reversed to avoid this race window. This is of particular concern to container runtimes, where joining a PID namespace with file descriptors referring to the host filesystem can result in security issues (since PRCTL_SET_DUMPABLE doesn't protect against access of CLOEXEC file descriptors -- file descriptors which may reference filesystem objects the container shouldn't have access to). Cc: dev@opencontainers.org Cc: <stable@vger.kernel.org> # v3.2+ Reported-by: Michael Crosby <crosbymichael@gmail.com> Signed-off-by: Aleksa Sarai <asarai@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12block_dev: don't test bdev->bd_contains when it is not stableNeilBrown
[ Upstream commit bcc7f5b4bee8e327689a4d994022765855c807ff ] bdev->bd_contains is not stable before calling __blkdev_get(). When __blkdev_get() is called on a parition with ->bd_openers == 0 it sets bdev->bd_contains = bdev; which is not correct for a partition. After a call to __blkdev_get() succeeds, ->bd_openers will be > 0 and then ->bd_contains is stable. When FMODE_EXCL is used, blkdev_get() calls bd_start_claiming() -> bd_prepare_to_claim() -> bd_may_claim() This call happens before __blkdev_get() is called, so ->bd_contains is not stable. So bd_may_claim() cannot safely use ->bd_contains. It currently tries to use it, and this can lead to a BUG_ON(). This happens when a whole device is already open with a bd_holder (in use by dm in my particular example) and two threads race to open a partition of that device for the first time, one opening with O_EXCL and one without. The thread that doesn't use O_EXCL gets through blkdev_get() to __blkdev_get(), gains the ->bd_mutex, and sets bdev->bd_contains = bdev; Immediately thereafter the other thread, using FMODE_EXCL, calls bd_start_claiming() from blkdev_get(). This should fail because the whole device has a holder, but because bdev->bd_contains == bdev bd_may_claim() incorrectly reports success. This thread continues and blocks on bd_mutex. The first thread then sets bdev->bd_contains correctly and drops the mutex. The thread using FMODE_EXCL then continues and when it calls bd_may_claim() again in: BUG_ON(!bd_may_claim(bdev, whole, holder)); The BUG_ON fires. Fix this by removing the dependency on ->bd_contains in bd_may_claim(). As bd_may_claim() has direct access to the whole device, it can simply test if the target bdev is the whole device. Fixes: 6b4517a7913a ("block: implement bd_claiming and claiming block") Cc: stable@vger.kernel.org (v2.6.35+) Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12btrfs: limit async_work allocation and worker func durationMaxim Patlasov
[ Upstream commit 2939e1a86f758b55cdba73e29397dd3d94df13bc ] Problem statement: unprivileged user who has read-write access to more than one btrfs subvolume may easily consume all kernel memory (eventually triggering oom-killer). Reproducer (./mkrmdir below essentially loops over mkdir/rmdir): [root@kteam1 ~]# cat prep.sh DEV=/dev/sdb mkfs.btrfs -f $DEV mount $DEV /mnt for i in `seq 1 16` do mkdir /mnt/$i btrfs subvolume create /mnt/SV_$i ID=`btrfs subvolume list /mnt |grep "SV_$i$" |cut -d ' ' -f 2` mount -t btrfs -o subvolid=$ID $DEV /mnt/$i chmod a+rwx /mnt/$i done [root@kteam1 ~]# sh prep.sh [maxim@kteam1 ~]$ for i in `seq 1 16`; do ./mkrmdir /mnt/$i 2000 2000 & done [root@kteam1 ~]# for i in `seq 1 4`; do grep "kmalloc-128" /proc/slabinfo | grep -v dma; sleep 60; done kmalloc-128 10144 10144 128 32 1 : tunables 0 0 0 : slabdata 317 317 0 kmalloc-128 9992352 9992352 128 32 1 : tunables 0 0 0 : slabdata 312261 312261 0 kmalloc-128 24226752 24226752 128 32 1 : tunables 0 0 0 : slabdata 757086 757086 0 kmalloc-128 42754240 42754240 128 32 1 : tunables 0 0 0 : slabdata 1336070 1336070 0 The huge numbers above come from insane number of async_work-s allocated and queued by btrfs_wq_run_delayed_node. The problem is caused by btrfs_wq_run_delayed_node() queuing more and more works if the number of delayed items is above BTRFS_DELAYED_BACKGROUND. The worker func (btrfs_async_run_delayed_root) processes at least BTRFS_DELAYED_BATCH items (if they are present in the list). So, the machinery works as expected while the list is almost empty. As soon as it is getting bigger, worker func starts to process more than one item at a time, it takes longer, and the chances to have async_works queued more than needed is getting higher. The problem above is worsened by another flaw of delayed-inode implementation: if async_work was queued in a throttling branch (number of items >= BTRFS_DELAYED_WRITEBACK), corresponding worker func won't quit until the number of items < BTRFS_DELAYED_BACKGROUND / 2. So, it is possible that the func occupies CPU infinitely (up to 30sec in my experiments): while the func is trying to drain the list, the user activity may add more and more items to the list. The patch fixes both problems in straightforward way: refuse queuing too many works in btrfs_wq_run_delayed_node and bail out of worker func if at least BTRFS_DELAYED_WRITEBACK items are processed. Changed in v2: remove support of thresh == NO_THRESHOLD. Signed-off-by: Maxim Patlasov <mpatlasov@virtuozzo.com> Signed-off-by: Chris Mason <clm@fb.com> Cc: stable@vger.kernel.org # v3.15+ Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12ext4: return -ENOMEM instead of successDan Carpenter
[ Upstream commit 578620f451f836389424833f1454eeeb2ffc9e9f ] We should set the error code if kzalloc() fails. Fixes: 67cf5b09a46f ("ext4: add the basic function for inline data support") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12nfs_write_end(): fix handling of short copiesAl Viro
[ Upstream commit c0cf3ef5e0f47e385920450b245d22bead93e7ad ] What matters when deciding if we should make a page uptodate is not how much we _wanted_ to copy, but how much we actually have copied. As it is, on architectures that do not zero tail on short copy we can leave uninitialized data in page marked uptodate. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12CIFS: Fix a possible memory corruption during reconnectPavel Shilovsky
[ Upstream commit 53e0e11efe9289535b060a51d4cf37c25e0d0f2b ] We can not unlock/lock cifs_tcp_ses_lock while walking through ses and tcon lists because it can corrupt list iterator pointers and a tcon structure can be released if we don't hold an extra reference. Fix it by moving a reconnect process to a separate delayed work and acquiring a reference to every tcon that needs to be reconnected. Also do not send an echo request on newly established connections. CC: Stable <stable@vger.kernel.org> Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12CIFS: Fix a possible memory corruption in push locksPavel Shilovsky
[ Upstream commit e3d240e9d505fc67f8f8735836df97a794bbd946 ] If maxBuf is not 0 but less than a size of SMB2 lock structure we can end up with a memory corruption. Cc: Stable <stable@vger.kernel.org> Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12CIFS: Fix missing nls unload in smb2_reconnect()Pavel Shilovsky
[ Upstream commit 4772c79599564bd08ee6682715a7d3516f67433f ] Cc: Stable <stable@vger.kernel.org> Acked-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12xfs: set AGI buffer type in xlog_recover_clear_agi_bucketEric Sandeen
[ Upstream commit 6b10b23ca94451fae153a5cc8d62fd721bec2019 ] xlog_recover_clear_agi_bucket didn't set the type to XFS_BLFT_AGI_BUF, so we got a warning during log replay (or an ASSERT on a debug build). XFS (md0): Unknown buffer type 0! XFS (md0): _xfs_buf_ioapply: no ops on block 0xaea8802/0x1 Fix this, as was done in f19b872b for 2 other locations with the same problem. cc: <stable@vger.kernel.org> # 3.10 to current Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12block: protect iterate_bdevs() against concurrent closeRabin Vincent
[ Upstream commit af309226db916e2c6e08d3eba3fa5c34225200c4 ] If a block device is closed while iterate_bdevs() is handling it, the following NULL pointer dereference occurs because bdev->b_disk is NULL in bdev_get_queue(), which is called from blk_get_backing_dev_info() (in turn called by the mapping_cap_writeback_dirty() call in __filemap_fdatawrite_range()): BUG: unable to handle kernel NULL pointer dereference at 0000000000000508 IP: [<ffffffff81314790>] blk_get_backing_dev_info+0x10/0x20 PGD 9e62067 PUD 9ee8067 PMD 0 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 1 PID: 2422 Comm: sync Not tainted 4.5.0-rc7+ #400 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996) task: ffff880009f4d700 ti: ffff880009f5c000 task.ti: ffff880009f5c000 RIP: 0010:[<ffffffff81314790>] [<ffffffff81314790>] blk_get_backing_dev_info+0x10/0x20 RSP: 0018:ffff880009f5fe68 EFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff88000ec17a38 RCX: ffffffff81a4e940 RDX: 7fffffffffffffff RSI: 0000000000000000 RDI: ffff88000ec176c0 RBP: ffff880009f5fe68 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffff88000ec17860 R13: ffffffff811b25c0 R14: ffff88000ec178e0 R15: ffff88000ec17a38 FS: 00007faee505d700(0000) GS:ffff88000fb00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000508 CR3: 0000000009e8a000 CR4: 00000000000006e0 Stack: ffff880009f5feb8 ffffffff8112e7f5 0000000000000000 7fffffffffffffff 0000000000000000 0000000000000000 7fffffffffffffff 0000000000000001 ffff88000ec178e0 ffff88000ec17860 ffff880009f5fec8 ffffffff8112e81f Call Trace: [<ffffffff8112e7f5>] __filemap_fdatawrite_range+0x85/0x90 [<ffffffff8112e81f>] filemap_fdatawrite+0x1f/0x30 [<ffffffff811b25d6>] fdatawrite_one_bdev+0x16/0x20 [<ffffffff811bc402>] iterate_bdevs+0xf2/0x130 [<ffffffff811b2763>] sys_sync+0x63/0x90 [<ffffffff815d4272>] entry_SYSCALL_64_fastpath+0x12/0x76 Code: 0f 1f 44 00 00 48 8b 87 f0 00 00 00 55 48 89 e5 <48> 8b 80 08 05 00 00 5d RIP [<ffffffff81314790>] blk_get_backing_dev_info+0x10/0x20 RSP <ffff880009f5fe68> CR2: 0000000000000508 ---[ end trace 2487336ceb3de62d ]--- The crash is easily reproducible by running the following command, if an msleep(100) is inserted before the call to func() in iterate_devs(): while :; do head -c1 /dev/nullb0; done > /dev/null & while :; do sync; done Fix it by holding the bd_mutex across the func() call and only calling func() if the bdev is opened. Cc: stable@vger.kernel.org Fixes: 5c0d6b60a0ba ("vfs: Create function for iterating over block devices") Reported-and-tested-by: Wei Fang <fangwei1@huawei.com> Signed-off-by: Rabin Vincent <rabinv@axis.com> Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12Btrfs: fix tree search logic when replaying directory entry deletesRobbie Ko
[ Upstream commit 2a7bf53f577e49c43de4ffa7776056de26db65d9 ] If a log tree has a layout like the following: leaf N: ... item 240 key (282 DIR_LOG_ITEM 0) itemoff 8189 itemsize 8 dir log end 1275809046 leaf N + 1: item 0 key (282 DIR_LOG_ITEM 3936149215) itemoff 16275 itemsize 8 dir log end 18446744073709551615 ... When we pass the value 1275809046 + 1 as the parameter start_ret to the function tree-log.c:find_dir_range() (done by replay_dir_deletes()), we end up with path->slots[0] having the value 239 (points to the last item of leaf N, item 240). Because the dir log item in that position has an offset value smaller than *start_ret (1275809046 + 1) we need to move on to the next leaf, however the logic for that is wrong since it compares the current slot to the number of items in the leaf, which is smaller and therefore we don't lookup for the next leaf but instead we set the slot to point to an item that does not exist, at slot 240, and we later operate on that slot which has unexpected content or in the worst case can result in an invalid memory access (accessing beyond the last page of leaf N's extent buffer). So fix the logic that checks when we need to lookup at the next leaf by first incrementing the slot and only after to check if that slot is beyond the last item of the current leaf. Signed-off-by: Robbie Ko <robbieko@synology.com> Reviewed-by: Filipe Manana <fdmanana@suse.com> Fixes: e02119d5a7b4 (Btrfs: Add a write ahead tree log to optimize synchronous operations) Cc: stable@vger.kernel.org # 2.6.29+ Signed-off-by: Filipe Manana <fdmanana@suse.com> [Modified changelog for clarity and correctness] Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12Btrfs: fix deadlock caused by fsync when logging directory entriesRobbie Ko
[ Upstream commit ec125cfb7ae2157af3dd45dd8abe823e3e233eec ] While logging new directory entries, at tree-log.c:log_new_dir_dentries(), after we call btrfs_search_forward() we get a leaf with a read lock on it, and without unlocking that leaf we can end up calling btrfs_iget() to get an inode pointer. The later (btrfs_iget()) can end up doing a read-only search on the same tree again, if the inode is not in memory already, which ends up causing a deadlock if some other task in the meanwhile started a write search on the tree and is attempting to write lock the same leaf that btrfs_search_forward() locked while holding write locks on upper levels of the tree blocking the read search from btrfs_iget(). In this scenario we get a deadlock. So fix this by releasing the search path before calling btrfs_iget() at tree-log.c:log_new_dir_dentries(). Example trace of such deadlock: [ 4077.478852] kworker/u24:10 D ffff88107fc90640 0 14431 2 0x00000000 [ 4077.486752] Workqueue: btrfs-endio-write btrfs_endio_write_helper [btrfs] [ 4077.494346] ffff880ffa56bad0 0000000000000046 0000000000009000 ffff880ffa56bfd8 [ 4077.502629] ffff880ffa56bfd8 ffff881016ce21c0 ffffffffa06ecb26 ffff88101a5d6138 [ 4077.510915] ffff880ebb5173b0 ffff880ffa56baf8 ffff880ebb517410 ffff881016ce21c0 [ 4077.519202] Call Trace: [ 4077.528752] [<ffffffffa06ed5ed>] ? btrfs_tree_lock+0xdd/0x2f0 [btrfs] [ 4077.536049] [<ffffffff81053680>] ? wake_up_atomic_t+0x30/0x30 [ 4077.542574] [<ffffffffa068cc1f>] ? btrfs_search_slot+0x79f/0xb10 [btrfs] [ 4077.550171] [<ffffffffa06a5073>] ? btrfs_lookup_file_extent+0x33/0x40 [btrfs] [ 4077.558252] [<ffffffffa06c600b>] ? __btrfs_drop_extents+0x13b/0xdf0 [btrfs] [ 4077.566140] [<ffffffffa06fc9e2>] ? add_delayed_data_ref+0xe2/0x150 [btrfs] [ 4077.573928] [<ffffffffa06fd629>] ? btrfs_add_delayed_data_ref+0x149/0x1d0 [btrfs] [ 4077.582399] [<ffffffffa06cf3c0>] ? __set_extent_bit+0x4c0/0x5c0 [btrfs] [ 4077.589896] [<ffffffffa06b4a64>] ? insert_reserved_file_extent.constprop.75+0xa4/0x320 [btrfs] [ 4077.599632] [<ffffffffa06b206d>] ? start_transaction+0x8d/0x470 [btrfs] [ 4077.607134] [<ffffffffa06bab57>] ? btrfs_finish_ordered_io+0x2e7/0x600 [btrfs] [ 4077.615329] [<ffffffff8104cbc2>] ? process_one_work+0x142/0x3d0 [ 4077.622043] [<ffffffff8104d729>] ? worker_thread+0x109/0x3b0 [ 4077.628459] [<ffffffff8104d620>] ? manage_workers.isra.26+0x270/0x270 [ 4077.635759] [<ffffffff81052b0f>] ? kthread+0xaf/0xc0 [ 4077.641404] [<ffffffff81052a60>] ? kthread_create_on_node+0x110/0x110 [ 4077.648696] [<ffffffff814a9ac8>] ? ret_from_fork+0x58/0x90 [ 4077.654926] [<ffffffff81052a60>] ? kthread_create_on_node+0x110/0x110 [ 4078.358087] kworker/u24:15 D ffff88107fcd0640 0 14436 2 0x00000000 [ 4078.365981] Workqueue: btrfs-endio-write btrfs_endio_write_helper [btrfs] [ 4078.373574] ffff880ffa57fad0 0000000000000046 0000000000009000 ffff880ffa57ffd8 [ 4078.381864] ffff880ffa57ffd8 ffff88103004d0a0 ffffffffa06ecb26 ffff88101a5d6138 [ 4078.390163] ffff880fbeffc298 ffff880ffa57faf8 ffff880fbeffc2f8 ffff88103004d0a0 [ 4078.398466] Call Trace: [ 4078.408019] [<ffffffffa06ed5ed>] ? btrfs_tree_lock+0xdd/0x2f0 [btrfs] [ 4078.415322] [<ffffffff81053680>] ? wake_up_atomic_t+0x30/0x30 [ 4078.421844] [<ffffffffa068cc1f>] ? btrfs_search_slot+0x79f/0xb10 [btrfs] [ 4078.429438] [<ffffffffa06a5073>] ? btrfs_lookup_file_extent+0x33/0x40 [btrfs] [ 4078.437518] [<ffffffffa06c600b>] ? __btrfs_drop_extents+0x13b/0xdf0 [btrfs] [ 4078.445404] [<ffffffffa06fc9e2>] ? add_delayed_data_ref+0xe2/0x150 [btrfs] [ 4078.453194] [<ffffffffa06fd629>] ? btrfs_add_delayed_data_ref+0x149/0x1d0 [btrfs] [ 4078.461663] [<ffffffffa06cf3c0>] ? __set_extent_bit+0x4c0/0x5c0 [btrfs] [ 4078.469161] [<ffffffffa06b4a64>] ? insert_reserved_file_extent.constprop.75+0xa4/0x320 [btrfs] [ 4078.478893] [<ffffffffa06b206d>] ? start_transaction+0x8d/0x470 [btrfs] [ 4078.486388] [<ffffffffa06bab57>] ? btrfs_finish_ordered_io+0x2e7/0x600 [btrfs] [ 4078.494561] [<ffffffff8104cbc2>] ? process_one_work+0x142/0x3d0 [ 4078.501278] [<ffffffff8104a507>] ? pwq_activate_delayed_work+0x27/0x40 [ 4078.508673] [<ffffffff8104d729>] ? worker_thread+0x109/0x3b0 [ 4078.515098] [<ffffffff8104d620>] ? manage_workers.isra.26+0x270/0x270 [ 4078.522396] [<ffffffff81052b0f>] ? kthread+0xaf/0xc0 [ 4078.528032] [<ffffffff81052a60>] ? kthread_create_on_node+0x110/0x110 [ 4078.535325] [<ffffffff814a9ac8>] ? ret_from_fork+0x58/0x90 [ 4078.541552] [<ffffffff81052a60>] ? kthread_create_on_node+0x110/0x110 [ 4079.355824] user-space-program D ffff88107fd30640 0 32020 1 0x00000000 [ 4079.363716] ffff880eae8eba10 0000000000000086 0000000000009000 ffff880eae8ebfd8 [ 4079.372003] ffff880eae8ebfd8 ffff881016c162c0 ffffffffa06ecb26 ffff88101a5d6138 [ 4079.380294] ffff880fbed4b4c8 ffff880eae8eba38 ffff880fbed4b528 ffff881016c162c0 [ 4079.388586] Call Trace: [ 4079.398134] [<ffffffffa06ed595>] ? btrfs_tree_lock+0x85/0x2f0 [btrfs] [ 4079.405431] [<ffffffff81053680>] ? wake_up_atomic_t+0x30/0x30 [ 4079.411955] [<ffffffffa06876fb>] ? btrfs_lock_root_node+0x2b/0x40 [btrfs] [ 4079.419644] [<ffffffffa068ce83>] ? btrfs_search_slot+0xa03/0xb10 [btrfs] [ 4079.427237] [<ffffffffa06aba52>] ? btrfs_buffer_uptodate+0x52/0x70 [btrfs] [ 4079.435041] [<ffffffffa0689b60>] ? generic_bin_search.constprop.38+0x80/0x190 [btrfs] [ 4079.443897] [<ffffffffa068ea44>] ? btrfs_insert_empty_items+0x74/0xd0 [btrfs] [ 4079.451975] [<ffffffffa072c443>] ? copy_items+0x128/0x850 [btrfs] [ 4079.458890] [<ffffffffa072da10>] ? btrfs_log_inode+0x629/0xbf3 [btrfs] [ 4079.466292] [<ffffffffa06f34a1>] ? btrfs_log_inode_parent+0xc61/0xf30 [btrfs] [ 4079.474373] [<ffffffffa06f45a9>] ? btrfs_log_dentry_safe+0x59/0x80 [btrfs] [ 4079.482161] [<ffffffffa06c298d>] ? btrfs_sync_file+0x20d/0x330 [btrfs] [ 4079.489558] [<ffffffff8112777c>] ? do_fsync+0x4c/0x80 [ 4079.495300] [<ffffffff81127a0a>] ? SyS_fdatasync+0xa/0x10 [ 4079.501422] [<ffffffff814a9b72>] ? system_call_fastpath+0x16/0x1b [ 4079.508334] user-space-program D ffff88107fc30640 0 32021 1 0x00000004 [ 4079.516226] ffff880eae8efbf8 0000000000000086 0000000000009000 ffff880eae8effd8 [ 4079.524513] ffff880eae8effd8 ffff881030279610 ffffffffa06ecb26 ffff88101a5d6138 [ 4079.532802] ffff880ebb671d88 ffff880eae8efc20 ffff880ebb671de8 ffff881030279610 [ 4079.541092] Call Trace: [ 4079.550642] [<ffffffffa06ed595>] ? btrfs_tree_lock+0x85/0x2f0 [btrfs] [ 4079.557941] [<ffffffff81053680>] ? wake_up_atomic_t+0x30/0x30 [ 4079.564463] [<ffffffffa068cc1f>] ? btrfs_search_slot+0x79f/0xb10 [btrfs] [ 4079.572058] [<ffffffffa06bb7d8>] ? btrfs_truncate_inode_items+0x168/0xb90 [btrfs] [ 4079.580526] [<ffffffffa06b04be>] ? join_transaction.isra.15+0x1e/0x3a0 [btrfs] [ 4079.588701] [<ffffffffa06b206d>] ? start_transaction+0x8d/0x470 [btrfs] [ 4079.596196] [<ffffffffa0690ac6>] ? block_rsv_add_bytes+0x16/0x50 [btrfs] [ 4079.603789] [<ffffffffa06bc2e9>] ? btrfs_truncate+0xe9/0x2e0 [btrfs] [ 4079.610994] [<ffffffffa06bd00b>] ? btrfs_setattr+0x30b/0x410 [btrfs] [ 4079.618197] [<ffffffff81117c1c>] ? notify_change+0x1dc/0x680 [ 4079.624625] [<ffffffff8123c8a4>] ? aa_path_perm+0xd4/0x160 [ 4079.630854] [<ffffffff810f4fcb>] ? do_truncate+0x5b/0x90 [ 4079.636889] [<ffffffff810f59fa>] ? do_sys_ftruncate.constprop.15+0x10a/0x160 [ 4079.644869] [<ffffffff8110d87b>] ? SyS_fcntl+0x5b/0x570 [ 4079.650805] [<ffffffff814a9b72>] ? system_call_fastpath+0x16/0x1b [ 4080.410607] user-space-program D ffff88107fc70640 0 32028 12639 0x00000004 [ 4080.418489] ffff880eaeccbbe0 0000000000000086 0000000000009000 ffff880eaeccbfd8 [ 4080.426778] ffff880eaeccbfd8 ffff880f317ef1e0 ffffffffa06ecb26 ffff88101a5d6138 [ 4080.435067] ffff880ef7e93928 ffff880f317ef1e0 ffff880eaeccbc08 ffff880f317ef1e0 [ 4080.443353] Call Trace: [ 4080.452920] [<ffffffffa06ed15d>] ? btrfs_tree_read_lock+0xdd/0x190 [btrfs] [ 4080.460703] [<ffffffff81053680>] ? wake_up_atomic_t+0x30/0x30 [ 4080.467225] [<ffffffffa06876bb>] ? btrfs_read_lock_root_node+0x2b/0x40 [btrfs] [ 4080.475400] [<ffffffffa068cc81>] ? btrfs_search_slot+0x801/0xb10 [btrfs] [ 4080.482994] [<ffffffffa06b2df0>] ? btrfs_clean_one_deleted_snapshot+0xe0/0xe0 [btrfs] [ 4080.491857] [<ffffffffa06a70a6>] ? btrfs_lookup_inode+0x26/0x90 [btrfs] [ 4080.499353] [<ffffffff810ec42f>] ? kmem_cache_alloc+0xaf/0xc0 [ 4080.505879] [<ffffffffa06bd905>] ? btrfs_iget+0xd5/0x5d0 [btrfs] [ 4080.512696] [<ffffffffa06caf04>] ? btrfs_get_token_64+0x104/0x120 [btrfs] [ 4080.520387] [<ffffffffa06f341f>] ? btrfs_log_inode_parent+0xbdf/0xf30 [btrfs] [ 4080.528469] [<ffffffffa06f45a9>] ? btrfs_log_dentry_safe+0x59/0x80 [btrfs] [ 4080.536258] [<ffffffffa06c298d>] ? btrfs_sync_file+0x20d/0x330 [btrfs] [ 4080.543657] [<ffffffff8112777c>] ? do_fsync+0x4c/0x80 [ 4080.549399] [<ffffffff81127a0a>] ? SyS_fdatasync+0xa/0x10 [ 4080.555534] [<ffffffff814a9b72>] ? system_call_fastpath+0x16/0x1b Signed-off-by: Robbie Ko <robbieko@synology.com> Reviewed-by: Filipe Manana <fdmanana@suse.com> Fixes: 2f2ff0ee5e43 (Btrfs: fix metadata inconsistencies after directory fsync) Cc: stable@vger.kernel.org # 4.1+ Signed-off-by: Filipe Manana <fdmanana@suse.com> [Modified changelog for clarity and correctness] Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12f2fs: set ->owner for debugfs status file's file_operationsNicolai Stange
[ Upstream commit 05e6ea2685c964db1e675a24a4f4e2adc22d2388 ] The struct file_operations instance serving the f2fs/status debugfs file lacks an initialization of its ->owner. This means that although that file might have been opened, the f2fs module can still get removed. Any further operation on that opened file, releasing included, will cause accesses to unmapped memory. Indeed, Mike Marshall reported the following: BUG: unable to handle kernel paging request at ffffffffa0307430 IP: [<ffffffff8132a224>] full_proxy_release+0x24/0x90 <...> Call Trace: [] __fput+0xdf/0x1d0 [] ____fput+0xe/0x10 [] task_work_run+0x8e/0xc0 [] do_exit+0x2ae/0xae0 [] ? __audit_syscall_entry+0xae/0x100 [] ? syscall_trace_enter+0x1ca/0x310 [] do_group_exit+0x44/0xc0 [] SyS_exit_group+0x14/0x20 [] do_syscall_64+0x61/0x150 [] entry_SYSCALL64_slow_path+0x25/0x25 <...> ---[ end trace f22ae883fa3ea6b8 ]--- Fixing recursive fault but reboot is needed! Fix this by initializing the f2fs/status file_operations' ->owner with THIS_MODULE. This will allow debugfs to grab a reference to the f2fs module upon any open on that file, thus preventing it from getting removed. Fixes: 902829aa0b72 ("f2fs: move proc files to debugfs") Reported-by: Mike Marshall <hubcap@omnibond.com> Reported-by: Martin Brandenburg <martin@omnibond.com> Cc: stable@vger.kernel.org Signed-off-by: Nicolai Stange <nicstange@gmail.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12ext4: add sanity checking to count_overhead()Theodore Ts'o
[ Upstream commit c48ae41bafe31e9a66d8be2ced4e42a6b57fa814 ] The commit "ext4: sanity check the block and cluster size at mount time" should prevent any problems, but in case the superblock is modified while the file system is mounted, add an extra safety check to make sure we won't overrun the allocated buffer. Signed-off-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12ext4: use more strict checks for inodes_per_block on mountTheodore Ts'o
[ Upstream commit cd6bb35bf7f6d7d922509bf50265383a0ceabe96 ] Centralize the checks for inodes_per_block and be more strict to make sure the inodes_per_block_group can't end up being zero. Signed-off-by: Theodore Ts'o <tytso@mit.edu> Reviewed-by: Andreas Dilger <adilger@dilger.ca> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12ext4: sanity check the block and cluster size at mount timeTheodore Ts'o
[ Upstream commit 9e47a4c9fc58032ee135bf76516809c7624b1551 ] If the block size or cluster size is insane, reject the mount. This is important for security reasons (although we shouldn't be just depending on this check). Ref: http://www.securityfocus.com/archive/1/539661 Ref: https://bugzilla.redhat.com/show_bug.cgi?id=1332506 Reported-by: Borislav Petkov <bp@alien8.de> Reported-by: Nikolay Borisov <kernel@kyup.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12ext4: fix stack memory corruption with 64k block sizeChandan Rajendra
[ Upstream commit 30a9d7afe70ed6bd9191d3000e2ef1a34fb58493 ] The number of 'counters' elements needed in 'struct sg' is super_block->s_blocksize_bits + 2. Presently we have 16 'counters' elements in the array. This is insufficient for block sizes >= 32k. In such cases the memcpy operation performed in ext4_mb_seq_groups_show() would cause stack memory corruption. Fixes: c9de560ded61f Signed-off-by: Chandan Rajendra <chandan@linux.vnet.ibm.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Reviewed-by: Jan Kara <jack@suse.cz> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-01-12ext4: fix mballoc breakage with 64k block sizeChandan Rajendra
[ Upstream commit 69e43e8cc971a79dd1ee5d4343d8e63f82725123 ] 'border' variable is set to a value of 2 times the block size of the underlying filesystem. With 64k block size, the resulting value won't fit into a 16-bit variable. Hence this commit changes the data type of 'border' to 'unsigned int'. Fixes: c9de560ded61f Signed-off-by: Chandan Rajendra <chandan@linux.vnet.ibm.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Reviewed-by: Andreas Dilger <adilger@dilger.ca> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-23mnt: Add a per mount namespace limit on the number of mountsEric W. Biederman
[ Upstream commit d29216842a85c7970c536108e093963f02714498 ] CAI Qian <caiqian@redhat.com> pointed out that the semantics of shared subtrees make it possible to create an exponentially increasing number of mounts in a mount namespace. mkdir /tmp/1 /tmp/2 mount --make-rshared / for i in $(seq 1 20) ; do mount --bind /tmp/1 /tmp/2 ; done Will create create 2^20 or 1048576 mounts, which is a practical problem as some people have managed to hit this by accident. As such CVE-2016-6213 was assigned. Ian Kent <raven@themaw.net> described the situation for autofs users as follows: > The number of mounts for direct mount maps is usually not very large because of > the way they are implemented, large direct mount maps can have performance > problems. There can be anywhere from a few (likely case a few hundred) to less > than 10000, plus mounts that have been triggered and not yet expired. > > Indirect mounts have one autofs mount at the root plus the number of mounts that > have been triggered and not yet expired. > > The number of autofs indirect map entries can range from a few to the common > case of several thousand and in rare cases up to between 30000 and 50000. I've > not heard of people with maps larger than 50000 entries. > > The larger the number of map entries the greater the possibility for a large > number of active mounts so it's not hard to expect cases of a 1000 or somewhat > more active mounts. So I am setting the default number of mounts allowed per mount namespace at 100,000. This is more than enough for any use case I know of, but small enough to quickly stop an exponential increase in mounts. Which should be perfect to catch misconfigurations and malfunctioning programs. For anyone who needs a higher limit this can be changed by writing to the new /proc/sys/fs/mount-max sysctl. Tested-by: CAI Qian <caiqian@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Conflicts: fs/namespace.c kernel/sysctl.c Signed-off-by: Philipp Hahn <hahn@univention.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-23posix_acl: Clear SGID bit when setting file permissionsJan Kara
[ Upstream commit 073931017b49d9458aa351605b43a7e34598caef ] When file permissions are modified via chmod(2) and the user is not in the owning group or capable of CAP_FSETID, the setgid bit is cleared in inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file permissions as well as the new ACL, but doesn't clear the setgid bit in a similar way; this allows to bypass the check in chmod(2). Fix that. References: CVE-2016-7097 Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Philipp Hahn <hahn@univention.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-23fs: Avoid premature clearing of capabilitiesJan Kara
[ Upstream commit 030b533c4fd4d2ec3402363323de4bb2983c9cee ] Currently, notify_change() clears capabilities or IMA attributes by calling security_inode_killpriv() before calling into ->setattr. Thus it happens before any other permission checks in inode_change_ok() and user is thus allowed to trigger clearing of capabilities or IMA attributes for any file he can look up e.g. by calling chown for that file. This is unexpected and can lead to user DoSing a system. Fix the problem by calling security_inode_killpriv() at the end of inode_change_ok() instead of from notify_change(). At that moment we are sure user has permissions to do the requested change. References: CVE-2015-1350 Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Philipp Hahn <hahn@univention.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-23fs: Give dentry to inode_change_ok() instead of inodeJan Kara
[ Upstream commit 31051c85b5e2aaaf6315f74c72a732673632a905 ] inode_change_ok() will be resposible for clearing capabilities and IMA extended attributes and as such will need dentry. Give it as an argument to inode_change_ok() instead of an inode. Also rename inode_change_ok() to setattr_prepare() to better relect that it does also some modifications in addition to checks. References: CVE-2015-1350 Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Philipp Hahn <hahn@univention.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-23nfsd: Disable NFSv2 timestamp workaround for NFSv3+Andreas Gruenbacher
NFSv2 can set the atime and/or mtime of a file to specific timestamps but not to the server's current time. To implement the equivalent of utimes("file", NULL), it uses a heuristic. NFSv3 and later do support setting the atime and/or mtime to the server's current time directly. The NFSv2 heuristic is still enabled, and causes timestamps to be set wrong sometimes. Fix this by moving the heuristic into the NFSv2 specific code. We can leave it out of the create code path: the owner can always set timestamps arbitrarily, and the workaround would never trigger. References: CVE-2015-1350 Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Philipp Hahn <hahn@univention.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-23fuse: Propagate dentry down to inode_change_ok()Jan Kara
[ Upstream commit 62490330769c1ce5dcba3f1f3e8f4005e9b797e6 ] To avoid clearing of capabilities or security related extended attributes too early, inode_change_ok() will need to take dentry instead of inode. Propagate it down to fuse_do_setattr(). References: CVE-2015-1350 Acked-by: Miklos Szeredi <mszeredi@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Conflicts: Missing file_dentry() from d101a125954eae1d397adda94ca6319485a50493 Signed-off-by: Philipp Hahn <hahn@univention.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-23xfs: Propagate dentry down to inode_change_ok()Jan Kara
[ upstream commit 69bca80744eef58fa155e8042996b968fec17b26 ] To avoid clearing of capabilities or security related extended attributes too early, inode_change_ok() will need to take dentry instead of inode. Propagate dentry down to functions calling inode_change_ok(). This is rather straightforward except for xfs_set_mode() function which does not have dentry easily available. Luckily that function does not call inode_change_ok() anyway so we just have to do a little dance with function prototypes. References: CVE-2015-1350 Acked-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Conflicts: Missing file_dentry() from d101a125954eae1d397adda94ca6319485a50493 Signed-off-by: Philipp Hahn <hahn@univention.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-23xattr: Option to disable meta-data block cacheAndreas Dilger
mbcache provides absolutely no value for Lustre xattrs (because they are unique and cannot be shared between files) and as we can see it has a noticable overhead in some cases. In the past there was a CONFIG_MBCACHE option that would allow it to be disabled, but this was removed in newer kernels, so we will need to patch ldiskfs to fix this. References: <https://bugzilla.kernel.org/show_bug.cgi?id=107301> References: <https://git.hpdd.intel.com/fs/lustre-release.git/blob_plain/HEAD:/ldiskfs/kernel_patches/patches/rhel7/ext4-disable-mb-cache.patch> References: CVE-2015-8952 On 13.12.2016 at 15:58 Ben Hutchings wrote: > I decided not to apply this as it's a userland ABI extension that we > would then need to carry indefinitely. Signed-off-by: Philipp Hahn <hahn@univention.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-12-17Merge tag 'v4.1.36' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.36 * tag 'v4.1.36': (72 commits) Linux 4.1.36 kbuild: add -fno-PIE firewire: net: fix fragmented datagram_size off-by-one firewire: net: guard against rx buffer overflows parisc: Ensure consistent state when switching to kernel stack at syscall entry ovl: fsync after copy-up virtio: console: Unlock vqs while freeing buffers md: be careful not lot leak internal curr_resync value into metadata. -- (all) md: sync sync_completed has correct value as recovery finishes. scsi: arcmsr: Send SYNCHRONIZE_CACHE command to firmware scsi: scsi_debug: Fix memory leak if LBP enabled and module is unloaded drm/radeon/si_dpm: workaround for SI kickers drm/dp/mst: Check peer device type before attempting EDID read drm/dp/mst: add some defines for logical/physical ports drm/dp/mst: Clear port->pdt when tearing down the i2c adapter KVM: MIPS: Precalculate MMIO load resume PC KVM: MIPS: Make ERET handle ERL before EXL drm/radeon: drop register readback in cayman_cp_int_cntl_setup scsi: megaraid_sas: Fix data integrity failure for JBOD (passthrough) devices Revert "drm/radeon: fix DP link training issue with second 4K monitor" ...
2016-11-25ovl: fsync after copy-upMiklos Szeredi
[ Upstream commit 641089c1549d8d3df0b047b5de7e9a111362cdce ] Make sure the copied up file hits the disk before renaming to the final destination. If this is not done then the copy-up may corrupt the data in the file in case of a crash. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-11-25ubifs: Fix regression in ubifs_readdir()Richard Weinberger
[ Upstream commit a00052a296e54205cf238c75bd98d17d5d02a6db ] Commit c83ed4c9dbb35 ("ubifs: Abort readdir upon error") broke overlayfs support because the fix exposed an internal error code to VFS. Reported-by: Peter Rosin <peda@axentia.se> Tested-by: Peter Rosin <peda@axentia.se> Reported-by: Ralph Sennhauser <ralph.sennhauser@gmail.com> Tested-by: Ralph Sennhauser <ralph.sennhauser@gmail.com> Fixes: c83ed4c9dbb35 ("ubifs: Abort readdir upon error") Cc: stable@vger.kernel.org Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-11-23btrfs: fix races on root_log_ctx listsChris Mason
[ Upstream commit 570dd45042a7c8a7aba1ee029c5dd0f5ccf41b9b ] btrfs_remove_all_log_ctxs takes a shortcut where it avoids walking the list because it knows all of the waiters are patiently waiting for the commit to finish. But, there's a small race where btrfs_sync_log can remove itself from the list if it finds a log commit is already done. Also, it uses list_del_init() to remove itself from the list, but there's no way to know if btrfs_remove_all_log_ctxs has already run, so we don't know for sure if it is safe to call list_del_init(). This gets rid of all the shortcuts for btrfs_remove_all_log_ctxs(), and just calls it with the proper locking. This is part two of the corruption fixed by cbd60aa7cd1. I should have done this in the first place, but convinced myself the optimizations were safe. A 12 hour run of dbench 2048 will eventually trigger a list debug WARN_ON for the list_del_init() in btrfs_sync_log(). Fixes: d1433debe7f4346cf9fc0dafc71c3137d2a97bc4 Reported-by: Dave Jones <davej@codemonkey.org.uk> cc: stable@vger.kernel.org # 3.15+ Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-11-23libxfs: clean up _calc_dquots_per_chunkDarrick J. Wong
[ Upstream commit 58d789678546d46d7bbd809dd7dab417c0f23655 ] The function xfs_calc_dquots_per_chunk takes a parameter in units of basic blocks. The kernel seems to get the units wrong, but userspace got 'fixed' by commenting out the unnecessary conversion. Fix both. cc: <stable@vger.kernel.org> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-11-23ubifs: Abort readdir upon errorRichard Weinberger
[ Upstream commit c83ed4c9dbb358b9e7707486e167e940d48bfeed ] If UBIFS is facing an error while walking a directory, it reports this error and ubifs_readdir() returns the error code. But the VFS readdir logic does not make the getdents system call fail in all cases. When the readdir cursor indicates that more entries are present, the system call will just return and the libc wrapper will try again since it also knows that more entries are present. This causes the libc wrapper to busy loop for ever when a directory is corrupted on UBIFS. A common approach do deal with corrupted directory entries is skipping them by setting the cursor to the next entry. On UBIFS this approach is not possible since we cannot compute the next directory entry cursor position without reading the current entry. So all we can do is setting the cursor to the "no more entries" position and make getdents exit. Cc: stable@vger.kernel.org Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-11-23UBIFS: Fix possible memory leak in ubifs_readdir()Richard Weinberger
[ Upstream commit aeeb14f763917ccf639a602cfbeee6957fd944a2 ] If ubifs_tnc_next_ent() returns something else than -ENOENT we leak file->private_data. Signed-off-by: Richard Weinberger <richard@nod.at> Reviewed-by: David Gstir <david@sigma-star.at> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-11-23ubifs: Fix xattr_names length in exit pathsRichard Weinberger
[ Upstream commit 843741c5778398ea67055067f4cc65ae6c80ca0e ] When the operation fails we also have to undo the changes we made to ->xattr_names. Otherwise listxattr() will report wrong lengths. Cc: stable@vger.kernel.org Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-11-01isofs: Do not return EACCES for unknown filesystemsJan Kara
[ Upstream commit a2ed0b391dd9c3ef1d64c7c3e370f4a5ffcd324a ] When isofs_mount() is called to mount a device read-write, it returns EACCES even before it checks that the device actually contains an isofs filesystem. This may confuse mount(8) which then tries to mount all subsequent filesystem types in read-only mode. Fix the problem by returning EACCES only once we verify that the device indeed contains an iso9660 filesystem. CC: stable@vger.kernel.org Fixes: 17b7f7cf58926844e1dd40f5eb5348d481deca6a Reported-by: Kent Overstreet <kent.overstreet@gmail.com> Reported-by: Karel Zak <kzak@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-11-01ceph: fix error handling in ceph_read_iterNikolay Borisov
[ Upstream commit 0d7718f666be181fda1ba2d08f137d87c1419347 ] In case __ceph_do_getattr returns an error and the retry_op in ceph_read_iter is not READ_INLINE, then it's possible to invoke __free_page on a page which is NULL, this naturally leads to a crash. This can happen when, for example, a process waiting on a MDS reply receives sigterm. Fix this by explicitly checking whether the page is set or not. Cc: stable@vger.kernel.org # 3.19+ Signed-off-by: Nikolay Borisov <kernel@kyup.com> Reviewed-by: Yan, Zheng <zyan@redhat.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-11-01jbd2: fix incorrect unlock on j_list_lockTaesoo Kim
[ Upstream commit 559cce698eaf4ccecb2213b2519ea3a0413e5155 ] When 'jh->b_transaction == transaction' (asserted by below) J_ASSERT_JH(jh, (jh->b_transaction == transaction || ... 'journal->j_list_lock' will be incorrectly unlocked, since the the lock is aquired only at the end of if / else-if statements (missing the else case). Signed-off-by: Taesoo Kim <tsgatesv@gmail.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Reviewed-by: Andreas Dilger <adilger@dilger.ca> Fixes: 6e4862a5bb9d12be87e4ea5d9a60836ebed71d28 Cc: stable@vger.kernel.org # 3.14+ Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-10-26Merge tag 'v4.1.35' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.35 * tag 'v4.1.35': (98 commits) Linux 4.1.35 xhci: fix usb2 resume timing and races. mm: remove gup_flags FOLL_WRITE games from __get_user_pages() timekeeping: Fix __ktime_get_fast_ns() regression time: Add cycles to nanoseconds translation Linux 4.1.34 openrisc: fix the fix of copy_from_user() avr32: fix 'undefined reference to `___copy_from_user' fix memory leaks in tracing_buffers_splice_read() tracing: Move mutex to protect against resetting of seq data MIPS: SMP: Fix possibility of deadlock when bringing CPUs online MIPS: Fix pre-r6 emulation FPU initialisation btrfs: ensure that file descriptor used with subvol ioctls is a dir fix fault_in_multipages_...() on architectures with no-op access_ok() ocfs2: fix start offset to ocfs2_zero_range_for_truncate() fanotify: fix list corruption in fanotify_get_response() fsnotify: add a way to stop queueing events on group shutdown autofs: use dentry flags to block walks during expire autofs races ocfs2/dlm: fix race between convert and migration ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
