[ Upstream commit ae62ca7b03217be5e74759dc6d7698c95df498b3 ]
commit 35f9c09fe9c72e (tcp: tcp_sendpages() should call tcp_push() once)
added an internal flag : MSG_SENDPAGE_NOTLAST meant to be set on all
frags but the last one for a splice() call.
The condition used to set the flag in pipe_to_sendpage() relied on
splice() user passing the exact number of bytes present in the pipe,
or a smaller one.
But some programs pass an arbitrary high value, and the test fails.
The effect of this bug is a lack of tcp_push() at the end of a
splice(pipe -> socket) call, and possibly very slow or erratic TCP
sessions.
We should both test sd->total_len and fact that another fragment
is in the pipe (pipe->nrbufs > 1)
Many thanks to Willy for providing very clear bug report, bisection
and test programs.
Reported-by: Willy Tarreau <w@1wt.eu>
Bisected-by: Willy Tarreau <w@1wt.eu>
Tested-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Willy Tarreau <w@1wt.eu>
[ This combines upstream commit
2f53384424251c06038ae612e56231b96ab610ee and the follow-on bug fix
commit 35f9c09fe9c72eb8ca2b8e89a593e1c151f28fc2 ]
vmsplice()/splice(pipe, socket) call do_tcp_sendpages() one page at a
time, adding at most 4096 bytes to an skb. (assuming PAGE_SIZE=4096)
The call to tcp_push() at the end of do_tcp_sendpages() forces an
immediate xmit when pipe is not already filled, and tso_fragment() try
to split these skb to MSS multiples.
4096 bytes are usually split in a skb with 2 MSS, and a remaining
sub-mss skb (assuming MTU=1500)
This makes slow start suboptimal because many small frames are sent to
qdisc/driver layers instead of big ones (constrained by cwnd and packets
in flight of course)
In fact, applications using sendmsg() (adding an additional memory copy)
instead of vmsplice()/splice()/sendfile() are a bit faster because of
this anomaly, especially if serving small files in environments with
large initial [c]wnd.
Call tcp_push() only if MSG_MORE is not set in the flags parameter.
This bit is automatically provided by splice() internals but for the
last page, or on all pages if user specified SPLICE_F_MORE splice()
flag.
In some workloads, this can reduce number of sent logical packets by an
order of magnitude, making zero-copy TCP actually faster than
one-copy :)
Reported-by: Tom Herbert <therbert@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: H.K. Jerry Chu <hkchu@google.com>
Cc: Maciej Żenczykowski <maze@google.com>
Cc: Mahesh Bandewar <maheshb@google.com>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
commit 43da5f2e0d0c69ded3d51907d9552310a6b545e8 upstream.
The implementation of dev_ifconf() for the compat ioctl interface uses
an intermediate ifc structure allocated in userland for the duration of
the syscall. Though, it fails to initialize the padding bytes inserted
for alignment and that for leaks four bytes of kernel stack. Add an
explicit memset(0) before filling the structure to avoid the info leak.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
[bwh: Backported to 2.6.32: adjust filename, context]
commit d5f50b0c290431c65377c4afa1c764e2c3fe5305 upstream.
If the argument and reply together exceed the maximum payload size, then
a reply with a read-like operation can overlow the rq_pages array.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit bc178622d40d87e75abc131007342429c9b03351 upstream.
Doing this would reliably fail with -EBUSY for me:
# mount /dev/sdb2 /mnt/scratch; umount /mnt/scratch; mkfs.btrfs -f /dev/sdb2
unable to open /dev/sdb2: Device or resource busy
because mkfs.btrfs tries to open the device O_EXCL, and somebody still has it.
Using systemtap to track bdev gets & puts shows a kworker thread doing a
blkdev put after mkfs attempts a get; this is left over from the unmount
path:
btrfs_close_devices
__btrfs_close_devices
call_rcu(&device->rcu, free_device);
free_device
INIT_WORK(&device->rcu_work, __free_device);
schedule_work(&device->rcu_work);
so unmount might complete before __free_device fires & does its blkdev_put.
Adding an rcu_barrier() to btrfs_close_devices() causes unmount to wait
until all blkdev_put()s are done, and the device is truly free once
unmount completes.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
commit 12f267a20aecf8b84a2a9069b9011f1661c779b4 upstream.
Change a u32 to loff_t hfsplus_file_truncate().
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
commit 0720a06a7518c9d0c0125bd5d1f3b6264c55c3dd upstream.
The utf8s_to_utf16s conversion routine needs to be improved. Unlike
its utf16s_to_utf8s sibling, it doesn't accept arguments specifying
the maximum length of the output buffer or the endianness of its
16-bit output.
This patch (as1501) adds the two missing arguments, and adjusts the
only two places in the kernel where the function is called. A
follow-on patch will add a third caller that does utilize the new
capabilities.
The two conversion routines are still annoyingly inconsistent in the
way they handle invalid byte combinations. But that's a subject for a
different patch.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Clemens Ladisch <clemens@ladisch.de>
[bwh: Bakckported to 2.6.32: drop Hyper-V change]
commit eeb5b4ae81f4a750355fa0c15f4fea22fdf83be1 upstream.
I found that the length of a file name when created cannot exceed 255
characters, yet, pathconf(), via statfs(), returns the maximum as 260.
Signed-off-by: Kevin Dankwardt <k@kcomputing.com>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
commit fe685aabf7c8c9f138e5ea900954d295bf229175 upstream.
For type 1 the parent_offset member in struct isofs_fid gets copied
uninitialized to userland. Fix this by initializing it to 0.
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 10b8c7dff5d3633b69e77f57d404dab54ead3787 upstream.
When it goes to error through line 144, the memory allocated to *devname is
not freed, and the caller doesn't free it either in line 250. So we free the
memroy of *devname in function cifs_compose_mount_options() when it goes to
error.
Signed-off-by: Cong Ding <dinggnu@gmail.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 89b1f39eb4189de745fae554b0d614d87c8d5c63 upstream.
For large UDF filesystems with 512-byte blocks the number of necessary
bitmap blocks is larger than 2^16 so s_nr_groups in udf_bitmap overflows
(the number will overflow for filesystems larger than 128 GB with
512-byte blocks). That results in ENOSPC errors despite the filesystem
has plenty of free space.
Fix the problem by changing s_nr_groups' type to 'int'. That is enough
even for filesystems 2^32 blocks (UDF maximum) and 512-byte blocksize.
Reported-and-tested-by: v10lator@myway.de
Cc: Jim Trigg <jtrigg@spamcop.net>
commit 0143fc5e9f6f5aad4764801015bc8d4b4a278200 upstream.
For type 0x51 the udf.parent_partref member in struct fid gets copied
commit 2fb7d99d0de3fd8ae869f35ab682581d8455887a upstream.
Need to brelse the buffer_head stored in cur_epos and next_epos.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Ashish Sangwan <a.sangwan@samsung.com>
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
commit 0e9a9a1ad619e7e987815d20262d36a2f95717ca upstream.
When trying to mount a file system which does not contain a journal,
but which does have a orphan list containing an inode which needs to
be truncated, the mount call with hang forever in
ext4_orphan_cleanup() because ext4_orphan_del() will return
immediately without removing the inode from the orphan list, leading
to an uninterruptible loop in kernel code which will busy out one of
the CPU's on the system.
This can be trivially reproduced by trying to mount the file system
found in tests/f_orphan_extents_inode/image.gz from the e2fsprogs
source tree. If a malicious user were to put this on a USB stick, and
mount it on a Linux desktop which has automatic mounts enabled, this
could be considered a potential denial of service attack. (Not a big
deal in practice, but professional paranoids worry about such things,
and have even been known to allocate CVE numbers for such problems.)
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
Cc: stable@vger.kernel.org
commit c9b92530a723ac5ef8e352885a1862b18f31b2f5 upstream.
Instead of checking whether the handle is valid, we check if journal
is enabled. This avoids taking the s_orphan_lock mutex in all cases
when there is no journal in use, including the error paths where
ext4_orphan_del() is called with a handle set to NULL.
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
CVE-2012-4508 kernel: ext4: AIO vs fallocate stale data exposure
[dannf: backported to Debian's 2.6.32]
According to Ben :
> The original upstream commits were c278531d39f3158bfee93dc67da0b77e09776de2,
> 60d4616f3dc63371b3dc367e5e88fd4b4f037f65 and (most importantly)
> dee1f973ca341c266229faa5a1a5bb268bed3531 by Dmitry Monakhov
> <dmonakhov@openvz.org>. They were backported into the RHEL 6 kernel by
> Lukas Czerner, according to its changelog. Dann got this version from
> Oracle's redpatch repository, where, if I understand rightly, Jamie Iles
> attempted to regenerate Lukas's patch(es).
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
commit e6155736ad76b2070652745f9e54cdea3f0d8567 upstream.
In the case where we are allocating for a non-extent file,
we must limit the groups we allocate from to those below
2^32 blocks, and ext4_mb_regular_allocator() attempts to
do this initially by putting a cap on ngroups for the
subsequent search loop.
However, the initial target group comes in from the
allocation context (ac), and it may already be beyond
the artificially limited ngroups. In this case,
the limit
if (group == ngroups)
group = 0;
at the top of the loop is never true, and the loop will
run away.
Catch this case inside the loop and reset the search to
start at group 0.
[sandeen@redhat.com: add commit msg & comments]
Signed-off-by: Lachlan McIlroy <lmcilroy@redhat.com>
commit f1167009711032b0d747ec89a632a626c901a1ad upstream.
In ext4_mb_add_n_trim(), lg_prealloc_lock should be taken when
changing the lg_prealloc_list.
Signed-off-by: Niu Yawei <yawei.niu@intel.com>
commit 721e3eba21e43532e438652dd8f1fcdfce3187e7 upstream.
Commit c278531d39 added a warning when ext4_flush_unwritten_io() is
called without i_mutex being taken. It had previously not been taken
during orphan cleanup since races weren't possible at that point in
the mount process, but as a result of this c278531d39, we will now see
a kernel WARN_ON in this case. Take the i_mutex in
ext4_orphan_cleanup() to suppress this warning.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
commit b71fc079b5d8f42b2a52743c8d2f1d35d655b1c5 upstream.
Code tracking when transaction needs to be committed on fdatasync(2) forgets
to handle a situation when only inode's i_size is changed. Thus in such
situations fdatasync(2) doesn't force transaction with new i_size to disk
and that can result in wrong i_size after a crash.
Fix the issue by updating inode's i_datasync_tid whenever its size is
updated.
Reported-by: Kristian Nielsen <knielsen@knielsen-hq.org>
commit 6a08f447facb4f9e29fcc30fb68060bb5a0d21c2 upstream.
ext4_special_inode_operations have their own ifdef CONFIG_EXT4_FS_XATTR
to mask those methods. And ext4_iget also always sets it, so there is
an inconsistency.
Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
commit f066055a3449f0e5b0ae4f3ceab4445bead47638 upstream.
Proper block swap for inodes with full journaling enabled is
truly non obvious task. In order to be on a safe side let's
explicitly disable it for now.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit 24ec19b0ae83a385ad9c55520716da671274b96c upstream.
In ext4_xattr_set_acl(), if ext4_journal_start() returns an error,
posix_acl_release() will not be called for 'acl' which may result in a
memory leak.
This patch fixes that.
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: Eugene Shatokhin <eugene.shatokhin@rosalab.ru>
commit f17722f917b2f21497deb6edc62fb1683daa08e6 upstream
Kazuya Mio reported that he was able to hit BUG_ON(next == lblock)
in ext4_ext_put_gap_in_cache() while creating a sparse file in extent
format and fill the tail of file up to its end. We will hit the BUG_ON
when we write the last block (2^32-1) into the sparse file.
The root cause of the problem lies in the fact that we specifically set
s_maxbytes so that block at s_maxbytes fit into on-disk extent format,
which is 32 bit long. However, we are not storing start and end block
number, but rather start block number and length in blocks. It means
that in order to cover extent from 0 to EXT_MAX_BLOCK we need
EXT_MAX_BLOCK+1 to fit into len (because we counting block 0 as well) -
and it does not.
The only way to fix it without changing the meaning of the struct
ext4_extent members is, as Kazuya Mio suggested, to lower s_maxbytes
by one fs block so we can cover the whole extent we can get by the
on-disk extent format.
Also in many places EXT_MAX_BLOCK is used as length instead of maximum
logical block number as the name suggests, it is all a bit messy. So
this commit renames it to EXT_MAX_BLOCKS and change its usage in some
places to actually be maximum number of blocks in the extent.
The bug which this commit fixes can be reproduced as follows:
dd if=/dev/zero of=/mnt/mp1/file bs=<blocksize> count=1 seek=$((2**32-2))
sync
dd if=/dev/zero of=/mnt/mp1/file bs=<blocksize> count=1 seek=$((2**32-1))
Reported-by: Kazuya Mio <k-mio@sx.jp.nec.com>
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
[dannf: Applied the backport from RHEL6 to Debian's 2.6.32]
Fix for a null pointer bug found while running punch hole tests
Signed-off-by: Allison Henderson <achender@us.ibm.com>
(cherry picked from commit 6976a6f2acde2b0443cd64f1d08af90630e4ce81)
When make_indexed_dir() fails (e.g. because of ENOSPC) after it has
allocated block for index tree root, we did not properly mark all
changed buffers dirty. This lead to only some of these buffers being
written out and thus effectively corrupting the directory.
Fix the issue by marking all changed data dirty even in the error
failure case.
(cherry picked from commit 7ad8e4e6ae2a7c95445ee1715b1714106fb95037)
commit 25389bb207987b5774182f763b9fb65ff08761c8 upstream.
Commit 09e05d48 introduced a wait for transaction commit into
journal_unmap_buffer() in the case we are truncating a buffer undergoing commit
in the page stradding i_size on a filesystem with blocksize < pagesize. Sadly
we forgot to drop buffer lock before waiting for transaction commit and thus
deadlock is possible when kjournald wants to lock the buffer.
Fix the problem by dropping the buffer lock before waiting for transaction
commit. Since we are still holding page lock (and that is OK), buffer cannot
disappear under us.
ext3 users of data=journal mode with blocksize < pagesize were occasionally
hitting assertion failure in journal_commit_transaction() checking whether the
transaction has at least as many credits reserved as buffers attached. The
core of the problem is that when a file gets truncated, buffers that still need
checkpointing or that are attached to the committing transaction are left with
buffer_mapped set. When this happens to buffers beyond i_size attached to a
page stradding i_size, subsequent write extending the file will see these
buffers and as they are mapped (but underlying blocks were freed) things go
awry from here.
The assertion failure just coincidentally (and in this case luckily as we would
start corrupting filesystem) triggers due to journal_head not being properly
cleaned up as well.
Under some rare circumstances this bug could even hit data=ordered mode users.
There the assertion won't trigger and we would end up corrupting the
filesystem.
We fix the problem by unmapping buffers if possible (in lots of cases we just
need a buffer attached to a transaction as a place holder but it must not be
written out anyway). And in one case, we just have to bite the bullet and wait
for transaction commit to finish.
Reviewed-by: Josef Bacik <jbacik@fusionio.com>
(cherry picked from commit 09e05d4805e6c524c1af74e524e5d0528bb3fef3)
Delay discarding buffers in journal_unmap_buffer until
we know that "add to orphan" operation has definitely been
committed, otherwise the log space of committing transation
may be freed and reused before truncate get committed, updates
may get lost if crash happens.
This patch is a backport of JBD2 fix by dingdinghua <dingdinghua@nrchpc.ac.cn>.
(cherry picked from commit 86963918965eb8fe0c8ae009e7c1b4c630f533d5)
commit 66081a72517a131430dcf986775f3268aafcb546 upstream.
The warning check for duplicate sysfs entries can cause a buffer overflow
when printing the warning, as strcat() doesn't check buffer sizes.
Use strlcat() instead.
Since strlcat() doesn't return a pointer to the passed buffer, unlike
strcat(), I had to convert the nested concatenation in sysfs_add_one() to
an admittedly more obscure comma operator construct, to avoid emitting code
for the concatenation if CONFIG_BUG is disabled.
commit ec686c9239b4d472052a271c505d04dae84214cc upstream.
There is a kernel memory leak observed when the proc file
/proc/fs/fscache/stats is read.
The reason is that in fscache_stats_open, single_open is called and the
respective release function is not called during release. Hence fix
with correct release function - single_release().
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=57101
Signed-off-by: Anurup m <anurup.m@huawei.com>
Cc: shyju pv <shyju.pv@huawei.com>
Cc: Sanil kumar <sanil.kumar@huawei.com>
Cc: Nataraj m <nataraj.m@huawei.com>
Cc: Li Zefan <lizefan@huawei.com>
commit 12176503366885edd542389eed3aaf94be163fdb upstream.
The compat ioctl for VIDEO_SET_SPU_PALETTE was missing an error check
while converting ioctl arguments. This could lead to leaking kernel
stack contents into userspace.
Patch extracted from existing fix in grsecurity.
Cc: Brad Spengler <spender@grsecurity.net>
Cc: PaX Team <pageexec@freemail.hu>
commit 128dd1759d96ad36c379240f8b9463e8acfd37a1 upstream.
EPOLL_CTL_MOD sets the interest mask before calling f_op->poll() to
ensure events are not missed. Since the modifications to the interest
mask are not protected by the same lock as ep_poll_callback, we need to
ensure the change is visible to other CPUs calling ep_poll_callback.
We also need to ensure f_op->poll() has an up-to-date view of past
events which occured before we modified the interest mask. So this
barrier also pairs with the barrier in wq_has_sleeper().
This should guarantee either ep_poll_callback or f_op->poll() (or both)
will notice the readiness of a recently-ready/modified item.
This issue was encountered by Andreas Voellmy and Junchang(Jason) Wang in:
http://thread.gmane.org/gmane.linux.kernel/1408782/
Signed-off-by: Eric Wong <normalperson@yhbt.net>
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Andreas Voellmy <andreas.voellmy@yale.edu>
Tested-by: "Junchang(Jason) Wang" <junchang.wang@yale.edu>
Cc: netdev@vger.kernel.org
Cc: linux-fsdevel@vger.kernel.org
[bwh: Backported to 3.2: adjust context]
commit f34f9d186df35e5c39163444c43b4fc6255e39c5 upstream.
In !CORE_DUMP_USE_REGSET case, if elf_note_info_init fails to allocate
memory for info->fields, it frees already allocated stuff and returns
error to its caller, fill_note_info. Which in turn returns error to its
caller, elf_core_dump. Which jumps to cleanup label and calls
free_note_info, which will happily try to free all info->fields again.
BOOM.
This is the fix.
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
Cc: Venu Byravarasu <vbyravarasu@nvidia.com>
commit d740269867021faf4ce38a449353d2b986c34a67 upstream
To avoid an explosion of request_module calls on a chain of abusive
scripts, fail maximum recursion with -ELOOP instead of -ENOEXEC. As soon
as maximum recursion depth is hit, the error will fail all the way back
up the chain, aborting immediately.
This also has the side-effect of stopping the user's shell from attempting
to reexecute the top-level file as a shell script. As seen in the
dash source:
if (cmd != path_bshell && errno == ENOEXEC) {
*argv-- = cmd;
*argv = cmd = path_bshell;
goto repeat;
The above logic was designed for running scripts automatically that lacked
the "#!" header, not to re-try failed recursion. On a legitimate -ENOEXEC,
things continue to behave as the shell expects.
Additionally, when tracking recursion, the binfmt handlers should not be
involved. The recursion being tracked is the depth of calls through
search_binary_handler(), so that function should be exclusively responsible
for tracking the depth.
Cc: halfdog <me@halfdog.net>
Cc: P J P <ppandit@redhat.com>
commit b66c5984017533316fd1951770302649baf1aa33 upstream
If a series of scripts are executed, each triggering module loading via
unprintable bytes in the script header, kernel stack contents can leak
into the command line.
Normally execution of binfmt_script and binfmt_misc happens recursively.
However, when modules are enabled, and unprintable bytes exist in the
bprm->buf, execution will restart after attempting to load matching
binfmt modules. Unfortunately, the logic in binfmt_script and
binfmt_misc does not expect to get restarted. They leave bprm->interp
pointing to their local stack. This means on restart bprm->interp is
left pointing into unused stack memory which can then be copied into the
userspace argv areas.
After additional study, it seems that both recursion and restart remains
the desirable way to handle exec with scripts, misc, and modules. As
such, we need to protect the changes to interp.
This changes the logic to require allocation for any changes to the
bprm->interp. To avoid adding a new kmalloc to every exec, the default
value is left as-is. Only when passing through binfmt_script or
binfmt_misc does an allocation take place.
For a proof of concept, see DoTest.sh from:
http://www.halfdog.net/Security/2012/LinuxKernelBinfmtScriptStackDataDisclosure/
Cc: <stable@vger.kernel.org>
commit 13d518074a952d33d47c428419693f63389547e9 upstream.
An epoll_ctl(,EPOLL_CTL_ADD,,) operation can return '-ELOOP' to prevent
circular epoll dependencies from being created. However, in that case we
do not properly clear the 'tfile_check_list'. Thus, add a call to
clear_tfile_check_list() for the -ELOOP case.
Signed-off-by: Jason Baron <jbaron@redhat.com>
Reported-by: Yurij M. Plotnikov <Yurij.Plotnikov@oktetlabs.ru>
Cc: Nelson Elhage <nelhage@nelhage.com>
Tested-by: Alexandra N. Kossovsky <Alexandra.Kossovsky@oktetlabs.ru>
commit 93dc6107a76daed81c07f50215fa6ae77691634f upstream.
Commit 28d82dc1c4ed ("epoll: limit paths") that I did to limit the
number of possible wakeup paths in epoll is causing a few applications
to longer work (dovecot for one).
The original patch is really about limiting the amount of epoll nesting
(since epoll fds can be attached to other fds). Thus, we probably can
allow an unlimited number of paths of depth 1. My current patch limits
it at 1000. And enforce the limits on paths that have a greater depth.
This is captured in: https://bugzilla.redhat.com/show_bug.cgi?id=681578
commit 28d82dc1c4edbc352129f97f4ca22624d1fe61de upstream.
The current epoll code can be tickled to run basically indefinitely in
both loop detection path check (on ep_insert()), and in the wakeup paths.
The programs that tickle this behavior set up deeply linked networks of
epoll file descriptors that cause the epoll algorithms to traverse them
indefinitely. A couple of these sample programs have been previously
posted in this thread: https://lkml.org/lkml/2011/2/25/297.
To fix the loop detection path check algorithms, I simply keep track of
the epoll nodes that have been already visited. Thus, the loop detection
becomes proportional to the number of epoll file descriptor and links.
This dramatically decreases the run-time of the loop check algorithm. In
one diabolical case I tried it reduced the run-time from 15 mintues (all
in kernel time) to .3 seconds.
Fixing the wakeup paths could be done at wakeup time in a similar manner
by keeping track of nodes that have already been visited, but the
complexity is harder, since there can be multiple wakeups on different
cpus...Thus, I've opted to limit the number of possible wakeup paths when
the paths are created.
This is accomplished, by noting that the end file descriptor points that
are found during the loop detection pass (from the newly added link), are
actually the sources for wakeup events. I keep a list of these file
descriptors and limit the number and length of these paths that emanate
from these 'source file descriptors'. In the current implemetation I
allow 1000 paths of length 1, 500 of length 2, 100 of length 3, 50 of
length 4 and 10 of length 5. Note that it is sufficient to check the
'source file descriptors' reachable from the newly added link, since no
other 'source file descriptors' will have newly added links. This allows
us to check only the wakeup paths that may have gotten too long, and not
re-check all possible wakeup paths on the system.
In terms of the path limit selection, I think its first worth noting that
the most common case for epoll, is probably the model where you have 1
epoll file descriptor that is monitoring n number of 'source file
descriptors'. In this case, each 'source file descriptor' has a 1 path of
length 1. Thus, I believe that the limits I'm proposing are quite
reasonable and in fact may be too generous. Thus, I'm hoping that the
proposed limits will not prevent any workloads that currently work to
fail.
In terms of locking, I have extended the use of the 'epmutex' to all
epoll_ctl add and remove operations. Currently its only used in a subset
of the add paths. I need to hold the epmutex, so that we can correctly
traverse a coherent graph, to check the number of paths. I believe that
this additional locking is probably ok, since its in the setup/teardown
paths, and doesn't affect the running paths, but it certainly is going to
add some extra overhead. Also, worth noting is that the epmuex was
recently added to the ep_ctl add operations in the initial path loop
detection code using the argument that it was not on a critical path.
Another thing to note here, is the length of epoll chains that is allowed.
Currently, eventpoll.c defines:
/* Maximum number of nesting allowed inside epoll sets */
This basically means that I am limited to a graph depth of 5 (EP_MAX_NESTS
+ 1). However, this limit is currently only enforced during the loop
check detection code, and only when the epoll file descriptors are added
in a certain order. Thus, this limit is currently easily bypassed. The
newly added check for wakeup paths, stricly limits the wakeup paths to a
length of 5, regardless of the order in which ep's are linked together.
Thus, a side-effect of the new code is a more consistent enforcement of
the graph depth.
Thus far, I've tested this, using the sample programs previously
mentioned, which now either return quickly or return -EINVAL. I've also
testing using the piptest.c epoll tester, which showed no difference in
performance. I've also created a number of different epoll networks and
tested that they behave as expectded.
I believe this solves the original diabolical test cases, while still
preserving the sane epoll nesting.
Cc: Nelson Elhage <nelhage@ksplice.com>
commit 971316f0503a5c50633d07b83b6db2f15a3a5b00 upstream.
signalfd_cleanup() ensures that ->signalfd_wqh is not used, but
this is not enough. eppoll_entry->whead still points to the memory
we are going to free, ep_unregister_pollwait()->remove_wait_queue()
is obviously unsafe.
Change ep_poll_callback(POLLFREE) to set eppoll_entry->whead = NULL,
change ep_unregister_pollwait() to check pwq->whead != NULL under
rcu_read_lock() before remove_wait_queue(). We add the new helper,
ep_remove_wait_queue(), for this.
This works because sighand_cachep is SLAB_DESTROY_BY_RCU and because
->signalfd_wqh is initialized in sighand_ctor(), not in copy_sighand.
ep_unregister_pollwait()->remove_wait_queue() can play with already
freed and potentially reused ->sighand, but this is fine. This memory
must have the valid ->signalfd_wqh until rcu_read_unlock().
Reported-by: Maxime Bizon <mbizon@freebox.fr>
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream.
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
commit 68766a2edcd5cd744262a70a2f67a320ac944760 upstream.
In case we detect a problem and bail out, we fail to set "ret" to a
nonzero value, and udf_load_logicalvol will mistakenly report success.
Signed-off-by: Nikola Pajkovsky <npajkovs@redhat.com>
commit 1df2ae31c724e57be9d7ac00d78db8a5dabdd050 upstream.
Add sanity checks when loading sparing table from disk to avoid accessing
unallocated memory or writing to it.
commit 156bddd8e505b295540f3ca0e27dda68cb0d49aa upstream.
updated.
commit 9c2fc0de1a6e638fe58c354a463f544f42a90a09 upstream.
When a file is stored in ICB (inode), we overwrite part of the file, and
the page containing file's data is not in page cache, we end up corrupting
file's data by overwriting them with zeros. The problem is we use
simple_write_begin() which simply zeroes parts of the page which are not
written to. The problem has been introduced by be021ee4 (udf: convert to
new aops).
Fix the problem by providing a ->write_begin function which makes the page
properly uptodate.
Reported-by: Ian Abbott <abbotti@mev.co.uk>
commit 425e776d93a7a5070b77d4f458a5bab0f924652c upstream.
This allows distros to remove the line from their modprobe
configuration.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 086600430493e04b802bee6e5b3ce0458e4eb77f upstream.
If the rpc call to NFS3PROC_FSINFO fails, then we need to report that
error so that the mount fails. Otherwise we can end up with a
superblock with completely unusable values for block sizes, maxfilesize,
etc.
Reported-by: Yuanming Chen <hikvision_linux@163.com>
commit 0e665d5d1125f9f4ccff56a75e814f10f88861a2 upstream.
compat_sys_{read,write}v() need the same "pass a copy of file->f_pos" thing
as sys_{read,write}{,v}().
commit fb6ccff667712c46b4501b920ea73a326e49626a upstream.
Commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 attempted to verify that
the total iovec from the client doesn't overflow iov_length() but it
only checked the first element. The iovec could still overflow by
starting with a small element. The obvious fix is to check all the
elements.
The overflow case doesn't look dangerous to the kernel as the copy is
limited by the length after the overflow. This fix restores the
intention of returning an error instead of successfully copying less
than the iovec represented.
I found this by code inspection. I built it but don't have a test case.
I'm cc:ing stable because the initial commit did as well.
Signed-off-by: Zach Brown <zab@redhat.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 97795d2a5b8d3c8dc4365d4bd3404191840453ba upstream.
If we hit a condition where we have allocated metadata blocks that
were not appropriately reserved, we risk underflow of
ei->i_reserved_meta_blocks. In turn, this can throw
sbi->s_dirtyclusters_counter significantly out of whack and undermine
the nondelalloc fallback logic in ext4_nonda_switch(). Warn if this
occurs and set i_allocated_meta_blocks to avoid this problem.
This condition is reproduced by xfstests 270 against ext2 with
delalloc enabled:
Mar 28 08:58:02 localhost kernel: [ 171.526344] EXT4-fs (loop1): delayed block allocation failed for inode 14 at logical offset 64486 with max blocks 64 with error -28
Mar 28 08:58:02 localhost kernel: [ 171.526346] EXT4-fs (loop1): This should not happen!! Data will be lost
270 ultimately fails with an inconsistent filesystem and requires an
fsck to repair. The cause of the error is an underflow in
ext4_da_update_reserve_space() due to an unreserved meta block
allocation.
Signed-off-by: Brian Foster <bfoster@redhat.com>
